do_lookup_path()
We're presently running lock_kernel() under fs_lock via nfs's ->permission
handler. That's a ranking bug and sometimes a sleep-in-spinlock bug. This
problem was introduced in the openat() patchset.
We should not need to hold the current->fs->lock for a codepath that doesn't
use current->fs.
[vsu@altlinux.ru: fix error path]
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: Al Viro <viro@ftp.linux.org.uk>
Signed-off-by: Sergey Vlasov <vsu@altlinux.ru>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
It seems there is error check missing in open_namei for errors returned
through intent.open.file (from lookup_instantiate_filp).
If there is plain open performed, then such a check done inside
__path_lookup_intent_open called from path_lookup_open(), but when the open
is performed with O_CREAT flag set, then __path_lookup_intent_open is only
called with LOOKUP_PARENT set where no file opening can occur yet.
Later on lookup_hash is called where exact opening might take place and
intent.open.file may be filled. If it is filled with error value of some
sort, then we get kernel attempting to dereference this error value as
address (and corresponding oops) in nameidata_to_filp() called from
filp_open().
While this is relatively simple to workaround in ->lookup() method by just
checking lookup_instantiate_filp() return value and returning error as
needed, this is not so easy in ->d_revalidate(), where we can only return
"yes, dentry is valid" or "no, dentry is invalid, perform full lookup
again", and just returning 0 on error would cause extra lookup (with
potential extra costly RPCs).
So in short, I believe that there should be no difference in error handling
for opening a file and creating a file in open_namei() and propose this
simple patch as a solution.
Mentioned by Mark Armbrust somewhere on Usenet.
Cc: Ulrich Drepper <drepper@redhat.com>
Yesterday, I got the following error with 2.6.16.13 during a file copy from
a smb filesystem over a wireless link. I guess there was some error on the
wireless link, which in turn caused an error condition for the smb
filesystem.
In the log, smb_file_read reports error=4294966784 (0xfffffe00), which also
shows up in the slab dumps, and also is -ERESTARTSYS. Error code 27499
corresponds to 0x6b6b, so the rq_errno field seems to be the only one being
set after freeing the slab.
In smb_add_request (which is the only place in smbfs where I found
ERESTARTSYS), I found the following:
if (!timeleft || signal_pending(current)) {
* On timeout or on interrupt we want to try and remove the
* request from the recvq/xmitq.
smb_lock_server(server);
if (!(req->rq_flags & SMB_REQ_RECEIVED)) {
list_del_init(&req->rq_queue);
smb_rput(req);
smb_unlock_server(server);
if (signal_pending(current))
req->rq_errno = -ERESTARTSYS;
I guess that some codepath like smbiod_flush() caused the request to be
removed from the queue, and smb_rput(req) be called, without
SMB_REQ_RECEIVED being set. This violates an asumption made by the quoted
code.
Then, the above code calls smb_rput(req) again, the req gets freed, and
req->rq_errno = -ERESTARTSYS writes into the already freed slab. As
list_del_init doesn't cause an error if called multiple times, that does
cause the observed behaviour (freed slab with rq_errno=-ERESTARTSYS).
If this observation is correct, the following patch should fix it.
I wonder why the smb code uses list_del_init everywhere - using list_del
instead would catch such situations by poisoning the next and prev
pointers.
May 4 23:29:21 knautsch kernel: [17180085.456000] ipw2200: Firmware error detected. Restarting.
May 4 23:29:21 knautsch kernel: [17180085.456000] ipw2200: Sysfs 'error' log captured.
May 4 23:33:02 knautsch kernel: [17180306.316000] ipw2200: Firmware error detected. Restarting.
May 4 23:33:02 knautsch kernel: [17180306.316000] ipw2200: Sysfs 'error' log already exists.
