path: root/fs
2013-07-03UBIFS: fix a horrid bugArtem Bityutskiy
commit 605c912bb843c024b1ed173dc427cd5c08e5d54d upstream. Al Viro pointed me to the fact that '->readdir()' and '->llseek()' have no mutual exclusion, which means the 'ubifs_dir_llseek()' can be run while we are in the middle of 'ubifs_readdir()'. This means that 'file->private_data' can be freed while 'ubifs_readdir()' uses it, and this is a very bad bug: not only 'ubifs_readdir()' can return garbage, but this may corrupt memory and lead to all kinds of problems like crashes an security holes. This patch fixes the problem by using the 'file->f_version' field, which '->llseek()' always unconditionally sets to zero. We set it to 1 in 'ubifs_readdir()' and whenever we detect that it became 0, we know there was a seek and it is time to clear the state saved in 'file->private_data'. I tested this patch by writing a user-space program which runds readdir and seek in parallell. I could easily crash the kernel without these patches, but could not crash it with these patches. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-03UBIFS: prepare to fix a horrid bugArtem Bityutskiy
commit 33f1a63ae84dfd9ad298cf275b8f1887043ced36 upstream. Al Viro pointed me to the fact that '->readdir()' and '->llseek()' have no mutual exclusion, which means the 'ubifs_dir_llseek()' can be run while we are in the middle of 'ubifs_readdir()'. First of all, this means that 'file->private_data' can be freed while 'ubifs_readdir()' uses it. But this particular patch does not fix the problem. This patch is only a preparation, and the fix will follow next. In this patch we make 'ubifs_readdir()' stop using 'file->f_pos' directly, because 'file->f_pos' can be changed by '->llseek()' at any point. This may lead 'ubifs_readdir()' to returning inconsistent data: directory entry names may correspond to incorrect file positions. So here we introduce a local variable 'pos', read 'file->f_pose' once at very the beginning, and then stick to 'pos'. The result of this is that when 'ubifs_dir_llseek()' changes 'file->f_pos' while we are in the middle of 'ubifs_readdir()', the latter "wins". Reported-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-03perf: Disable monitoring on setuid processes for regular usersStephane Eranian
commit 2976b10f05bd7f6dab9f9e7524451ddfed656a89 upstream. There was a a bug in setup_new_exec(), whereby the test to disabled perf monitoring was not correct because the new credentials for the process were not yet committed and therefore the get_dumpable() test was never firing. The patch fixes the problem by moving the perf_event test until after the credentials are committed. Signed-off-by: Stephane Eranian <eranian@google.com> Tested-by: Jiri Olsa <jolsa@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-20libceph: wrap auth ops in wrapper functionsSage Weil
commit 27859f9773e4a0b2042435b13400ee2c891a61f4 upstream. Use wrapper functions that check whether the auth op exists so that callers do not need a bunch of conditional checks. Simplifies the external interface. Signed-off-by: Sage Weil <sage@inktank.com> Reviewed-by: Alex Elder <elder@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-20libceph: add update_authorizer auth methodSage Weil
commit 0bed9b5c523d577378b6f83eab5835fe30c27208 upstream. Currently the messenger calls out to a get_authorizer con op, which will create a new authorizer if it doesn't yet have one. In the meantime, when we rotate our service keys, the authorizer doesn't get updated. Eventually it will be rejected by the server on a new connection attempt and get invalidated, and we will then rebuild a new authorizer, but this is not ideal. Instead, if we do have an authorizer, call a new update_authorizer op that will verify that the current authorizer is using the latest secret. If it is not, we will build a new one that does. This avoids the transient failure. This fixes one of the sorry sequence of events for bug http://tracker.ceph.com/issues/4282 Signed-off-by: Sage Weil <sage@inktank.com> Reviewed-by: Alex Elder <elder@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-20kmsg: honor dmesg_restrict sysctl on /dev/kmsgKees Cook
commit 637241a900cbd982f744d44646b48a273d609b34 upstream. The dmesg_restrict sysctl currently covers the syslog method for access dmesg, however /dev/kmsg isn't covered by the same protections. Most people haven't noticed because util-linux dmesg(1) defaults to using the syslog method for access in older versions. With util-linux dmesg(1) defaults to reading directly from /dev/kmsg. To fix /dev/kmsg, let's compare the existing interfaces and what they allow: - /proc/kmsg allows: - open (SYSLOG_ACTION_OPEN) if CAP_SYSLOG since it uses a destructive single-reader interface (SYSLOG_ACTION_READ). - everything, after an open. - syslog syscall allows: - anything, if CAP_SYSLOG. - SYSLOG_ACTION_READ_ALL and SYSLOG_ACTION_SIZE_BUFFER, if dmesg_restrict==0. - nothing else (EPERM). The use-cases were: - dmesg(1) needs to do non-destructive SYSLOG_ACTION_READ_ALLs. - sysklog(1) needs to open /proc/kmsg, drop privs, and still issue the destructive SYSLOG_ACTION_READs. AIUI, dmesg(1) is moving to /dev/kmsg, and systemd-journald doesn't clear the ring buffer. Based on the comments in devkmsg_llseek, it sounds like actions besides reading aren't going to be supported by /dev/kmsg (i.e. SYSLOG_ACTION_CLEAR), so we have a strict subset of the non-destructive syslog syscall actions. To this end, move the check as Josh had done, but also rename the constants to reflect their new uses (SYSLOG_FROM_CALL becomes SYSLOG_FROM_READER, and SYSLOG_FROM_FILE becomes SYSLOG_FROM_PROC). SYSLOG_FROM_READER allows non-destructive actions, and SYSLOG_FROM_PROC allows destructive actions after a capabilities-constrained SYSLOG_ACTION_OPEN check. - /dev/kmsg allows: - open if CAP_SYSLOG or dmesg_restrict==0 - reading/polling, after open Addresses https://bugzilla.redhat.com/show_bug.cgi?id=903192 [akpm@linux-foundation.org: use pr_warn_once()] Signed-off-by: Kees Cook <keescook@chromium.org> Reported-by: Christian Kujau <lists@nerdbynature.de> Tested-by: Josh Boyer <jwboyer@redhat.com> Cc: Kay Sievers <kay@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-20ceph: ceph_pagelist_append might sleep while atomicJim Schutt
