* pm-acpi: (24 commits)
olpc-xo15-sci: Use struct dev_pm_ops for power management
ACPI / PM: Drop PM callbacks from the ACPI bus type
ACPI / PM: Drop legacy driver PM callbacks that are not used any more
ACPI / PM: Do not execute legacy driver PM callbacks
acpi_power_meter: Use struct dev_pm_ops for power management
fujitsu-tablet: Use struct dev_pm_ops for power management
classmate-laptop: Use struct dev_pm_ops for power management
xo15-ebook: Use struct dev_pm_ops for power management
toshiba_bluetooth: Use struct dev_pm_ops for power management
panasonic-laptop: Use struct dev_pm_ops for power management
sony-laptop: Use struct dev_pm_ops for power management
hp_accel: Use struct dev_pm_ops for power management
toshiba_acpi: Use struct dev_pm_ops for power management
ACPI: Use struct dev_pm_ops for power management in the SBS driver
ACPI: Use struct dev_pm_ops for power management in the power driver
ACPI: Use struct dev_pm_ops for power management in the button driver
ACPI: Use struct dev_pm_ops for power management in the battery driver
ACPI: Use struct dev_pm_ops for power management in the AC driver
ACPI: Use struct dev_pm_ops for power management in processor driver
ACPI: Use struct dev_pm_ops for power management in the thermal driver
Remove the time field as it is not used.
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Remove the usage field as it is not used.
Remove the latency_ticks field as it is not used.
Make the ACPI processor driver define its PM callbacks through
a struct dev_pm_ops object rather than by using legacy PM hooks
in struct acpi_device_ops.
None of the drivers implementing the ACPI device suspend callback
uses the pm_message_t argument of it, so this argument may be dropped
entirely from that callback. This will simplify switching the ACPI
bus type to PM handling based on struct dev_pm_ops.
This was done to resolve a merge and build problem with the
drivers/acpi/processor_driver.c file.
The only left over hole in automatic cpufreq driver loading was the loading
of ACPI cpufreq. This driver should be loaded when ACPI supports a _PDC
method and the CPU vendor wants to use acpi cpufreq.
Simply add a request module call to the acpi processor core driver
when this is true. This seems like the simplest solution for this.
Cc: Len Brown <lenb@kernel.org>
Signed-off-by: Thomas Renninger <trenn@suse.de>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Delay the setting up of features (cpuidle, throttling by calling
acpi_processor_start()) to the time when the hotplugged
core got onlined the first time and got fully
initialized.
Signed-off-by: Len Brown <len.brown@intel.com>
This patch makes the cpuidle_states structure global (single copy)
instead of per-cpu. The statistics needed on per-cpu basis
by the governor are kept per-cpu. This simplifies the cpuidle
subsystem as state registration is done by single cpu only.
Having single copy of cpuidle_states saves memory. Rare case
of asymmetric C-states can be handled within the cpuidle driver
and architectures such as POWER do not have asymmetric C-states.
Having single/global registration of all the idle states,
dynamic C-state transitions on x86 are handled by
the boot cpu. Here, the boot cpu would disable all the devices,
re-populate the states and later enable all the devices,
irrespective of the cpu that would receive the notification first.
Reference:
https://lkml.org/lkml/2011/4/25/83
Signed-off-by: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
Signed-off-by: Trinabh Gupta <g.trinabh@gmail.com>
Tested-by: Jean Pihet <j-pihet@ti.com>
Reviewed-by: Kevin Hilman <khilman@ti.com>
Acked-by: Arjan van de Ven <arjan@linux.intel.com>
Acked-by: Kevin Hilman <khilman@ti.com>
Structs battery_file, acpi_dock_ops, file_operations,
thermal_cooling_device_ops, thermal_zone_device_ops, kernel_param_ops
are not changed in runtime. It is safe to make them const.
register_hotplug_dock_device() was altered to take const "ops" argument
to respect acpi_dock_ops' const notion.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Acked-by: Jeff Garzik <jgarzik@redhat.com>
Usually, there are multiple processors defined in ACPI table, for
example
Scope (_PR)
Processor (CPU0, 0x00, 0x00000410, 0x06) {}
Processor (CPU1, 0x01, 0x00000410, 0x06) {}
Processor (CPU2, 0x02, 0x00000410, 0x06) {}
Processor (CPU3, 0x03, 0x00000410, 0x06) {}
processor_physically_present(...) will be called to check whether those
processors are physically present.
Currently we have below codes in processor_physically_present,
cpuid = acpi_get_cpuid(...);
if ((cpuid == -1) && (num_possible_cpus() > 1))
return false;
return true;
In UP kernel, acpi_get_cpuid(...) always return -1 and
num_possible_cpus() always return 1, so
processor_physically_present(...) always returns true for all passed in
processor handles.