May 4 23:33:02 knautsch kernel: [17180306.968000] smb_file_read: //some_file validation failed, error=4294966784
May 4 23:34:18 knautsch kernel: [17180383.256000] smb_file_read: //some_file validation failed, error=4294966784
May 4 23:34:18 knautsch kernel: [17180383.284000] SMB connection re-established (-5)
May 4 23:37:19 knautsch kernel: [17180563.956000] smb_file_read: //some_file validation failed, error=4294966784
May 4 23:40:09 knautsch kernel: [17180733.636000] smb_file_read: //some_file validation failed, error=4294966784
May 4 23:40:26 knautsch kernel: [17180750.700000] smb_file_read: //some_file validation failed, error=4294966784
May 4 23:43:02 knautsch kernel: [17180907.304000] smb_file_read: //some_file validation failed, error=4294966784
May 4 23:43:08 knautsch kernel: [17180912.324000] smb_file_read: //some_file validation failed, error=4294966784
May 4 23:43:34 knautsch kernel: [17180938.416000] smb_errno: class Unknown, code 27499 from command 0x6b
May 4 23:43:34 knautsch kernel: [17180938.416000] Slab corruption: start=c4ebe09c, len=244
May 4 23:43:34 knautsch kernel: [17180938.416000] Redzone: 0x5a2cf071/0x5a2cf071.
May 4 23:43:34 knautsch kernel: [17180938.416000] Last user: [<e087b903>](smb_rput+0x53/0x90 [smbfs])
May 4 23:43:34 knautsch kernel: [17180938.416000] 000: 6b 6b 6b 6b 6b 6b 6b 6b 6a 6b 6b 6b 6b 6b 6b 6b
May 4 23:43:34 knautsch kernel: [17180938.416000] 0f0: 00 fe ff ff
May 4 23:43:34 knautsch kernel: [17180938.416000] Next obj: start=c4ebe19c, len=244
May 4 23:43:34 knautsch kernel: [17180938.416000] Last user: [<00000000>](_stext+0x3feffde0/0x30)
May 4 23:43:34 knautsch kernel: [17180938.416000] 000: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b
May 4 23:43:34 knautsch kernel: [17180938.416000] 010: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b
May 4 23:43:34 knautsch kernel: [17180938.460000] SMB connection re-established (-5)
May 4 23:43:42 knautsch kernel: [17180946.292000] ipw2200: Firmware error detected. Restarting.
May 4 23:43:42 knautsch kernel: [17180946.292000] ipw2200: Sysfs 'error' log already exists.
May 4 23:45:04 knautsch kernel: [17181028.752000] ipw2200: Firmware error detected. Restarting.
May 4 23:45:04 knautsch kernel: [17181028.752000] ipw2200: Sysfs 'error' log already exists.
May 4 23:45:05 knautsch kernel: [17181029.868000] smb_file_read: //some_file validation failed, error=4294966784
May 4 23:45:36 knautsch kernel: [17181060.984000] smb_errno: class Unknown, code 27499 from command 0x6b
May 4 23:45:36 knautsch kernel: [17181060.984000] Slab corruption: start=c4ebe09c, len=244
May 4 23:45:36 knautsch kernel: [17181060.984000] Redzone: 0x5a2cf071/0x5a2cf071.
May 4 23:45:36 knautsch kernel: [17181060.984000] Last user: [<e087b903>](smb_rput+0x53/0x90 [smbfs])
May 4 23:45:36 knautsch kernel: [17181060.984000] 000: 6b 6b 6b 6b 6b 6b 6b 6b 6a 6b 6b 6b 6b 6b 6b 6b
May 4 23:45:36 knautsch kernel: [17181060.984000] 0f0: 00 fe ff ff
May 4 23:45:36 knautsch kernel: [17181060.984000] Next obj: start=c4ebe19c, len=244
May 4 23:45:36 knautsch kernel: [17181060.984000] Last user: [<00000000>](_stext+0x3feffde0/0x30)
May 4 23:45:36 knautsch kernel: [17181060.984000] 000: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b
May 4 23:45:36 knautsch kernel: [17181060.984000] 010: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b
May 4 23:45:36 knautsch kernel: [17181061.024000] SMB connection re-established (-5)
May 4 23:46:17 knautsch kernel: [17181102.132000] smb_file_read: //some_file validation failed, error=4294966784
May 4 23:47:46 knautsch kernel: [17181190.468000] smb_errno: class Unknown, code 27499 from command 0x6b
May 4 23:47:46 knautsch kernel: [17181190.468000] Slab corruption: start=c4ebe09c, len=244
May 4 23:47:46 knautsch kernel: [17181190.468000] Redzone: 0x5a2cf071/0x5a2cf071.
