path: root/include/asm-arm/arch-at91/io.h
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-01[ARM] fix AT91 include loopsRussell King
AT91 has one include loop in its header files: include/asm-arm/io.h <- include/asm-arm/arch-at91/io.h <- include/asm-arm/io.h Circular include dependencies are dangerous since they can result in inconsistent definitions being provided to other code, especially if '#ifndef' constructs are used. Solve this by removing the offending includes. Built tested using my AT91 configuration. Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-11[ARM] 4369/1: AT91: Fix circular dependency in header filesAndrew Victor
Resolve the circular dependency in the AT91 header files (io.h and hardware.h) by moving the at91_sys_read() and at91_sys_write() functions to io.h Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-08[ARM] 4124/1: Rename mach-at91rm9200 and arch-at91rm9200 directoriesAndrew Victor
Now that Linux includes support for the Atmel AT91SAM9260 and AT91SAM9261 processors in addition to the original Atmel AT91RM9200 (with support for more AT91 processors pending), the "mach-at91rm9200" and "arch-at91rm9200" directories should be renamed to indicate their more generic nature. The following git commands should be run BEFORE applying this patch: git-mv arch/arm/mach-at91rm9200 arch/arm/mach-at91 git-mv include/asm-arm/arch-at91rm9200 include/asm-arm/arch-at91 Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
