commit 960cc0f4fef607baabc2232fbd7cce5368a9dcfd upstream.
commit 0762b8bde9729f10f8e6249809660ff2ec3ad735
(from 14 months ago) introduced a use-after-free bug which has just
recently started manifesting in my md testing.
I tried git bisect to find out what caused the bug to start
manifesting, and it could have been the recent change to
blk_unregister_queue (48c0d4d4c04) but the results were inconclusive.
This patch certainly fixes my symptoms and looks correct as the two
calls are now in the same order as elsewhere in that function.
Signed-off-by: NeilBrown <neilb@suse.de>
Acked-by: Tejun Heo <tj@kernel.org>
commit 1b7323965a8c6eee9dc4e345a7ae4bff1dc93149 upstream.
The comment in fuse_open about O_DIRECT:
"VFS checks this, but only _after_ ->open()"
also holds for fuse_create, however, the same kind of check was missing there.
As an impact of this bug, open(newfile, O_RDWR|O_CREAT|O_DIRECT) fails, but a
stub newfile will remain if the fuse server handled the implied FUSE_CREATE
request appropriately.
Other impact: in the above situation ima_file_free() will complain to open/free
imbalance if CONFIG_IMA is set.
Signed-off-by: Csaba Henk <csaba@gluster.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Cc: Harshavardhana <harsha@gluster.com>
commit 96d25e532234bec1a1989e6e1baf702d43a78b0d upstream.
Changeset a65318bf3afc93ce49227e849d213799b072c5fd (NFSv4: Simplify some
cache consistency post-op GETATTRs) incorrectly changed the getattr
bitmap for readdir().
This causes the readdir() function to fail to return a
fileid/inode number, which again exposed a bug in the NFS readdir code that
causes spurious ENOENT errors to appear in applications (see
http://bugzilla.kernel.org/show_bug.cgi?id=14541).
The immediate band aid is to revert the incorrect bitmap change, but more
long term, we should change the NFS readdir code to cope with the
fact that NFSv4 servers are not required to support fileids/inode numbers.
Reported-by: Daniel J Blueman <daniel.blueman@gmail.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 29f12ca32122db98481150be09d35bd72b68045e upstream.
Daniel Lezcano reported a leak in 'struct pid' and 'struct pid_namespace'
that is discussed in:
http://lkml.org/lkml/2009/10/2/159.
To summarize the thread, when container-init is terminated, it sets the
PF_EXITING flag, zaps other processes in the container and waits to reap
them. As a part of reaping, the container-init should flush any /proc
dentries associated with the processes. But because the container-init is
itself exiting and the following PF_EXITING check, the dentries are not
flushed, resulting in leak in /proc inodes and dentries.
This fix reverts the commit 7766755a2f249e7e0 ("Fix /proc dcache deadlock
in do_exit") which introduced the check for PF_EXITING. At the time of
the commit, shrink_dcache_parent() flushed dentries from other filesystems
also and could have caused a deadlock which the commit fixed. But as
pointed out by Eric Biederman, after commit 0feae5c47aabdde59,
shrink_dcache_parent() no longer affects other filesystems. So reverting
the commit is now safe.
As pointed out by Jan Kara, the leak is not as critical since the
unclaimed space will be reclaimed under memory pressure or by:
echo 3 > /proc/sys/vm/drop_caches
But since this check is no longer required, its best to remove it.
Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Reported-by: Daniel Lezcano <dlezcano@fr.ibm.com>
Acked-by: Eric W. Biederman <ebiederm@xmission.com>
Acked-by: Jan Kara <jack@ucw.cz>
Cc: Andrea Arcangeli <andrea@cpushare.com>
Cc: Serge Hallyn <serue@us.ibm.com>
commit 7779d7bed950a7fb1af4f540c2f82a6b81b65901 upstream.
For FS_IOC_RESVSP and FS_IOC_RESVSP64 compat_sys_ioctl() uses its
arg argument as a pointer to userspace. However it is missing a
a call to compat_ptr() which will do a proper pointer conversion.
This was introduced with 3e63cbb1 "fs: Add new pre-allocation ioctls
to vfs for compatibility with legacy xfs ioctls".
Cc: Ankit Jain <me@ankitjain.org>
Acked-by: Christoph Hellwig <hch@lst.de>
Acked-by: Arnd Bergmann <arndbergmann@googlemail.com>
commit 199bc9ff5ca5e4b3bcaff8927b2983c65f34c263 upstream.
In 2.6.23 kernel, commit a32ea1e1f925399e0d81ca3f7394a44a6dafa12c
("Fix read/truncate race") fixed a race in the generic code, and as a
side effect, now do_generic_file_read() can ask us to readpage() past
the i_size. This seems to be correctly handled by the block routines
(e.g. block_read_full_page() fills the page with zeroes in case if
somebody is trying to read past the last inode's block).
