path: root/fs
2013-10-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "This is a small collection of fixes, including a regression fix from Liu Bo that solves rare crashes with compression on. I've merged my for-linus up to 3.12-rc3 because the top commit is only meant for 3.12. The rest of the fixes are also available in my master branch on top of my last 3.11 based pull" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: btrfs: Fix crash due to not allocating integrity data for a bioset Btrfs: fix a use-after-free bug in btrfs_dev_replace_finishing Btrfs: eliminate races in worker stopping code Btrfs: fix crash of compressed writes Btrfs: fix transid verify errors when recovering log tree
2013-10-05btrfs: Fix crash due to not allocating integrity data for a biosetDarrick J. Wong
When btrfs creates a bioset, we must also allocate the integrity data pool. Otherwise btrfs will crash when it tries to submit a bio to a checksumming disk: BUG: unable to handle kernel NULL pointer dereference at 0000000000000018 IP: [<ffffffff8111e28a>] mempool_alloc+0x4a/0x150 PGD 2305e4067 PUD 23063d067 PMD 0 Oops: 0000 [#1] PREEMPT SMP Modules linked in: btrfs scsi_debug xfs ext4 jbd2 ext3 jbd mbcache sch_fq_codel eeprom lpc_ich mfd_core nfsd exportfs auth_rpcgss af_packet raid6_pq xor zlib_deflate libcrc32c [last unloaded: scsi_debug] CPU: 1 PID: 4486 Comm: mount Not tainted 3.12.0-rc1-mcsum #2 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 task: ffff8802451c9720 ti: ffff880230698000 task.ti: ffff880230698000 RIP: 0010:[<ffffffff8111e28a>] [<ffffffff8111e28a>] mempool_alloc+0x4a/0x150 RSP: 0018:ffff880230699688 EFLAGS: 00010286 RAX: 0000000000000001 RBX: 0000000000000000 RCX: 00000000005f8445 RDX: 0000000000000001 RSI: 0000000000000010 RDI: 0000000000000000 RBP: ffff8802306996f8 R08: 0000000000011200 R09: 0000000000000008 R10: 0000000000000020 R11: ffff88009d6e8000 R12: 0000000000011210 R13: 0000000000000030 R14: ffff8802306996b8 R15: ffff8802451c9720 FS: 00007f25b8a16800(0000) GS:ffff88024fc80000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000000018 CR3: 0000000230576000 CR4: 00000000000007e0 Stack: ffff8802451c9720 0000000000000002 ffffffff81a97100 0000000000281250 ffffffff81a96480 ffff88024fc99150 ffff880228d18200 0000000000000000 0000000000000000 0000000000000040 ffff880230e8c2e8 ffff8802459dc900 Call Trace: [<ffffffff811b2208>] bio_integrity_alloc+0x48/0x1b0 [<ffffffff811b26fc>] bio_integrity_prep+0xac/0x360 [<ffffffff8111e298>] ? mempool_alloc+0x58/0x150 [<ffffffffa03e8041>] ? alloc_extent_state+0x31/0x110 [btrfs] [<ffffffff81241579>] blk_queue_bio+0x1c9/0x460 [<ffffffff8123e58a>] generic_make_request+0xca/0x100 [<ffffffff8123e639>] submit_bio+0x79/0x160 [<ffffffffa03f865e>] btrfs_map_bio+0x48e/0x5b0 [btrfs] [<ffffffffa03c821a>] btree_submit_bio_hook+0xda/0x110 [btrfs] [<ffffffffa03e7eba>] submit_one_bio+0x6a/0xa0 [btrfs] [<ffffffffa03ef450>] read_extent_buffer_pages+0x250/0x310 [btrfs] [<ffffffff8125eef6>] ? __radix_tree_preload+0x66/0xf0 [<ffffffff8125f1c5>] ? radix_tree_insert+0x95/0x260 [<ffffffffa03c66f6>] btree_read_extent_buffer_pages.constprop.128+0xb6/0x120 [btrfs] [<ffffffffa03c8c1a>] read_tree_block+0x3a/0x60 [btrfs] [<ffffffffa03caefd>] open_ctree+0x139d/0x2030 [btrfs] [<ffffffffa03a282a>] btrfs_mount+0x53a/0x7d0 [btrfs] [<ffffffff8113ab0b>] ? pcpu_alloc+0x8eb/0x9f0 [<ffffffff81167305>] ? __kmalloc_track_caller+0x35/0x1e0 [<ffffffff81176ba0>] mount_fs+0x20/0xd0 [<ffffffff81191096>] vfs_kern_mount+0x76/0x120 [<ffffffff81193320>] do_mount+0x200/0xa40 [<ffffffff81135cdb>] ? strndup_user+0x5b/0x80 [<ffffffff81193bf0>] SyS_mount+0x90/0xe0 [<ffffffff8156d31d>] system_call_fastpath+0x1a/0x1f Code: 4c 8d 75 a8 4c 89 6d e8 45 89 e0 4c 8d 6f 30 48 89 5d d8 41 83 e0 af 48 89 fb 49 83 c6 18 4c 89 7d f8 65 4c 8b 3c 25 c0 b8 00 00 <48> 8b 73 18 44 89 c7 44 89 45 98 ff 53 20 48 85 c0 48 89 c2 74 RIP [<ffffffff8111e28a>] mempool_alloc+0x4a/0x150 RSP <ffff880230699688> CR2: 0000000000000018 ---[ end trace 7a96042017ed21e2 ]--- Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-10-05Merge branch 'for-linus' into for-linus-3.12Chris Mason
2013-10-04Merge branch 'for-linus' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull CIFS fixes from Steve French: "Small set of cifs fixes. Most important is Jeff's fix that works around disconnection problems which can be caused by simultaneous use of user space tools (starting a long running smbclient backup then doing a cifs kernel mount) or multiple cifs mounts through a NAT, and Jim's fix to deal with reexport of cifs share. I expect to send two more cifs fixes next week (being tested now) - fixes to address an SMB2 unmount hang when server dies and a fix for cifs symlink handling of Windows "NFS" symlinks" * 'for-linus' of git://git.samba.org/sfrench/cifs-2.6: [CIFS] update cifs.ko version [CIFS] Remove ext2 flags that have been moved to fs.h [CIFS] Provide sane values for nlink cifs: stop trying to use virtual circuits CIFS: FS-Cache: Uncache unread pages in cifs_readpages() before freeing them
2013-10-04Merge tag 'xfs-for-linus-v3.12-rc4' of git://oss.sgi.com/xfs/xfsLinus Torvalds
Pull xfs bugfixes from Ben Myers: "There are lockdep annotations for project quotas, a fix for dirent dtype support on v4 filesystems, a fix for a memory leak in recovery, and a fix for the build error that resulted from it. D'oh" * tag 'xfs-for-linus-v3.12-rc4' of git://oss.sgi.com/xfs/xfs: xfs: Use kmem_free() instead of free() xfs: fix memory leak in xlog_recover_add_to_trans xfs: dirent dtype presence is dependent on directory magic numbers xfs: lockdep needs to know about 3 dquot-deep nesting
2013-10-04Btrfs: fix a use-after-free bug in btrfs_dev_replace_finishingIlya Dryomov