This is wrong for UP processor or SMP processor running UP kernel.
This patch removes the !SMP version of acpi_get_cpuid(), so both UP and
SMP kernel use the same acpi_get_cpuid function.
And for UP kernel, only processor 0 is valid.
https://bugzilla.kernel.org/show_bug.cgi?id=16548
https://bugzilla.kernel.org/show_bug.cgi?id=16357
Tested-by: Anton Kochkov <anton.kochkov@gmail.com>
Tested-by: Ambroz Bizjak <ambrop7@gmail.com>
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
online/offline
After one CPU is offlined, it is unnecessary to switch T-state for it.
So it will be better that the throttling is disabled after the cpu
is offline.
At the same time after one cpu is online, we should check whether
the T-state is supported and then set the corresponding T-state
flag.
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
Remove deprecated ACPI processor procfs I/F, including:
/proc/acpi/processor/CPUX/power
/proc/acpi/processor/CPUX/limit
/proc/acpi/processor/CPUX/info
/proc/acpi/processor/CPUX/throttling still exists,
as we don't have sysfs I/F available for now.
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
It turns out that there is a bit in the _CST for Intel FFH C3
that tells the OS if we should be checking BM_STS or not.
Linux has been unconditionally checking BM_STS.
If the chip-set is configured to enable BM_STS,
it can retard or completely prevent entry into
deep C-states -- as illustrated by turbostat:
http://userweb.kernel.org/~lenb/acpi/utils/pmtools/turbostat/
ref: Intel Processor Vendor-Specific ACPI Interface Specification
table 4 "_CST FFH GAS Field Encoding"
Bit 1: Set to 1 if OSPM should use Bus Master avoidance for this C-state
https://bugzilla.kernel.org/show_bug.cgi?id=15886
These were used before cpuidle by the native ACPI idle driver,
which tracked promotion and demotion between states.
The code was referenced by CONFIG_ACPI_PROCFS
for /proc/acpi/processor/*/power,
but as we no longer do promotion/demotion, that
reference has been a NOP since the transition.
Rename static get_cpu_id() to acpi_get_cpuid() and export it.
This change also gives us an opportunity to remove the
#ifndef CONFIG_SMP from processor_driver.c and into a header file
where it properly belongs.
Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Signed-off-by: Alex Chiang <achiang@hp.com>
We've renamed the old processor_core.c to processor_driver.c, to
convey the idea that it can be built modular and has driver-like
bits.
Now let's re-create a processor_core.c for the bits needed
statically by the rest of the kernel. The contents of processor_pdc.c
are a good starting spot, so let's just rename that file and
complete our three card monte.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: add __percpu sparse annotations to what's left
percpu: add __percpu sparse annotations to fs
percpu: add __percpu sparse annotations to core kernel subsystems
local_t: Remove leftover local.h
this_cpu: Remove pageset_notifier
this_cpu: Page allocator conversion
percpu, x86: Generic inc / dec percpu instructions
local_t: Move local.h include to ringbuffer.c and ring_buffer_benchmark.c
module: Use this_cpu_xx to dynamically allocate counters
local_t: Remove cpu_local_xx macros
percpu: refactor the code in pcpu_[de]populate_chunk()
percpu: remove compile warnings caused by __verify_pcpu_ptr()
percpu: make accessors check for percpu pointer in sparse
percpu: add __percpu for sparse.
percpu: make access macros universal
percpu: remove per_cpu__ prefix.
Add __percpu sparse annotations to places which didn't make it in one
of the previous patches. All converions are trivial.
These annotations are to make sparse consider percpu variables to be
in a different address space and warn if accessed without going
through percpu accessors. This patch doesn't affect normal builds.
Acked-by: Borislav Petkov <borislav.petkov@amd.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Huang Ying <ying.huang@intel.com>
Cc: Neil Brown <neilb@suse.de>
acpi_integer is now obsolete and removed from the ACPICA code base,
replaced by u64.
When we call _PDC, we get a handle to the processor, allocate the
object list buffer as needed, and free it immediately after calling
_PDC.
There's no need to drag around this object list with us everywhere
else, so let's just get rid of it.
When calling _PDC, we really only need the handle to the processor
to call the method; we don't look at any other parts of the
struct acpi_processor * given to us.
In the early path, when we walk the namespace, we are given the
handle directly, so just pass it through to acpi_processor_set_pdc()
without stuffing it into a wasteful struct acpi_processor allocated
on the stack each time
This saves 2834 bytes of stack.
Update the interface accordingly.
The x86 and ia64 implementations of the function in $subject are
exactly the same.
Also, since the arch-specific implementations of setting _PDC have
been completely hollowed out, remove the empty shells.
The only thing arch-specific about calling _PDC is what bits get
set in the input obj_list buffer.
