path: root/fs
2014-02-22Merge branch 'xfs-fixes-for-3.14-rc4' of git://oss.sgi.com/xfs/xfsLinus Torvalds
Pull xfs fixes from Dave Chinner: "This is the first pull request I've had to do for you, so I'm still sorting things out. The reason I'm sending this and not Ben should be obvious from the first commit below - SGI has stepped down from the XFS maintainership role. As such, I'd like to take another opportunity to thank them for their many years of effort maintaining XFS and supporting the XFS community that they developed from the ground up. So I haven't had time to work things like signed tags into my workflows yet, so this is just a repo branch I'm asking you to pull from. And yes, I named the branch -rc4 because I wanted the fixes in rc4, not because the branch was for merging into -rc3. Probably not right, either. Anyway, I should have everything sorted out by the time the next merge window comes around. If there's anything that you don't like in the pull req, feel free to flame me unmercifully. The changes are fixes for recent regressions and important thinkos in verification code: - a log vector buffer alignment issue on ia32 - timestamps on truncate got mangled - primary superblock CRC validation fixes and error message sanitisation" * 'xfs-fixes-for-3.14-rc4' of git://oss.sgi.com/xfs/xfs: xfs: limit superblock corruption errors to actual corruption xfs: skip verification on initial "guess" superblock read MAINTAINERS: SGI no longer maintaining XFS xfs: xfs_sb_read_verify() doesn't flag bad crcs on primary sb xfs: ensure correct log item buffer alignment xfs: ensure correct timestamp updates from truncate
2014-02-20Merge branch 'for-3.14-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup fixes from Tejun Heo: "Quite a few fixes this time. Three locking fixes, all marked for -stable. A couple error path fixes and some misc fixes. Hugh found a bug in memcg offlining sequence and we thought we could fix that from cgroup core side but that turned out to be insufficient and got reverted. A different fix has been applied to -mm" * 'for-3.14-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cgroup: update cgroup_enable_task_cg_lists() to grab siglock Revert "cgroup: use an ordered workqueue for cgroup destruction" cgroup: protect modifications to cgroup_idr with cgroup_mutex cgroup: fix locking in cgroup_cfts_commit() cgroup: fix error return from cgroup_create() cgroup: fix error return value in cgroup_mount() cgroup: use an ordered workqueue for cgroup destruction nfs: include xattr.h from fs/nfs/nfs3proc.c cpuset: update MAINTAINERS entry arm, pm, vmpressure: add missing slab.h includes
2014-02-19Merge tag 'nfs-for-3.14-4' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: "Highlights include stable fixes for the following bugs: - General performance regression due to NFS_INO_INVALID_LABEL being set when the server doesn't support labeled NFS - Hang in the RPC code due to a socket out-of-buffer race - Infinite loop when trying to establish the NFSv4 lease - Use-after-free bug in the RPCSEC gss code. - nfs4_select_rw_stateid is returning with a non-zero error value on success Other bug fixes: - Potential memory scribble in the RPC bi-directional RPC code - Pipe version reference leak - Use the correct net namespace in the new NFSv4 migration code" * tag 'nfs-for-3.14-4' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: NFS fix error return in nfs4_select_rw_stateid NFSv4: Use the correct net namespace in nfs4_update_server SUNRPC: Fix a pipe_version reference leak SUNRPC: Ensure that gss_auth isn't freed before its upcall messages SUNRPC: Fix potential memory scribble in xprt_free_bc_request() SUNRPC: Fix races in xs_nospace() SUNRPC: Don't create a gss auth cache unless rpc.gssd is running NFS: Do not set NFS_INO_INVALID_LABEL unless server supports labeled NFS
2014-02-19NFS fix error return in nfs4_select_rw_stateidAndy Adamson
Do not return an error when nfs4_copy_delegation_stateid succeeds. Signed-off-by: Andy Adamson <andros@netapp.com> Link: http://lkml.kernel.org/r/1392737765-41942-1-git-send-email-andros@netapp.com Fixes: ef1820f9be27b (NFSv4: Don't try to recover NFSv4 locks when...) Cc: NeilBrown <neilb@suse.de> Cc: stable@vger.kernel.org # 3.12+ Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-02-19xfs: limit superblock corruption errors to actual corruptionEric Sandeen