free_device rcu callback, scheduled from btrfs_rm_dev_replace_srcdev, can be processed before btrfs_scratch_superblock is called, which would result in a use-after-free on btrfs_device contents. Fix this by zeroing the superblock before the rcu callback is registered. Cc: Stefan Behrens <sbehrens@giantdisaster.de> Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-10-04Btrfs: eliminate races in worker stopping codeIlya Dryomov
The current implementation of worker threads in Btrfs has races in worker stopping code, which cause all kinds of panics and lockups when running btrfs/011 xfstest in a loop. The problem is that btrfs_stop_workers is unsynchronized with respect to check_idle_worker, check_busy_worker and __btrfs_start_workers. E.g., check_idle_worker race flow: btrfs_stop_workers(): check_idle_worker(aworker): - grabs the lock - splices the idle list into the working list - removes the first worker from the working list - releases the lock to wait for its kthread's completion - grabs the lock - if aworker is on the working list, moves aworker from the working list to the idle list - releases the lock - grabs the lock - puts the worker - removes the second worker from the working list ...... btrfs_stop_workers returns, aworker is on the idle list FS is umounted, memory is freed ...... aworker is waken up, fireworks ensue With this applied, I wasn't able to trigger the problem in 48 hours, whereas previously I could reliably reproduce at least one of these races within an hour. Reported-by: David Sterba <dsterba@suse.cz> Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-10-04Btrfs: fix crash of compressed writesLiu Bo
The crash[1] is found by xfstests/generic/208 with "-o compress", it's not reproduced everytime, but it does panic. The bug is quite interesting, it's actually introduced by a recent commit (573aecafca1cf7a974231b759197a1aebcf39c2a, Btrfs: actually limit the size of delalloc range). Btrfs implements delay allocation, so during writeback, we (1) get a page A and lock it (2) search the state tree for delalloc bytes and lock all pages within the range (3) process the delalloc range, including find disk space and create ordered extent and so on. (4) submit the page A. It runs well in normal cases, but if we're in a racy case, eg. buffered compressed writes and aio-dio writes, sometimes we may fail to lock all pages in the 'delalloc' range, in which case, we need to fall back to search the state tree again with a smaller range limit(max_bytes = PAGE_CACHE_SIZE - offset). The mentioned commit has a side effect, that is, in the fallback case, we can find delalloc bytes before the index of the page we already have locked, so we're in the case of (delalloc_end <= *start) and return with (found > 0). This ends with not locking delalloc pages but making ->writepage still process them, and the crash happens. This fixes it by just thinking that we find nothing and returning to caller as the caller knows how to deal with it properly. [1]: ------------[ cut here ]------------ kernel BUG at mm/page-writeback.c:2170! [...] CPU: 2 PID: 11755 Comm: btrfs-delalloc- Tainted: G O 3.11.0+ #8 [...] RIP: 0010:[<ffffffff810f5093>] [<ffffffff810f5093>] clear_page_dirty_for_io+0x1e/0x83 [...] [ 4934.248731] Stack: [ 4934.248731] ffff8801477e5dc8 ffffea00049b9f00 ffff8801869f9ce8 ffffffffa02b841a [ 4934.248731] 0000000000000000 0000000000000000 0000000000000fff 0000000000000620 [ 4934.248731] ffff88018db59c78 ffffea0005da8d40 ffffffffa02ff860 00000001810016c0 [ 4934.248731] Call Trace: [ 4934.248731] [<ffffffffa02b841a>] extent_range_clear_dirty_for_io+0xcf/0xf5 [btrfs] [ 4934.248731] [<ffffffffa02a8889>] compress_file_range+0x1dc/0x4cb [btrfs] [ 4934.248731] [<ffffffff8104f7af>] ? detach_if_pending+0x22/0x4b [ 4934.248731] [<ffffffffa02a8bad>] async_cow_start+0x35/0x53 [btrfs] [ 4934.248731] [<ffffffffa02c694b>] worker_loop+0x14b/0x48c [btrfs] [ 4934.248731] [<ffffffffa02c6800>] ? btrfs_queue_worker+0x25c/0x25c [btrfs] [ 4934.248731] [<ffffffff810608f5>] kthread+0x8d/0x95 [ 4934.248731] [<ffffffff81060868>] ? kthread_freezable_should_stop+0x43/0x43 [ 4934.248731] [<ffffffff814fe09c>] ret_from_fork+0x7c/0xb0 [ 4934.248731] [<ffffffff81060868>] ? kthread_freezable_should_stop+0x43/0x43 [ 4934.248731] Code: ff 85 c0 0f 94 c0 0f b6 c0 59 5b 5d c3 0f 1f 44 00 00 55 48 89 e5 41 54 53 48 89 fb e8 2c de 00 00 49 89 c4 48 8b 03 a8 01 75 02 <0f> 0b 4d 85 e4 74 52 49 8b 84 24 80 00 00 00 f6 40 20 01 75 44 [ 4934.248731] RIP [<ffffffff810f5093>] clear_page_dirty_for_io+0x1e/0x83 [ 4934.248731] RSP <ffff8801869f9c48> [ 4934.280307] ---[ end trace 36f06d3f8750236a ]--- Signed-off-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-10-04Btrfs: fix transid verify errors when recovering log treeJosef Bacik
If we crash with a log, remount and recover that log, and then crash before we can commit another transaction we will get transid verify errors on the next mount. This is because we were not zero'ing out the log when we committed the transaction after recovery. This is ok as long as we commit another transaction at some point in the future, but if you abort or something else goes wrong you can end up in this weird state because the recovery stuff says that the tree log should have a generation+1 of the super generation, which won't be the case of the transaction that was started for recovery. Fix this by removing the check and _always_ zero out the log portion of the super when we commit a transaction. This fixes the transid verify issues I was seeing with my force errors tests. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-10-04xfs: Use kmem_free() instead of free()Thierry Reding
