commit b48c6af2086ab2ba8a9c9b6ce9ecb34592ce500c upstream.
The test in fuse_file_llseek() "not SEEK_CUR or not SEEK_SET" always evaluates
to true.
This was introduced in 3.1 by commit 06222e49 (fs: handle SEEK_HOLE/SEEK_DATA
properly in all fs's that define their own llseek) and changed the behavior of
SEEK_CUR and SEEK_SET to always retrieve the file attributes. This is a
performance regression.
Fix the test so that it makes sense.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
CC: Josef Bacik <josef@redhat.com>
CC: Al Viro <viro@zeniv.linux.org.uk>
commit 48706d0a91583d08c56e7ef2a7602d99c8d4133f upstream.
Fix two bugs in fuse_retrieve():
- retrieving more than one page would yield repeated instances of the
first page
- if more than FUSE_MAX_PAGES_PER_REQ pages were requested than the
request page array would overflow
fuse_retrieve() was added in 2.6.36 and these bugs had been there since the
beginning.
commit 5a0dc7365c240795bf190766eba7a27600be3b3e upstream.
We need to zero out part of a page which beyond EOF before setting uptodate,
otherwise, mapread or write will see non-zero data beyond EOF.
Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 13a79a4741d37fda2fbafb953f0f301dc007928f upstream.
If there is an unwritten but clean buffer in a page and there is a
dirty buffer after the buffer, then mpage_submit_io does not write the
dirty buffer out. As a result, da_writepages loops forever.
This patch fixes the problem by checking dirty flag.
commit ea51d132dbf9b00063169c1159bee253d9649224 upstream.
If the pte mapping in generic_perform_write() is unmapped between
iov_iter_fault_in_readable() and iov_iter_copy_from_user_atomic(), the
"copied" parameter to ->end_write can be zero. ext4 couldn't cope with
it with delayed allocations enabled. This skips the i_disksize
enlargement logic if copied is zero and no new data was appeneded to
the inode.
gdb> bt
#0 0xffffffff811afe80 in ext4_da_should_update_i_disksize (file=0xffff88003f606a80, mapping=0xffff88001d3824e0, pos=0x1\
08000, len=0x1000, copied=0x0, page=0xffffea0000d792e8, fsdata=0x0) at fs/ext4/inode.c:2467
#1 ext4_da_write_end (file=0xffff88003f606a80, mapping=0xffff88001d3824e0, pos=0x108000, len=0x1000, copied=0x0, page=0\
xffffea0000d792e8, fsdata=0x0) at fs/ext4/inode.c:2512
#2 0xffffffff810d97f1 in generic_perform_write (iocb=<value optimized out>, iov=<value optimized out>, nr_segs=<value o\
ptimized out>, pos=0x108000, ppos=0xffff88001e26be40, count=<value optimized out>, written=0x0) at mm/filemap.c:2440
#3 generic_file_buffered_write (iocb=<value optimized out>, iov=<value optimized out>, nr_segs=<value optimized out>, p\
os=0x108000, ppos=0xffff88001e26be40, count=<value optimized out>, written=0x0) at mm/filemap.c:2482
#4 0xffffffff810db5d1 in __generic_file_aio_write (iocb=0xffff88001e26bde8, iov=0xffff88001e26bec8, nr_segs=0x1, ppos=0\
xffff88001e26be40) at mm/filemap.c:2600
#5 0xffffffff810db853 in generic_file_aio_write (iocb=0xffff88001e26bde8, iov=0xffff88001e26bec8, nr_segs=<value optimi\
zed out>, pos=<value optimized out>) at mm/filemap.c:2632
#6 0xffffffff811a71aa in ext4_file_write (iocb=0xffff88001e26bde8, iov=0xffff88001e26bec8, nr_segs=0x1, pos=0x108000) a\
t fs/ext4/file.c:136
#7 0xffffffff811375aa in do_sync_write (filp=0xffff88003f606a80, buf=<value optimized out>, len=<value optimized out>, \
ppos=0xffff88001e26bf48) at fs/read_write.c:406
#8 0xffffffff81137e56 in vfs_write (file=0xffff88003f606a80, buf=0x1ec2960 <Address 0x1ec2960 out of bounds>, count=0x4\
000, pos=0xffff88001e26bf48) at fs/read_write.c:435
#9 0xffffffff8113816c in sys_write (fd=<value optimized out>, buf=0x1ec2960 <Address 0x1ec2960 out of bounds>, count=0x\
4000) at fs/read_write.c:487
#10 <signal handler called>
#11 0x00007f120077a390 in __brk_reservation_fn_dmi_alloc__ ()
#12 0x0000000000000000 in ?? ()
gdb> print offset
$22 = 0xffffffffffffffff
gdb> print idx
$23 = 0xffffffff
gdb> print inode->i_blkbits
$24 = 0xc
gdb> up
2512 if (ext4_da_should_update_i_disksize(page, end)) {
gdb> print start
$25 = 0x0
gdb> print end
$26 = 0xffffffffffffffff
gdb> print pos
$27 = 0x108000
gdb> print new_i_size
$28 = 0x108000
gdb> print ((struct ext4_inode_info *)((char *)inode-((int)(&((struct ext4_inode_info *)0)->vfs_inode))))->i_disksize
$29 = 0xd9000
gdb> down
2467 for (i = 0; i < idx; i++)
gdb> print i
$30 = 0xd44acbee
This is 100% reproducible with some autonuma development code tuned in
a very aggressive manner (not normal way even for knumad) which does
"exotic" changes to the ptes. It wouldn't normally trigger but I don't
see why it can't happen normally if the page is added to swap cache in
between the two faults leading to "copied" being zero (which then
hangs in ext4). So it should be fixed. Especially possible with lumpy
reclaim (albeit disabled if compaction is enabled) as that would
ignore the young bits in the ptes.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
commit fc6cb1cda5db7b2d24bf32890826214b857c728e upstream.
