path: root/include/asm-generic/bitops
2006-03-26[PATCH] bitops: generic ↵Akinobu Mita
minix_{test,set,test_and_clear,test,find_first_zero}_bit() This patch introduces the C-language equivalents of the functions below: int minix_test_and_set_bit(int nr, volatile unsigned long *addr); int minix_set_bit(int nr, volatile unsigned long *addr); int minix_test_and_clear_bit(int nr, volatile unsigned long *addr); int minix_test_bit(int nr, const volatile unsigned long *addr); unsigned long minix_find_first_zero_bit(const unsigned long *addr, unsigned long size); In include/asm-generic/bitops/minix.h and include/asm-generic/bitops/minix-le.h This code largely copied from: include/asm-sparc/bitops.h Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: generic ext2_{set,clear}_bit_atomic()Akinobu Mita
This patch introduces the C-language equivalents of the functions below: int ext2_set_bit_atomic(int nr, volatile unsigned long *addr); int ext2_clear_bit_atomic(int nr, volatile unsigned long *addr); In include/asm-generic/bitops/ext2-atomic.h This code largely copied from: include/asm-sparc/bitops.h Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() This patch introduces the C-language equivalents of the functions below: int ext2_set_bit(int nr, volatile unsigned long *addr); int ext2_clear_bit(int nr, volatile unsigned long *addr); int ext2_test_bit(int nr, const volatile unsigned long *addr); unsigned long ext2_find_first_zero_bit(const unsigned long *addr, unsigned long size); unsinged long ext2_find_next_zero_bit(const unsigned long *addr, unsigned long size); In include/asm-generic/bitops/ext2-non-atomic.h This code largely copied from: include/asm-powerpc/bitops.h include/asm-parisc/bitops.h Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] fix error: __u32 undeclaredAkinobu Mita
Build fix for s390 declare __u32 and __u64. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: generic hweight{64,32,16,8}()Akinobu Mita
This patch introduces the C-language equivalents of the functions below: unsigned int hweight32(unsigned int w); unsigned int hweight16(unsigned int w); unsigned int hweight8(unsigned int w); unsigned long hweight64(__u64 w); In include/asm-generic/bitops/hweight.h This code largely copied from: include/linux/bitops.h Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: generic ffs()Akinobu Mita
This patch introduces the C-language equivalent of the function: int ffs(int x); In include/asm-generic/bitops/ffs.h This code largely copied from: include/linux/bitops.h Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: generic sched_find_first_bit()Akinobu Mita
This patch introduces the C-language equivalent of the function: int sched_find_first_bit(const unsigned long *b); In include/asm-generic/bitops/sched.h This code largely copied from: include/asm-powerpc/bitops.h Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: generic find_{next,first}{,_zero}_bit()Akinobu Mita
This patch introduces the C-language equivalents of the functions below: unsigned logn find_next_bit(const unsigned long *addr, unsigned long size, unsigned long offset); unsigned long find_next_zero_bit(const unsigned long *addr, unsigned long size, unsigned long offset); unsigned long find_first_zero_bit(const unsigned long *addr, unsigned long size); unsigned long find_first_bit(const unsigned long *addr, unsigned long size); In include/asm-generic/bitops/find.h This code largely copied from: arch/powerpc/lib/bitops.c Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: generic fls64()Akinobu Mita
This patch introduces the C-language equivalent of the function: int fls64(__u64 x); In include/asm-generic/bitops/fls64.h This code largely copied from: include/linux/bitops.h Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: generic fls()Akinobu Mita
This patch introduces the C-language equivalent of the function: int fls(int x); In include/asm-generic/bitops/fls.h This code largely copied from: include/linux/bitops.h Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: generic ffz()Akinobu Mita
This patch introduces the C-language equivalent of the function: unsigned long ffz(unsigned long word); In include/asm-generic/bitops/ffz.h This code largely copied from: include/asm-parisc/bitops.h Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: generic __ffs()Akinobu Mita
This patch introduces the C-language equivalent of the function: unsigned long __ffs(unsigned long word); In include/asm-generic/bitops/__ffs.h This code largely copied from: include/asm-sparc/bitops.h Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: generic __{,test_and_}{set,clear,change}_bit() and test_bit()Akinobu Mita
This patch introduces the C-language equivalents of the functions below: void __set_bit(int nr, volatile unsigned long *addr); void __clear_bit(int nr, volatile unsigned long *addr); void __change_bit(int nr, volatile unsigned long *addr); int __test_and_set_bit(int nr, volatile unsigned long *addr); int __test_and_clear_bit(int nr, volatile unsigned long *addr); int __test_and_change_bit(int nr, volatile unsigned long *addr); int test_bit(int nr, const volatile unsigned long *addr); In include/asm-generic/bitops/non-atomic.h This code largely copied from: asm-powerpc/bitops.h Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: generic {,test_and_}{set,clear,change}_bit()Akinobu Mita
This patch introduces the C-language equivalents of the functions below: void set_bit(int nr, volatile unsigned long *addr); void clear_bit(int nr, volatile unsigned long *addr); void change_bit(int nr, volatile unsigned long *addr); int test_and_set_bit(int nr, volatile unsigned long *addr); int test_and_clear_bit(int nr, volatile unsigned long *addr); int test_and_change_bit(int nr, volatile unsigned long *addr); In include/asm-generic/bitops/atomic.h This code largely copied from: include/asm-powerpc/bitops.h include/asm-parisc/bitops.h include/asm-parisc/atomic.h Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