JFFS2 doesn't handle this; it assumes that it won't be asked to read
pages which don't exist -- and thus that there will be at least _one_
valid 'frag' on the page it's being asked to read. It will fill any
holes with the following memset:
memset(buf, 0, min(end, frag->ofs + frag->size) - offset);
When the 'closest smaller match' returned by jffs2_lookup_node_frag() is
actually on a previous page and ends before 'offset', that results in:
memset(buf, 0, <huge unsigned negative>);
Hopefully, in most cases the corruption is fatal, and quickly causing
random oopses, like this:
root@10.0.0.4:~/ltp-fs-20090531# ./testcases/kernel/fs/ftest/ftest01
Unable to handle kernel paging request for data at address 0x00000008
Faulting instruction address: 0xc01cd980
Oops: Kernel access of bad area, sig: 11 [#1]
NIP [c01cd980] rb_insert_color+0x38/0x184
LR [c0043978] enqueue_hrtimer+0x88/0xc4
Call Trace:
[c6c63b60] [c004f9a8] tick_sched_timer+0xa0/0xe4 (unreliable)
[c6c63b80] [c0043978] enqueue_hrtimer+0x88/0xc4
[c6c63b90] [c0043a48] __run_hrtimer+0x94/0xbc
[c6c63bb0] [c0044628] hrtimer_interrupt+0x140/0x2b8
[c6c63c10] [c000f8e8] timer_interrupt+0x13c/0x254
[c6c63c30] [c001352c] ret_from_except+0x0/0x14
--- Exception: 901 at memset+0x38/0x5c
LR = jffs2_read_inode_range+0x144/0x17c
[c6c63cf0] [00000000] (null) (unreliable)
This patch fixes the issue, plus fixes all LTP tests on NAND/UBI with
JFFS2 filesystem that were failing since 2.6.23 (seems like the bug
above also broke the truncation).
Reported-By: Anton Vorontsov <avorontsov@ru.mvista.com>
Tested-By: Anton Vorontsov <avorontsov@ru.mvista.com>
commit cea62343956c24452700c06cf028b72414c58a74 upstream.
SMB writes are sent with a starting offset and length. When the server
supports the newer SMB trans2 posix open (rather than using the SMB
NTCreateX) a file can be opened with SMB_O_APPEND flag, and for that
case Samba server assumes that the offset sent in SMBWriteX is unneeded
since the write should go to the end of the file - which can cause
problems if the write was cached (since the beginning part of a
page could be written twice by the client mm). Jeff suggested that
masking the flag on posix open on the client is easiest for the time
being. Note that recent Samba server also had an unrelated problem with
SMB NTCreateX and append (see samba bugzilla bug number 6898) which
should not affect current Linux clients (unless cifs Unix Extensions
are disabled).
The cifs client did not send the O_APPEND flag on posix open
before 2.6.29 so the fix is unneeded on early kernels.
In the future, for the non-cached case (O_DIRECT, and forcedirectio mounts)
it would be possible and useful to send O_APPEND on posix open (for Windows
case: FILE_APPEND_DATA but not FILE_WRITE_DATA on SMB NTCreateX) but for
cached writes although the vfs sets the offset to end of file it
may fragment a write across pages - so we can't send O_APPEND on
open (could result in sending part of a page twice).
Reviewed-by: Shirish Pargaonkar <shirishp@us.ibm.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
commit 8e6c0332d5032aef2d3bc8f41771f999112c8c66 upstream.
Fixes bugzilla.kernel.org bug number 14641
Lookup called during network boot (network root filesystem
for diskless workstation) has case where nd is null in
lookup. This patch fixes that in cifs_lookup.
(Shirish noted that 2.6.30 and 2.6.31 stable need the same check)
Signed-off-by: Shirish Pargaonkar <shirishp@us.ibm.com>
Acked-by: Jeff Layton <jlayton@redhat.com>
Tested-by: Vladimir Stavrinov <vs@inist.ru>
commit f534dc994397560343be4a3223b9bbaa8e739e1f upstream.
Fix the commit ec06aedd44 that intended to turn off querying for server inode
numbers when server doesn't consistently support inode numbers. Presumably
the commit didn't actually clear the CIFS_MOUNT_SERVER_INUM flag, perhaps a
typo.
Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de>
commit ec06aedd44541129840ed52e6165afa3796a27bf upstream.
It's possible that a server will return a valid FileID when we query the
FILE_INTERNAL_INFO for the root inode, but then zeroed out inode numbers
when we do a FindFile with an infolevel of
SMB_FIND_FILE_ID_FULL_DIR_INFO.
In this situation turn off querying for server inode numbers, generate a
warning for the user and just generate an inode number using iunique.
Once we generate any inode number with iunique we can no longer use any
server inode numbers or we risk collisions, so ensure that we don't do
that in cifs_get_inode_info either.
Reported-by: Timothy Normand Miller <theosib@gmail.com>
commit f475f6775465283494346663f201ad04810d2e8a upstream.
Because it's lighter weight, CIFS tries to use CIFSGetSrvInodeNumber to
verify the accessibility of the root inode and then falls back to doing a
full QPathInfo if that fails with -EOPNOTSUPP. I have at least a report
of a server that returns NT_STATUS_INTERNAL_ERROR rather than something
that translates to EOPNOTSUPP.