/proc/mounts was showing the mount option [no]init_inode_table when
the correct mount option that will be accepted by parse_options() is
[no]init_itable.
commit b5a7e97039a80fae673ccc115ce595d5b88fb4ee upstream.
We need to make sure iocb->private is cleared *before* we put the
io_end structure on i_completed_io_list. Otherwise fsync() could
potentially run on another CPU and free the iocb structure out from
under us.
Reported-by: Kent Overstreet <koverstreet@google.com>
commit 434a964daa14b9db083ce20404a4a2add54d037a upstream.
Clement Lecigne reports a filesystem which causes a kernel oops in
hfs_find_init() trying to dereference sb->ext_tree which is NULL.
This proves to be because the filesystem has a corrupted MDB extent
record, where the extents file does not fit into the first three extents
in the file record (the first blocks).
In hfs_get_block() when looking up the blocks for the extent file
(HFS_EXT_CNID), it fails the first blocks special case, and falls
through to the extent code (which ultimately calls hfs_find_init())
which is in the process of being initialised.
Hfs avoids this scenario by always having the extents b-tree fitting
into the first blocks (the extents B-tree can't have overflow extents).
The fix is to check at mount time that the B-tree fits into first
blocks, i.e. fail if HFS_I(inode)->alloc_blocks >=
HFS_I(inode)->first_blocks
Note, the existing commit 47f365eb57573 ("hfs: fix oops on mount with
corrupted btree extent records") becomes subsumed into this as a special
case, but only for the extents B-tree (HFS_EXT_CNID), it is perfectly
acceptable for the catalog B-Tree file to grow beyond three extents,
with the remaining extent descriptors in the extents overfow.
This fixes CVE-2011-2203
Reported-by: Clement LECIGNE <clement.lecigne@netasq.com>
Signed-off-by: Phillip Lougher <plougher@redhat.com>
Cc: Jeff Mahoney <jeffm@suse.com>
Cc: Moritz Mühlenhoff <jmm@inutil.org>
commit 8762202dd0d6e46854f786bdb6fb3780a1625efe upstream.
I hit a J_ASSERT(blocknr != 0) failure in cleanup_journal_tail() when
mounting a fsfuzzed ext3 image. It turns out that the corrupted ext3
image has s_first = 0 in journal superblock, and the 0 is passed to
journal->j_head in journal_reset(), then to blocknr in
cleanup_journal_tail(), in the end the J_ASSERT failed.
So validate s_first after reading journal superblock from disk in
journal_get_superblock() to ensure s_first is valid.
The following script could reproduce it:
fstype=ext3
blocksize=1024
img=$fstype.img
offset=0
found=0
magic="c0 3b 39 98"
dd if=/dev/zero of=$img bs=1M count=8
mkfs -t $fstype -b $blocksize -F $img
filesize=`stat -c %s $img`
while [ $offset -lt $filesize ]
do
if od -j $offset -N 4 -t x1 $img | grep -i "$magic";then
echo "Found journal: $offset"
found=1
break
fi
offset=`echo "$offset+$blocksize" | bc`
done
if [ $found -ne 1 ];then
echo "Magic \"$magic\" not found"
exit 1
fi
dd if=/dev/zero of=$img seek=$(($offset+23)) conv=notrunc bs=1 count=1
mkdir -p ./mnt
mount -o loop $img ./mnt
Cc: Jan Kara <jack@suse.cz>
Signed-off-by: Eryu Guan <guaneryu@gmail.com>
commit 7023676f9ee851d94f0942e879243fc1f9081c47 upstream.
Prior to commit eaf35b1, cifs_save_resume_key had some NULL pointer
checks at the top. It turns out that at least one of those NULL
pointer checks is needed after all.
When the LastNameOffset in a FIND reply appears to be beyond the end of
the buffer, CIFSFindFirst and CIFSFindNext will set srch_inf.last_entry
to NULL. Since eaf35b1, the code will now oops in this situation.
Fix this by having the callers check for a NULL last entry pointer
before calling cifs_save_resume_key. No change is needed for the
call site in cifs_readdir as it's not reachable with a NULL
current_entry pointer.
This should fix:
https://bugzilla.redhat.com/show_bug.cgi?id=750247
Reported-by: Adam G. Metzler <adamgmetzler@gmail.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <smfrench@gmail.com>
commit 02125a826459a6ad142f8d91c5b6357562f96615 upstream.
