commit fe316bf2d5847bc5dd975668671a7b1067603bc7 upstream.
Since 2.6.39 (1196f8b), when a driver returns -ENOMEDIUM for open(),
__blkdev_get() calls rescan_partitions() to remove
in-kernel partition structures and raise KOBJ_CHANGE uevent.
However it ends up calling driver's revalidate_disk without open
and could cause oops.
In the case of SCSI:
process A process B
sys_open
__blkdev_get
sd_open
returns -ENOMEDIUM
scsi_remove_device
<scsi_device torn down>
rescan_partitions
sd_revalidate_disk
<oops>
Oopses are reported here:
http://marc.info/?l=linux-scsi&m=132388619710052
This patch separates the partition invalidation from rescan_partitions()
and use it for -ENOMEDIUM case.
Reported-by: Huajun Li <huajun.li.lee@gmail.com>
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Acked-by: Tejun Heo <tj@kernel.org>
commit 097b180ca09b581ef0dc24fbcfc1b227de3875df upstream.
complete_walk() already puts nd->path, no need to do it again at cleanup time.
This would result in Oopses if triggered, apparently the codepath is not too
well exercised.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit 7f6c7e62fcc123e6bd9206da99a2163fe3facc31 upstream.
complete_walk() returns either ECHILD or ESTALE. do_last() turns this into
ECHILD unconditionally. If not in RCU mode, this error will reach userspace
which is complete nonsense.
commit c7b285550544c22bc005ec20978472c9ac7138c6 upstream.
Current code has put_ioctx() called asynchronously from aio_fput_routine();
that's done *after* we have killed the request that used to pin ioctx,
so there's nothing to stop io_destroy() waiting in wait_for_all_aios()
from progressing. As the result, we can end up with async call of
put_ioctx() being the last one and possibly happening during exit_mmap()
or elf_core_dump(), neither of which expects stray munmap() being done
to them...
We do need to prevent _freeing_ ioctx until aio_fput_routine() is done
with that, but that's all we care about - neither io_destroy() nor
exit_aio() will progress past wait_for_all_aios() until aio_fput_routine()
does really_put_req(), so the ioctx teardown won't be done until then
and we don't care about the contents of ioctx past that point.
Since actual freeing of these suckers is RCU-delayed, we don't need to
bump ioctx refcount when request goes into list for async removal.
All we need is rcu_read_lock held just over the ->ctx_lock-protected
area in aio_fput_routine().
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Acked-by: Benjamin LaHaise <bcrl@kvack.org>
commit 86b62a2cb4fc09037bbce2959d2992962396fd7f upstream.
Have ioctx_alloc() return an extra reference, so that caller would drop it
on success and not bother with re-grabbing it on failure exit. The current
code is obviously broken - io_destroy() from another thread that managed
to guess the address io_setup() would've returned would free ioctx right
under us; gets especially interesting if aio_context_t * we pass to
io_setup() points to PROT_READ mapping, so put_user() fails and we end
up doing io_destroy() on kioctx another thread has just got freed...
commit 5bccda0ebc7c0331b81ac47d39e4b920b198b2cd upstream.
The cifs code will attempt to open files on lookup under certain
circumstances. What happens though if we find that the file we opened
was actually a FIFO or other special file?
Currently, the open filehandle just ends up being leaked leading to
a dentry refcount mismatch and oops on umount. Fix this by having the
code close the filehandle on the server if it turns out not to be a
regular file. While we're at it, change this spaghetti if statement
into a switch too.
Reported-by: CAI Qian <caiqian@redhat.com>
Tested-by: CAI Qian <caiqian@redhat.com>
Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <smfrench@gmail.com>
commit c8e252586f8d5de906385d8cf6385fee289a825e upstream.
The regset common infrastructure assumed that regsets would always
have .get and .set methods, but not necessarily .active methods.
Unfortunately people have since written regsets without .set methods.
Rather than putting in stub functions everywhere, handle regsets with
null .get or .set methods explicitly.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Acked-by: Roland McGrath <roland@hack.frob.com>
commit a32744d4abae24572eff7269bc17895c41bd0085 upstream.
When the autofs protocol version 5 packet type was added in commit
5c0a32fc2cd0 ("autofs4: add new packet type for v5 communications"), it
obvously tried quite hard to be word-size agnostic, and uses explicitly
sized fields that are all correctly aligned.
However, with the final "char name[NAME_MAX+1]" array at the end, the
actual size of the structure ends up being not very well defined:
because the struct isn't marked 'packed', doing a "sizeof()" on it will
align the size of the struct up to the biggest alignment of the members
it has.
And despite all the members being the same, the alignment of them is
different: a "__u64" has 4-byte alignment on x86-32, but native 8-byte
alignment on x86-64. And while 'NAME_MAX+1' ends up being a nice round
number (256), the name[] array starts out a 4-byte aligned.
End result: the "packed" size of the structure is 300 bytes: 4-byte, but
not 8-byte aligned.
As a result, despite all the fields being in the same place on all
architectures, sizeof() will round up that size to 304 bytes on
architectures that have 8-byte alignment for u64.