May 4 23:47:46 knautsch kernel: [17181190.468000] Last user: [<e087b903>](smb_rput+0x53/0x90 [smbfs])
May 4 23:47:46 knautsch kernel: [17181190.468000] 000: 6b 6b 6b 6b 6b 6b 6b 6b 6a 6b 6b 6b 6b 6b 6b 6b
May 4 23:47:46 knautsch kernel: [17181190.468000] 0f0: 00 fe ff ff
May 4 23:47:46 knautsch kernel: [17181190.468000] Next obj: start=c4ebe19c, len=244
May 4 23:47:46 knautsch kernel: [17181190.468000] Last user: [<00000000>](_stext+0x3feffde0/0x30)
May 4 23:47:46 knautsch kernel: [17181190.468000] 000: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b
May 4 23:47:46 knautsch kernel: [17181190.468000] 010: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b
May 4 23:47:46 knautsch kernel: [17181190.492000] SMB connection re-established (-5)
May 4 23:49:20 knautsch kernel: [17181284.828000] smb_file_read: //some_file validation failed, error=4294966784
May 4 23:49:39 knautsch kernel: [17181303.896000] smb_file_read: //some_file validation failed, error=4294966784
Signed-off-by: Jan Niehusmann <jan@gondor.com>
sys_flock() currently has a race which can result in a double free in the
multi-thread case.
Thread 1 Thread 2
sys_flock(file, LOCK_EX)
sys_flock(file, LOCK_UN)
If Thread 2 removes the lock from inode->i_lock before Thread 1 tests for
list_empty(&lock->fl_link) at the end of sys_flock, then both threads will
end up calling locks_free_lock for the same lock.
Fix is to make flock_lock_file() do the same as posix_lock_file(), namely
to make a copy of the request, so that the caller can always free the lock.
This also has the side-effect of fixing up a reference problem in the
lockd handling of flock.
It is insane to be giving lease_init() the task of freeing the lock it is
supposed to initialise, given that the lock is not guaranteed to be
allocated on the stack. This causes lockups in fcntl_setlease().
Problem diagnosed by Daniel Hokka Zakrisson <daniel@hozac.com>
Also fix a slab leak in __setlease() due to an uninitialised return value.
Problem diagnosed by Björn Steinbrink.
Tested-by: Daniel Hokka Zakrisson <daniel@hozac.com>
Cc: Björn Steinbrink <B.Steinbrink@gmx.de>
Mark Moseley reported that a chroot environment on a SMB share can be
left via "cd ..\\". Similar to CVE-2006-1863 issue with cifs, this fix
is for smbfs.
Steven French <sfrench@us.ibm.com> wrote:
Looks fine to me. This should catch the slash on lookup or equivalent,
which will be all obvious paths of interest.
This patch addresses a flaw in LSM, where there is no mediation of readv()
and writev() in for 32-bit compatible apps using a 64-bit kernel.
This bug was discovered and fixed initially in the native readv/writev
code [1], but was not fixed in the compat code. Thanks to Al for spotting
this one.
[1] http://lwn.net/Articles/154282/
Signed-off-by: James Morris <jmorris@namei.org>
reiserfs_cache_default_acl() should return whether we successfully found
the acl or not. We have to return correct value even if reiserfs_get_acl()
returns error code and not just 0. Otherwise callers such as
reiserfs_mkdir() can unnecessarily lock the xattrs and later functions such
as reiserfs_new_inode() fail to notice that we have already taken the lock
and try to take it again with obvious consequences.
Cc: <reiserfs-dev@namesys.com>
Repair /proc/devices early-termination regression.