__d_path() API is asking for trouble and in case of apparmor d_namespace_path()
getting just that. The root cause is that when __d_path() misses the root
it had been told to look for, it stores the location of the most remote ancestor
in *root. Without grabbing references. Sure, at the moment of call it had
been pinned down by what we have in *path. And if we raced with umount -l, we
could have very well stopped at vfsmount/dentry that got freed as soon as
prepend_path() dropped vfsmount_lock.
It is safe to compare these pointers with pre-existing (and known to be still
alive) vfsmount and dentry, as long as all we are asking is "is it the same
address?". Dereferencing is not safe and apparmor ended up stepping into
that. d_namespace_path() really wants to examine the place where we stopped,
even if it's not connected to our namespace. As the result, it looked
at ->d_sb->s_magic of a dentry that might've been already freed by that point.
All other callers had been careful enough to avoid that, but it's really
a bad interface - it invites that kind of trouble.
The fix is fairly straightforward, even though it's bigger than I'd like:
* prepend_path() root argument becomes const.
* __d_path() is never called with NULL/NULL root. It was a kludge
to start with. Instead, we have an explicit function - d_absolute_root().
Same as __d_path(), except that it doesn't get root passed and stops where
it stops. apparmor and tomoyo are using it.
* __d_path() returns NULL on path outside of root. The main
caller is show_mountinfo() and that's precisely what we pass root for - to
skip those outside chroot jail. Those who don't want that can (and do)
use d_path().
* __d_path() root argument becomes const. Everyone agrees, I hope.
* apparmor does *NOT* try to use __d_path() or any of its variants
when it sees that path->mnt is an internal vfsmount. In that case it's
definitely not mounted anywhere and dentry_path() is exactly what we want
there. Handling of sysctl()-triggered weirdness is moved to that place.
* if apparmor is asked to do pathname relative to chroot jail
and __d_path() tells it we it's not in that jail, the sucker just calls
d_absolute_path() instead. That's the other remaining caller of __d_path(),
BTW.
* seq_path_root() does _NOT_ return -ENAMETOOLONG (it's stupid anyway -
the normal seq_file logics will take care of growing the buffer and redoing
the call of ->show() just fine). However, if it gets path not reachable
from root, it returns SEQ_SKIP. The only caller adjusted (i.e. stopped
ignoring the return value as it used to do).
Reviewed-by: John Johansen <john.johansen@canonical.com>
ACKed-by: John Johansen <john.johansen@canonical.com>
commit b53fc7c2974a50913f49e1d800fe904a28c338e3 upstream.
Fix the error message "directives may not be used inside a macro argument"
which appears when the kernel is compiled for the cris architecture.
Signed-off-by: Claudio Scordino <claudio@evidence.eu.com>
commit db3e74b582915d66e10b0c73a62763418f54c340 upstream.
The doalloc arg in xfs_qm_dqattach_one() is a flag that indicates
whether a new area to handle quota information will be allocated
if needed. Originally, it was passed to xfs_qm_dqget(), but has
been removed by the following commit (probably by mistake):
commit 8e9b6e7fa4544ea8a0e030c8987b918509c8ff47
Author: Christoph Hellwig <hch@lst.de>
Date: Sun Feb 8 21:51:42 2009 +0100
xfs: remove the unused XFS_QMOPT_DQLOCK flag
As the result, xfs_qm_dqget() called from xfs_qm_dqattach_one()
never allocates the new area even if it is needed.
This patch gives the doalloc arg to xfs_qm_dqget() in
xfs_qm_dqattach_one() to fix this problem.
Signed-off-by: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com>
Cc: Alex Elder <aelder@sgi.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
commit b52a360b2aa1c59ba9970fb0f52bbb093fcc7a24 upstream.
Fixes a possible memory corruption when the link is larger than
MAXPATHLEN and XFS_DEBUG is not enabled. This also remove the
S_ISLNK assert, since the inode mode is checked previously in
xfs_readlink_by_handle() and via VFS.
Updated to address concerns raised by Ben Hutchings about the loose
attention paid to 32- vs 64-bit values, and the lack of handling a
potentially negative pathlen value:
- Changed type of "pathlen" to be xfs_fsize_t, to match that of
ip->i_d.di_size
- Added checking for a negative pathlen to the too-long pathlen
test, and generalized the message that gets reported in that case
to reflect the change
As a result, if a negative pathlen were encountered, this function
would return EFSCORRUPTED (and would fail an assertion for a debug
build)--just as would a too-long pathlen.
Signed-off-by: Alex Elder <aelder@sgi.com>
Signed-off-by: Carlos Maiolino <cmaiolino@redhat.com>
Cc: Ben Myers <bpm@sgi.com>
commit 87c7bec7fc3377b3873eb3a0f4b603981ea16ebb upstream.
The code to flush buffers in the umount code is a bit iffy: we first
flush all delwri buffers out, but then might be able to queue up a
new one when logging the sb counts. On a normal shutdown that one
would get flushed out when doing the synchronous superblock write in
xfs_unmountfs_writesb, but we skip that one if the filesystem has
been shut down.
Fix this by moving the delwri list flushing until just before unmounting
the log, and while we're at it also remove the superflous delwri list
and buffer lru flusing for the rt and log device that can never have
cached or delwri buffers.
Reported-by: Amit Sahrawat <amit.sahrawat83@gmail.com>
Tested-by: Amit Sahrawat <amit.sahrawat83@gmail.com>
commit ed32201e65e15f3e6955cb84cbb544b08f81e5a5 upstream.
