commit f2e717d655040d632c9015f19aa4275f8b16e7f2 upstream.
RFC3530 notes that the 'dircount' field may be zero, in which case the
recommendation is to ignore it, and only enforce the 'maxcount' field.
In RFC5661, this recommendation to ignore a zero valued field becomes a
requirement.
Fixes: aee377644146 ("nfsd4: fix rd_dircount enforcement")
Cc: <stable@vger.kernel.org>
Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com>
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
[ Upstream commit 372d1f3e1bfede719864d0d1fbf3146b1e638c88 ]
The ext2_error() function syncs the filesystem so it sleeps. The caller
is holding a spinlock so it's not allowed to sleep.
ext2_statfs() <- disables preempt
-> ext2_count_free_blocks()
-> ext2_get_group_desc()
Fix this by using WARN() to print an error message and a stack trace
instead of using ext2_error().
Link: https://lore.kernel.org/r/20210921203233.GA16529@kili
commit 42cb447410d024e9d54139ae9c21ea132a8c384c upstream.
When ext4_htree_fill_tree() fails, ext4_dx_readdir() can run into an
infinite loop since if info->last_pos != ctx->pos this will reset the
directory scan and reread the failing entry. For example:
1. a dx_dir which has 3 block, block 0 as dx_root block, block 1/2 as
leaf block which own the ext4_dir_entry_2
2. block 1 read ok and call_filldir which will fill the dirent and update
the ctx->pos
3. block 2 read fail, but we has already fill some dirent, so we will
return back to userspace will a positive return val(see ksys_getdents64)
4. the second ext4_dx_readdir will reset the world since info->last_pos
!= ctx->pos, and will also init the curr_hash which pos to block 1
5. So we will read block1 too, and once block2 still read fail, we can
only fill one dirent because the hash of the entry in block1(besides
the last one) won't greater than curr_hash
6. this time, we forget update last_pos too since the read for block2
will fail, and since we has got the one entry, ksys_getdents64 can
return success
7. Latter we will trapped in a loop with step 4~6
Cc: stable@kernel.org
Signed-off-by: yangerkun <yangerkun@huawei.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Link: https://lore.kernel.org/r/20210914111415.3921954-1-yangerkun@huawei.com
commit d5f6545934c47e97c0b48a645418e877b452a992 upstream.
In commit b7213ffa0e58 ("qnx4: avoid stringop-overread errors") I tried
to teach gcc about how the directory entry structure can be two
different things depending on a status flag. It made the code clearer,
and it seemed to make gcc happy.
However, Arnd points to a gcc bug, where despite using two different
members of a union, gcc then gets confused, and uses the size of one of
the members to decide if a string overrun happens. And not necessarily
the rigth one.
End result: with some configurations, gcc-11 will still complain about
the source buffer size being overread:
fs/qnx4/dir.c: In function 'qnx4_readdir':
fs/qnx4/dir.c:76:32: error: 'strnlen' specified bound [16, 48] exceeds source size 1 [-Werror=stringop-overread]
76 | size = strnlen(name, size);
fs/qnx4/dir.c:26:22: note: source object declared here
26 | char de_name;
because gcc will get confused about which union member entry is actually
getting accessed, even when the source code is very clear about it. Gcc
internally will have combined two "redundant" pointers (pointing to
different union elements that are at the same offset), and takes the
size checking from one or the other - not necessarily the right one.
This is clearly a gcc bug, but we can work around it fairly easily. The
biggest thing here is the big honking comment about why we do what we
do.
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=99578#c6
Reported-and-tested-by: Arnd Bergmann <arnd@kernel.org>
[ Upstream commit b7213ffa0e585feb1aee3e7173e965e66ee0abaa ]
The qnx4 directory entries are 64-byte blocks that have different
contents depending on the a status byte that is in the last byte of the
block.
In particular, a directory entry can be either a "link info" entry with
a 48-byte name and pointers to the real inode information, or an "inode
entry" with a smaller 16-byte name and the full inode information.
But the code was written to always just treat the directory name as if
it was part of that "inode entry", and just extend the name to the
longer case if the status byte said it was a link entry.
That work just fine and gives the right results, but now that gcc is
tracking data structure accesses much more, the code can trigger a
compiler error about using up to 48 bytes (the long name) in a structure
that only has that shorter name in it:
fs/qnx4/dir.c: In function ‘qnx4_readdir’:
fs/qnx4/dir.c:51:32: error: ‘strnlen’ specified bound 48 exceeds source size 16 [-Werror=stringop-overread]
51 | size = strnlen(de->di_fname, size);
In file included from fs/qnx4/qnx4.h:3,
from fs/qnx4/dir.c:16:
include/uapi/linux/qnx4_fs.h:45:25: note: source object declared here
45 | char di_fname[QNX4_SHORT_NAME_MAX];
which is because the source code doesn't really make this whole "one of
two different types" explicit.
Fix this by introducing a very explicit union of the two types, and
basically explaining to the compiler what is really going on.
commit 9ed38fd4a15417cac83967360cf20b853bfab9b6 upstream.
Although very unlikely that the tlink pointer would be null in this case,
get_next_mid function can in theory return null (but not an error)
so need to check for null (not for IS_ERR, which can not be returned
here).
Address warning:
fs/smbfs_client/connect.c:2392 cifs_match_super()
warn: 'tlink' isn't an ERR_PTR
Pointed out by Dan Carpenter via smatch code analysis tool
CC: stable@vger.kernel.org
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Acked-by: Ronnie Sahlberg <lsahlber@redhat.com>
Signed-off-by: Steve French <stfrench@microsoft.com>
[ Upstream commit 17243e1c3072b8417a5ebfc53065d0a87af7ca77 ]
kobject_put() should be used to cleanup the memory associated with the
kobject instead of kobject_del(). See the section "Kobject removal" of
"Documentation/core-api/kobject.rst".