Rather than trying to be clever with that call, just have
is_path_accessible do a normal QPathInfo. That call is widely
supported and it shouldn't increase the overhead significantly.
commit 5399dd1fc8f5e812db931225ef5f67d89f3b1a56 upstream.
This fixes a kernel oops reported by Markus Trippelsdorf in the email
titled "[NILFS users] kernel Oops while running nilfs_cleanerd".
The oops was caused by a bug of error path in
nilfs_ioctl_move_blocks() function, which was inlined in
nilfs_ioctl_clean_segments().
nilfs_ioctl_move_blocks checks duplication of blocks which will be
moved in garbage collection. But, the check should have be done
within nilfs_ioctl_move_inode_block() to prevent list corruption among
buffers storing the target blocks.
To fix the kernel oops, this moves forward the duplication check
before the list insertion.
I also tested this for stable trees [2.6.30, 2.6.31].
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
commit 9a3936aac133037f65124fcb2d676a6c201a90a4 upstream.
Otherwise, we have to wait for the server to recall it.
commit 3050141bae57984dd660e6861632ccf9b8bca77e upstream.
The NFSv4 renew daemon is shared between all active super blocks that refer
to a particular NFS server, so it is wrong to be shutting it down in
nfs4_kill_super every time a super block is destroyed.
This patch therefore kills nfs4_renewd_prepare_shutdown altogether, and
leaves it up to nfs4_shutdown_client() to also shut down the renew daemon
by means of the existing call to nfs4_kill_renewd().
commit 141aeb9f26f9f12f1584c128ce8697cdffb046e7 upstream.
Commits 29fba38b (nfs41: lease renewal) and fc01cea9 (nfs41: sequence
operation) introduce a couple of put_rpccred() calls on credentials for
which there is no corresponding get_rpccred().
See http://bugzilla.kernel.org/show_bug.cgi?id=14249
commit 52567b03ca38b6e556ced450d64dba8d66e23b0e upstream.
RFC 3530 states that when we recieve the error NFS4ERR_RESOURCE, we are not
supposed to bump the sequence number on OPEN, LOCK, LOCKU, CLOSE, etc
operations. The problem is that we map that error into EREMOTEIO in the XDR
layer, and so the NFSv4 middle-layer routines like seqid_mutating_err(),
and nfs_increment_seqid() don't recognise it.
The fix is to defer the mapping until after the middle layers have
processed the error.
commit a8b40bc7e635831b61c43acc71a86d3a68b2dff0 upstream.
Actually pass the NFS_FILE_SYNC option to the server to avoid a
Panic in nfs_direct_write_complete() when a commit fails.
At the end of an nfs write, if the nfs commit fails, all the writes
will be rescheduled. They are supposed to be rescheduled as NFS_FILE_SYNC
writes, but the rpc_task structure is not completely intialized and so
the option is not passed. When the rescheduled writes complete, the
return indicates that they are NFS_UNSTABLE and we try to do another
commit. This leads to a Panic because the commit data structure pointer
was set to null in the initial (failed) commit attempt.
Signed-off-by: Terry Loftin <terry.loftin@hp.com>
commit f4373bf9e67e4a653c8854acd7b02dac9714c98a upstream.
As seen in <http://bugs.debian.org/549002>, nfs4_init_client() can
overrun the source string when copying the client IP address from
nfs_parsed_mount_data::client_address to nfs_client::cl_ipaddr. Since
these are both treated as null-terminated strings elsewhere, the copy
should be done with strlcpy() not memcpy().
commit 9f0d793b52eb2266359661369ef6303838904855 upstream.
fsnotify_add_mark is supposed to add a mark to the g_list and i_list and to
set the group and inode for the mark. fsnotify_destroy_mark_by_entry uses
the fact that ->group != NULL to know if this group should be destroyed or
if it's already been done.
But fsnotify_add_mark sets the group and inode before it actually adds the
mark to the i_list and g_list. This can result in a race in inotify, it
requires 3 threads.
sys_inotify_add_watch("file") sys_inotify_add_watch("file") sys_inotify_rm_watch([a])
inotify_update_watch()
inotify_new_watch()
inotify_add_to_idr()
^--- returns wd = [a]
inotfiy_update_watch()
inotify_new_watch()
fsnotify_add_mark()
^--- returns wd = [b]
returns to userspace;
inotify_idr_find([a])
^--- gives us the pointer from task 1
fsnotify_add_mark()
^--- this is going to set the mark->group and mark->inode fields, but will
return -EEXIST because of the race with [b].
fsnotify_destroy_mark()
^--- since ->group != NULL we call back
into inotify_freeing_mark() which calls
inotify_remove_from_idr([a])
since fsnotify_add_mark() failed we call:
inotify_remove_from_idr([a]) <------WHOOPS it's not in the idr, this could
have been any entry added later!
The fix is to make sure we don't set mark->group until we are sure the mark is
on the inode and fsnotify_add_mark will return success.
Signed-off-by: Eric Paris <eparis@redhat.com>
commit 0bd87182d3ab18a32a8e9175d3f68754c58e3432 upstream.
