path: root/fs
2010-03-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (205 commits) ceph: update for write_inode API change ceph: reset osd after relevant messages timed out ceph: fix flush_dirty_caps race with caps migration ceph: include migrating caps in issued set ceph: fix osdmap decoding when pools include (removed) snaps ceph: return EBADF if waiting for caps on closed file ceph: set osd request message front length correctly ceph: reset front len on return to msgpool; BUG on mismatched front iov ceph: fix snaptrace decoding on cap migration between mds ceph: use single osd op reply msg ceph: reset bits on connection close ceph: remove bogus mds forward warning ceph: remove fragile __map_osds optimization ceph: fix connection fault STANDBY check ceph: invalidate_authorizer without con->mutex held ceph: don't clobber write return value when using O_SYNC ceph: fix client_request_forward decoding ceph: drop messages on unregistered mds sessions; cleanup ceph: fix comments, locking in destroy_inode ceph: move dereference after NULL test ... Fix trivial conflicts in Documentation/ioctl/ioctl-number.txt
2010-03-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: cifs: trivial white space [CIFS] checkpatch cleanup cifs: add cifs_revalidate_file cifs: add a CIFSSMBUnixQFileInfo function cifs: add a CIFSSMBQFileInfo function cifs: overhaul cifs_revalidate and rename to cifs_revalidate_dentry
2010-03-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (30 commits) Btrfs: fix the inode ref searches done by btrfs_search_path_in_tree Btrfs: allow treeid==0 in the inode lookup ioctl Btrfs: return keys for large items to the search ioctl Btrfs: fix key checks and advance in the search ioctl Btrfs: buffer results in the space_info ioctl Btrfs: use __u64 types in ioctl.h Btrfs: fix search_ioctl key advance Btrfs: fix gfp flags masking in the compression code Btrfs: don't look at bio flags after submit_bio btrfs: using btrfs_stack_device_id() get devid btrfs: use memparse Btrfs: add a "df" ioctl for btrfs Btrfs: cache the extent state everywhere we possibly can V2 Btrfs: cache ordered extent when completing io Btrfs: cache extent state in find_delalloc_range Btrfs: change the ordered tree to use a spinlock instead of a mutex Btrfs: finish read pages in the order they are submitted btrfs: fix btrfs_mkdir goto for no free objectids Btrfs: flush data on snapshot creation Btrfs: make df be a little bit more understandable ...
2010-03-18Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: NFS: ensure bdi_unregister is called on mount failure. NFS: Avoid a deadlock in nfs_release_page NFSv4: Don't ignore the NFS_INO_REVAL_FORCED flag in nfs_revalidate_inode() nfs4: Make the v4 callback service hidden nfs: fix unlikely memory leak rpc client can not deal with ENOSOCK, so translate it into ENOCONN
2010-03-18Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: don't warn about page discards on shutdown xfs: use scalable vmap API xfs: remove old vmap cache
2010-03-18Btrfs: fix the inode ref searches done by btrfs_search_path_in_treeChris Mason
This is used by the inode lookup ioctl to follow all the backrefs up to the subvol root. But the search being done would sometimes land one past the last item in the leaf instead of finding the backref. This changes the search to look for the highest possible backref and hop back one item. It also fixes a leaked path on failure to find the root. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-18Btrfs: allow treeid==0 in the inode lookup ioctlChris Mason
When a root id of 0 is sent to the inode lookup ioctl, it will use the root of the file we're ioctling and pass the root id back to userland along with the results. This allows userland to do searches based on that root later on. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-18Btrfs: return keys for large items to the search ioctlChris Mason
The search ioctl was skipping large items entirely (ones that are too big for the results buffer). This changes things to at least copy the item header so that we can send information about the item back to userland. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-18Btrfs: fix key checks and advance in the search ioctlChris Mason
The search ioctl was working well for finding tree roots, but using it for generic searches requires a few changes to how the keys are advanced. This treats the search control min fields for objectid, type and offset more like a key, where we drop the offset to zero once we bump the type, etc. The downside of this is that we are changing the min_type and min_offset fields during the search, and so the ioctl caller needs extra checks to make sure the keys in the result are the ones it wanted. This also changes key_in_sk to use btrfs_comp_cpu_keys, just to make things more readable. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-17ntfs: use bitmap_weightAkinobu Mita