commit 39be95e9c8c0b5668c9f8806ffe29bf9f4bc0f40 upstream. Ceph's encode_caps_cb() worked hard to not call __page_cache_alloc() while holding a lock, but it's spoiled because ceph_pagelist_addpage() always calls kmap(), which might sleep. Here's the result: [13439.295457] ceph: mds0 reconnect start [13439.300572] BUG: sleeping function called from invalid context at include/linux/highmem.h:58 [13439.309243] in_atomic(): 1, irqs_disabled(): 0, pid: 12059, name: kworker/1:1 . . . [13439.376225] Call Trace: [13439.378757] [<ffffffff81076f4c>] __might_sleep+0xfc/0x110 [13439.384353] [<ffffffffa03f4ce0>] ceph_pagelist_append+0x120/0x1b0 [libceph] [13439.391491] [<ffffffffa0448fe9>] ceph_encode_locks+0x89/0x190 [ceph] [13439.398035] [<ffffffff814ee849>] ? _raw_spin_lock+0x49/0x50 [13439.403775] [<ffffffff811cadf5>] ? lock_flocks+0x15/0x20 [13439.409277] [<ffffffffa045e2af>] encode_caps_cb+0x41f/0x4a0 [ceph] [13439.415622] [<ffffffff81196748>] ? igrab+0x28/0x70 [13439.420610] [<ffffffffa045e9f8>] ? iterate_session_caps+0xe8/0x250 [ceph] [13439.427584] [<ffffffffa045ea25>] iterate_session_caps+0x115/0x250 [ceph] [13439.434499] [<ffffffffa045de90>] ? set_request_path_attr+0x2d0/0x2d0 [ceph] [13439.441646] [<ffffffffa0462888>] send_mds_reconnect+0x238/0x450 [ceph] [13439.448363] [<ffffffffa0464542>] ? ceph_mdsmap_decode+0x5e2/0x770 [ceph] [13439.455250] [<ffffffffa0462e42>] check_new_map+0x352/0x500 [ceph] [13439.461534] [<ffffffffa04631ad>] ceph_mdsc_handle_map+0x1bd/0x260 [ceph] [13439.468432] [<ffffffff814ebc7e>] ? mutex_unlock+0xe/0x10 [13439.473934] [<ffffffffa043c612>] extra_mon_dispatch+0x22/0x30 [ceph] [13439.480464] [<ffffffffa03f6c2c>] dispatch+0xbc/0x110 [libceph] [13439.486492] [<ffffffffa03eec3d>] process_message+0x1ad/0x1d0 [libceph] [13439.493190] [<ffffffffa03f1498>] ? read_partial_message+0x3e8/0x520 [libceph] . . . [13439.587132] ceph: mds0 reconnect success [13490.720032] ceph: mds0 caps stale [13501.235257] ceph: mds0 recovery completed [13501.300419] ceph: mds0 caps renewed Fix it up by encoding locks into a buffer first, and when the number of encoded locks is stable, copy that into a ceph_pagelist. [elder@inktank.com: abbreviated the stack info a bit.] Signed-off-by: Jim Schutt <jaschut@sandia.gov> Reviewed-by: Alex Elder <elder@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-20ceph: add cpu_to_le32() calls when encoding a reconnect capabilityJim Schutt
commit c420276a532a10ef59849adc2681f45306166b89 upstream. In his review, Alex Elder mentioned that he hadn't checked that num_fcntl_locks and num_flock_locks were properly decoded on the server side, from a le32 over-the-wire type to a cpu type. I checked, and AFAICS it is done; those interested can consult Locker::_do_cap_update() in src/mds/Locker.cc and src/include/encoding.h in the Ceph server code (git://github.com/ceph/ceph). I also checked the server side for flock_len decoding, and I believe that also happens correctly, by virtue of having been declared __le32 in struct ceph_mds_cap_reconnect, in src/include/ceph_fs.h. Signed-off-by: Jim Schutt <jaschut@sandia.gov> Reviewed-by: Alex Elder <elder@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13eCryptfs: Check return of filemap_write_and_wait during fsyncTyler Hicks
commit bc5abcf7e411b889f73ea2a90439071a0f451011 upstream. Error out of ecryptfs_fsync() if filemap_write_and_wait() fails. Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Cc: Paul Taysom <taysom@chromium.org> Cc: Olof Johansson <olofj@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13ecryptfs: fixed msync to flush dataPaul Taysom
commit c15cddd900e867c5adfb3c79596479dc5975f743 upstream. When msync is called on a memory mapped file, that data is not flushed to the disk. In Linux, msync calls fsync for the file. For ecryptfs, fsync just calls the lower level file system's fsync. Changed the ecryptfs fsync code to call filemap_write_and_wait before calling the lower level fsync. Addresses the problem described in http://crbug.com/239536 Signed-off-by: Paul Taysom <taysom@chromium.org> Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13cifs: fix off-by-one bug in build_unc_path_to_rootJeff Layton
commit 1fc29bacedeabb278080e31bb9c1ecb49f143c3b upstream. commit 839db3d10a (cifs: fix up handling of prefixpath= option) changed the code such that the vol->prepath no longer contained a leading delimiter and then fixed up the places that accessed that field to account for that change. One spot in build_unc_path_to_root was missed however. When doing the pointer addition on pos, that patch failed to account for the fact that we had already incremented "pos" by one when adding the length of the prepath. This caused a buffer overrun by one byte. This patch fixes the problem by correcting the handling of "pos". Reported-by: Marcus Moeller <marcus.moeller@gmx.ch> Reported-by: Ken Fallon <ken.fallon@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13hpfs: fix warnings when the filesystem fills upMikulas Patocka
commit bbd465df73f0d8ba41b8a0732766a243d0f5b356 upstream. This patch fixes warnings due to missing lock on write error path. WARNING: at fs/hpfs/hpfs_fn.h:353 hpfs_truncate+0x75/0x80 [hpfs]() Hardware name: empty Pid: 26563, comm: dd Tainted: P O 3.9.4 #12 Call Trace: hpfs_truncate+0x75/0x80 [hpfs] hpfs_write_begin+0x84/0x90 [hpfs] _hpfs_bmap+0x10/0x10 [hpfs] generic_file_buffered_write+0x121/0x2c0 __generic_file_aio_write+0x1c7/0x3f0 generic_file_aio_write+0x7c/0x100 do_sync_write+0x98/0xd0 hpfs_file_write+0xd/0x50 [hpfs] vfs_write+0xa2/0x160 sys_write+0x51/0xa0 page_fault+0x22/0x30 system_call_fastpath+0x1a/0x1f Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07fuse: fix readdirplus Oops in fuse_dentry_revalidateMiklos Szeredi
