path: root/fs
2011-07-29ARM: report present cpus instead of online CPUsJon Mayo
For machines that use hotplug to control special power domains, report present cpus in /proc/cpuinfo and /proc/stat instead of the standard of reporting online. This break hotplug behavior on all other platforms. The option is enabled using CONFIG_REPORT_PRESENT_CPUS Bug 849167 Change-Id: Ib04bb73634b3a8c99592b1ac13eb471a8ecfd0c5 Reviewed-on: http://git-master/r/37732 Reviewed-by: Jonathan Mayo <jmayo@nvidia.com> Tested-by: Jonathan Mayo <jmayo@nvidia.com> Reviewed-by: Aleksandr Frid <afrid@nvidia.com> Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
2011-07-13fs:yaffs2: filesystem with stable YAFFS2 releasemchourasia
Yaffs2 update is required for making it build with linux-2.6.36 kernel. (cherry picked from commit 801807856be210442c88812b357f4b83fe79b344) Change-Id: I120b262b203c751e1730914ce3b5e6656930bd20 Reviewed-on: http://git-master/r/39783 Reviewed-by: Venu Byravarasu <vbyravarasu@nvidia.com> Tested-by: Manoj Chourasia <mchourasia@nvidia.com> Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
2011-06-06fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going awayJens Axboe
We don't have proper reference counting for this yet, so we run into cases where the device is pulled and we OOPS on flushing the fs data. This happens even though the dirty inodes have already been migrated to the default_backing_dev_info. Bug 808894 (cherry picked from commit 95f28604a65b1c40b6c6cd95e58439cd7ded3add of kernel.org, linux-2.6 tree) Signed-off-by: Jens Axboe <jaxboe@fusionio.com> Change-Id: I56476eb6d33d0fbc0472c0a35dec02e13c4202c9 Reviewed-on: http://git-master/r/32921 Reviewed-by: Venkata Jagadish <vjagadish@nvidia.com> Reviewed-by: Scott Williams <scwilliams@nvidia.com> Reviewed-by: Bitan Biswas <bbiswas@nvidia.com> Tested-by: Venkata Jagadish <vjagadish@nvidia.com>
2011-02-11fs: partitions: efi: Add force_gpt_sector parameterColin Cross
force_gpt_sector=<sector> causes the GPT partition search to look at the specified sector for a valid GPT header if the GPT is not found at the beginning or the end of the block device. Change-Id: I9b5f85ce24719c0538d42ec5a94344c7f6556b2b Signed-off-by: Colin Cross <ccross@android.com>
2011-01-07Merge branch 'linux-tegra-2.6.36' into android-tegra-2.6.36Colin Cross
Conflicts: arch/arm/mm/cache-v6.S Change-Id: I1a2063218dd705a762a40f4a9dfe504ce1a1d491
2011-01-07install_special_mapping skips security_file_mmap check.Tavis Ormandy
commit 462e635e5b73ba9a4c03913b77138cd57ce4b050 upstream. The install_special_mapping routine (used, for example, to setup the vdso) skips the security check before insert_vm_struct, allowing a local attacker to bypass the mmap_min_addr security restriction by limiting the available pages for special mappings. bprm_mm_init() also skips the check, and although I don't think this can be used to bypass any restrictions, I don't see any reason not to have the security check. $ uname -m x86_64 $ cat /proc/sys/vm/mmap_min_addr 65536 $ cat install_special_mapping.s section .bss resb BSS_SIZE section .text global _start _start: mov eax, __NR_pause int 0x80 $ nasm -D__NR_pause=29 -DBSS_SIZE=0xfffed000 -f elf -o install_special_mapping.o install_special_mapping.s $ ld -m elf_i386 -Ttext=0x10000 -Tbss=0x11000 -o install_special_mapping install_special_mapping.o $ ./install_special_mapping & [1] 14303 $ cat /proc/14303/maps 0000f000-00010000 r-xp 00000000 00:00 0 [vdso] 00010000-00011000 r-xp 00001000 00:19 2453665 /home/taviso/install_special_mapping 00011000-ffffe000 rwxp 00000000 00:00 0 [stack] It's worth noting that Red Hat are shipping with mmap_min_addr set to 4096. Signed-off-by: Tavis Ormandy <taviso@google.com> Acked-by: Kees Cook <kees@ubuntu.com> Acked-by: Robert Swiecki <swiecki@google.com> [ Changed to not drop the error code - akpm ] Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-07inotify: stop kernel memory leak on file creation failureEric Paris
commit a2ae4cc9a16e211c8a128ba10d22a85431f093ab upstream. If inotify_init is unable to allocate a new file for the new inotify group we leak the new group. This patch drops the reference on the group on file allocation failure. Reported-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-07NFS: Fix fcntl F_GETLK not reporting some conflictsSergey Vlasov