An attribute of inode can be fetched via xfs_vn_getattr() in XFS.
Currently it returns EIO, not negative value, when it failed. As a
result, the system call returns not negative value even though an
error occured. The stat(2), ls and mv commands cannot handle this
error and do not work correctly.
This patch fixes this bug, and returns -EIO, not EIO when an error
is detected in xfs_vn_getattr().
commit c58cb165bd44de8aaee9755a144136ae743be116 upstream.
Currently a buffered reader or writer can add pages to the pagecache
while we are waiting for the iolock in xfs_file_dio_aio_write. Prevent
this by re-checking mapping->nrpages after we got the iolock, and if
nessecary upgrade the lock to exclusive mode. To simplify this a bit
only take the ilock inside of xfs_file_aio_write_checks.
Reviewed-by: Dave Chinner <dchinner@redhat.com>
commit 0c38a2512df272b14ef4238b476a2e4f70da1479 upstream.
There is no need to grab the i_mutex of the IO lock in exclusive
mode if we don't need to invalidate the page cache. Taking these
locks on every direct IO effective serialises them as taking the IO
lock in exclusive mode has to wait for all shared holders to drop
the lock. That only happens when IO is complete, so effective it
prevents dispatch of concurrent direct IO reads to the same inode.
Fix this by taking the IO lock shared to check the page cache state,
and only then drop it and take the IO lock exclusively if there is
work to be done. Hence for the normal direct IO case, no exclusive
locking will occur.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Tested-by: Joern Engel <joern@logfs.org>
commit 4c81f045c0bd2cbb78cc6446a4cd98038fe11a2e upstream.
ext4_end_io_dio() queues io_end->work and then clears iocb->private;
however, io_end->work calls aio_complete() which frees the iocb
object. If that slab object gets reallocated, then ext4_end_io_dio()
can end up clearing someone else's iocb->private, this use-after-free
can cause a leak of a struct ext4_io_end_t structure.
Detected and tested with slab poisoning.
[ Note: Can also reproduce using 12 fio's against 12 file systems with the
following configuration file:
[global]
direct=1
ioengine=libaio
iodepth=1
bs=4k
ba=4k
size=128m
[create]
filename=${TESTDIR}
rw=write
-- tytso ]
Google-Bug-Id: 5354697
Tested-by: Kent Overstreet <koverstreet@google.com>
commit 0f751e641a71157aa584c2a2e22fda52b52b8a56 upstream.
From mhalcrow's original commit message:
Characters with ASCII values greater than the size of
filename_rev_map[] are valid filename characters.
ecryptfs_decode_from_filename() will access kernel memory beyond
that array, and ecryptfs_parse_tag_70_packet() will then decrypt
those characters. The attacker, using the FNEK of the crafted file,
can then re-encrypt the characters to reveal the kernel memory past
the end of the filename_rev_map[] array. I expect low security
impact since this array is statically allocated in the text area,
and the amount of memory past the array that is accessible is
limited by the largest possible ASCII filename character.
This patch solves the issue reported by mhalcrow but with an
implementation suggested by Linus to simply extend the length of
filename_rev_map[] to 256. Characters greater than 0x7A are mapped to
0x00, which is how invalid characters less than 0x7A were previously
being handled.
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
Reported-by: Michael Halcrow <mhalcrow@google.com>
commit 32001d6fe9ac6b0423e674a3093aa56740849f3b upstream.
Dirty pages weren't being written back when an mmap'ed eCryptfs file was
closed before the mapping was unmapped. Since f_ops->flush() is not
called by the munmap() path, the lower file was simply being released.
This patch flushes the eCryptfs file in the vm_ops->close() path.
https://launchpad.net/bugs/870326
commit b59db43ad4434519feb338eacb01d77eb50825c5 upstream.
The file creation path prematurely called d_instantiate() and
unlock_new_inode() before the eCryptfs inode info was fully
allocated and initialized and before the eCryptfs metadata was written
to the lower file.
This could result in race conditions in subsequent file and inode
operations leading to unexpected error conditions or a null pointer
dereference while attempting to use the unallocated memory.
https://launchpad.net/bugs/813146
commit 09f363c7363eb10cfb4b82094bd7064e5608258b upstream.
The callback must not return -1 when nr_to_scan is zero. Fix the bug in
fs/super.c and add this requirement to the callback specification.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
commit 1788ea6e3b2a58cf4fb00206e362d9caff8d86a7 upstream.
commit d953126 changed how nfs_atomic_lookup handles an -EISDIR return
from an OPEN call. Prior to that patch, that caused the client to fall
back to doing a normal lookup. When that patch went in, the code began
returning that error to userspace. The d_revalidate codepath however
never had the corresponding change, so it was still possible to end up
with a NULL ctx->state pointer after that.
That patch caused a regression. When we attempt to open a directory that
does not have a cached dentry, that open now errors out with EISDIR. If
you attempt the same open with a cached dentry, it will succeed.
Fix this by reverting the change in nfs_atomic_lookup and allowing
attempts to open directories to fall back to a normal lookup
Also, add a NFSv4-specific f_ops->open routine that just returns
-ENOTDIR. This should never be called if things are working properly,
but if it ever is, then the dprintk may help in debugging.
