commit 0633da48f0793aeba27f82d30605624416723a91 upstream.
autofs_sbi() does not check the superblock magic number to verify it has
been given an autofs super block.
Backport Note: autofs4 has been renamed to autofs upstream. As a result
the upstream patch does not apply cleanly onto 4.14.y.
Link: http://lkml.kernel.org/r/153475422934.17131.7563724552005298277.stgit@pluto.themaw.net
Reported-by: <syzbot+87c3c541582e56943277@syzkaller.appspotmail.com>
Signed-off-by: Ian Kent <raven@themaw.net>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: Zubin Mithra <zsm@chromium.org>
[ Upstream commit bd3d16a887b0c19a2a20d35ffed499e3a3637feb ]
If the client is sending a layoutget, but the server issues a callback
to recall what it thinks may be an outstanding layout, then we may find
an uninitialised layout attached to the inode due to the layoutget.
In that case, it is appropriate to return NFS4ERR_NOMATCHING_LAYOUT
rather than NFS4ERR_DELAY, as the latter can end up deadlocking.
Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com>
[ Upstream commit c77ec61ca0a49544ca81881cc5d5529858f7e196 ]
This patch adds to do sanity check with {sit,nat}_ver_bitmap_bytesize
during mount, in order to avoid accessing across cache boundary with
this abnormal bitmap size.
- Overview
buffer overrun in build_sit_info() when mounting a crafted f2fs image
- Reproduce
- Kernel message
[ 548.580867] F2FS-fs (loop0): Invalid log blocks per segment (8201)
[ 548.580877] F2FS-fs (loop0): Can't find valid F2FS filesystem in 1th superblock
[ 548.584979] ==================================================================
[ 548.586568] BUG: KASAN: use-after-free in kmemdup+0x36/0x50
[ 548.587715] Read of size 64 at addr ffff8801e9c265ff by task mount/1295
[ 548.589428] CPU: 1 PID: 1295 Comm: mount Not tainted 4.18.0-rc1+ #4
[ 548.589432] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 548.589438] Call Trace:
[ 548.589474] dump_stack+0x7b/0xb5
[ 548.589487] print_address_description+0x70/0x290
[ 548.589492] kasan_report+0x291/0x390
[ 548.589496] ? kmemdup+0x36/0x50
[ 548.589509] check_memory_region+0x139/0x190
[ 548.589514] memcpy+0x23/0x50
[ 548.589518] kmemdup+0x36/0x50
[ 548.589545] f2fs_build_segment_manager+0x8fa/0x3410
[ 548.589551] ? __asan_loadN+0xf/0x20
[ 548.589560] ? f2fs_sanity_check_ckpt+0x1be/0x240
[ 548.589566] ? f2fs_flush_sit_entries+0x10c0/0x10c0
[ 548.589587] ? __put_user_ns+0x40/0x40
[ 548.589604] ? find_next_bit+0x57/0x90
[ 548.589610] f2fs_fill_super+0x194b/0x2b40
[ 548.589617] ? f2fs_commit_super+0x1b0/0x1b0
[ 548.589637] ? set_blocksize+0x90/0x140
[ 548.589651] mount_bdev+0x1c5/0x210
[ 548.589655] ? f2fs_commit_super+0x1b0/0x1b0
[ 548.589667] f2fs_mount+0x15/0x20
[ 548.589672] mount_fs+0x60/0x1a0
[ 548.589683] ? alloc_vfsmnt+0x309/0x360
[ 548.589688] vfs_kern_mount+0x6b/0x1a0
[ 548.589699] do_mount+0x34a/0x18c0
[ 548.589710] ? lockref_put_or_lock+0xcf/0x160
[ 548.589716] ? copy_mount_string+0x20/0x20
[ 548.589728] ? memcg_kmem_put_cache+0x1b/0xa0
[ 548.589734] ? kasan_check_write+0x14/0x20
[ 548.589740] ? _copy_from_user+0x6a/0x90
[ 548.589744] ? memdup_user+0x42/0x60
[ 548.589750] ksys_mount+0x83/0xd0
[ 548.589755] __x64_sys_mount+0x67/0x80
[ 548.589781] do_syscall_64+0x78/0x170
[ 548.589797] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 548.589820] RIP: 0033:0x7f76fc331b9a
[ 548.589821] Code: 48 8b 0d 01 c3 2b 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 49 89 ca b8 a5 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d ce c2 2b 00 f7 d8 64 89 01 48
[ 548.589880] RSP: 002b:00007ffd4f0a0e48 EFLAGS: 00000206 ORIG_RAX: 00000000000000a5
[ 548.589890] RAX: ffffffffffffffda RBX: 000000000146c030 RCX: 00007f76fc331b9a
[ 548.589892] RDX: 000000000146c210 RSI: 000000000146df30 RDI: 0000000001474ec0
[ 548.589895] RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000013
[ 548.589897] R10: 00000000c0ed0000 R11: 0000000000000206 R12: 0000000001474ec0
[ 548.589900] R13: 000000000146c210 R14: 0000000000000000 R15: 0000000000000003
[ 548.590242] The buggy address belongs to the page:
[ 548.591243] page:ffffea0007a70980 count:0 mapcount:0 mapping:0000000000000000 index:0x0
[ 548.592886] flags: 0x2ffff0000000000()
[ 548.593665] raw: 02ffff0000000000 dead000000000100 dead000000000200 0000000000000000
[ 548.595258] raw: 0000000000000000 0000000000000000 00000000ffffffff 0000000000000000
[ 548.603713] page dumped because: kasan: bad access detected
[ 548.605203] Memory state around the buggy address:
[ 548.606198] ffff8801e9c26480: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 548.607676] ffff8801e9c26500: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 548.609157] >ffff8801e9c26580: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 548.610629] ^
[ 548.612088] ffff8801e9c26600: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 548.613674] ffff8801e9c26680: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 548.615141] ==================================================================
[ 548.616613] Disabling lock debugging due to kernel taint
[ 548.622871] WARNING: CPU: 1 PID: 1295 at mm/page_alloc.c:4065 __alloc_pages_slowpath+0xe4a/0x1420
[ 548.622878] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hwdep snd_hda_core snd_pcm snd_timer snd mac_hid i2c_piix4 soundcore ib_iser rdma_cm iw_cm ib_cm ib_core iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear 8139too crct10dif_pclmul crc32_pclmul qxl drm_kms_helper syscopyarea aesni_intel sysfillrect sysimgblt fb_sys_fops ttm drm aes_x86_64 crypto_simd cryptd 8139cp glue_helper mii pata_acpi floppy