Today, if xfs_sb_read_verify xfs_sb_verify xfs_mount_validate_sb detects superblock corruption, it'll be extremely noisy, dumping 2 stacks, 2 hexdumps, etc. This is because we call XFS_CORRUPTION_ERROR in xfs_mount_validate_sb as well as in xfs_sb_read_verify. Also, *any* errors in xfs_mount_validate_sb which are not corruption per se; things like too-big-blocksize, bad version, bad magic, v1 dirs, rw-incompat etc - things which do not return EFSCORRUPTED - will still do the whole XFS_CORRUPTION_ERROR spew when xfs_sb_read_verify sees any error at all. And it suggests to the user that they should run xfs_repair, even if the root cause of the mount failure is a simple incompatibility. I'll submit that the probably-not-corrupted errors don't warrant this much noise, so this patch removes the warning for anything other than EFSCORRUPTED returns, and replaces the lower-level XFS_CORRUPTION_ERROR with an xfs_notice(). Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-02-19xfs: skip verification on initial "guess" superblock readEric Sandeen
When xfs_readsb() does the very first read of the superblock, it makes a guess at the length of the buffer, based on the sector size of the underlying storage. This may or may not match the filesystem sector size in sb_sectsize, so we can't i.e. do a CRC check on it; it might be too short. In fact, mounting a filesystem with sb_sectsize larger than the device sector size will cause a mount failure if CRCs are enabled, because we are checksumming a length which exceeds the buffer passed to it. So always read twice; the first time we read with NULL buffer ops to skip verification; then set the proper read length, hook up the proper verifier, and give it another go. Once we are sure that we've got the right buffer length, we can also use bp->b_length in the xfs_sb_read_verify, rather than the less-trusted on-disk sectorsize for secondary superblocks. Before this we ran the risk of passing junk to the crc32c routines, which didn't always handle extreme values. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-02-19xfs: xfs_sb_read_verify() doesn't flag bad crcs on primary sbEric Sandeen
My earlier commit 10e6e65 deserves a layer or two of brown paper bags. The logic in that commit means that a CRC failure on the primary superblock will *never* result in an error return. Hopefully this fixes it, so that we always return the error if it's a primary superblock, otherwise only if the filesystem has CRCs enabled. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2014-02-18Merge tag 'jfs-3.14-rc4' of git://github.com/kleikamp/linux-shaggyLinus Torvalds
Pull jfs fix from David Kleikamp: "Another ACL regression. This one more subtle" * tag 'jfs-3.14-rc4' of git://github.com/kleikamp/linux-shaggy: jfs: set i_ctime when setting ACL
2014-02-18Merge tag 'ext4_for_linus_stable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 fixes from Ted Ts'o: "Miscellaneous ext4 bug fixes for v3.14" * tag 'ext4_for_linus_stable' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: jbd2: fix use after free in jbd2_journal_start_reserved() ext4: don't leave i_crtime.tv_sec uninitialized ext4: fix online resize with a non-standard blocks per group setting ext4: fix online resize with very large inode tables ext4: don't try to modify s_flags if the the file system is read-only ext4: fix error paths in swap_inode_boot_loader() ext4: fix xfstest generic/299 block validity failures
2014-02-17jbd2: fix use after free in jbd2_journal_start_reserved()Dan Carpenter
If start_this_handle() fails then it leads to a use after free of "handle". Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@vger.kernel.org
2014-02-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull Ceph fixes from Sage Weil: "We have some patches fixing up ACL support issues from Zheng and Guangliang and a mount option to enable/disable this support. (These fixes were somewhat delayed by the Chinese holiday.) There is also a small fix for cached readdir handling when directories are fragmented" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: fix __dcache_readdir() ceph: add acl, noacl options for cephfs mount ceph: make ceph_forget_all_cached_acls() static inline ceph: add missing init_acl() for mkdir() and atomic_open() ceph: fix ceph_set_acl() ceph: fix ceph_removexattr() ceph: remove xattr when null value is given to setxattr() ceph: properly handle XATTR_CREATE and XATTR_REPLACE
2014-02-17Merge branch 'for-linus' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull CIFS fixes from Steve French: "Three cifs fixes, the most important fixing the problem with passing bogus pointers with writev (CVE-2014-0069). Two additional cifs fixes are still in review (including the fix for an append problem which Al also discovered)" * 'for-linus' of git://git.samba.org/sfrench/cifs-2.6: CIFS: Fix too big maxBuf size for SMB3 mounts cifs: ensure that uncached writes handle unmapped areas correctly [CIFS] Fix cifsacl mounts over smb2 to not call cifs
2014-02-17FS-Cache: Handle removal of unadded object to the fscache_object_list rb treeDavid Howells
