path: root/fs
2011-09-02Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: fix ->write_inode return values xfs: fix xfs_mark_inode_dirty during umount xfs: deprecate the nodelaylog mount option
2011-09-01xfs: fix ->write_inode return valuesChristoph Hellwig
Currently we always redirty an inode that was attempted to be written out synchronously but has been cleaned by an AIL pushed internall, which is rather bogus. Fix that by doing the i_update_core check early on and return 0 for it. Also include async calls for it, as doing any work for those is just as pointless. While we're at it also fix the sign for the EIO return in case of a filesystem shutdown, and fix the completely non-sensical locking around xfs_log_inode. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Alex Elder <aelder@sgi.com> (cherry picked from commit 297db93bb74cf687510313eb235a7aec14d67e97) Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-31xfs: fix xfs_mark_inode_dirty during umountChristoph Hellwig
During umount we do not add a dirty inode to the lru and wait for it to become clean first, but force writeback of data and metadata with I_WILL_FREE set. Currently there is no way for XFS to detect that the inode has been redirtied for metadata operations, as we skip the mark_inode_dirty call during teardown. Fix this by setting i_update_core nanually in that case, so that the inode gets flushed during inode reclaim. Alternatively we could enable calling mark_inode_dirty for inodes in I_WILL_FREE state, and let the VFS dirty tracking handle this. I decided against this as we will get better I/O patterns from reclaim compared to the synchronous writeout in write_inode_now, and always marking the inode dirty in some way from xfs_mark_inode_dirty is a better safetly net in either case. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Alex Elder <aelder@sgi.com> (cherry picked from commit da6742a5a4cc844a9982fdd936ddb537c0747856) Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-31Merge tag 'for_linus-20110831' of git://github.com/tytso/ext4Linus Torvalds
* tag 'for_linus-20110831' of git://github.com/tytso/ext4: ext4: remove i_mutex lock in ext4_evict_inode to fix lockdep complaining
2011-08-31ext4: remove i_mutex lock in ext4_evict_inode to fix lockdep complainingJiaying Zhang
The i_mutex lock and flush_completed_IO() added by commit 2581fdc810 in ext4_evict_inode() causes lockdep complaining about potential deadlock in several places. In most/all of these LOCKDEP complaints it looks like it's a false positive, since many of the potential circular locking cases can't take place by the time the ext4_evict_inode() is called; but since at the very least it may mask real problems, we need to address this. This change removes the flush_completed_IO() and i_mutex lock in ext4_evict_inode(). Instead, we take a different approach to resolve the software lockup that commit 2581fdc810 intends to fix. Rather than having ext4-dio-unwritten thread wait for grabing the i_mutex lock of an inode, we use mutex_trylock() instead, and simply requeue the work item if we fail to grab the inode's i_mutex lock. This should speed up work queue processing in general and also prevents the following deadlock scenario: During page fault, shrink_icache_memory is called that in turn evicts another inode B. Inode B has some pending io_end work so it calls ext4_ioend_wait() that waits for inode B's i_ioend_count to become zero. However, inode B's ioend work was queued behind some of inode A's ioend work on the same cpu's ext4-dio-unwritten workqueue. As the ext4-dio-unwritten thread on that cpu is processing inode A's ioend work, it tries to grab inode A's i_mutex lock. Since the i_mutex lock of inode A is still hold before the page fault happened, we enter a deadlock. Signed-off-by: Jiaying Zhang <jiayingz@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-08-26All Arch: remove linkage for sys_nfsservctl system callNeilBrown
The nfsservctl system call is now gone, so we should remove all linkage for it. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-25lockdep: Add helper function for dir vs file i_mutex annotationJosh Boyer