[ 548.623217] CPU: 1 PID: 1295 Comm: mount Tainted: G B 4.18.0-rc1+ #4
[ 548.623219] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 548.623226] RIP: 0010:__alloc_pages_slowpath+0xe4a/0x1420
[ 548.623227] Code: ff ff 01 89 85 c8 fe ff ff e9 91 fc ff ff 41 89 c5 e9 5c fc ff ff 0f 0b 89 f8 25 ff ff f7 ff 89 85 8c fe ff ff e9 d5 f2 ff ff <0f> 0b e9 65 f2 ff ff 65 8b 05 38 81 d2 47 f6 c4 01 74 1c 65 48 8b
[ 548.623281] RSP: 0018:ffff8801f28c7678 EFLAGS: 00010246
[ 548.623284] RAX: 0000000000000000 RBX: 00000000006040c0 RCX: ffffffffb82f73b7
[ 548.623287] RDX: 1ffff1003e518eeb RSI: 000000000000000c RDI: 0000000000000000
[ 548.623290] RBP: ffff8801f28c7880 R08: 0000000000000000 R09: ffffed0047fff2c5
[ 548.623292] R10: 0000000000000001 R11: ffffed0047fff2c4 R12: ffff8801e88de040
[ 548.623295] R13: 00000000006040c0 R14: 000000000000000c R15: ffff8801f28c7938
[ 548.623299] FS: 00007f76fca51840(0000) GS:ffff8801f6f00000(0000) knlGS:0000000000000000
[ 548.623302] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 548.623304] CR2: 00007f19b9171760 CR3: 00000001ed952000 CR4: 00000000000006e0
[ 548.623317] Call Trace:
[ 548.623325] ? kasan_check_read+0x11/0x20
[ 548.623330] ? __zone_watermark_ok+0x92/0x240
[ 548.623336] ? get_page_from_freelist+0x1c3/0x1d90
[ 548.623347] ? _raw_spin_lock_irqsave+0x2a/0x60
[ 548.623353] ? warn_alloc+0x250/0x250
[ 548.623358] ? save_stack+0x46/0xd0
[ 548.623361] ? kasan_kmalloc+0xad/0xe0
[ 548.623366] ? __isolate_free_page+0x2a0/0x2a0
[ 548.623370] ? mount_fs+0x60/0x1a0
[ 548.623374] ? vfs_kern_mount+0x6b/0x1a0
[ 548.623378] ? do_mount+0x34a/0x18c0
[ 548.623383] ? ksys_mount+0x83/0xd0
[ 548.623387] ? __x64_sys_mount+0x67/0x80
[ 548.623391] ? do_syscall_64+0x78/0x170
[ 548.623396] ? entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 548.623401] __alloc_pages_nodemask+0x3c5/0x400
[ 548.623407] ? __alloc_pages_slowpath+0x1420/0x1420
[ 548.623412] ? __mutex_lock_slowpath+0x20/0x20
[ 548.623417] ? kvmalloc_node+0x31/0x80
[ 548.623424] alloc_pages_current+0x75/0x110
[ 548.623436] kmalloc_order+0x24/0x60
[ 548.623442] kmalloc_order_trace+0x24/0xb0
[ 548.623448] __kmalloc_track_caller+0x207/0x220
[ 548.623455] ? f2fs_build_node_manager+0x399/0xbb0
[ 548.623460] kmemdup+0x20/0x50
[ 548.623465] f2fs_build_node_manager+0x399/0xbb0
[ 548.623470] f2fs_fill_super+0x195e/0x2b40
[ 548.623477] ? f2fs_commit_super+0x1b0/0x1b0
[ 548.623481] ? set_blocksize+0x90/0x140
[ 548.623486] mount_bdev+0x1c5/0x210
[ 548.623489] ? f2fs_commit_super+0x1b0/0x1b0
[ 548.623495] f2fs_mount+0x15/0x20
[ 548.623498] mount_fs+0x60/0x1a0
[ 548.623503] ? alloc_vfsmnt+0x309/0x360
[ 548.623508] vfs_kern_mount+0x6b/0x1a0
[ 548.623513] do_mount+0x34a/0x18c0
[ 548.623518] ? lockref_put_or_lock+0xcf/0x160
[ 548.623523] ? copy_mount_string+0x20/0x20
[ 548.623528] ? memcg_kmem_put_cache+0x1b/0xa0
[ 548.623533] ? kasan_check_write+0x14/0x20
[ 548.623537] ? _copy_from_user+0x6a/0x90
[ 548.623542] ? memdup_user+0x42/0x60
[ 548.623547] ksys_mount+0x83/0xd0
[ 548.623552] __x64_sys_mount+0x67/0x80
[ 548.623557] do_syscall_64+0x78/0x170
[ 548.623562] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 548.623566] RIP: 0033:0x7f76fc331b9a
[ 548.623567] Code: 48 8b 0d 01 c3 2b 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 49 89 ca b8 a5 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d ce c2 2b 00 f7 d8 64 89 01 48
[ 548.623632] RSP: 002b:00007ffd4f0a0e48 EFLAGS: 00000206 ORIG_RAX: 00000000000000a5
[ 548.623636] RAX: ffffffffffffffda RBX: 000000000146c030 RCX: 00007f76fc331b9a
[ 548.623639] RDX: 000000000146c210 RSI: 000000000146df30 RDI: 0000000001474ec0
[ 548.623641] RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000013
[ 548.623643] R10: 00000000c0ed0000 R11: 0000000000000206 R12: 0000000001474ec0
[ 548.623646] R13: 000000000146c210 R14: 0000000000000000 R15: 0000000000000003
[ 548.623650] ---[ end trace 4ce02f25ff7d3df5 ]---
[ 548.623656] F2FS-fs (loop0): Failed to initialize F2FS node manager
[ 548.627936] F2FS-fs (loop0): Invalid log blocks per segment (8201)
[ 548.627940] F2FS-fs (loop0): Can't find valid F2FS filesystem in 1th superblock
[ 548.635835] F2FS-fs (loop0): Failed to initialize F2FS node manager
- Location
https://elixir.bootlin.com/linux/v4.18-rc1/source/fs/f2fs/segment.c#L3578
sit_i->sit_bitmap = kmemdup(src_bitmap, bitmap_size, GFP_KERNEL);
Buffer overrun happens when doing memcpy. I suspect there is missing (inconsistent) checks on bitmap_size.
Reported by Wen Xu (wen.xu@gatech.edu) from SSLab, Gatech.
Reported-by: Wen Xu <wen.xu@gatech.edu>
Signed-off-by: Chao Yu <yuchao0@huawei.com>
Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
[ Upstream commit 2a96d8ad94ce57cb0072f7a660b1039720c47716 ]
"ret" can be uninitialized on the success path when "in ==
F2FS_GOING_DOWN_FULLSYNC".
Fixes: 60b2b4ee2bc0 ("f2fs: Fix deadlock in shutdown ioctl")
Reviewed-by: Chao Yu <yuchao0@huawei.com>
[ Upstream commit 4dbe38dc386910c668c75ae616b99b823b59f3eb ]
As Wen Xu reported in bugzilla, after image was injected with random data
by fuzzing, inline inode would contain invalid reserved blkaddr, then
during inline conversion, we will encounter illegal memory accessing
reported by KASAN, the root cause of this is when writing out converted
inline page, we will use invalid reserved blkaddr to update sit bitmap,
result in accessing memory beyond sit bitmap boundary.