When FS-Cache allocates an object, the following sequence of events can occur: -->fscache_alloc_object() -->cachefiles_alloc_object() [via cache->ops->alloc_object] <--[returns new object] -->fscache_attach_object() <--[failed] -->cachefiles_put_object() [via cache->ops->put_object] -->fscache_object_destroy() -->fscache_objlist_remove() -->rb_erase() to remove the object from fscache_object_list. resulting in a crash in the rbtree code. The problem is that the object is only added to fscache_object_list on the success path of fscache_attach_object() where it calls fscache_objlist_add(). So if fscache_attach_object() fails, the object won't have been added to the objlist rbtree. We do, however, unconditionally try to remove the object from the tree. Thanks to NeilBrown for finding this and suggesting this solution. Reported-by: NeilBrown <neilb@suse.de> Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: (a customer of) NeilBrown <neilb@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-17reiserfs: fix utterly brain-damaged indentation.Dave Jones
This has been this way for years, and every time I stumble across it I lose my lunch. After coming across it for the nth time in the Coverity results, I had to overcome the bystander effect and do something about it. This ignores the 79 column limit in favor of making it look like C instead of gibberish. The correct thing to do here would be to lose some of the indentation by breaking this function up into several smaller ones. I might do that at some point if I have the stomach to look at this again. (Also some of those overlong ternary operations would likely be more readable as regular if's) Signed-off-by: Dave Jones <davej@fedoraproject.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-17ceph: fix __dcache_readdir()Yan, Zheng
If directory is fragmented, readdir() read its dirfrags one by one. After reading all dirfrags, the corresponding dentries are sorted in (frag_t, off) order in the dcache. If dentries of a directory are all cached, __dcache_readdir() can use the cached dentries to satisfy readdir syscall. But when checking if a given dentry is after the position of readdir, __dcache_readdir() compares numerical value of frag_t directly. This is wrong, it should use ceph_frag_compare(). Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com>
2014-02-17ceph: add acl, noacl options for cephfs mountSage Weil
Make the 'acl' option dependent on having ACL support compiled in. Make the 'noacl' option work even without it so that one can always ask it to be off and not error out on mount when it is not supported. Signed-off-by: Guangliang Zhao <lucienchao@gmail.com> Signed-off-by: Sage Weil <sage@inktank.com>
2014-02-17ceph: make ceph_forget_all_cached_acls() static inlineGuangliang Zhao
Signed-off-by: Guangliang Zhao <lucienchao@gmail.com> Reviewed-by: Alex Elder <elder@linaro.org> Signed-off-by: Sage Weil <sage@inktank.com>
2014-02-17ceph: add missing init_acl() for mkdir() and atomic_open()Yan, Zheng
2014-02-17ceph: fix ceph_set_acl()Yan, Zheng
If acl is equivalent to file mode permission bits, ceph_set_acl() needs to remove any existing acl xattr. Use __ceph_setxattr() to handle both setting and removing acl xattr cases, it doesn't return -ENODATA when there is no acl xattr. Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com>
2014-02-17ceph: fix ceph_removexattr()Yan, Zheng
2014-02-17ceph: remove xattr when null value is given to setxattr()Yan, Zheng
For the setxattr request, introduce a new flag CEPH_XATTR_REMOVE to distinguish null value case from the zero-length value case. Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com>
2014-02-17ceph: properly handle XATTR_CREATE and XATTR_REPLACEYan, Zheng
return -EEXIST if XATTR_CREATE is set and xattr alread exists. return -ENODATA if XATTR_REPLACE is set but xattr does not exist. Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com>
2014-02-17NFSv4: Use the correct net namespace in nfs4_update_serverTrond Myklebust
We need to use the same net namespace that was used to resolve the hostname and sockaddr arguments. Fixes: 32e62b7c3ef09 (NFS: Add nfs4_update_server) Cc: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-02-16ext4: don't leave i_crtime.tv_sec uninitializedTheodore Ts'o
If the i_crtime field is not present in the inode, don't leave the field uninitialized. Fixes: ef7f38359 ("ext4: Add nanosecond timestamps") Reported-by: Vegard Nossum <vegard.nossum@oracle.com> Tested-by: Vegard Nossum <vegard.nossum@oracle.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@vger.kernel.org
