path: root/fs
2014-12-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile #3 from Al Viro: "Assorted fixes and patches from the last cycle" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: [regression] chunk lost from bd9b51 vfs: make mounts and mountstats honor root dir like mountinfo does vfs: cleanup show_mountinfo init: fix read-write root mount unfuck binfmt_misc.c (broken by commit e6084d4) vm_area_operations: kill ->migrate() new helper: iter_is_iovec() move_extent_per_page(): get rid of unused w_flags lustre: get rid of playing with ->fs btrfs: filp_open() returns ERR_PTR() on failure, not NULL...
2014-12-19Merge tag 'ecryptfs-3.19-rc1-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs Pull eCryptfs fixes from Tyler Hicks: "Fixes for filename decryption and encrypted view plus a cleanup - The filename decryption routines were, at times, writing a zero byte one character past the end of the filename buffer - The encrypted view feature attempted, and failed, to roll its own form of enforcing a read-only mount instead of letting the VFS enforce it" * tag 'ecryptfs-3.19-rc1-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs: eCryptfs: Remove buggy and unnecessary write in file name decode routine eCryptfs: Remove unnecessary casts when parsing packet lengths eCryptfs: Force RO mount when encrypted view is enabled
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull more btrfs updates from Chris Mason: "This is part two of our merge window patches. These are all from Filipe, and fix some really hard to find races that can cause corruptions. Most of them involved block group removal (balance) or discard" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: remove non-sense btrfs_error_discard_extent() function Btrfs: fix fs corruption on transaction abort if device supports discard Btrfs: always clear a block group node when removing it from the tree Btrfs: ensure deletion from pinned_chunks list is protected
2014-12-19Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq core fix from Thomas Gleixner: "A single fix plugging a long standing race between proc/stat and proc/interrupts access and freeing of interrupt descriptors" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: genirq: Prevent proc race against freeing of irq descriptors
2014-12-18Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge misc patches from Andrew Morton: "A few stragglers" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: tools/testing/selftests/Makefile: alphasort the TARGETS list mm/zsmalloc: adjust order of functions ocfs2: fix journal commit deadlock ocfs2/dlm: fix race between dispatched_work and dlm_lockres_grab_inflight_worker ocfs2: reflink: fix slow unlink for refcounted file mm/memory.c:do_shared_fault(): add comment .mailmap: Santosh Shilimkar has moved .mailmap: update akpm@osdl.org lib/show_mem.c: add cma reserved information fs/proc/meminfo.c: include cma info in proc/meminfo mm: cma: split cma-reserved in dmesg log hfsplus: fix longname handling mm/mempolicy.c: remove unnecessary is_valid_nodemask()
2014-12-18ocfs2: fix journal commit deadlockJunxiao Bi
For buffer write, page lock will be got in write_begin and released in write_end, in ocfs2_write_end_nolock(), before it unlock the page in ocfs2_free_write_ctxt(), it calls ocfs2_run_deallocs(), this will ask for the read lock of journal->j_trans_barrier. Holding page lock and ask for journal->j_trans_barrier breaks the locking order. This will cause a deadlock with journal commit threads, ocfs2cmt will get write lock of journal->j_trans_barrier first, then it wakes up kjournald2 to do the commit work, at last it waits until done. To commit journal, kjournald2 needs flushing data first, it needs get the cache page lock. Since some ocfs2 cluster locks are holding by write process, this deadlock may hung the whole cluster. unlock pages before ocfs2_run_deallocs() can fix the locking order, also put unlock before ocfs2_commit_trans() to make page lock is unlocked before j_trans_barrier to preserve unlocking order. Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com> Reviewed-by: Wengang Wang <wen.gang.wang@oracle.com> Cc: <stable@vger.kernel.org> Reviewed-by: Mark Fasheh <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-18ocfs2/dlm: fix race between dispatched_work and dlm_lockres_grab_inflight_workerJoseph Qi