In order to fix this issue, let's do sanity check with reserved block
address of inline inode to avoid above condition.
https://bugzilla.kernel.org/show_bug.cgi?id=200179
[ 1428.846352] BUG: KASAN: use-after-free in update_sit_entry+0x80/0x7f0
[ 1428.846618] Read of size 4 at addr ffff880194483540 by task a.out/2741
[ 1428.846855] CPU: 0 PID: 2741 Comm: a.out Tainted: G W 4.17.0+ #1
[ 1428.846858] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 1428.846860] Call Trace:
[ 1428.846868] dump_stack+0x71/0xab
[ 1428.846875] print_address_description+0x6b/0x290
[ 1428.846881] kasan_report+0x28e/0x390
[ 1428.846888] ? update_sit_entry+0x80/0x7f0
[ 1428.846898] update_sit_entry+0x80/0x7f0
[ 1428.846906] f2fs_allocate_data_block+0x6db/0xc70
[ 1428.846914] ? f2fs_get_node_info+0x14f/0x590
[ 1428.846920] do_write_page+0xc8/0x150
[ 1428.846928] f2fs_outplace_write_data+0xfe/0x210
[ 1428.846935] ? f2fs_do_write_node_page+0x170/0x170
[ 1428.846941] ? radix_tree_tag_clear+0xff/0x130
[ 1428.846946] ? __mod_node_page_state+0x22/0xa0
[ 1428.846951] ? inc_zone_page_state+0x54/0x100
[ 1428.846956] ? __test_set_page_writeback+0x336/0x5d0
[ 1428.846964] f2fs_convert_inline_page+0x407/0x6d0
[ 1428.846971] ? f2fs_read_inline_data+0x3b0/0x3b0
[ 1428.846978] ? __get_node_page+0x335/0x6b0
[ 1428.846987] f2fs_convert_inline_inode+0x41b/0x500
[ 1428.846994] ? f2fs_convert_inline_page+0x6d0/0x6d0
[ 1428.847000] ? kasan_unpoison_shadow+0x31/0x40
[ 1428.847005] ? kasan_kmalloc+0xa6/0xd0
[ 1428.847024] f2fs_file_mmap+0x79/0xc0
[ 1428.847029] mmap_region+0x58b/0x880
[ 1428.847037] ? arch_get_unmapped_area+0x370/0x370
[ 1428.847042] do_mmap+0x55b/0x7a0
[ 1428.847048] vm_mmap_pgoff+0x16f/0x1c0
[ 1428.847055] ? vma_is_stack_for_current+0x50/0x50
[ 1428.847062] ? __fsnotify_update_child_dentry_flags.part.1+0x160/0x160
[ 1428.847068] ? do_sys_open+0x206/0x2a0
[ 1428.847073] ? __fget+0xb4/0x100
[ 1428.847079] ksys_mmap_pgoff+0x278/0x360
[ 1428.847085] ? find_mergeable_anon_vma+0x50/0x50
[ 1428.847091] do_syscall_64+0x73/0x160
[ 1428.847098] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 1428.847102] RIP: 0033:0x7fb1430766ba
[ 1428.847103] Code: 89 f5 41 54 49 89 fc 55 53 74 35 49 63 e8 48 63 da 4d 89 f9 49 89 e8 4d 63 d6 48 89 da 4c 89 ee 4c 89 e7 b8 09 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 56 5b 5d 41 5c 41 5d 41 5e 41 5f c3 0f 1f 00
[ 1428.847162] RSP: 002b:00007ffc651d9388 EFLAGS: 00000246 ORIG_RAX: 0000000000000009
[ 1428.847167] RAX: ffffffffffffffda RBX: 0000000000000001 RCX: 00007fb1430766ba
[ 1428.847170] RDX: 0000000000000001 RSI: 0000000000001000 RDI: 0000000000000000
[ 1428.847173] RBP: 0000000000000003 R08: 0000000000000003 R09: 0000000000000000
[ 1428.847176] R10: 0000000000008002 R11: 0000000000000246 R12: 0000000000000000
[ 1428.847179] R13: 0000000000001000 R14: 0000000000008002 R15: 0000000000000000
[ 1428.847252] Allocated by task 2683:
[ 1428.847372] kasan_kmalloc+0xa6/0xd0
[ 1428.847380] kmem_cache_alloc+0xc8/0x1e0
[ 1428.847385] getname_flags+0x73/0x2b0
[ 1428.847390] user_path_at_empty+0x1d/0x40
[ 1428.847395] vfs_statx+0xc1/0x150
[ 1428.847401] __do_sys_newlstat+0x7e/0xd0
[ 1428.847405] do_syscall_64+0x73/0x160
[ 1428.847411] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 1428.847466] Freed by task 2683:
[ 1428.847566] __kasan_slab_free+0x137/0x190
[ 1428.847571] kmem_cache_free+0x85/0x1e0
[ 1428.847575] filename_lookup+0x191/0x280
[ 1428.847580] vfs_statx+0xc1/0x150
[ 1428.847585] __do_sys_newlstat+0x7e/0xd0
[ 1428.847590] do_syscall_64+0x73/0x160
[ 1428.847596] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 1428.847648] The buggy address belongs to the object at ffff880194483300
which belongs to the cache names_cache of size 4096
[ 1428.847946] The buggy address is located 576 bytes inside of
4096-byte region [ffff880194483300, ffff880194484300)
[ 1428.848234] The buggy address belongs to the page:
[ 1428.848366] page:ffffea0006512000 count:1 mapcount:0 mapping:ffff8801f3586380 index:0x0 compound_mapcount: 0
[ 1428.848606] flags: 0x17fff8000008100(slab|head)
[ 1428.848737] raw: 017fff8000008100 dead000000000100 dead000000000200 ffff8801f3586380
[ 1428.848931] raw: 0000000000000000 0000000000070007 00000001ffffffff 0000000000000000
[ 1428.849122] page dumped because: kasan: bad access detected
[ 1428.849305] Memory state around the buggy address:
[ 1428.849436] ffff880194483400: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 1428.849620] ffff880194483480: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 1428.849804] >ffff880194483500: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 1428.849985] ^
[ 1428.850120] ffff880194483580: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 1428.850303] ffff880194483600: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 1428.850498] ==================================================================
[ Upstream commit 10d255c3540239c7920f52d2eb223756e186af56 ]
If segment type in SSA and SIT is inconsistent, we will encounter below
BUG_ON during GC, to avoid this panic, let's just skip doing GC on such
segment.
The bug is triggered with image reported in below link:
https://bugzilla.kernel.org/show_bug.cgi?id=200223
[ 388.060262] ------------[ cut here ]------------
[ 388.060268] kernel BUG at /home/y00370721/git/devf2fs/gc.c:989!
