commit 6c1488fd581a447ec87c4b59f0d33f95f0aa441b upstream.
When creating a new file, ima_path_check() assumed the new file
was being opened for write. Call ima_path_check() with the
appropriate acc_mode so that the read/write counters are
incremented correctly.
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
Signed-off-by: James Morris <jmorris@namei.org>
commit 36520be8e32b49bd85a63b7b8b40cd07c3da59a5 upstream.
The unencrypted files are being measured. Update the counters to get
rid of the ecryptfs imbalance message. (http://bugzilla.redhat.com/519737)
Reported-by: Sachin Garg
Cc: Eric Paris <eparis@redhat.com>
Cc: Dustin Kirkland <kirkland@canonical.com>
Cc: David Safford <safford@watson.ibm.com>
Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
commit 96830a57de1197519b62af6a4c9ceea556c18c3d upstream.
Git commit 79741dd changes idle cputime accounting, but unfortunately
the /proc/uptime file hasn't caught up. Here the idle time calculation
from /proc/stat is copied over.
Signed-off-by: Michael Abbott <michael.abbott@diamond.ac.uk>
Not upstream due to other fixes in .32
Works around a BUG() which is triggered when the kernel accesses holes in
vmalloc regions.
BUG: unable to handle kernel paging request at fa54c000
IP: [<c04f687a>] read_kcore+0x260/0x31a
*pde = 3540b067 *pte = 00000000
Oops: 0000 [#1] SMP
last sysfs file: /sys/devices/pci0000:00/0000:00:1c.2/0000:03:00.0/ieee80211/phy0/rfkill0/state
Modules linked in: fuse sco bridge stp llc bnep l2cap bluetooth sunrpc nf_conntrack_ftp ip6t_REJECT nf_conntrack_ipv6 ip6table_filter ip6_tables ipv6 cpufreq_ondemand acpi_cpufreq dm_multipath uinput usb_storage arc4 ecb snd_hda_codec_realtek snd_hda_intel ath5k snd_hda_codec snd_hwdep iTCO_wdt snd_pcm iTCO_vendor_support pcspkr i2c_i801 mac80211 joydev snd_timer serio_raw r8169 snd soundcore mii snd_page_alloc ath cfg80211 ata_generic i915 drm i2c_algo_bit i2c_core video output [last unloaded: scsi_wait_scan]
Sep 4 12:45:16 tuxedu kernel: Pid: 2266, comm: cat Not tainted (2.6.31-rc8 #2) Joybook Lite U101
EIP: 0060:[<c04f687a>] EFLAGS: 00010286 CPU: 0
EIP is at read_kcore+0x260/0x31a
EAX: f5e5ea00 EBX: fa54d000 ECX: 00000400 EDX: 00001000
ESI: fa54c000 EDI: f44ad000 EBP: e4533f4c ESP: e4533f24
DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
Process cat (pid: 2266, ti=e4532000 task=f09d19a0 task.ti=e4532000)
Stack:
00005000 00000000 f44ad000 09d9c000 00003000 fa54c000 00001000 f6d16f60
e4520b80 fffffffb e4533f70 c04ef8eb e4533f98 00008000 09d97000 c04f661a
e4520b80 09d97000 c04ef88c e4533f8c c04ba531 e4533f98 c04c0930 e4520b80
Call Trace:
[<c04ef8eb>] ? proc_reg_read+0x5f/0x73
[<c04f661a>] ? read_kcore+0x0/0x31a
[<c04ef88c>] ? proc_reg_read+0x0/0x73
[<c04ba531>] ? vfs_read+0x82/0xe1
[<c04c0930>] ? path_put+0x1a/0x1d
[<c04ba62e>] ? sys_read+0x40/0x62
[<c0403298>] ? sysenter_do_call+0x12/0x2d
Code: 39 f3 89 ca 0f 43 f3 89 fb 29 f2 29 f3 39 cf 0f 46 d3 29 55 dc 8d 1c 32 f6 40 0c 01 75 18 89 d1 89 f7 c1 e9 02 2b 7d ec 03 7d e0 <f3> a5 89 d1 83 e1 03 74 02 f3 a4 8b 00 83 7d dc 00 74 04 85 c0
EIP: [<c04f687a>] read_kcore+0x260/0x31a SS:ESP 0068:e4533f24
CR2: 00000000fa54c000
To access vmalloc area which may have memory holes, copy_from_user is
useful. So this:
# cat /proc/kcore > /dev/null
will not panic.