Note that this is *not* a problem for 32-bit compat mode on POWER, since
there __u64 is 8-byte aligned even in 32-bit mode. But on x86, 32-bit
and 64-bit alignment is different for 64-bit entities, and as a result
the structure that has exactly the same layout has different sizes.
So on x86-64, but no other architecture, we will just subtract 4 from
the size of the structure when running in a compat task. That way we
will write the properly sized packet that user mode expects.
Not pretty. Sadly, this very subtle, and unnecessary, size difference
has been encoded in user space that wants to read packets of *exactly*
the right size, and will refuse to touch anything else.
Reported-and-tested-by: Thomas Meyer <thomas@m3y3r.de>
Signed-off-by: Ian Kent <raven@themaw.net>
Cc: Jonathan Nieder <jrnieder@gmail.com>
commit 28d82dc1c4edbc352129f97f4ca22624d1fe61de upstream.
The current epoll code can be tickled to run basically indefinitely in
both loop detection path check (on ep_insert()), and in the wakeup paths.
The programs that tickle this behavior set up deeply linked networks of
epoll file descriptors that cause the epoll algorithms to traverse them
indefinitely. A couple of these sample programs have been previously
posted in this thread: https://lkml.org/lkml/2011/2/25/297.
To fix the loop detection path check algorithms, I simply keep track of
the epoll nodes that have been already visited. Thus, the loop detection
becomes proportional to the number of epoll file descriptor and links.
This dramatically decreases the run-time of the loop check algorithm. In
one diabolical case I tried it reduced the run-time from 15 mintues (all
in kernel time) to .3 seconds.
Fixing the wakeup paths could be done at wakeup time in a similar manner
by keeping track of nodes that have already been visited, but the
complexity is harder, since there can be multiple wakeups on different
cpus...Thus, I've opted to limit the number of possible wakeup paths when
the paths are created.
This is accomplished, by noting that the end file descriptor points that
are found during the loop detection pass (from the newly added link), are
actually the sources for wakeup events. I keep a list of these file
descriptors and limit the number and length of these paths that emanate
from these 'source file descriptors'. In the current implemetation I
allow 1000 paths of length 1, 500 of length 2, 100 of length 3, 50 of
length 4 and 10 of length 5. Note that it is sufficient to check the
'source file descriptors' reachable from the newly added link, since no
other 'source file descriptors' will have newly added links. This allows
us to check only the wakeup paths that may have gotten too long, and not
re-check all possible wakeup paths on the system.
In terms of the path limit selection, I think its first worth noting that
the most common case for epoll, is probably the model where you have 1
epoll file descriptor that is monitoring n number of 'source file
descriptors'. In this case, each 'source file descriptor' has a 1 path of
length 1. Thus, I believe that the limits I'm proposing are quite
reasonable and in fact may be too generous. Thus, I'm hoping that the
proposed limits will not prevent any workloads that currently work to
fail.
In terms of locking, I have extended the use of the 'epmutex' to all
epoll_ctl add and remove operations. Currently its only used in a subset
of the add paths. I need to hold the epmutex, so that we can correctly
traverse a coherent graph, to check the number of paths. I believe that
this additional locking is probably ok, since its in the setup/teardown
paths, and doesn't affect the running paths, but it certainly is going to
add some extra overhead. Also, worth noting is that the epmuex was
recently added to the ep_ctl add operations in the initial path loop
detection code using the argument that it was not on a critical path.
Another thing to note here, is the length of epoll chains that is allowed.
Currently, eventpoll.c defines:
/* Maximum number of nesting allowed inside epoll sets */
#define EP_MAX_NESTS 4
This basically means that I am limited to a graph depth of 5 (EP_MAX_NESTS
+ 1). However, this limit is currently only enforced during the loop
check detection code, and only when the epoll file descriptors are added
in a certain order. Thus, this limit is currently easily bypassed. The
newly added check for wakeup paths, stricly limits the wakeup paths to a
length of 5, regardless of the order in which ep's are linked together.
Thus, a side-effect of the new code is a more consistent enforcement of
the graph depth.
Thus far, I've tested this, using the sample programs previously
mentioned, which now either return quickly or return -EINVAL. I've also
testing using the piptest.c epoll tester, which showed no difference in
performance. I've also created a number of different epoll networks and
tested that they behave as expectded.
I believe this solves the original diabolical test cases, while still
preserving the sane epoll nesting.
Signed-off-by: Jason Baron <jbaron@redhat.com>
Cc: Nelson Elhage <nelhage@ksplice.com>
Cc: Davide Libenzi <davidel@xmailserver.org>
commit 971316f0503a5c50633d07b83b6db2f15a3a5b00 upstream.
signalfd_cleanup() ensures that ->signalfd_wqh is not used, but
this is not enough. eppoll_entry->whead still points to the memory
we are going to free, ep_unregister_pollwait()->remove_wait_queue()
is obviously unsafe.