[ 388.061172] invalid opcode: 0000 [#1] SMP
[ 388.061773] Modules linked in: f2fs(O) bluetooth ecdh_generic xt_tcpudp iptable_filter ip_tables x_tables lp ttm drm_kms_helper drm intel_rapl sb_edac crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcbc aesni_intel fb_sys_fops ppdev aes_x86_64 syscopyarea crypto_simd sysfillrect parport_pc joydev sysimgblt glue_helper parport cryptd i2c_piix4 serio_raw mac_hid btrfs hid_generic usbhid hid raid6_pq psmouse pata_acpi floppy
[ 388.064247] CPU: 7 PID: 4151 Comm: f2fs_gc-7:0 Tainted: G O 4.13.0-rc1+ #26
[ 388.065306] Hardware name: Xen HVM domU, BIOS 4.1.2_115-900.260_ 11/06/2015
[ 388.066058] task: ffff880201583b80 task.stack: ffffc90004d7c000
[ 388.069948] RIP: 0010:do_garbage_collect+0xcc8/0xcd0 [f2fs]
[ 388.070766] RSP: 0018:ffffc90004d7fc68 EFLAGS: 00010202
[ 388.071783] RAX: ffff8801ed227000 RBX: 0000000000000001 RCX: ffffea0007b489c0
[ 388.072700] RDX: ffff880000000000 RSI: 0000000000000001 RDI: ffffea0007b489c0
[ 388.073607] RBP: ffffc90004d7fd58 R08: 0000000000000003 R09: ffffea0007b489dc
[ 388.074619] R10: 0000000000000000 R11: 0052782ab317138d R12: 0000000000000018
[ 388.075625] R13: 0000000000000018 R14: ffff880211ceb000 R15: ffff880211ceb000
[ 388.076687] FS: 0000000000000000(0000) GS:ffff880214fc0000(0000) knlGS:0000000000000000
[ 388.083277] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 388.084536] CR2: 0000000000e18c60 CR3: 00000001ecf2e000 CR4: 00000000001406e0
[ 388.085748] Call Trace:
[ 388.086690] ? find_next_bit+0xb/0x10
[ 388.088091] f2fs_gc+0x1a8/0x9d0 [f2fs]
[ 388.088888] ? lock_timer_base+0x7d/0xa0
[ 388.090213] ? try_to_del_timer_sync+0x44/0x60
[ 388.091698] gc_thread_func+0x342/0x4b0 [f2fs]
[ 388.092892] ? wait_woken+0x80/0x80
[ 388.094098] kthread+0x109/0x140
[ 388.095010] ? f2fs_gc+0x9d0/0x9d0 [f2fs]
[ 388.096043] ? kthread_park+0x60/0x60
[ 388.097281] ret_from_fork+0x25/0x30
[ 388.098401] Code: ff ff 48 83 e8 01 48 89 44 24 58 e9 27 f8 ff ff 48 83 e8 01 e9 78 fc ff ff 48 8d 78 ff e9 17 fb ff ff 48 83 ef 01 e9 4d f4 ff ff <0f> 0b 66 0f 1f 44 00 00 0f 1f 44 00 00 55 48 89 e5 41 56 41 55
[ 388.100864] RIP: do_garbage_collect+0xcc8/0xcd0 [f2fs] RSP: ffffc90004d7fc68
[ 388.101810] ---[ end trace 81c73d6e6b7da61d ]---
[ Upstream commit 4b270a8cc5047682f0a3f3f9af3b498408dbd2bc ]
In synchronous scenario, like in checkpoint(), we are going to flush
dirty node pages to device synchronously, we can easily failed
writebacking node page due to trylock_page() failure, especially in
condition of intensive lock competition, which can cause long latency
of checkpoint(). So let's use lock_page() in synchronous scenario to
avoid this issue.
Signed-off-by: Yunlei He <heyunlei@huawei.com>
[ Upstream commit 32cd3ee511f4e07ca25d71163b50e704808d22f4 ]
If there is an error during processing of a callback message, it leads
to refrence leak on the client structure and eventually an unclean
superblock.
Signed-off-by: Olga Kornievskaia <kolga@netapp.com>
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
[ Upstream commit 3611ce9911267cb93d364bd71ddea6821278d11f ]
For the case when sbi->segs_per_sec > 1, take section:segment = 5 for
example, if segment 1 is just used and allocate new segment 2, and the
blocks of segment 1 is invalidated, at this time, the previous code will
use __set_test_and_free to free the free_secmap and free_sections++,
this is not correct since it is still a current section, so fix it.
Signed-off-by: Yunlong Song <yunlong.song@huawei.com>
commit d814a49198eafa6163698bdd93961302f3a877a4 upstream.
We use customized, nodesize batch value to update dirty_metadata_bytes.
We should also use batch version of compare function or we will easily
goto fast path and get false result from percpu_counter_compare().
Fixes: e2d845211eda ("Btrfs: use percpu counter for dirty metadata count")
CC: stable@vger.kernel.org # 4.4+
Signed-off-by: Ethan Lien <ethanlien@synology.com>
Reviewed-by: Nikolay Borisov <nborisov@suse.com>
Signed-off-by: David Sterba <dsterba@suse.com>
nb: Rebased on 4.4.y ]
Signed-off-by: Nikolay Borisov <nborisov@suse.com>
[ Upstream commit 43794446548730ac8461be30bbe47d5d027d1d16 ]
[BUG]
Under certain KVM load and LTP tests, it is possible to hit the
following calltrace if quota is enabled:
BTRFS critical (device vda2): unable to find logical 8820195328 length 4096
WARNING: CPU: 0 PID: 49 at ../block/blk-core.c:172 blk_status_to_errno+0x1a/0x30
CPU: 0 PID: 49 Comm: kworker/u2:1 Not tainted 4.12.14-15-default #1 SLE15 (unreleased)
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.0.0-prebuilt.qemu-project.org 04/01/2014
Workqueue: btrfs-endio-write btrfs_endio_write_helper [btrfs]
task: ffff9f827b340bc0 task.stack: ffffb4f8c0304000
RIP: 0010:blk_status_to_errno+0x1a/0x30
Call Trace:
submit_extent_page+0x191/0x270 [btrfs]
? btrfs_create_repair_bio+0x130/0x130 [btrfs]
__do_readpage+0x2d2/0x810 [btrfs]
? run_one_async_done+0xc0/0xc0 [btrfs]
__extent_read_full_page+0xe7/0x100 [btrfs]
read_extent_buffer_pages+0x1ab/0x2d0 [btrfs]
btree_read_extent_buffer_pages+0x94/0xf0 [btrfs]
read_tree_block+0x31/0x60 [btrfs]
read_block_for_search.isra.35+0xf0/0x2e0 [btrfs]
btrfs_search_slot+0x46b/0xa00 [btrfs]
? kmem_cache_alloc+0x1a8/0x510
? btrfs_get_token_32+0x5b/0x120 [btrfs]
find_parent_nodes+0x11d/0xeb0 [btrfs]
? leaf_space_used+0xb8/0xd0 [btrfs]
? btrfs_leaf_free_space+0x49/0x90 [btrfs]
? btrfs_find_all_roots_safe+0x93/0x100 [btrfs]
btrfs_find_all_roots+0x45/0x60 [btrfs]
btrfs_qgroup_trace_extent_post+0x20/0x40 [btrfs]
btrfs_add_delayed_data_ref+0x1a3/0x1d0 [btrfs]
btrfs_alloc_reserved_file_extent+0x38/0x40 [btrfs]
insert_reserved_file_extent.constprop.71+0x289/0x2e0 [btrfs]
btrfs_finish_ordered_io+0x2f4/0x7f0 [btrfs]
? pick_next_task_fair+0x2cd/0x530
? __switch_to+0x92/0x4b0
btrfs_worker_helper+0x81/0x300 [btrfs]
process_one_work+0x1da/0x3f0
worker_thread+0x2b/0x3f0
? process_one_work+0x3f0/0x3f0
kthread+0x11a/0x130
? kthread_create_on_node+0x40/0x40
ret_from_fork+0x35/0x40
BTRFS critical (device vda2): unable to find logical 8820195328 length 16384
BTRFS: error (device vda2) in btrfs_finish_ordered_io:3023: errno=-5 IO failure
BTRFS info (device vda2): forced readonly
BTRFS error (device vda2): pending csums is 2887680
[CAUSE]
It's caused by race with block group auto removal:
- There is a meta block group X, which has only one tree block
The tree block belongs to fs tree 257.
- In current transaction, some operation modified fs tree 257
The tree block gets COWed, so the block group X is empty, and marked
as unused, queued to be deleted.
- Some workload (like fsync) wakes up cleaner_kthread()
Which will call btrfs_delete_unused_bgs() to remove unused block
groups.