commit 28420dad233520811c0e0860e7fb4975ed863fc4 upstream. Fix bug introduced by commit 4582a4ab2a "FUSE: Adapt readdirplus to application usage patterns". We need to check for a positive dentry; negative dentries are not added by readdirplus. Secondly we need to advise the use of readdirplus on the *parent*, otherwise the whole thing is useless. Thirdly all this is only relevant if "readdirplus_auto" mode is selected by the filesystem. We advise the use of readdirplus only if the dentry was still valid. If we had to redo the lookup then there was no use in doing the -plus version. Reported-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: Feng Shuo <steve.shuo.feng@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07jfs: fix a couple racesDave Kleikamp
commit 73aaa22d5ffb2630456bac2f9a4ed9b81d0d7271 upstream. This patch fixes races uncovered by xfstests testcase 068. One race is the result of jfs_sync() trying to write a sync point to the journal after it has been frozen (or possibly in the process). Since freezing sync's the journal, there is no need to write a sync point so we simply want to return. The second involves jfs_write_inode() being called on a deleted inode. It calls jfs_flush_journal which is held up by the jfs_commit thread doing the final iput on the same deleted inode, which itself is waiting for the I_SYNC flag to be cleared. jfs_write_inode need not do anything when i_nlink is zero, which is the easy fix. Reported-by: Michael L. Semon <mlsemon35@gmail.com> Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07reiserfs: fix spurious multiple-fill in reiserfs_readdir_dentryJeff Mahoney
commit 0bdc7acba56a7ca4232f15f37b16f7ec079385ab upstream. After sleeping for filldir(), we check to see if the file system has changed and research. The next_pos pointer is updated but its value isn't pushed into the key used for the search itself. As a result, the search returns the same item that the last cycle of the loop did and filldir() is called multiple times with the same data. The end result is that the buffer can contain the same name multiple times. This can be returned to userspace or used internally in the xattr code where it can manifest with the following warning: jdm-20004 reiserfs_delete_xattrs: Couldn't delete all xattrs (-2) reiserfs_for_each_xattr uses reiserfs_readdir_dentry to iterate over the xattr names and ends up trying to unlink the same name twice. The second attempt fails with -ENOENT and the error is returned. At some point I'll need to add support into reiserfsck to remove the orphaned directories left behind when this occurs. The fix is to push the value into the key before researching. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07reiserfs: fix problems with chowning setuid file w/ xattrsJeff Mahoney
commit 4a8570112b76a63ad21cfcbe2783f98f7fd5ba1b upstream. reiserfs_chown_xattrs() takes the iattr struct passed into ->setattr and uses it to iterate over all the attrs associated with a file to change ownership of xattrs (and transfer quota associated with the xattr files). When the setuid bit is cleared during chown, ATTR_MODE and iattr->ia_mode are passed to all the xattrs as well. This means that the xattr directory will have S_IFREG added to its mode bits. This has been prevented in practice by a missing IS_PRIVATE check in reiserfs_acl_chmod, which caused a double-lock to occur while holding the write lock. Since the file system was completely locked up, the writeout of the corrupted mode never happened. This patch temporarily clears everything but ATTR_UID|ATTR_GID for the calls to reiserfs_setattr and adds the missing IS_PRIVATE check. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07reiserfs: fix deadlock with nfs racing on create/lookupJeff Mahoney
commit a1457c0ce976bad1356b9b0437f2a5c3ab8a9cfc upstream. Reiserfs is currently able to be deadlocked by having two NFS clients where one has removed and recreated a file and another is accessing the file with an open file handle. If one client deletes and recreates a file with timing such that the recreated file obtains the same [dirid, objectid] pair as the original file while another client accesses the file via file handle, the create and lookup can race and deadlock if the lookup manages to create the in-memory inode first. The create thread, in insert_inode_locked4, will hold the write lock while waiting on the other inode to be unlocked. The lookup thread, anywhere in the iget path, will release and reacquire the write lock while it schedules. If it needs to reacquire the lock while the create thread has it, it will never be able to make forward progress because it needs to reacquire the lock before ultimately unlocking the inode. This patch drops the write lock across the insert_inode_locked4 call so that the ordering of inode_wait -> write lock is retained. Since this would have been the case before the BKL push-down, this is safe. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07NFSv4: Fix a thinko in nfs4_try_open_cachedTrond Myklebust
commit f448badd34700ae728a32ba024249626d49c10e1 upstream. We need to pass the full open mode flags to nfs_may_open() when doing a delegated open. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07cifs: fix potential buffer overrun when composing a new options stringJeff Layton
commit 166faf21bd14bc5c5295a44874bf7f3930c30b20 upstream. Consider the case where we have a very short ip= string in the original mount options, and when we chase a referral we end up with a very long IPv6 address. Be sure to allow for that possibility when estimating the size of the string to allocate. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07xfs: kill suid/sgid through the truncate path.Dave Chinner
commit 2962f5a5dcc56f69cbf62121a7be67cc15d6940b upstream. XFS has failed to kill suid/sgid bits correctly when truncating files of non-zero size since commit c4ed4243 ("xfs: split xfs_setattr") introduced in the 3.1 kernel. Fix it. Fix it. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07nilfs2: fix issue of nilfs_set_page_dirty() for page at EOF boundaryRyusuke Konishi