This fixes a build failure caused by calling the free() function which does not exist in the Linux kernel. Signed-off-by: Thierry Reding <treding@nvidia.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit aaaae98022efa4f3c31042f1fdf9e7a0c5f04663)
2013-10-04xfs: fix memory leak in xlog_recover_add_to_transtinguely@sgi.com
Free the memory in error path of xlog_recover_add_to_trans(). Normally this memory is freed in recovery pass2, but is leaked in the error path. Signed-off-by: Mark Tinguely <tinguely@sgi.com> Reviewed-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit 519ccb81ac1c8e3e4eed294acf93be00b43dcad6)
2013-10-04xfs: dirent dtype presence is dependent on directory magic numbersDave Chinner
The determination of whether a directory entry contains a dtype field originally was dependent on the filesystem having CRCs enabled. This meant that the format for dtype beign enabled could be determined by checking the directory block magic number rather than doing a feature bit check. This was useful in that it meant that we didn't need to pass a struct xfs_mount around to functions that were already supplied with a directory block header. Unfortunately, the introduction of dtype fields into the v4 structure via a feature bit meant this "use the directory block magic number" method of discriminating the dirent entry sizes is broken. Hence we need to convert the places that use magic number checks to use feature bit checks so that they work correctly and not by chance. The current code works on v4 filesystems only because the dirent size roundup covers the extra byte needed by the dtype field in the places where this problem occurs. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit 367993e7c6428cb7617ab7653d61dca54e2fdede)
2013-10-04xfs: lockdep needs to know about 3 dquot-deep nestingDave Chinner
Michael Semon reported that xfs/299 generated this lockdep warning: ============================================= [ INFO: possible recursive locking detected ] 3.12.0-rc2+ #2 Not tainted --------------------------------------------- touch/21072 is trying to acquire lock: (&xfs_dquot_other_class){+.+...}, at: [<c12902fb>] xfs_trans_dqlockedjoin+0x57/0x64 but task is already holding lock: (&xfs_dquot_other_class){+.+...}, at: [<c12902fb>] xfs_trans_dqlockedjoin+0x57/0x64 other info that might help us debug this: Possible unsafe locking scenario: CPU0 ---- lock(&xfs_dquot_other_class); lock(&xfs_dquot_other_class); *** DEADLOCK *** May be due to missing lock nesting notation 7 locks held by touch/21072: #0: (sb_writers#10){++++.+}, at: [<c11185b6>] mnt_want_write+0x1e/0x3e #1: (&type->i_mutex_dir_key#4){+.+.+.}, at: [<c11078ee>] do_last+0x245/0xe40 #2: (sb_internal#2){++++.+}, at: [<c122c9e0>] xfs_trans_alloc+0x1f/0x35 #3: (&(&ip->i_lock)->mr_lock/1){+.+...}, at: [<c126cd1b>] xfs_ilock+0x100/0x1f1 #4: (&(&ip->i_lock)->mr_lock){++++-.}, at: [<c126cf52>] xfs_ilock_nowait+0x105/0x22f #5: (&dqp->q_qlock){+.+...}, at: [<c12902fb>] xfs_trans_dqlockedjoin+0x57/0x64 #6: (&xfs_dquot_other_class){+.+...}, at: [<c12902fb>] xfs_trans_dqlockedjoin+0x57/0x64 The lockdep annotation for dquot lock nesting only understands locking for user and "other" dquots, not user, group and quota dquots. Fix the annotations to match the locking heirarchy we now have. Reported-by: Michael L. Semon <mlsemon35@gmail.com> Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit f112a049712a5c07de25d511c3c6587a2b1a015e)
2013-10-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse Pull fuse bugfixes from Miklos Szeredi: "This contains two more fixes by Maxim for writeback/truncate races and fixes for RCU walk in fuse_dentry_revalidate()" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: no RCU mode in fuse_access() fuse: readdirplus: fix RCU walk fuse: don't check_submounts_and_drop() in RCU walk fuse: fix fallocate vs. ftruncate race fuse: wait for writeback in fuse_file_fallocate()
2013-10-02Merge git://git.kvack.org/~bcrl/aio-nextLinus Torvalds
Pull aio use-after-free fix from Ben LaHaise. * git://git.kvack.org/~bcrl/aio-next: aio: fix use-after-free in aio_migratepage
2013-10-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs lru leak fix from Al Viro: "The fix in "super: fix for destroy lrus" didn't - they need to be destroyed, all right, but that's the wrong place..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fs/super.c: fix lru_list leak for real
2013-10-01fs/super.c: fix lru_list leak for realAl Viro
Freeing ->s_{inode,dentry}_lru in deactivate_locked_super() is wrong; the right place is destroy_super(). As it is, we leak them if sget() decides that new superblock it has allocated (and never shown to anybody) isn't needed and should be freed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-10-01fuse: no RCU mode in fuse_access()Miklos Szeredi
fuse_access() is never called in RCU walk, only on the final component of access(2) and chdir(2)... Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-10-01fuse: readdirplus: fix RCU walkMiklos Szeredi
Doing dput(parent) is not valid in RCU walk mode. In RCU mode it would probably be okay to update the parent flags, but it's actually not necessary most of the time... So only set the FUSE_I_ADVISE_RDPLUS flag on the parent when the entry was recently initialized by READDIRPLUS. This is achieved by setting FUSE_I_INIT_RDPLUS on entries added by READDIRPLUS and only dropping out of RCU mode if this flag is set. FUSE_I_INIT_RDPLUS is cleared once the FUSE_I_ADVISE_RDPLUS flag is set in the parent. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: stable@vger.kernel.org
2013-10-01fuse: don't check_submounts_and_drop() in RCU walkMiklos Szeredi