2014-02-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "We have a small collection of fixes in my for-linus branch. The big thing that stands out is a revert of a new ioctl. Users haven't shipped yet in btrfs-progs, and Dave Sterba found a better way to export the information" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: use right clone root offset for compressed extents btrfs: fix null pointer deference at btrfs_sysfs_add_one+0x105 Btrfs: unset DCACHE_DISCONNECTED when mounting default subvol Btrfs: fix max_inline mount option Btrfs: fix a lockdep warning when cleaning up aborted transaction Revert "btrfs: add ioctl to export size of global metadata reservation"
2014-02-15ext4: fix online resize with a non-standard blocks per group settingTheodore Ts'o
The set_flexbg_block_bitmap() function assumed that the number of blocks in a blockgroup was sb->blocksize * 8, which is normally true, but not always! Use EXT4_BLOCKS_PER_GROUP(sb) instead, to fix block bitmap corruption after: mke2fs -t ext4 -g 3072 -i 4096 /dev/vdd 1G mount -t ext4 /dev/vdd /vdd resize2fs /dev/vdd 8G Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reported-by: Jon Bernard <jbernard@tuxion.com> Cc: stable@vger.kernel.org
2014-02-15ext4: fix online resize with very large inode tablesTheodore Ts'o
If a file system has a large number of inodes per block group, all of the metadata blocks in a flex_bg may be larger than what can fit in a single block group. Unfortunately, ext4_alloc_group_tables() in resize.c was never tested to see if it would handle this case correctly, and there were a large number of bugs which caused the following sequence to result in a BUG_ON: kernel bug at fs/ext4/resize.c:409! ... call trace: [<ffffffff81256768>] ext4_flex_group_add+0x1448/0x1830 [<ffffffff81257de2>] ext4_resize_fs+0x7b2/0xe80 [<ffffffff8123ac50>] ext4_ioctl+0xbf0/0xf00 [<ffffffff811c111d>] do_vfs_ioctl+0x2dd/0x4b0 [<ffffffff811b9df2>] ? final_putname+0x22/0x50 [<ffffffff811c1371>] sys_ioctl+0x81/0xa0 [<ffffffff81676aa9>] system_call_fastpath+0x16/0x1b code: c8 4c 89 df e8 41 96 f8 ff 44 89 e8 49 01 c4 44 29 6d d4 0 rip [<ffffffff81254fa1>] set_flexbg_block_bitmap+0x171/0x180 This can be reproduced with the following command sequence: mke2fs -t ext4 -i 4096 /dev/vdd 1G mount -t ext4 /dev/vdd /vdd resize2fs /dev/vdd 8G To fix this, we need to make sure the right thing happens when a block group's inode table straddles two block groups, which means the following bugs had to be fixed: 1) Not clearing the BLOCK_UNINIT flag in the second block group in ext4_alloc_group_tables --- the was proximate cause of the BUG_ON. 2) Incorrectly determining how many block groups contained contiguous free blocks in ext4_alloc_group_tables(). 3) Incorrectly setting the start of the next block range to be marked in use after a discontinuity in setup_new_flex_group_blocks(). Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@vger.kernel.org
2014-02-15Btrfs: use right clone root offset for compressed extentsFilipe David Borba Manana
For non compressed extents, iterate_extent_inodes() gives us offsets that take into account the data offset from the file extent items, while for compressed extents it doesn't. Therefore we have to adjust them before placing them in a send clone instruction. Not doing this adjustment leads to the receiving end requesting for a wrong a file range to the clone ioctl, which results in different file content from the one in the original send root. Issue reproducible with the following excerpt from the test I made for xfstests: _scratch_mkfs _scratch_mount "-o compress-force=lzo" $XFS_IO_PROG -f -c "truncate 118811" $SCRATCH_MNT/foo $XFS_IO_PROG -c "pwrite -S 0x0d -b 39987 92267 39987" $SCRATCH_MNT/foo $BTRFS_UTIL_PROG subvolume snapshot -r $SCRATCH_MNT $SCRATCH_MNT/mysnap1 $XFS_IO_PROG -c "pwrite -S 0x3e -b 80000 200000 80000" $SCRATCH_MNT/foo $BTRFS_UTIL_PROG filesystem sync $SCRATCH_MNT $XFS_IO_PROG -c "pwrite -S 0xdc -b 10000 250000 10000" $SCRATCH_MNT/foo $XFS_IO_PROG -c "pwrite -S 0xff -b 10000 300000 10000" $SCRATCH_MNT/foo # will be used for incremental send to be able to issue clone operations $BTRFS_UTIL_PROG subvolume snapshot -r $SCRATCH_MNT $SCRATCH_MNT/clones_snap $BTRFS_UTIL_PROG subvolume snapshot -r $SCRATCH_MNT $SCRATCH_MNT/mysnap2 $FSSUM_PROG -A -f -w $tmp/1.fssum $SCRATCH_MNT/mysnap1 $FSSUM_PROG -A -f -w $tmp/2.fssum -x $SCRATCH_MNT/mysnap2/mysnap1 \ -x $SCRATCH_MNT/mysnap2/clones_snap $SCRATCH_MNT/mysnap2 $FSSUM_PROG -A -f -w $tmp/clones.fssum $SCRATCH_MNT/clones_snap \ -x $SCRATCH_MNT/clones_snap/mysnap1 -x $SCRATCH_MNT/clones_snap/mysnap2 $BTRFS_UTIL_PROG send $SCRATCH_MNT/mysnap1 -f $tmp/1.snap $BTRFS_UTIL_PROG send $SCRATCH_MNT/clones_snap -f $tmp/clones.snap $BTRFS_UTIL_PROG send -p $SCRATCH_MNT/mysnap1 \ -c $SCRATCH_MNT/clones_snap $SCRATCH_MNT/mysnap2 -f $tmp/2.snap _scratch_unmount _scratch_mkfs _scratch_mount $BTRFS_UTIL_PROG receive $SCRATCH_MNT -f $tmp/1.snap $FSSUM_PROG -r $tmp/1.fssum $SCRATCH_MNT/mysnap1 2>> $seqres.full $BTRFS_UTIL_PROG receive $SCRATCH_MNT -f $tmp/clones.snap $FSSUM_PROG -r $tmp/clones.fssum $SCRATCH_MNT/clones_snap 2>> $seqres.full $BTRFS_UTIL_PROG receive $SCRATCH_MNT -f $tmp/2.snap $FSSUM_PROG -r $tmp/2.fssum $SCRATCH_MNT/mysnap2 2>> $seqres.full Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-15btrfs: fix null pointer deference at btrfs_sysfs_add_one+0x105Anand Jain