Looks like another victim of the confusing kmap() vs kmap_atomic() API
differences.
Reported-by: Todor Gyumyushev <yodor1@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
commit f60311d5f7670d9539b424e4ed8b5c0872fc9e83 upstream.
fuse_direct_io() has a loop where requests are allocated in each
iteration. if allocation fails, the loop is broken out and follows
into an unconditional fuse_put_request() on that invalid pointer.
Signed-off-by: Anand V. Avati <avati@gluster.com>
commit b1e19e5601277845b4f17ecd7c9ba04f73ee11aa upstream.
Bruno Prémont and Dunphy, Bill noticed me that NILFS will certainly
hang on ARM-based targets.
I found this was caused by an underflow of dirty pages counter. A
b-tree cache routine was marking page dirty without adjusting page
account information.
This fixes the dirty page accounting leak and resolves the hang on
arm-based targets.
Reported-by: Bruno Prémont <bonbons@linux-vserver.org>
Reported-by: Dunphy, Bill <WDunphy@tandbergdata.com>
Tested-by: Bruno Prémont <bonbons@linux-vserver.org>
commit 8347a5cdd1422eea0470ed586274c7f29e274b47 upstream.
trivial bug in fs/cifs/connect.c .
The bug is caused by fail of extract_hostname()
when mounting cifs file system.
This is the situation when I noticed this bug.
% sudo mount -t cifs //192.168.10.208 mountpoint -o options...
Then my kernel says,
[ 1461.807776] ------------[ cut here ]------------
[ 1461.807781] kernel BUG at mm/slab.c:521!
[ 1461.807784] invalid opcode: 0000 [#2] PREEMPT SMP
[ 1461.807790] last sysfs file:
/sys/devices/pci0000:00/0000:00:1e.0/0000:09:02.0/resource
[ 1461.807793] CPU 0
[ 1461.807796] Modules linked in: nls_iso8859_1 usbhid sbp2 uhci_hcd
ehci_hcd i2c_i801 ohci1394 ieee1394 psmouse serio_raw pcspkr sky2 usbcore
evdev
[ 1461.807816] Pid: 3446, comm: mount Tainted: G D 2.6.32-rc2-vanilla
[ 1461.807820] RIP: 0010:[<ffffffff810b888e>] [<ffffffff810b888e>]
kfree+0x63/0x156
[ 1461.807829] RSP: 0018:ffff8800b4f7fbb8 EFLAGS: 00010046
[ 1461.807832] RAX: ffffea00033fff98 RBX: ffff8800afbae7e2 RCX:
0000000000000000
[ 1461.807836] RDX: ffffea0000000000 RSI: 000000000000005c RDI:
ffffffffffffffea
[ 1461.807839] RBP: ffff8800b4f7fbf8 R08: 0000000000000001 R09:
0000000000000000
[ 1461.807842] R10: 0000000000000000 R11: ffff8800b4f7fbf8 R12:
00000000ffffffea
[ 1461.807845] R13: ffff8800afb23000 R14: ffff8800b4f87bc0 R15:
ffffffffffffffea
[ 1461.807849] FS: 00007f52b6f187c0(0000) GS:ffff880007600000(0000)
knlGS:0000000000000000
[ 1461.807852] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 1461.807855] CR2: 0000000000613000 CR3: 00000000af8f9000 CR4:
00000000000006f0
[ 1461.807858] DR0: 0000000000000000 DR1: 0000000000000000 DR2:
0000000000000000
[ 1461.807861] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7:
0000000000000400
[ 1461.807865] Process mount (pid: 3446, threadinfo ffff8800b4f7e000, task
ffff8800950e4380)
[ 1461.807867] Stack:
[ 1461.807869] 0000000000000202 0000000000000282 ffff8800b4f7fbf8
ffff8800afbae7e2
[ 1461.807876] <0> 00000000ffffffea ffff8800afb23000 ffff8800b4f87bc0
ffff8800b4f7fc28
[ 1461.807884] <0> ffff8800b4f7fcd8 ffffffff81159f6d ffffffff81147bc2
ffffffff816bfb48
[ 1461.807892] Call Trace:
[ 1461.807899] [<ffffffff81159f6d>] cifs_get_tcp_session+0x440/0x44b
[ 1461.807904] [<ffffffff81147bc2>] ? find_nls+0x1c/0xe9
[ 1461.807909] [<ffffffff8115b889>] cifs_mount+0x16bc/0x2167
[ 1461.807917] [<ffffffff814455bd>] ? _spin_unlock+0x30/0x4b
[ 1461.807923] [<ffffffff81150da9>] cifs_get_sb+0xa5/0x1a8
[ 1461.807928] [<ffffffff810c1b94>] vfs_kern_mount+0x56/0xc9
[ 1461.807933] [<ffffffff810c1c64>] do_kern_mount+0x47/0xe7
[ 1461.807938] [<ffffffff810d8632>] do_mount+0x712/0x775
[ 1461.807943] [<ffffffff810d671f>] ? copy_mount_options+0xcf/0x132
[ 1461.807948] [<ffffffff810d8714>] sys_mount+0x7f/0xbf
[ 1461.807953] [<ffffffff8144509a>] ? lockdep_sys_exit_thunk+0x35/0x67
[ 1461.807960] [<ffffffff81011cc2>] system_call_fastpath+0x16/0x1b
[ 1461.807963] Code: 00 00 00 00 ea ff ff 48 c1 e8 0c 48 6b c0 68 48 01 d0
66 83 38 00 79 04 48 8b 40 10 66 83 38 00 79 04 48 8b 40 10 80 38 00 78 04
<0f> 0b eb fe 4c 8b 70 58 4c 89 ff 41 8b 76 4c e8 b8 49 fb ff e8
[ 1461.808022] RIP [<ffffffff810b888e>] kfree+0x63/0x156
[ 1461.808027] RSP <ffff8800b4f7fbb8>
[ 1461.808031] ---[ end trace ffe26fcdc72c0ce4 ]---
The reason of this bug is that the error handling code of
cifs_get_tcp_session()
calls kfree() when corresponding kmalloc() failed.