If revalidate finds an invalid dentry in RCU walk mode, let the VFS deal with it instead of calling check_submounts_and_drop() which is not prepared for being called from RCU walk. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: stable@vger.kernel.org
2013-09-30Merge tag 'nfs-for-3.12-4' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: - Stable fix for Oopses in the pNFS files layout driver - Fix a regression when doing a non-exclusive file create on NFSv4.x - NFSv4.1 security negotiation fixes when looking up the root filesystem - Fix a memory ordering issue in the pNFS files layout driver * tag 'nfs-for-3.12-4' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: NFS: Give "flavor" an initial value to fix a compile warning NFSv4.1: try SECINFO_NO_NAME flavs until one works NFSv4.1: Ensure memory ordering between nfs4_ds_connect and nfs4_fl_prepare_ds NFSv4.1: nfs4_fl_prepare_ds - fix bugs when the connect attempt fails NFSv4: Honour the 'opened' parameter in the atomic_open() filesystem method
2013-09-30Merge branch 'akpm' (fixes from Andrew Morton)Linus Torvalds
Merge misc fixes from Andrew Morton. * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (22 commits) pidns: fix free_pid() to handle the first fork failure ipc,msg: prevent race with rmid in msgsnd,msgrcv ipc/sem.c: update sem_otime for all operations mm/hwpoison: fix the lack of one reference count against poisoned page mm/hwpoison: fix false report on 2nd attempt at page recovery mm/hwpoison: fix test for a transparent huge page mm/hwpoison: fix traversal of hugetlbfs pages to avoid printk flood block: change config option name for cmdline partition parsing mm/mlock.c: prevent walking off the end of a pagetable in no-pmd configuration mm: avoid reinserting isolated balloon pages into LRU lists arch/parisc/mm/fault.c: fix uninitialized variable usage include/asm-generic/vtime.h: avoid zero-length file nilfs2: fix issue with race condition of competition between segments for dirty blocks Documentation/kernel-parameters.txt: replace kernelcore with Movable mm/bounce.c: fix a regression where MS_SNAP_STABLE (stable pages snapshotting) was ignored kernel/kmod.c: check for NULL in call_usermodehelper_exec() ipc/sem.c: synchronize the proc interface ipc/sem.c: optimize sem_lock() ipc/sem.c: fix race in sem_lock() mm/compaction.c: periodically schedule when freeing pages ...
2013-09-30nilfs2: fix issue with race condition of competition between segments for ↵Vyacheslav Dubeyko
dirty blocks Many NILFS2 users were reported about strange file system corruption (for example): NILFS: bad btree node (blocknr=185027): level = 0, flags = 0x0, nchildren = 768 NILFS error (device sda4): nilfs_bmap_last_key: broken bmap (inode number=11540) But such error messages are consequence of file system's issue that takes place more earlier. Fortunately, Jerome Poulin <jeromepoulin@gmail.com> and Anton Eliasson <devel@antoneliasson.se> were reported about another issue not so recently. These reports describe the issue with segctor thread's crash: BUG: unable to handle kernel paging request at 0000000000004c83 IP: nilfs_end_page_io+0x12/0xd0 [nilfs2] Call Trace: nilfs_segctor_do_construct+0xf25/0x1b20 [nilfs2] nilfs_segctor_construct+0x17b/0x290 [nilfs2] nilfs_segctor_thread+0x122/0x3b0 [nilfs2] kthread+0xc0/0xd0 ret_from_fork+0x7c/0xb0 These two issues have one reason. This reason can raise third issue too. Third issue results in hanging of segctor thread with eating of 100% CPU. REPRODUCING PATH: One of the possible way or the issue reproducing was described by Jermoe me Poulin <jeromepoulin@gmail.com>: 1. init S to get to single user mode. 2. sysrq+E to make sure only my shell is running 3. start network-manager to get my wifi connection up 4. login as root and launch "screen" 5. cd /boot/log/nilfs which is a ext3 mount point and can log when NILFS dies. 6. lscp | xz -9e > lscp.txt.xz 7. mount my snapshot using mount -o cp=3360839,ro /dev/vgUbuntu/root /mnt/nilfs 8. start a screen to dump /proc/kmsg to text file since rsyslog is killed 9. start a screen and launch strace -f -o find-cat.log -t find /mnt/nilfs -type f -exec cat {} > /dev/null \; 10. start a screen and launch strace -f -o apt-get.log -t apt-get update 11. launch the last command again as it did not crash the first time 12. apt-get crashes 13. ps aux > ps-aux-crashed.log 13. sysrq+W 14. sysrq+E wait for everything to terminate 15. sysrq+SUSB Simplified way of the issue reproducing is starting kernel compilation task and "apt-get update" in parallel. REPRODUCIBILITY: The issue is reproduced not stable [60% - 80%]. It is very important to have proper environment for the issue reproducing. The critical conditions for successful reproducing: (1) It should have big modified file by mmap() way. (2) This file should have the count of dirty blocks are greater that several segments in size (for example, two or three) from time to time during processing. (3) It should be intensive background activity of files modification in another thread. INVESTIGATION: First of all, it is possible to see that the reason of crash is not valid page address: NILFS [nilfs_segctor_complete_write]:2100 bh->b_count 0, bh->b_blocknr 13895680, bh->b_size 13897727, bh->b_page 0000000000001a82 NILFS [nilfs_segctor_complete_write]:2101 segbuf->sb_segnum 6783 Moreover, value of b_page (0x1a82) is 6786. This value looks like segment number. And b_blocknr with b_size values look like block numbers. So, buffer_head's pointer points on not proper address value. Detailed investigation of the issue is discovered such picture: [-----------------------------SEGMENT 6783-------------------------------] NILFS [nilfs_segctor_do_construct]:2310 nilfs_segctor_begin_construction NILFS [nilfs_segctor_do_construct]:2321 nilfs_segctor_collect NILFS [nilfs_segctor_do_construct]:2336 