Link: https://lkml.kernel.org/r/20210629022556.3985106-7-sunnanyong@huawei.com
Link: https://lkml.kernel.org/r/1625651306-10829-7-git-send-email-konishi.ryusuke@gmail.com
Signed-off-by: Nanyong Sun <sunnanyong@huawei.com>
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@gmail.com>
[ Upstream commit b2fe39c248f3fa4bbb2a20759b4fdd83504190f7 ]
If kobject_init_and_add returns with error, kobject_put() is needed here
to avoid memory leak, because kobject_init_and_add may return error
without freeing the memory associated with the kobject it allocated.
Link: https://lkml.kernel.org/r/20210629022556.3985106-6-sunnanyong@huawei.com
Link: https://lkml.kernel.org/r/1625651306-10829-6-git-send-email-konishi.ryusuke@gmail.com
[ Upstream commit a3e181259ddd61fd378390977a1e4e2316853afa ]
The kobject_put() should be used to cleanup the memory associated with the
kobject instead of kobject_del. See the section "Kobject removal" of
Link: https://lkml.kernel.org/r/20210629022556.3985106-5-sunnanyong@huawei.com
Link: https://lkml.kernel.org/r/1625651306-10829-5-git-send-email-konishi.ryusuke@gmail.com
[ Upstream commit 24f8cb1ed057c840728167dab33b32e44147c86f ]
If kobject_init_and_add return with error, kobject_put() is needed here to
avoid memory leak, because kobject_init_and_add may return error without
Link: https://lkml.kernel.org/r/20210629022556.3985106-4-sunnanyong@huawei.com
Link: https://lkml.kernel.org/r/1625651306-10829-4-git-send-email-konishi.ryusuke@gmail.com
[ Upstream commit dbc6e7d44a514f231a64d9d5676e001b660b6448 ]
In nilfs_##name##_attr_release, kobj->parent should not be referenced
because it is a NULL pointer. The release() method of kobject is always
called in kobject_put(kobj), in the implementation of kobject_put(), the
kobj->parent will be assigned as NULL before call the release() method.
So just use kobj to get the subgroups, which is more efficient and can fix
a NULL pointer reference problem.
Link: https://lkml.kernel.org/r/20210629022556.3985106-3-sunnanyong@huawei.com
Link: https://lkml.kernel.org/r/1625651306-10829-3-git-send-email-konishi.ryusuke@gmail.com
[ Upstream commit 5f5dec07aca7067216ed4c1342e464e7307a9197 ]
Patch series "nilfs2: fix incorrect usage of kobject".
This patchset from Nanyong Sun fixes memory leak issues and a NULL
pointer dereference issue caused by incorrect usage of kboject in nilfs2
sysfs implementation.
This patch (of 6):
Reported by syzkaller:
BUG: memory leak
unreferenced object 0xffff888100ca8988 (size 8):
comm "syz-executor.1", pid 1930, jiffies 4294745569 (age 18.052s)
hex dump (first 8 bytes):
6c 6f 6f 70 31 00 ff ff loop1...
backtrace:
kstrdup+0x36/0x70 mm/util.c:60
kstrdup_const+0x35/0x60 mm/util.c:83
kvasprintf_const+0xf1/0x180 lib/kasprintf.c:48
kobject_set_name_vargs+0x56/0x150 lib/kobject.c:289
kobject_add_varg lib/kobject.c:384 [inline]
kobject_init_and_add+0xc9/0x150 lib/kobject.c:473
nilfs_sysfs_create_device_group+0x150/0x7d0 fs/nilfs2/sysfs.c:986
init_nilfs+0xa21/0xea0 fs/nilfs2/the_nilfs.c:637
nilfs_fill_super fs/nilfs2/super.c:1046 [inline]
nilfs_mount+0x7b4/0xe80 fs/nilfs2/super.c:1316
legacy_get_tree+0x105/0x210 fs/fs_context.c:592
vfs_get_tree+0x8e/0x2d0 fs/super.c:1498
do_new_mount fs/namespace.c:2905 [inline]
path_mount+0xf9b/0x1990 fs/namespace.c:3235
do_mount+0xea/0x100 fs/namespace.c:3248
__do_sys_mount fs/namespace.c:3456 [inline]
__se_sys_mount fs/namespace.c:3433 [inline]
__x64_sys_mount+0x14b/0x1f0 fs/namespace.c:3433
do_syscall_x64 arch/x86/entry/common.c:50 [inline]
do_syscall_64+0x3b/0x90 arch/x86/entry/common.c:80
entry_SYSCALL_64_after_hwframe+0x44/0xae
If kobject_init_and_add return with error, then the cleanup of kobject
is needed because memory may be allocated in kobject_init_and_add
without freeing.
And the place of cleanup_dev_kobject should use kobject_put to free the
memory associated with the kobject. As the section "Kobject removal" of
"Documentation/core-api/kobject.rst" says, kobject_del() just makes the
kobject "invisible", but it is not cleaned up. And no more cleanup will
do after cleanup_dev_kobject, so kobject_put is needed here.
Link: https://lkml.kernel.org/r/1625651306-10829-1-git-send-email-konishi.ryusuke@gmail.com
Link: https://lkml.kernel.org/r/1625651306-10829-2-git-send-email-konishi.ryusuke@gmail.com
Link: https://lkml.kernel.org/r/20210629022556.3985106-2-sunnanyong@huawei.com
[ Upstream commit 3eaf5aa1cfa8c97c72f5824e2e9263d6cc977b03 ]
Signed-off-by: Jeff Layton <jlayton@kernel.org>
Reviewed-by: Ilya Dryomov <idryomov@gmail.com>
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
[ Upstream commit d72c74197b70bc3c95152f351a568007bffa3e11 ]
smb_buf is allocated by small_smb_init_no_tc(), and buf type is
CIFS_SMALL_BUFFER, so we should use cifs_small_buf_release() to
release it in failed path.