There's no need for several levels of indirection to twiddle those
bits. Additionally, since we're just messing around with a buffer,
we can simplify the interface; no need to pass around the entire
struct acpi_processor * just to get at the buffer.
We discovered that at least one machine (HP Envy), methods in the DSDT
attempt to call external methods defined in a dynamically loaded SSDT.
Unfortunately, the DSDT methods we are trying to call are part of the
EC initialization, which happens very early, and the the dynamic SSDT
is only loaded when a processor _PDC method runs much later.
This results in namespace lookup errors for the (as of yet) undefined
methods.
Since Windows doesn't have any issues with this machine, we take it
as a hint that they must be evaluating _PDC much earlier than we are.
Thus, the proper thing for Linux to do should be to match the Windows
implementation more closely.
Provide a mechanism to call _PDC before we enable the EC. Doing so loads
the dynamic tables, and allows the EC to be enabled correctly.
The ACPI processor driver will still evaluate _PDC in its .add() method
to cover the hotplug case.
Resolves: http://bugzilla.kernel.org/show_bug.cgi?id=14824
Cc: ming.m.lin@intel.com
include/acpi/processor.h
This interface is mainly intended (and implemented) for ACPI _PPC BIOS
frequency limitations, but other cpufreq drivers can also use it for
similar use-cases.
Why is this needed:
Currently it's not obvious why cpufreq got limited.
People see cpufreq/scaling_max_freq reduced, but this could have
happened by:
- any userspace prog writing to scaling_max_freq
- thermal limitations
- hardware (_PPC in ACPI case) limitiations
Therefore export bios_limit (in kHz) to:
- Point the user that it's the BIOS (broken or intended) which limits
frequency
- Export it as a sysfs interface for userspace progs.
While this was a rarely used feature on laptops, there will appear
more and more server implemenations providing "Green IT" features like
allowing the service processor to limit the frequency. People want
to know about HW/BIOS frequency limitations.
All ACPI P-state driven cpufreq drivers are covered with this patch:
- powernow-k8
- powernow-k7
- acpi-cpufreq
Tested with a patched DSDT which limits the first two cores (_PPC returns 1)
via _PPC, exposed by bios_limit:
# echo 2200000 >cpu2/cpufreq/scaling_max_freq
# cat cpu*/cpufreq/scaling_max_freq
2600000
2600000
2200000
2200000
# #scaling_max_freq shows general user/thermal/BIOS limitations
# cat cpu*/cpufreq/bios_limit
2600000
2600000
2800000
2800000
# #bios_limit only shows the HW/BIOS limitation
CC: Pallipadi Venkatesh <venkatesh.pallipadi@intel.com>
CC: Len Brown <lenb@kernel.org>
CC: davej@codemonkey.org.uk
CC: linux@dominikbrodowski.net
Signed-off-by: Dave Jones <davej@redhat.com>
According to the ACPI spec(section 8.4.4.3) OSPM should convey the _PPC
evaluations status to the platform if there exists the _OST object.
The _OST contains two arguments:
The first is the PERFORMANCE notificatin event.
The second is the status of _PPC object.
OSPM will convey the _PPC evaluation status to the platform.
Of course when the module parameter of "ignore_ppc" is added, OSPM won't
evaluate the _PPC object. But it will call the _OST object.
At the same time the _OST object will be evaluated only when the PERFORMANCE
notification event is received.
If the BIOS reports an invalid throttling state (which seems to be
fairly common after system boot), a reset is done to state T0.
Because of a check in acpi_processor_get_throttling_ptc(), the reset
never actually gets executed, which results in the error reoccurring
on every access of for example /proc/acpi/processor/CPU0/throttling.
Add a 'force' option to acpi_processor_set_throttling() to ensure
the reset really takes effect.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13389
This patch, together with the next one, fixes a regression introduced in
2.6.30, listed on the regression list. They have been available for 2.5
months now in bugzilla, but have not been picked up, despite various
reminders and without any reason given.
Google shows that numerous people are hitting this issue. The issue is in
itself relatively minor, but the bug in the code is clear.
The patches have been in all my kernels and today testing has shown that
throttling works correctly with the patches applied when the system
overheats (http://bugzilla.kernel.org/show_bug.cgi?id=13918#c14).
Signed-off-by: Frans Pop <elendil@planet.nl>
Acked-by: Zhang Rui <rui.zhang@intel.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
arch_acpi_processor_cleanup_pdc() in x86 and ia64 results in memory allocated
for _PDC objects that is never freed and will cause memory leak in case of
physical CPU remove and add. Patch fixes the memory leak by freeing the
objects soon after _PDC is evaluated.
Reported-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Linux-2.6.29 deleted the legacy ACPI idle handler, leaving
the CPU_IDLE handler, which does not track bus master activity.
So delete the unused bm_activity field -- it is confusing to
print an always zero value.