Commit ac4fef4d23ed ("ocfs2/dlm: do not purge lockres that is queued for assert master") may have the following possible race case: dlm_dispatch_assert_master dlm_wq ======================================================================== queue_work(dlm->quedlm_worker, &dlm->dispatched_work); dispatch work, dlm_lockres_drop_inflight_worker *BUG_ON(res->inflight_assert_workers == 0)* dlm_lockres_grab_inflight_worker inflight_assert_workers++ So ensure inflight_assert_workers to be increased first. Signed-off-by: Joseph Qi <joseph.qi@huawei.com> Signed-off-by: Xue jiufei <xuejiufei@huawei.com> Cc: Joel Becker <jlbec@evilplan.org> Reviewed-by: Mark Fasheh <mfasheh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-18ocfs2: reflink: fix slow unlink for refcounted fileJunxiao Bi
When running ocfs2 test suite multiple nodes reflink stress test, for a 4 nodes cluster, every unlink() for refcounted file needs about 700s. The slow unlink is caused by the contention of refcount tree lock since all nodes are unlink files using the same refcount tree. When the unlinking file have many extents(over 1600 in our test), most of the extents has refcounted flag set. In ocfs2_commit_truncate(), it will execute the following call trace for every extents. This means it needs get and released refcount tree lock about 1600 times. And when several nodes are do this at the same time, the performance will be very low. ocfs2_remove_btree_range() -- ocfs2_lock_refcount_tree() ---- ocfs2_refcount_lock() ------ __ocfs2_cluster_lock() ocfs2_refcount_lock() is costly, move it to ocfs2_commit_truncate() to do lock/unlock once can improve a lot performance. Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com> Cc: Wengang <wen.gang.wang@oracle.com> Reviewed-by: Mark Fasheh <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-18fs/proc/meminfo.c: include cma info in proc/meminfoPintu Kumar
This patch include CMA info (CMATotal, CMAFree) in /proc/meminfo. Currently, in a CMA enabled system, if somebody wants to know the total CMA size declared, there is no way to tell, other than the dmesg or /var/log/messages logs. With this patch we are showing the CMA info as part of meminfo, so that it can be determined at any point of time. This will be populated only when CMA is enabled. Below is the sample output from a ARM based device with RAM:512MB and CMA:16MB. MemTotal: 471172 kB MemFree: 111712 kB MemAvailable: 271172 kB . . . CmaTotal: 16384 kB CmaFree: 6144 kB This patch also fix below checkpatch errors that were found during these changes. ERROR: space required after that ',' (ctx:ExV) 199: FILE: fs/proc/meminfo.c:199: + ,atomic_long_read(&num_poisoned_pages) << (PAGE_SHIFT - 10) ^ ERROR: space required after that ',' (ctx:ExV) 202: FILE: fs/proc/meminfo.c:202: + ,K(global_page_state(NR_ANON_TRANSPARENT_HUGEPAGES) * ^ ERROR: space required after that ',' (ctx:ExV) 206: FILE: fs/proc/meminfo.c:206: + ,K(totalcma_pages) ^ total: 3 errors, 0 warnings, 2 checks, 236 lines checked Signed-off-by: Pintu Kumar <pintu.k@samsung.com> Signed-off-by: Vishnu Pratap Singh <vishnu.ps@samsung.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Cc: Rafael Aquini <aquini@redhat.com> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-18hfsplus: fix longname handlingSougata Santra
Longname is not correctly handled by hfsplus driver. If an attempt to create a longname(>255) file/directory is made, it succeeds by creating a file/directory with HFSPLUS_MAX_STRLEN and incorrect catalog key. Thus leaving the volume in an inconsistent state. This patch fixes this issue. Although lookup is always called first to create a negative entry, so just doing a check in lookup would probably fix this issue. I choose to propagate error to other iops as well. Please NOTE: I have factored out hfsplus_cat_build_key_with_cnid from hfsplus_cat_build_key, to avoid unncessary branching. Thanks a lot. TEST: ------ dir="TEST_DIR" cdir=`pwd` name255="_123456789_123456789_123456789_123456789_123456789_123456789\ _123456789_123456789_123456789_123456789_123456789_123456789_123456789\ _123456789_123456789_123456789_123456789_123456789_123456789_123456789\ _123456789_123456789_123456789_123456789_123456789_1234" name256="${name255}5" mkdir $dir cd $dir touch $name255 rm -f $name255 