path: root/include/asm-cris/thread_info.h
2007-11-14cris build fixes: corrected and improved NMI and IRQ handlingJesper Nilsson
Corrects compile errors and the following: - Remove oldset parameter from do_signal and do_notify_resume. - Modified to fit new consolidated IRQ handling code. - Reverse check order between external nmi and watchdog nmi to avoid false watchdog oops in case of a glitch on the nmi pin. - Return from an pin-generated NMI the same way as for other interrupts. - Moved blocking of ethernet rx/tx irq from ethernet interrupt handler to low-level asm interrupt handlers. Fixed in the multiple interrupt handler also. - Add space for thread local storage in thread_info struct. - Add NO_DMA to Kconfig, and include arch specific Kconfig using arch independent path. Include subsystem Kconfigs for pcmcia, usb, i2c, rtc and pci. Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31remove unused TIF_NOTIFY_RESUME flagStephane Eranian
Remove unused TIF_NOTIFY_RESUME flag for all processor architectures. The flag was not used excecpt on IA-64 where the patch replaces it with TIF_PERFMON_WORK. Signed-off-by: stephane eranian <eranian@hpl.hp.com> Cc: <linux-arch@vger.kernel.org> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-01-12[PATCH] death of get_thread_info/put_thread_infoAl Viro
{get,put}_thread_info() were introduced in 2.5.4 and never had been called by anything in the tree. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] CRIS update: updates for 2.6.12Mikael Starvik
Patches to make CRIS work with 2.6.12. Signed-off-by: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] streamline preempt_count type across archsJesper Juhl
The preempt_count member of struct thread_info is currently either defined as int, unsigned int or __s32 depending on arch. This patch makes the type of preempt_count an int on all archs. Having preempt_count be an unsigned type prevents the catching of preempt_count < 0 bugs, and using int on some archs and __s32 on others is not exactely "neat" - much nicer when it's just int all over. A previous version of this patch was already ACK'ed by Robert Love, and the only change in this version of the patch compared to the one he ACK'ed is that this one also makes sure the preempt_count member is consistently commented. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
