path: root/include/asm-arm/ptrace.h
2007-07-12[ARM] 4474/1: Do not check the PSR_F_BIT in valid_user_regsCatalin Marinas
When running Linux in non-secure mode (on ARM1176 for example), depending on the CP15 secure configuration register, the CPSR.F bit (6) might only be modified from the secure mode. However, the valid_user_regs() function checks for this bit being cleared. With commit a6c61e9d, a SIGSEGV is forced in handle_signal() if the user registers are not considered valid. The patch also ensures that the CPSR.A bit is cleared and the USR mode is set if the CPU does not support the 26bit user mode. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-12[ARM] 4453/1: Fully Decode ARM instruction set state in show_regs() tombstoneGeorge G. Davis
The ARM show_regs() tombstone only partially decodes which ARM ISA was executing at the time a fault occurred displaying either "(T)" for the Thumb case or nothing at all for other cases. This patch therefore explicitly identifies which state the processor is in at the time of a fault: ARM, Thumb, Jazelle or JazelleEE. Signed-off-by: George G. Davis <gdavis@mvista.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-06-18[ARM] Update show_regs/oops register formatRussell King
Add the kernel release and version information to the output of show_regs/oops. Add the CPU PSR register. Avoid using printk to output partial lines; always output a complete line. Re-combine the "Control" and "Table + DAC" lines after nommu separated them; we don't want to waste vertical screen space needlessly. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-06[ARM] Add comments marking in-use ptrace numbersRussell King
2006-06-28[ARM] 3665/1: crunch: add ptrace supportLennert Buytenhek
Patch from Lennert Buytenhek This patch makes it possible to get/set a task's Crunch state via the ptrace(2) system call. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-01-14[ARM] 3262/4: allow ptraced syscalls to be overridenNicolas Pitre
Patch from Nicolas Pitre This is needed by strace to properly handle the tracing of some system calls. It could be useful for other applications as well. Based on an earlier patch from Daniel Jacobowitz. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Daniel Jacobowitz <dan@debian.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-14[ARM] 3102/1: ARM EABI: stack pointer must be 64-bit aligned after a CPU ↵Nicolas Pitre
exception Patch from Nicolas Pitre The ARM EABI says that the stack pointer has to be 64-bit aligned for reasons already mentioned in patch #3101 when calling C functions. We therefore must verify and adjust sp accordingly when taking an exception from kernel mode since sp might not necessarily be 64-bit aligned if the exception occurs in the middle of a kernel function. If the exception occurs while in user mode then no sp fixup is needed as long as sizeof(struct pt_regs) as well as any additional syscall data stack space remain multiples of 8. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-04-17[PATCH] ARM: showregsRussell King
Fix show_regs() to provide a backtrace. Provide a new __show_regs() function which implements the common subset of show_regs() and die(). Add prototypes to asm-arm/system.h Signed-off-by: Russell King <rmk@arm.linux.org.uk>
