path: root/include/asm-generic/local.h
2010-01-05local_t: Remove cpu_local_xx macrosChristoph Lameter
These macros have not been used for awhile now. Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2009-05-18asm-generic: fix local_add_unless macroRoel Kluin
`local_add_unless(x, y, z)' will be expanded to `(&(x)->y, (y), (x))', but `&(x)->y' should be `&(x)->a' Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06remove linux/hardirq.h from asm-generic/local.hRussell King
While looking at reducing the amount of architecture namespace pollution in the generic kernel, I found that asm/irq.h is included in the vast majority of compilations on ARM (around 650 files.) Since asm/irq.h includes a sub-architecture include file on ARM, this causes a negative impact on the ccache's ability to re-use the build results from other sub-architectures, so we have a desire to reduce the dependencies on asm/irq.h. It turns out that a major cause of this is the needless include of linux/hardirq.h into asm-generic/local.h. The patch below removes this include, resulting in some 250 to 300 files (around half) of the kernel then omitting asm/irq.h. My test builds still succeed, provided two ARM files are fixed (arch/arm/kernel/traps.c and arch/arm/mm/fault.c) - so there may be negative impacts for this on other architectures. Note that x86 does not include asm/irq.h nor linux/hardirq.h in its asm/local.h, so this patch can be viewed as bringing the generic version into line with the x86 version. [kosaki.motohiro@jp.fujitsu.com: add #include <linux/irqflags.h> to acpi/processor_idle.c] [adobriyan@gmail.com: fix sparc64] Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08local_t: architecture independent extensionMathieu Desnoyers
This series extena and standardises local_t operations on each architecture, allowing a rich set of atomic operations to be done on per-cpu data with minimal performance impact. On architectures where there seems to be no difference between the SMP and UP operation (same memory barriers, same LOCKing), local.h simply includes asm-generic/local.h, which removes duplicated code from the current kernel tree. This patch: local_t: architecture independent extension Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-31[PATCH] make local_t signedAndrew Morton
local_t's were defined to be unsigned. This increases confusion because atomic_t's are signed. The patch goes through and changes all implementations to use signed longs throughout. Also, x86-64 was using 32-bit quantities for the value passed into local_add() and local_sub(). Fixed. All (actually, both) existing users have been audited. (Also s/__inline__/inline/ in x86_64/local.h) Cc: Andi Kleen <ak@muc.de> Cc: Benjamin LaHaise <bcrl@kvack.org> Cc: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Decrapify asm-generic/local.hKyle McMartin
Now that Christoph Lameter's atomic_long_t support is merged in mainline, might as well convert asm-generic/local.h to use it, so the same code can be used for both sizes of 32 and 64-bit unsigned longs. akpm sayeth: Q: Is there any particular reason why these routines weren't simply implemented with local_save/restore_flags, if they are only meant to guarantee atomicity to the local cpu? I'm sure on most platforms this would be more efficient than using an atomic... A: The whole _point_ of local_t is to avoid local_irq_disable(). It's designed to exploit the fact that many CPUs can do incs and decs in a way which is atomic wrt local interrupts, but not atomic wrt SMP. But this patch makes sense, because asm-generic/local.h is just a fallback implementation for architectures which either cannot perform these local-irq-atomic operations, or its maintainers haven't yet got around to implementing them. We need more work done on local_t in the 2.6.17 timeframe - they're defined as unsigned long, but some architectures implement them as signed long. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Cc: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