Change ep_poll_callback(POLLFREE) to set eppoll_entry->whead = NULL,
change ep_unregister_pollwait() to check pwq->whead != NULL under
rcu_read_lock() before remove_wait_queue(). We add the new helper,
ep_remove_wait_queue(), for this.
This works because sighand_cachep is SLAB_DESTROY_BY_RCU and because
->signalfd_wqh is initialized in sighand_ctor(), not in copy_sighand.
ep_unregister_pollwait()->remove_wait_queue() can play with already
freed and potentially reused ->sighand, but this is fine. This memory
must have the valid ->signalfd_wqh until rcu_read_unlock().
Reported-by: Maxime Bizon <mbizon@freebox.fr>
commit d80e731ecab420ddcb79ee9d0ac427acbc187b4b upstream.
This patch is intentionally incomplete to simplify the review.
It ignores ep_unregister_pollwait() which plays with the same wqh.
See the next change.
epoll assumes that the EPOLL_CTL_ADD'ed file controls everything
f_op->poll() needs. In particular it assumes that the wait queue
can't go away until eventpoll_release(). This is not true in case
of signalfd, the task which does EPOLL_CTL_ADD uses its ->sighand
which is not connected to the file.
This patch adds the special event, POLLFREE, currently only for
epoll. It expects that init_poll_funcptr()'ed hook should do the
necessary cleanup. Perhaps it should be defined as EPOLLFREE in
eventpoll.
__cleanup_sighand() is changed to do wake_up_poll(POLLFREE) if
->signalfd_wqh is not empty, we add the new signalfd_cleanup()
helper.
ep_poll_callback(POLLFREE) simply does list_del_init(task_list).
This make this poll entry inconsistent, but we don't care. If you
share epoll fd which contains our sigfd with another process you
should blame yourself. signalfd is "really special". I simply do
not know how we can define the "right" semantics if it used with
epoll.
The main problem is, epoll calls signalfd_poll() once to establish
the connection with the wait queue, after that signalfd_poll(NULL)
returns the different/inconsistent results depending on who does
EPOLL_CTL_MOD/signalfd_read/etc. IOW: apart from sigmask, signalfd
has nothing to do with the file, it works with the current thread.
In short: this patch is the hack which tries to fix the symptoms.
It also assumes that nobody can take tasklist_lock under epoll
locks, this seems to be true.
Note:
- we do not have wake_up_all_poll() but wake_up_poll()
is fine, poll/epoll doesn't use WQ_FLAG_EXCLUSIVE.
- signalfd_cleanup() uses POLLHUP along with POLLFREE,
we need a couple of simple changes in eventpoll.c to
make sure it can't be "lost".
commit b9f9a03150969e4bd9967c20bce67c4de769058f upstream.
To ensure that we don't just reuse the bad delegation when we attempt to
recover the nfs4_state that received the bad stateid error.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 545d680938be1e86a6c5250701ce9abaf360c495 upstream.
After passing through a ->setxattr() call, eCryptfs needs to copy the
inode attributes from the lower inode to the eCryptfs inode, as they
may have changed in the lower filesystem's ->setxattr() path.
One example is if an extended attribute containing a POSIX Access
Control List is being set. The new ACL may cause the lower filesystem to
modify the mode of the lower inode and the eCryptfs inode would need to
be updated to reflect the new mode.
https://launchpad.net/bugs/926292
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
Reported-by: Sebastien Bacher <seb128@ubuntu.com>
Cc: John Johansen <john.johansen@canonical.com>
commit de47a4176c532ef5961b8a46a2d541a3517412d3 upstream.
For null user mounts, do not invoke string length function
during session setup.
Reported-and-Tested-by: Chris Clayton <chris2553@googlemail.com>
Acked-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
commit 684a3ff7e69acc7c678d1a1394fe9e757993fd34 upstream.
ecryptfs_write() can enter an infinite loop when truncating a file to a
size larger than 4G. This only happens on architectures where size_t is
represented by 32 bits.
This was caused by a size_t overflow due to it incorrectly being used to
store the result of a calculation which uses potentially large values of
type loff_t.
[tyhicks@canonical.com: rewrite subject and commit message]
Signed-off-by: Li Wang <liwang@nudt.edu.cn>
Signed-off-by: Yunchuan Wen <wenyunchuan@kylinos.com.cn>
Reviewed-by: Cong Wang <xiyou.wangcong@gmail.com>
commit 853a0c25baf96b028de1654bea1e0c8857eadf3d upstream.
When we hit EIO while writing LVID, the buffer uptodate bit is cleared.
This then results in an anoying warning from mark_buffer_dirty() when we
write the buffer again. So just set uptodate flag unconditionally.
Reviewed-by: Namjae Jeon <linkinjeon@gmail.com>
Cc: Dave Jones <davej@redhat.com>
commit 6d08f2c7139790c268820a2e590795cb8333181a upstream.
Once /proc/pid/mem is opened, the memory can't be released until
mem_release() even if its owner exits.
Change mem_open() to do atomic_inc(mm_count) + mmput(), this only
pins mm_struct. Change mem_rw() to do atomic_inc_not_zero(mm_count)
before access_remote_vm(), this verifies that this mm is still alive.