Use bitmap_weight() instead of doing hweight32() for each u32 element in the page. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-17jffs2: fix up rb_root initializations to use RB_ROOTVenkatesh Pallipadi
jffs2 uses rb_node = NULL; to zero rb_root. The problem with this is that 17d9ddc72fb8bba0d4f678 ("rbtree: Add support for augmented rbtrees") in the linux-next tree adds a new field to that struct which needs to be NULL as well. This patch uses RB_ROOT as the intializer so all of the relevant fields will be NULL'd. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Eric Paris <eparis@redhat.com> Acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-16xfs: don't warn about page discards on shutdownDave Chinner
If we are doing a forced shutdown, we can get lots of noise about delalloc pages being discarded. This is happens by design during a forced shutdown, so don't spam the logs with these messages. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-03-16xfs: use scalable vmap APIAlex Elder
Re-apply a commit that had been reverted due to regressions that have since been fixed. From 95f8e302c04c0b0c6de35ab399a5551605eeb006 Mon Sep 17 00:00:00 2001 From: Nick Piggin <npiggin@suse.de> Date: Tue, 6 Jan 2009 14:43:09 +1100 Implement XFS's large buffer support with the new vmap APIs. See the vmap rewrite (db64fe02) for some numbers. The biggest improvement that comes from using the new APIs is avoiding the global KVA allocation lock on every call. Signed-off-by: Nick Piggin <npiggin@suse.de> Reviewed-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Only modifications here were a minor reformat, plus making the patch apply given the new use of xfs_buf_is_vmapped(). Modified-by: Alex Elder <aelder@sgi.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-03-16xfs: remove old vmap cacheAlex Elder
Re-apply a commit that had been reverted due to regressions that have since been fixed. Original commit: d2859751cd0bf586941ffa7308635a293f943c17 Author: Nick Piggin <npiggin@suse.de> Date: Tue, 6 Jan 2009 14:40:44 +1100 XFS's vmap batching simply defers a number (up to 64) of vunmaps, and keeps track of them in a list. To purge the batch, it just goes through the list and calls vunamp on each one. This is pretty poor: a global TLB flush is generally still performed on each vunmap, with the most expensive parts of the operation being the broadcast IPIs and locking involved in the SMP callouts, and the locking involved in the vmap management -- none of these are avoided by just batching up the calls. I'm actually surprised it ever made much difference. (Now that the lazy vmap allocator is upstream, this description is not quite right, but the vunmap batching still doesn't seem to do much). Rip all this logic out of XFS completely. I will improve vmap performance and scalability directly in subsequent patch. Signed-off-by: Nick Piggin <npiggin@suse.de> Reviewed-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> The only change I made was to use the "new" xfs_buf_is_vmapped() function in a place it had been open-coded in the original. Modified-by: Alex Elder <aelder@sgi.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-03-16Btrfs: buffer results in the space_info ioctlChris Mason
The space_info ioctl was using copy_to_user inside rcu_read_lock. This commit changes things to copy into a buffer first and then dump the result down to userland. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-16Btrfs: use __u64 types in ioctl.hSage Weil
Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-16Btrfs: fix search_ioctl key advanceSage Weil
key->type is u8, not u64. fs/btrfs/ioctl.c: In function 'copy_to_sk': fs/btrfs/ioctl.c:1024: warning: comparison is always true due to limited range of data type Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15NFS: ensure bdi_unregister is called on mount failure.NeilBrown
bdi_unregister is called by nfs_put_super which is only called by generic_shutdown_super if ->s_root is not NULL. So if we error out in a circumstance where we called nfs_bdi_register (i.e. server != NULL) but have not set s_root, then we need to call bdi_unregister explicitly in nfs_get_sb and various other *_get_sb() functions. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-03-15cifs: trivial white spaceDan Carpenter
I fixed the indent level. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-03-15Btrfs: fix gfp flags masking in the compression codeNick Piggin