(The kmalloc() is called by extract_hostname().)
Signed-off-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
commit 5c36fe3d87b3f0c85894a49193c66096a3d6b26f upstream.
As found in <http://bugs.debian.org/550010>, hfsplus is using type u32
rather than sector_t for some sector number calculations.
In particular, hfsplus_get_block() does:
u32 ablock, dblock, mask;
map_bh(bh_result, sb, (dblock << HFSPLUS_SB(sb).fs_shift) + HFSPLUS_SB(sb).blockoffset + (iblock & mask));
I am not confident that I can find and fix all cases where a sector number
may be truncated. For now, avoid data loss by refusing to mount HFS+
volumes with more than 2^32 sectors (2TB).
[akpm@linux-foundation.org: fix 32 and 64-bit issues]
Cc: Eric Sesterhenn <snakebyte@gmx.de>
Cc: Roman Zippel <zippel@linux-m68k.org>
commit 4223a4a155f245d41c350ed9eba4fc32e965c4da upstream.
Fix a (small) memory leak in one of the error paths of the NFS mount
options parsing code.
Regression introduced in 2.6.30 by commit a67d18f (NFS: load the
rpc/rdma transport module automatically).
Reported-by: Yinghai Lu <yinghai@kernel.org>
Reported-by: Pekka Enberg <penberg@cs.helsinki.fi>
commit ad3960243e55320d74195fb85c975e0a8cc4466c upstream.
This patch fixes a null pointer exception in pipe_rdwr_open() which
generates the stack trace:
> Unable to handle kernel NULL pointer dereference at 0000000000000028 RIP:
> [<ffffffff802899a5>] pipe_rdwr_open+0x35/0x70
> [<ffffffff8028125c>] __dentry_open+0x13c/0x230
> [<ffffffff8028143d>] do_filp_open+0x2d/0x40
> [<ffffffff802814aa>] do_sys_open+0x5a/0x100
> [<ffffffff8021faf3>] sysenter_do_call+0x1b/0x67
The failure mode is triggered by an attempt to open an anonymous
pipe via /proc/pid/fd/* as exemplified by this script:
while : ; do
{ echo y ; sleep 1 ; } | { while read ; do echo z$REPLY; done ; } &
PID=$!
OUT=$(ps -efl | grep 'sleep 1' | grep -v grep |
{ read PID REST ; echo $PID; } )
OUT="${OUT%% *}"
DELAY=$((RANDOM * 1000 / 32768))
usleep $((DELAY * 1000 + RANDOM % 1000 ))
echo n > /proc/$OUT/fd/1 # Trigger defect
done
Note that the failure window is quite small and I could only
reliably reproduce the defect by inserting a small delay
in pipe_rdwr_open(). For example:
static int
pipe_rdwr_open(struct inode *inode, struct file *filp)
msleep(100);
mutex_lock(&inode->i_mutex);
Although the defect was observed in pipe_rdwr_open(), I think it
makes sense to replicate the change through all the pipe_*_open()
functions.
The core of the change is to verify that inode->i_pipe has not
been released before attempting to manipulate it. If inode->i_pipe
is no longer present, return ENOENT to indicate so.
The comment about potentially using atomic_t for i_pipe->readers
and i_pipe->writers has also been removed because it is no longer
relevant in this context. The inode->i_mutex lock must be used so
that inode->i_pipe can be dealt with correctly.
Signed-off-by: Earl Chew <earl_chew@agilent.com>
commit 83db93f4de2d9ae441a491d1dc61c2204f0195de upstream.
sysfs_notify_dirent is a simple atomic operation that can be used to
alert user-space that new data can be read from a sysfs attribute.
Unfortunately it cannot currently be called from non-process context
because of its use of spin_lock which is sometimes taken with
interrupts enabled.
So change all lockers of sysfs_open_dirent_lock to disable interrupts,
thus making sysfs_notify_dirent safe to be called from non-process
context (as drivers/md does in md_safemode_timeout).
sysfs_get_open_dirent is (documented as being) only called from
process context, so it uses spin_lock_irq. Other places
use spin_lock_irqsave.