This is a minimal fix, suitable for 2.6.30.x and 2.6.31. More extensive
/proc/kcore changes are planned for 2.6.32.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Tested-by: Nick Craig-Wood <nick@craig-wood.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Reported-by: <kbowa@tuxedu.org>
commit 886e3b7fe6054230c89ae078a09565ed183ecc73 upstream.
On setting up the callback to the client, we attempt to use the same
authentication flavor the client did. We find an rpc cred to use by
calling rpcauth_lookup_credcache(), which assumes that the given
authentication flavor has a credentials cache. However, this is not
required to be true--in particular, auth_null does not use one.
Instead, we should call the auth's lookup_cred() method.
Without this, a client attempting to mount using nfsv4 and auth_null
triggers a null dereference.
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
commit 1f28fcd925b2b3157411bbd08f0024b55b70d8dd upstream.
This will fix file system corruption which infrequently happens after
mount. The problem was reported from users with the title "[NILFS
users] Fail to mount NILFS." (Message-ID:
<200908211918.34720.yuri@itinteg.net>), and so forth. I've also
experienced the corruption multiple times on kernel 2.6.30 and 2.6.31.
The problem turned out to be caused due to discordance between
mapping->nrpages of a btree node cache and the actual number of pages
hung on the cache; if the mapping->nrpages becomes zero even as it has
pages, truncate_inode_pages() returns without doing anything. Usually
this is harmless except it may cause page leak, but garbage collection
fairly infrequently sees a stale page remained in the btree node cache
of DAT (i.e. disk address translation file of nilfs), and induces the
corruption.
I identified a missing initialization in btree node caches was the
root cause. This corrects the bug.
I've tested this for kernel 2.6.30 and 2.6.31.
Reported-by: Yuri Chislov <yuri@itinteg.net>
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
commit 20d1752f3d6bd32beb90949559e0d14a0b234445 upstream.
commit ac68392460ffefed13020967bae04edc4d3add06 ("[CIFS] Allow raw
ntlmssp code to be enabled with sec=ntlmssp") added a new bit to the
allowed security flags mask but seems to have inadvertently removed
Lanman security from the allowed flags. Add it back.
Signed-off-by: Chuck Ebbert <cebbert@redhat.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
commit 9c2d2056647790c5034d722bd24e9d913ebca73c upstream.
When calling vfs_unlink() on the lower dentry, d_delete() turns the
dentry into a negative dentry when the d_count is 1. This eventually
caused a NULL pointer deref when a read() or write() was done and the
negative dentry's d_inode was dereferenced in
ecryptfs_read_update_atime() or ecryptfs_getxattr().
Placing mutt's tmpdir in an eCryptfs mount is what initially triggered
the oops and I was able to reproduce it with the following sequence:
open("/tmp/upper/foo", O_RDWR|O_CREAT|O_EXCL|O_NOFOLLOW, 0600) = 3
link("/tmp/upper/foo", "/tmp/upper/bar") = 0
unlink("/tmp/upper/foo") = 0
open("/tmp/upper/bar", O_RDWR|O_CREAT|O_NOFOLLOW, 0600) = 4
unlink("/tmp/upper/bar") = 0
write(4, "eCryptfs test\n"..., 14 <unfinished ...>
+++ killed by SIGKILL +++
https://bugs.launchpad.net/ecryptfs/+bug/387073
Reported-by: Loïc Minier <loic.minier@canonical.com>
Cc: Serge Hallyn <serue@us.ibm.com>
Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Cc: ecryptfs-devel@lists.launchpad.net
commit 3891959846709a19f76628e33478cd85edb0e79f upstream.
When searching through the global authentication tokens for a given key
signature, verify that a matching key has not been revoked and has not
expired. This allows the `keyctl revoke` command to be properly used on
keys in use by eCryptfs.
Acked-by: Serge Hallyn <serue@us.ibm.com>
commit df6ad33ba1b9846bd5f0e2b9016c30c20bc2d948 upstream.