Purely in-memory filesystems do not use the inode hash as the dcache tells us if an entry already exists. As a result, they do not call unlock_new_inode, and thus directory inodes do not get put into a different lockdep class for i_sem. We need the different lockdep classes, because the locking order for i_mutex is different for directory inodes and regular inodes. Directory inodes can do "readdir()", which takes i_mutex *before* possibly taking mm->mmap_sem (due to a page fault while copying the directory entry to user space). In contrast, regular inodes can be mmap'ed, which takes mm->mmap_sem before accessing i_mutex. The two cases can never happen for the same inode, so no real deadlock can occur, but without the different lockdep classes, lockdep cannot understand that. As a result, if CONFIG_DEBUG_LOCK_ALLOC is set, this can lead to false positives from lockdep like below: find/645 is trying to acquire lock: (&mm->mmap_sem){++++++}, at: [<ffffffff81109514>] might_fault+0x5c/0xac but task is already holding lock: (&sb->s_type->i_mutex_key#15){+.+.+.}, at: [<ffffffff81149f34>] vfs_readdir+0x5b/0xb4 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (&sb->s_type->i_mutex_key#15){+.+.+.}: [<ffffffff8108ac26>] lock_acquire+0xbf/0x103 [<ffffffff814db822>] __mutex_lock_common+0x4c/0x361 [<ffffffff814dbc46>] mutex_lock_nested+0x40/0x45 [<ffffffff811daa87>] hugetlbfs_file_mmap+0x82/0x110 [<ffffffff81111557>] mmap_region+0x258/0x432 [<ffffffff811119dd>] do_mmap_pgoff+0x2ac/0x306 [<ffffffff81111b4f>] sys_mmap_pgoff+0x118/0x16a [<ffffffff8100c858>] sys_mmap+0x22/0x24 [<ffffffff814e3ec2>] system_call_fastpath+0x16/0x1b -> #0 (&mm->mmap_sem){++++++}: [<ffffffff8108a4bc>] __lock_acquire+0xa1a/0xcf7 [<ffffffff8108ac26>] lock_acquire+0xbf/0x103 [<ffffffff81109541>] might_fault+0x89/0xac [<ffffffff81149cff>] filldir+0x6f/0xc7 [<ffffffff811586ea>] dcache_readdir+0x67/0x205 [<ffffffff81149f54>] vfs_readdir+0x7b/0xb4 [<ffffffff8114a073>] sys_getdents+0x7e/0xd1 [<ffffffff814e3ec2>] system_call_fastpath+0x16/0x1b This patch moves the directory vs file lockdep annotation into a helper function that can be called by in-memory filesystems and has hugetlbfs call it. Signed-off-by: Josh Boyer <jwboyer@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-25xfs: deprecate the nodelaylog mount optionChristoph Hellwig
2011-08-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: check size of FUSE_NOTIFY_INVAL_ENTRY message fuse: mark pages accessed when written to fuse: delete dead .write_begin and .write_end aops fuse: fix flock fuse: fix non-ANSI void function notation
2011-08-24fuse: check size of FUSE_NOTIFY_INVAL_ENTRY messageMiklos Szeredi
FUSE_NOTIFY_INVAL_ENTRY didn't check the length of the write so the message processing could overrun and result in a "kernel BUG at fs/fuse/dev.c:629!" Reported-by: Han-Wen Nienhuys <hanwenn@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: stable@kernel.org
2011-08-23Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: fix tracing builds inside the source tree xfs: remove subdirectories xfs: don't expect xfs headers to be in subdirectories
2011-08-22xfs: fix tracing builds inside the source treeChristoph Hellwig
The code really requires the current source directory to be in the header search path. We already do this if building with an object tree separate from the source, but it needs to be added manually if building inside the source. The cflags addition for it accidentally got removed when collapsing the xfs directory structure. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-21Btrfs: fix 64 bit divide problemJosef Bacik
This fixes a regression introduced by commit cdcb725c05fe ("Btrfs: check if there is enough space for balancing smarter"). We can't do 64-bit divides on 32-bit architectures. In cases where we need to divide/multiply by 2 we should just left/right shift respectively, and in cases where theres N number of devices use do_div. Also make the counters u64 to match up with rw_devices. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Acked-and-tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-21Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: flush any pending end_io requests before DIO reads w/dioread_nolock ext4: fix nomblk_io_submit option so it correctly converts uninit blocks ext4: Resolve the hang of direct i/o read in handling EXT4_IO_END_UNWRITTEN. ext4: call ext4_ioend_wait and ext4_flush_completed_IO in ext4_evict_inode ext4: Fix ext4_should_writeback_data() for no-journal mode
2011-08-19ext4: flush any pending end_io requests before DIO reads w/dioread_nolockJiaying Zhang