The usage for sysfs_notify_dirent in md_safemode_timeout was
introduced in 2.6.28, so this patch is suitable for that and more
recent kernels.
Reported-by: Joel Andres Granados <jgranado@redhat.com>
commit 6c1488fd581a447ec87c4b59f0d33f95f0aa441b upstream.
When creating a new file, ima_path_check() assumed the new file
was being opened for write. Call ima_path_check() with the
appropriate acc_mode so that the read/write counters are
incremented correctly.
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
Signed-off-by: James Morris <jmorris@namei.org>
commit 36520be8e32b49bd85a63b7b8b40cd07c3da59a5 upstream.
The unencrypted files are being measured. Update the counters to get
rid of the ecryptfs imbalance message. (http://bugzilla.redhat.com/519737)
Reported-by: Sachin Garg
Cc: Eric Paris <eparis@redhat.com>
Cc: Dustin Kirkland <kirkland@canonical.com>
Cc: David Safford <safford@watson.ibm.com>
Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
commit 96830a57de1197519b62af6a4c9ceea556c18c3d upstream.
Git commit 79741dd changes idle cputime accounting, but unfortunately
the /proc/uptime file hasn't caught up. Here the idle time calculation
from /proc/stat is copied over.
Signed-off-by: Michael Abbott <michael.abbott@diamond.ac.uk>
Not upstream due to other fixes in .32
Works around a BUG() which is triggered when the kernel accesses holes in
vmalloc regions.
BUG: unable to handle kernel paging request at fa54c000
IP: [<c04f687a>] read_kcore+0x260/0x31a
*pde = 3540b067 *pte = 00000000
Oops: 0000 [#1] SMP
last sysfs file: /sys/devices/pci0000:00/0000:00:1c.2/0000:03:00.0/ieee80211/phy0/rfkill0/state
Modules linked in: fuse sco bridge stp llc bnep l2cap bluetooth sunrpc nf_conntrack_ftp ip6t_REJECT nf_conntrack_ipv6 ip6table_filter ip6_tables ipv6 cpufreq_ondemand acpi_cpufreq dm_multipath uinput usb_storage arc4 ecb snd_hda_codec_realtek snd_hda_intel ath5k snd_hda_codec snd_hwdep iTCO_wdt snd_pcm iTCO_vendor_support pcspkr i2c_i801 mac80211 joydev snd_timer serio_raw r8169 snd soundcore mii snd_page_alloc ath cfg80211 ata_generic i915 drm i2c_algo_bit i2c_core video output [last unloaded: scsi_wait_scan]
Sep 4 12:45:16 tuxedu kernel: Pid: 2266, comm: cat Not tainted (2.6.31-rc8 #2) Joybook Lite U101
EIP: 0060:[<c04f687a>] EFLAGS: 00010286 CPU: 0
EIP is at read_kcore+0x260/0x31a
EAX: f5e5ea00 EBX: fa54d000 ECX: 00000400 EDX: 00001000
ESI: fa54c000 EDI: f44ad000 EBP: e4533f4c ESP: e4533f24
DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
Process cat (pid: 2266, ti=e4532000 task=f09d19a0 task.ti=e4532000)
Stack:
00005000 00000000 f44ad000 09d9c000 00003000 fa54c000 00001000 f6d16f60
e4520b80 fffffffb e4533f70 c04ef8eb e4533f98 00008000 09d97000 c04f661a
e4520b80 09d97000 c04ef88c e4533f8c c04ba531 e4533f98 c04c0930 e4520b80
Call Trace:
[<c04ef8eb>] ? proc_reg_read+0x5f/0x73
[<c04f661a>] ? read_kcore+0x0/0x31a
[<c04ef88c>] ? proc_reg_read+0x0/0x73
[<c04ba531>] ? vfs_read+0x82/0xe1
[<c04c0930>] ? path_put+0x1a/0x1d
[<c04ba62e>] ? sys_read+0x40/0x62
[<c0403298>] ? sysenter_do_call+0x12/0x2d
Code: 39 f3 89 ca 0f 43 f3 89 fb 29 f2 29 f3 39 cf 0f 46 d3 29 55 dc 8d 1c 32 f6 40 0c 01 75 18 89 d1 89 f7 c1 e9 02 2b 7d ec 03 7d e0 <f3> a5 89 d1 83 e1 03 74 02 f3 a4 8b 00 83 7d dc 00 74 04 85 c0
EIP: [<c04f687a>] read_kcore+0x260/0x31a SS:ESP 0068:e4533f24
CR2: 00000000fa54c000
To access vmalloc area which may have memory holes, copy_from_user is
useful. So this:
# cat /proc/kcore > /dev/null
will not panic.
This is a minimal fix, suitable for 2.6.30.x and 2.6.31. More extensive
/proc/kcore changes are planned for 2.6.32.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Tested-by: Nick Craig-Wood <nick@craig-wood.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Reported-by: <kbowa@tuxedu.org>
commit 886e3b7fe6054230c89ae078a09565ed183ecc73 upstream.
