path: root/include/asm-alpha/dma-mapping.h
2008-04-02alpha: fix ALSA DMA mmap crashIvan Kokshaysky
Make dma_alloc_coherent respect gfp flags (__GFP_COMP is one that matters). Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Tested-by: Michael Cree <mcree@orcon.net.nz> Cc: Richard Henderson <rth@twiddle.net> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30[PATCH] dma-mapping.h stubs fixAl Viro
do { } while(0) is not a good imitation of function returning void; use ((void)0) instead. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30[PATCH] missing dma_sync_single_range_for{cpu,device} on alphaAl Viro
no-op as all dma_sync_... there. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] Pass struct dev pointer to dma_cache_sync()Ralf Baechle
Pass struct dev pointer to dma_cache_sync() dma_cache_sync() is ill-designed in that it does not have a struct device pointer argument which makes proper support for systems that consist of a mix of coherent and non-coherent DMA devices hard. Change dma_cache_sync to take a struct device pointer as first argument and fix all its callers to pass it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Add struct dev pointer to dma_is_consistent()Ralf Baechle
dma_is_consistent() is ill-designed in that it does not have a struct device pointer argument which makes proper support for systems that consist of a mix of coherent and non-coherent DMA devices hard. Change dma_is_consistent to take a struct device pointer as first argument and fix the sole caller to pass it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-02-01[PATCH] alpha: dma-mapping.h: add "struct scatterlist;"Alexey Dobriyan
On alpha-jensen: CC drivers/base/platform.o In file included from include/linux/dma-mapping.h:24, from drivers/base/platform.c:16: include/asm/dma-mapping.h:36: warning: "struct scatterlist" declared inside parameter list include/asm/dma-mapping.h:36: warning: its scope is only this definition or declaration, which is probably not what you want Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] alpha: dma_map_page() fixAndrew Morton
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: dma-mapping (alpha)Al Viro