commit 136e8770cd5d1fe38b3c613100dd6dc4db6d4fa6 upstream. nilfs2: fix issue of nilfs_set_page_dirty for page at EOF boundary DESCRIPTION: There are use-cases when NILFS2 file system (formatted with block size lesser than 4 KB) can be remounted in RO mode because of encountering of "broken bmap" issue. The issue was reported by Anthony Doggett <Anthony2486@interfaces.org.uk>: "The machine I've been trialling nilfs on is running Debian Testing, Linux version 3.2.0-4-686-pae (debian-kernel@lists.debian.org) (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP Debian 3.2.35-2), but I've also reproduced it (identically) with Debian Unstable amd64 and Debian Experimental (using the 3.8-trunk kernel). The problematic partitions were formatted with "mkfs.nilfs2 -b 1024 -B 8192"." SYMPTOMS: (1) System log contains error messages likewise: [63102.496756] nilfs_direct_assign: invalid pointer: 0 [63102.496786] NILFS error (device dm-17): nilfs_bmap_assign: broken bmap (inode number=28) [63102.496798] [63102.524403] Remounting filesystem read-only (2) The NILFS2 file system is remounted in RO mode. REPRODUSING PATH: (1) Create volume group with name "unencrypted" by means of vgcreate utility. (2) Run script (prepared by Anthony Doggett <Anthony2486@interfaces.org.uk>): ----------------[BEGIN SCRIPT]-------------------- VG=unencrypted lvcreate --size 2G --name ntest $VG mkfs.nilfs2 -b 1024 -B 8192 /dev/mapper/$VG-ntest mkdir /var/tmp/n mkdir /var/tmp/n/ntest mount /dev/mapper/$VG-ntest /var/tmp/n/ntest mkdir /var/tmp/n/ntest/thedir cd /var/tmp/n/ntest/thedir sleep 2 date darcs init sleep 2 dmesg|tail -n 5 date darcs whatsnew || true date sleep 2 dmesg|tail -n 5 ----------------[END SCRIPT]-------------------- REPRODUCIBILITY: 100% INVESTIGATION: As it was discovered, the issue takes place during segment construction after executing such sequence of user-space operations: open("_darcs/index", O_RDWR|O_CREAT|O_NOCTTY, 0666) = 7 fstat(7, {st_mode=S_IFREG|0644, st_size=0, ...}) = 0 ftruncate(7, 60) The error message "NILFS error (device dm-17): nilfs_bmap_assign: broken bmap (inode number=28)" takes place because of trying to get block number for third block of the file with logical offset #3072 bytes. As it is possible to see from above output, the file has 60 bytes of the whole size. So, it is enough one block (1 KB in size) allocation for the whole file. Trying to operate with several blocks instead of one takes place because of discovering several dirty buffers for this file in nilfs_segctor_scan_file() method. The root cause of this issue is in nilfs_set_page_dirty function which is called just before writing to an mmapped page. When nilfs_page_mkwrite function handles a page at EOF boundary, it fills hole blocks only inside EOF through __block_page_mkwrite(). The __block_page_mkwrite() function calls set_page_dirty() after filling hole blocks, thus nilfs_set_page_dirty function (= a_ops->set_page_dirty) is called. However, the current implementation of nilfs_set_page_dirty() wrongly marks all buffers dirty even for page at EOF boundary. As a result, buffers outside EOF are inconsistently marked dirty and queued for write even though they are not mapped with nilfs_get_block function. FIX: This modifies nilfs_set_page_dirty() not to mark hole blocks dirty. Thanks to Vyacheslav Dubeyko for his effort on analysis and proposals for this issue. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Reported-by: Anthony Doggett <Anthony2486@interfaces.org.uk> Reported-by: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07ocfs2: goto out_unlock if ocfs2_get_clusters_nocache() failed in ocfs2_fiemap()Joseph Qi
commit b4ca2b4b577c3530e34dcfaafccb2cc680ce95d1 upstream. Last time we found there is lock/unlock bug in ocfs2_file_aio_write, and then we did a thorough search for all lock resources in ocfs2_inode_info, including rw, inode and open lockres and found this bug. My kernel version is 3.0.13, and it is also in the lastest version 3.9. In ocfs2_fiemap, once ocfs2_get_clusters_nocache failed, it should goto out_unlock instead of out, because we need release buffer head, up read alloc sem and unlock inode. Signed-off-by: Joseph Qi <joseph.qi@huawei.com> Reviewed-by: Jie Liu <jeff.liu@oracle.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Acked-by: Sunil Mushran <sunil.mushran@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07fat: fix possible overflow for fat_clustersOGAWA Hirofumi
commit 7b92d03c3239f43e5b86c9cc9630f026d36ee995 upstream. Intermediate value of fat_clusters can be overflowed on 32bits arch. Reported-by: Krzysztof Strasburger <strasbur@chkw386.ch.pwr.wroc.pl> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07cifs: only set ops for inodes in I_NEW stateJeff Layton
commit c2b93e0699723700f886ce17bb65ffd771195a6d upstream. It's generally not safe to reset the inode ops once they've been set. In the case where the inode was originally thought to be a directory and then later found to be a DFS referral, this can lead to an oops when we try to trigger an inode op on it after changing the ops to the blank referral operations. Reported-and-Tested-by: Sachin Prabhu <sprabhu@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24btrfs: don't stop searching after encountering the wrong itemGabriel de Perthuis
commit 03b71c6ca6286625d8f1ed44aabab9b5bf5dac10 upstream. The search ioctl skips items that are too large for a result buffer, but inline items of a certain size occuring before any search result is found would trigger an overflow and stop the search entirely. Bug: https://bugzilla.kernel.org/show_bug.cgi?id=57641 Signed-off-by: Gabriel de Perthuis <g2p.code+btrfs@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19ext4: limit group search loop for non-extent filesLachlan McIlroy
commit e6155736ad76b2070652745f9e54cdea3f0d8567 upstream. In the case where we are allocating for a non-extent file, we must limit the groups we allocate from to those below 2^32 blocks, and ext4_mb_regular_allocator() attempts to do this initially by putting a cap on ngroups for the subsequent search loop. However, the initial target group comes in from the allocation context (ac), and it may already be beyond the artificially limited ngroups. In this case, the limit if (group == ngroups) group = 0; at the top of the loop is never true, and the loop will run away. Catch this case inside the loop and reset the search to start at group 0. [sandeen@redhat.com: add commit msg & comments] Signed-off-by: Lachlan McIlroy <lmcilroy@redhat.com> Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19audit: vfs: fix audit_inode call in O_CREAT case of do_lastJeff Layton