Signed-off-by: Ding Hui <dinghui@sangfor.com.cn>
Reviewed-by: Paulo Alcantara (SUSE) <pc@cjr.nz>
[ Upstream commit d1340f80f0b8066321b499a376780da00560e857 ]
In the gfs2 withdraw sequence, the dlm protocol is unmounted with a call
to lm_unmount. After a withdraw, users are allowed to unmount the
withdrawn file system. But at that point we may still have glocks left
over that we need to free via unmount's call to gfs2_gl_hash_clear.
These glocks may have never been completed because of whatever problem
caused the withdraw (IO errors or whatever).
Before this patch, function gdlm_put_lock would still try to call into
dlm to unlock these leftover glocks, which resulted in dlm returning
-EINVAL because the lock space was abandoned. These glocks were never
freed because there was no mechanism after that to free them.
This patch adds a check to gdlm_put_lock to see if the locking protocol
was inactive (DFL_UNMOUNT flag) and if so, free the glock and not
make the invalid call into dlm.
I could have combined this "if" with the one that follows, related to
leftover glock LVBs, but I felt the code was more readable with its own
if clause.
Signed-off-by: Bob Peterson <rpeterso@redhat.com>
[ Upstream commit f980d055a0f858d73d9467bb0b570721bbfcdfb8 ]
strlcpy() reads the entire source buffer first. This read may exceed the
destination size limit. This is both inefficient and can lead to linear
read overflows if a source string is not NUL-terminated.
Also, the strnlen() call does not avoid the read overflow in the strlcpy
function when a not NUL-terminated string is passed.
So, replace this block by a call to kstrndup() that avoids this type of
overflow and does the same.
Fixes: 066ce6899484d ("cifs: rename cifs_strlcpy_to_host and make it use new functions")
Signed-off-by: Len Baker <len.baker@gmx.com>
Reviewed-by: Jeff Layton <jlayton@kernel.org>
[ Upstream commit 58bc6d1be2f3b0ceecb6027dfa17513ec6aa2abb ]
When parsing the ExtendedAttr data, malicous or corrupt attribute length
could cause kernel hangs and buffer overruns in some special cases.
Link: https://lore.kernel.org/r/20210822093332.25234-1-stian.skjelstad@gmail.com
Signed-off-by: Stian Skjelstad <stian.skjelstad@gmail.com>
commit 4e9655763b82a91e4c341835bb504a2b1590f984 upstream.
This reverts commit f2165627319ffd33a6217275e5690b1ab5c45763.
[BUG]
It's no longer possible to create compressed inline extent after commit
f2165627319f ("btrfs: compression: don't try to compress if we don't
have enough pages").
[CAUSE]
For compression code, there are several possible reasons we have a range
that needs to be compressed while it's no more than one page.
- Compressed inline write
The data is always smaller than one sector and the test lacks the
condition to properly recognize a non-inline extent.
- Compressed subpage write
For the incoming subpage compressed write support, we require page
alignment of the delalloc range.
And for 64K page size, we can compress just one page into smaller
sectors.
For those reasons, the requirement for the data to be more than one page
is not correct, and is already causing regression for compressed inline
data writeback. The idea of skipping one page to avoid wasting CPU time
could be revisited in the future.
[FIX]
Fix it by reverting the offending commit.
Reported-by: Zygo Blaxell <ce3g8jdj@umail.furryterror.org>
Link: https://lore.kernel.org/linux-btrfs/afa2742.c084f5d6.17b6b08dffc@tnonline.net
Fixes: f2165627319f ("btrfs: compression: don't try to compress if we don't have enough pages")
CC: stable@vger.kernel.org # 4.4+
Signed-off-by: Qu Wenruo <wqu@suse.com>
Reviewed-by: David Sterba <dsterba@suse.com>
Signed-off-by: David Sterba <dsterba@suse.com>
commit a54c4613dac1500b40e4ab55199f7c51f028e848 upstream.
The location of the system.data extended attribute can change whenever
xattr_sem is not taken. So we need to recalculate the i_inline_off
field since it mgiht have changed between ext4_write_begin() and
ext4_write_end().
This means that caching i_inline_off is probably not helpful, so in
the long run we should probably get rid of it and shrink the in-memory
ext4 inode slightly, but let's fix the race the simple way for now.
Fixes: f19d5870cbf72 ("ext4: add normal write support for inline data")
Reported-by: syzbot+13146364637c7363a7de@syzkaller.appspotmail.com
commit 427215d85e8d1476da1a86b8d67aceb485eb3631 upstream.
Add the following checks from __do_loopback() to clone_private_mount() as
well:
- verify that the mount is in the current namespace
- verify that there are no locked children
Reported-by: Alois Wohlschlager <alois1@gmx-topmail.de>
Fixes: c771d683a62e ("vfs: introduce clone_private_mount()")
Cc: <stable@vger.kernel.org> # v3.18
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
commit 46c4c9d1beb7f5b4cec4dd90e7728720583ee348 upstream.
This program always prints 4096 and hangs before the patch, and always
prints 8192 and exits successfully after:
int main()
int pipefd[2];
for (int i = 0; i < 1025; i++)
if (pipe(pipefd) == -1)
return 1;
size_t bufsz = fcntl(pipefd[1], F_GETPIPE_SZ);
printf("%zd\n", bufsz);
char *buf = calloc(bufsz, 1);
write(pipefd[1], buf, bufsz);
read(pipefd[0], buf, bufsz-1);
write(pipefd[1], buf, 1);
Note that you may need to increase your RLIMIT_NOFILE before running the
program.
