path: root/include/asm-arm/arch-omap/common.h
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-03ARM: OMAP: Introduce omap_globals and prcm access functions for multi-omapTony Lindgren
New struct omap_globals contains the omap processor specific module bases. Use omap_globals to set the various base addresses to make detecting omap chip type simpler. Also introduce OMAP1_IO_ADDRESS and OMAP2_IO_ADDRESS for future multi-omap patches. Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-05-09ARM: OMAP: Add calls to omap2_set_globals_*()Paul Walmsley
Add the omap2_set_globals_{242x,243x,343x}() functions. These functions are called early upon boot in the map_io() functions in the board-specific init files. This patch was accidentally left out of the earlier series. This fixes omap2 booting as noted by Kyungmin Park <kmpark@infradead.org>. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Kyungmin Park <kmpark@infradead.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-03-05ARM: OMAP: Remove compiler warning when i2c is not setKyungmin Park
Remove compiler warning when i2c is not set Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Jarkko Nikula <jarkko.nikula@nokia.com>
2008-02-08ARM: OMAP: Add helper module for board specific I2C bus registrationJarkko Nikula
This helper module simplifies I2C bus registration for different OMAP platforms by doing registration in one place only and to allow board specific bus configuration like clock rate and number of busses configured. Helper should cover OMAP processors from first to third generation. This patch just adds the feature and current implementation cleanup and board file modifications will be done in following patches. Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2005-11-10[ARM] 3143/1: OMAP 4/5: Update omap include filesTony Lindgren
Patch from Tony Lindgren This patch syncs the mainline kernel with linux-omap tree. This patch contains changes to common header files for omap1xxx and omap24xx by various omap developers, and improved cpu detection by Imre Deak Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-10[PATCH] ARM: 2802/1: OMAP update 8/11: Update OMAP arch filesTony Lindgren
Patch from Tony Lindgren This patch by various OMAP developers syncs the OMAP specific arch files with the linux-omap tree. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