touch $name256 ls -la cd $cdir rm -rf $dir RESULT: ------- [sougata@ultrabook tmp]$ cdir=`pwd` [sougata@ultrabook tmp]$ name255="_123456789_123456789_123456789_123456789_123456789_123456789\ > _123456789_123456789_123456789_123456789_123456789_123456789_123456789\ > _123456789_123456789_123456789_123456789_123456789_123456789_123456789\ > _123456789_123456789_123456789_123456789_123456789_1234" [sougata@ultrabook tmp]$ name256="${name255}5" [sougata@ultrabook tmp]$ [sougata@ultrabook tmp]$ mkdir $dir [sougata@ultrabook tmp]$ cd $dir [sougata@ultrabook TEST_DIR]$ touch $name255 [sougata@ultrabook TEST_DIR]$ rm -f $name255 [sougata@ultrabook TEST_DIR]$ touch $name256 [sougata@ultrabook TEST_DIR]$ ls -la ls: cannot access _123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_1234: No such file or directory total 0 drwxrwxr-x 1 sougata sougata 3 Feb 20 19:56 . drwxrwxrwx 1 root root 6 Feb 20 19:56 .. -????????? ? ? ? ? ? _123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_1234 [sougata@ultrabook TEST_DIR]$ cd $cdir [sougata@ultrabook tmp]$ rm -rf $dir rm: cannot remove `TEST_DIR': Directory not empty -ENAMETOOLONG returned from hfsplus_asc2uni was not propaged to iops. This allowed hfsplus to create files/directories with HFSPLUS_MAX_STRLEN and incorrect keys, leaving the FS in an inconsistent state. This patch fixes this issue. Signed-off-by: Sougata Santra <sougata@tuxera.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-18mnt: Fix a memory stomp in umountEric W. Biederman
While reviewing the code of umount_tree I realized that when we append to a preexisting unmounted list we do not change pprev of the former first item in the list. Which means later in namespace_unlock hlist_del_init(&mnt->mnt_hash) on the former first item of the list will stomp unmounted.first leaving it set to some random mount point which we are likely to free soon. This isn't likely to hit, but if it does I don't know how anyone could track it down. [ This happened because we don't have all the same operations for hlist's as we do for normal doubly-linked lists. In particular, list_splice() is easy on our standard doubly-linked lists, while hlist_splice() doesn't exist and needs both start/end entries of the hlist. And commit 38129a13e6e7 incorrectly open-coded that missing hlist_splice(). We should think about making these kinds of "mindless" conversions easier to get right by adding the missing hlist helpers - Linus ] Fixes: 38129a13e6e71f666e0468e99fdd932a687b4d7e switch mnt_hash to hlist Cc: stable@vger.kernel.org Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-17Ceph: remove left-over reject fileLinus Torvalds
Neither Sage nor I noticed that Zheng Yan had mistakenly committed fs/ceph/super.h.rej as part of commit 31c542a199d7 ("ceph: add inline data to pagecache"). Remove it. Requested-by: Yan, Zheng <ukernel@gmail.com> Cc: Sage Weil <sweil@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull ceph updates from Sage Weil: "The big item here is support for inline data for CephFS and for message signatures from Zheng. There are also several bug fixes, including interrupted flock request handling, 0-length xattrs, mksnap, cached readdir results, and a message version compat field. Finally there are several cleanups from Ilya, Dan, and Markus. Note that there is another series coming soon that fixes some bugs in the RBD 'lingering' requests, but it isn't quite ready yet" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (27 commits) ceph: fix setting empty extended attribute ceph: fix mksnap crash ceph: do_sync is never initialized libceph: fixup includes in pagelist.h ceph: support inline data feature ceph: flush inline version ceph: convert inline data to normal data before data write ceph: sync read inline data ceph: fetch inline data when getting Fcr cap refs ceph: use getattr request to fetch inline data ceph: add inline data to pagecache ceph: parse inline data in MClientReply and MClientCaps libceph: specify position of extent operation libceph: add CREATE osd operation support libceph: add SETXATTR/CMPXATTR osd operations support rbd: don't treat CEPH_OSD_OP_DELETE as extent op ceph: remove unused stringification macros libceph: require cephx message signature by default ceph: introduce global empty snap context ceph: message versioning fixes ...
