Add function acpi_bus_update_power() for reading the actual power
state of an ACPI device and updating its device->power.state field
in such a way that its power resources' reference counters will
remain consistent with that field.
For this purpose introduce __acpi_bus_set_power() setting the
power state of an ACPI device without updating its
device->power.state field and make acpi_bus_set_power() and
acpi_bus_update_power() use it (acpi_bus_set_power() retains the
current behavior for now).
Signed-off-by: Len Brown <len.brown@intel.com>
Version 20101209.
Signed-off-by: Bob Moore <robert.moore@intel.com>
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
The global event handler is called whenever a general purpose
or fixed ACPI event occurs.
Also update Linux OSL to collect events counter with
global event handler.
This feature provides an automatic device notification for wake devices
when a wakeup GPE occurs and there is no corresponding GPE method or
handler. Rather than ignoring such a GPE, an implicit AML Notify
operation is performed on the parent device object.
This feature is not part of the ACPI specification and is provided for
Windows compatibility only.
The new GPE handler callback has 2 additional parameters, gpe_device and
gpe_number.
typedef
u32 (*acpi_gpe_handler) (acpi_handle gpe_device, u32 gpe_number, void *context);
Some function and variable names are renamed to be consistent with
ACPICA code base.
acpi_raw_enable_gpe -> acpi_ev_add_gpe_reference
acpi_raw_disable_gpe -> acpi_ev_remove_gpe_reference
acpi_gpe_can_wake -> acpi_setup_gpe_for_wake
acpi_gpe_wakeup -> acpi_set_gpe_wake_mask
acpi_update_gpes -> acpi_update_all_gpes
acpi_all_gpes_initialized -> acpi_gbl_all_gpes_initialized
acpi_handler_info -> acpi_gpe_handler_info
online/offline
After one CPU is offlined, it is unnecessary to switch T-state for it.
So it will be better that the throttling is disabled after the cpu
is offline.
At the same time after one cpu is online, we should check whether
the T-state is supported and then set the corresponding T-state
flag.
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
Drop special ACPI wakeup flags, wakeup.state.enabled and
wakeup.flags.always_enabled, that aren't necessary any more after
we've started to use standard device wakeup flags for handling ACPI
wakeup devices.
MAINTAINERS
arch/arm/mach-omap2/pm24xx.c
drivers/scsi/bfa/bfa_fcpim.c
Needed to update to apply fixes for which the old branch was too
outdated.
In file included from drivers/gpu/drm/i915/intel_opregion.c:30:
include/acpi/video.h:22: warning: ‘struct acpi_device’ declared inside parameter list
include/acpi/video.h:24: error: ‘ENODEV’ undeclared (first use in this function)
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
"gadget", "through", "command", "maintain", "maintain", "controller", "address",
"between", "initiali[zs]e", "instead", "function", "select", "already",
"equal", "access", "management", "hierarchy", "registration", "interest",
"relative", "memory", "offset", "already",
into release
drivers/acpi/acpica/aclocal.h
Found by running make namespacecheck on linux-next
Version 20101013.
There is a number of problems with acpi_pm_device_sleep_state() now.
First, if _S0W is not defined, it prevents devices from being put
into D3 by PCI runtime PM, which shouldn't happen. Second, it
shouldn't use adev->wakeup.state.enabled, because if it's set, it
only means that either the device is permanently enabled to wake up
the system, or that it has been enabled to do that through
/proc/acpi/wakeup. Finally, it should be compiled if CONFIG_PM_SLEEP
is not set, so that PCI runtime PM works correctly in that case.
Fix these problems.
Reported-by: Matthew Garrett <mjg59@srcf.ucam.org>
Signed-off-by: Thomas Renninger <trenn@suse.de>
Version 20100915.
Added extern for this boolean in acpixf.h. Some hosts utilize
this value during suspend/restore operations.