To facilitate this, a new file_operations field is also added to the
nfs_rpc_ops struct.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit bc5b8a9003132ae44559edd63a1623b7b99dfb68 upstream.
On a corrupted file system the ->len field could be wrong leading to
a buffer overflow.
Reported-and-acked-by: Clement LECIGNE <clement.lecigne@netasq.com>
commit a3fbbde70a0cec017f2431e8f8de208708c76acc upstream.
Mountpoint crossing is similar to following procfs symlinks - we do
not get ->d_revalidate() called for dentry we have arrived at, with
unpleasant consequences for NFS4.
Simple way to reproduce the problem in mainline:
cat >/tmp/a.c <<'EOF'
#include <unistd.h>
#include <fcntl.h>
#include <stdio.h>
main()
struct flock fl = {.l_type = F_RDLCK, .l_whence = SEEK_SET, .l_len = 1};
if (fcntl(0, F_SETLK, &fl))
perror("setlk");
EOF
cc /tmp/a.c -o /tmp/test
then on nfs4:
mount --bind file1 file2
/tmp/test < file1 # ok
/tmp/test < file2 # spews "setlk: No locks available"...
What happens is the missing call of ->d_revalidate() after mountpoint
crossing and that's where NFS4 would issue OPEN request to server.
The fix is simple - treat mountpoint crossing the same way we deal with
following procfs-style symlinks. I.e. set LOOKUP_JUMPED...
commit 5c8a0fbba543d9428a486f0d1282bbcf3cf1d95a upstream.
No one in their right mind would expect statfs() to not work on a
automounter managed mount point. Fix it.
[ I'm not sure about the "no one in their right mind" part. It's not
mounted, and you didn't ask for it to be mounted. But nobody will
really care, and this probably makes it match previous semantics, so..
- Linus ]
This mirrors the fix made to the quota code in 815d405ceff0d69646.
Signed-off-by: Dan McGee <dpmcgee@gmail.com>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
commit f992ae801a7dec34a4ed99a6598bbbbfb82af4fb upstream.
The following command sequence triggers an oops.
# mount /dev/sdb1 /mnt
# echo 1 > /sys/class/scsi_device/0\:0\:1\:0/device/delete
# umount /mnt
general protection fault: 0000 [#1] PREEMPT SMP
CPU 2
Modules linked in:
Pid: 791, comm: umount Not tainted 3.1.0-rc3-work+ #8 Bochs Bochs
RIP: 0010:[<ffffffff810d0879>] [<ffffffff810d0879>] __lock_acquire+0x389/0x1d60
Call Trace:
[<ffffffff810d2845>] lock_acquire+0x95/0x140
[<ffffffff81aed87b>] _raw_spin_lock+0x3b/0x50
[<ffffffff811573bc>] bdi_lock_two+0x5c/0x70
[<ffffffff811c2f6c>] bdev_inode_switch_bdi+0x4c/0xf0
[<ffffffff811c3fcb>] __blkdev_put+0x11b/0x1d0
[<ffffffff811c4010>] __blkdev_put+0x160/0x1d0
[<ffffffff811c40df>] blkdev_put+0x5f/0x190
[<ffffffff8118f18d>] kill_block_super+0x4d/0x80
[<ffffffff8118f4a5>] deactivate_locked_super+0x45/0x70
[<ffffffff8119003a>] deactivate_super+0x4a/0x70
[<ffffffff811ac4ad>] mntput_no_expire+0xed/0x130
[<ffffffff811acf2e>] sys_umount+0x7e/0x3a0
[<ffffffff81aeeeab>] system_call_fastpath+0x16/0x1b
This is because bdev holds on to disk but disk doesn't pin the
associated queue. If a SCSI device is removed while the device is
still open, the sdev puts the base reference to the queue on release.
When the bdev is finally released, the associated queue is already
gone along with the bdi and bdev_inode_switch_bdi() ends up
dereferencing already freed bdi.
Even if it were not for this bug, disk not holding onto the associated
queue is very unusual and error-prone.
Fix it by making add_disk() take an extra reference to its queue and
put it on disk_release() and ensuring that disk and its fops owner are
put in that order after all accesses to the disk and queue are
complete.
commit 6d6a435190bdf2e04c9465cde5bdc3ac68cf11a4 upstream.
Ceph users reported that when using Ceph on ext4, the filesystem
would often become corrupted, containing inodes with incorrect
i_blocks counters.
I managed to reproduce this with a very hacked-up "streamtest"
binary from the Ceph tree.
Ceph is doing a lot of xattr writes, to out-of-inode blocks.
