path: root/include/asm-arm/locks.h
2005-10-18[ARM] 3019/1: fix wrong commentsNicolas Pitre
Patch from Nicolas Pitre Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-26[PATCH] ARM SMP: Add ARMv6 memory barriersRussell King
Convert explicit gcc asm-based memory barriers into smp_mb() calls. These change between barrier() and the ARMv6 data memory barrier instruction depending on whether ARMv6 SMP is enabled. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-24[PATCH] ARM SMP: Fix ARMv6 spinlock and semaphore implementationsRussell King