Returns -ENOTSUPP when attempting to use filename encryption with
something other than a password authentication token, such as a private
token from openssl. Using filename encryption with a userspace eCryptfs
key module is a future goal. Until then, this patch handles the
situation a little better than simply using a BUG_ON().
commit ac22ba23b659e34a5961aec8c945608e471b0d5b upstream.
If the lower inode is read-only, don't attempt to open the lower file
read/write and don't hand off the open request to the privileged
eCryptfs kthread for opening it read/write. Instead, only try an
unprivileged, read-only open of the file and give up if that fails.
This patch fixes an oops when eCryptfs is mounted on top of a read-only
mount.
Cc: Eric Sandeen <esandeen@redhat.com>
commit b0105eaefa7cce8f4a941d0fc6354b250d30e745 upstream.
Returns an error when an unrecognized cipher code is present in a tag 3
packet or an ecryptfs_crypt_stat cannot be initialized. Also sets an
crypt_stat->tfm error pointer to NULL to ensure that it will not be
incorrectly freed in ecryptfs_destroy_crypt_stat().
commit 580be0837a7a59b207c3d5c661d044d8dd0a6a30 upstream.
In theory it could happen that on one CPU we initialize a new inode but
clearing of I_NEW | I_LOCK gets reordered before some of the
initialization. Thus on another CPU we return not fully uptodate inode
from iget_locked().
This seems to fix a corruption issue on ext3 mounted over NFS.
[akpm@linux-foundation.org: add some commentary]
commit 9f0ab4a3f0fdb1ff404d150618ace2fa069bb2e1 upstream.
In fs/binfmt_elf.c, load_elf_interp() calls padzero() for .bss even if
the PT_LOAD has no PROT_WRITE and no .bss. This generates EFAULT.
Here is a small test case. (Yes, there are other, useful PT_INTERP
which have only .text and no .data/.bss.)
----- ptinterp.S
_start: .globl _start
nop
int3
$ gcc -m32 -nostartfiles -nostdlib -o ptinterp ptinterp.S
$ gcc -m32 -Wl,--dynamic-linker=ptinterp -o hello hello.c
$ ./hello
Segmentation fault # during execve() itself
After applying the patch:
$ ./hello
Trace trap # user-mode execution after execve() finishes
If the ELF headers are actually self-inconsistent, then dying is fine.
But having no PROT_WRITE segment is perfectly normal and correct if
there is no segment with p_memsz > p_filesz (i.e. bss). John Reiser
suggested checking for PROT_WRITE in the bss logic. I think it makes
most sense to simply apply the bss logic only when there is bss.
This patch looks less trivial than it is due to some reindentation.
It just moves the "if (last_bss > elf_bss) {" test up to include the
partial-page bss logic as well as the more-pages bss logic.
Reported-by: John Reiser <jreiser@bitwagon.com>
Signed-off-by: Roland McGrath <roland@redhat.com>
- As ima_counts_put() may be called after the inode has been freed,
verify that the inode is not NULL, before dereferencing it.
- Maintain the IMA file counters in may_open() properly, decrementing
any counter increments on subsequent errors.
Reported-by: Ciprian Docan <docan@eden.rutgers.edu>
Reported-by: J.R. Okajima <hooanon05@yahoo.co.jp>
Acked-by: Eric Paris <eparis@redhat.com
* git://git.infradead.org/~dwmw2/mtd-2.6.31:
JFFS2: add missing verify buffer allocation/deallocation
mtd: nftl: fix offset alignments
mtd: nftl: write support is broken
mtd: m25p80: fix null pointer dereference bug
* 'for-linus' of git://oss.sgi.com/xfs/xfs:
xfs: actually enable the swapext compat handler
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2:
nilfs2: fix preempt count underflow in nilfs_btnode_prepare_change_key
In ext2_rename(), dir_page is acquired through ext2_dotdot(). It is
then released through ext2_set_link() but only if old_dir != new_dir.
Failing that, the pkmap reference count is never decremented and the
page remains pinned forever. Repeat that a couple times with highmem
pages and all pkmap slots get exhausted, and every further kmap() calls
end up stalling on the pkmap_map_wait queue at which point the whole
system comes to a halt.