Fixes: 759c01142a ("pipe: limit the per-user amount of pages allocated in pipes")
Link: https://lore.kernel.org/lkml/1628086770.5rn8p04n6j.none@localhost/
Link: https://lore.kernel.org/lkml/1628127094.lxxn016tj7.none@localhost/
Signed-off-by: Alex Xu (Hello71) <alex_y_xu@yahoo.ca>
[ Upstream commit 13d257503c0930010ef9eed78b689cec417ab741 ]
While verifying the leaf item that we read from the disk, reiserfs
doesn't check the directory items, this could cause a crash when we
read a directory item from the disk that has an invalid deh_location.
This patch adds a check to the directory items read from the disk that
does a bounds check on deh_location for the directory entries. Any
directory entry header with a directory entry offset greater than the
item length is considered invalid.
Link: https://lore.kernel.org/r/20210709152929.766363-1-chouhan.shreyansh630@gmail.com
Reported-by: syzbot+c31a48e6702ccb3d64c9@syzkaller.appspotmail.com
Signed-off-by: Shreyansh Chouhan <chouhan.shreyansh630@gmail.com>
[ Upstream commit 2acf15b94d5b8ea8392c4b6753a6ffac3135cd78 ]
Our syzcaller report a NULL pointer dereference:
BUG: kernel NULL pointer dereference, address: 0000000000000000
PGD 116e95067 P4D 116e95067 PUD 1080b5067 PMD 0
Oops: 0010 [#1] SMP KASAN
CPU: 7 PID: 592 Comm: a.out Not tainted 5.13.0-next-20210629-dirty #67
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS ?-20190727_073836-buildvm-p4
RIP: 0010:0x0
Code: Unable to access opcode bytes at RIP 0xffffffffffffffd6.
RSP: 0018:ffff888114e779b8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: 1ffff110229cef39 RCX: ffffffffaa67e1aa
RDX: 0000000000000000 RSI: ffff88810a58ee00 RDI: ffff8881233180b0
RBP: ffffffffac38e9c0 R08: ffffffffaa67e17e R09: 0000000000000001
R10: ffffffffb91c5557 R11: fffffbfff7238aaa R12: ffff88810a58ee00
R13: ffff888114e77aa0 R14: 0000000000000000 R15: ffff8881233180b0
FS: 00007f946163c480(0000) GS:ffff88839f1c0000(0000) knlGS:0000000000000000
CR2: ffffffffffffffd6 CR3: 00000001099c1000 CR4: 00000000000006e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
__lookup_slow+0x116/0x2d0
? page_put_link+0x120/0x120
? __d_lookup+0xfc/0x320
? d_lookup+0x49/0x90
lookup_one_len+0x13c/0x170
? __lookup_slow+0x2d0/0x2d0
? reiserfs_schedule_old_flush+0x31/0x130
reiserfs_lookup_privroot+0x64/0x150
reiserfs_fill_super+0x158c/0x1b90
? finish_unfinished+0xb10/0xb10
? bprintf+0xe0/0xe0
? __mutex_lock_slowpath+0x30/0x30
? __kasan_check_write+0x20/0x30
? up_write+0x51/0xb0
? set_blocksize+0x9f/0x1f0
mount_bdev+0x27c/0x2d0
? reiserfs_kill_sb+0x120/0x120
get_super_block+0x19/0x30
legacy_get_tree+0x76/0xf0
vfs_get_tree+0x49/0x160
? capable+0x1d/0x30
path_mount+0xacc/0x1380
? putname+0x97/0xd0
? finish_automount+0x450/0x450
? kmem_cache_free+0xf8/0x5a0
? putname+0x97/0xd0
do_mount+0xe2/0x110
? path_mount+0x1380/0x1380
? copy_mount_options+0x69/0x140
__x64_sys_mount+0xf0/0x190
do_syscall_64+0x35/0x80
This is because 'root_inode' is initialized with wrong mode, and
it's i_op is set to 'reiserfs_special_inode_operations'. Thus add
check for 'root_inode' to fix the problem.
Link: https://lore.kernel.org/r/20210702040743.1918552-1-yukuai3@huawei.com
Signed-off-by: Yu Kuai <yukuai3@huawei.com>
[ Upstream commit 240246f6b913b0c23733cfd2def1d283f8cc9bbe ]
In compression write endio sequence, the range which the compressed_bio
writes is marked as uptodate if the last bio of the compressed (sub)bios
is completed successfully. There could be previous bio which may
have failed which is recorded in cb->errors.
Set the writeback range as uptodate only if cb->errors is zero, as opposed
to checking only the last bio's status.
Backporting notes: in all versions up to 4.4 the last argument is always
replaced by "!cb->errors".
Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.com>
commit 9449ad33be8480f538b11a593e2dda2fb33ca06d upstream.
For punch holes in EOF blocks, fallocate used buffer write to zero the
EOF blocks in last cluster. But since ->writepage will ignore EOF
pages, those zeros will not be flushed.
This "looks" ok as commit 6bba4471f0cc ("ocfs2: fix data corruption by
fallocate") will zero the EOF blocks when extend the file size, but it
isn't. The problem happened on those EOF pages, before writeback, those
pages had DIRTY flag set and all buffer_head in them also had DIRTY flag
set, when writeback run by write_cache_pages(), DIRTY flag on the page
was cleared, but DIRTY flag on the buffer_head not.
When next write happened to those EOF pages, since buffer_head already
had DIRTY flag set, it would not mark page DIRTY again. That made
writeback ignore them forever. That will cause data corruption. Even
directio write can't work because it will fail when trying to drop pages
caches before direct io, as it found the buffer_head for those pages
still had DIRTY flag set, then it will fall back to buffer io mode.