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace related fixes from Eric Biederman: "As these are bug fixes almost all of thes changes are marked for backporting to stable. The first change (implicitly adding MNT_NODEV on remount) addresses a regression that was created when security issues with unprivileged remount were closed. I go on to update the remount test to make it easy to detect if this issue reoccurs. Then there are a handful of mount and umount related fixes. Then half of the changes deal with the a recently discovered design bug in the permission checks of gid_map. Unix since the beginning has allowed setting group permissions on files to less than the user and other permissions (aka ---rwx---rwx). As the unix permission checks stop as soon as a group matches, and setgroups allows setting groups that can not later be dropped, results in a situtation where it is possible to legitimately use a group to assign fewer privileges to a process. Which means dropping a group can increase a processes privileges. The fix I have adopted is that gid_map is now no longer writable without privilege unless the new file /proc/self/setgroups has been set to permanently disable setgroups. The bulk of user namespace using applications even the applications using applications using user namespaces without privilege remain unaffected by this change. Unfortunately this ix breaks a couple user space applications, that were relying on the problematic behavior (one of which was tools/selftests/mount/unprivileged-remount-test.c). To hopefully prevent needing a regression fix on top of my security fix I rounded folks who work with the container implementations mostly like to be affected and encouraged them to test the changes. > So far nothing broke on my libvirt-lxc test bed. :-) > Tested with openSUSE 13.2 and libvirt 1.2.9. > Tested-by: Richard Weinberger <richard@nod.at> > Tested on Fedora20 with libvirt 1.2.11, works fine. > Tested-by: Chen Hanxiao <chenhanxiao@cn.fujitsu.com> > Ok, thanks - yes, unprivileged lxc is working fine with your kernels. > Just to be sure I was testing the right thing I also tested using > my unprivileged nsexec testcases, and they failed on setgroup/setgid > as now expected, and succeeded there without your patches. > Tested-by: Serge Hallyn <serge.hallyn@ubuntu.com> > I tested this with Sandstorm. It breaks as is and it works if I add > the setgroups thing. > Tested-by: Andy Lutomirski <luto@amacapital.net> # breaks things as designed :(" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: userns: Unbreak the unprivileged remount tests userns; Correct the comment in map_write userns: Allow setting gid_maps without privilege when setgroups is disabled userns: Add a knob to disable setgroups on a per user namespace basis userns: Rename id_map_mutex to userns_state_mutex userns: Only allow the creator of the userns unprivileged mappings userns: Check euid no fsuid when establishing an unprivileged uid mapping userns: Don't allow unprivileged creation of gid mappings userns: Don't allow setgroups until a gid mapping has been setablished userns: Document what the invariant required for safe unprivileged mappings. groups: Consolidate the setgroups permission checks mnt: Clear mnt_expire during pivot_root mnt: Carefully set CL_UNPRIVILEGED in clone_mnt mnt: Move the clear of MNT_LOCKED from copy_tree to it's callers. umount: Do not allow unmounting rootfs. umount: Disallow unprivileged mount force mnt: Update unprivileged remount test mnt: Implicitly add MNT_NODEV on remount when it was implicitly added by mount
2014-12-17Merge tag 'for-linus-20141215' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD updates from Brian Norris: "Summary: - Add device tree support for DoC3 - SPI NOR: Refactoring, for better layering between spi-nor.c and its driver users (e.g., m25p80.c) New flash device support Support 6-byte ID strings - NAND: New NAND driver for Allwinner SoC's (sunxi) GPMI NAND: add support for raw (no ECC) access, for testing purposes Add ATO manufacturer ID A few odd driver fixes - MTD tests: Allow testers to compensate for OOB bitflips in oobtest Fix a torturetest regression - nandsim: Support longer ID byte strings And more" * tag 'for-linus-20141215' of git://git.infradead.org/linux-mtd: (63 commits) mtd: tests: abort