There is a race between ext4 buffer write and direct_IO read with dioread_nolock mount option enabled. The problem is that we clear PageWriteback flag during end_io time but will do uninitialized-to-initialized extent conversion later with dioread_nolock. If an O_direct read request comes in during this period, ext4 will return zero instead of the recently written data. This patch checks whether there are any pending uninitialized-to-initialized extent conversion requests before doing O_direct read to close the race. Note that this is just a bandaid fix. The fundamental issue is that we clear PageWriteback flag before we really complete an IO, which is problem-prone. To fix the fundamental issue, we may need to implement an extent tree cache that we can use to look up pending to-be-converted extents. Signed-off-by: Jiaying Zhang <jiayingz@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2011-08-18Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: NFSv4.1: Return NFS4ERR_BADSESSION to callbacks during session resets NFSv4.1: Fix the callback 'highest_used_slotid' behaviour pnfs-obj: Fix the comp_index != 0 case pnfs-obj: Bug when we are running out of bio nfs: add missing prefetch.h include
2011-08-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: set i_size properly when fallocating and we already btrfs: unlock on error in btrfs_file_llseek() btrfs: btrfs_permission's RO check shouldn't apply to device nodes Btrfs: truncate pages from clone ioctl target range Btrfs: fix uninitialized sync_pending Btrfs: fix wrong free space information btrfs: memory leak in btrfs_add_inode_defrag() Btrfs: use plain page_address() in header fields setget functions Btrfs: forced readonly when btrfs_drop_snapshot() fails Btrfs: check if there is enough space for balancing smarter Btrfs: fix a bug of balance on full multi-disk partitions Btrfs: fix an oops of log replay Btrfs: detect wether a device supports discard Btrfs: force unplugs when switching from high to regular priority bios
2011-08-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: update cifs version to 1.75 [CIFS] possible memory corruption on mount cifs: demote cERROR in build_path_from_dentry to cFYI
2011-08-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6: fat: fat16 support maximum 4GB file/vol size as WinXP or 7. fat: fix utf8 iocharset warning message fat: fix build warning
2011-08-18update cifs version to 1.75Steve French
Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-08-18[CIFS] possible memory corruption on mountSteve French
CIFS cleanup_volume_info_contents() looks like having a memory corruption problem. When UNCip is set to "&vol->UNC[2]" in cifs_parse_mount_options(), it should not be kfree()-ed in cleanup_volume_info_contents(). Introduced in commit b946845a9dc523c759cae2b6a0f6827486c3221a Signed-off-by: J.R. Okajima <hooanon05@yahoo.co.jp> Reviewed-by: Jeff Layton <jlayton@redhat.com> CC: Stable <stable@kernel.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-08-18Merge branch 'btrfs-3.0' into for-linusChris Mason
2011-08-18Btrfs: set i_size properly when fallocating and we alreadyJosef Bacik
xfstests exposed a problem with preallocate when it fallocates a range that already has an extent. We don't set the new i_size properly because we see that we already have an extent. This isn't right and we should update i_size if the space already exists. With this patch we now pass xfstests 075. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-18btrfs: unlock on error in btrfs_file_llseek()Dan Carpenter
There were some unlocks on error missing in a recent patch to btrfs_file_llseek(). Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-18btrfs: btrfs_permission's RO check shouldn't apply to device nodesJeff Mahoney
This patch tightens the read-only access checks in btrfs_permission to match the constraints in inode_permission. Currently, even though the device node itself will be unmodified, read-write access to device nodes is denied to when the device node resides on a read-only subvolume or a is a file that has been marked read-only by the btrfs conversion utility. With this patch applied, the check only affects regular files, directories, and symlinks. It also restructures the code a bit so that we don't duplicate the MAY_WRITE check for both tests. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-17befs: Validate length of long symbolic links.Timo Warns
Signed-off-by: Timo Warns <warns@pre-sense.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-17fat: fat16 support maximum 4GB file/vol size as WinXP or 7.Namjae Jeon