2.6.16 broke /proc/devices. An application often gets an
EOF before the end of data is reached, if that application
uses a series of short read(2)s to access the data. I have
used read buffers of varying sizes with varying degrees
of unsuccess (larger sizes get further into the data than
smaller sizes, following a simple pattern). It appears
that the only safe way to get the data is to use a single
read buffer larger than all the data in /proc/devices.
The following example demonstates the problem:
# dd if=/proc/devices bs=1
Character devices:
1 mem
27+0 records in
27+0 records out
This patch is a backport of the fix recently accepted to
Linus's tree:
commit 68eef3b4791572ecb70249c7fb145bb3742dd899
[PATCH] Simplify proc/devices and fix early termination regression
It replaces the complex, state-machine algorithm introduced
in 2.6.16 with a simple algorithm, modeled on the implementation
of /proc/interrupts.
[akpm@osdl.org: cleanups, simplifications]
Signed-off-by: Joe Korty <joe.korty@ccur.com>
Unless Posix paths have been negotiated, the backslash, "\", is not a valid
character in a path component.
Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
There are places in the kernel where we look up files in fd tables and
access the file structure without holding refereces to the file. So, we
need special care to avoid the race between looking up files in the fd
table and tearing down of the file in another CPU. Otherwise, one might
see a NULL f_dentry or such torn down version of the file. This patch
fixes those special places where such a race may happen.
Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com>
Acked-by: "Paul E. McKenney" <paulmck@us.ibm.com>
x86: be careful about tailcall breakage for sys_open[at] too
Came up through a quick grep for other cases similar to the ftruncate()
one in commit 0a489cb3b6a7b277030cdbc97c2c65905db94536.
Also, add a comment, so that people who read the code understand why we
do what looks like a no-op.
(Again, this won't actually matter to any sane user, since libc will
save and restore the register gcc stomps on, but it's still wrong to
stomp on it)
x86: don't allow tail-calls in sys_ftruncate[64]()
Gcc thinks it owns the incoming argument stack, but that's not true for
"asmlinkage" functions, and it corrupts the caller-set-up argument stack
when it pushes the third argument onto the stack. Which can result in
%ebx getting corrupted in user space.
Now, normally nobody sane would ever notice, since libc will save and
restore %ebx anyway over the system call, but it's still wrong.
I'd much rather have "asmlinkage" tell gcc directly that it doesn't own
the stack, but no such attribute exists, so we're stuck with our hacky
manual "prevent_tail_call()" macro once more (we've had the same issue
before with sys_waitpid() and sys_wait4()).
Thanks to Hans-Werner Hilse <hilse@sub.uni-goettingen.de> for reporting
the issue and testing the fix.
Fixes Samba bug 3621 and kernel.org bug 6147
For servers which require SMB/CIFS packet signing, we were sending the
wrong signature (all zeros) on SMB Read request. The new cifs routine
to do signatures across an iovec was not complete - and SMB Read, unlike
the new SMBWrite2, did not fall back to the older routine (ie use
SendReceive vs. the more efficient SendReceive2 ie used the older
cifs_sign_smb vs. the disabled cifs_sign_smb2) for calculating signatures.
This finishes up cifs_sign_smb2/cifs_calc_signature2 so that the callers
of SendReceive2 can get SMB/CIFS packet signatures.
Now that cifs_sign_smb2 is supported, we could start using it in
the write path but this smaller fix does not include the change
to use SMBWrite2 when signatures are required (which when enabled
will make more Writes more efficient and alloc less memory).
Currently Write2 is only used when signatures are not
required at the moment but after more testing we will enable
that as well).
Thanks to James Slepicka and Sam Flory for initial investigation.
SGI-PV: 949858
SGI-Modid: xfs-linux-melb:xfs-kern:25717a
Signed-off-by: Jes Sorensen <jes@sgi.com>
Signed-off-by: Nathan Scott <nathans@sgi.com>
Missed unlock_super()call is added in error condition code path.
Signed-off-by: Leonid Ananiev <leonid.i.ananiev@intel.com>
As noted further on the this file, some block devices have a / in their
name, so fix the "block:..." symlink name the same as the /sys/block name.