Move the 64-bit overlay structures to the utmath module since
they are used nowhere else. Update module comment. ACPICA BZ 829.
http://www.acpica.org/bugzilla/show_bug.cgi?id=829
Change definition of acpi_thread_id to always be a u64. This
simplifies the code, especially any printf output. u64 is
the only common data type for all thread_id types across all
operating systems. We now force the OSL to cast the native
thread_id type to u64 before returning the value to ACPICA
(via acpi_os_get_thread_id).
The C inline keyword is not standardized, ACPI_INLINE allows this
to be configured on a per-compiler basis.
This function is not OS-dependent and has been replaced by
acpi_hw_derive_pci_id, which is now in the ACPICA core code. Local
implementations of acpi_os_derive_pci_id are no longer necessary and
are removed. ACPICA BZ 857.
http://www.acpica.org/bugzilla/show_bug.cgi?id=857
Version 20100806.
Adds install/remove interfaces so that the host can dynamically
alter the global _OSI table. Also adds support for _OSI handlers.
Additional support: new debugger command (osi), and test support in
the acpiexec utility. Adds new file, utilities/utosi.c.
ACPICA bugzilla 836.
The Linux OSL _OSI code is also changed.
acpi_osi_setup can't call acpi_install/remove_interface because ACPICA
is not initialized yet at this early time.
So we just save the osi string in acpi_osi_setup and will handle it
later in a new function acpi_osi_setup_late.
http://www.acpica.org/bugzilla/show_bug.cgi?id=836
Prototype in acpiosxf.h had the output value pointer as a (u32 *).
Should be a (u64 *).
The current ACPI GPEs initialization code has a problem that it
enables some GPEs pointed to by device _PRW methods, generally
intended for signaling wakeup events (system or device wakeup).
These GPEs are then almost immediately disabled by the ACPI namespace
scanning code with the help of acpi_gpe_can_wake(), but it would be
better not to enable them at all until really necessary.
Modify the initialization of GPEs so that the ones that have
associated _Lxx or _Exx methods and are not pointed to by any _PRW
methods will be enabled after the namespace scan is complete.
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: bus speed strings should be const
PCI hotplug: Fix build with CONFIG_ACPI unset
PCI: PCIe: Remove the port driver module exit routine
PCI: PCIe: Move PCIe PME code to the pcie directory
PCI: PCIe: Disable PCIe port services during port initialization
PCI: PCIe: Ask BIOS for control of all native services at once
ACPI/PCI: Negotiate _OSC control bits before requesting them
ACPI/PCI: Do not preserve _OSC control bits returned by a query
ACPI/PCI: Make acpi_pci_query_osc() return control bits
ACPI/PCI: Reorder checks in acpi_pci_osc_control_set()
PCI: PCIe: Introduce commad line switch for disabling port services
PCI: PCIe AER: Introduce pci_aer_available()
x86/PCI: only define pci_domain_nr if PCI and PCI_DOMAINS are set
PCI: provide stub pci_domain_nr function for !CONFIG_PCI configs
There is the assumption in acpi_pci_osc_control_set() that it is
always sufficient to compare the mask of _OSC control bits to be
requested with the result of an _OSC query where all of the known
control bits have been checked. However, in general, that need not
be the case. For example, if an _OSC feature A depends on an _OSC
feature B and control of A, B plus another _OSC feature C is
requested simultaneously, the BIOS may return A, B, C, while it would
only return C if A and C were requested without B.
That may result in passing a wrong mask of _OSC control bits to an
_OSC control request, in which case the BIOS may only grant control
of a subset of the requested features. Moreover, acpi_pci_run_osc()
will return error code if that happens and the caller of
acpi_pci_osc_control_set() will not know that it's been granted
control of some _OSC features. Consequently, the system will
generally not work as expected.
Apart from this acpi_pci_osc_control_set() always uses the mask
of _OSC control bits returned by the very first invocation of
acpi_pci_query_osc(), but that is done with the second argument
equal to OSC_PCI_SEGMENT_GROUPS_SUPPORT which generally happens
to affect the returned _OSC control bits.
