path: root/include/asm-arm/arch-pxa/pxa2xx-gpio.h
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-14[ARM] Merge most of the PXA work for initial mergeRussell King
This includes PXA work up to the SPI changes for the initial merge, since e172274ccc55d20536fbdceb6131f38e288541e0 depends on the SPI tree being merged. Conflicts: arch/arm/configs/em_x270_defconfig arch/arm/configs/xm_x270_defconfig
2008-07-07[ARM] 5079/1: Warn people when using pxa2xx-gpio.hStefan Schmidt
Warn people when using pxa2xx-gpio.h as it is only here for backwards compatibility. The new mfp-pxa2[57]x.h and the relevant API should be used instead. Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-02[ARM] 5068/1: PXA2xx Additional gpio definitionsJonathan Cameron
Some additional alternate gpio definitions relating to FFUART and USB on the pxa27x. These are used on the xbow imote2 platform. Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] pxa: V4L2 soc_camera driver for PXA270Guennadi Liakhovetski
This patch adds a driver for the Quick Capture Interface on the PXA270. It is based on the original driver from Intel, but has been re-worked multiple times since then, now it also supports the V4L2 API. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] pxa: separate GPIOs and their mode definitions to pxa2xx-gpio.heric miao
two reasons: 1. GPIO namings and their mode definitions are conceptually not part of the PXA register definitions 2. this is actually a temporary move in the transition of PXA2xx to use MFP-alike APIs (as what PXA3xx is now doing), so that legacy code will still work and new code can be added in step by step Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
