path: root/include/acpi/apei.h
2014-07-22acpi, apei, ghes: Factor out ioremap virtual memory for IRQ and NMI context.Tomasz Nowicki
GHES currently maps two pages with atomic_ioremap. From now on, NMI is architectural depended so there is no need to allocate an NMI page for platforms without NMI support. To make it possible to not use a second page, swap the existing page order so that the IRQ context page is first, and the optional NMI context page is second. Then, use HAVE_ACPI_APEI_NMI to decide how many pages are to be allocated. Signed-off-by: Tomasz Nowicki <tomasz.nowicki@linaro.org> Acked-by: Borislav Petkov <bp@suse.de> Signed-off-by: Tony Luck <tony.luck@intel.com>
2014-07-22apei, mce: Factor out APEI architecture specific MCE calls.Tomasz Nowicki
This commit abstracts MCE calls and provides weak corresponding default implementation for those architectures which do not need arch specific actions. Each platform willing to do additional architectural actions should provides desired function definition. It allows us to avoid wrap code into #ifdef in generic code and prevent new platform from introducing dummy stub function too. Initially, there are two APEI arch-specific calls: - arch_apei_enable_cmcff() - arch_apei_report_mem_error() Both interact with MCE driver for X86 architecture. Signed-off-by: Tomasz Nowicki <tomasz.nowicki@linaro.org> Acked-by: Borislav Petkov <bp@suse.de> Signed-off-by: Tony Luck <tony.luck@intel.com>
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-08-03ACPI: APEI build fixLen Brown
as GHES is optional... When # CONFIG_ACPI_APEI_GHES is not set: (.init.text+0x4c22): undefined reference to `ghes_disable' Reported-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Len Brown <len.brown@intel.com>
2011-07-13ACPI, APEI, GHES, Support disable GHES at boot timeHuang Ying
Some machine may have broken firmware so that GHES and firmware first mode should be disabled. This patch adds support to that. Signed-off-by: Huang Ying <ying.huang@intel.com> Reviewed-by: Andi Kleen <ak@linux.intel.com> Reviewed-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-21ACPI, APEI, Add ERST record ID cacheHuang Ying
APEI ERST firmware interface and implementation has no multiple users in mind. For example, if there is four records in storage with ID: 1, 2, 3 and 4, if two ERST readers enumerate the records via GET_NEXT_RECORD_ID as follow, reader 1 reader 2 1 2 3 4 -1 -1 where -1 signals there is no more record ID. Reader 1 has no chance to check record 2 and 4, while reader 2 has no chance to check record 1 and 3. And any other GET_NEXT_RECORD_ID will return -1, that is, other readers will has no chance to check any record even they are not cleared by anyone. This makes raw GET_NEXT_RECORD_ID not suitable for used by multiple users. To solve the issue, an in-memory ERST record ID cache is designed and implemented. When enumerating record ID, the ID returned by GET_NEXT_RECORD_ID is added into cache in addition to be returned to caller. So other readers can check the cache to get all record ID available. Signed-off-by: Huang Ying <ying.huang@intel.com> Reviewed-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-14PCI/ACPI: Request _OSC control once for each root bridge (v3)Rafael J. Wysocki
Move the evaluation of acpi_pci_osc_control_set() (to request control of PCI Express native features) into acpi_pci_root_add() to avoid calling it many times for the same root complex with the same arguments. Additionally, check if all of the requisite _OSC support bits are set before calling acpi_pci_osc_control_set() for a given root complex. References: https://bugzilla.kernel.org/show_bug.cgi?id=20232 Reported-by: Ozan Caglayan <ozan@pardus.org.tr> Tested-by: Ozan Caglayan <ozan@pardus.org.tr> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-05-19ACPI, APEI, Error Record Serialization Table (ERST) supportHuang Ying
ERST is a way provided by APEI to save and retrieve hardware error record to and from some simple persistent storage (such as flash). The Linux kernel support implementation is quite simple and workable in NMI context. So it can be used to save hardware error record into flash in hardware error exception or NMI handler, where other more complex persistent storage such as disk is not usable. After saving hardware error records via ERST in hardware error exception or NMI handler, the error records can be retrieved and logged into disk or network after a clean reboot. For more information about ERST, please refer to ACPI Specification version 4.0, section 17.4. This patch incorporate fixes from Jin Dongming. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> CC: Jin Dongming <jin.dongming@np.css.fujitsu.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-05-19ACPI, APEI, HEST table parsingHuang Ying
HEST describes error sources in detail; communicating operational parameters (i.e. severity levels, masking bits, and threshold values) to OS as necessary. It also allows the platform to report error sources for which OS would typically not implement support (for example, chipset-specific error registers). HEST information may be needed by other subsystems. For example, HEST PCIE AER error source information describes whether a PCIE root port works in "firmware first" mode, this is needed by general PCIE AER error subsystem. So a public HEST tabling parsing interface is provided. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