bdev is null when disk has disappeared and mounted with the degrade option stack trace --------- btrfs_sysfs_add_one+0x105/0x1c0 [btrfs] open_ctree+0x15f3/0x1fe0 [btrfs] btrfs_mount+0x5db/0x790 [btrfs] ? alloc_pages_current+0xa4/0x160 mount_fs+0x34/0x1b0 vfs_kern_mount+0x62/0xf0 do_mount+0x22e/0xa80 ? __get_free_pages+0x9/0x40 ? copy_mount_options+0x31/0x170 SyS_mount+0x7e/0xc0 system_call_fastpath+0x16/0x1b --------- reproducer: ------- mkfs.btrfs -draid1 -mraid1 /dev/sdc /dev/sdd (detach a disk) devmgt detach /dev/sdc [1] mount -o degrade /dev/sdd /btrfs ------- [1] github.com/anajain/devmgt.git Signed-off-by: Anand Jain <Anand.Jain@oracle.com> Tested-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-14CIFS: Fix too big maxBuf size for SMB3 mountsPavel Shilovsky
SMB3 servers can respond with MaxTransactSize of more than 4M that can cause a memory allocation error returned from kmalloc in a lock codepath. Also the client doesn't support multicredit requests now and allows buffer sizes of 65536 bytes only. Set MaxTransactSize to this maximum supported value. Cc: stable@vger.kernel.org # 3.7+ Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2014-02-14cifs: ensure that uncached writes handle unmapped areas correctlyJeff Layton
It's possible for userland to pass down an iovec via writev() that has a bogus user pointer in it. If that happens and we're doing an uncached write, then we can end up getting less bytes than we expect from the call to iov_iter_copy_from_user. This is CVE-2014-0069 cifs_iovec_write isn't set up to handle that situation however. It'll blindly keep chugging through the page array and not filling those pages with anything useful. Worse yet, we'll later end up with a negative number in wdata->tailsz, which will confuse the sending routines and cause an oops at the very least. Fix this by having the copy phase of cifs_iovec_write stop copying data in this situation and send the last write as a short one. At the same time, we want to avoid sending a zero-length write to the server, so break out of the loop and set rc to -EFAULT if that happens. This also allows us to handle the case where no address in the iovec is valid. [Note: Marking this for stable on v3.4+ kernels, but kernels as old as v2.6.38 may have a similar problem and may need similar fix] Cc: <stable@vger.kernel.org> # v3.4+ Reviewed-by: Pavel Shilovsky <piastry@etersoft.ru> Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2014-02-14Btrfs: unset DCACHE_DISCONNECTED when mounting default subvolJosef Bacik
A user was running into errors from an NFS export of a subvolume that had a default subvol set. When we mount a default subvol we will use d_obtain_alias() to find an existing dentry for the subvolume in the case that the root subvol has already been mounted, or a dummy one is allocated in the case that the root subvol has not already been mounted. This allows us to connect the dentry later on if we wander into the path. However if we don't ever wander into the path we will keep DCACHE_DISCONNECTED set for a long time, which angers NFS. It doesn't appear to cause any problems but it is annoying nonetheless, so simply unset DCACHE_DISCONNECTED in the get_default_root case and switch btrfs_lookup() to use d_materialise_unique() instead which will make everything play nicely together and reconnect stuff if we wander into the defaul subvol path from a different way. With this patch I'm no longer getting the NFS errors when exporting a volume that has been mounted with a default subvol set. Thanks, cc: bfields@fieldses.org cc: ebiederm@xmission.com Signed-off-by: Josef Bacik <jbacik@fb.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-14Btrfs: fix max_inline mount optionMitch Harder
Currently, the only mount option for max_inline that has any effect is max_inline=0. Any other value that is supplied to max_inline will be adjusted to a minimum of 4k. Since max_inline has an effective maximum of ~3900 bytes due to page size limitations, the current behaviour only has meaning for max_inline=0. This patch will allow the the max_inline mount option to accept non-zero values as indicated in the documentation. Signed-off-by: Mitch Harder <mitch.harder@sabayonlinux.org> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-14Btrfs: fix a lockdep warning when cleaning up aborted transactionLiu Bo