nilfs_segctor_assign NILFS [nilfs_segctor_do_construct]:2367 nilfs_segctor_update_segusage NILFS [nilfs_segctor_do_construct]:2371 nilfs_segctor_prepare_write NILFS [nilfs_segctor_do_construct]:2376 nilfs_add_checksums_on_logs NILFS [nilfs_segctor_do_construct]:2381 nilfs_segctor_write NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111149024, segbuf->sb_segnum 6783 [-----------------------------SEGMENT 6784-------------------------------] NILFS [nilfs_segctor_do_construct]:2310 nilfs_segctor_begin_construction NILFS [nilfs_segctor_do_construct]:2321 nilfs_segctor_collect NILFS [nilfs_lookup_dirty_data_buffers]:782 bh->b_count 1, bh->b_page ffffea000709b000, page->index 0, i_ino 1033103, i_size 25165824 NILFS [nilfs_lookup_dirty_data_buffers]:783 bh->b_assoc_buffers.next ffff8802174a6798, bh->b_assoc_buffers.prev ffff880221cffee8 NILFS [nilfs_segctor_do_construct]:2336 nilfs_segctor_assign NILFS [nilfs_segctor_do_construct]:2367 nilfs_segctor_update_segusage NILFS [nilfs_segctor_do_construct]:2371 nilfs_segctor_prepare_write NILFS [nilfs_segctor_do_construct]:2376 nilfs_add_checksums_on_logs NILFS [nilfs_segctor_do_construct]:2381 nilfs_segctor_write NILFS [nilfs_segbuf_submit_bh]:575 bh->b_count 1, bh->b_page ffffea000709b000, page->index 0, i_ino 1033103, i_size 25165824 NILFS [nilfs_segbuf_submit_bh]:576 segbuf->sb_segnum 6784 NILFS [nilfs_segbuf_submit_bh]:577 bh->b_assoc_buffers.next ffff880218a0d5f8, bh->b_assoc_buffers.prev ffff880218bcdf50 NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111150080, segbuf->sb_segnum 6784, segbuf->sb_nbio 0 [----------] ditto NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111164416, segbuf->sb_segnum 6784, segbuf->sb_nbio 15 [-----------------------------SEGMENT 6785-------------------------------] NILFS [nilfs_segctor_do_construct]:2310 nilfs_segctor_begin_construction NILFS [nilfs_segctor_do_construct]:2321 nilfs_segctor_collect NILFS [nilfs_lookup_dirty_data_buffers]:782 bh->b_count 2, bh->b_page ffffea000709b000, page->index 0, i_ino 1033103, i_size 25165824 NILFS [nilfs_lookup_dirty_data_buffers]:783 bh->b_assoc_buffers.next ffff880219277e80, bh->b_assoc_buffers.prev ffff880221cffc88 NILFS [nilfs_segctor_do_construct]:2367 nilfs_segctor_update_segusage NILFS [nilfs_segctor_do_construct]:2371 nilfs_segctor_prepare_write NILFS [nilfs_segctor_do_construct]:2376 nilfs_add_checksums_on_logs NILFS [nilfs_segctor_do_construct]:2381 nilfs_segctor_write NILFS [nilfs_segbuf_submit_bh]:575 bh->b_count 2, bh->b_page ffffea000709b000, page->index 0, i_ino 1033103, i_size 25165824 NILFS [nilfs_segbuf_submit_bh]:576 segbuf->sb_segnum 6785 NILFS [nilfs_segbuf_submit_bh]:577 bh->b_assoc_buffers.next ffff880218a0d5f8, bh->b_assoc_buffers.prev ffff880222cc7ee8 NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111165440, segbuf->sb_segnum 6785, segbuf->sb_nbio 0 [----------] ditto NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111177728, segbuf->sb_segnum 6785, segbuf->sb_nbio 12 NILFS [nilfs_segctor_do_construct]:2399 nilfs_segctor_wait NILFS [nilfs_segbuf_wait]:676 segbuf->sb_segnum 6783 NILFS [nilfs_segbuf_wait]:676 segbuf->sb_segnum 6784 NILFS [nilfs_segbuf_wait]:676 segbuf->sb_segnum 6785 NILFS [nilfs_segctor_complete_write]:2100 bh->b_count 0, bh->b_blocknr 13895680, bh->b_size 13897727, bh->b_page 0000000000001a82 BUG: unable to handle kernel paging request at 0000000000001a82 IP: [<ffffffffa024d0f2>] nilfs_end_page_io+0x12/0xd0 [nilfs2] Usually, for every segment we collect dirty files in list. Then, dirty blocks are gathered for every dirty file, prepared for write and submitted by means of nilfs_segbuf_submit_bh() call. Finally, it takes place complete write phase after calling nilfs_end_bio_write() on the block layer. Buffers/pages are marked as not dirty on final phase and processed files removed from the list of dirty files. It is possible to see that we had three prepare_write and submit_bio phases before segbuf_wait and complete_write phase. Moreover, segments compete between each other for dirty blocks because on every iteration of segments processing dirty buffer_heads are added in several lists of payload_buffers: [SEGMENT 6784]: bh->b_assoc_buffers.next ffff880218a0d5f8, bh->b_assoc_buffers.prev ffff880218bcdf50 [SEGMENT 6785]: bh->b_assoc_buffers.next ffff880218a0d5f8, bh->b_assoc_buffers.prev ffff880222cc7ee8 The next pointer is the same but prev pointer has changed. It means that buffer_head has next pointer from one list but prev pointer from another. Such modification can be made several times. And, finally, it can be resulted in various issues: (1) segctor hanging, (2) segctor crashing, (3) file system metadata corruption. FIX: This patch adds: (1) setting of BH_Async_Write flag in nilfs_segctor_prepare_write() for every proccessed dirty block; (2) checking of BH_Async_Write flag in nilfs_lookup_dirty_data_buffers() and nilfs_lookup_dirty_node_buffers(); (3) clearing of BH_Async_Write flag in nilfs_segctor_complete_write(), nilfs_abort_logs(), nilfs_forget_buffer(), nilfs_clear_dirty_page(). Reported-by: Jerome Poulin <jeromepoulin@gmail.com> Reported-by: Anton Eliasson <devel@antoneliasson.se> Cc: Paul Fertser <fercerpav@gmail.com> Cc: ARAI Shun-ichi <hermes@ceres.dti.ne.jp> Cc: Piotr Szymaniak <szarpaj@grubelek.pl> Cc: Juan Barry Manuel Canham <Linux@riotingpacifist.net> Cc: Zahid Chowdhury <zahid.chowdhury@starsolutions.com> Cc: Elmer Zhang <freeboy6716@gmail.com> Cc: Kenneth Langga <klangga@gmail.com> Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-30fs/binfmt_elf.c: prevent a coredump with a large vm_map_count from OopsingDan Aloni