commit 33e2208acfc15ce00d3dd13e839bf6434faa2b04 upstream. Jiri reported a regression in auditing of open(..., O_CREAT) syscalls. In older kernels, creating a file with open(..., O_CREAT) created audit_name records that looked like this: type=PATH msg=audit(1360255720.628:64): item=1 name="/abc/foo" inode=138810 dev=fd:00 mode=0100640 ouid=0 ogid=0 rdev=00:00 obj=unconfined_u:object_r:default_t:s0 type=PATH msg=audit(1360255720.628:64): item=0 name="/abc/" inode=138635 dev=fd:00 mode=040750 ouid=0 ogid=0 rdev=00:00 obj=unconfined_u:object_r:default_t:s0 ...in recent kernels though, they look like this: type=PATH msg=audit(1360255402.886:12574): item=2 name=(null) inode=264599 dev=fd:00 mode=0100640 ouid=0 ogid=0 rdev=00:00 obj=unconfined_u:object_r:default_t:s0 type=PATH msg=audit(1360255402.886:12574): item=1 name=(null) inode=264598 dev=fd:00 mode=040750 ouid=0 ogid=0 rdev=00:00 obj=unconfined_u:object_r:default_t:s0 type=PATH msg=audit(1360255402.886:12574): item=0 name="/abc/foo" inode=264598 dev=fd:00 mode=040750 ouid=0 ogid=0 rdev=00:00 obj=unconfined_u:object_r:default_t:s0 Richard bisected to determine that the problems started with commit bfcec708, but the log messages have changed with some later audit-related patches. The problem is that this audit_inode call is passing in the parent of the dentry being opened, but audit_inode is being called with the parent flag false. This causes later audit_inode and audit_inode_child calls to match the wrong entry in the audit_names list. This patch simply sets the flag to properly indicate that this inode represents the parent. With this, the audit_names entries are back to looking like they did before. Reported-by: Jiri Jaburek <jjaburek@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Test By: Richard Guy Briggs <rbriggs@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19nfsd: fix oops when legacy_recdir_name_error is passed a -ENOENT errorJeff Layton
commit 7255e716b1757dc10fa5e3a4d2eaab303ff9f7b6 upstream. Toralf reported the following oops to the linux-nfs mailing list: -----------------[snip]------------------ NFSD: unable to generate recoverydir name (-2). NFSD: disabling legacy clientid tracking. Reboot recovery will not function correctly! BUG: unable to handle kernel NULL pointer dereference at 000003c8 IP: [<f90a3d91>] nfsd4_client_tracking_exit+0x11/0x50 [nfsd] *pdpt = 000000002ba33001 *pde = 0000000000000000 Oops: 0000 [#1] SMP Modules linked in: loop nfsd auth_rpcgss ipt_MASQUERADE xt_owner xt_multiport ipt_REJECT xt_tcpudp xt_recent xt_conntrack nf_conntrack_ftp xt_limit xt_LOG iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack iptable_filter ip_tables x_tables af_packet pppoe pppox ppp_generic slhc bridge stp llc tun arc4 iwldvm mac80211 coretemp kvm_intel uvcvideo sdhci_pci sdhci mmc_core videobuf2_vmalloc videobuf2_memops usblp videobuf2_core i915 iwlwifi psmouse videodev cfg80211 kvm fbcon bitblit cfbfillrect acpi_cpufreq mperf evdev softcursor font cfbimgblt i2c_algo_bit cfbcopyarea intel_agp intel_gtt drm_kms_helper snd_hda_codec_conexant drm agpgart fb fbdev tpm_tis thinkpad_acpi tpm nvram e1000e rfkill thermal ptp wmi pps_core tpm_bios 8250_pci processor 8250 ac snd_hda_intel snd_hda_codec snd_pcm battery video i2c_i801 snd_page_alloc snd_timer button serial_core i2c_core snd soundcore thermal_sys hwmon aesni_intel ablk_helper cryp td lrw aes_i586 xts gf128mul cbc fuse nfs lockd sunrpc dm_crypt dm_mod hid_monterey hid_microsoft hid_logitech hid_ezkey hid_cypress hid_chicony hid_cherry hid_belkin hid_apple hid_a4tech hid_generic usbhid hid sr_mod cdrom sg [last unloaded: microcode] Pid: 6374, comm: nfsd Not tainted 3.9.1 #6 LENOVO 4180F65/4180F65 EIP: 0060:[<f90a3d91>] EFLAGS: 00010202 CPU: 0 EIP is at nfsd4_client_tracking_exit+0x11/0x50 [nfsd] EAX: 00000000 EBX: fffffffe ECX: 00000007 EDX: 00000007 ESI: eb9dcb00 EDI: eb2991c0 EBP: eb2bde38 ESP: eb2bde34 DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 CR0: 80050033 CR2: 000003c8 CR3: 2ba80000 CR4: 000407f0 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 DR6: ffff0ff0 DR7: 00000400 Process nfsd (pid: 6374, ti=eb2bc000 task=eb2711c0 task.ti=eb2bc000) Stack: fffffffe eb2bde4c f90a3e0c f90a7754 fffffffe eb0a9c00 eb2bdea0 f90a41ed eb2991c0 1b270000 eb2991c0 eb2bde7c f9099ce9 eb2bde98 0129a020 eb29a020 eb2bdecc eb2991c0 eb2bdea8 f9099da5 00000000 eb9dcb00 00000001 67822f08 Call Trace: [<f90a3e0c>] legacy_recdir_name_error+0x3c/0x40 [nfsd] [<f90a41ed>] nfsd4_create_clid_dir+0x15d/0x1c0 [nfsd] [<f9099ce9>] ? nfsd4_lookup_stateid+0x99/0xd0 [nfsd] [<f9099da5>] ? nfs4_preprocess_seqid_op+0x85/0x100 [nfsd] [<f90a4287>] nfsd4_client_record_create+0x37/0x50 [nfsd] [<f909d6ce>] nfsd4_open_confirm+0xfe/0x130 [nfsd] [<f90980b1>] ? nfsd4_encode_operation+0x61/0x90 [nfsd] [<f909d5d0>] ? nfsd4_free_stateid+0xc0/0xc0 [nfsd] [<f908fd0b>] nfsd4_proc_compound+0x41b/0x530 [nfsd] [<f9081b7b>] nfsd_dispatch+0x8b/0x1a0 [nfsd] [<f857b85d>] svc_process+0x3dd/0x640 [sunrpc] [<f908165d>] nfsd+0xad/0x110 [nfsd] [<f90815b0>] ? nfsd_destroy+0x70/0x70 [nfsd] [<c1054824>] kthread+0x94/0xa0 [<c1486937>] ret_from_kernel_thread+0x1b/0x28 [<c1054790>] ? flush_kthread_work+0xd0/0xd0 Code: 86 b0 00 00 00 90 c5 0a f9 c7 04 24 70 76 0a f9 e8 74 a9 3d c8 eb ba 8d 76 00 55 89 e5 53 66 66 66 66 90 8b 15 68 c7 0a f9 85 d2 <8b> 88 c8 03 00 00 74 2c 3b 11 77 28 8b 5c 91 08 85 db 74 22 8b EIP: [<f90a3d91>] nfsd4_client_tracking_exit+0x11/0x50 [nfsd] SS:ESP 0068:eb2bde34 CR2: 00000000000003c8 ---[ end trace 09e54015d145c9c6 ]--- The problem appears to be a regression that was introduced in commit 9a9c6478 "nfsd: make NFSv4 recovery client tracking options per net". Prior to that commit, it was safe to pass a NULL net pointer to nfsd4_client_tracking_exit in the legacy recdir case, and legacy_recdir_name_error did so. After that comit, the net pointer must be valid. This patch just fixes legacy_recdir_name_error to pass in a valid net pointer to that function. Reported-and-tested-by: Toralf Förster <toralf.foerster@gmx.de> Cc: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19nfsd4: don't allow owner override on 4.1 CLAIM_FH opensJ. Bruce Fields