So block group X along its chunk map get removed.
- Some delalloc work finished for fs tree 257
Quota needs to get the original reference of the extent, which will
read tree blocks of commit root of 257.
Then since the chunk map gets removed, the above warning gets
triggered.
[FIX]
Just let btrfs_delete_unused_bgs() skip block group which still has
pinned bytes.
However there is a minor side effect: currently we only queue empty
blocks at update_block_group(), and such empty block group with pinned
bytes won't go through update_block_group() again, such block group
won't be removed, until it gets new extent allocated and removed.
Signed-off-by: Qu Wenruo <wqu@suse.com>
Reviewed-by: Filipe Manana <fdmanana@suse.com>
initialized
[ Upstream commit 389305b2aa68723c754f88d9dbd268a400e10664 ]
Invalid reloc tree can cause kernel NULL pointer dereference when btrfs
does some cleanup of the reloc roots.
It turns out that fs_info::reloc_ctl can be NULL in
btrfs_recover_relocation() as we allocate relocation control after all
reloc roots have been verified.
So when we hit: note, we haven't called set_reloc_control() thus
fs_info::reloc_ctl is still NULL.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=199833
Reported-by: Xu Wen <wen.xu@gatech.edu>
Tested-by: Gu Jinxiang <gujx@cn.fujitsu.com>
Reviewed-by: David Sterba <dsterba@suse.com>
[ Upstream commit 1e7e1f9e3aba00c9b9c323bfeeddafe69ff21ff6 ]
on-disk devs stats value is updated in btrfs_run_dev_stats(),
which is called during commit transaction, if device->dev_stats_ccnt
is not zero.
Since current replace operation does not touch dev_stats_ccnt,
on-disk dev stats value is not updated. Therefore "btrfs device stats"
may return old device's value after umount/mount
(Example: See "btrfs ins dump-t -t DEV $DEV" after btrfs/100 finish).
Fix this by just incrementing dev_stats_ccnt in
btrfs_dev_replace_finishing() when replace is succeeded and this will
update the values.
Signed-off-by: Misono Tomohiro <misono.tomohiro@jp.fujitsu.com>
[ Upstream commit 289131e1f1e6ad8c661ec05e176b8f0915672059 ]
For SMB2/SMB3 the number of requests sent was not displayed
in /proc/fs/cifs/Stats unless CONFIG_CIFS_STATS2 was
enabled (only number of failed requests displayed). As
with earlier dialects, we should be displaying these
counters if CONFIG_CIFS_STATS is enabled. They
are important for debugging.
e.g. when you cat /proc/fs/cifs/Stats (before the patch)
Resources in use
CIFS Session: 1
Share (unique mount targets): 2
SMB Request/Response Buffer: 1 Pool size: 5
SMB Small Req/Resp Buffer: 1 Pool size: 30
Operations (MIDs): 0
0 session 0 share reconnects
Total vfs operations: 690 maximum at one time: 2
1) \\localhost\test
SMBs: 975
Negotiates: 0 sent 0 failed
SessionSetups: 0 sent 0 failed
Logoffs: 0 sent 0 failed
TreeConnects: 0 sent 0 failed
TreeDisconnects: 0 sent 0 failed
Creates: 0 sent 2 failed
Closes: 0 sent 0 failed
Flushes: 0 sent 0 failed
Reads: 0 sent 0 failed
Writes: 0 sent 0 failed
Locks: 0 sent 0 failed
IOCTLs: 0 sent 1 failed
Cancels: 0 sent 0 failed
Echos: 0 sent 0 failed
QueryDirectories: 0 sent 63 failed
Signed-off-by: Steve French <stfrench@microsoft.com>
Reviewed-by: Aurelien Aptel <aaptel@suse.com>
Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
[ Upstream commit c281bc0c7412308c7ec0888904f7c99353da4796 ]
echo 0 > /proc/fs/cifs/Stats is supposed to reset the stats
but there were four (see example below) that were not reset
(bytes read and witten, total vfs ops and max ops
at one time).
Total vfs operations: 100 maximum at one time: 2
1) \\localhost\test
SMBs: 0
Bytes read: 502092 Bytes written: 31457286
TreeConnects: 0 total 0 failed
TreeDisconnects: 0 total 0 failed
This patch fixes cifs_stats_proc_write to properly reset
those four.
[ Upstream commit 6cd00a01f0c1ae6a852b09c59b8dd55cc6c35d1d ]
Since only dentry->d_name.len + 1 bytes out of DNAME_INLINE_LEN bytes
are initialized at __d_alloc(), we can't copy the whole size
unconditionally.
WARNING: kmemcheck: Caught 32-bit read from uninitialized memory (ffff8fa27465ac50)
636f6e66696766732e746d70000000000010000000000000020000000188ffff
i i i i i i i i i i i i i u u u u u u u u u u i i i i i u u u u
RIP: 0010:take_dentry_name_snapshot+0x28/0x50
RSP: 0018:ffffa83000f5bdf8 EFLAGS: 00010246
RAX: 0000000000000020 RBX: ffff8fa274b20550 RCX: 0000000000000002
RDX: ffffa83000f5be40 RSI: ffff8fa27465ac50 RDI: ffffa83000f5be60
RBP: ffffa83000f5bdf8 R08: ffffa83000f5be48 R09: 0000000000000001
R10: ffff8fa27465ac00 R11: ffff8fa27465acc0 R12: ffff8fa27465ac00
R13: ffff8fa27465acc0 R14: 0000000000000000 R15: 0000000000000000
FS: 00007f79737ac8c0(0000) GS:ffffffff8fc30000(0000) knlGS:0000000000000000
CR2: ffff8fa274c0b000 CR3: 0000000134aa7002 CR4: 00000000000606f0
vfs_rename+0x128/0x870
SyS_rename+0x3b2/0x3d0
entry_SYSCALL_64_fastpath+0x1a/0xa4
0xffffffffffffffff
Link: http://lkml.kernel.org/r/201709131912.GBG39012.QMJLOVFSFFOOtH@I-love.SAKURA.ne.jp
Cc: Vegard Nossum <vegard.nossum@gmail.com>
[ Upstream commit 0afa9626667c3659ef8bd82d42a11e39fedf235c ]
On corrupted FATfs may have invalid ->i_start. To handle it, this checks
->i_start before using, and return proper error code.
Link: http://lkml.kernel.org/r/87o9f8y1t5.fsf_-_@mail.parknet.co.jp
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Reported-by: Anatoly Trosinenko <anatoly.trosinenko@gmail.com>
Tested-by: Anatoly Trosinenko <anatoly.trosinenko@gmail.com>
Cc: Alan Cox <gnomes@lxorguk.ukuu.org.uk>
[ Upstream commit a7ec7a4193a2eb3b5341243fc0b621c1ac9e4ec4 ]
An HFS+ filesystem can be mounted read-only without having a metadata
directory, which is needed to support hardlinks. But if the catalog
data is corrupted, a directory lookup may still find dentries claiming
to be hardlinks.
hfsplus_lookup() does check that ->hidden_dir is not NULL in such a
situation, but mistakenly does so after dereferencing it for the first
time. Reorder this check to prevent a crash.