I am not sure what should mem_rw() return if atomic_inc_not_zero()
fails. With this patch it returns zero to match the "mm == NULL" case,
may be it should return -EINVAL like it did before e268337d.
Perhaps it makes sense to add the additional fatal_signal_pending()
check into the main loop, to ensure we do not hold this memory if
the target task was oom-killed.
commit 572d34b946bae070debd42db1143034d9687e13f upstream.
No functional changes, cleanup and preparation.
mem_read() and mem_write() are very similar. Move this code into the
new common helper, mem_rw(), which takes the additional "int write"
argument.
commit 71879d3cb3dd8f2dfdefb252775c1b3ea04a3dd4 upstream.
mem_release() can hit mm == NULL, add the necessary check.
commit b1c770c273a4787069306fc82aab245e9ac72e9d upstream
When finding the longest extent in an AG, we read the value directly
out of the AGF buffer without endian conversion. This will give an
incorrect length, resulting in FITRIM operations potentially not
trimming everything that it should.
Note, for 3.0-stable this has been modified to apply to
fs/xfs/linux-2.6/xfs_discard.c instead of fs/xfs/xfs_discard.c. -bpm
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
commit 9b025eb3a89e041bab6698e3858706be2385d692 upstream.
Commit b52a360b forgot to call xfs_iunlock() when it detected corrupted
symplink and bailed out. Fix it by jumping to 'out' instead of doing return.
CC: Carlos Maiolino <cmaiolino@redhat.com>
Reviewed-by: Alex Elder <elder@kernel.org>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
commit 58ded24f0fcb85bddb665baba75892f6ad0f4b8a upstream.
If pages passed to the eCryptfs extent-based crypto functions are not
mapped and the module parameter ecryptfs_verbosity=1 was specified at
loading time, a NULL pointer dereference will occur.
Note that this wouldn't happen on a production system, as you wouldn't
pass ecryptfs_verbosity=1 on a production system. It leaks private
information to the system logs and is for debugging only.
The debugging info printed in these messages is no longer very useful
and rather than doing a kmap() in these debugging paths, it will be
better to simply remove the debugging paths completely.
https://launchpad.net/bugs/913651
commit a261a03904849c3df50bd0300efb7fb3f865137d upstream.
Most filesystems call inode_change_ok() very early in ->setattr(), but
eCryptfs didn't call it at all. It allowed the lower filesystem to make
the call in its ->setattr() function. Then, eCryptfs would copy the
appropriate inode attributes from the lower inode to the eCryptfs inode.
This patch changes that and actually calls inode_change_ok() on the
eCryptfs inode, fairly early in ecryptfs_setattr(). Ideally, the call
would happen earlier in ecryptfs_setattr(), but there are some possible
inode initialization steps that must happen first.
Since the call was already being made on the lower inode, the change in
functionality should be minimal, except for the case of a file extending
truncate call. In that case, inode_newsize_ok() was never being
called on the eCryptfs inode. Rather than inode_newsize_ok() catching
maximum file size errors early on, eCryptfs would encrypt zeroed pages
and write them to the lower filesystem until the lower filesystem's
write path caught the error in generic_write_checks(). This patch
introduces a new function, called ecryptfs_inode_newsize_ok(), which
checks if the new lower file size is within the appropriate limits when
the truncate operation will be growing the lower file.
In summary this change prevents eCryptfs truncate operations (and the
resulting page encryptions), which would exceed the lower filesystem
limits or FSIZE rlimits, from ever starting.
Reviewed-by: Li Wang <liwang@nudt.edu.cn>
commit 5e6f0d769017cc49207ef56996e42363ec26c1f0 upstream.
ecryptfs_write() handles the truncation of eCryptfs inodes. It grabs a
page, zeroes out the appropriate portions, and then encrypts the page
before writing it to the lower filesystem. It was unkillable and due to
the lack of sparse file support could result in tying up a large portion
of system resources, while encrypting pages of zeros, with no way for
the truncate operation to be stopped from userspace.
This patch adds the ability for ecryptfs_write() to detect a pending
fatal signal and return as gracefully as possible. The intent is to
leave the lower file in a useable state, while still allowing a user to
break out of the encryption loop. If a pending fatal signal is detected,
the eCryptfs inode size is updated to reflect the modified inode size
and then -EINTR is returned.
commit 30373dc0c87ffef68d5628e77d56ffb1fa22e1ee upstream.
Print inode on metadata read failure. The only real
way of dealing with metadata read failures is to delete
the underlying file system file. Having the inode
allows one to 'find . -inum INODE`.
[tyhicks@canonical.com: Removed some minor not-for-stable parts]
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
commit db10e556518eb9d21ee92ff944530d84349684f4 upstream.
A malicious count value specified when writing to /dev/ecryptfs may
result in a a very large kernel memory allocation.
This patch peeks at the specified packet payload size, adds that to the
size of the packet headers and compares the result with the write count
value. The resulting maximum memory allocation size is approximately 532
bytes.