This patch could break programs that parse
/proc/acpi/processor/*/power, since it deletes this
line from that file:
bus master activity: 00000000
http://bugzilla.kernel.org/show_bug.cgi?id=13145
is not fixed by this patch, but provoked this patch.
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Impact: Reduce memory usage, use new API.
This is part of an effort to reduce structure sizes for machines
configured with large NR_CPUS. cpumask_t gets replaced by
cpumask_var_t, which is either struct cpumask[1] (small NR_CPUS) or
struct cpumask * (large NR_CPUS).
(Changes to powernow-k* by <travis>.)
Signed-off-by: Mike Travis <travis@sgi.com>
Change processors from an array sized by NR_CPUS to a per_cpu variable.
This patch adds a proper prototype for acpi_processor_tstate_has_changed()
in include/acpi/processor.h
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Add a new sysfs entry under cpuidle states. desc - can be used by driver to
communicate to userspace any specific information about the state.
This helps in identifying the exact hardware C-states behind the ACPI C-state
definition.
Idea is to export this through powertop, which will help to map the C-state
reported by powertop to actual hardware C-state.
drivers/acpi/video.c
Add MWAIT idle for C1 state instead of halt, on platforms that support
C1 state with MWAIT.
Renames cx->space_id to something more appropriate.
Accordint to ACPI spec, the _TSD object provides T-state control cross
logical processor dependency information to OSPM.
After the _TSD data for all cpus are obtained, OSPM will set up
the T-state coordination between CPUs.
Of course if the _TSD doesn't exist or _TSD data is incorrect , it is
assumed that there is no T-state coordination and T-state is changed
independently.
Now there is no proper solution to update T-state coordination after
one cpu is hotplugged. So this patch won't support hotplugged cpu very well.
Register ACPI processor as thermal cooling devices.
A combination of processor T-state and P-state are used for thermal throttling.
the processor will reduce the frequency first and then set the T-state.
we use cpufreq_thermal_reduction_pctg to calculate the cpufreq limit,
and call cpufreq_verify_with_limit to set the cpufreq limit.
if cpufreq driver is loaded, then we have four cooling state for cpufreq control.
cooling state 0: cpufreq limit == max_freq
cooling state 1: cpufreq limit == max_freq * 80%
cooling state 2: cpufreq limit == max_freq * 60%
cooling state 3: cpufreq limit == max_freq * 40%
after the cpufreq limit is set to 40 percentage of the max_freq,
we use T-state for cooling.
eg. a processor has P-state support, and it has 8 T-state (T0-T7),
the max_state of the proceesor is 10:
state cpufreq-limit T-state
0: max_freq T0
1: max_freq * 80% T0
2: max_freq * 60% T0
3: max_freq * 40% T0
4: max_freq * 40% T1
5: max_freq * 40% T2
6: max_freq * 40% T3
7: max_freq * 40% T4
8: max_freq * 40% T5
9: max_freq * 40% T6
10: max_freq * 40% T7
Signed-off-by: Thomas Sujith <sujith.thomas@intel.com>
Fix for http://bugzilla.kernel.org/show_bug.cgi?id=9355
cpuidle always used to fallback to C2 if there is some bm activity while
entering C3. But, presence of C2 is not always guaranteed. Change cpuidle
algorithm to detect a safe_state to fallback in case of bm_activity and
use that state instead of C2.
commit e5a16b1f9eec0af7cfa0830304b41c1c0833cf9f
Author: Len Brown <len.brown@intel.com>
Date: Tue Oct 2 23:44:44 2007 -0400
cpuidle: shrink diff
processor_idle.c | 440 +++++++++++++++++++++++++++++++++++++++++--
1 file changed, 429 insertions(+), 11 deletions(-)
commit dfbb9d5aedfb18848a3e0d6f6e3e4969febb209c
Date: Wed Sep 26 02:17:55 2007 -0400
cpuidle: reduce diff size
Reduces the cpuidle processor_idle.c diff vs 2.6.22 from this
processor_idle.c | 2006 ++++++++++++++++++++++++++-----------------
1 file changed, 1219 insertions(+), 787 deletions(-)
to this:
processor_idle.c | 502 +++++++++++++++++++++++++++++++++++++++----
1 file changed, 458 insertions(+), 44 deletions(-)
...for the purpose of making the cpuilde patch less invasive
and easier to review.
no functional changes. build tested only.
commit 889172fc915f5a7fe20f35b133cbd205ce69bf6c
Author: Venki Pallipadi <venkatesh.pallipadi@intel.com>
Date: Thu Sep 13 13:40:05 2007 -0700
cpuidle: Retain old ACPI policy for !CONFIG_CPU_IDLE
Retain the old policy in processor_idle, so that when CPU_IDLE is not
configured, old C-state policy will still be used. This provides a
clean gradual migration path from old ACPI policy to new cpuidle
based policy.
commit 9544a8181edc7ecc33b3bfd69271571f98ed08bc
Date: Thu Sep 13 13:39:17 2007 -0700
cpuidle: Configure governors by default
Quoting Len "Do not give an option to users to shoot themselves in the foot".