This happens when looking up corrupted catalog data (dentry) on a
filesystem with no metadata directory (this could only ever happen on a
read-only mount). Wen Xu sent the replication steps in detail to the
fsdevel list: https://bugzilla.kernel.org/show_bug.cgi?id=200297
Link: http://lkml.kernel.org/r/20180712215344.q44dyrhymm4ajkao@eaf
Signed-off-by: Ernesto A. Fernández <ernesto.mnd.fernandez@gmail.com>
Cc: Viacheslav Dubeyko <slava@dubeyko.com>
[ Upstream commit 8b73ce6a4bae4fe12bcb2c361c0da4183c2e1b6f ]
This uses the deprecated time_t type but is write-only, and could be
removed, but as Jeff explains, having a timestamp can be usefule for
post-mortem analysis in crash dumps.
In order to remove one of the last instances of time_t, this changes the
type to time64_t, same as j_trans_start_time.
Link: http://lkml.kernel.org/r/20180622133315.221210-1-arnd@arndb.de
Cc: Jan Kara <jack@suse.cz>
Cc: Jeff Mahoney <jeffm@suse.com>
[ Upstream commit dc2572791d3a41bab94400af2b6bca9d71ccd303 ]
hfs_find_exit() expects fd->bnode to be NULL after a search has failed.
hfs_brec_insert() may instead set it to an error-valued pointer. Fix
this to prevent a crash.
Link: http://lkml.kernel.org/r/53d9749a029c41b4016c495fc5838c9dba3afc52.1530294815.git.ernesto.mnd.fernandez@gmail.com
Cc: Anatoly Trosinenko <anatoly.trosinenko@gmail.com>
[ Upstream commit 7464726cb5998846306ed0a7d6714afb2e37b25d ]
syzbot is reporting NULL pointer dereference at mount_fs() [1]. This is
because hfsplus_fill_super() is by error returning 0 when
hfsplus_fill_super() detected invalid filesystem image, and mount_bdev()
is returning NULL because dget(s->s_root) == NULL if s->s_root == NULL,
and mount_fs() is accessing root->d_sb because IS_ERR(root) == false if
root == NULL. Fix this by returning -EINVAL when hfsplus_fill_super()
detected invalid filesystem image.
[1] https://syzkaller.appspot.com/bug?id=21acb6850cecbc960c927229e597158cf35f33d0
Link: http://lkml.kernel.org/r/d83ce31a-874c-dd5b-f790-41405983a5be@I-love.SAKURA.ne.jp
Reported-by: syzbot <syzbot+01ffaf5d9568dd1609f7@syzkaller.appspotmail.com>
Reviewed-by: Ernesto A. Fernández <ernesto.mnd.fernandez@gmail.com>
[ Upstream commit e6c47dd0da1e3a484e778046fc10da0b20606a86 ]
Some SMB2/3 servers, Win2016 but possibly others too, adds padding
not only between PDUs in a compound but also to the final PDU.
This padding extends the PDU to a multiple of 8 bytes.
Check if the unexpected length looks like this might be the case
and avoid triggering the log messages for :
"SMB2 server sent bad RFC1001 len %d not %d\n"
Signed-off-by: Ronnie Sahlberg <lsahlber@redhat.com>
commit 7b6924d94a60c6b8c1279ca003e8744e6cd9e8b1 upstream.
'type' is user-controlled, so sanitize it after the bounds check to
avoid using it in speculative execution. This covers the following
potential gadgets detected with the help of smatch:
* fs/ext4/super.c:5741 ext4_quota_read() warn: potential spectre issue
'sb_dqopt(sb)->files' [r]
* fs/ext4/super.c:5778 ext4_quota_write() warn: potential spectre issue
* fs/f2fs/super.c:1552 f2fs_quota_read() warn: potential spectre issue
* fs/f2fs/super.c:1608 f2fs_quota_write() warn: potential spectre issue
* fs/quota/dquot.c:412 mark_info_dirty() warn: potential spectre issue
'sb_dqopt(sb)->info' [w]
* fs/quota/dquot.c:933 dqinit_needed() warn: potential spectre issue
'dquots' [r]
* fs/quota/dquot.c:2112 dquot_commit_info() warn: potential spectre
issue 'dqopt->ops' [r]
* fs/quota/dquot.c:2362 vfs_load_quota_inode() warn: potential spectre
issue 'dqopt->files' [w] (local cap)
* fs/quota/dquot.c:2369 vfs_load_quota_inode() warn: potential spectre
issue 'dqopt->ops' [w] (local cap)
* fs/quota/dquot.c:2370 vfs_load_quota_inode() warn: potential spectre
issue 'dqopt->info' [w] (local cap)
* fs/quota/quota.c:110 quota_getfmt() warn: potential spectre issue
'sb_dqopt(sb)->info' [r]
* fs/quota/quota_v2.c:84 v2_check_quota_file() warn: potential spectre
issue 'quota_magics' [w]
* fs/quota/quota_v2.c:85 v2_check_quota_file() warn: potential spectre
issue 'quota_versions' [w]
* fs/quota/quota_v2.c:96 v2_read_file_info() warn: potential spectre
issue 'dqopt->info' [r]
* fs/quota/quota_v2.c:172 v2_write_file_info() warn: potential spectre
Additionally, a quick inspection indicates there are array accesses with
'type' in quota_on() and quota_off() functions which are also addressed
by this.
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: stable@vger.kernel.org
Signed-off-by: Jeremy Cline <jcline@redhat.com>
commit 82c9a927bc5df6e06b72d206d24a9d10cced4eb5 upstream.
When running in a container with a user namespace, if you call getxattr
with name = "system.posix_acl_access" and size % 8 != 4, then getxattr
silently skips the user namespace fixup that it normally does resulting in
un-fixed-up data being returned.
This is caused by posix_acl_fix_xattr_to_user() being passed the total
buffer size and not the actual size of the xattr as returned by
vfs_getxattr().
This commit passes the actual length of the xattr as returned by
vfs_getxattr() down.
A reproducer for the issue is:
touch acl_posix
setfacl -m user:0:rwx acl_posix
and the compile:
#define _GNU_SOURCE
#include <errno.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <sys/types.h>
#include <unistd.h>
#include <attr/xattr.h>
/* Run in user namespace with nsuid 0 mapped to uid != 0 on the host. */
int main(int argc, void **argv)
ssize_t ret1, ret2;
char buf1[128], buf2[132];
int fret = EXIT_SUCCESS;
char *file;
if (argc < 2) {
fprintf(stderr,
"Please specify a file with "
"\"system.posix_acl_access\" permissions set\n");
_exit(EXIT_FAILURE);
file = argv[1];
ret1 = getxattr(file, "system.posix_acl_access",
buf1, sizeof(buf1));
if (ret1 < 0) {
fprintf(stderr, "%s - Failed to retrieve "
"\"system.posix_acl_access\" "
"from \"%s\"\n", strerror(errno), file);
ret2 = getxattr(file, "system.posix_acl_access",
buf2, sizeof(buf2));
if (ret2 < 0) {
if (ret1 != ret2) {
fprintf(stderr, "The value of \"system.posix_acl_"
"access\" for file \"%s\" changed "
"between two successive calls\n", file);
for (ssize_t i = 0; i < ret2; i++) {
if (buf1[i] == buf2[i])
continue;
fprintf(stderr,
"Unexpected different in byte %zd: "
"%02x != %02x\n", i, buf1[i], buf2[i]);
fret = EXIT_FAILURE;
if (fret == EXIT_SUCCESS)
fprintf(stderr, "Test passed\n");
else
fprintf(stderr, "Test failed\n");
_exit(fret);
and run:
./tester acl_posix
On a non-fixed up kernel this should return something like:
root@c1:/# ./t
Unexpected different in byte 16: ffffffa0 != 00
Unexpected different in byte 17: ffffff86 != 00
Unexpected different in byte 18: 01 != 00
and on a fixed kernel:
root@c1:~# ./t
Test passed
Fixes: 2f6f0654ab61 ("userns: Convert vfs posix_acl support to use kuids and kgids")
Link: https://bugzilla.kernel.org/show_bug.cgi?id=199945
Reported-by: Colin Watson <cjwatson@ubuntu.com>
Signed-off-by: Christian Brauner <christian@brauner.io>
Acked-by: Serge Hallyn <serge@hallyn.com>
commit 59965593205fa4044850d35ee3557cf0b7edcd14 upstream.