FAT16 support maximum 4GB vol/file size with 64KB cluster size. Win NT/XP/7 increased the maximum cluster size to 64KB, and file/vol size increased 4GB also. Although increasing, the file size of linux FAT is still limited at 2GB. I found that it is limited by sb->maxbytes(0x7fffffff) when partition is formatted by FAT16. sb->s_maxbytes in fill_super should be set to 0xffffffff like fat32. Signed-off-by: Namjae Jeon <linkinjeon@gmail.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-08-17fat: fix utf8 iocharset warning messageMihai Moldovan
The fat_msg function already formats the given message and appends a newline to it - we don't need to do this in the passed message string as well, or will end up with a blank line printed in the kernel log ring buffer. Also change the loglevel from error to warning. Signed-off-by: Mihai Moldovan <ionic@ionic.de> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-08-17fat: fix build warningJonas Aberg
This fixes a compile warning (unititialized variable) in the fat filesystem code. Signed-off-by: Jonas Aberg <jonas.aberg@stericsson.com> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-08-16Btrfs: truncate pages from clone ioctl target rangeSage Weil
We need to truncate page cache pages for the clone ioctl target range or else we'll confuse ourselves to no end. If the old data was cached, we used to still see it (until remount). If the page was partially updated we used to get a mix of old and new data. Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-16Btrfs: fix uninitialized sync_pendingMiao Xie
sync_pending is uninitialized before it be used, fix it. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-16Btrfs: fix wrong free space informationMiao Xie
Btrfs subtracted the size of the allocated space twice when it allocated the space from the bitmap in the cluster, it broke the free space information and led to oops finally. And this patch also fixes the bug that ctl->free_space was subtracted without lock. Reported-by: Liu Bo <liubo2009@cn.fujitsu.com> Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-16btrfs: memory leak in btrfs_add_inode_defrag()Dan Carpenter
We don't use the defrag struct on this path. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-16Btrfs: use plain page_address() in header fields setget functionsLi Zefan
We've stopped using highmem for extent buffers. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-16Btrfs: forced readonly when btrfs_drop_snapshot() failsTsutomu Itoh
The filesystem turns readonly instead of returning the error to the caller when detected error in btrfs_drop_snapshot(). and, because the caller doesn't check the error, the function type is changed to 'void'. Signed-off-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-16Btrfs: check if there is enough space for balancing smarterliubo
When checking if there is enough space for balancing a block group, since we do not take raid types into consideration, we do not account corrent amounts of space that we needed. This makes us do some extra work before we get ENOSPC. Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-16Btrfs: fix a bug of balance on full multi-disk partitionsliubo
When balancing, we'll first try to shrink devices for some space, but if it is working on a full multi-disk partition with raid protection, we may encounter a bug, that is, while shrinking, total_bytes may be less than bytes_used, and btrfs may allocate a dev extent that accesses out of device's bounds. Then we will not be able to write or read the data which stores at the end of the device, and get the followings: device fsid 0939f071-7ea3-46c8-95df-f176d773bfb6 devid 1 transid 10 /dev/sdb5 Btrfs detected SSD devices, enabling SSD mode btrfs: relocating block group 476315648 flags 9 btrfs: found 4 extents attempt to access beyond end of device sdb5: rw=145, want=546176, limit=546147 attempt to access beyond end of device sdb5: rw=145, want=546304, limit=546147 attempt to access beyond end of device sdb5: rw=145, want=546432, limit=546147 attempt to access beyond end of device sdb5: rw=145, want=546560, limit=546147 attempt to access beyond end of device Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-16Btrfs: fix an oops of log replayliubo