For these reasons, make acpi_pci_osc_control_set() always check if
control of the requested _OSC features will be granted before making
the final control request. As a result, the osc_control_qry and
osc_queried members of struct acpi_pci_root are not necessary any
more, so drop them and remove the remaining code referring to them.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
drivers/acpi/debug.c
Remove deprecated ACPI processor procfs I/F, including:
/proc/acpi/processor/CPUX/power
/proc/acpi/processor/CPUX/limit
/proc/acpi/processor/CPUX/info
/proc/acpi/processor/CPUX/throttling still exists,
as we don't have sysfs I/F available for now.
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Introduce module parameter acpi.aml_debug_output.
With acpi.aml_debug_output set, we can get AML debug object output
(Store (AAA, Debug)), even with CONFIG_ACPI_DEBUG cleared.
Together with the runtime custom method mechanism,
we can debug AML code problems without rebuilding the kernel.
The ACPI_PREEMPTION_POINT() logic was introduced in commit 8bd108d
(ACPICA: add preemption point after each opcode parse). The follow up
commits abe1dfab6, 138d15692, c084ca70 tried to fix the preemption logic
back and forth, but nobody noticed that the usage of
in_atomic_preempt_off() in that context is wrong.
The check which guards the call of cond_resched() is:
if (!in_atomic_preempt_off() && !irqs_disabled())
in_atomic_preempt_off() is not intended for general use as the comment
above the macro definition clearly says:
* Check whether we were atomic before we did preempt_disable():
* (used by the scheduler, *after* releasing the kernel lock)
On a CONFIG_PREEMPT=n kernel the usage of in_atomic_preempt_off() works by
accident, but with CONFIG_PREEMPT=y it's just broken.
The whole purpose of the ACPI_PREEMPTION_POINT() is to reduce the latency
on a CONFIG_PREEMPT=n kernel, so make ACPI_PREEMPTION_POINT() depend on
CONFIG_PREEMPT=n and remove the in_atomic_preempt_off() check.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=16210
[akpm@linux-foundation.org: fix build]
Cc: Len Brown <lenb@kernel.org>
Cc: Francois Valenduc <francois.valenduc@tvcablenet.be>
Cc: Lin Ming <ming.m.lin@intel.com>
Cc: <stable@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'acpica' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (27 commits)
ACPI / ACPICA: Simplify acpi_ev_initialize_gpe_block()
ACPI / ACPICA: Fail acpi_gpe_wakeup() if ACPI_GPE_CAN_WAKE is unset
ACPI / ACPICA: Do not execute _PRW methods during initialization
ACPI: Fix bogus GPE test in acpi_bus_set_run_wake_flags()
ACPICA: Update version to 20100702
ACPICA: Fix for Alias references within Package objects
ACPICA: Fix lint warning for 64-bit constant
ACPICA: Remove obsolete GPE function
ACPICA: Update debug output components
ACPICA: Add support for WDDT - Watchdog Descriptor Table
ACPICA: Drop acpi_set_gpe
ACPICA: Use low-level GPE enable during GPE block initialization
ACPI / EC: Do not use acpi_set_gpe
ACPI / EC: Drop suspend and resume routines
ACPICA: Remove wakeup GPE reference counting which is not used
ACPICA: Introduce acpi_gpe_wakeup()
ACPICA: Rename acpi_hw_gpe_register_bit
ACPICA: Update version to 20100528
ACPICA: Add signatures for undefined tables: ATKG, GSCI, IEIT
ACPICA: Optimization: Reduce the number of namespace walks
It turns out that there is a bit in the _CST for Intel FFH C3
that tells the OS if we should be checking BM_STS or not.
Linux has been unconditionally checking BM_STS.