Remove the configurability of ladder and menu governors as they are
needed for default policy of cpuidle. That way users will not be able to
have cpuidle without any policy loosing all C-state power savings.
commit 8975059a2c1e56cfe83d1bcf031bcf4cb39be743
Author: Adam Belay <abelay@novell.com>
Date: Tue Aug 21 18:27:07 2007 -0400
CPUIDLE: load ACPI properly when CPUIDLE is disabled
Change the registration return codes for when CPUIDLE
support is not compiled into the kernel. As a result, the ACPI
processor driver will load properly even if CPUIDLE is unavailable.
However, it may be possible to cleanup the ACPI processor driver further
and eliminate some dead code paths.
Signed-off-by: Adam Belay <abelay@novell.com>
commit e0322e2b58dd1b12ec669bf84693efe0dc2414a8
Date: Tue Aug 21 18:26:06 2007 -0400
CPUIDLE: remove cpuidle_get_bm_activity()
Remove cpuidle_get_bm_activity() and updates governors
accordingly.
commit 18a6e770d5c82ba26653e53d240caa617e09e9ab
Date: Tue Aug 21 18:25:58 2007 -0400
CPUIDLE: max_cstate fix
Currently max_cstate is limited to 0, resulting in no idle processor
power management on ACPI platforms. This patch restores the value to
the array size.
commit 1fdc0887286179b40ce24bcdbde663172e205ef0
Date: Tue Aug 21 18:25:40 2007 -0400
CPUIDLE: handle BM detection inside the ACPI Processor driver
Update the ACPI processor driver to detect BM activity and
limit state entry depth internally, rather than exposing such
requirements to CPUIDLE. As a result, CPUIDLE can drop this
ACPI-specific interface and become more platform independent. BM
activity is now handled much more aggressively than it was in the
original implementation, so some testing coverage may be needed to
verify that this doesn't introduce any DMA buffer under-run issues.
commit 0ef38840db666f48e3cdd2b769da676c57228dd9
Date: Tue Aug 21 18:25:14 2007 -0400
CPUIDLE: menu governor updates
Tweak the menu governor to more effectively handle non-timer
break events. Non-timer break events are detected by comparing the
actual sleep time to the expected sleep time. In future revisions, it
may be more reliable to use the timer data structures directly.
commit bb4d74fca63fa96cf3ace644b15ae0f12b7df5a1
Date: Tue Aug 21 18:24:40 2007 -0400
CPUIDLE: fix 'current_governor' sysfs entry
Allow the "current_governor" sysfs entry to properly handle
input terminated with '\n'.
commit df3c71559bb69b125f1a48971bf0d17f78bbdf47
Date: Sun Aug 12 02:00:45 2007 -0400
cpuidle: fix IA64 build (again)
commit a02064579e3f9530fd31baae16b1fc46b5a7bca8
Author: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Date: Sun Aug 12 01:39:27 2007 -0400
cpuidle: Remove support for runtime changing of max_cstate
Remove support for runtime changeability of max_cstate. Drivers can use
use latency APIs.
max_cstate can still be used as a boot time option and dmi override.
commit 0912a44b13adf22f5e3f607d263aed23b4910d7e
Date: Sun Aug 12 01:39:16 2007 -0400
cpuidle: Remove ACPI cstate_limit calls from ipw2100
ipw2100 already has code to use accetable_latency interfaces to limit the
C-state. Remove the calls to acpi_set_cstate_limit and acpi_get_cstate_limit
as they are redundant.
commit c649a76e76be6bff1fd770d0a775798813a3f6e0
Date: Sun Aug 12 01:35:39 2007 -0400
cpuidle: compile fix for pause and resume functions
Fix the compilation failure when cpuidle is not compiled in.
Acked-by: Adam Belay <adam.belay@novell.com>
commit 2305a5920fb8ee6ccec1c62ade05aa8351091d71
Date: Thu Jul 19 00:49:00 2007 -0400
cpuidle: re-write
Some portions have been rewritten to make the code cleaner and lighter
weight. The following is a list of changes:
1.) the state name is now included in the sysfs interface
2.) detection, hotplug, and available state modifications are handled by
CPUIDLE drivers directly
3.) the CPUIDLE idle handler is only ever installed when at least one
cpuidle_device is enabled and ready
4.) the menu governor BM code no longer overflows
5.) the sysfs attributes are now printed as unsigned integers, avoiding
negative values
6.) a variety of other small cleanups
Also, Idle drivers are no longer swappable during runtime through the
CPUIDLE sysfs inteface. On i386 and x86_64 most idle handlers (e.g.
poll, mwait, halt, etc.) don't benefit from an infrastructure that
supports multiple states, so I think using a more general case idle
handler selection mechanism would be cleaner.