GFP_FS must be masked out, NOFS can't be or'd in. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: don't look at bio flags after submit_bioChris Mason
After callling submit_bio, the bio can be freed at any time. The btrfs submission thread helper was checking the bio flags too late, which might not give the correct answer. When CONFIG_DEBUG_PAGE_ALLOC is turned on, it can lead to oopsen. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15btrfs: using btrfs_stack_device_id() get devidXiao Guangrong
We can use btrfs_stack_device_id() to get dev_item->devid Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15btrfs: use memparseAkinobu Mita
Use memparse() instead of its own private implementation. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: linux-btrfs@vger.kernel.org Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: add a "df" ioctl for btrfsJosef Bacik
df is a very loaded question in btrfs. This gives us a way to get the per-space usage information so we can tell exactly what is in use where. This will help us figure out ENOSPC problems, and help users better understand where their disk space is going. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: cache the extent state everywhere we possibly can V2Josef Bacik
This patch just goes through and fixes everybody that does lock_extent() blah unlock_extent() to use lock_extent_bits() blah unlock_extent_cached() and pass around a extent_state so we only have to do the searches once per function. This gives me about a 3 mb/s boots on my random write test. I have not converted some things, like the relocation and ioctl's, since they aren't heavily used and the relocation stuff is in the middle of being re-written. I also changed the clear_extent_bit() to only unset the cached state if we are clearing EXTENT_LOCKED and related stuff, so we can do things like this lock_extent_bits() clear delalloc bits unlock_extent_cached() without losing our cached state. I tested this thoroughly and turned on LEAK_DEBUG to make sure we weren't leaking extent states, everything worked out fine. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: cache ordered extent when completing ioJosef Bacik
When finishing io we run btrfs_dec_test_ordered_pending, and then immediately run btrfs_lookup_ordered_extent, but btrfs_dec_test_ordered_pending does that already, so we're searching twice when we don't have to. This patch lets us pass a btrfs_ordered_extent in to btrfs_dec_test_ordered_pending so if we do complete io on that ordered extent we can just use the one we found then instead of having to do another btrfs_lookup_ordered_extent. This made my fio job with the other patch go from 24 mb/s to 29 mb/s. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: cache extent state in find_delalloc_rangeJosef Bacik
This patch makes us cache the extent state we find in find_delalloc_range since we'll have to lock the extent later on in the function. This will keep us from re-searching for the rang when we try to lock the extent. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: change the ordered tree to use a spinlock instead of a mutexJosef Bacik
The ordered tree used to need a mutex, but currently all we use it for is to protect the rb_tree, and a spin_lock is just fine for that. Using a spin_lock instead makes dbench run a little faster, 58 mb/s instead of 51 mb/s, and have less latency, 3445.138 ms instead of 3820.633 ms. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: finish read pages in the order they are submittedChris Mason
The endio is done at reverse order of bio vectors. That means for a sequential read, the page first submitted will finish last in a bio. Considering we will do checksum (making cache hot) for every page, this does introduce delay (and chance to squeeze cache used soon) for pages submitted at the begining. I don't observe obvious performance difference with below patch at my simple test, but seems more natural to finish read in the order they are submitted. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15btrfs: fix btrfs_mkdir goto for no free objectidsMiao Xie
btrfs_mkdir() must jump to the place of ending transaction after btrfs_find_free_objectid() failed. Or this transaction can't end. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: flush data on snapshot creationSage Weil
Flush any delalloc extents when we create a snapshot, so that recently written file data is always included in the snapshot. A later commit will add the ability to snapshot without the flush, but most people expect flushing. Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: make df be a little bit more understandableJosef Bacik