commit 21ac19d484a8ffb66f64487846c8d53afef04d2b upstream. The commit 129a84de2347002f09721cda3155ccfd19fade40 (locks: fix F_GETLK regression (failure to find conflicts)) fixed the posix_test_lock() function by itself, however, its usage in NFS changed by the commit 9d6a8c5c213e34c475e72b245a8eb709258e968c (locks: give posix_test_lock same interface as ->lock) remained broken - subsequent NFS-specific locking code received F_UNLCK instead of the user-specified lock type. To fix the problem, fl->fl_type needs to be saved before the posix_test_lock() call and restored if no local conflicts were reported. Reference: https://bugzilla.kernel.org/show_bug.cgi?id=23892 Tested-by: Alexander Morozov <amorozov@etersoft.ru> Signed-off-by: Sergey Vlasov <vsu@altlinux.ru> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-07nfsd: Fix possible BUG_ON firing in set_change_infoNeil Brown
commit c1ac3ffcd0bc7e9617f62be8c7043d53ab84deac upstream. If vfs_getattr in fill_post_wcc returns an error, we don't set fh_post_change. For NFSv4, this can result in set_change_info triggering a BUG_ON. i.e. fh_post_saved being zero isn't really a bug. So: - instead of BUGging when fh_post_saved is zero, just clear ->atomic. - if vfs_getattr fails in fill_post_wcc, take a copy of i_ctime anyway. This will be used i seg_change_info, but not overly trusted. - While we are there, remove the pointless 'if' statements in set_change_info. There is no harm setting all the values. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-07NFS: Fix panic after nfs_umount()Chuck Lever
commit 5b362ac3799ff4225c40935500f520cad4d7ed66 upstream. After a few unsuccessful NFS mount attempts in which the client and server cannot agree on an authentication flavor both support, the client panics. nfs_umount() is invoked in the kernel in this case. Turns out nfs_umount()'s UMNT RPC invocation causes the RPC client to write off the end of the rpc_clnt's iostat array. This is because the mount client's nrprocs field is initialized with the count of defined procedures (two: MNT and UMNT), rather than the size of the client's proc array (four). The fix is to use the same initialization technique used by most other upper layer clients in the kernel. Introduced by commit 0b524123, which failed to update nrprocs when support was added for UMNT in the kernel. BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=24302 BugLink: http://bugs.launchpad.net/bugs/683938 Reported-by: Stefan Bader <stefan.bader@canonical.com> Tested-by: Stefan Bader <stefan.bader@canonical.com> Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-07fuse: fix ioctl when server is 32bitMiklos Szeredi
commit d9d318d39dd5cb686660504a3565aac453709ccc upstream. If a 32bit CUSE server is run on 64bit this results in EIO being returned to the caller. The reason is that FUSE_IOCTL_RETRY reply was defined to use 'struct iovec', which is different on 32bit and 64bit archs. Work around this by looking at the size of the reply to determine which struct was used. This is only needed if CONFIG_COMPAT is defined. A more permanent fix for the interface will be to use the same struct on both 32bit and 64bit. Reported-by: "ccmail111" <ccmail111@yahoo.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-07fuse: verify ioctl retriesMiklos Szeredi
commit 7572777eef78ebdee1ecb7c258c0ef94d35bad16 upstream. Verify that the total length of the iovec returned in FUSE_IOCTL_RETRY doesn't overflow iov_length(). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-21Merge branch 'linux-tegra-2.6.36' into android-tegra-2.6.36Colin Cross
Conflicts: drivers/usb/gadget/composite.c Change-Id: I1a332ec21da62aea98912df9a01cf0282ed50ee1
2010-12-09Un-inline get_pipe_info() helper functionLinus Torvalds
commit 72083646528d4887b920deb71b37e09bc7d227bb upstream. This avoids some include-file hell, and the function isn't really important enough to be inlined anyway. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09Export 'get_pipe_info()' to other usersLinus Torvalds
commit c66fb347946ebdd5b10908866ecc9fa05ee2cf3d upstream. And in particular, use it in 'pipe_fcntl()'. The other pipe functions do not need to use the 'careful' version, since they are only ever called for things that are already known to be pipes. The normal read/write/ioctl functions are called through the file operations structures, so if a file isn't a pipe, they'd never get called. But pipe_fcntl() is special, and called directly from the generic fcntl code, and needs to use the same careful function that the splice code is using. Cc: Jens Axboe <jaxboe@fusionio.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09Rename 'pipe_info()' to 'get_pipe_info()'Linus Torvalds
