commit f8f6ae5d077a9bdaf5cbf2ac960a5d1a04b47482 upstream.
The purpose of io_remap_pfn_range() is to map IO memory, such as a
memory mapped IO exposed through a PCI BAR. IO devices do not
understand encryption, so this memory must always be decrypted.
Automatically call pgprot_decrypted() as part of the generic
implementation.
This fixes a bug where enabling AMD SME causes subsystems, such as RDMA,
using io_remap_pfn_range() to expose BAR pages to user space to fail.
The CPU will encrypt access to those BAR pages instead of passing
unencrypted IO directly to the device.
Places not mapping IO should use remap_pfn_range().
Fixes: aca20d546214 ("x86/mm: Add support to make use of Secure Memory Encryption")
Signed-off-by: Jason Gunthorpe <jgg@nvidia.com>
Cc: Tom Lendacky <thomas.lendacky@amd.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Brijesh Singh <brijesh.singh@amd.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: "Dave Young" <dyoung@redhat.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Larry Woodman <lwoodman@redhat.com>
Cc: Matt Fleming <matt@codeblueprint.co.uk>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Toshimitsu Kani <toshi.kani@hpe.com>
Cc: <stable@vger.kernel.org>
Link: https://lkml.kernel.org/r/0-v1-025d64bdf6c4+e-amd_sme_fix_jgg@nvidia.com
commit d3f7b1bb204099f2f7306318896223e8599bb6a2 upstream.
Currently to make sure that every page table entry is read just once
gup_fast walks perform READ_ONCE and pass pXd value down to the next
gup_pXd_range function by value e.g.:
static int gup_pud_range(p4d_t p4d, unsigned long addr, unsigned long end,
unsigned int flags, struct page **pages, int *nr)
pudp = pud_offset(&p4d, addr);
This function passes a reference on that local value copy to pXd_offset,
and might get the very same pointer in return. This happens when the
level is folded (on most arches), and that pointer should not be
iterated.
On s390 due to the fact that each task might have different 5,4 or
3-level address translation and hence different levels folded the logic
is more complex and non-iteratable pointer to a local copy leads to
severe problems.
Here is an example of what happens with gup_fast on s390, for a task
with 3-level paging, crossing a 2 GB pud boundary:
// addr = 0x1007ffff000, end = 0x10080001000
unsigned long next;
pud_t *pudp;
// pud_offset returns &p4d itself (a pointer to a value on stack)
do {
// on second iteratation reading "random" stack value
pud_t pud = READ_ONCE(*pudp);
// next = 0x10080000000, due to PUD_SIZE/MASK != PGDIR_SIZE/MASK on s390
next = pud_addr_end(addr, end);
} while (pudp++, addr = next, addr != end); // pudp++ iterating over stack
return 1;
This happens since s390 moved to common gup code with commit
d1874a0c2805 ("s390/mm: make the pxd_offset functions more robust") and
commit 1a42010cdc26 ("s390/mm: convert to the generic
get_user_pages_fast code").
s390 tried to mimic static level folding by changing pXd_offset
primitives to always calculate top level page table offset in pgd_offset
and just return the value passed when pXd_offset has to act as folded.
What is crucial for gup_fast and what has been overlooked is that
PxD_SIZE/MASK and thus pXd_addr_end should also change correspondingly.
And the latter is not possible with dynamic folding.
To fix the issue in addition to pXd values pass original pXdp pointers
down to gup_pXd_range functions. And introduce pXd_offset_lockless
helpers, which take an additional pXd entry value parameter. This has
already been discussed in
https://lkml.kernel.org/r/20190418100218.0a4afd51@mschwideX1
Fixes: 1a42010cdc26 ("s390/mm: convert to the generic get_user_pages_fast code")
Signed-off-by: Vasily Gorbik <gor@linux.ibm.com>
Reviewed-by: Gerald Schaefer <gerald.schaefer@linux.ibm.com>
Reviewed-by: Alexander Gordeev <agordeev@linux.ibm.com>
Reviewed-by: Jason Gunthorpe <jgg@nvidia.com>
Reviewed-by: Mike Rapoport <rppt@linux.ibm.com>
Reviewed-by: John Hubbard <jhubbard@nvidia.com>
Cc: Russell King <linux@armlinux.org.uk>
Cc: Will Deacon <will@kernel.org>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Heiko Carstens <hca@linux.ibm.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Claudio Imbrenda <imbrenda@linux.ibm.com>
Cc: <stable@vger.kernel.org> [5.2+]
Link: https://lkml.kernel.org/r/patch.git-943f1e5dcff2.your-ad-here.call-01599856292-ext-8676@work.hours
According to 78ddc5347341 ("thp: rename split_huge_page_pmd() to
split_huge_pmd()"), update related comment.