torturetest on erase errors mtd: physmap_of: fix potential NULL dereference mtd: spi-nor: allow NULL as chip name and try to auto detect it mtd: nand: gpmi: add raw oob access functions mtd: nand: gpmi: add proper raw access support mtd: nand: gpmi: add gpmi_copy_bits function mtd: spi-nor: factor out write_enable() for erase commands mtd: spi-nor: add support for s25fl128s mtd: spi-nor: remove the jedec_id/ext_id mtd: spi-nor: add id/id_len for flash_info{} mtd: nand: correct the comment of function nand_block_isreserved() jffs2: Drop bogus if in comment mtd: atmel_nand: replace memcpy32_toio/memcpy32_fromio with memcpy mtd: cafe_nand: drop duplicate .write_page implementation mtd: m25p80: Add support for serial flash Spansion S25FL132K MTD: m25p80: fix inconsistency in m25p_ids compared to spi_nor_ids mtd: spi-nor: improve wait-till-ready timeout loop mtd: delete unnecessary checks before two function calls mtd: nand: omap: Fix NAND enumeration on 3430 LDP mtd: nand: add ATO manufacturer info ...
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse Pull fuse update from Miklos Szeredi: "The first part makes sure we don't hold up umount with pending async requests. In addition to being a cleanup, this is a small behavioral change (for the better) and unlikely to break anything. The second part prepares for a cleanup of the fuse device I/O code by adding a helper for simple request submission, with some savings in line numbers already realized" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: use file_inode() in fuse_file_fallocate() fuse: introduce fuse_simple_request() helper fuse: reduce max out args fuse: hold inode instead of path after release fuse: flush requests on umount fuse: don't wake up reserved req in fuse_conn_kill()
2014-12-17ceph: fix setting empty extended attributeYan, Zheng
make sure 'value' is not null. otherwise __ceph_setxattr will remove the extended attribute. Signed-off-by: Yan, Zheng <zyan@redhat.com> Reviewed-by: Sage Weil <sage@redhat.com>
2014-12-17ceph: fix mksnap crashYan, Zheng
mksnap reply only contain 'target', does not contain 'dentry'. So it's wrong to use req->r_reply_info.head->is_dentry to detect traceless reply. Signed-off-by: Yan, Zheng <zyan@redhat.com> Reviewed-by: Sage Weil <sage@redhat.com>
2014-12-17ceph: do_sync is never initializedDan Carpenter
Probably this code was syncing a lot more often then intended because the do_sync variable wasn't set to zero. Cc: stable@vger.kernel.org # v3.11+ Fixes: c62988ec0910 ('ceph: avoid meaningless calling ceph_caps_revoking if sync_mode == WB_SYNC_ALL.') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Ilya Dryomov <idryomov@redhat.com>
2014-12-17ceph: support inline data featureYan, Zheng
2014-12-17ceph: flush inline versionYan, Zheng
After converting inline data to normal data, client need to flush the new i_inline_version (CEPH_INLINE_NONE) to MDS. This commit makes cap messages (sent to MDS) contain inline_version and inline_data. Client always converts inline data to normal data before data write, so the inline data length part is always zero. Signed-off-by: Yan, Zheng <zyan@redhat.com>
2014-12-17ceph: convert inline data to normal data before data writeYan, Zheng
Before any data write, convert inline data to normal data and set i_inline_version to CEPH_INLINE_NONE. The OSD request that saves inline data to object contains 3 operations (CMPXATTR, WRITE and SETXATTR). It compares a xattr named 'inline_version' to prevent old data overwrites newer data. Signed-off-by: Yan, Zheng <zyan@redhat.com>
2014-12-17ceph: sync read inline dataYan, Zheng
we can't use getattr to fetch inline data while holding Fr cap, because it can cause deadlock. If we need to sync read inline data, drop cap refs first, then use getattr to fetch inline data. Signed-off-by: Yan, Zheng <zyan@redhat.com>
2014-12-17ceph: fetch inline data when getting Fcr cap refsYan, Zheng
we can't use getattr to fetch inline data after getting Fcr caps, because it can cause deadlock. The solution is try bringing inline data to page cache when not holding any cap, and hope the inline data page is still there after getting the Fcr caps. If the page is still there, pin it in page cache for later IO. Signed-off-by: Yan, Zheng <zyan@redhat.com>
2014-12-17ceph: use getattr request to fetch inline dataYan, Zheng