commit 9f415eb25574db4b73a9a712a4438e41dc284922 upstream. The Linux client is using CLAIM_FH to implement regular opens, not just recovery cases, so it depends on the server to check permissions correctly. Therefore the owner override, which may make sense in the delegation recovery case, isn't right in the CLAIM_FH case. Symptoms: on a client with 49f9a0fafd844c32f2abada047c0b9a5ba0d6255 "NFSv4.1: Enable open-by-filehandle", Bryan noticed this: touch test.txt chmod 000 test.txt echo test > test.txt succeeding. Reported-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11NFSv4.x: Fix handling of partially delegated locksTrond Myklebust
commit c5a2a15f8146fdfe45078df7873a6dc1006b3869 upstream. If a NFS client receives a delegation for a file after it has taken a lock on that file, we can currently end up in a situation where we mistakenly skip unlocking that file. The following patch swaps an erroneous check in nfs4_proc_unlck for whether or not the file has a delegation to one which checks whether or not we hold a lock stateid for that file. Reported-by: Chuck Lever <Chuck.Lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Tested-by: Chuck Lever <Chuck.Lever@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11Btrfs: fix extent logging with O_DIRECT into preallocJosef Bacik
commit eb384b55ae9c2055ea00c5cc87971e182d47aefa upstream. This is the same as the fix from commit Btrfs: fix bad extent logging but for O_DIRECT. I missed this when I fixed the problem originally, we were still using the em for the orig_start and orig_block_len, which would be the merged extent. We need to use the actual extent from the on disk file extent item, which we have to lookup to make sure it's ok to nocow anyway so just pass in some pointers to hold this info. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11Btrfs: compare relevant parts of delayed tree refsJosef Bacik
commit 41b0fc42800569f63e029549b75c4c9cb63f2dfd upstream. A user reported a panic while running a balance. What was happening was he was relocating a block, which added the reference to the relocation tree. Then relocation would walk through the relocation tree and drop that reference and free that block, and then it would walk down a snapshot which referenced the same block and add another ref to the block. The problem is this was all happening in the same transaction, so the parent block was free'ed up when we drop our reference which was immediately available for allocation, and then it was used _again_ to add a reference for the same block from a different snapshot. This resulted in something like this in the delayed ref tree add ref to 90234880, parent=2067398656, ref_root 1766, level 1 del ref to 90234880, parent=2067398656, ref_root 18446744073709551608, level 1 add ref to 90234880, parent=2067398656, ref_root 1767, level 1 as you can see the ref_root's don't match, because when we inc the ref we use the header owner, which is the original tree the block belonged to, instead of the data reloc tree. Then when we remove the extent we use the reloc tree objectid. But none of this matters, since it is a shared reference which means only the parent matters. When the delayed ref stuff runs it adds all the increments first, and then does all the drops, to make sure that we don't delete the ref if we net a positive ref count. But tree blocks aren't allowed to have multiple refs from the same block, so this panics when it tries to add the second ref. We need the add and the drop to cancel each other out in memory so we only do the final add. So to fix this we need to adjust how the delayed refs are added to the tree. Only the ref_root matters when it is a normal backref, and only the parent matters when it is a shared backref. So make our decision based on what ref type we have. This allows us to keep the ref_root in memory in case anybody wants to use it for something else, and it allows the delayed refs to be merged properly so we don't end up with this panic. With this patch the users image no longer panics on mount, and it has a clean fsck after a normal mount/umount cycle. Thanks, Reported-by: Roman Mamedov <rm@romanrm.ru> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11ext4: add check for inodes_count overflow in new resize ioctlTheodore Ts'o
commit 3f8a6411fbada1fa482276591e037f3b1adcf55b upstream. Addresses-Red-Hat-Bugzilla: #913245 Reported-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com> Signed-off-by: Lingzhu Xiang <lxiang@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11hugetlbfs: fix mmap failure in unaligned size requestNaoya Horiguchi
commit af73e4d9506d3b797509f3c030e7dcd554f7d9c4 upstream. The current kernel returns -EINVAL unless a given mmap length is "almost" hugepage aligned. This is because in sys_mmap_pgoff() the given length is passed to vm_mmap_pgoff() as it is without being aligned with hugepage boundary. This is a regression introduced in commit 40716e29243d ("hugetlbfs: fix alignment of huge page requests"), where alignment code is pushed into hugetlb_file_setup() and the variable len in caller side is not changed. To fix this, this patch partially reverts that commit, and adds alignment code in caller side. And it also introduces hstate_sizelog() in order to get proper hstate to specified hugepage size. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=56881 [akpm@linux-foundation.org: fix warning when CONFIG_HUGETLB_PAGE=n] Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reported-by: <iceman_dvd@yahoo.com> Cc: Steven Truelove <steven.truelove@utoronto.ca> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11autofs - remove autofs dentry mount checkDavid Jeffery
commit ce8a5dbdf9e709bdaf4618d7ef8cceb91e8adc69 upstream. When checking if an autofs mount point is busy it isn't sufficient to only check if it's a mount point. For example, if the mount of an offset mountpoint in a tree is denied for this host by its export and the dentry becomes a process working directory the check incorrectly returns the mount as not in use at expire. This can happen since the default when mounting within a tree is nostrict, which means ingnore mount fails on mounts within the tree and continue. The nostrict option is meant to allow mounting in this case. Signed-off-by: David Jeffery <djeffery@redhat.com> Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07do_mount(): fix a leak introduced in 3.9 ("mount: consolidate permission ↵Al Viro