When btrfs recovers from a crash, it may hit the oops below: ------------[ cut here ]------------ kernel BUG at fs/btrfs/inode.c:4580! [...] RIP: 0010:[<ffffffffa03df251>] [<ffffffffa03df251>] btrfs_add_link+0x161/0x1c0 [btrfs] [...] Call Trace: [<ffffffffa03e7b31>] ? btrfs_inode_ref_index+0x31/0x80 [btrfs] [<ffffffffa04054e9>] add_inode_ref+0x319/0x3f0 [btrfs] [<ffffffffa0407087>] replay_one_buffer+0x2c7/0x390 [btrfs] [<ffffffffa040444a>] walk_down_log_tree+0x32a/0x480 [btrfs] [<ffffffffa0404695>] walk_log_tree+0xf5/0x240 [btrfs] [<ffffffffa0406cc0>] btrfs_recover_log_trees+0x250/0x350 [btrfs] [<ffffffffa0406dc0>] ? btrfs_recover_log_trees+0x350/0x350 [btrfs] [<ffffffffa03d18b2>] open_ctree+0x1442/0x17d0 [btrfs] [...] This comes from that while replaying an inode ref item, we forget to check those old conflicting DIR_ITEM and DIR_INDEX items in fs/file tree, then we will come to conflict corners which lead to BUG_ON(). Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Tested-by: Andy Lutomirski <luto@mit.edu> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-16Btrfs: detect wether a device supports discardJosef Bacik
We have a problem where if a user specifies discard but doesn't actually support it we will return EOPNOTSUPP from btrfs_discard_extent. This is a problem because this gets called (in a fashion) from the tree log recovery code, which has a nice little BUG_ON(ret) after it, which causes us to fail the tree log replay. So instead detect wether our devices support discard when we're adding them and then don't issue discards if we know that the device doesn't support it. And just for good measure set ret = 0 in btrfs_issue_discard just in case we still get EOPNOTSUPP so we don't screw anybody up like this again. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-16cifs: demote cERROR in build_path_from_dentry to cFYIJeff Layton
Running the cthon tests on a recent kernel caused this message to pop occasionally: CIFS VFS: did not end path lookup where expected namelen is 0 Some added debugging showed that namelen and dfsplen were both 0 when this occurred. That means that the read_seqretry returned true. Assuming that the comment inside the if statement is true, this should be harmless and just means that we raced with a rename. If that is the case, then there's no need for alarm and we can demote this to cFYI. While we're at it, print the dfsplen too so that we can see what happened here if the message pops during debugging. Cc: stable@kernel.org Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-08-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6: jfs: flush journal completely before releasing metadata inodes
2011-08-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: cifs: Do not set cifs/ntfs acl using a file handle (try #4) [CIFS] Cleanup use of CONFIG_CIFS_STATS2 ifdef to make transport routines more readable
2011-08-13ext4: fix nomblk_io_submit option so it correctly converts uninit blocksTheodore Ts'o
Bug discovered by Jan Kara: Finally, commit 1449032be17abb69116dbc393f67ceb8bd034f92 returned back the old IO submission code but apparently it forgot to return the old handling of uninitialized buffers so we unconditionnaly call block_write_full_page() without specifying end_io function. So AFAICS we never convert unwritten extents to written in some cases. For example when I mount the fs as: mount -t ext4 -o nomblk_io_submit,dioread_nolock /dev/ubdb /mnt and do int fd = open(argv[1], O_RDWR | O_CREAT | O_TRUNC, 0600); char buf[1024]; memset(buf, 'a', sizeof(buf)); fallocate(fd, 0, 0, 16384); write(fd, buf, sizeof(buf)); I get a file full of zeros (after remounting the filesystem so that pagecache is dropped) instead of seeing the first KB contain 'a's. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2011-08-13ext4: Resolve the hang of direct i/o read in handling EXT4_IO_END_UNWRITTEN.Tao Ma
EXT4_IO_END_UNWRITTEN flag set and the increase of i_aiodio_unwritten should be done simultaneously since ext4_end_io_nolock always clear the flag and decrease the counter in the same time. We don't increase i_aiodio_unwritten when setting EXT4_IO_END_UNWRITTEN so it will go nagative and causes some process to wait forever. Part of the patch came from Eric in his e-mail, but it doesn't fix the problem met by Michael actually. http://marc.info/?l=linux-ext4&m=131316851417460&w=2 Reported-and-Tested-by: Michael Tokarev<mjt@tls.msk.ru> Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2011-08-13ext4: call ext4_ioend_wait and ext4_flush_completed_IO in ext4_evict_inodeJiaying Zhang