Add a new parameter 'locked_page' to ceph_do_getattr(). If inline data in getattr reply will be copied to the page. Signed-off-by: Yan, Zheng <zyan@redhat.com>
2014-12-17ceph: add inline data to pagecacheYan, Zheng
Request reply and cap message can contain inline data. add inline data to the page cache if there is Fc cap. Signed-off-by: Yan, Zheng <zyan@redhat.com>
2014-12-17ceph: parse inline data in MClientReply and MClientCapsYan, Zheng
2014-12-17libceph: specify position of extent operationYan, Zheng
allow specifying position of extent operation in multi-operations osd request. This is required for cephfs to convert inline data to normal data (compare xattr, then write object). Signed-off-by: Yan, Zheng <zyan@redhat.com> Reviewed-by: Ilya Dryomov <idryomov@redhat.com>
2014-12-17ceph: remove unused stringification macrosIlya Dryomov
These were used to report git versions a long time ago. Signed-off-by: Ilya Dryomov <idryomov@redhat.com>
2014-12-17ceph: introduce global empty snap contextYan, Zheng
Current snaphost code does not properly handle moving inode from one empty snap realm to another empty snap realm. After changing inode's snap realm, some dirty pages' snap context can be not equal to inode's i_head_snap. This can trigger BUG() in ceph_put_wrbuffer_cap_refs() The fix is introduce a global empty snap context for all empty snap realm. This avoids triggering the BUG() for filesystem with no snapshot. Fixes: http://tracker.ceph.com/issues/9928 Signed-off-by: Yan, Zheng <zyan@redhat.com> Reviewed-by: Ilya Dryomov <idryomov@redhat.com>
2014-12-17ceph: message versioning fixesJohn Spray
There were two places we were assigning version in host byte order instead of network byte order. Also in MSG_CLIENT_SESSION we weren't setting compat_version in the header to reflect continued compatability with older MDSs. Fixes: http://tracker.ceph.com/issues/9945 Signed-off-by: John Spray <john.spray@redhat.com> Reviewed-by: Sage Weil <sage@redhat.com>
2014-12-17libceph: message signature supportYan, Zheng
2014-12-17ceph, rbd: delete unnecessary checks before two function callsSF Markus Elfring
The functions ceph_put_snap_context() and iput() test whether their argument is NULL and then return immediately. Thus the test around the call is not needed. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> [idryomov@redhat.com: squashed rbd.c hunk, changelog] Signed-off-by: Ilya Dryomov <idryomov@redhat.com>
2014-12-17ceph: introduce a new inode flag indicating if cached dentries are orderedYan, Zheng
After creating/deleting/renaming file, offsets of sibling dentries may change. So we can not use cached dentries to satisfy readdir. But we can still use the cached dentries to conclude -ENOENT for lookup. This patch introduces a new inode flag indicating if child dentries are ordered. The flag is set at the same time marking a directory complete. After creating/deleting/renaming file, we clear the flag on directory inode. This prevents ceph_readdir() from using cached dentries to satisfy readdir syscall. Signed-off-by: Yan, Zheng <zyan@redhat.com>
2014-12-17ceph: fix file lock interruptionYan, Zheng
When a lock operation is interrupted, current code sends a unlock request to MDS to undo the lock operation. This method does not work as expected because the unlock request can drop locks that have already been acquired. The fix is use the newly introduced CEPH_LOCK_FCNTL_INTR/CEPH_LOCK_FLOCK_INTR requests to interrupt blocked file lock request. These requests do not drop locks that have alread been acquired, they only interrupt blocked file lock request. Signed-off-by: Yan, Zheng <zyan@redhat.com>
2014-12-17vfs: make mounts and mountstats honor root dir like mountinfo doesDmitry V. Levin
As we already show mountpoints relative to the root directory, thanks to the change made back in 2000, change show_vfsmnt() and show_vfsstat() to skip out-of-root mountpoints the same way as show_mountinfo() does. Signed-off-by: Dmitry V. Levin <ldv@altlinux.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-12-17vfs: cleanup show_mountinfoDmitry V. Levin