On setting up the callback to the client, we attempt to use the same
authentication flavor the client did. We find an rpc cred to use by
calling rpcauth_lookup_credcache(), which assumes that the given
authentication flavor has a credentials cache. However, this is not
required to be true--in particular, auth_null does not use one.
Instead, we should call the auth's lookup_cred() method.
Without this, a client attempting to mount using nfsv4 and auth_null
triggers a null dereference.
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
commit 1f28fcd925b2b3157411bbd08f0024b55b70d8dd upstream.
This will fix file system corruption which infrequently happens after
mount. The problem was reported from users with the title "[NILFS
users] Fail to mount NILFS." (Message-ID:
<200908211918.34720.yuri@itinteg.net>), and so forth. I've also
experienced the corruption multiple times on kernel 2.6.30 and 2.6.31.
The problem turned out to be caused due to discordance between
mapping->nrpages of a btree node cache and the actual number of pages
hung on the cache; if the mapping->nrpages becomes zero even as it has
pages, truncate_inode_pages() returns without doing anything. Usually
this is harmless except it may cause page leak, but garbage collection
fairly infrequently sees a stale page remained in the btree node cache
of DAT (i.e. disk address translation file of nilfs), and induces the
corruption.
I identified a missing initialization in btree node caches was the
root cause. This corrects the bug.
I've tested this for kernel 2.6.30 and 2.6.31.
Reported-by: Yuri Chislov <yuri@itinteg.net>
commit 20d1752f3d6bd32beb90949559e0d14a0b234445 upstream.
commit ac68392460ffefed13020967bae04edc4d3add06 ("[CIFS] Allow raw
ntlmssp code to be enabled with sec=ntlmssp") added a new bit to the
allowed security flags mask but seems to have inadvertently removed
Lanman security from the allowed flags. Add it back.
Signed-off-by: Chuck Ebbert <cebbert@redhat.com>
commit 9c2d2056647790c5034d722bd24e9d913ebca73c upstream.
When calling vfs_unlink() on the lower dentry, d_delete() turns the
dentry into a negative dentry when the d_count is 1. This eventually
caused a NULL pointer deref when a read() or write() was done and the
negative dentry's d_inode was dereferenced in
ecryptfs_read_update_atime() or ecryptfs_getxattr().
Placing mutt's tmpdir in an eCryptfs mount is what initially triggered
the oops and I was able to reproduce it with the following sequence:
open("/tmp/upper/foo", O_RDWR|O_CREAT|O_EXCL|O_NOFOLLOW, 0600) = 3
link("/tmp/upper/foo", "/tmp/upper/bar") = 0
unlink("/tmp/upper/foo") = 0
open("/tmp/upper/bar", O_RDWR|O_CREAT|O_NOFOLLOW, 0600) = 4
unlink("/tmp/upper/bar") = 0
write(4, "eCryptfs test\n"..., 14 <unfinished ...>
+++ killed by SIGKILL +++
https://bugs.launchpad.net/ecryptfs/+bug/387073
Reported-by: Loïc Minier <loic.minier@canonical.com>
Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Cc: ecryptfs-devel@lists.launchpad.net
commit 3891959846709a19f76628e33478cd85edb0e79f upstream.
When searching through the global authentication tokens for a given key
signature, verify that a matching key has not been revoked and has not
expired. This allows the `keyctl revoke` command to be properly used on
keys in use by eCryptfs.
Acked-by: Serge Hallyn <serue@us.ibm.com>
commit df6ad33ba1b9846bd5f0e2b9016c30c20bc2d948 upstream.
Returns -ENOTSUPP when attempting to use filename encryption with
something other than a password authentication token, such as a private
token from openssl. Using filename encryption with a userspace eCryptfs
key module is a future goal. Until then, this patch handles the
situation a little better than simply using a BUG_ON().
commit ac22ba23b659e34a5961aec8c945608e471b0d5b upstream.
If the lower inode is read-only, don't attempt to open the lower file
read/write and don't hand off the open request to the privileged
eCryptfs kthread for opening it read/write. Instead, only try an
unprivileged, read-only open of the file and give up if that fails.
This patch fixes an oops when eCryptfs is mounted on top of a read-only
mount.
Cc: Eric Sandeen <esandeen@redhat.com>
commit b0105eaefa7cce8f4a941d0fc6354b250d30e745 upstream.
Returns an error when an unrecognized cipher code is present in a tag 3
packet or an ecryptfs_crypt_stat cannot be initialized. Also sets an
crypt_stat->tfm error pointer to NULL to ensure that it will not be
incorrectly freed in ecryptfs_destroy_crypt_stat().
commit 580be0837a7a59b207c3d5c661d044d8dd0a6a30 upstream.
In theory it could happen that on one CPU we initialize a new inode but
clearing of I_NEW | I_LOCK gets reordered before some of the
initialization. Thus on another CPU we return not fully uptodate inode
from iget_locked().
This seems to fix a corruption issue on ext3 mounted over NFS.