A high setting of max_map_count, and a process core-dumping with a large enough vm_map_count could result in an NT_FILE note not being written, and the kernel crashing immediately later because it has assumed otherwise. Reproduction of the oops-causing bug described here: https://lkml.org/lkml/2013/8/30/50 Rge ussue originated in commit 2aa362c49c31 ("coredump: extend core dump note section to contain file names of mapped file") from Oct 4, 2012. This patch make that section optional in that case. fill_files_note() should signify the error, and also let the info struct in elf_core_dump() be zero-initialized so that we can check for the optionally written note. [akpm@linux-foundation.org: avoid abusing E2BIG, remove a couple of not-really-needed local variables] [akpm@linux-foundation.org: fix sparse warning] Signed-off-by: Dan Aloni <alonid@stratoscale.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Denys Vlasenko <vda.linux@googlemail.com> Reported-by: Martin MOKREJS <mmokrejs@gmail.com> Tested-by: Martin MOKREJS <mmokrejs@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-29afs: dget_parent() can't return a negative dentryAl Viro
2013-09-29ocfs2: needs ->d_lock to poke in ->d_parent->d_inode from ->d_revalidate()Al Viro
2013-09-29sysv: Add forgotten superblock lock init for v7 fsLubomir Rintel
Superblock lock was replaced with (un)lock_super() removal, but left uninitialized for Seventh Edition UNIX filesystem in the following commit (3.7): c07cb01 sysv: drop lock/unlock super Signed-off-by: Lubomir Rintel <lkundrak@v3.sk> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-09-29NFS: Give "flavor" an initial value to fix a compile warningAnna Schumaker
The previous patch introduces a compile warning by not assigning an initial value to the "flavor" variable. This could only be a problem if the server returns a supported secflavor list of length zero, but it's better to fix this before it's ever hit. Signed-off-by: Anna Schumaker <bjschuma@netapp.com> Acked-by: Weston Andros Adamson <dros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-09-29NFSv4.1: try SECINFO_NO_NAME flavs until one worksWeston Andros Adamson
Call nfs4_lookup_root_sec for each flavor returned by SECINFO_NO_NAME until one works. One example of a situation this fixes: - server configured for krb5 - server principal somehow gets deleted from KDC - server still thinking krb is good, sends krb5 as first entry in SECINFO_NO_NAME response - client tries krb5, but this fails without even sending an RPC because gssd's requests to the KDC can't find the server's principal Signed-off-by: Weston Andros Adamson <dros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-09-29NFSv4.1: Ensure memory ordering between nfs4_ds_connect and nfs4_fl_prepare_dsTrond Myklebust
We need to ensure that the initialisation of the data server nfs_client structure in nfs4_ds_connect is correctly ordered w.r.t. the read of ds->ds_clp in nfs4_fl_prepare_ds. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-09-29NFSv4.1: nfs4_fl_prepare_ds - fix bugs when the connect attempt failsTrond Myklebust
- Fix an Oops when nfs4_ds_connect() returns an error. - Always check the device status after waiting for a connect to complete. Reported-by: Andy Adamson <andros@netapp.com> Reported-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: <stable@vger.kernel.org> # v3.10+
2013-09-28Merge tag 'xfs-for-linus-v3.12-rc3' of git://oss.sgi.com/xfs/xfsLinus Torvalds
Pull xfs bugfixes from Ben Myers: - fix for directory node collapse regression - fix for recovery over stale on disk structures - fix for eofblocks ioctl - fix asserts in xfs_inode_free - lock the ail before removing an item from it * tag 'xfs-for-linus-v3.12-rc3' of git://oss.sgi.com/xfs/xfs: xfs: fix node forward in xfs_node_toosmall xfs: log recovery lsn ordering needs uuid check xfs: fix XFS_IOC_FREE_EOFBLOCKS definition xfs: asserting lock not held during freeing not valid xfs: lock the AIL before removing the buffer item
2013-09-27Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull reiserfs and UDF fixes from Jan Kara: "The contains fix of an UDF oops when mounting corrupted media and a fix of a race in reiserfs leading to oops" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: reiserfs: fix race with flush_used_journal_lists and flush_journal_list reiserfs: remove useless flush_old_journal_lists udf: Fortify LVID loading
2013-09-26aio: fix use-after-free in aio_migratepageBenjamin LaHaise
Dmitry Vyukov managed to trigger a case where aio_migratepage can cause a use-after-free during teardown of the aio ring buffer's mapping. This turns out to be caused by access to the ioctx's ring_pages via the migratepage operation which was not being protected by any locks during ioctx freeing. Use the address_space's private_lock to protect use and updates of the mapping's private_data, and make ioctx teardown unlink the ioctx from the address space. Reported-by: Dmitry Vyukov <dvyukov@google.com> Tested-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Benjamin LaHaise <bcrl@kvack.org>
2013-09-26xfs: fix node forward in xfs_node_toosmallMark Tinguely
Commit f5ea1100 cleans up the disk to host conversions for node directory entries, but because a variable is reused in xfs_node_toosmall() the next node is not correctly found. If the original node is small enough (<= 3/8 of the node size), this change may incorrectly cause a node collapse when it should not. That will cause an assert in xfstest generic/319: Assertion failed: first <= last && last < BBTOB(bp->b_length), file: /root/newest/xfs/fs/xfs/xfs_trans_buf.c, line: 569 Keep the original node header to get the correct forward node. (When a node is considered for a merge with a sibling, it overwrites the sibling pointers of the original incore nodehdr with the sibling's pointers. This leads to loop considering the original node as a merge candidate with itself in the second pass, and so it incorrectly determines a merge should occur.) Signed-off-by: Mark Tinguely <tinguely@sgi.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com> [v3: added Dave Chinner's (slightly modified) suggestion to the commit header, cleaned up whitespace. -bpm]