Reported-by: Sasha Levin <levinsasha928@gmail.com>
commit 1f5d78dc4823a85f112aaa2d0f17624f8c2a6c52 upstream.
We switch to dynamic debugging in commit
56e46742e846e4de167dde0e1e1071ace1c882a5 but did not take into account that
now we do not control anymore whether a specific message is enabled or not.
So now we lock the "dbg_lock" and release it in every debugging macro, which
make them not so light-weight.
This commit removes the "dbg_lock" protection from the debugging macros to
fix the issue.
The downside is that now our DBGKEY() stuff is broken, but this is not
critical at all and will be fixed later.
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
commit 85e72aa5384b1a614563ad63257ded0e91d1a620 upstream.
/proc/pid/clear_refs is used to clear the Referenced and YOUNG bits for
pages and corresponding page table entries of the task with PID pid, which
includes any special mappings inserted into the page tables in order to
provide things like vDSOs and user helper functions.
On ARM this causes a problem because the vectors page is mapped as a
global mapping and since ec706dab ("ARM: add a vma entry for the user
accessible vector page"), a VMA is also inserted into each task for this
page to aid unwinding through signals and syscall restarts. Since the
vectors page is required for handling faults, clearing the YOUNG bit (and
subsequently writing a faulting pte) means that we lose the vectors page
*globally* and cannot fault it back in. This results in a system deadlock
on the next exception.
To see this problem in action, just run:
$ echo 1 > /proc/self/clear_refs
on an ARM platform (as any user) and watch your system hang. I think this
has been the case since 2.6.37
This patch avoids clearing the aforementioned bits for reserved pages,
therefore leaving the vectors page intact on ARM. Since reserved pages
are not candidates for swap, this change should not have any impact on the
usefulness of clear_refs.
Reported-by: Moussa Ba <moussaba@micron.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Cc: Matt Mackall <mpm@selenic.com>
commit fe0fe83585f88346557868a803a479dfaaa0688a upstream.
As mandated by the standard. In case of an IO error, a pNFS
objects layout driver must return it's layout. This is because
all device errors are reported to the server as part of the
layout return buffer.
This is implemented the same way PNFS_LAYOUTRET_ON_SETATTR
is done, through a bit flag on the pnfs_layoutdriver_type->flags
member. The flag is set by the layout driver that wants a
layout_return preformed at pnfs_ld_{write,read}_done in case
of an error.
(Though I have not defined a wrapper like pnfs_ld_layoutret_on_setattr
because this code is never called outside of pnfs.c and pnfs IO
paths)
Without this patch 3.[0-2] Kernels leak memory and have an annoying
WARN_ON after every IO error utilizing the pnfs-obj driver.
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
commit 5c0b4129c07b902b27d3f3ebc087757f534a3abd upstream.
Some time along the way pNFS IO errors were switched to
communicate with a special iodata->pnfs_error member instead
of the regular RPC members. But objlayout was not switched
over.
Fix that!
Without this fix any IO error is hanged, because IO is not
switched to MDS and pages are never cleared or read.
commit e268337dfe26dfc7efd422a804dbb27977a3cccc upstream.
Jüri Aedla reported that the /proc/<pid>/mem handling really isn't very
robust, and it also doesn't match the permission checking of any of the
other related files.
This changes it to do the permission checks at open time, and instead of
tracking the process, it tracks the VM at the time of the open. That
simplifies the code a lot, but does mean that if you hold the file
descriptor open over an execve(), you'll continue to read from the _old_
VM.
That is different from our previous behavior, but much simpler. If
somebody actually finds a load where this matters, we'll need to revert
this commit.
I suspect that nobody will ever notice - because the process mapping
addresses will also have changed as part of the execve. So you cannot
actually usefully access the fd across a VM change simply because all
the offsets for IO would have changed too.
Reported-by: Jüri Aedla <asd@ut.ee>
commit c3e0ef9a298e028a82ada28101ccd5cf64d209ee upstream.
For 32-bit architectures using standard jiffies the idletime calculation
in uptime_proc_show will quickly overflow. It takes (2^32 / HZ) seconds
of idle-time, or e.g. 12.45 days with no load on a quad-core with HZ=1000.
Switch to 64-bit calculations.
Cc: Michael Abbott <michael.abbott@diamond.ac.uk>
commit eaf5f9073533cde21c7121c136f1c3f072d9cf59 upstream.
Two (or more) concurrent calls of shrink_dcache_parent() on the same dentry may
cause shrink_dcache_parent() to loop forever.
Here's what appears to happen:
1 - CPU0: select_parent(P) finds C and puts it on dispose list, returns 1
2 - CPU1: select_parent(P) locks P->d_lock
3 - CPU0: shrink_dentry_list() locks C->d_lock
dentry_kill(C) tries to lock P->d_lock but fails, unlocks C->d_lock
4 - CPU1: select_parent(P) locks C->d_lock,
moves C from dispose list being processed on CPU0 to the new
5 - CPU0: shrink_dentry_list() finds dispose list empty, returns
6 - Goto 2 with CPU0 and CPU1 switched
Basically select_parent() steals the dentry from shrink_dentry_list() and thinks
it found a new one, causing shrink_dentry_list() to think it's making progress
and loop over and over.