In ubifs_jnl_update() we sync parent and child inodes to the flash,
in case of xattrs, the parent inode (AKA host inode) has a non-zero
data_len. Therefore we need to adjust synced_i_size too.
This issue was reported by ubifs self tests unter a xattr related work
load.
UBIFS error (ubi0:0 pid 1896): dbg_check_synced_i_size: ui_size is 4, synced_i_size is 0, but inode is clean
UBIFS error (ubi0:0 pid 1896): dbg_check_synced_i_size: i_ino 65, i_mode 0x81a4, i_size 4
Cc: <stable@vger.kernel.org>
Fixes: 1e51764a3c2a ("UBIFS: add new flash file system")
Signed-off-by: Richard Weinberger <richard@nod.at>
commit 95a22d2084d72ea067d8323cc85677dba5d97cae upstream.
Check whether the size is within bounds before using it.
If the size is not correct, abort and dump the bad data node.
Cc: Silvio Cesare <silvio.cesare@gmail.com>
Fixes: 1e51764a3c2ac ("UBIFS: add new flash file system")
Reported-by: Silvio Cesare <silvio.cesare@gmail.com>
commit 08acbdd6fd736b90f8d725da5a0de4de2dd6de62 upstream.
This reverts commit 353748a359f1821ee934afc579cf04572406b420.
It bypassed the linux-mtd review process and fixes the issue not as it
should.
commit eef19816ada3abd56d9f20c88794cc2fea83ebb2 upstream.
Allocate the buffer after we return early.
Otherwise memory is being leaked.
commit 0f90be132cbf1537d87a6a8b9e80867adac892f6 upstream.
After a live data migration event at the NFS server, the client may send
I/O requests to the wrong server, causing a live hang due to repeated
recovery events. On the wire, this will appear as an I/O request failing
with NFS4ERR_BADSESSION, followed by successful CREATE_SESSION, repeatedly.
NFS4ERR_BADSSESSION is returned because the session ID being used was
issued by the other server and is not valid at the old server.
The failure is caused by async worker threads having cached the transport
(xprt) in the rpc_task structure. After the migration recovery completes,
the task is redispatched and the task resends the request to the wrong
server based on the old value still present in tk_xprt.
The solution is to recompute the tk_xprt field of the rpc_task structure
so that the request goes to the correct server.
Signed-off-by: Bill Baker <bill.baker@oracle.com>
Reviewed-by: Chuck Lever <chuck.lever@oracle.com>
Tested-by: Helen Chao <helen.chao@oracle.com>
Fixes: fb43d17210ba ("SUNRPC: Use the multipath iterator to assign a ...")
Cc: stable@vger.kernel.org # v4.9+
commit 0914bb965e38a055e9245637aed117efbe976e91 upstream.
"dev->nr_children" is the number of children which were parsed
successfully in bl_parse_stripe(). It could be all of them and then, in
that case, it is equal to v->stripe.volumes_count. Either way, the >
should be >= so that we don't go beyond the end of what we're supposed
to.
Fixes: 5c83746a0cf2 ("pnfs/blocklayout: in-kernel GETDEVICEINFO XDR parsing")
Cc: stable@vger.kernel.org # 3.17+
commit 3111784bee81591ea2815011688d28b65df03627 upstream.
In my testing, v9fs_fid_xattr_set will return successfully even if the
backend ext4 filesystem has no space to store xattr key-value. That will
cause inconsistent behavior between front end and back end. The reason is
that lsetxattr will be triggered by p9_client_clunk, and unfortunately we
did not catch the error. This patch will catch the error to notify upper
caller.
p9_client_clunk (in 9p)
p9_client_rpc(clnt, P9_TCLUNK, "d", fid->fid);
v9fs_clunk (in qemu)
put_fid
free_fid
v9fs_xattr_fid_clunk
v9fs_co_lsetxattr
s->ops->lsetxattr
ext4_xattr_user_set (in host ext4 filesystem)
Link: http://lkml.kernel.org/r/5B57EACC.2060900@huawei.com
Signed-off-by: Jun Piao <piaojun@huawei.com>
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Ron Minnich <rminnich@sandia.gov>
Cc: Latchesar Ionkov <lucho@ionkov.net>
Signed-off-by: Dominique Martinet <dominique.martinet@cea.fr>
commit 2afc9166f79b8f6da5f347f48515215ceee4ae37 upstream.
Introduce these two functions and export them such that the next patch
can add calls to these functions from the SCSI core.
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit 109728ccc5933151c68d1106e4065478a487a323 upstream.
The above error path returns with page unlocked, so this place seems also
to behave the same.
Fixes: f8dbdf81821b ("fuse: rework fuse_readpages()")
Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com>
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
commit e8f3bd773d22f488724dffb886a1618da85c2966 upstream.
syzbot is hitting NULL pointer dereference at process_init_reply().
This is because deactivate_locked_super() is called before response for
initial request is processed.
Fix this by aborting and waiting for all requests (including FUSE_INIT)
before resetting fc->sb.
Original patch by Tetsuo Handa <penguin-kernel@I-love.SKAURA.ne.jp>.
Reported-by: syzbot <syzbot+b62f08f4d5857755e3bc@syzkaller.appspotmail.com>
Fixes: e27c9d3877a0 ("fuse: fuse: add time_gran to INIT_OUT")
Cc: <stable@vger.kernel.org> # v3.19
commit b8f95e5d13f5f0191dcb4b9113113d241636e7cb upstream.
fuse_abort_conn() does not guarantee that all async requests have actually
finished aborting (i.e. their ->end() function is called). This could
actually result in still used inodes after umount.
Add a helper to wait until all requests are fully done. This is done by
looking at the "num_waiting" counter. When this counter drops to zero, we
can be sure that no more requests are outstanding.
Fixes: 0d8e84b0432b ("fuse: simplify request abort")
Cc: <stable@vger.kernel.org> # v4.2
commit 45ff350bbd9d0f0977ff270a0d427c71520c0c37 upstream.
fuse_dev_release() assumes that it's the only one referencing the
fpq->processing list, but that's not true, since fuse_abort_conn() can be
doing the same without any serialization between the two.
Fixes: c3696046beb3 ("fuse: separate pqueue for clones")
commit 87114373ea507895a62afb10d2910bd9adac35a8 upstream.
Refcounting of request is broken when fuse_abort_conn() is called and
request is on the fpq->io list:
- ref is taken too late
- then it is not dropped
commit 63576c13bd17848376c8ba4a98f5d5151140c4ac upstream.
If parallel dirops are enabled in FUSE_INIT reply, then first operation may
leave fi->mutex held.