commit 71993e62a47dabddf10302807d6aa260455503f4 upstream. .. and change it to take the 'file' pointer instead of an inode, since that's what all users want anyway. The renaming is preparatory to exporting it to other users. The old 'pipe_info()' name was too generic and is already used elsewhere, so before making the function public we need to use a more specific name. Cc: Jens Axboe <jaxboe@fusionio.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09ext4: fix NULL pointer dereference in print_daily_error_info()Sergey Senozhatsky
commit a1c6c5698d53db4c47a25c3a8d11731a4d7b8370 upstream. Fix NULL pointer dereference in print_daily_error_info, when called on unmounted fs (EXT4_SB(sb) returns NULL), by removing error reporting timer in ext4_put_super. Google-Bug-Id: 3017663 Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09Revert "vfs: show unreachable paths in getcwd and proc"Eric W. Biederman
commit 7b2a69ba7055da9a04eb96aa7b38c8e3280aaaa5 upstream. Because it caused a chroot ttyname regression in 2.6.36. As of 2.6.36 ttyname does not work in a chroot. It has already been reported that screen breaks, and for me this breaks an automated distribution testsuite, that I need to preserve the ability to run the existing binaries on for several more years. glibc 2.11.3 which has a fix for this is not an option. The root cause of this breakage is: commit 8df9d1a4142311c084ffeeacb67cd34d190eff74 Author: Miklos Szeredi <mszeredi@suse.cz> Date: Tue Aug 10 11:41:41 2010 +0200 vfs: show unreachable paths in getcwd and proc Prepend "(unreachable)" to path strings if the path is not reachable from the current root. Two places updated are - the return string from getcwd() - and symlinks under /proc/$PID. Other uses of d_path() are left unchanged (we know that some old software crashes if /proc/mounts is changed). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> So remove the nice sounding, but ultimately ill advised change to how /proc/fd symlinks work. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09cifs: fix parsing of hostname in dfs referralsJeff Layton
commit ba03864872691c0bb580a7fb47388da337ef4aa2 upstream. The DFS referral parsing code does a memchr() call to find the '\\' delimiter that separates the hostname in the referral UNC from the sharename. It then uses that value to set the length of the hostname via pointer subtraction. Instead of subtracting the start of the hostname however, it subtracts the start of the UNC, which causes the code to pass in a hostname length that is 2 bytes too long. Regression introduced in commit 1a4240f4. Reported-and-Tested-by: Robbert Kouprie <robbert@exx.nl> Signed-off-by: Jeff Layton <jlayton@redhat.com> Cc: Wang Lei <wang840925@gmail.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09cifs: fix another memleak, in cifs_root_igetOskar Schirmer
commit a7851ce73b9fdef53f251420e6883cf4f3766534 upstream. cifs_root_iget allocates full_path through cifs_build_path_to_root, but fails to kfree it upon cifs_get_inode_info* failure. Make all failure exit paths traverse clean up handling at the end of the function. Signed-off-by: Oskar Schirmer <oskar@scara.com> Reviewed-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Steve French <sfrench@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09fuse: fix attributes after open(O_TRUNC)Ken Sumrall
commit a0822c55779d9319939eac69f00bb729ea9d23da upstream. The attribute cache for a file was not being cleared when a file is opened with O_TRUNC. If the filesystem's open operation truncates the file ("atomic_o_trunc" feature flag is set) then the kernel should invalidate the cached st_mtime and st_ctime attributes. Also i_size should be explicitly be set to zero as it is used sometimes without refreshing the cache. Signed-off-by: Ken Sumrall <ksumrall@android.com> Cc: Anfei <anfei.zhou@gmail.com> Cc: "Anand V. Avati" <avati@gluster.com> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09exec: copy-and-paste the fixes into compat_do_execve() pathsOleg Nesterov
commit 114279be2120a916e8a04feeb2ac976a10016f2f upstream. Note: this patch targets 2.6.37 and tries to be as simple as possible. That is why it adds more copy-and-paste horror into fs/compat.c and uglifies fs/exec.c, this will be cleanuped later. compat_copy_strings() plays with bprm->vma/mm directly and thus has two problems: it lacks the RLIMIT_STACK check and argv/envp memory is not visible to oom killer. Export acct_arg_size() and get_arg_page(), change compat_copy_strings() to use get_arg_page(), change compat_do_execve() to do acct_arg_size(0) as do_execve() does. Add the fatal_signal_pending/cond_resched checks into compat_count() and compat_copy_strings(), this matches the code in fs/exec.c and certainly makes sense. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09exec: make argv/envp memory visible to oom-killerOleg Nesterov