To make a summary of the issue, as writeback ingores EOF pages, once any
EOF page is generated, any write to it will only go to the page cache,
it will never be flushed to disk even file size extends and that page is
not EOF page any more. The fix is to avoid zero EOF blocks with buffer
write.
The following code snippet from qemu-img could trigger the corruption.
656 open("6b3711ae-3306-4bdd-823c-cf1c0060a095.conv.2", O_RDWR|O_DIRECT|O_CLOEXEC) = 11
660 fallocate(11, FALLOC_FL_KEEP_SIZE|FALLOC_FL_PUNCH_HOLE, 2275868672, 327680 <unfinished ...>
660 fallocate(11, 0, 2275868672, 327680) = 0
658 pwrite64(11, "
Link: https://lkml.kernel.org/r/20210722054923.24389-2-junxiao.bi@oracle.com
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
Reviewed-by: Joseph Qi <joseph.qi@linux.alibaba.com>
Cc: Mark Fasheh <mark@fasheh.com>
Cc: Changwei Ge <gechangwei@live.cn>
Cc: Gang He <ghe@suse.com>
Cc: Jun Piao <piaojun@huawei.com>
commit f267aeb6dea5e468793e5b8eb6a9c72c0020d418 upstream.
If append-dio feature is enabled, direct-io write and fallocate could
run in parallel to extend file size, fallocate used "orig_isize" to
record i_size before taking "ip_alloc_sem", when
ocfs2_zeroout_partial_cluster() zeroout EOF blocks, i_size maybe already
extended by ocfs2_dio_end_io_write(), that will cause valid data zeroed
out.
Link: https://lkml.kernel.org/r/20210722054923.24389-1-junxiao.bi@oracle.com
Fixes: 6bba4471f0cc ("ocfs2: fix data corruption by fallocate")
[ Upstream commit b3b2177a2d795e35dc11597b2609eb1e7e57e570 ]
Syzbot reports a possible recursive lock in [1].
This happens due to missing lock nesting information. From the logs, we
see that a call to hfs_fill_super is made to mount the hfs filesystem.
While searching for the root inode, the lock on the catalog btree is
grabbed. Then, when the parent of the root isn't found, a call to
__hfs_bnode_create is made to create the parent of the root. This
eventually leads to a call to hfs_ext_read_extent which grabs a lock on
the extents btree.
Since the order of locking is catalog btree -> extents btree, this lock
hierarchy does not lead to a deadlock.
To tell lockdep that this locking is safe, we add nesting notation to
distinguish between catalog btrees, extents btrees, and attributes
btrees (for HFS+). This has already been done in hfsplus.
Link: https://syzkaller.appspot.com/bug?id=f007ef1d7a31a469e3be7aeb0fde0769b18585db [1]
Link: https://lkml.kernel.org/r/20210701030756.58760-4-desmondcheongzx@gmail.com
Signed-off-by: Desmond Cheong Zhi Xi <desmondcheongzx@gmail.com>
Reported-by: syzbot+b718ec84a87b7e73ade4@syzkaller.appspotmail.com
Tested-by: syzbot+b718ec84a87b7e73ade4@syzkaller.appspotmail.com
Reviewed-by: Viacheslav Dubeyko <slava@dubeyko.com>
Cc: Gustavo A. R. Silva <gustavoars@kernel.org>
Cc: Shuah Khan <skhan@linuxfoundation.org>
[ Upstream commit 54a5ead6f5e2b47131a7385d0c0af18e7b89cb02 ]
Pages that we read in hfs_bnode_read need to be kmapped into kernel
address space. However, currently only the 0th page is kmapped. If the
given offset + length exceeds this 0th page, then we have an invalid
memory access.
To fix this, we kmap relevant pages one by one and copy their relevant
portions of data.
An example of invalid memory access occurring without this fix can be seen
in the following crash report:
BUG: KASAN: use-after-free in memcpy include/linux/fortify-string.h:191 [inline]
BUG: KASAN: use-after-free in hfs_bnode_read+0xc4/0xe0 fs/hfs/bnode.c:26
Read of size 2 at addr ffff888125fdcffe by task syz-executor5/4634
CPU: 0 PID: 4634 Comm: syz-executor5 Not tainted 5.13.0-syzkaller #0
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:79 [inline]
dump_stack+0x195/0x1f8 lib/dump_stack.c:120
print_address_description.constprop.0+0x1d/0x110 mm/kasan/report.c:233
__kasan_report mm/kasan/report.c:419 [inline]
kasan_report.cold+0x7b/0xd4 mm/kasan/report.c:436
check_region_inline mm/kasan/generic.c:180 [inline]
kasan_check_range+0x154/0x1b0 mm/kasan/generic.c:186
memcpy+0x24/0x60 mm/kasan/shadow.c:65
hfs_bnode_read_u16 fs/hfs/bnode.c:34 [inline]
hfs_bnode_find+0x880/0xcc0 fs/hfs/bnode.c:365
hfs_brec_find+0x2d8/0x540 fs/hfs/bfind.c:126
hfs_brec_read+0x27/0x120 fs/hfs/bfind.c:165
hfs_cat_find_brec+0x19a/0x3b0 fs/hfs/catalog.c:194
hfs_fill_super+0xc13/0x1460 fs/hfs/super.c:419
mount_bdev+0x331/0x3f0 fs/super.c:1368
hfs_mount+0x35/0x40 fs/hfs/super.c:457
legacy_get_tree+0x10c/0x220 fs/fs_context.c:592
vfs_get_tree+0x93/0x300 fs/super.c:1498
path_mount+0x13f5/0x20e0 fs/namespace.c:3235
do_mount fs/namespace.c:3248 [inline]
__x64_sys_mount+0x2b8/0x340 fs/namespace.c:3433
do_syscall_64+0x37/0xc0 arch/x86/entry/common.c:47
RIP: 0033:0x45e63a
Code: 48 c7 c2 bc ff ff ff f7 d8 64 89 02 b8 ff ff ff ff eb d2 e8 88 04 00 00 0f 1f 84 00 00 00 00 00 49 89 ca b8 a5 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 c7 c1 bc ff ff ff f7 d8 64 89 01 48
RSP: 002b:00007f9404d410d8 EFLAGS: 00000246 ORIG_RAX: 00000000000000a5
RAX: ffffffffffffffda RBX: 0000000020000248 RCX: 000000000045e63a
RDX: 0000000020000000 RSI: 0000000020000100 RDI: 00007f9404d41120