During heavy parallel filesystem activity it was possible to Oops the
kernel. The reason is that read_cache_pages() could skip pages which
have already been inserted into the cache by another task.
Occasionally this may result in zero pages actually being sent, while
fuse_send_readpages() relies on at least one page being in the
request.
So check this corner case and just free the request instead of trying
to send it.
Reported and tested by Konstantin Isakov.
Signed-off-by: Miklos Szeredi <miklos@szeredi.hu>
A couple of /proc/vmcore data structures overflow with 32bit systems having
memory more than 4G. This patch fixes those.
Signed-off-by: Ken'ichi Ohmichi <oomichi@mxs.nes.nec.co.jp>
Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com>
NFSd makes sure there is enough space to hold the maximum possible reply
before accepting a request. The units for this maximum is (4byte) words.
However in three places, particularly for read request, the number given is
a number of bytes.
This means too much space is reserved which is slightly wasteful.
This is the sort of patch that could uncover a deeper bug, and it is not
critical, so it would be best for it to spend a while in -mm before going
in to mainline.
(akpm: target 2.6.17-rc2, 2.6.16.3 (approx))
Discovered-by: "Eivind Sarto" <ivan@kasenna.com>
Signed-off-by: Neil Brown <neilb@suse.de>
No one should be writing a PAGE_SIZE worth of data to a normal sysfs
file, so properly terminate the buffer.
Thanks to Al Viro for pointing out my stupidity here.
CVE-2006-1055 has been assigned for this.
Fix a duplicate block device line printed after the "Block device" header
in /proc/devices.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
If a file is not found in v9fs_vfs_lookup, the function creates negative
dentry, but doesn't assign any dentry ops. This leaves the negative entry
in the cache (there is no d_delete to mark it for removal). If the file is
created outside of the mounted v9fs filesystem, the file shows up in the
directory with weird permissions.
This patch assigns the default v9fs dentry ops to the negative dentry.
Signed-off-by: Latchesar Ionkov <lucho@ionkov.net>
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
[XFS] Check that a page has dirty buffers before finding it acceptable for
rewrite clustering. This prevents writing excessive amounts of clean data
when doing random rewrites of a cached file.
Signed-off-by: David Chinner <dgc@sgi.com>
As pointed out by Oliver Neukum.
Cc: Maneesh Soni <maneesh@in.ibm.com>
Cc: Oliver Neukum <oliver@neukum.org>
When calling sysfs_remove_dir() don't allow any further sysfs functions
to work for this kobject anymore. This fixes a nasty USB cdc-acm oops
on disconnect.
Many thanks to Bob Copeland and Paul Fulghum for taking the time to
track this down.
Cc: Bob Copeland <email@bobcopeland.com>
Cc: Paul Fulghum <paulkf@microgate.com>
A user can use nfsservctl() to spam the logs.
This can happen because the arguments to the nfsservctl() system call are
versioned. This is a good thing. However, when a bad version is detected,
the kernel prints a message and then returns an error.
Signed-off-by: Peter Staubach <staubach@redhat.com>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
There is a d_drop in dir_release which caused problems as it invalidates
dcache entries too soon. This was likely a part of the wierd cwd behavior
folks were seeing.
This fixes not one, but _two_, silly (but admittedly hard to hit) bugs
in the ext2 filesystem "readdir()" function. It also cleans up the code
to avoid the unnecessary goto mess.
The bugs were related to re-valiating the f_pos value after somebody had
either done an "lseek()" on the directory to an invalid offset, or when
the offset had become invalid due to a file being unlinked in the
directory. The code would not only set the f_version too eagerly, it
would also not update f_pos appropriately for when the offset fixup took
place.
When that happened, we'd occasionally subsequently fail the readdir()
even when we shouldn't (no real harm done, but an ugly printk, and
obviously you would end up not necessarily seeing all entries).
Thanks to Masoud Sharbiani <masouds@google.com> who noticed the problem
and had a test-case for it, and also fixed up a thinko in the first
version of this patch.