Given now we have 2 spinlock for management of delayed refs, CONFIG_DEBUG_SPINLOCK=y helped me find this, [ 4723.413809] BUG: spinlock wrong CPU on CPU#1, btrfs-transacti/2258 [ 4723.414882] lock: 0xffff880048377670, .magic: dead4ead, .owner: btrfs-transacti/2258, .owner_cpu: 2 [ 4723.417146] CPU: 1 PID: 2258 Comm: btrfs-transacti Tainted: G W O 3.12.0+ #4 [ 4723.421321] Call Trace: [ 4723.421872] [<ffffffff81680fe7>] dump_stack+0x54/0x74 [ 4723.422753] [<ffffffff81681093>] spin_dump+0x8c/0x91 [ 4723.424979] [<ffffffff816810b9>] spin_bug+0x21/0x26 [ 4723.425846] [<ffffffff81323956>] do_raw_spin_unlock+0x66/0x90 [ 4723.434424] [<ffffffff81689bf7>] _raw_spin_unlock+0x27/0x40 [ 4723.438747] [<ffffffffa015da9e>] btrfs_cleanup_one_transaction+0x35e/0x710 [btrfs] [ 4723.443321] [<ffffffffa015df54>] btrfs_cleanup_transaction+0x104/0x570 [btrfs] [ 4723.444692] [<ffffffff810c1b5d>] ? trace_hardirqs_on_caller+0xfd/0x1c0 [ 4723.450336] [<ffffffff810c1c2d>] ? trace_hardirqs_on+0xd/0x10 [ 4723.451332] [<ffffffffa015e5ee>] transaction_kthread+0x22e/0x270 [btrfs] [ 4723.452543] [<ffffffffa015e3c0>] ? btrfs_cleanup_transaction+0x570/0x570 [btrfs] [ 4723.457833] [<ffffffff81079efa>] kthread+0xea/0xf0 [ 4723.458990] [<ffffffff81079e10>] ? kthread_create_on_node+0x140/0x140 [ 4723.460133] [<ffffffff81692aac>] ret_from_fork+0x7c/0xb0 [ 4723.460865] [<ffffffff81079e10>] ? kthread_create_on_node+0x140/0x140 [ 4723.496521] ------------[ cut here ]------------ ---------------------------------------------------------------------- The reason is that we get to call cond_resched_lock(&head_ref->lock) while still holding @delayed_refs->lock. So it's different with __btrfs_run_delayed_refs(), where we do drop-acquire dance before and after actually processing delayed refs. Here we don't drop the lock, others are not able to add new delayed refs to head_ref, so cond_resched_lock(&head_ref->lock) is not necessary here. Signed-off-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-14Revert "btrfs: add ioctl to export size of global metadata reservation"Chris Mason
This reverts commit 01e219e8069516cdb98594d417b8bb8d906ed30d. David Sterba found a different way to provide these features without adding a new ioctl. We haven't released any progs with this ioctl yet, so I'm taking this out for now until we finalize things. Signed-off-by: Chris Mason <clm@fb.com> Signed-off-by: David Sterba <dsterba@suse.cz> CC: Jeff Mahoney <jeffm@suse.com>
2014-02-14Merge branch 'for-3.14' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull two nfsd bugfixes from Bruce Fields. * 'for-3.14' of git://linux-nfs.org/~bfields/linux: lockd: send correct lock when granting a delayed lock. nfsd4: fix acl buffer overrun
2014-02-14Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block IO fixes from Jens Axboe: "Second round of updates and fixes for 3.14-rc2. Most of this stuff has been queued up for a while. The notable exception is the blk-mq changes, which are naturally a bit more in flux still. The pull request contains: - Two bug fixes for the new immutable vecs, causing crashes with raid or swap. From Kent. - Various blk-mq tweaks and fixes from Christoph. A fix for integrity bio's from Nic. - A few bcache fixes from Kent and Darrick Wong. - xen-blk{front,back} fixes from David Vrabel, Matt Rushton, Nicolas Swenson, and Roger Pau Monne. - Fix for a vec miscount with integrity vectors from Martin. - Minor annotations or fixes from Masanari Iida and Rashika Kheria. - Tweak to null_blk to do more normal FIFO processing of requests from Shlomo Pongratz. - Elevator switching bypass fix from Tejun. - Softlockup in blkdev_issue_discard() fix when !CONFIG_PREEMPT from me" * 'for-linus' of git://git.kernel.dk/linux-block: (31 commits) block: add cond_resched() to potentially long running ioctl discard loop xen-blkback: init persistent_purge_work work_struct blk-mq: pair blk_mq_start_request / blk_mq_requeue_request blk-mq: dont assume rq->errors is set when returning an error from ->queue_rq block: Fix cloning of discard/write same bios block: Fix type mismatch in ssize_t_blk_mq_tag_sysfs_show blk-mq: rework flush sequencing logic null_blk: use blk_complete_request and blk_mq_complete_request virtio_blk: use blk_mq_complete_request blk-mq: rework I/O completions fs: Add prototype declaration to appropriate header file include/linux/bio.h fs: Mark function as static in fs/bio-integrity.c block/null_blk: Fix completion processing from LIFO to FIFO block: Explicitly handle discard/write same segments block: Fix nr_vecs for inline integrity vectors blk-mq: Add bio_integrity setup to blk_mq_make_request blk-mq: initialize sg_reserved_size blk-mq: handle dma_drain_size blk-mq: divert __blk_put_request for MQ ops blk-mq: support at_head inserations for blk_execute_rq ...