RBP: 00007f9404d41120 R08: 00000000200002c0 R09: 0000000020000000
R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000003
R13: 0000000000000003 R14: 00000000004ad5d8 R15: 0000000000000000
The buggy address belongs to the page:
page:00000000dadbcf3e refcount:0 mapcount:0 mapping:0000000000000000 index:0x1 pfn:0x125fdc
flags: 0x2fffc0000000000(node=0|zone=2|lastcpupid=0x3fff)
raw: 02fffc0000000000 ffffea000497f748 ffffea000497f6c8 0000000000000000
raw: 0000000000000001 0000000000000000 00000000ffffffff 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff888125fdce80: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
ffff888125fdcf00: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
>ffff888125fdcf80: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
ffff888125fdd000: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
ffff888125fdd080: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Link: https://lkml.kernel.org/r/20210701030756.58760-3-desmondcheongzx@gmail.com
[ Upstream commit 16ee572eaf0d09daa4c8a755fdb71e40dbf8562d ]
Patch series "hfs: fix various errors", v2.
This series ultimately aims to address a lockdep warning in
hfs_find_init reported by Syzbot [1].
The work done for this led to the discovery of another bug, and the
Syzkaller repro test also reveals an invalid memory access error after
clearing the lockdep warning. Hence, this series is broken up into
three patches:
1. Add a missing call to hfs_find_exit for an error path in
hfs_fill_super
2. Fix memory mapping in hfs_bnode_read by fixing calls to kmap
3. Add lock nesting notation to tell lockdep that the observed locking
hierarchy is safe
This patch (of 3):
Before exiting hfs_fill_super, the struct hfs_find_data used in
hfs_find_init should be passed to hfs_find_exit to be cleaned up, and to
release the lock held on the btree.
The call to hfs_find_exit is missing from an error path. We add it back
in by consolidating calls to hfs_find_exit for error paths.
Link: https://lkml.kernel.org/r/20210701030756.58760-1-desmondcheongzx@gmail.com
Link: https://lkml.kernel.org/r/20210701030756.58760-2-desmondcheongzx@gmail.com
commit f2165627319ffd33a6217275e5690b1ab5c45763 upstream
The early check if we should attempt compression does not take into
account the number of input pages. It can happen that there's only one
page, eg. a tail page after some ranges of the BTRFS_MAX_UNCOMPRESSED
have been processed, or an isolated page that won't be converted to an
inline extent.
The single page would be compressed but a later check would drop it
again because the result size must be at least one block shorter than
the input. That can never work with just one page.
[sudip: adjust context]
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
[ Upstream commit d238692b4b9f2c36e35af4c6e6f6da36184aeb3e ]
Use size_t when capping the count argument received by mem_rw(). Since
count is size_t, using min_t(int, ...) can lead to a negative value
that will later be passed to access_remote_vm(), which can cause
unexpected behavior.
Since we are capping the value to at maximum PAGE_SIZE, the conversion
from size_t to int when passing it to access_remote_vm() as "len"
shouldn't be a problem.
Link: https://lkml.kernel.org/r/20210512125215.3348316-1-marcelo.cerri@canonical.com
Reviewed-by: David Disseldorp <ddiss@suse.de>
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@canonical.com>
Signed-off-by: Marcelo Henrique Cerri <marcelo.cerri@canonical.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Souza Cascardo <cascardo@canonical.com>
Cc: Christian Brauner <christian.brauner@ubuntu.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Helge Deller <deller@gmx.de>
Cc: Lorenzo Stoakes <lstoakes@gmail.com>
commit 8cae8cd89f05f6de223d63e6d15e31c8ba9cf53b upstream.
There is no reasonable need for a buffer larger than this, and it avoids
int overflow pitfalls.
Fixes: 058504edd026 ("fs/seq_file: fallback to vmalloc allocation")
Suggested-by: Al Viro <viro@zeniv.linux.org.uk>
Reported-by: Qualys Security Advisory <qsa@qualys.com>
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
[ Upstream commit 1fcb6fcd74a222d9ead54d405842fc763bb86262 ]
When looking into another nfs xfstests report, I found acl and
default_acl in nfs3_proc_create() and nfs3_proc_mknod() error
paths are possibly leaked. Fix them in advance.
Fixes: 013cdf1088d7 ("nfs: use generic posix ACL infrastructure for v3 Posix ACLs")
Cc: Trond Myklebust <trond.myklebust@hammerspace.com>
Cc: Anna Schumaker <anna.schumaker@netapp.com>
Cc: Joseph Qi <joseph.qi@linux.alibaba.com>
Signed-off-by: Gao Xiang <hsiangkao@linux.alibaba.com>
[ Upstream commit 22d41cdcd3cfd467a4af074165357fcbea1c37f5 ]
The checks for page->mapping are odd, as set_page_dirty is an
address_space operation, and I don't see where it would be called on a
non-pagecache page.
The warning about the page lock also seems bogus. The comment over
set_page_dirty() says that it can be called without the page lock in
some rare cases. I don't think we want to warn if that's the case.