The way we report df usage is way confusing for everybody, including some other utilities (bacula for one). So this patch makes df a little bit more understandable. First we make used actually count the total amount of used space in all space info's. This will give us a real view of how much disk space is in use. Second, for blocks available, only count data space. This makes things like bacula work because it says 0 when you can no longer write anymore data to the disk. I think this is a nice compromise, since you will end up with something like the following [root@alpha ~]# df -h Filesystem Size Used Avail Use% Mounted on /dev/mapper/VolGroup-lv_root 148G 30G 111G 21% / /dev/sda1 194M 116M 68M 64% /boot tmpfs 985M 12K 985M 1% /dev/shm /dev/mapper/VolGroup-LogVol02 145G 140G 0 100% /mnt/btrfs-test Compare this with btrfsctl -i output [root@alpha btrfs-progs-unstable]# ./btrfsctl -i /mnt/btrfs-test/ Metadata, DUP: total=4.62GB, used=2.46GB System, DUP: total=8.00MB, used=24.00KB Data: total=134.80GB, used=134.80GB Metadata: total=8.00MB, used=0.00 System: total=4.00MB, used=0.00 operation complete This way we show that there is no more data space to be used, but we have another 5GB of space left for metadata. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15btrfs: Update existing btrfs_device for renaming deviceTARUISI Hiroaki
When we scan devices in a multi-device filesystem, we memorize the original name. If the device gets a new name, later scans don't update the in-kernel structures related to it, and we're not able to mount the filesystem. This patch updates device name during scaning. Signed-off-by: TARUISI Hiroaki <taruishi.hiroak@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: add new defrag-range ioctl.Chris Mason
The btrfs defrag ioctl was limited to doing the entire file. This commit adds a new interface that can defrag a specific range inside the file. It can also force compression on the file, allowing you to selectively compress individual files after they were created, even when mount -o compress isn't turned on. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: be more selective in the defrag ioctlChris Mason
The btrfs defrag ioctl had some bugs around delalloc accounting, and it wasn't properly skipping pages that were not in the mapping. It wasn't properly clearing the page checked flag, which could make the writeback code ignore the page forever while pinning it as dirty. This commit fixes those problems and makes defrag a little smarter. It skips holes and it doesn't waste time defragging large extents. If a tiny extent comes before a very large extent, it will defrag both of them to make sure the tiny extent ends up next to something big. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: run the backing dev more often in the submit_bio helperChris Mason
The submit_bio helper thread can decide to loop back around to service more bios. This commit forces it to unplug first, which helps reduce the latency seen by submitters. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: make subvolid=0 mount the original default rootJosef Bacik
Since theres not a good way to make sure the user sees the original default root tree id, and not to mention it's 5 so is way different than any other volume, just make subvol=0 mount the original default root. This makes it a bit easier for users to handle in the long run. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: add ioctl and incompat flag to set the default mount subvolJosef Bacik
This patch needs to go along with my previous patch. This lets us set the default dir item's location to whatever root we want to use as our default mounting subvol. With this we don't have to use mount -o subvol=<tree id> anymore to mount a different subvol, we can just set the new one and it will just magically work. I've done some moderate testing with this, mostly just switching the default mount around, mounting subvols and the default mount at the same time and such, everything seems to work. Thanks, Older kernels would generally be able to still mount the filesystem with the default subvolume set, but it would result in a different volume being mounted, which could be an even more unpleasant suprise for users. So if you set your default subvolume, you can't go back to older kernels. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: change how we mount subvolumesJosef Bacik