Signed-off-by: Nicolas Pitre <nico@marvell.com>
Acked-by: Theodore Ts'o <tytso@mit.edu>
Cc: stable@kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2:
ocfs2: ocfs2_write_begin_nolock() should handle len=0
ocfs2: invalidate dentry if its dentry_lock isn't initialized.
Tom Horsley reports that his debugger hangs when it tries to read
/proc/pid_of_tracee/maps, this happens since
"mm_for_maps: take ->cred_guard_mutex to fix the race with exec"
04b836cbf19e885f8366bccb2e4b0474346c02d
commit in 2.6.31.
But the root of the problem lies in the fact that do_execve() path calls
tracehook_report_exec() which can stop if the tracer sets PT_TRACE_EXEC.
The tracee must not sleep in TASK_TRACED holding this mutex. Even if we
remove ->cred_guard_mutex from mm_for_maps() and proc_pid_attr_write(),
another task doing PTRACE_ATTACH should not hang until it is killed or the
tracee resumes.
With this patch do_execve() does not use ->cred_guard_mutex directly and
we do not hold it throughout, instead:
- introduce prepare_bprm_creds() helper, it locks the mutex
and calls prepare_exec_creds() to initialize bprm->cred.
- install_exec_creds() drops the mutex after commit_creds(),
and thus before tracehook_report_exec()->ptrace_stop().
or, if exec fails,
free_bprm() drops this mutex when bprm->cred != NULL which
indicates install_exec_creds() was not called.
Reported-by: Tom Horsley <tom.horsley@att.net>
Cc: Roland McGrath <roland@redhat.com>
Bug introduced by mainline commit e7432675f8ca868a4af365759a8d4c3779a3d922
The bug causes ocfs2_write_begin_nolock() to oops when len=0.
Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com>
Signed-off-by: Joel Becker <joel.becker@oracle.com>
The function jffs2_nor_wbuf_flash_setup() doesn't allocate the verify buffer
if CONFIG_JFFS2_FS_WBUF_VERIFY is defined, so causing a kernel panic when
that macro is enabled and the verify function is called. Similarly the
jffs2_nor_wbuf_flash_cleanup() must free the buffer if
CONFIG_JFFS2_FS_WBUF_VERIFY is enabled.
The following patch fixes the problem.
The following patch applies to 2.6.30 kernel.
Signed-off-by: Massimo Cirillo <maxcir@gmail.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Fix a small typo in the compat ioctl handler that cause the swapext
compat handler to never be called.
Reviewed-by: Torsten Kaiser <just.for.lkml@googlemail.com>
Tested-by: Torsten Kaiser <just.for.lkml@googlemail.com>
Reviewed-by: Eric Sandeen <sandeen@sandeen.net>
Reviewed-by: Felix Blyakher <felixb@sgi.com>
Signed-off-by: Felix Blyakher <felixb@sgi.com>
In the recent change by Al Viro that changes verious subsystems
to use "struct path" one case was missed in the autofs4 module
which causes mounts to no longer expire.
Signed-off-by: Ian Kent <raven@themaw.net>
This will fix the following preempt count underflow reported from
users with the title "[NILFS users] segctord problem" (Message-ID:
<949415.6494.qm@web58808.mail.re1.yahoo.com> and Message-ID:
<debc30fc0908270825v747c1734xa59126623cfd5b05@mail.gmail.com>):
WARNING: at kernel/sched.c:4890 sub_preempt_count+0x95/0xa0()
Hardware name: HP Compaq 6530b (KR980UT#ABC)
Modules linked in: bridge stp llc bnep rfcomm l2cap xfs exportfs nilfs2 cowloop loop vboxnetadp vboxnetflt vboxdrv btusb bluetooth uvcvideo videodev v4l1_compat v4l2_compat_ioctl32 arc4 snd_hda_codec_analog ecb iwlagn iwlcore rfkill lib80211 mac80211 snd_hda_intel snd_hda_codec ehci_hcd uhci_hcd usbcore snd_hwdep snd_pcm tg3 cfg80211 psmouse snd_timer joydev libphy ohci1394 snd_page_alloc hp_accel lis3lv02d ieee1394 led_class i915 drm i2c_algo_bit video backlight output i2c_core dm_crypt dm_mod