checks") commit 0d5cadb87e0fa764db7fa0b78d8a6f173cb475a1 upstream. Bisected-by: Michael Leun <lkml20130126@newton.leun.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07ext4: fix Kconfig documentation for CONFIG_EXT4_DEBUGTheodore Ts'o
commit 7f3e3c7cfcec148ccca9c0dd2dbfd7b00b7ac10f upstream. Fox the Kconfig documentation for CONFIG_EXT4_DEBUG to match the change made by commit a0b30c1229: ext4: use module parameters instead of debugfs for mballoc_debug Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07ext4: fix online resizing for ext3-compat file systemsTheodore Ts'o
commit c5c72d814cf0f650010337c73638b25e6d14d2d4 upstream. Commit fb0a387dcdc restricts block allocations for indirect-mapped files to block groups less than s_blockfile_groups. However, the online resizing code wasn't setting s_blockfile_groups, so the newly added block groups were not available for non-extent mapped files. Reported-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07ext4: fix big-endian bug in metadata checksum calculationsDmitry Monakhov
commit 171a7f21a76a0958c225b97c00a97a10390d40ee upstream. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07ext4: unregister es_shrinker if mount failedDmitry Monakhov
commit a75ae78f087f933ab3432e98bb4dbbf2196cf6d5 upstream. Otherwise destroyed ext_sb_info will be part of global shinker list and result in the following OOPS: JBD2: corrupted journal superblock JBD2: recovery failed EXT4-fs (dm-2): error loading journal general protection fault: 0000 [#1] SMP Modules linked in: fuse acpi_cpufreq freq_table mperf coretemp kvm_intel kvm crc32c_intel microcode sg button sd_mod crc_t10dif ahci libahci pata_acpi ata_generic dm_mirror dm_region_hash dm_log dm_\ mod CPU 1 Pid: 2758, comm: mount Not tainted 3.8.0-rc3+ #136 /DH55TC RIP: 0010:[<ffffffff811bfb2d>] [<ffffffff811bfb2d>] unregister_shrinker+0xad/0xe0 RSP: 0000:ffff88011d5cbcd8 EFLAGS: 00010207 RAX: 6b6b6b6b6b6b6b6b RBX: 6b6b6b6b6b6b6b53 RCX: 0000000000000006 RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000246 RBP: ffff88011d5cbce8 R08: 0000000000000002 R09: 0000000000000001 R10: 0000000000000001 R11: 0000000000000000 R12: ffff88011cd3f848 R13: ffff88011cd3f830 R14: ffff88011cd3f000 R15: 0000000000000000 FS: 00007f7b721dd7e0(0000) GS:ffff880121a00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00007fffa6f75038 CR3: 000000011bc1c000 CR4: 00000000000007e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process mount (pid: 2758, threadinfo ffff88011d5ca000, task ffff880116aacb80) Stack: ffff88011cd3f000 ffffffff8209b6c0 ffff88011d5cbd18 ffffffff812482f1 00000000000003f3 00000000ffffffea ffff880115f4c200 0000000000000000 ffff88011d5cbda8 ffffffff81249381 ffff8801219d8bf8 ffffffff00000000 Call Trace: [<ffffffff812482f1>] deactivate_locked_super+0x91/0xb0 [<ffffffff81249381>] mount_bdev+0x331/0x340 [<ffffffff81376730>] ? ext4_alloc_flex_bg_array+0x180/0x180 [<ffffffff81362035>] ext4_mount+0x15/0x20 [<ffffffff8124869a>] mount_fs+0x9a/0x2e0 [<ffffffff81277e25>] vfs_kern_mount+0xc5/0x170 [<ffffffff81279c02>] do_new_mount+0x172/0x2e0 [<ffffffff8127aa56>] do_mount+0x376/0x380 [<ffffffff8127ab98>] sys_mount+0x138/0x150 [<ffffffff818ffed9>] system_call_fastpath+0x16/0x1b Code: 8b 05 88 04 eb 00 48 3d 90 ff 06 82 48 8d 58 e8 75 19 4c 89 e7 e8 e4 d7 2c 00 48 c7 c7 00 ff 06 82 e8 58 5f ef ff 5b 41 5c c9 c3 <48> 8b 4b 18 48 8b 73 20 48 89 da 31 c0 48 c7 c7 c5 a0 e4 81 e\ 8 RIP [<ffffffff811bfb2d>] unregister_shrinker+0xad/0xe0 RSP <ffff88011d5cbcd8> Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07ext4: fix journal callback list traversalDmitry Monakhov
commit 5d3ee20855e28169d711b394857ee608a5023094 upstream. It is incorrect to use list_for_each_entry_safe() for journal callback traversial because ->next may be removed by other task: ->ext4_mb_free_metadata() ->ext4_mb_free_metadata() ->ext4_journal_callback_del() This results in the following issue: WARNING: at lib/list_debug.c:62 __list_del_entry+0x1c0/0x250() Hardware name: list_del corruption. prev->next should be ffff88019a4ec198, but was 6b6b6b6b6b6b6b6b Modules linked in: cpufreq_ondemand acpi_cpufreq freq_table mperf coretemp kvm_intel kvm crc32c_intel ghash_clmulni_intel microcode sg xhci_hcd button sd_mod crc_t10dif aesni_intel ablk_helper cryptd lrw aes_x86_64 xts gf128mul ahci libahci pata_acpi ata_generic dm_mirror dm_region_hash dm_log dm_mod Pid: 16400, comm: jbd2/dm-1-8 Tainted: G W 3.8.0-rc3+ #107 Call Trace: [<ffffffff8106fb0d>] warn_slowpath_common+0xad/0xf0 [<ffffffff8106fc06>] warn_slowpath_fmt+0x46/0x50 [<ffffffff813637e9>] ? ext4_journal_commit_callback+0x99/0xc0 [<ffffffff8148cae0>] __list_del_entry+0x1c0/0x250 [<ffffffff813637bf>] ext4_journal_commit_callback+0x6f/0xc0 [<ffffffff813ca336>] jbd2_journal_commit_transaction+0x23a6/0x2570 [<ffffffff8108aa42>] ? try_to_del_timer_sync+0x82/0xa0 [<ffffffff8108b491>] ? del_timer_sync+0x91/0x1e0 [<ffffffff813d3ecf>] kjournald2+0x19f/0x6a0 [<ffffffff810ad630>] ? wake_up_bit+0x40/0x40 [<ffffffff813d3d30>] ? bit_spin_lock+0x80/0x80 [<ffffffff810ac6be>] kthread+0x10e/0x120 [<ffffffff810ac5b0>] ? __init_kthread_worker+0x70/0x70 [<ffffffff818ff6ac>] ret_from_fork+0x7c/0xb0 [<ffffffff810ac5b0>] ? __init_kthread_worker+0x70/0x70 This patch fix the issue as follows: - ext4_journal_commit_callback() make list truly traversial safe simply by always starting from list_head - fix race between two ext4_journal_callback_del() and ext4_journal_callback_try_del() Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07jbd2: fix race between jbd2_journal_remove_checkpoint and ->j_commit_callbackDmitry Monakhov