Acked-by: Shaohua Li <shaohua.li@intel.com>
commit df25b6b56955714e6e24b574d88d1fd11f0c3ee5
Date: Tue Jul 24 17:08:21 2007 -0400
cpuidle: fix IA64 buid
commit fd6ada4c14488755ff7068860078c437431fbccd
Author: Adrian Bunk <bunk@stusta.de>
Date: Mon Jul 9 11:33:13 2007 -0700
cpuidle: static
make cpuidle_replace_governor() static
Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
commit c1d4a2cebcadf2429c0c72e1d29aa2a9684c32e0
Date: Tue Jul 3 00:54:40 2007 -0400
cpuidle: static
This patch makes the needlessly global struct menu_governor static.
commit dbf8780c6e8d572c2c273da97ed1cca7608fd999
Author: Andrew Morton <akpm@linux-foundation.org>
Date: Tue Jul 3 00:49:14 2007 -0400
export symbol tick_nohz_get_sleep_length
ERROR: "tick_nohz_get_sleep_length" [drivers/cpuidle/governors/menu.ko] undefined!
ERROR: "tick_nohz_get_idle_jiffies" [drivers/cpuidle/governors/menu.ko] undefined!
And please be sure to get your changes to core kernel suitably reviewed.
Cc: Adam Belay <abelay@novell.com>
Cc: Venki Pallipadi <venkatesh.pallipadi@intel.com>
Cc: john stultz <johnstul@us.ibm.com>
commit 29f0e248e7017be15f99febf9143a2cef00b2961
Date: Tue Jul 3 00:43:04 2007 -0400
tick.h needs hrtimer.h
It uses hrtimers.
commit e40cede7d63a029e92712a3fe02faee60cc38fb4
Date: Tue Jul 3 00:40:34 2007 -0400
cpuidle: first round of documentation updates
Documentation changes based on Pavel's feedback.
commit 83b42be2efece386976507555c29e7773a0dfcd1
Date: Tue Jul 3 00:39:25 2007 -0400
cpuidle: add rating to the governors and pick the one with highest rating by default
Introduce a governor rating scheme to pick the right governor by default.
commit d2a74b8c5e8f22def4709330d4bfc4a29209b71c
Date: Tue Jul 3 00:38:08 2007 -0400
cpuidle: make cpuidle sysfs driver governor switch off by default
Make default cpuidle sysfs to show current_governor and current_driver in
read-only mode. More elaborate available_governors and available_drivers with
writeable current_governor and current_driver interface only appear with
"cpuidle_sysfs_switch" boot parameter.
commit 1f60a0e80bf83cf6b55c8845bbe5596ed8f6307b
Date: Tue Jul 3 00:37:00 2007 -0400
cpuidle: menu governor: change the early break condition
Change the C-state early break out algorithm in menu governor.
We only look at early breakouts that result in wakeups shorter than idle
state's target_residency. If such a breakout is frequent enough, eliminate
the particular idle state upto a timeout period.
commit 45a42095cf64b003b4a69be3ce7f434f97d7af51
Date: Tue Jul 3 00:35:38 2007 -0400
cpuidle: fix uninitialized variable in sysfs routine
Fix the uninitialized usage of ret.
commit 80dca7cdba3e6ee13eae277660873ab9584eb3be
Date: Tue Jul 3 00:34:16 2007 -0400
cpuidle: reenable /proc/acpi//power interface for the time being
Keep /proc/acpi/processor/CPU*/power around for a while as powertop depends
on it. It will be marked deprecated and removed in future. powertop can use
cpuidle interfaces instead.
commit 589c37c2646c5e3813a51255a5ee1159cb4c33fc
Date: Tue Jul 3 00:32:37 2007 -0400
cpuidle: menu governor and hrtimer compile fix
Compile fix for menu governor.
commit 0ba80bd9ab3ed304cb4f19b722e4cc6740588b5e
Date: Thu May 31 22:51:43 2007 -0400
cpuidle: build fix - cpuidle vs ipw2100 module
ERROR: "acpi_set_cstate_limit" [drivers/net/wireless/ipw2100.ko] undefined!
commit d7d8fa7f96a7f7682be7c6cc0cc53fa7a18c3b58
Date: Sat Mar 24 03:47:07 2007 -0400
cpuidle: add the 'menu' governor
Here is my first take at implementing an idle PM governor that takes
full advantage of NO_HZ. I call it the 'menu' governor because it
considers the full list of idle states before each entry.