Reported-by: syzbot <syzbot+3f7b29af1baa9d0a55be@syzkaller.appspotmail.com>
Fixes: 5c672ab3f0ee ("fuse: serialize dirops by default")
Cc: <stable@vger.kernel.org> # v4.7
commit a2477b0e67c52f4364a47c3ad70902bc2a61bd4c upstream.
fuse_dev_splice_write() reads pipe->buffers to determine the size of
'bufs' array before taking the pipe_lock(). This is not safe as
another thread might change the 'pipe->buffers' between the allocation
and taking the pipe_lock(). So we end up with too small 'bufs' array.
Move the bufs allocations inside pipe_lock()/pipe_unlock() to fix this.
Fixes: dd3bb14f44a6 ("fuse: support splice() writing to fuse device")
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: <stable@vger.kernel.org> # v2.6.35
commit f39b3f45dbcb0343822cce31ea7636ad66e60bc2 upstream.
When ext4_find_entry() falls back to "searching the old fashioned
way" due to a corrupt dx dir, it needs to reset the error code
to NULL so that the nonstandard ERR_BAD_DX_DIR code isn't returned
to userspace.
https://bugzilla.kernel.org/show_bug.cgi?id=199947
Reported-by: Anatoly Trosinenko <anatoly.trosinenko@yandex.com>
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit a4d2aadca184ece182418950d45ba4ffc7b652d2 upstream.
While working on extended rand for last_error/first_error timestamps,
I noticed that the endianess is wrong; we access the little-endian
fields in struct ext4_super_block as native-endian when we print them.
This adds a special case in ext4_attr_show() and ext4_attr_store()
to byteswap the superblock fields if needed.
In older kernels, this code was part of super.c, it got moved to
sysfs.c in linux-4.4.
Fixes: 52c198c6820f ("ext4: add sysfs entry showing whether the fs contains errors")
commit 7d95178c77014dbd8dce36ee40bbbc5e6c121ff5 upstream.
Extended attribute names are defined to be NUL-terminated, so the name
must not contain a NUL character. This is important because there are
places when remove extended attribute, the code uses strlen to
determine the length of the entry. That should probably be fixed at
some point, but code is currently really messy, so the simplest fix
for now is to simply validate that the extended attributes are sane.
https://bugzilla.kernel.org/show_bug.cgi?id=200401
commit 22783155f4bf956c346a81624ec9258930a6fe06 upstream.
Fixes problem pointed out by Pavel in discussions about commit
729c0c9dd55204f0c9a823ac8a7bfa83d36c7e78
Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com>
Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com>
CC: Stable <stable@vger.kernel.org> # 3.18.x+
commit fd09b7d3b352105f08b8e02f7afecf7e816380ef upstream.
An earlier commit had a typo which prevented the
optimization from working:
commit 18dd8e1a65dd ("Do not send SMB3 SET_INFO request if nothing is changing")
Thank you to Metze for noticing this. Also clear a
reserved field in the FILE_BASIC_INFO struct we send
that should be zero (all the other fields in that
struct were set or cleared explicitly already in
cifs_set_file_info).
CC: Stable <stable@vger.kernel.org> # 4.9.x+
Reported-by: Stefan Metzmacher <metze@samba.org>
commit e02789a53d71334b067ad72eee5d4e88a0158083 upstream.
When enumerating snapshots, the last few bytes of the final
snapshot could be left off since we were miscalculating the
length returned (leaving off the sizeof struct SRV_SNAPSHOT_ARRAY)
See MS-SMB2 section 2.2.32.2. In addition fixup the length used
to allow smaller buffer to be passed in, in order to allow
returning the size of the whole snapshot array more easily.
Sample userspace output with a kernel patched with this
(mounted to a Windows volume with two snapshots).
Before this patch, the second snapshot would be missing a
few bytes at the end.
~/cifs-2.6# ~/enum-snapshots /mnt/file
press enter to issue the ioctl to retrieve snapshot information ...
size of snapshot array = 102
Num snapshots: 2 Num returned: 2 Array Size: 102
Snapshot 0:@GMT-2018.06.30-19.34.17
Snapshot 1:@GMT-2018.06.30-19.33.37
commit 126c97f4d0d1b5b956e8b0740c81a2b2a2ae548c upstream.
The kmalloc was not being checked - if it fails issue a warning
and return -ENOMEM to the caller.
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
Fixes: b8da344b74c8 ("cifs: dynamic allocation of ntlmssp blob")
cc: Stable <stable@vger.kernel.org>`
commit 950132afd59385caf6e2b84e5235d069fa10681d upstream.
/proc/fs/cifs/DebugData displays the features (Kconfig options)
used to build cifs.ko but it was missing some, and needed comma
separator. These can be useful in debugging certain problems
so we know which optional features were enabled in the user's build.
Also clarify them, by making them more closely match the
corresponding CONFIG_CIFS_* parm.
Old format:
Features: dfs fscache posix spnego xattr acl
New format:
Features: DFS,FSCACHE,SMB_DIRECT,STATS,DEBUG2,ALLOW_INSECURE_LEGACY,CIFS_POSIX,UPCALL(SPNEGO),XATTR,ACL
Reviewed-by: Paulo Alcantara <palcantara@suse.de>
[ Upstream commit a3f94cb99a854fa381fe7fadd97c4f61633717a5 ]
Previously in squashfs_readpage() when copying data into the page
cache, it used the length of the datablock read from the filesystem
(after decompression). However, if the filesystem has been corrupted
this data block may be short, which will leave pages unfilled.
The fix for this is to compute the expected number of bytes to copy
from the inode size, and use this to detect if the block is short.
Signed-off-by: Phillip Lougher <phillip@squashfs.org.uk>
Tested-by: Willy Tarreau <w@1wt.eu>
Cc: Анатолий Тросиненко <anatoly.trosinenko@gmail.com>
[ Upstream commit cdbb65c4c7ead680ebe54f4f0d486e2847a500ea ]
Anatoly continues to find issues with fuzzed squashfs images.
This time, corrupt, missing, or undersized data for the page filling
wasn't checked for, because the squashfs_{copy,read}_cache() functions
did the squashfs_copy_data() call without checking the resulting data
size.
Which could result in the page cache pages being incompletely filled in,
and no error indication to the user space reading garbage data.
So make a helper function for the "fill in pages" case, because the
exact same incomplete sequence existed in two places.
[ I should have made a squashfs branch for these things, but I didn't
intend to start doing them in the first place.
My historical connection through cramfs is why I got into looking at
these issues at all, and every time I (continue to) think it's a
one-off.
Because _this_ time is always the last time. Right? - Linus ]
Cc: Phillip Lougher <phillip@squashfs.org.uk>
[ Upstream commit c2412ac45a8f8f1cd582723c1a139608694d410d ]
If we meet a conflicting object that is marked FSCACHE_OBJECT_IS_LIVE in
the active object tree, we have been emitting a BUG after logging
information about it and the new object.
Instead, we should wait for the CACHEFILES_OBJECT_ACTIVE flag to be cleared
on the old object (or return an error). The ACTIVE flag should be cleared
after it has been removed from the active object tree. A timeout of 60s is
used in the wait, so we shouldn't be able to get stuck there.
Fixes: 9ae326a69004 ("CacheFiles: A cache that backs onto a mounted filesystem")
Signed-off-by: Kiran Kumar Modukuri <kiran.modukuri@gmail.com>