If the chip-set is configured to enable BM_STS,
it can retard or completely prevent entry into
deep C-states -- as illustrated by turbostat:
http://userweb.kernel.org/~lenb/acpi/utils/pmtools/turbostat/
ref: Intel Processor Vendor-Specific ACPI Interface Specification
table 4 "_CST FFH GAS Field Encoding"
Bit 1: Set to 1 if OSPM should use Bus Master avoidance for this C-state
https://bugzilla.kernel.org/show_bug.cgi?id=15886
Currently, during initialization ACPICA walks the entire ACPI
namespace in search of any device objects with assciated _PRW
methods. All of the _PRW methods found are executed in the process
to extract the GPE information returned by them, so that the GPEs in
question can be marked as "able to wakeup" (more precisely, the
ACPI_GPE_CAN_WAKE flag is set for them). The only purpose of this
exercise is to avoid enabling the CAN_WAKE GPEs automatically, even
if there are _Lxx/_Exx methods associated with them. However, it is
both costly and unnecessary, because the host OS has to execute the
_PRW methods anyway to check which devices can wake up the system
from sleep states. Moreover, it then uses full information
returned by _PRW, including the GPE information, so it can take care
of disabling the GPEs if necessary.
Remove the code that walks the namespace and executes _PRW from
ACPICA and modify comments to reflect that change. Make
acpi_bus_set_run_wake_flags() disable GPEs for wakeup devices
so that they don't cause spurious wakeup events to be signaled.
This not only reduces the complexity of the ACPICA initialization
code, but in some cases it should reduce the kernel boot time as
well.
Unfortunately, for this purpose we need a new ACPICA function,
acpi_gpe_can_wake(), to be called by the host OS in order to disable
the GPEs that can wake up the system and were previously enabled by
acpi_ev_initialize_gpe_block() or acpi_ev_update_gpes() (such a GPE
should be disabled only once, because the initialization code enables
it only once, but it may be pointed to by _PRW for multiple devices
and that's why the additional function is necessary).
Version 20100702.
Add data table compiler output component
Header file support.
The acpi_set_gpe() function is a little awkward, because it doesn't
really work as advertised in the "disable" case. Namely, if a GPE
has been enabled with acpi_enable_gpe() and triggered a notification
to occur, and if acpi_set_gpe() is used to disable it before
acpi_ev_asynch_enable_gpe() runs, the GPE will be immediately enabled
by the latter as though the acpi_set_gpe() had no effect.
Thus, since it's been possible to make all of its callers use
alternative operations to disable or enable GPEs, acpi_set_gpe() can
be dropped.
After the previous patch that introduced acpi_gpe_wakeup() and
modified the ACPI suspend and wakeup code to use it, the third
argument of acpi_{enable|disable}_gpe() and the GPE wakeup
reference counter are not necessary any more. Remove them and
modify all of the users of acpi_{enable|disable}_gpe()
accordingly. Also drop GPE type constants that aren't used
any more.
ACPICA uses reference counters to avoid disabling GPEs too early in
case they have been enabled for many times. This is done separately
for runtime and for wakeup, but the wakeup GPE reference counter is
not really necessary, because GPEs are only enabled to wake up the
system at the hardware level by acpi_enter_sleep_state(). Thus it
only is necessary to set the corresponding bits in the wakeup enable
masks of these GPEs' registers right before the system enters a sleep
state. Moreover, the GPE wakeup enable bits can only be set when the
target sleep state of the system is known and they need to be cleared
immediately after wakeup regardless of how many wakeup devices are
associated with a given GPE.
On the basis of the above observations, introduce function
acpi_gpe_wakeup() to be used for setting or clearing the enable bit
corresponding to a given GPE in its enable register's enable_for_wake
mask. Modify the ACPI suspend and wakeup code the use
acpi_gpe_wakeup() instead of acpi_{enable|disable}_gpe() to set
and clear GPE enable bits in their registers' enable_for_wake masks
during system transitions to a sleep state and back to the working
state, respectively. [This will allow us to drop the third
argument of acpi_{enable|disable}_gpe() and simplify the GPE
handling code.]
Version 20100528.
These ACPI tables have been seen in the field, but the actual
table definitions are unkown at this time.