Acked-by: Masoud Sharbiani <masouds@google.com>
The Coverity checker spotted the following bug in dup_namespace():
<-- snip -->
if (!new_ns->root) {
up_write(&namespace_sem);
kfree(new_ns);
goto out;
out:
return new_ns;
<-- snip -->
Callers expect a non-NULL result to not be freed.
page migration currently simply retries a couple of times if try_to_unmap()
fails without inspecting the return code.
However, SWAP_FAIL indicates that the page is in a vma that has the
VM_LOCKED flag set (if ignore_refs ==1). We can check for that return code
and avoid retrying the migration.
migrate_page_remove_references() now needs to return a reason why the
failure occured. So switch migrate_page_remove_references to use -Exx
style error messages.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
* git://oss.sgi.com:8090/oss/git/rc-fixes:
Fix a direct I/O locking issue revealed by the new mutex code.
Affects only XFS (i.e. DIO_OWN_LOCKING case) - currently it is
not possible to get i_mutex locking correct when using DIO_OWN
direct I/O locking in a filesystem due to indeterminism in the
possible return code/lock/unlock combinations. This can cause
a direct read to attempt a double i_mutex unlock inside XFS.
We're now ensuring __blockdev_direct_IO always exits with the
inode i_mutex (still) held for a direct reader.
Tested with the three different locking modes (via direct block
device access, ext3 and XFS) - both reading and writing; cannot
find any regressions resulting from this change, and it clearly
fixes the mutex_unlock warning originally reported here:
http://marc.theaimsgroup.com/?l=linux-kernel&m=114189068126253&w=2
Acked-by: Christoph Hellwig <hch@lst.de>
This fixes a race where lsn could be cleared before taking the lock
In theory, NLM specs assure us that the server will only reply LCK_GRANTED or
LCK_DENIED_GRACE_PERIOD to our NLM_UNLOCK request.
In practice, we should not assume this to be the case, and the code will
currently Oops if we do.
It turns out that nfs4_proc_get_root() may return raw NFSv4 errors instead of
mapping them to kernel errors. Problem spotted by Neil Horman
Based on an original patch by Mike O'Connor and Greg Banks of SGI.
Mike states:
A normal user can panic an NFS client and cause a local DoS with
'judicious'(?) use of O_DIRECT. Any O_DIRECT write to an NFS file where the
user buffer starts with a valid mapped page and contains an unmapped page,
will crash in this way. I haven't followed the code, but O_DIRECT reads with
similar user buffers will probably also crash albeit in different ways.
Details: when nfs_get_user_pages() calls get_user_pages(), it detects and
correctly handles get_user_pages() returning an error, which happens if the
first page covered by the user buffer's address range is unmapped. However,
if the first page is mapped but some subsequent page isn't, get_user_pages()
will return a positive number which is less than the number of pages requested
(this behaviour is sort of analagous to a short write() call and appears to be
intentional). nfs_get_user_pages() doesn't detect this and hands off the
array of pages (whose last few elements are random rubbish from the newly
allocated array memory) to it's caller, whence they go to
nfs_direct_write_seg(), which then totally ignores the nr_pages it's given,
and calculates its own idea of how many pages are in the array from the user
buffer length. Needless to say, when it comes to transmit those uninitialised
page* pointers, we see a crash in the network stack.
One can do "chattr +j" on a file to change its journalling mode. Fix
writeback mode with "nobh" handling for it.
Even though, we mount ext3 filesystem in writeback mode with "nobh" option,
some one can do "chattr +j" on a single file to force it to do journalled
mode. In order to do journaling, ext3_block_truncate_page() need to
fallback to default case of creating buffers and adding them to transaction
etc.
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
This patch fixes illegal __GFP_FS allocation inside ext3 transaction in
ext3_symlink(). Such allocation may re-enter ext3 code from
try_to_free_pages. But JBD/ext3 code keeps a pointer to current journal
handle in task_struct and, hence, is not reentrable.