I've kept the implementation fairly simple. It attempts to guess the
next residency time and then chooses a state that would meet at least
the break-even point between power savings and entry cost. To this end,
it selects the deepest idle state that satisfies the following
constraints:
1. If the idle time elapsed since bus master activity was detected
is below a threshold (currently 20 ms), then limit the selection
to C2-type or above.
2. Do not choose a state with a break-even residency that exceeds
the expected time remaining until the next timer interrupt.
3. Do not choose a state with a break-even residency that exceeds
the elapsed time between the last pair of break events,
excluding timer interrupts.
This governor has an advantage over "ladder" governor because it
proactively checks how much time remains until the next timer interrupt
using the tick infrastructure. Also, it handles device interrupt
activity more intelligently by not including timer interrupts in break
event calculations. Finally, it doesn't make policy decisions using the
number of state entries, which can have variable residency times (NO_HZ
makes these potentially very large), and instead only considers sleep
time deltas.
The menu governor can be selected during runtime using the cpuidle sysfs
interface like so:
"echo "menu" > /sys/devices/system/cpu/cpuidle/current_governor"
commit a4bec7e65aa3b7488b879d971651cc99a6c410fe
Date: Sat Mar 24 03:47:03 2007 -0400
cpuidle: export time until next timer interrupt using NO_HZ
Expose information about the time remaining until the next
timer interrupt expires by utilizing the dynticks infrastructure.
Also modify the main idle loop to allow dynticks to handle
non-interrupt break events (e.g. DMA). Finally, expose sleep ticks
information to external code. Thomas Gleixner is responsible for much
of the code in this patch. However, I've made some additional changes,
so I'm probably responsible if there are any bugs or oversights :)
commit 2929d8996fbc77f41a5ff86bb67cdde3ca7d2d72
Date: Sat Mar 24 03:46:58 2007 -0400
cpuidle: governor API changes
This patch prepares cpuidle for the menu governor. It adds an optional
stage after idle state entry to give the governor an opportunity to
check why the state was exited. Also it makes sure the idle loop
returns after each state entry, allowing the appropriate dynticks code
to run.
commit 3a7fd42f9825c3b03e364ca59baa751bb350775f
Date: Thu Apr 26 00:03:59 2007 -0700
cpuidle: hang fix
Prevent hang on x86-64, when ACPI processor driver is added as a module on
a system that does not support C-states.
x86-64 expects all idle handlers to enable interrupts before returning from
idle handler. This is due to enter_idle(), exit_idle() races. Make
cpuidle_idle_call() confirm to this when there is no pm_idle_old.
Also, cpuidle look at the return values of attch_driver() and set
current_driver to NULL if attach fails on all CPUs.
commit 4893339a142afbd5b7c01ffadfd53d14746e858e
Author: Shaohua Li <shaohua.li@intel.com>
Date: Thu Apr 26 10:40:09 2007 +0800
cpuidle: add support for max_cstate limit
With CPUIDLE framework, the max_cstate (to limit max cpu c-state)
parameter is ingored. Some systems require it to ignore C2/C3
and some drivers like ipw require it too.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
commit 43bbbbe1cb998cbd2df656f55bb3bfe30f30e7d1
Date: Thu Apr 26 10:40:13 2007 +0800
cpuidle: add cpuidle_fore_redetect_devices API
add cpuidle_force_redetect_devices API,
which forces all CPU redetect idle states.
Next patch will use it.
commit d1edadd608f24836def5ec483d2edccfb37b1d19
Date: Thu Apr 26 10:40:01 2007 +0800
cpuidle: fix sysfs related issue
Fix the cpuidle sysfs issue.
a. make kobject dynamicaly allocated
b. fixed sysfs init issue to avoid suspend/resume issue
commit 7169a5cc0d67b263978859672e86c13c23a5570d
Author: Randy Dunlap <randy.dunlap@oracle.com>
Date: Wed Mar 28 22:52:53 2007 -0400
cpuidle: 1-bit field must be unsigned
A 1-bit bitfield has no room for a sign bit.
drivers/cpuidle/governors/ladder.c:54:16: error: dubious bitfield without explicit `signed' or `unsigned'
commit 4658620158dc2fbd9e4bcb213c5b6fb5d05ba7d4
Date: Wed Mar 28 22:52:41 2007 -0400
cpuidle: fix boot hang
Patch for cpuidle boot hang reported by Larry Finger here.