2014-02-13jfs: set i_ctime when setting ACLDave Kleikamp
This fixes a regression in 3.14-rc1 where xfstests generic/307 fails. jfs sets the ctime on the inode when writing an xattr. Previously, jfs went ahead and stored an acl that can be completely represented in the traditional permission bits, so the ctime was always set in the xattr code. The new code doesn't bother storing the acl in that case, thus the ctime isn't getting set. Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Reported-by: Michael L. Semon <mlsemon35@gmail.com>
2014-02-13lockd: send correct lock when granting a delayed lock.NeilBrown
If an NFS client attempts to get a lock (using NLM) and the lock is not available, the server will remember the request and when the lock becomes available it will send a GRANT request to the client to provide the lock. If the client already held an adjacent lock, the GRANT callback will report the union of the existing and new locks, which can confuse the client. This happens because __posix_lock_file (called by vfs_lock_file) updates the passed-in file_lock structure when adjacent or over-lapping locks are found. To avoid this problem we take a copy of the two fields that can be changed (fl_start and fl_end) before the call and restore them afterwards. An alternate would be to allocate a 'struct file_lock', initialise it, use locks_copy_lock() to take a copy, then locks_release_private() after the vfs_lock_file() call. But that is a lot more work. Reported-by: Olaf Kirch <okir@suse.com> Signed-off-by: NeilBrown <neilb@suse.de> Cc: stable@vger.kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com> -- v1 had a couple of issues (large on-stack struct and didn't really work properly). This version is much better tested. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2014-02-12ext4: don't try to modify s_flags if the the file system is read-onlyTheodore Ts'o
If an ext4 file system is created by some tool other than mke2fs (perhaps by someone who has a pathalogical fear of the GPL) that doesn't set one or the other of the EXT2_FLAGS_{UN}SIGNED_HASH flags, and that file system is then mounted read-only, don't try to modify the s_flags field. Otherwise, if dm_verity is in use, the superblock will change, causing an dm_verity failure. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@vger.kernel.org
2014-02-12ext4: fix error paths in swap_inode_boot_loader() Zheng Liu
In swap_inode_boot_loader() we forgot to release ->i_mutex and resume unlocked dio for inode and inode_bl if there is an error starting the journal handle. This commit fixes this issue. Reported-by: Ahmed Tamrawi <ahmedtamrawi@gmail.com> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Dr. Tilmann Bubeck <t.bubeck@reinform.de> Signed-off-by: Zheng Liu <wenqing.lz@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@vger.kernel.org # v3.10+
2014-02-12ext4: fix xfstest generic/299 block validity failuresEric Whitney
Commit a115f749c1 (ext4: remove wait for unwritten extent conversion from ext4_truncate) exposed a bug in ext4_ext_handle_uninitialized_extents(). It can be triggered by xfstest generic/299 when run on a test file system created without a journal. This test continuously fallocates and truncates files to which random dio/aio writes are simultaneously performed by a separate process. The test completes successfully, but if the test filesystem is mounted with the block_validity option, a warning message stating that a logical block has been mapped to an illegal physical block is posted in the kernel log. The bug occurs when an extent is being converted to the written state by ext4_end_io_dio() and ext4_ext_handle_uninitialized_extents() discovers a mapping for an existing uninitialized extent. Although it sets EXT4_MAP_MAPPED in map->m_flags, it fails to set map->m_pblk to the discovered physical block number. Because map->m_pblk is not otherwise initialized or set by this function or its callers, its uninitialized value is returned to ext4_map_blocks(), where it is stored as a bogus mapping in the extent status tree. Since map->m_pblk can accidentally contain illegal values that are larger than the physical size of the file system, calls to check_block_validity() in ext4_map_blocks() that are enabled if the block_validity mount option is used can fail, resulting in the logged warning message. Signed-off-by: Eric Whitney <enwlinux@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@vger.kernel.org # 3.11+
2014-02-11nfsd4: fix acl buffer overrunJ. Bruce Fields
4ac7249ea5a0ceef9f8269f63f33cc873c3fac61 "nfsd: use get_acl and ->set_acl" forgets to set the size in the case get_acl() succeeds, so _posix_to_nfsv4_one() can then write past the end of its allocation. Symptoms were slab corruption warnings. Also, some minor cleanup while we're here. (Among other things, note that the first few lines guarantee that pacl is non-NULL.) Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2014-02-11block: Fix cloning of discard/write same biosKent Overstreet