commit 3c77f845722158206a7209c45ccddc264d19319c upstream. Brad Spengler published a local memory-allocation DoS that evades the OOM-killer (though not the virtual memory RLIMIT): http://www.grsecurity.net/~spender/64bit_dos.c execve()->copy_strings() can allocate a lot of memory, but this is not visible to oom-killer, nobody can see the nascent bprm->mm and take it into account. With this patch get_arg_page() increments current's MM_ANONPAGES counter every time we allocate the new page for argv/envp. When do_execve() succeds or fails, we change this counter back. Technically this is not 100% correct, we can't know if the new page is swapped out and turn MM_ANONPAGES into MM_SWAPENTS, but I don't think this really matters and everything becomes correct once exec changes ->mm or fails. Reported-by: Brad Spengler <spender@grsecurity.net> Reviewed-and-discussed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09bio: take care not overflow page count when mapping/copying user dataJens Axboe
commit cb4644cac4a2797afc847e6c92736664d4b0ea34 upstream. If the iovec is being set up in a way that causes uaddr + PAGE_SIZE to overflow, we could end up attempting to map a huge number of pages. Check for this invalid input type. Reported-by: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09nfs: handle lock context allocation failures in nfs_create_requestJeff Layton
commit 015f0212d51d85bd281a831639a769b4a1a3307a upstream. nfs_get_lock_context can return NULL on an allocation failure. Regression introduced by commit f11ac8db. Reported-by: Steve Dickson <steved@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09ecryptfs: call vfs_setxattr() in ecryptfs_setxattr()Roberto Sassu
commit 48b512e6857139393cdfce26348c362b87537018 upstream. Ecryptfs is a stackable filesystem which relies on lower filesystems the ability of setting/getting extended attributes. If there is a security module enabled on the system it updates the 'security' field of inodes according to the owned extended attribute set with the function vfs_setxattr(). When this function is performed on a ecryptfs filesystem the 'security' field is not updated for the lower filesystem since the call security_inode_post_setxattr() is missing for the lower inode. Further, the call security_inode_setxattr() is missing for the lower inode, leading to policy violations in the security module because specific checks for this hook are not performed (i. e. filesystem 'associate' permission on SELinux is not checked for the lower filesystem). This patch replaces the call of the setxattr() method of the lower inode in the function ecryptfs_setxattr() with vfs_setxattr(). Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Cc: Dustin Kirkland <kirkland@canonical.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09eCryptfs: Clear LOOKUP_OPEN flag when creating lower fileTyler Hicks
commit 2e21b3f124eceb6ab5a07c8a061adce14ac94e14 upstream. eCryptfs was passing the LOOKUP_OPEN flag through to the lower file system, even though ecryptfs_create() doesn't support the flag. A valid filp for the lower filesystem could be returned in the nameidata if the lower file system's create() function supported LOOKUP_OPEN, possibly resulting in unencrypted writes to the lower file. However, this is only a potential problem in filesystems (FUSE, NFS, CIFS, CEPH, 9p) that eCryptfs isn't known to support today. https://bugs.launchpad.net/ecryptfs/+bug/641703 Reported-by: Kevin Buhr Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09hostfs: fix UML crash: remove f_spare from hostfsRichard Weinberger
commit 1b627d5771312c92404b66f0a0b16f66036dd2e1 upstream. 365b1818 ("add f_flags to struct statfs(64)") resized f_spare within struct statfs which caused a UML crash. There is no need to copy f_spare. Signed-off-by: Richard Weinberger <richard@nod.at> Reported-by: Toralf Förster <toralf.foerster@gmx.de> Tested-by: Toralf Förster <toralf.foerster@gmx.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09reiserfs: don't acquire lock recursively in reiserfs_acl_chmodFrederic Weisbecker
commit 238af8751f64a75f8b638193353b1c31ea32e738 upstream. reiserfs_acl_chmod() can be called by reiserfs_set_attr() and then take the reiserfs lock a second time. Thereafter it may call journal_begin() that definitely requires the lock not to be nested in order to release it before taking the journal mutex because the reiserfs lock depends on the journal mutex already. So, aviod nesting the lock in reiserfs_acl_chmod(). Reported-by: Pawel Zawora <pzawora@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Tested-by: Pawel Zawora <pzawora@gmail.com> Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09reiserfs: fix inode mutex - reiserfs lock misorderingFrederic Weisbecker