This bug led to "Assertion failure in journal_dirty_metadata()" messages.
http://bugzilla.openvz.org/show_bug.cgi?id=115
Signed-off-by: Andrey Savochkin <saw@saw.sw.com.sg>
Signed-off-by: Kirill Korotaev <dev@openvz.org>
Fix some bugs in mtd/jffs2 on 64bit platform.
The MEMGETBADBLOCK/MEMSETBADBLOCK ioctl are not listed in compat_ioctl.h.
And some variables in jffs2 are declared as uint32_t but used to hold
size_t values.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Acked-by: David Woodhouse <dwmw2@infradead.org>
A recent change to compat. dev_ifconf() in fs/compat_ioctl.c
causes ifconf data to be truncated 1 entry too early when copying it
to userspace. The correct amount of data (length) is returned,
but the final entry is empty (zero, not filled in).
The for-loop 'i' check should use <= to allow the final struct
ifreq32 to be copied. I also used the ifconf-corruption program
in kernel bugzilla #4746 to make sure that this change does not
re-introduce the corruption.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Miscellaneous fixes related to accessing uninitialized variables or memory
that was already freed.
Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org>
DASD allows to open a device as soon as gendisk is registered, which means the
device is a fake device (capacity=0) and we do know nothing about blocksize
and partitions at that point of time. In case the device is opened by
someone, the bdev and inode creation is done with the fake device info and the
following partition detection code is just using the wrong data.
To avoid this modify the DASD state machine to make sure that the open is
rejected until the device analysis is either finished or an unformatted device
was detected.
Signed-off-by: Horst Hummel <horst.hummel@de.ibm.com>
I have benchmarked this on an x86_64 NUMA system and see no significant
performance difference on kernbench. Tested on both x86_64 and powerpc.
The way we do file struct accounting is not very suitable for batched
freeing. For scalability reasons, file accounting was
constructor/destructor based. This meant that nr_files was decremented
only when the object was removed from the slab cache. This is susceptible
to slab fragmentation. With RCU based file structure, consequent batched
freeing and a test program like Serge's, we just speed this up and end up
with a very fragmented slab -
llm22:~ # cat /proc/sys/fs/file-nr
587730 0 758844
At the same time, I see only a 2000+ objects in filp cache. The following
patch I fixes this problem.
This patch changes the file counting by removing the filp_count_lock.
Instead we use a separate percpu counter, nr_files, for now and all
accesses to it are through get_nr_files() api. In the sysctl handler for
nr_files, we populate files_stat.nr_files before returning to user.
Counting files as an when they are created and destroyed (as opposed to
inside slab) allows us to correctly count open files with RCU.
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
Fix a bug in udf where it would write uid/gid = 0 to the disk for files
owned by the id given with the uid=/gid= mount options. It also adds 4 new
mount options: uid/gid=forget and uid/gid=ignore. Without any options the
id in core and on disk always match. Giving uid/gid=nnn specifies a
default ID to be used in core when the on disk ID is -1. uid/gid=ignore
forces the in core ID to allways be used no matter what the on disk ID is.
uid/gid=forget forces the on disk ID to always be written out as -1.
The use of these options allows you to override ownerships on a disk or
disable ownwership information from being written, allowing the media to be
used portably between different computers and possibly different users
without permissions issues that would require root to correct.
Signed-off-by: Phillip Susi <psusi@cfl.rr.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
They aren't used (nor even really usable) outside of pipe.c anyway
We don't do interruptible waits for the pipe mutex anywhere else any
more either, so don't do it in fifo_open() either.
The point of the smaps "shared" is to count the number of pages that are
mapped by more than one process, according to Mauricio Lin. However, smaps
uses page_count for this, so it will return a false positive for every page
that is mapped by just that one process, which is also in pagecache or
swapcache. There are false positive situations for anonymous pages not in
swapcache as well: - page reclaim, migration - get_user_pages (eg.
direct-io, ptrace)
Use page_mapcount instead, to count the number of mappings to the page.
Use vm_normal_page so that weird things like /dev/mem aren't counted either.
Signed-off-by: Nick Piggin <npiggin@suse.de>