Immutable biovecs changed the way bio segments are treated in such a way that bio_for_each_segment() cannot now do what we want for discard/write same bios, since bi_size means something completely different for them. Fortunately discard and write same bios never have more than a single biovec, so bio_for_each_segment() is unnecessary and not terribly meaningful for them, but we still have to special case them in a few places. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Tested-by: Richard W.M. Jones <rjones@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-02-10Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge misc fixes from Andrew Morton: "A bunch of fixes" * emailed patches fron Andrew Morton <akpm@linux-foundation.org>: ocfs2: check existence of old dentry in ocfs2_link() ocfs2: update inode size after zeroing the hole ocfs2: fix issue that ocfs2_setattr() does not deal with new_i_size==i_size mm/memory-failure.c: move refcount only in !MF_COUNT_INCREASED smp.h: fix x86+cpu.c sparse warnings about arch nonboot CPU calls mm: fix page leak at nfs_symlink() slub: do not assert not having lock in removing freed partial gitignore: add all.config ocfs2: fix ocfs2_sync_file() if filesystem is readonly drivers/edac/edac_mc_sysfs.c: poll timeout cannot be zero fs/file.c:fdtable: avoid triggering OOMs from alloc_fdmem xen: properly account for _PAGE_NUMA during xen pte translations mm/slub.c: list_lock may not be held in some circumstances drivers/md/bcache/extents.c: use %zi to format size_t vmcore: prevent PT_NOTE p_memsz overflow during header update drivers/message/i2o/i2o_config.c: fix deadlock in compat_ioctl(I2OGETIOPS) Documentation/: update 00-INDEX files checkpatch: fix detection of git repository get_maintainer: fix detection of git repository drivers/misc/sgi-gru/grukdump.c: unlocking should be conditional in gru_dump_context()
2014-02-10ocfs2: check existence of old dentry in ocfs2_link()Xue jiufei
System call linkat first calls user_path_at(), check the existence of old dentry, and then calls vfs_link()->ocfs2_link() to do the actual work. There may exist a race when Node A create a hard link for file while node B rm it. Node A Node B user_path_at() ->ocfs2_lookup(), find old dentry exist rm file, add inode say inodeA to orphan_dir call ocfs2_link(),create a hard link for inodeA. rm the link, add inodeA to orphan_dir again When orphan_scan work start, it calls ocfs2_queue_orphans() to do the main work. It first tranverses entrys in orphan_dir, linking all inodes in this orphan_dir to a list look like this: inodeA->inodeB->...->inodeA When tranvering this list, it will fall into loop, calling iput() again and again. And finally trigger BUG_ON(inode->i_state & I_CLEAR). Signed-off-by: joyce <xuejiufei@huawei.com> Reviewed-by: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-10ocfs2: update inode size after zeroing the holeJunxiao Bi
fs-writeback will release the dirty pages without page lock whose offset are over inode size, the release happens at block_write_full_page_endio(). If not update, dirty pages in file holes may be released before flushed to the disk, then file holes will contain some non-zero data, this will cause sparse file md5sum error. To reproduce the bug, find a big sparse file with many holes, like vm image file, its actual size should be bigger than available mem size to make writeback work more frequently, tar it with -S option, then keep untar it and check its md5sum again and again until you get a wrong md5sum. Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com> Cc: Younger Liu <younger.liu@huawei.com> Reviewed-by: Mark Fasheh <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-10ocfs2: fix issue that ocfs2_setattr() does not deal with new_i_size==i_sizeYounger Liu
The issue scenario is as following: - Create a small file and fallocate a large disk space for a file with FALLOC_FL_KEEP_SIZE option. - ftruncate the file back to the original size again. but the disk free space is not changed back. This is a real bug that be fixed in this patch. In order to solve the issue above, we modified ocfs2_setattr(), if attr->ia_size != i_size_read(inode), It calls ocfs2_truncate_file(), and truncate disk space to attr->ia_size. Signed-off-by: Younger Liu <younger.liu@huawei.com> Reviewed-by: Jie Liu <jeff.liu@oracle.com> Tested-by: Jie Liu <jeff.liu@oracle.com> Cc: Joel Becker <jlbec@evilplan.org> Reviewed-by: Mark Fasheh <mfasheh@suse.de> Cc: Sunil Mushran <sunil.mushran@gmail.com> Reviewed-by: Jensen <shencanquan@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-10mm: fix page leak at nfs_symlink()Rafael Aquini
Changes in commit a0b8cab3b9b2 ("mm: remove lru parameter from __pagevec_lru_add and remove parts of pagevec API") have introduced a call to add_to_page_cache_lru() which causes a leak in nfs_symlink() as now the page gets an extra refcount that is not dropped. Jan Stancek observed and reported the leak effect while running test8 from Connectathon Testsuite. After several iterations over the test case, which creates several symlinks on a NFS mountpoint, the test system was quickly getting into an out-of-memory scenario. This patch fixes the page leak by dropping that extra refcount add_to_page_cache_lru() is grabbing. Signed-off-by: Jan Stancek <jstancek@redhat.com> Signed-off-by: Rafael Aquini <aquini@redhat.com> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Cc: Jeff Layton <jlayton@redhat.com> Cc: Trond Myklebust <trond.myklebust@primarydata.com> Cc: <stable@vger.kernel.org> [3.11.x+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-10ocfs2: fix ocfs2_sync_file() if filesystem is readonlyYounger Liu
If filesystem is readonly, there is no need to flush drive's caches or force any uncommitted transactions. [akpm@linux-foundation.org: return -EROFS, not 0] Signed-off-by: Younger Liu <younger.liucn@gmail.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