commit da905873effecd1c0166e578bc4b5006f041b18b upstream. reiserfs_unpack() locks the inode mutex with reiserfs_mutex_lock_safe() to protect against reiserfs lock dependency. However this protection requires to have the reiserfs lock to be locked. This is the case if reiserfs_unpack() is called by reiserfs_ioctl but not from reiserfs_quota_on() when it tries to unpack tails of quota files. Fix the ordering of the two locks in reiserfs_unpack() to fix this issue. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Reported-by: Markus Gapp <markus.gapp@gmx.net> Reported-by: Jan Kara <jack@suse.cz> Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09NFS: Don't SIGBUS if nfs_vm_page_mkwrite races with a cache invalidationTrond Myklebust
commit bc4866b6e0b44f8ea0df22a16e5927714beb4983 upstream. In the case where we lock the page, and then find out that the page has been thrown out of the page cache, we should just return VM_FAULT_NOPAGE. This is what block_page_mkwrite() does in these situations. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09NFSv4: Fix open recoveryTrond Myklebust
commit b0ed9dbc24f1fd912b2dd08b995153cafc1d5b1c upstream. NFSv4 open recovery is currently broken: since we do not clear the state->flags states before attempting recovery, we end up with the 'can_open_cached()' function triggering. This again leads to no OPEN call being put on the wire. Reported-by: Sachin Prabhu <sprabhu@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09NFSv4: Don't call nfs4_state_mark_reclaim_reboot() from error handlersTrond Myklebust
commit ae1007d37e00144b72906a4bdc47d517ae91bcc1 upstream. In the case of a server reboot, the state recovery thread starts by calling nfs4_state_end_reclaim_reboot() in order to avoid edge conditions when the server reboots while the client is in the middle of recovery. However, if the client has already marked the nfs4_state as requiring reboot recovery, then the above behaviour will cause the recovery thread to treat the open as if it was part of such an edge condition: the open will be recovered as if it was part of a lease expiration (and all the locks will be lost). Fix is to remove the call to nfs4_state_mark_reclaim_reboot from nfs4_async_handle_error(), and nfs4_handle_exception(). Instead we leave it to the recovery thread to do this for us. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09NFSv4: Don't call nfs4_reclaim_complete() on receiving NFS4ERR_STALE_CLIENTIDTrond Myklebust
commit 6eaa61496fb3b93cceface7a296415fc4c030bce upstream. If the server sends us an NFS4ERR_STALE_CLIENTID while the state management thread is busy reclaiming state, we do want to treat all state that wasn't reclaimed before the STALE_CLIENTID as if a network partition occurred (see the edge conditions described in RFC3530 and RFC5661). What we do not want to do is to send an nfs4_reclaim_complete(), since we haven't yet even started reclaiming state after the server rebooted. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09block: limit vec count in bio_kmalloc() and bio_alloc_map_data()Jens Axboe
commit f3f63c1c28bc861a931fac283b5bc3585efb8967 upstream. Reported-by: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-01Merge branch 'android-2.6.36' into android-tegra-2.6.36Colin Cross
2010-12-01ext4: initialize the percpu counters before replaying the journalTheodore Ts'o
We now initialize the percpu counters before replaying the journal, but after the journal, we recalculate the global counters, to deal with the possibility of the per-blockgroup counts getting updated by the journal replay. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-12-01fuse: fix attributes after open(O_TRUNC)Ken Sumrall
The attribute cache for a file was not being cleared when a file is opened with O_TRUNC. If the filesystem's open operation truncates the file ("atomic_o_trunc" feature flag is set) then the kernel should invalidate the cached st_mtime and st_ctime attributes. Also i_size should be explicitly be set to zero as it is used sometimes without refreshing the cache. Signed-off-by: Ken Sumrall <ksumrall@android.com> Cc: Anfei <anfei.zhou@gmail.com> Cc: "Anand V. Avati" <avati@gluster.com> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-22Fixed Regression in NFS Direct I/O pathSteve Dickson
