path: root/include/asm-blackfin/mach-bf537/anomaly.h
2008-08-27Blackfin arch: move include/asm-blackfin header files to arch/blackfinBryan Wu
Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-05-31Blackfin arch: update anomaly headers from toolchain trunkMike Frysinger
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-04-25[Blackfin] arch: Update anomaly list.Sonic Zhang
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2007-12-24[Blackfin] arch: update to latest anomaly sheetsMike Frysinger
Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-10-10Blackfin arch: Comply with revised Anomaly Workarounds for BF533 05000311 ↵Michael Hennerich
and BF561 05000323 Comply with revised Anomaly Workarounds for BF533 05000311 and BF561 05000323 accoring to BF533 anomaly sheet Rev. A 09/04/07 Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-08-05Blackfin arch: make sure to stub out ANOMALY_05000230 were appropriateMike Frysinger
2007-10-10Blackfin arch: to do some consolidation of common code and common name spacesRobin Getz
now all BLKFIN should be BFIN, should be no functional changes. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-08-05Blackfin arch: update to latest anomaly sheetsMike Frysinger
2007-07-25Blackfin arch: revise anomaly handling by basing things on the compiler not ↵Mike Frysinger
the kconfig defines revise anomaly handling by basing things on the compiler not the kconfig defines, so the header is stable and usable outside of the kernel. This also allows us to move some code from preprocessing to compiling (gcc culls dead code) which should help with code quality (readability, catch minor bugs, etc...). Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-07-24Blackfin arch: cleanup and standardize anomaly.h file format -- no ↵Mike Frysinger
functional changes Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-06-21Blackfin arch: update ANOMALY handlingRobin Getz
update lists for 533, 537, and add SSYNC workaround into assembly files. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-05-07blackfin architectureBryan Wu
This adds support for the Analog Devices Blackfin processor architecture, and currently supports the BF533, BF532, BF531, BF537, BF536, BF534, and BF561 (Dual Core) devices, with a variety of development platforms including those avaliable from Analog Devices (BF533-EZKit, BF533-STAMP, BF537-STAMP, BF561-EZKIT), and Bluetechnix! Tinyboards. The Blackfin architecture was jointly developed by Intel and Analog Devices Inc. (ADI) as the Micro Signal Architecture (MSA) core and introduced it in December of 2000. Since then ADI has put this core into its Blackfin processor family of devices. The Blackfin core has the advantages of a clean, orthogonal,RISC-like microprocessor instruction set. It combines a dual-MAC (Multiply/Accumulate), state-of-the-art signal processing engine and single-instruction, multiple-data (SIMD) multimedia capabilities into a single instruction-set architecture. The Blackfin architecture, including the instruction set, is described by the ADSP-BF53x/BF56x Blackfin Processor Programming Reference http://blackfin.uclinux.org/gf/download/frsrelease/29/2549/Blackfin_PRM.pdf The Blackfin processor is already supported by major releases of gcc, and there are binary and source rpms/tarballs for many architectures at: http://blackfin.uclinux.org/gf/project/toolchain/frs There is complete documentation, including "getting started" guides available at: http://docs.blackfin.uclinux.org/ which provides links to the sources and patches you will need in order to set up a cross-compiling environment for bfin-linux-uclibc This patch, as well as the other patches (toolchain, distribution, uClibc) are actively supported by Analog Devices Inc, at: http://blackfin.uclinux.org/ We have tested this on LTP, and our test plan (including pass/fails) can be found at: http://docs.blackfin.uclinux.org/doku.php?id=testing_the_linux_kernel [m.kozlowski@tuxland.pl: balance parenthesis in blackfin header files] Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Aubrey Li <aubrey.li@analog.com> Signed-off-by: Jie Zhang <jie.zhang@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