One way to trigger this is to make udev calls stat() on the sysfs file while it
is going away.
Having a file in /lib/udev/rules.d/ with only this one rule seems to the trick:
ATTR{vendor}=="0x8086", ATTR{device}=="0x10ca", ENV{PCI_SLOT_NAME}="%k", ENV{MATCHADDR}="$attr{address}", RUN+="/bin/true"
Then execute the following loop:
while true; do
echo -bond0 > /sys/class/net/bonding_masters
echo +bond0 > /sys/class/net/bonding_masters
echo -bond1 > /sys/class/net/bonding_masters
echo +bond1 > /sys/class/net/bonding_masters
done
One fix would be to check all callers and prevent concurrent calls to
shrink_dcache_parent(). But I think a better solution is to stop the
stealing behavior.
This patch adds a new dentry flag that is set when the dentry is added to the
dispose list. The flag is cleared in dentry_lru_del() in case the dentry gets a
new reference just before being pruned.
If the dentry has this flag, select_parent() will skip it and let
shrink_dentry_list() retry pruning it. With select_parent() skipping those
dentries there will not be the appearance of progress (new dentries found) when
there is none, hence shrink_dcache_parent() will not loop forever.
Set the flag is also set in prune_dcache_sb() for consistency as suggested by
Linus.
commit fed474857efbed79cd390d0aee224231ca718f63 upstream.
Removing the parent of a watched file results in "kernel BUG at
fs/notify/mark.c:139".
To reproduce
add "-w /tmp/audit/dir/watched_file" to audit.rules
rm -rf /tmp/audit/dir
This is caused by fsnotify_destroy_mark() being called without an
extra reference taken by the caller.
Reported by Francesco Cosoleto here:
https://bugzilla.novell.com/show_bug.cgi?id=689860
Fix by removing the BUG_ON and adding a comment about not accessing mark after
the iput.
commit b2ea70afade7080360ac55c4e64ff7a5fafdb67b upstream.
expkey_parse() oopses when handling a 0 length export. This is easily
triggerable from usermode by writing 0 bytes into
'/proc/[proc id]/net/rpc/nfsd.fh/channel'.
Below is the log:
[ 1402.286893] BUG: unable to handle kernel paging request at ffff880077c49fff
[ 1402.287632] IP: [<ffffffff812b4b99>] expkey_parse+0x28/0x2e1
[ 1402.287632] PGD 2206063 PUD 1fdfd067 PMD 1ffbc067 PTE 8000000077c49160
[ 1402.287632] Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
[ 1402.287632] CPU 1
[ 1402.287632] Pid: 20198, comm: trinity Not tainted 3.2.0-rc2-sasha-00058-gc65cd37 #6
[ 1402.287632] RIP: 0010:[<ffffffff812b4b99>] [<ffffffff812b4b99>] expkey_parse+0x28/0x2e1
[ 1402.287632] RSP: 0018:ffff880077f0fd68 EFLAGS: 00010292
[ 1402.287632] RAX: ffff880077c49fff RBX: 00000000ffffffea RCX: 0000000001043400
[ 1402.287632] RDX: 0000000000000000 RSI: ffff880077c4a000 RDI: ffffffff82283de0
[ 1402.287632] RBP: ffff880077f0fe18 R08: 0000000000000001 R09: ffff880000000000
[ 1402.287632] R10: 0000000000000000 R11: 0000000000000001 R12: ffff880077c4a000
[ 1402.287632] R13: ffffffff82283de0 R14: 0000000001043400 R15: ffffffff82283de0
[ 1402.287632] FS: 00007f25fec3f700(0000) GS:ffff88007d400000(0000) knlGS:0000000000000000
[ 1402.287632] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 1402.287632] CR2: ffff880077c49fff CR3: 0000000077e1d000 CR4: 00000000000406e0
[ 1402.287632] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 1402.287632] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 1402.287632] Process trinity (pid: 20198, threadinfo ffff880077f0e000, task ffff880077db17b0)
[ 1402.287632] Stack:
[ 1402.287632] ffff880077db17b0 ffff880077c4a000 ffff880077f0fdb8 ffffffff810b411e
[ 1402.287632] ffff880000000000 ffff880077db17b0 ffff880077c4a000 ffffffff82283de0
[ 1402.287632] 0000000001043400 ffffffff82283de0 ffff880077f0fde8 ffffffff81111f63
[ 1402.287632] Call Trace:
[ 1402.287632] [<ffffffff810b411e>] ? lock_release+0x1af/0x1bc
[ 1402.287632] [<ffffffff81111f63>] ? might_fault+0x97/0x9e
[ 1402.287632] [<ffffffff81111f1a>] ? might_fault+0x4e/0x9e
[ 1402.287632] [<ffffffff81a8bcf2>] cache_do_downcall+0x3e/0x4f
[ 1402.287632] [<ffffffff81a8c950>] cache_write.clone.16+0xbb/0x130
[ 1402.287632] [<ffffffff81a8c9df>] ? cache_write_pipefs+0x1a/0x1a
[ 1402.287632] [<ffffffff81a8c9f8>] cache_write_procfs+0x19/0x1b