commit 568a810d7edd58bd505222dd1c7e48895532290b upstream. A typo, introduced by commit f11ac8db, in the nfs_direct_write() routine causes writes with O_DIRECT set to fail with a ENOMEM error. Found-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve Dickson <steved@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22pipe: fix failure to return error code on ->confirm()Nicolas Kaiser
commit e5953cbdff26f7cbae7eff30cd9b18c4e19b7594 upstream. The arguments were transposed, we want to assign the error code to 'ret', which is being returned. Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22cifs: fix broken oplock handlingSuresh Jayaraman
commit aa91c7e4ab9b0842b7d7a7cbf8cca18b20df89b5 upstream. cifs_new_fileinfo() does not use the 'oplock' value from the callers. Instead, it sets it to REQ_OPLOCK which seems wrong. We should be using the oplock value obtained from the Server to set the inode's clientCanCacheAll or clientCanCacheRead flags. Fix this by passing oplock from the callers to cifs_new_fileinfo(). This change dates back to commit a6ce4932 (2.6.30-rc3). So, all the affected versions will need this fix. Please Cc stable once reviewed and accepted. Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Steve French <sfrench@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-02Merge branch 'android-2.6.36' into android-tegra-2.6.36Colin Cross
2010-10-29ext4: fix kernel oops if the journal superblock has a non-zero j_errnoTheodore Ts'o
Commit 84061e0 fixed an accounting bug only to introduce the possibility of a kernel OOPS if the journal has a non-zero j_errno field indicating that the file system had detected a fs inconsistency. After the journal replay, if the journal superblock indicates that the file system has an error, this indication is transfered to the file system and then ext4_commit_super() is called to write this to the disk. But since the percpu counters are now initialized after the journal replay, the call to ext4_commit_super() will cause a kernel oops since it needs to use the percpu counters the ext4 superblock structure. The fix is to skip setting the ext4 free block and free inode fields if the percpu counter has not been set. Thanks to Ken Sumrall for reporting and analyzing the root causes of this bug. Addresses-Google-Bug: #3054080 Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-21Merge commit 'v2.6.36' into android-2.6.36Dima Zavin
2010-10-21Merge branch 'linux-tegra-2.6.36' into android-tegra-2.6.36Colin Cross
2010-10-15Merge branch 'linux-tegra-2.6.36' into android-tegra-2.6.36Colin Cross
2010-10-14Export dump_{write,seek} to binary loader modulesLinus Torvalds
If you build aout support as a module, you'll want these exported. Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-14Un-inline the core-dump helper functionsLinus Torvalds
Tony Luck reports that the addition of the access_ok() check in commit 0eead9ab41da ("Don't dump task struct in a.out core-dumps") broke the ia64 compile due to missing the necessary header file includes. Rather than add yet another include (<asm/unistd.h>) to make everything happy, just uninline the silly core dump helper functions and move the bodies to fs/exec.c where they make a lot more sense. dump_seek() in particular was too big to be an inline function anyway, and none of them are in any way performance-critical. And we really don't need to mess up our include file headers more than they already are. Reported-and-tested-by: Tony Luck <tony.luck@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-14Don't dump task struct in a.out core-dumpsLinus Torvalds
akiphie points out that a.out core-dumps have that odd task struct dumping that was never used and was never really a good idea (it goes back into the mists of history, probably the original core-dumping code). Just remove it. Also do the access_ok() check on dump_write(). It probably doesn't matter (since normal filesystems all seem to do it anyway), but he points out that it's normally done by the VFS layer, so ... [ I suspect that we should possibly do "vfs_write()" instead of calling ->write directly. That also does the whole fsnotify and write statistics thing, which may or may not be a good idea. ] And just to be anal, do this all for the x86-64 32-bit a.out emulation code too, even though it's not enabled (and won't currently even compile) Reported-by: akiphie <akiphie@lavabit.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-13Merge branch 'for-2.6.36' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.36' of git://linux-nfs.org/~bfields/linux: nfsd: fix BUG at fs/nfsd/nfsfh.h:199 on unlink