Pid: 4197, comm: segctord Not tainted 2.6.30-gentoo-r4-64 #7
Call Trace:
[<ffffffff8023fa05>] ? sub_preempt_count+0x95/0xa0
[<ffffffff802470f8>] warn_slowpath_common+0x78/0xd0
[<ffffffff8024715f>] warn_slowpath_null+0xf/0x20
[<ffffffff8023fa05>] sub_preempt_count+0x95/0xa0
[<ffffffffa04ce4db>] nilfs_btnode_prepare_change_key+0x11b/0x190 [nilfs2]
[<ffffffffa04d01ad>] nilfs_btree_assign_p+0x19d/0x1e0 [nilfs2]
[<ffffffffa04d10ad>] nilfs_btree_assign+0xbd/0x130 [nilfs2]
[<ffffffffa04cead7>] nilfs_bmap_assign+0x47/0x70 [nilfs2]
[<ffffffffa04d9bc6>] nilfs_segctor_do_construct+0x956/0x20f0 [nilfs2]
[<ffffffff805ac8e2>] ? _spin_unlock_irqrestore+0x12/0x40
[<ffffffff803c06e0>] ? __up_write+0xe0/0x150
[<ffffffff80262959>] ? up_write+0x9/0x10
[<ffffffffa04ce9f3>] ? nilfs_bmap_test_and_clear_dirty+0x43/0x60 [nilfs2]
[<ffffffffa04cd627>] ? nilfs_mdt_fetch_dirty+0x27/0x60 [nilfs2]
[<ffffffffa04db5fc>] nilfs_segctor_construct+0x8c/0xd0 [nilfs2]
[<ffffffffa04dc3dc>] nilfs_segctor_thread+0x15c/0x3a0 [nilfs2]
[<ffffffffa04dbe20>] ? nilfs_construction_timeout+0x0/0x10 [nilfs2]
[<ffffffff80252633>] ? add_timer+0x13/0x20
[<ffffffff802370da>] ? __wake_up_common+0x5a/0x90
[<ffffffff8025e960>] ? autoremove_wake_function+0x0/0x40
[<ffffffffa04dc280>] ? nilfs_segctor_thread+0x0/0x3a0 [nilfs2]
[<ffffffff8025e556>] kthread+0x56/0x90
[<ffffffff8020cdea>] child_rip+0xa/0x20
[<ffffffff8025e500>] ? kthread+0x0/0x90
[<ffffffff8020cde0>] ? child_rip+0x0/0x20
This problem was caused due to a missing radix_tree_preload() call in
the retry path of nilfs_btnode_prepare_change_key() function.
Reported-by: Eric A <eric225125@yahoo.com>
Reported-by: Jerome Poulin <jeromepoulin@gmail.com>
Tested-by: Jerome Poulin <jeromepoulin@gmail.com>
Seperating the addition and update of marks in inotify resulted in a
regression in that inotify never gets events. The inotify group mask is
always 0. This mask should be updated any time a new mark is added.
Signed-off-by: Eric Paris <eparis@redhat.com>
0db501bd0610ee0c0 introduced a regresion in that it now sends a nul
terminator but the length accounting when checking for space or
reporting to userspace did not take this into account. This corrects
all of the rounding logic.
When an event has no pathname, there's no need to pad it with a null byte and
therefore generate an inotify_event sized block of zeros. This fixes a
regression introduced by commit 0db501bd0610ee0c0aca84d927f90bcccd09e2bd where
my system wouldn't finish booting because some process was being confused by
this.
Signed-off-by: Brian Rogers <brian@xyzw.org>
In commit a5a0a630922a2f6a774b6dac19f70cb5abd86bb0, when
ocfs2_attch_dentry_lock fails, we call an extra iput and reset
dentry->d_fsdata to NULL. This resolve a bug, but it isn't
completed and the dentry is still there. When we want to use
it again, ocfs2_dentry_revalidate doesn't catch it and return
true. That make future ocfs2_dentry_lock panic out.
One bug is http://oss.oracle.com/bugzilla/show_bug.cgi?id=1162.
The resolution is to add a check for dentry->d_fsdata in
revalidate process and return false if dentry->d_fsdata is NULL,
so that a new ocfs2_lookup will be called again.