Starting with commit v3.2-rc4-1-g02125a8, seq_path_root() no longer changes the value of its "struct path *root" argument. Starting with commit v3.2-rc7-104-g8c9379e, the "struct path *root" argument of seq_path_root() is const. As result, the temporary variable "root" in show_mountinfo() that holds a copy of struct path root is no longer needed. Signed-off-by: Dmitry V. Levin <ldv@altlinux.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-12-17unfuck binfmt_misc.c (broken by commit e6084d4)Al Viro
scanarg(s, del) never returns s; the empty field results in s + 1. Restore the correct checks, and move NUL-termination into scanarg(), while we are at it. Incidentally, mixing "coding style cleanups" (for small values of cleanup) with functional changes is a Bad Idea(tm)... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-12-17vm_area_operations: kill ->migrate()Al Viro
the only instance this method has ever grown was one in kernfs - one that call ->migrate() of another vm_ops if it exists. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-12-17move_extent_per_page(): get rid of unused w_flagsAl Viro
... and comparing get_fs() with KERNEL_DS used only to initialize that Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-12-17btrfs: filp_open() returns ERR_PTR() on failure, not NULL...Al Viro
2014-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile #2 from Al Viro: "Next pile (and there'll be one or two more). The large piece in this one is getting rid of /proc/*/ns/* weirdness; among other things, it allows to (finally) make nameidata completely opaque outside of fs/namei.c, making for easier further cleanups in there" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: coda_venus_readdir(): use file_inode() fs/namei.c: fold link_path_walk() call into path_init() path_init(): don't bother with LOOKUP_PARENT in argument fs/namei.c: new helper (path_cleanup()) path_init(): store the "base" pointer to file in nameidata itself make default ->i_fop have ->open() fail with ENXIO make nameidata completely opaque outside of fs/namei.c kill proc_ns completely take the targets of /proc/*/ns/* symlinks to separate fs bury struct proc_ns in fs/proc copy address of proc_ns_ops into ns_common new helpers: ns_alloc_inum/ns_free_inum make proc_ns_operations work with struct ns_common * instead of void * switch the rest of proc_ns_operations to working with &...->ns netns: switch ->get()/->put()/->install()/->inum() to working with &net->ns make mntns ->get()/->put()/->install()/->inum() work with &mnt_ns->ns common object embedded into various struct ....ns
2014-12-16Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull isofs and reiserfs fixes from Jan Kara: "A reiserfs and an isofs fix. They arrived after I sent you my first pull request and I don't want to delay them unnecessarily till rc2" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: isofs: Fix infinite looping over CE entries reiserfs: destroy allocated commit workqueue
2014-12-16Merge branch 'for-3.19' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd updates from Bruce Fields: "A comparatively quieter cycle for nfsd this time, but still with two larger changes: - RPC server scalability improvements from Jeff Layton (using RCU instead of a spinlock to find idle threads). - server-side NFSv4.2 ALLOCATE/DEALLOCATE support from Anna Schumaker, enabling fallocate on new clients" * 'for-3.19' of git://linux-nfs.org/~bfields/linux: (32 commits) nfsd4: fix xdr4 count of server in fs_location4 nfsd4: fix xdr4 inclusion of escaped char sunrpc/cache: convert to use string_escape_str() sunrpc: only call test_bit once in svc_xprt_received fs: nfsd: Fix signedness bug in compare_blob sunrpc: add some tracepoints around enqueue and dequeue of svc_xprt sunrpc: convert to lockless lookup of queued server threads sunrpc: fix potential races in pool_stats collection sunrpc: add a rcu_head to svc_rqst and use kfree_rcu to free it sunrpc: require svc_create callers to pass in meaningful shutdown routine sunrpc: have svc_wake_up only deal with pool 0 sunrpc: convert sp_task_pending flag to use atomic bitops sunrpc: move rq_cachetype field to better optimize space sunrpc: move rq_splice_ok flag into rq_flags sunrpc: move rq_dropme flag into rq_flags sunrpc: move rq_usedeferral flag to rq_flags sunrpc: move rq_local field to rq_flags sunrpc: add a generic rq_flags field to svc_rqst and move rq_secure to it nfsd: minor off by one checks in __write_versions() sunrpc: release svc_pool_map reference when serv allocation fails ...