[ 1402.287632] [<ffffffff8118dc54>] proc_reg_write+0x8e/0xad
[ 1402.287632] [<ffffffff8113fe81>] vfs_write+0xaa/0xfd
[ 1402.287632] [<ffffffff8114142d>] ? fget_light+0x35/0x9e
[ 1402.287632] [<ffffffff8113ff8b>] sys_write+0x48/0x6f
[ 1402.287632] [<ffffffff81bbdb92>] system_call_fastpath+0x16/0x1b
[ 1402.287632] Code: c0 c9 c3 55 48 63 d2 48 89 e5 48 8d 44 32 ff 41 57 41 56 41 55 41 54 53 bb ea ff ff ff 48 81 ec 88 00 00 00 48 89 b5 58 ff ff ff
[ 1402.287632] 38 0a 0f 85 89 02 00 00 c6 00 00 48 8b 3d 44 4a e5 01 48 85
[ 1402.287632] RIP [<ffffffff812b4b99>] expkey_parse+0x28/0x2e1
[ 1402.287632] RSP <ffff880077f0fd68>
[ 1402.287632] ---[ end trace 368ef53ff773a5e3 ]---
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Neil Brown <neilb@suse.de>
Cc: linux-nfs@vger.kernel.org
Signed-off-by: Sasha Levin <levinsasha928@gmail.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit d34315da9146253351146140ea4b277193ee5e5f upstream.
Patch 56e46742e846e4de167dde0e1e1071ace1c882a5 broke UBIFS debugging messages:
before that commit when UBIFS debugging was enabled, users saw few useful
debugging messages after mount. However, that patch turned 'dbg_msg()' into
'pr_debug()', so to enable the debugging messages users have to enable them
first via /sys/kernel/debug/dynamic_debug/control, which is very impractical.
This commit makes 'dbg_msg()' to use 'printk()' instead of 'pr_debug()', just
as it was before the breakage.
commit 8a0d551a59ac92d8ff048d6cb29d3a02073e81e8 upstream.
Setting the security context of a NFSv4 mount via the context= mount
option is currently broken. The NFSv4 codepath allocates a parsed
options struct, and then parses the mount options to fill it. It
eventually calls nfs4_remote_mount which calls security_init_mnt_opts.
That clobbers the lsm_opts struct that was populated earlier. This bug
also looks like it causes a small memory leak on each v4 mount where
context= is used.
Fix this by moving the initialization of the lsm_opts into
nfs_alloc_parsed_mount_data. Also, add a destructor for
nfs_parsed_mount_data to make it easier to free all of the allocations
hanging off of it, and to ensure that the security_free_mnt_opts is
called whenever security_init_mnt_opts is.
I believe this regression was introduced quite some time ago, probably
by commit c02d7adf.
commit 61f2e5106582d02f30b6807e3f9c07463c572ccb upstream.
Signed-off-by: Andy Adamson <andros@netapp.com>
commit d50f2ab6f050311dbf7b8f5501b25f0bf64a439b upstream.
Commit 503358ae01b70ce6909d19dd01287093f6b6271c ("ext4: avoid divide by
zero when trying to mount a corrupted file system") fixes CVE-2009-4307
by performing a sanity check on s_log_groups_per_flex, since it can be
set to a bogus value by an attacker.
sbi->s_log_groups_per_flex = sbi->s_es->s_log_groups_per_flex;
groups_per_flex = 1 << sbi->s_log_groups_per_flex;
if (groups_per_flex < 2) { ... }
This patch fixes two potential issues in the previous commit.
1) The sanity check might only work on architectures like PowerPC.
On x86, 5 bits are used for the shifting amount. That means, given a
large s_log_groups_per_flex value like 36, groups_per_flex = 1 << 36
is essentially 1 << 4 = 16, rather than 0. This will bypass the check,
leaving s_log_groups_per_flex and groups_per_flex inconsistent.
2) The sanity check relies on undefined behavior, i.e., oversized shift.
A standard-confirming C compiler could rewrite the check in unexpected
ways. Consider the following equivalent form, assuming groups_per_flex
is unsigned for simplicity.
if (groups_per_flex == 0 || groups_per_flex == 1) {
We compile the code snippet using Clang 3.0 and GCC 4.6. Clang will
completely optimize away the check groups_per_flex == 0, leaving the
patched code as vulnerable as the original. GCC keeps the check, but
there is no guarantee that future versions will do the same.
Signed-off-by: Xi Wang <xi.wang@gmail.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 093019cf1b18dd31b2c3b77acce4e000e2cbc9ce upstream.
Commit fa8b18ed didn't prevent the integer overflow and possible
memory corruption. "count" can go negative and bypass the check.
commit d2eb8c359309ec45d6bf5b147303ab8e13be86ea upstream.