2013-09-26NFSv4: Honour the 'opened' parameter in the atomic_open() filesystem methodTrond Myklebust
Determine if we've created a new file by examining the directory change attribute and/or the O_EXCL flag. This fixes a regression when doing a non-exclusive create of a new file. If the FILE_CREATED flag is not set, the atomic_open() command will perform full file access permissions checks instead of just checking for MAY_OPEN. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-09-25[CIFS] update cifs.ko versionSteve French
To 2.02 Signed-off-by: Steve French <smfrench@gmail.com>
2013-09-25[CIFS] Remove ext2 flags that have been moved to fs.hSteve French
These flags were unused by cifs and since the EXT flags have been moved to common code in uapi/linux/fs.h we won't need to have a cifs specific copy. Signed-off-by: Steve French <smfrench@gmail.com>
2013-09-24Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge fixes from Andrew Morton: "Bunch of fixes. And a reversion of mhocko's "Soft limit rework" patch series. This is actually your fault for opening the merge window when I was off racing ;) I didn't read the email thread before sending everything off. Johannes Weiner raised significant issues: http://www.spinics.net/lists/cgroups/msg08813.html and we agreed to back it all out" I clearly need to be more aware of Andrew's racing schedule. * akpm: MAINTAINERS: update mach-bcm related email address checkpatch: make extern in .h prototypes quieter cciss: fix info leak in cciss_ioctl32_passthru() cpqarray: fix info leak in ida_locked_ioctl() kernel/reboot.c: re-enable the function of variable reboot_default audit: fix endless wait in audit_log_start() revert "memcg, vmscan: integrate soft reclaim tighter with zone shrinking code" revert "memcg: get rid of soft-limit tree infrastructure" revert "vmscan, memcg: do softlimit reclaim also for targeted reclaim" revert "memcg: enhance memcg iterator to support predicates" revert "memcg: track children in soft limit excess to improve soft limit" revert "memcg, vmscan: do not attempt soft limit reclaim if it would not scan anything" revert "memcg: track all children over limit in the root" revert "memcg, vmscan: do not fall into reclaim-all pass too quickly" fs/ocfs2/super.c: use a bigger nodestr in ocfs2_dismount_volume watchdog: update watchdog_thresh properly watchdog: update watchdog attributes atomically
2013-09-24fs/ocfs2/super.c: use a bigger nodestr in ocfs2_dismount_volumeGoldwyn Rodrigues
While printing 32-bit node numbers, an 8-byte string is not enough. Increase the size of the string to 12 chars. This got left out in commit 49fa8140e487 ("fs/ocfs2/super.c: Use bigger nodestr to accomodate 32-bit node numbers"). Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-24block: Fix bio_copy_data()Kent Overstreet
The memcpy() in bio_copy_data() was using the wrong offset vars, leading to data corruption in weird unusual setups. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: linux-stable <stable@vger.kernel.org> # >= v3.9 Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-24xfs: log recovery lsn ordering needs uuid checkDave Chinner
After a fair number of xfstests runs, xfs/182 started to fail regularly with a corrupted directory - a directory read verifier was failing after recovery because it found a block with a XARM magic number (remote attribute block) rather than a directory data block. The first time I saw this repeated failure I did /something/ and the problem went away, so I was never able to find the underlying problem. Test xfs/182 failed again today, and I found the root cause before I did /something else/ that made it go away. Tracing indicated that the block in question was being correctly logged, the log was being flushed by sync, but the buffer was not being written back before the shutdown occurred. Tracing also indicated that log recovery was also reading the block, but then never writing it before log recovery invalidated the cache, indicating that it was not modified by log recovery. More detailed analysis of the corpse indicated that the filesystem had a uuid of "a4131074-1872-4cac-9323-2229adbcb886" but the XARM block had a uuid of "8f32f043-c3c9-e7f8-f947-4e7f989c05d3", which indicated it was a block from an older filesystem. The reason that log recovery didn't replay it was that the LSN in the XARM block was larger than the LSN of the transaction being replayed, and so the block was not overwritten by log recovery. Hence, log recovery cant blindly trust the magic number and LSN in the block - it must verify that it belongs to the filesystem being recovered before using the LSN. i.e. if the UUIDs don't match, we need to unconditionally recovery the change held in the log. This patch was first tested on a block device that was repeatedly causing xfs/182 to fail with the same failure on the same block with the same directory read corruption signature (i.e. XARM block). It did not fail, and hasn't failed since. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-09-24xfs: fix XFS_IOC_FREE_EOFBLOCKS definitionDave Chinner
It uses a kernel internal structure in it's definition rather than the user visible structure that is passed to the ioctl. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-09-24xfs: asserting lock not held during freeing not validDave Chinner