Signed-off-by: Tao Ma <tao.ma@oracle.com>
* 'for-linus' of git://git.infradead.org/users/eparis/notify:
inotify: Ensure we alwasy write the terminating NULL.
inotify: fix locking around inotify watching in the idr
inotify: do not BUG on idr entries at inotify destruction
inotify: seperate new watch creation updating existing watches
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs:
9p: update documentation pointers
9p: remove unnecessary v9fses->options which duplicates the mount string
net/9p: insulate the client against an invalid error code sent by a 9p server
9p: Add missing cast for the error return value in v9fs_get_inode
9p: Remove redundant inode uid/gid assignment
9p: Fix possible regressions when ->get_sb fails.
9p: Fix v9fs show_options
9p: Fix possible memleak in v9fs_inode_from fid.
9p: minor comment fixes
9p: Fix possible inode leak in v9fs_get_inode.
9p: Check for error in return value of v9fs_fid_add
kAFS crashes when asked to read a symbolic link because page_getlink()
passes a NULL file pointer to read_mapping_page(), but afs_readpage()
expects a file pointer from which to extract a key.
Modify afs_readpage() to request the appropriate key from the calling
process's keyrings if a file struct is not supplied with one attached.
Acked-by: Anton Blanchard <anton@samba.org>
Before the rewrite copy_event_to_user always wrote a terqminating '\0'
byte to user space after the filename. Since the rewrite that
terminating byte was skipped if your filename is exactly a multiple of
event_size. Ouch!
So add one byte to name_size before we round up and use clear_user to
set userspace to zero like /dev/zero does instead of copying the
strange nul_inotify_event. I can't quite convince myself len_to_zero
will never exceed 16 and even if it doesn't clear_user should be more
efficient and a more accurate reflection of what the code is trying to
do.
Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com>
The are races around the idr storage of inotify watches. It's possible
that a watch could be found from sys_inotify_rm_watch() in the idr, but it
could be removed from the idr before that code does it's removal. Move the
locking and the refcnt'ing so that these have to happen atomically.
If an inotify watch is left in the idr when an fsnotify group is destroyed
this will lead to a BUG. This is not a dangerous situation and really
indicates a programming bug and leak of memory. This patch changes it to
use a WARN and a printk rather than killing people's boxes.
There is nothing known wrong with the inotify watch addition/modification
but this patch seperates the two code paths to make them each easy to
verify as correct.
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6:
ext3: Improve error message that changing journaling mode on remount is not possible
ext3: Update Kconfig description of EXT3_DEFAULTS_TO_ORDERED
Commit 76db6d9500caeaa774a3e32a997eba30bbdc176b (nfs41: add session setup
to the state manager) introduces an infinite loop possibility in the NFSv4
state manager. By first checking nfs4_has_session() before clearing the
NFS4CLNT_SESSION_SETUP flag, it allows for a situation where someone sets
that flag, but it never gets cleared, and so the state manager loops.
In fact commit c3fad1b1aaf850bf692642642ace7cd0d64af0a3 (nfs41: add session
reset to state manager) causes this to happen every time we get a network
partition error.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Tested-by: Daniel J Blueman <daniel.blueman@gmail.com>
ocfs2/dlm: Wait on lockres instead of erroring cancel requests
ocfs2: Add missing lock name
ocfs2: Don't oops in ocfs2_kill_sb on a failed mount
ocfs2: release the buffer head in ocfs2_do_truncate.
ocfs2: Handle quota file corruption more gracefully
2.6.30's commit 8a0bdec194c21c8fdef840989d0d7b742bb5d4bc removed
user_shm_lock() calls in hugetlb_file_setup() but left the
user_shm_unlock call in shm_destroy().
In detail:
Assume that can_do_hugetlb_shm() returns true and hence user_shm_lock()
is not called in hugetlb_file_setup(). However, user_shm_unlock() is
called in any case in shm_destroy() and in the following
atomic_dec_and_lock(&up->__count) in free_uid() is executed and if
up->__count gets zero, also cleanup_user_struct() is scheduled.
Note that sched_destroy_user() is empty if CONFIG_USER_SCHED is not set.
However, the ref counter up->__count gets unexpectedly non-positive and
the corresponding structs are freed even though there are live
references to them, resulting in a kernel oops after a lots of
shmget(SHM_HUGETLB)/shmctl(IPC_RMID) cycles and CONFIG_USER_SCHED set.