There is also another thread which does sync_file_range and close,
of the same files. The problem appears to happen due to this race:
sync/flush thread xattr-set thread
do_writepages ext4_xattr_set
ext4_da_writepages ext4_xattr_set_handle
mpage_da_map_blocks ext4_xattr_block_set
set DELALLOC_RESERVE
ext4_new_meta_blocks
ext4_mb_new_blocks
if (!i_delalloc_reserved_flag)
vfs_dq_alloc_block
ext4_get_blocks
down_write(i_data_sem)
set i_delalloc_reserved_flag
up_write(i_data_sem)
if (i_delalloc_reserved_flag)
vfs_dq_alloc_block_nofail
In other words, the sync/flush thread pops in and sets
i_delalloc_reserved_flag on the inode, which makes the xattr thread
think that it's in a delalloc path in ext4_new_meta_blocks(),
and add the block for a second time, after already having added
it once in the !i_delalloc_reserved_flag case in ext4_mb_new_blocks
The real problem is that we shouldn't be using the DELALLOC_RESERVED
state flag, and instead we should be passing
EXT4_GET_BLOCKS_DELALLOC_RESERVE down to ext4_map_blocks() instead of
using an inode state flag. We'll fix this for now with using
i_data_sem to prevent this race, but this is really not the right way
to fix things.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
commit fcbb5515825f1bb20b7a6f75ec48bee61416f879 upstream.
The started journal handle should be stopped in failure case.
Acked-by: Jan Kara <jack@suse.cz>
commit 5930ea643805feb50a2f8383ae12eb6f10935e49 upstream.
ext4_dx_add_entry manipulates bh2 and frames[0].bh, which are two buffer_heads
that point to directory blocks assigned to the directory inode. However, the
function calls ext4_handle_dirty_metadata with the inode of the file that's
being added to the directory, not the directory inode itself. Therefore,
correct the code to dirty the directory buffers with the directory inode, not
the file inode.
Signed-off-by: Darrick J. Wong <djwong@us.ibm.com>
commit f9287c1f2d329f4d78a3bbc9cf0db0ebae6f146a upstream.
ext4_mkdir calls ext4_handle_dirty_metadata with dir_block and the inode "dir".
Unfortunately, dir_block belongs to the newly created directory (which is
"inode"), not the parent directory (which is "dir"). Fix the incorrect
association.
commit bcaa992975041e40449be8c010c26192b8c8b409 upstream.
When ext4_rename performs a directory rename (move), dir_bh is a
buffer that is modified to update the '..' link in the directory being
moved (old_inode). However, ext4_handle_dirty_metadata is called with
the old parent directory inode (old_dir) and dir_bh, which is
incorrect because dir_bh does not belong to the parent inode. Fix
this error.
commit 1cd9f0976aa4606db8d6e3dc3edd0aca8019372a upstream.
This doesn't make much sense, and it exposes a bug in the kernel where
attempts to create a new file in an append-only directory using
O_CREAT will fail (but still leave a zero-length file). This was
discovered when xfstests #79 was generalized so it could run on all
file systems.
commit a3defbe5c337dbc6da911f8cc49ae3cc3b49b453 upstream.
The case of address space randomization being disabled in runtime through
randomize_va_space sysctl is not treated properly in load_elf_binary(),
resulting in SIGKILL coming at exec() time for certain PIE-linked binaries
in case the randomization has been disabled at runtime prior to calling
exec().
Handle the randomize_va_space == 0 case the same way as if we were not
supporting .text randomization at all.
Based on original patch by H.J. Lu and Josh Boyer.
Cc: H.J. Lu <hongjiu.lu@intel.com>
Cc: <stable@kernel.org>
Tested-by: Josh Boyer <jwboyer@redhat.com>
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
commit 1fa1e7f615f4d3ae436fa319af6e4eebdd4026a8 upstream.
Since the commit below which added O_PATH support to the *at() calls, the
error return for readlink/readlinkat for the empty pathname has switched
from ENOENT to EINVAL:
commit 65cfc6722361570bfe255698d9cd4dccaf47570d
Author: Al Viro <viro@zeniv.linux.org.uk>
Date: Sun Mar 13 15:56:26 2011 -0400
readlinkat(), fchownat() and fstatat() with empty relative pathnames
This is both unexpected for userspace and makes readlink/readlinkat
inconsistant with all other interfaces; and inconsistant with our stated
return for these pathnames.
As the readlinkat call does not have a flags parameter we cannot use the
AT_EMPTY_PATH approach used in the other calls. Therefore expose whether
the original path is infact entry via a new user_path_at_empty() path
lookup function. Use this to determine whether to default to EINVAL or
ENOENT for failures.
Addresses http://bugs.launchpad.net/bugs/817187
[akpm@linux-foundation.org: remove unused getname_flags()]
Signed-off-by: Andy Whitcroft <apw@canonical.com>
commit fc360bd9cdcf875639a77f07fafec26699c546f3 upstream.
The display of the "huge" tag was accidentally removed in 29ea2f698 ("mm:
use walk_page_range() instead of custom page table walking code").
Reported-by: Stephen Hemminger <shemminger@vyatta.com>
Tested-by: Stephen Hemminger <shemminger@vyatta.com>
Reviewed-by: Stephen Wilson <wilsons@start.ca>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
commit a877ee03ac010ded434b77f7831f43cbb1fcc60f upstream.
nfsiostat was failing to find mounted filesystems on kernels after
2.6.38 because of changes to show_vfsstat() by commit
c7f404b40a3665d9f4e9a927cc5c1ee0479ed8f9. This patch adds back the
"device" tag before the nfs server entry so scripts can parse the
mountstats file correctly.
Signed-off-by: Bryan Schumaker <bjschuma@netapp.com>
commit c30e92df30d7d5fe65262fbce5d1b7de675fe34e upstream.