Reported-by: Matthew Wilcox <willy@infradead.org>
[ Upstream commit 492109333c29e1bb16d8732e1d597b02e8e0bf2e ]
The error code is missing in this code scenario, add the error code
'-EINVAL' to the return value 'rc.
Eliminate the follow smatch warning:
fs/jfs/jfs_logmgr.c:1327 lmLogInit() warn: missing error code 'rc'.
Reported-by: Abaci Robot <abaci@linux.alibaba.com>
Signed-off-by: Jiapeng Chong <jiapeng.chong@linux.alibaba.com>
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
commit 9d574f985fe33efd6911f4d752de6f485a1ea732 upstream.
Avoid passing inode with
JFS_SBI(inode->i_sb)->ipimap == NULL to
diFree()[1]. GFP will appear:
struct inode *ipimap = JFS_SBI(ip->i_sb)->ipimap;
struct inomap *imap = JFS_IP(ipimap)->i_imap;
JFS_IP() will return invalid pointer when ipimap == NULL
Call Trace:
diFree+0x13d/0x2dc0 fs/jfs/jfs_imap.c:853 [1]
jfs_evict_inode+0x2c9/0x370 fs/jfs/inode.c:154
evict+0x2ed/0x750 fs/inode.c:578
iput_final fs/inode.c:1654 [inline]
iput.part.0+0x3fe/0x820 fs/inode.c:1680
iput+0x58/0x70 fs/inode.c:1670
Reported-and-tested-by: syzbot+0a89a7b56db04c21a656@syzkaller.appspotmail.com
Signed-off-by: Pavel Skripkin <paskripkin@gmail.com>
commit 49221cf86d18bb66fe95d3338cb33bd4b9880ca5 upstream.
Don't allow userspace to report errors that could be kernel-internal.
Reported-by: Anatoly Trosinenko <anatoly.trosinenko@gmail.com>
Fixes: 334f485df85a ("[PATCH] FUSE - device functions")
Cc: <stable@vger.kernel.org> # v2.6.14
[ Upstream commit fa236c2b2d4436d9f19ee4e5d5924e90ffd7bb43 ]
In function udf_symlink, epos.bh is assigned with the value returned
by udf_tgetblk. The function udf_tgetblk is defined in udf/misc.c
and returns the value of sb_getblk function that could be NULL.
Then, epos.bh is used without any check, causing a possible
NULL pointer dereference when sb_getblk fails.
This fix adds a check to validate the value of epos.bh.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=213083
Signed-off-by: Arturo Giusti <koredump@protonmail.com>
[ Upstream commit a149127be52fa7eaf5b3681a0317a2bbb772d5a9 ]
syzbot reported divide error in reiserfs.
The problem was in incorrect journal 1st block.
Syzbot's reproducer manualy generated wrong superblock
with incorrect 1st block. In journal_init() wasn't
any checks about this particular case.
For example, if 1st journal block is before superblock
1st block, it can cause zeroing important superblock members
in do_journal_end().
Link: https://lore.kernel.org/r/20210517121545.29645-1-paskripkin@gmail.com
Reported-by: syzbot+0ba9909df31c6a36974d@syzkaller.appspotmail.com
[ Upstream commit 8b0ed8443ae6458786580d36b7d5f8125535c5d4 ]
The caller of wb_get_create() should pin the memcg, because
wb_get_create() relies on this guarantee. The rcu read lock
only can guarantee that the memcg css returned by css_from_id()
cannot be released, but the reference of the memcg can be zero.
rcu_read_lock()
memcg_css = css_from_id()
wb_get_create(memcg_css)
cgwb_create(memcg_css)
// css_get can change the ref counter from 0 back to 1
css_get(memcg_css)
rcu_read_unlock()
Fix it by holding a reference to the css before calling
wb_get_create(). This is not a problem I encountered in the
real world. Just the result of a code review.
Fixes: 682aa8e1a6a1 ("writeback: implement unlocked_inode_to_wb transaction and use it for stat updates")
Link: https://lore.kernel.org/r/20210402091145.80635-1-songmuchun@bytedance.com
Signed-off-by: Muchun Song <songmuchun@bytedance.com>
Acked-by: Tejun Heo <tj@kernel.org>
[ Upstream commit c6aa00e3d20c2767ba3f57b64eb862572b9744b3 ]
These rx tx flags arguments are for signaling close_connection() from
which worker they are called. Obviously the receive worker cannot cancel
itself and vice versa for swork. For the othercon the receive worker
should only be used, however to avoid deadlocks we should pass the same
flags as the original close_connection() was called.
Signed-off-by: Alexander Aring <aahringo@redhat.com>
Signed-off-by: David Teigland <teigland@redhat.com>
[ Upstream commit 12e0613715e1cf305fffafaf0e89d810d9a85cc0 ]
block_dump is an old debugging interface, one of it's functions is used
to print the information about who write which file on disk. If we
enable block_dump through /proc/sys/vm/block_dump and turn on debug log
level, we can gather information about write process name, target file
name and disk from kernel message. This feature is realized in
block_dump___mark_inode_dirty(), it print above information into kernel
message directly when marking inode dirty, so it is noisy and can easily
trigger log storm. At the same time, get the dentry refcount is also not
safe, we found it will lead to deadlock on ext4 file system with
data=journal mode.
After tracepoints has been introduced into the kernel, we got a
tracepoint in __mark_inode_dirty(), which is a better replacement of
block_dump___mark_inode_dirty(). The only downside is that it only trace
the inode number and not a file name, but it probably doesn't matter
because the original printed file name in block_dump is not accurate in
some cases, and we can still find it through the inode number and device
id. So this patch delete the dirting inode part of block_dump feature.