[akpm@linux-foundation.org: add some commentary]
commit 9f0ab4a3f0fdb1ff404d150618ace2fa069bb2e1 upstream.
In fs/binfmt_elf.c, load_elf_interp() calls padzero() for .bss even if
the PT_LOAD has no PROT_WRITE and no .bss. This generates EFAULT.
Here is a small test case. (Yes, there are other, useful PT_INTERP
which have only .text and no .data/.bss.)
----- ptinterp.S
_start: .globl _start
nop
int3
$ gcc -m32 -nostartfiles -nostdlib -o ptinterp ptinterp.S
$ gcc -m32 -Wl,--dynamic-linker=ptinterp -o hello hello.c
$ ./hello
Segmentation fault # during execve() itself
After applying the patch:
$ ./hello
Trace trap # user-mode execution after execve() finishes
If the ELF headers are actually self-inconsistent, then dying is fine.
But having no PROT_WRITE segment is perfectly normal and correct if
there is no segment with p_memsz > p_filesz (i.e. bss). John Reiser
suggested checking for PROT_WRITE in the bss logic. I think it makes
most sense to simply apply the bss logic only when there is bss.
This patch looks less trivial than it is due to some reindentation.
It just moves the "if (last_bss > elf_bss) {" test up to include the
partial-page bss logic as well as the more-pages bss logic.
Reported-by: John Reiser <jreiser@bitwagon.com>
Signed-off-by: Roland McGrath <roland@redhat.com>
- As ima_counts_put() may be called after the inode has been freed,
verify that the inode is not NULL, before dereferencing it.
- Maintain the IMA file counters in may_open() properly, decrementing
any counter increments on subsequent errors.
Reported-by: Ciprian Docan <docan@eden.rutgers.edu>
Reported-by: J.R. Okajima <hooanon05@yahoo.co.jp>
Acked-by: Eric Paris <eparis@redhat.com
* git://git.infradead.org/~dwmw2/mtd-2.6.31:
JFFS2: add missing verify buffer allocation/deallocation
mtd: nftl: fix offset alignments
mtd: nftl: write support is broken
mtd: m25p80: fix null pointer dereference bug
* 'for-linus' of git://oss.sgi.com/xfs/xfs:
xfs: actually enable the swapext compat handler
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2:
nilfs2: fix preempt count underflow in nilfs_btnode_prepare_change_key
In ext2_rename(), dir_page is acquired through ext2_dotdot(). It is
then released through ext2_set_link() but only if old_dir != new_dir.
Failing that, the pkmap reference count is never decremented and the
page remains pinned forever. Repeat that a couple times with highmem
pages and all pkmap slots get exhausted, and every further kmap() calls
end up stalling on the pkmap_map_wait queue at which point the whole
system comes to a halt.
Signed-off-by: Nicolas Pitre <nico@marvell.com>
Acked-by: Theodore Ts'o <tytso@mit.edu>
Cc: stable@kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2:
ocfs2: ocfs2_write_begin_nolock() should handle len=0
ocfs2: invalidate dentry if its dentry_lock isn't initialized.
Tom Horsley reports that his debugger hangs when it tries to read
/proc/pid_of_tracee/maps, this happens since
"mm_for_maps: take ->cred_guard_mutex to fix the race with exec"
04b836cbf19e885f8366bccb2e4b0474346c02d
commit in 2.6.31.
But the root of the problem lies in the fact that do_execve() path calls
tracehook_report_exec() which can stop if the tracer sets PT_TRACE_EXEC.
The tracee must not sleep in TASK_TRACED holding this mutex. Even if we
remove ->cred_guard_mutex from mm_for_maps() and proc_pid_attr_write(),
another task doing PTRACE_ATTACH should not hang until it is killed or the
tracee resumes.
With this patch do_execve() does not use ->cred_guard_mutex directly and
we do not hold it throughout, instead:
- introduce prepare_bprm_creds() helper, it locks the mutex
and calls prepare_exec_creds() to initialize bprm->cred.
- install_exec_creds() drops the mutex after commit_creds(),
and thus before tracehook_report_exec()->ptrace_stop().
or, if exec fails,
free_bprm() drops this mutex when bprm->cred != NULL which
indicates install_exec_creds() was not called.
Reported-by: Tom Horsley <tom.horsley@att.net>
Cc: Roland McGrath <roland@redhat.com>
Bug introduced by mainline commit e7432675f8ca868a4af365759a8d4c3779a3d922
The bug causes ocfs2_write_begin_nolock() to oops when len=0.
Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com>
Signed-off-by: Joel Becker <joel.becker@oracle.com>
The function jffs2_nor_wbuf_flash_setup() doesn't allocate the verify buffer
if CONFIG_JFFS2_FS_WBUF_VERIFY is defined, so causing a kernel panic when
that macro is enabled and the verify function is called. Similarly the
jffs2_nor_wbuf_flash_cleanup() must free the buffer if
CONFIG_JFFS2_FS_WBUF_VERIFY is enabled.
The following patch fixes the problem.
The following patch applies to 2.6.30 kernel.
Signed-off-by: Massimo Cirillo <maxcir@gmail.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