When we free an inode, we do so via RCU. As an RCU lookup can occur at any time before we free an inode, and that lookup takes the inode flags lock, we cannot safely assert that the flags lock is not held just before marking it dead and running call_rcu() to free the inode. We check on allocation of a new inode structre that the lock is not held, so we still have protection against locks being leaked and hence not correctly initialised when allocated out of the slab. Hence just remove the assert... Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-09-24xfs: lock the AIL before removing the buffer itemDave Chinner
Regression introduced by commit 46f9d2e ("xfs: aborted buf items can be in the AIL") which fails to lock the AIL before removing the item. Spinlock debugging throws a warning about this. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-09-24reiserfs: fix race with flush_used_journal_lists and flush_journal_listJeff Mahoney
There are two locks involved in managing the journal lists. The general reiserfs_write_lock and the journal->j_flush_mutex. While flush_journal_list is sleeping to acquire the j_flush_mutex or to submit a block for write, it will drop the write lock. This allows another thread to acquire the write lock and ultimately call flush_used_journal_lists to traverse the list of journal lists and select one for flushing. It can select the journal_list that has just had flush_journal_list called on it in the original thread and call it again with the same journal_list. The second thread then drops the write lock to acquire j_flush_mutex and the first thread reacquires it and continues execution and eventually clears and frees the journal list before dropping j_flush_mutex and returning. The second thread acquires j_flush_mutex and ends up operating on a journal_list that has already been released. If the memory hasn't been reused, we'll soon after hit a BUG_ON because the transaction id has already been cleared. If it's been reused, we'll crash in other fun ways. Since flush_journal_list will synchronize on j_flush_mutex, we can fix the race by taking a proper reference in flush_used_journal_lists and checking to see if it's still valid after the mutex is taken. It's safe to iterate the list of journal lists and pick a list with just the write lock as long as a reference is taken on the journal list before we drop the lock. We already have code to handle whether a transaction has been flushed already so we can use that to handle the race and get rid of the trans_id BUG_ON. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2013-09-24reiserfs: remove useless flush_old_journal_listsJeff Mahoney
Commit a3172027 introduced test_transaction as a requirement for flushing old lists -- but it can never return 1 unless the transaction has already been flushed. As a result, we have a routine that iterates the j_realblocks list but doesn't actually do anything. Since it's been this way since 2006 and the latency numbers were what Chris expected, let's just rip it out. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2013-09-24udf: Fortify LVID loadingJan Kara
A user has reported an oops in udf_statfs() that was caused by numOfPartitions entry in LVID structure being corrupted. Fix the problem by verifying whether numOfPartitions makes sense at least to the extent that LVID fits into a single block as it should. Reported-by: Juergen Weigert <jw@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2013-09-22Merge branch 'for-3.12/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block IO fixes from Jens Axboe: "After merge window, no new stuff this time only a collection of neatly confined and simple fixes" * 'for-3.12/core' of git://git.kernel.dk/linux-block: cfq: explicitly use 64bit divide operation for 64bit arguments block: Add nr_bios to block_rq_remap tracepoint If the queue is dying then we only call the rq->end_io callout. This leaves bios setup on the request, because the caller assumes when the blk_execute_rq_nowait/blk_execute_rq call has completed that the rq->bios have been cleaned up. bio-integrity: Fix use of bs->bio_integrity_pool after free blkcg: relocate root_blkg setting and clearing block: Convert kmalloc_node(...GFP_ZERO...) to kzalloc_node(...) block: trace all devices plug operation
2013-09-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "These are mostly bug fixes and a two small performance fixes. The most important of the bunch are Josef's fix for a snapshotting regression and Mark's update to fix compile problems on arm" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (25 commits) Btrfs: create the uuid tree on remount rw btrfs: change extent-same to copy entire argument struct Btrfs: dir_inode_operations should use btrfs_update_time also btrfs: Add btrfs: prefix to kernel log output btrfs: refuse to remount read-write after abort Btrfs: btrfs_ioctl_default_subvol: Revert back to toplevel subvolume when arg is 0 Btrfs: don't leak transaction in btrfs_sync_file() Btrfs: add the missing mutex unlock in write_all_supers() Btrfs: iput inode on allocation failure Btrfs: remove space_info->reservation_progress Btrfs: kill delay_iput arg to the wait_ordered functions Btrfs: fix worst case calculator for space usage Revert "Btrfs: rework the overcommit logic to be based on the total size" Btrfs: improve replacing nocow extents Btrfs: drop dir i_size when adding new names on replay Btrfs: replay dir_index items before other items Btrfs: check roots last log commit when checking if an inode has been logged Btrfs: actually log directory we are fsync()'ing Btrfs: actually limit the size of delalloc range Btrfs: allocate the free space by the existed max extent size when ENOSPC ...