http://www.ussg.iu.edu/hypermail/linux/kernel/0703.2/2025.html
Cc: Larry Finger <larry.finger@lwfinger.net>
commit c17e168aa6e5fe3851baaae8df2fbc1cf11443a9
Date: Wed Mar 7 04:37:53 2007 -0500
cpuidle: ladder does not depend on ACPI
build fix for CONFIG_ACPI=n
In file included from drivers/cpuidle/governors/ladder.c:21:
include/acpi/processor.h:88: error: expected specifier-qualifier-list before âacpi_integerâ
include/acpi/processor.h:106: error: expected specifier-qualifier-list before âacpi_integerâ
include/acpi/processor.h:168: error: expected specifier-qualifier-list before âacpi_handleâ
commit 8c91d958246bde68db0c3f0c57b535962ce861cb
Date: Tue Mar 6 02:29:40 2007 -0800
cpuidle: make code static
This patch makes the following needlessly global code static:
- driver.c: __cpuidle_find_driver()
- governor.c: __cpuidle_find_governor()
- ladder.c: struct ladder_governor
Cc: Shaohua Li <shaohua.li@intel.com>
commit 0c39dc3187094c72c33ab65a64d2017b21f372d2
Date: Wed Mar 7 02:38:22 2007 -0500
cpu_idle: fix build break
This patch fixes a build breakage with !CONFIG_HOTPLUG_CPU and
CONFIG_CPU_IDLE.
commit 8112e3b115659b07df340ef170515799c0105f82
Date: Tue Mar 6 02:29:39 2007 -0800
cpuidle: build fix for !CPU_IDLE
Fix the compile issues when CPU_IDLE is not configured.
commit 1eb4431e9599cd25e0d9872f3c2c8986821839dd
Date: Thu Feb 22 13:54:57 2007 -0800
cpuidle take2: Basic documentation for cpuidle
Documentation for cpuidle infrastructure
commit ef5f15a8b79123a047285ec2e3899108661df779
Date: Thu Feb 22 13:54:03 2007 -0800
cpuidle take2: Hookup ACPI C-states driver with cpuidle
Hookup ACPI C-states onto generic cpuidle infrastructure.
drivers/acpi/procesor_idle.c is now a ACPI C-states driver that registers as
a driver in cpuidle infrastructure and the policy part is removed from
drivers/acpi/processor_idle.c. We use governor in cpuidle instead.
commit 987196fa82d4db52c407e8c9d5dec884ba602183
Date: Thu Feb 22 13:52:57 2007 -0800
cpuidle take2: Core cpuidle infrastructure
Announcing 'cpuidle', a new CPU power management infrastructure to manage
idle CPUs in a clean and efficient manner.
cpuidle separates out the drivers that can provide support for multiple types
of idle states and policy governors that decide on what idle state to use
at run time.
A cpuidle driver can support multiple idle states based on parameters like
varying power consumption, wakeup latency, etc (ACPI C-states for example).
A cpuidle governor can be usage model specific (laptop, server,
laptop on battery etc).
Main advantage of the infrastructure being, it allows independent development
of drivers and governors and allows for better CPU power management.
A huge thanks to Adam Belay and Shaohua Li who were part of this mini-project
since its beginning and are greatly responsible for this patchset.
This patch:
Core cpuidle infrastructure.
Introduces a new abstraction layer for cpuidle:
* which manages drivers that can support multiple idles states. Drivers
can be generic or particular to specific hardware/platform
* allows pluging in multiple policy governors that can take idle state policy
decision
* The core also has a set of sysfs interfaces with which administrato can know
about supported drivers and governors and switch them at run time.
device_suspend() calls ACPI suspend functions, which seems to have undesired
side effects on lower idle C-states. It took me some time to realize that
especially the VAIO BIOSes (both Andrews jinxed UP and my elfstruck SMP one)
show this effect. I'm quite sure that other bug reports against suspend/resume
about turning the system into a brick have the same root cause.
After fishing in the dark for quite some time, I realized that removing the ACPI
processor module before suspend (this removes the lower C-state functionality)
made the problem disappear. Interestingly enough the propability of having a
bricked box is influenced by various factors (interrupts, size of the ram image,
...). Even adding a bunch of printks in the wrong places made the problem go
away. The previous periodic tick implementation simply pampered over the
problem, which explains why the dyntick / clockevents changes made this more
prominent.
We avoid complex functionality during the boot process and we have to do the
same during suspend/resume. It is a similar scenario and equaly fragile.
Add suspend / resume functions to the ACPI processor code and disable the lower
idle C-states across suspend/resume. Fall back to the default idle
implementation (halt) instead.
Tested-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
This patch addresses some issues in x86/x86-64 acpi-cpufreq driver:
1. Current memory allocation for acpi_perf_data is actually open-coded
alloc_percpu(). The patch defines and handles acpi_perf_data as percpu
data. The code will be cleaner and easier to be maintained with this
change.
2. Won't load driver in acpi_cpufreq_early_init() failure case.
3. Add __init for acpi_cpufreq_early_init().
Signed-off-by: Fenghua Yu <fenghua.yu@intel.com>
Cc: Dave Jones <davej@codemonkey.org.uk>
adds _TPC _TSS _PTC -- Throttling Present Capabilities
Signed-off-by: Luming Yu <luming.yu@intel.com>