During BKL removal in 2.6.38, conversion of files from in-ICB format to normal
format got broken. We call ->writepage with i_data_sem held but udf_get_block()
also acquires i_data_sem thus creating A-A deadlock.
We fix the problem by dropping i_data_sem before calling ->writepage() which is
safe since i_mutex still protects us against any changes in the file. Also fix
pagelock - i_data_sem lock inversion in udf_expand_file_adinicb() by dropping
i_data_sem before calling find_or_create_page().
Reported-by: Matthias Matiak <netzpython@mail-on.us>
Tested-by: Matthias Matiak <netzpython@mail-on.us>
commit 33c104d415e92a51aaf638dc3d93920cfa601e5c upstream.
WARN_ON_ONCE(IS_RDONLY(inode)) tends to trip when filesystem hits error and is
remounted read-only. This unnecessarily scares users (well, they should be
scared because of filesystem error, but the stack trace distracts them from the
right source of their fear ;-). We could as well just remove the WARN_ON but
it's not hard to fix it to not trip on filesystem with errors and not use more
cycles in the common case so that's what we do.
commit a9e36da655e54545c3289b2a0700b5c443de0edd upstream.
This patch fixes a crash in reiserfs_delete_xattrs during umount.
When shrink_dcache_for_umount clears the dcache from
generic_shutdown_super, delayed evictions are forced to disk. If an
evicted inode has extended attributes associated with it, it will
need to walk the xattr tree to locate and remove them.
But since shrink_dcache_for_umount will BUG if it encounters active
dentries, the xattr tree must be released before it's called or it will
crash during every umount.
This patch forces the evictions to occur before generic_shutdown_super
by calling shrink_dcache_sb first. The additional evictions caused
by the removal of each associated xattr file and dir will be automatically
handled as they're added to the LRU list.
CC: reiserfs-devel@vger.kernel.org
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
commit a06d789b424190e9f59da391681f908486db2554 upstream.
When jqfmt mount option is not specified on remount, we mistakenly clear
s_jquota_fmt value stored in superblock. Fix the problem.
Commit be4f1ac828776bbc7868a68b465cd8eedb733cfd upstream.
Since Linux 2.6.36 the writeback code has introduces various measures for
live lock prevention during sync(). Unfortunately some of these are
actively harmful for the XFS model, where the inode gets marked dirty for
metadata from the data I/O handler.
The older_than_this checks that are now more strictly enforced since
writeback: avoid livelocking WB_SYNC_ALL writeback
by only calling into __writeback_inodes_sb and thus only sampling the
current cut off time once. But on a slow enough devices the previous
asynchronous sync pass might not have fully completed yet, and thus XFS
might mark metadata dirty only after that sampling of the cut off time for
the blocking pass already happened. I have not myself reproduced this
myself on a real system, but by introducing artificial delay into the
XFS I/O completion workqueues it can be reproduced easily.
Fix this by iterating over all XFS inodes in ->sync_fs and log all that
are dirty. This might log inode that only got redirtied after the
previous pass, but given how cheap delayed logging of inodes is it
isn't a major concern for performance.
Tested-by: Mark Tinguely <tinguely@sgi.com>
Reviewed-by: Mark Tinguely <tinguely@sgi.com>
Commit 0b8fd3033c308e4088760aa1d38ce77197b4e074 upstream.
If the writeback code writes back an inode because it has expired we currently
use the non-blockin ->write_inode path. This means any inode that is pinned
is skipped. With delayed logging and a workload that has very little log
traffic otherwise it is very likely that an inode that gets constantly
written to is always pinned, and thus we keep refusing to write it. The VM
writeback code at that point redirties it and doesn't try to write it again
for another 30 seconds. This means under certain scenarious time based
metadata writeback never happens.
Fix this by calling into xfs_log_inode for kupdate in addition to data
integrity syncs, and thus transfer the inode to the log ASAP.
commit 695c60f21c69e525a89279a5f35bae4ff237afbc upstream.
commit 828b1c50ae ("nilfs2: add compat ioctl") incidentally broke all
other NILFS compat ioctls. Make them work again.
Signed-off-by: Thomas Meyer <thomas@m3y3r.de>
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
commit 111d489f0fb431f4ae85d96851fbf8d3248c09d8 upstream.
Currently, the code assumes that the SEQUENCE status bits are mutually
exclusive. They are not...
commit 48706d0a91583d08c56e7ef2a7602d99c8d4133f upstream.
Fix two bugs in fuse_retrieve():
- retrieving more than one page would yield repeated instances of the
first page
- if more than FUSE_MAX_PAGES_PER_REQ pages were requested than the
request page array would overflow
fuse_retrieve() was added in 2.6.36 and these bugs had been there since the
beginning.
commit 5a0dc7365c240795bf190766eba7a27600be3b3e upstream.
We need to zero out part of a page which beyond EOF before setting uptodate,
otherwise, mapread or write will see non-zero data beyond EOF.
Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com>