commit 794446c6946513c684d448205fbd76fa35f38b72 upstream. The following race is possible: [kjournald2] other_task jbd2_journal_commit_transaction() j_state = T_FINISHED; spin_unlock(&journal->j_list_lock); ->jbd2_journal_remove_checkpoint() ->jbd2_journal_free_transaction(); ->kmem_cache_free(transaction) ->j_commit_callback(journal, transaction); -> USE_AFTER_FREE WARNING: at lib/list_debug.c:62 __list_del_entry+0x1c0/0x250() Hardware name: list_del corruption. prev->next should be ffff88019a4ec198, but was 6b6b6b6b6b6b6b6b Modules linked in: cpufreq_ondemand acpi_cpufreq freq_table mperf coretemp kvm_intel kvm crc32c_intel ghash_clmulni_intel microcode sg xhci_hcd button sd_mod crc_t10dif aesni_intel ablk_helper cryptd lrw aes_x86_64 xts gf128mul ahci libahci pata_acpi ata_generic dm_mirror dm_region_hash dm_log dm_mod Pid: 16400, comm: jbd2/dm-1-8 Tainted: G W 3.8.0-rc3+ #107 Call Trace: [<ffffffff8106fb0d>] warn_slowpath_common+0xad/0xf0 [<ffffffff8106fc06>] warn_slowpath_fmt+0x46/0x50 [<ffffffff813637e9>] ? ext4_journal_commit_callback+0x99/0xc0 [<ffffffff8148cae0>] __list_del_entry+0x1c0/0x250 [<ffffffff813637bf>] ext4_journal_commit_callback+0x6f/0xc0 [<ffffffff813ca336>] jbd2_journal_commit_transaction+0x23a6/0x2570 [<ffffffff8108aa42>] ? try_to_del_timer_sync+0x82/0xa0 [<ffffffff8108b491>] ? del_timer_sync+0x91/0x1e0 [<ffffffff813d3ecf>] kjournald2+0x19f/0x6a0 [<ffffffff810ad630>] ? wake_up_bit+0x40/0x40 [<ffffffff813d3d30>] ? bit_spin_lock+0x80/0x80 [<ffffffff810ac6be>] kthread+0x10e/0x120 [<ffffffff810ac5b0>] ? __init_kthread_worker+0x70/0x70 [<ffffffff818ff6ac>] ret_from_fork+0x7c/0xb0 [<ffffffff810ac5b0>] ? __init_kthread_worker+0x70/0x70 In order to demonstrace this issue one should mount ext4 with mount -o discard option on SSD disk. This makes callback longer and race window becomes wider. In order to fix this we should mark transaction as finished only after callbacks have completed Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07ext4/jbd2: don't wait (forever) for stale tid caused by wraparoundTheodore Ts'o
commit d76a3a77113db020d9bb1e894822869410450bd9 upstream. In the case where an inode has a very stale transaction id (tid) in i_datasync_tid or i_sync_tid, it's possible that after a very large (2**31) number of transactions, that the tid number space might wrap, causing tid_geq()'s calculations to fail. Commit deeeaf13 "jbd2: fix fsync() tid wraparound bug", later modified by commit e7b04ac0 "jbd2: don't wake kjournald unnecessarily", attempted to fix this problem, but it only avoided kjournald spinning forever by fixing the logic in jbd2_log_start_commit(). Unfortunately, in the codepaths in fs/ext4/fsync.c and fs/ext4/inode.c that might call jbd2_log_start_commit() with a stale tid, those functions will subsequently call jbd2_log_wait_commit() with the same stale tid, and then wait for a very long time. To fix this, we replace the calls to jbd2_log_start_commit() and jbd2_log_wait_commit() with a call to a new function, jbd2_complete_transaction(), which will correctly handle stale tid's. As a bonus, jbd2_complete_transaction() will avoid locking j_state_lock for writing unless a commit needs to be started. This should have a small (but probably not measurable) improvement for ext4's scalability. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reported-by: Ben Hutchings <ben@decadent.org.uk> Reported-by: George Barnett <gbarnett@atlassian.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07nfsd: Decode and send 64bit time valuesBryan Schumaker
commit bf8d909705e9d9bac31d9b8eac6734d2b51332a7 upstream. The seconds field of an nfstime4 structure is 64bit, but we are assuming that the first 32bits are zero-filled. So if the client tries to set atime to a value before the epoch (touch -t 196001010101), then the server will save the wrong value on disk. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07nfsd: use kmem_cache_free() instead of kfree()Wei Yongjun
commit 2c44a23471d048118e49b616d08df0729cdbd9f1 upstream. memory allocated by kmem_cache_alloc() should be freed using kmem_cache_free(), not kfree(). Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07nfsd: don't run get_file if nfs4_preprocess_stateid_op return errorfanchaoting
commit b022032e195ffca83d7002d6b84297d796ed443b upstream. we should return error status directly when nfs4_preprocess_stateid_op return error. Signed-off-by: fanchaoting <fanchaoting@cn.fujitsu.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07nfsd4: don't close read-write opens too soonJ. Bruce Fields
commit 0c7c3e67ab91ec6caa44bdf1fc89a48012ceb0c5 upstream. Don't actually close any opens until we don't need them at all. This means being left with write access when it's not really necessary, but that's better than putting a file that might still have posix locks held on it, as we have been. Reported-by: Toralf Förster <toralf.foerster@gmx.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07NFSv4: Handle NFS4ERR_DELAY and NFS4ERR_GRACE in nfs4_open_delegation_recallTrond Myklebust
commit 8b6cc4d6f841d31f72fe7478453759166d366274 upstream. A server shouldn't normally return NFS4ERR_GRACE if the client holds a delegation, since no conflicting lock reclaims can be granted, however the spec does not require the server to grant the open in this instance Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07NFSv4: Handle NFS4ERR_DELAY and NFS4ERR_GRACE in nfs4_lock_delegation_recallTrond Myklebust
commit dbb21c25a35a71baf413f5176f028ee11b88cfbc upstream. A server shouldn't normally return NFS4ERR_GRACE if the client holds a delegation, since no conflicting lock reclaims can be granted, however the spec does not require the server to grant the lock in this instance. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07LOCKD: Ensure that nlmclnt_block resets block->b_status after a server rebootTrond Myklebust
commit 1dfd89af8697a299e7982ae740d4695ecd917eef upstream. After a server reboot, the reclaimer thread will recover all the existing locks. For locks that are blocked, however, it will change the value of block->b_status to nlm_lck_denied_grace_period in order to signal that they need to wake up and resend the original blocking lock request. Due to a bug, however, the block->b_status never gets reset after the blocked locks have been woken up, and so the process goes into an infinite loop of resends until the blocked lock is satisfied. Reported-by: Marc Eshel <eshel@us.ibm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