We don't use WANT bits yet--and sending them can probably trigger a
BUG() further down.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 3d02fa29dec920c597dd7b7db608a4bc71f088ce upstream.
Yet another open-management regression:
- nfs4_file_downgrade() doesn't remove the BOTH access bit on
downgrade, so the server's idea of the stateid's access gets
out of sync with the client's. If we want to keep an O_RDWR
open in this case, we should do that in the file_put_access
logic rather than here.
- We forgot to convert v4 access to an open mode here.
This logic has proven too hard to get right. In the future we may
consider:
- reexamining the lock/openowner relationship (locks probably
don't really need to take their own references here).
- adding open upgrade/downgrade support to the vfs.
- removing the atomic operations. They're redundant as long as
this is all under some other lock.
Also, maybe some kind of additional static checking would help catch
O_/NFS4_SHARE_ACCESS confusion.
commit a043226bc140a2c1dde162246d68a67e5043e6b2 upstream.
A client that wants to execute a file must be able to read it. Read
opens over nfs are therefore implicitly allowed for executable files
even when those files are not readable.
NFSv2/v3 get this right by using a passed-in NFSD_MAY_OWNER_OVERRIDE on
read requests, but NFSv4 has gotten this wrong ever since
dc730e173785e29b297aa605786c94adaffe2544 "nfsd4: fix owner-override on
open", when we realized that the file owner shouldn't override
permissions on non-reclaim NFSv4 opens.
So we can't use NFSD_MAY_OWNER_OVERRIDE to tell nfsd_permission to allow
reads of executable files.
So, do the same thing we do whenever we encounter another weird NFS
permission nit: define yet another NFSD_MAY_* flag.
The industry's future standardization on 128-bit processors will be
motivated primarily by the need for integers with enough bits for all
the NFSD_MAY_* flags.
Reported-by: Leonardo Borda <leonardoborda@gmail.com>
commit 576163005de286bbd418fcb99cfd0971523a0c6d upstream.
The set of errors here does *not* agree with the set of errors specified
in the rfc!
While we're there, turn this macros into a function, for the usual
reasons, and move it to the one place where it's actually used.
commit 3e77246393c0a433247631a1f0e9ec98d3d78a1c upstream.
The server is returning nfserr_resource for both permanent errors and
for errors (like allocation failures) that might be resolved by retrying
later. Save nfserr_resource for the former and use delay/jukebox for
the latter.
commit 832023bffb4b493f230be901f681020caf3ed1f8 upstream.
Fan Yong <yong.fan@whamcloud.com> noticed setting
FMODE_32bithash wouldn't work with nfsd v4, as
nfsd4_readdir() checks for 32 bit cookies. However, according to RFC 3530
cookies have a 64 bit type and cookies are also defined as u64 in
'struct nfsd4_readdir'. So remove the test for >32-bit values.
Signed-off-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de>
commit 2da956523526e440ef4f4dd174e26f5ac06fe011 upstream.
nfs_find_and_lock_request will take a reference to the nfs_page and
will then put it if the req is already locked. It's possible though
that the reference will be the last one. That put then can kick off
a whole series of reference puts:
nfs_page
nfs_open_context
dentry
inode
If the inode ends up being deleted, then the VFS will call
truncate_inode_pages. That function will try to take the page lock, but
it was already locked when migrate_page was called. The code
deadlocks.
Fix this by simply refusing the migration request if PagePrivate is
already set, indicating that the page is already associated with an
active read or write request.
We've had a customer test a backported version of this patch and
the preliminary results seem good.
Reported-by: Harshula Jayasuriya <harshula@redhat.com>
commit 3236c3e1adc0c7ec83eaff1de2d06746b7c5bb28 upstream.
commit 420e3646 allowed the kernel to reduce the number of unnecessary
commit calls by skipping the commit when there are a large number of
outstanding pages.
However, the current test in nfs_commit_unstable_pages does not handle
the edge condition properly. When ncommit == 0, then that means that the
kernel doesn't need to do anything more for the inode. The current test
though in the WB_SYNC_NONE case will return true, and the inode will end
up being marked dirty. Once that happens the inode will never be clean
until there's a WB_SYNC_ALL flush.
Fix this by immediately returning from nfs_commit_unstable_pages when
ncommit == 0.
Mike noticed this problem initially in RHEL5 (2.6.18-based kernel) which
has a backported version of 420e3646. The inode cache there was growing
very large. The inode cache was unable to be shrunk since the inodes
were all marked dirty. Calling sync() would essentially "fix" the
problem -- the WB_SYNC_ALL flush would result in the inodes all being
marked clean.
What I'm not clear on is how big a problem this is in mainline kernels
as the writeback code there is very different. Either way, it seems
incorrect to re-mark the inode dirty in this case.
Reported-by: Mike McLean <mikem@redhat.com>
commit c1225158a8dad9e9d5eee8a17dbbd9c7cda05ab9 upstream.
The same function is used by idmap, gss and blocklayout code. Make it
generic.
Signed-off-by: Peng Tao <peng_tao@emc.com>
Signed-off-by: Jim Rees <rees@umich.edu>
syncing"
commit 59b7c05fffba030e5d9e72324691e2f99aa69b79 upstream.
This reverts commit b80c3cb628f0ebc241b02e38dd028969fb8026a2.