Flush inode's i_completed_io_list before calling ext4_io_wait to prevent the following deadlock scenario: A page fault happens while some process is writing inode A. During page fault, shrink_icache_memory is called that in turn evicts another inode B. Inode B has some pending io_end work so it calls ext4_ioend_wait() that waits for inode B's i_ioend_count to become zero. However, inode B's ioend work was queued behind some of inode A's ioend work on the same cpu's ext4-dio-unwritten workqueue. As the ext4-dio-unwritten thread on that cpu is processing inode A's ioend work, it tries to grab inode A's i_mutex lock. Since the i_mutex lock of inode A is still hold before the page fault happened, we enter a deadlock. Also moves ext4_flush_completed_IO and ext4_ioend_wait from ext4_destroy_inode() to ext4_evict_inode(). During inode deleteion, ext4_evict_inode() is called before ext4_destroy_inode() and in ext4_evict_inode(), we may call ext4_truncate() without holding i_mutex lock. As a result, there is a race between flush_completed_IO that is called from ext4_ext_truncate() and ext4_end_io_work, which may cause corruption on an io_end structure. This change moves ext4_flush_completed_IO and ext4_ioend_wait from ext4_destroy_inode() to ext4_evict_inode() to resolve the race between ext4_truncate() and ext4_end_io_work during inode deletion. Signed-off-by: Jiaying Zhang <jiayingz@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2011-08-13ext4: Fix ext4_should_writeback_data() for no-journal modeCurt Wohlgemuth
ext4_should_writeback_data() had an incorrect sequence of tests to determine if it should return 0 or 1: in particular, even in no-journal mode, 0 was being returned for a non-regular-file inode. This meant that, in non-journal mode, we would use ext4_journalled_aops for directories, symlinks, and other non-regular files. However, calling journalled aop callbacks when there is no valid handle, can cause problems. This would cause a kernel crash with Jan Kara's commit 2d859db3e4 ("ext4: fix data corruption in inodes with journalled data"), because we now dereference 'handle' in ext4_journalled_write_end(). I also added BUG_ONs to check for a valid handle in the obviously journal-only aops callbacks. I tested this running xfstests with a scratch device in these modes: - no-journal - data=ordered - data=writeback - data=journal All work fine; the data=journal run has many failures and a crash in xfstests 074, but this is no different from a vanilla kernel. Signed-off-by: Curt Wohlgemuth <curtw@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2011-08-12Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: replace xfs_buf_geterror() with bp->b_error xfs: Check the return value of xfs_buf_read() for NULL "xfs: fix error handling for synchronous writes" revisited xfs: set cursor in xfs_ail_splice() even when AIL was empty xfs: Remove the macro XFS_BUFTARG_NAME xfs: Remove the macro XFS_BUF_TARGET xfs: Remove the macro XFS_BUF_SET_TARGET Replace the macro XFS_BUF_ISPINNED with helper xfs_buf_ispinned xfs: Remove the macro XFS_BUF_SET_PTR xfs: Remove the macro XFS_BUF_PTR xfs: Remove macro XFS_BUF_SET_START xfs: Remove macro XFS_BUF_HOLD xfs: Remove macro XFS_BUF_BUSY and family xfs: Remove the macro XFS_BUF_ERROR and family xfs: Remove the macro XFS_BUF_BFLAGS
2011-08-12xfs: remove subdirectoriesChristoph Hellwig
Use the move from Linux 2.6 to Linux 3.x as an excuse to kill the annoying subdirectories in the XFS source code. Besides the large amount of file rename the only changes are to the Makefile, a few files including headers with the subdirectory prefix, and the binary sysctl compat code that includes a header under fs/xfs/ from kernel/. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-12xfs: don't expect xfs headers to be in subdirectoriesAlex Elder
Fix up some #include directives in preparation for moving a few header files out of xfs source subdirectories. Note that "xfs_linux.h" also got its quoting convention for included files switched. Signed-off-by: Alex Elder <aelder@sgi.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2011-08-12xfs: replace xfs_buf_geterror() with bp->b_errorChandra Seetharaman
Since we just checked bp for NULL, it is ok to replace xfs_buf_geterror() with bp->b_error in these places. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Alex Elder <aelder@sgi.com>