This work is in preperation for being able to set a different root as the default mounting root. There is currently a problem with how we mount subvolumes. We cannot currently mount a subvolume of a subvolume, you can only mount subvolumes/snapshots of the default subvolume. So say you take a snapshot of the default subvolume and call it snap1, and then take a snapshot of snap1 and call it snap2, so now you have / /snap1 /snap1/snap2 as your available volumes. Currently you can only mount / and /snap1, you cannot mount /snap1/snap2. To fix this problem instead of passing subvolid=<name> you must pass in subvolid=<treeid>, where <treeid> is the tree id that gets spit out via the subvolume listing you get from the subvolume listing patches (btrfs filesystem list). This allows us to mount /, /snap1 and /snap1/snap2 as the root volume. In addition to the above, we also now read the default dir item in the tree root to get the root key that it points to. For now this just points at what has always been the default subvolme, but later on I plan to change it to point at whatever root you want to be the new default root, so you can just set the default mount and not have to mount with -o subvolid=<treeid>. I tested this out with the above scenario and it worked perfectly. Thanks, mount -o subvol operates inside the selected subvolid. For example: mount -o subvol=snap1,subvolid=256 /dev/xxx /mnt /mnt will have the snap1 directory for the subvolume with id 256. mount -o subvol=snap /dev/xxx /mnt /mnt will be the snap directory of whatever the default subvolume is. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: make set/get functions for the super compat_ro flags use compat_roJosef Bacik
Our set/get functions for compat_ro_flags actually look at compat_flags. This will mess any attempt to use compat flags up. The fix is obvious. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: add search and inode lookup ioctlsChris Mason
The search ioctl is a generic tool for doing btree searches from userland applications. The first user of the search ioctl is a subvolume listing feature, but we'll also use it to find new files in a subvolume. The search ioctl allows you to specify min and max keys to search for, along with min and max transid. It returns the items along with a header that includes the item key. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: add a function to lookup a directory path by following backrefsTARUISI Hiroaki
This will be used by the inode lookup ioctl. Signed-off-by: TARUISI Hiroaki <taruishi.hiroak@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2: nilfs2: remove whitespaces before quoted newlines nilfs2: remove spaces before tabs nilfs2: fix various typos in comments nilfs2: fix typo "cout" -> "count" in error message nilfs2: fix function name typos in docbook comments nilfs2: fix discrepancy in use of static specifier
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: 9p: Skip check for mandatory locks when unlocking 9p: Fixes a simple bug enabling writes beyond 2GB. 9p: Change the name of new protocol from 9p2010.L to 9p2000.L fs/9p: re-init the wstat in readdir loop net/9p: Add sysfs mount_tag file for virtio 9P device net/9p: Use the tag name in the config space for identifying mount point
2010-03-14nilfs2: remove whitespaces before quoted newlinesRyusuke Konishi
This kills the following checkpatch warnings: WARNING: unnecessary whitespace before a quoted newline #869: FILE: super.c:869: + "remount to a different snapshot. \n", WARNING: unnecessary whitespace before a quoted newline #389: FILE: the_nilfs.c:389: + printk(KERN_ERR "NILFS: too short segment. \n"); Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-03-14nilfs2: remove spaces before tabsRyusuke Konishi
This kills the following checkpatch warnings: WARNING: please, no space before tabs #74: FILE: segment.h:74: +^Iunsigned ^I^Iflags;$ WARNING: please, no space before tabs #35: FILE: segbuf.c:35: +^Iint ^I^I^Istart, end; /* The region to be submitted */$ Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-03-14nilfs2: fix various typos in commentsRyusuke Konishi
This fixes various typos I found in comments of nilfs2. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-03-14nilfs2: fix typo "cout" -> "count" in error messageRyusuke Konishi
2010-03-14nilfs2: fix function name typos in docbook commentsRyusuke Konishi
Fixes the following typos in docbook comments: nilfs_detroy_transaction_cache -> nilfs_destroy_transaction_cache nilfs_secgtor_start_timer -> nilfs_segctor_start_timer Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-03-14nilfs2: fix discrepancy in use of static specifierRyusuke Konishi
Two segbuf functions, nilfs_segbuf_write and nilfs_segbuf_wait, are declared with the static storage class specifier, but their implementations are not. This fixes the discrepancy. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