The reverted commit was rendered obsolete by a VFS fix: commit
5547e8aac6f71505d621a612de2fca0dd988b439 (writeback: Update dirty flags in
two steps). We now no longer need to worry about writeback_single_inode()
missing our marking the inode for COMMIT in 'do_writepages()' call.
Reverting this patch, fixes a performance regression in which the inode
would continuously get queued to the dirty list, causing the writeback
code to unnecessarily try to send a COMMIT.
Tested-by: Simon Kirby <sim@hostway.ca>
commit 7542274519b3ba87555410c66e8356ac1e3bc9b3 upstream.
We should check if the sector is already initialized before
trying to grab the page from page cache. Otherwise when two
pages of the same block are written back by two threads each
calling from writepage_locked, it can cause deadlock like bellow.
[ 1080.972099] INFO: task kswapd0:25 blocked for more than 120 seconds.
[ 1080.972377] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 1080.972812] kswapd0 D ffff88000c4926c0 0 25 2 0x00000000
[ 1080.972816] ffff88000df276b0 0000000000000046 ffff88000df27640 ffffffff81013ba7
[ 1080.972821] ffff88000c492310 ffff88000df27fd8 ffff88000df27fd8 00000000001d3440
[ 1080.972824] ffff88000c378000 ffff88000c492310 ffff8800175d3d40 ffff880017fc75a8
[ 1080.972828] Call Trace:
[ 1080.972860] [<ffffffff81013ba7>] ? read_tsc+0x9/0x19
[ 1080.972877] [<ffffffff810e0b23>] ? lock_page+0x2b/0x2b
[ 1080.972899] [<ffffffff81475a1d>] io_schedule+0x63/0x7e
[ 1080.972902] [<ffffffff810e0b31>] sleep_on_page+0xe/0x12
[ 1080.972905] [<ffffffff81475fe8>] __wait_on_bit_lock+0x46/0x8f
[ 1080.972916] [<ffffffff810822d7>] ? lock_release_holdtime.part.7+0x6b/0x72
[ 1080.972919] [<ffffffff810e0af6>] __lock_page+0x66/0x68
[ 1080.972928] [<ffffffff81072705>] ? autoremove_wake_function+0x3d/0x3d
[ 1080.972932] [<ffffffff810e0b1f>] lock_page+0x27/0x2b
[ 1080.972934] [<ffffffff810e0bcf>] find_lock_page+0x34/0x57
[ 1080.972937] [<ffffffff810e1738>] find_or_create_page+0x34/0x8a
[ 1080.972947] [<ffffffffa034245b>] bl_write_pagelist+0x205/0x6da [blocklayoutdriver]
[ 1080.972951] [<ffffffffa034145d>] ? bl_free_lseg+0x38/0x38 [blocklayoutdriver]
[ 1080.972995] [<ffffffffa02e27b9>] ? nfs_write_rpcsetup+0x118/0x123 [nfs]
[ 1080.973033] [<ffffffffa030246b>] pnfs_generic_pg_writepages+0x10b/0x1f4 [nfs]
[ 1080.973089] [<ffffffffa02deaae>] nfs_pageio_doio+0x1a/0x43 [nfs]
[ 1080.973098] [<ffffffffa02df035>] nfs_pageio_complete+0x16/0x2d [nfs]
[ 1080.973108] [<ffffffffa02e2d8f>] nfs_writepage_locked+0xa0/0xbf [nfs]
[ 1080.973119] [<ffffffffa02e36a1>] nfs_writepage+0x16/0x2b [nfs]
[ 1080.973122] [<ffffffff810e8762>] ? clear_page_dirty_for_io+0x87/0x9a
[ 1080.973133] [<ffffffff810efc5b>] shrink_page_list+0x39b/0x6c8
[ 1080.973139] [<ffffffff810f03bb>] shrink_inactive_list+0x22c/0x39e
[ 1080.973144] [<ffffffff810822d7>] ? lock_release_holdtime.part.7+0x6b/0x72
[ 1080.973148] [<ffffffff810f0c33>] shrink_zone+0x445/0x588
[ 1080.973152] [<ffffffff810f1a11>] balance_pgdat+0x2c2/0x56b
[ 1080.973170] [<ffffffff81254208>] ? __bitmap_weight+0x34/0x80
[ 1080.973175] [<ffffffff810f1f78>] kswapd+0x2be/0x2fa
[ 1080.973179] [<ffffffff810726c8>] ? __init_waitqueue_head+0x4b/0x4b
[ 1080.973183] [<ffffffff810f1cba>] ? balance_pgdat+0x56b/0x56b
[ 1080.973187] [<ffffffff81071f69>] kthread+0xa8/0xb0
[ 1080.973200] [<ffffffff814806b4>] kernel_thread_helper+0x4/0x10
[ 1080.973205] [<ffffffff81071ec1>] ? __init_kthread_worker+0x5a/0x5a
[ 1080.973210] [<ffffffff814806b0>] ? gs_change+0x13/0x13
[ 1080.973213] no locks held by kswapd0/25.
commit e6d05a757c314ad88d0649d3835a8a1daa964236 upstream.
bl_add_page_to_bio returns error pointer. bio should be reset to
NULL in failure cases as the out path always calls bl_submit_bio.