Hugh changed Stefan's suggested patch: can_do_hugetlb_shm() at the
time of shm_destroy() may give a different answer from at the time
of hugetlb_file_setup(). And fixed newseg()'s no_id error path,
which has missed user_shm_unlock() ever since it came in 2.6.9.
Reported-by: Stefan Huber <shuber2@gmail.com>
Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Tested-by: Stefan Huber <shuber2@gmail.com>
possible
This patch makes the error message about changing journaling mode on remount
more descriptive. Some people are going to hit this error now due to commit
bbae8bcc49bc4d002221dab52c79a50a82e7cd1f if they configure a kernel to default
to data=writeback mode. The problem happens if they have data=ordered set for
the root filesystem in /etc/fstab but not in the kernel command line (and they
don't use initrd). Their filesystem then gets mounted as data=writeback by
kernel but then their boot fails because init scripts won't be able to remount
the filesystem rw. Better error message will hopefully make it easier for them
to find the error in their setup and bother us less with error reports :).
The old description for this configuration option was perhaps not
completely balanced in terms of describing the tradeoffs of using a
default of data=writeback vs. data=ordered. Despite the fact that old
description very strongly recomended disabling this feature, all of
the major distributions have elected to preserve the existing 'legacy'
default, which is a strong hint that it perhaps wasn't telling the
whole story.
This revised description has been vetted by a number of ext3
developers as being better at informing the user about the tradeoffs
of enabling or disabling this configuration feature.
Cc: linux-ext4@vger.kernel.org
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
vfs_read() offset is defined as loff_t, but kernel_read()
offset is only defined as unsigned long. Redefine
kernel_read() offset as loff_t.
In commit a8e7d49aa7be728c4ae241a75a2a124cdcabc0c5 ("Fix race in
create_empty_buffers() vs __set_page_dirty_buffers()"), I removed a test
for a NULL page mapping unintentionally when some of the code inside
__set_page_dirty() was moved to the callers.
That removal generally didn't matter, since a filesystem would serialize
truncation (which clears the page mapping) against writing (which marks
the buffer dirty), so locking at a higher level (either per-page or an
inode at a time) should mean that the buffer page would be stable. And
indeed, nothing bad seemed to happen.
Except it turns out that apparently reiserfs does something odd when
under load and writing out the journal, and we have a number of bugzilla
entries that look similar:
http://bugzilla.kernel.org/show_bug.cgi?id=13556
http://bugzilla.kernel.org/show_bug.cgi?id=13756
http://bugzilla.kernel.org/show_bug.cgi?id=13876
and it looks like reiserfs depended on that check (the common theme
seems to be "data=journal", and a journal writeback during a truncate).
I suspect reiserfs should have some additional locking, but in the
meantime this should get us back to the pre-2.6.29 behavior.
Pattern-pointed-out-by: Roland Kletzing <devzero@web.de>
Cc: stable@kernel.org (2.6.29 and 2.6.30)
Cc: Jeff Mahoney <jeffm@suse.com>
Cc: Nick Piggin <npiggin@suse.de>
* 'btrfs' of git://git.kernel.dk/linux-2.6-block:
btrfs: fix inode rbtree corruption
Node may not be inserted over existing node. This causes inode tree
corruption and I was seeing crashes in inode_tree_del which I can not
reproduce after this patch.
The other way to fix this would be to tie inode lifetime in the rbtree
with inode while not in freeing state. I had a look at this but it is
not so trivial at this point. At least this patch gets things working again.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Cc: Chris Mason <chris.mason@oracle.com>
Acked-by: Yan Zheng <zheng.yan@oracle.com>
In case a downconvert is queued, and a flock receives a signal,
BUG_ON(lockres->l_action != OCFS2_AST_INVALID) is triggered
because a lock cancel triggers a dlmunlock while an AST is
scheduled.
To avoid this, allow a LKM_CANCEL to pass through, and let it
wait on __dlm_wait_on_lockres().
Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.de>
Acked-off-by: Mark Fasheh <mfasheh@suse.com>
There is missing name for NFSSync cluster lock. This makes lockdep unhappy
because we end up passing NULL to lockdep when initializing lock key. Fix it.
nilfs2: fix oopses with doubly mounted snapshots
nilfs2: missing a read lock for segment writer in nilfs_attach_checkpoint()