2014-12-15isofs: Fix infinite looping over CE entriesJan Kara
Rock Ridge extensions define so called Continuation Entries (CE) which define where is further space with Rock Ridge data. Corrupted isofs image can contain arbitrarily long chain of these, including a one containing loop and thus causing kernel to end in an infinite loop when traversing these entries. Limit the traversal to 32 entries which should be more than enough space to store all the Rock Ridge data. Reported-by: P J P <ppandit@redhat.com> CC: stable@vger.kernel.org Signed-off-by: Jan Kara <jack@suse.cz>
2014-12-14Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security layer updates from James Morris: "In terms of changes, there's general maintenance to the Smack, SELinux, and integrity code. The IMA code adds a new kconfig option, IMA_APPRAISE_SIGNED_INIT, which allows IMA appraisal to require signatures. Support for reading keys from rootfs before init is call is also added" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (23 commits) selinux: Remove security_ops extern security: smack: fix out-of-bounds access in smk_parse_smack() VFS: refactor vfs_read() ima: require signature based appraisal integrity: provide a hook to load keys when rootfs is ready ima: load x509 certificate from the kernel integrity: provide a function to load x509 certificate from the kernel integrity: define a new function integrity_read_file() Security: smack: replace kzalloc with kmem_cache for inode_smack Smack: Lock mode for the floor and hat labels ima: added support for new kernel cmdline parameter ima_template_fmt ima: allocate field pointers array on demand in template_desc_init_fields() ima: don't allocate a copy of template_fmt in template_desc_init_fields() ima: display template format in meas. list if template name length is zero ima: added error messages to template-related functions ima: use atomic bit operations to protect policy update interface ima: ignore empty and with whitespaces policy lines ima: no need to allocate entry for comment ima: report policy load status ima: use path names cache ...
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-12-14Merge tag 'squashfs-updates' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-next Pull squashfs update from Phillip Lougher: "These patches optionally add LZ4 compression support to Squashfs. LZ4 is a lightweight compression algorithm which can be used on embedded systems to reduce CPU and memory overhead (in comparison to the standard zlib compression). These patches add the wrapper code to allow Squashfs to use the existing LZ4 decompression code, and the necessary configuration option" * tag 'squashfs-updates' of git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-next: Squashfs: Add LZ4 compression configuration option Squashfs: add LZ4 compression support
2014-12-14Merge git://git.kvack.org/~bcrl/aio-nextLinus Torvalds
Pull aio updates from Benjamin LaHaise. * git://git.kvack.org/~bcrl/aio-next: aio: Skip timer for io_getevents if timeout=0 aio: Make it possible to remap aio ring
2014-12-13aio: Skip timer for io_getevents if timeout=0Fam Zheng
In this case, it is basically a polling. Let's not involve timer at all because that would hurt performance for application event loops. In an arbitrary test I've done, io_getevents syscall elapsed time reduces from 50000+ nanoseconds to a few hundereds. Signed-off-by: Fam Zheng <famz@redhat.com> Signed-off-by: Benjamin LaHaise <bcrl@kvack.org>