Signed-off-by: zhangyi (F) <yi.zhang@huawei.com>
Link: https://lore.kernel.org/r/20210313030146.2882027-2-yi.zhang@huawei.com
[ Upstream commit b05fbcc36be1f8597a1febef4892053a0b2f3f60 ]
With a config having PAGE_SIZE set to 256K, BTRFS build fails
with the following message
include/linux/compiler_types.h:326:38: error: call to
'__compiletime_assert_791' declared with attribute error:
BUILD_BUG_ON failed: (BTRFS_MAX_COMPRESSED % PAGE_SIZE) != 0
BTRFS_MAX_COMPRESSED being 128K, BTRFS cannot support platforms with
256K pages at the time being.
There are two platforms that can select 256K pages:
- hexagon
- powerpc
Disable BTRFS when 256K page size is selected. Supporting this would
require changes to the subpage mode that's currently being developed.
Given that 256K is many times larger than page sizes commonly used and
for what the algorithms and structures have been tuned, it's out of
scope and disabling build is a reasonable option.
Reported-by: kernel test robot <lkp@intel.com>
Signed-off-by: Christophe Leroy <christophe.leroy@csgroup.eu>
[ update changelog ]
commit 80ef08670d4c28a06a3de954bd350368780bcfef upstream.
A request could end up on the fpq->io list after fuse_abort_conn() has
reset fpq->connected and aborted requests on that list:
Thread-1 Thread-2
->fuse_simple_request() ->shutdown
->__fuse_request_send()
->queue_request() ->fuse_abort_conn()
->fuse_dev_do_read() ->acquire(fpq->lock)
->wait_for(fpq->lock) ->set err to all req's in fpq->io
->release(fpq->lock)
->add req to fpq->io
After the userspace copy is done the request will be ended, but
req->out.h.error will remain uninitialized. Also the copy might block
despite being already aborted.
Fix both issues by not allowing the request to be queued on the fpq->io
list after fuse_abort_conn() has processed this list.
Reported-by: Pradeep P V K <pragalla@codeaurora.org>
Fixes: fd22d62ed0c3 ("fuse: no fc->lock for iqueue parts")
Cc: <stable@vger.kernel.org> # v4.2
commit c89849cc0259f3d33624cc3bd127685c3c0fa25d upstream.
The avefreec should be average free clusters instead
of average free blocks, otherwize Orlov's allocator
will not work properly when bigalloc enabled.
Signed-off-by: Pan Dong <pandong.peter@bytedance.com>
Link: https://lore.kernel.org/r/20210525073656.31594-1-pandong.peter@bytedance.com
commit e5e7010e5444d923e4091cafff61d05f2d19cada upstream.
After converting fs shrinkers to new scan/count API, we are no longer
pass zero nr_to_scan parameter to detect the number of objects to free,
just remove this check.
Fixes: 1ab6c4997e04 ("fs: convert fs shrinkers to new scan/count API")
Cc: stable@vger.kernel.org # 3.12+
Signed-off-by: Zhang Yi <yi.zhang@huawei.com>
Link: https://lore.kernel.org/r/20210522103045.690103-2-yi.zhang@huawei.com
commit 4fb7c70a889ead2e91e184895ac6e5354b759135 upstream.
The cache_cnt parameter of tracepoint ext4_es_shrink_exit means the
remaining cache count after shrink, but now it is the cache count before
shrink, fix it by read sbi->s_extent_cache_cnt again.
Link: https://lore.kernel.org/r/20210522103045.690103-3-yi.zhang@huawei.com
commit ce3aba43599f0b50adbebff133df8d08a3d5fffe upstream.
Initialize eh_generation of struct ext4_extent_header to prevent leaking
info to userspace. Fixes KMSAN kernel-infoleak bug reported by syzbot at:
http://syzkaller.appspot.com/bug?id=78e9ad0e6952a3ca16e8234724b2fa92d041b9b8
Reported-by: syzbot+2dcfeaf8cb49b05e8f1a@syzkaller.appspotmail.com
Fixes: a86c61812637 ("[PATCH] ext3: add extent map support")
Signed-off-by: Anirudh Rayabharam <mail@anirudhrb.com>
Link: https://lore.kernel.org/r/20210506185655.7118-1-mail@anirudhrb.com
commit 6819703f5a365c95488b07066a8744841bf14231 upstream.
The defrag loop processes leaves in batches and starting transaction for
each. The whole defragmentation on a given root is protected by a bit
but in case the transaction fails, the bit is not cleared
In case the transaction fails the bit would prevent starting
defragmentation again, so make sure it's cleared.
Reviewed-by: Qu Wenruo <wqu@suse.com>
Reviewed-by: Anand Jain <anand.jain@oracle.com>
commit d98e4d95411bbde2220a7afa38dcc9c14d71acbe upstream.
When checking the file name attribute, we want to ensure that it fits
within the bounds of ATTR_RECORD. To do this, we should check that (attr
record + file name offset + file name length) < (attr record + attr record
length).
However, the original check did not include the file name offset in the
calculation. This means that corrupted on-disk metadata might not caught
by the incorrect file name check, and lead to an invalid memory access.
An example can be seen in the crash report of a memory corruption error
found by Syzbot:
https://syzkaller.appspot.com/bug?id=a1a1e379b225812688566745c3e2f7242bffc246
Adding the file name offset to the validity check fixes this error and
passes the Syzbot reproducer test.
Link: https://lkml.kernel.org/r/20210614050540.289494-1-desmondcheongzx@gmail.com
Reported-by: syzbot+213ac8bb98f7f4420840@syzkaller.appspotmail.com
Tested-by: syzbot+213ac8bb98f7f4420840@syzkaller.appspotmail.com
Acked-by: Anton Altaparmakov <anton@tuxera.com>