Link: http://lkml.kernel.org/r/20190731033406.185285-1-wangkefeng.wang@huawei.com
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Cc: "Kirill A . Shutemov" <kirill.shutemov@linux.intel.com>
Both pgtable_cache_init() and pgd_cache_init() are used to initialize kmem
cache for page table allocations on several architectures that do not use
PAGE_SIZE tables for one or more levels of the page table hierarchy.
Most architectures do not implement these functions and use __weak default
NOP implementation of pgd_cache_init(). Since there is no such default
for pgtable_cache_init(), its empty stub is duplicated among most
architectures.
Rename the definitions of pgd_cache_init() to pgtable_cache_init() and
drop empty stubs of pgtable_cache_init().
Link: http://lkml.kernel.org/r/1566457046-22637-1-git-send-email-rppt@linux.ibm.com
Signed-off-by: Mike Rapoport <rppt@linux.ibm.com>
Acked-by: Will Deacon <will@kernel.org> [arm64]
Acked-by: Thomas Gleixner <tglx@linutronix.de> [x86]
Cc: Matthew Wilcox <willy@infradead.org>
Poking-mm initialization might require to duplicate the PGD in early
stage. Initialize the PGD cache earlier to prevent boot failures.
Reported-by: kernel test robot <lkp@intel.com>
Signed-off-by: Nadav Amit <namit@vmware.com>
Cc: Rick Edgecombe <rick.p.edgecombe@intel.com>
Cc: Rik van Riel <riel@surriel.com>
Fixes: 4fc19708b165 ("x86/alternatives: Initialize temporary mm for patching")
Link: http://lkml.kernel.org/r/20190505011124.39692-1-namit@vmware.com
Architectures like ppc64 require to do a conditional tlb flush based on
the old and new value of pte. Enable that by passing old pte value as
the arg.
Link: http://lkml.kernel.org/r/20190116085035.29729-3-aneesh.kumar@linux.ibm.com
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.ibm.com>
Cc: Nicholas Piggin <npiggin@gmail.com>
Patch series "NestMMU pte upgrade workaround for mprotect", v5.
We can upgrade pte access (R -> RW transition) via mprotect. We need to
make sure we follow the recommended pte update sequence as outlined in
commit bd5050e38aec ("powerpc/mm/radix: Change pte relax sequence to
handle nest MMU hang") for such updates. This patch series does that.
This patch (of 5):
Some architectures may want to call flush_tlb_range from these helpers.
Link: http://lkml.kernel.org/r/20190116085035.29729-2-aneesh.kumar@linux.ibm.com
Whilst no architectures actually enable support for huge p4d mappings in
the vmap area, the code that is implemented should be using
break-before-make, as we do for pud and pmd huge entries.
Link: http://lkml.kernel.org/r/1544120495-17438-6-git-send-email-will.deacon@arm.com
Reviewed-by: Toshi Kani <toshi.kani@hpe.com>
Cc: Chintan Pandya <cpandya@codeaurora.org>
Cc: Toshi Kani <toshi.kani@hpe.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Sean Christopherson <sean.j.christopherson@intel.com>
Commit:
f77084d96355 "x86/mm/pat: Disable preemption around __flush_tlb_all()"
introduced a warning to capture cases __flush_tlb_all() is called without
pre-emption disabled. It triggers a false positive warning in the memory
hotplug path.
On investigation it was found that the __flush_tlb_all() calls are not
necessary. However, they are only "not necessary" in practice provided
the ptes are being initially populated from the !present state.
Introduce set_pte_safe() as a sanity check that the pte is being updated
in a way that does not require a TLB flush.
Forgive the macro, the availability of the various of set_pte() levels
is hit and miss across architectures.
[ mingo: Minor readability edits. ]
Suggested-by: Peter Zijlstra <peterz@infradead.org>
Suggested-by: Dave Hansen <dave.hansen@intel.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Link: https://lkml.kernel.org/r/279dadae-9148-465c-7ec6-3f37e026c6c9@intel.com
In preparation for introducing '_safe' versions of page table entry 'set'
helpers, introduce generic versions of p4d_same() and pgd_same().
Link: http://lkml.kernel.org/r/154395943153.32119.1733586547359626311.stgit@dwillia2-desk3.amr.corp.intel.com
In preparation for {pmd,pud}_same() to be used outside of transparent
huge page code paths, make them unconditionally available. This enables
them to be used in the definition of a new family of
set_{pte,pmd,pud,p4d,pgd}_safe() helpers.
Link: http://lkml.kernel.org/r/154395942644.32119.10238934183949418128.stgit@dwillia2-desk3.amr.corp.intel.com
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 fixes from Martin Schwidefsky:
- A fix for the pgtable_bytes misaccounting on s390. The patch changes
common code part in regard to page table folding and adds extra
checks to mm_[inc|dec]_nr_[pmds|puds].
- Add FORCE for all build targets using if_changed
- Use non-loadable phdr for the .vmlinux.info section to avoid a
segment overlap that confuses kexec
- Cleanup the attribute definition for the diagnostic sampling
- Increase stack size for CONFIG_KASAN=y builds
- Export __node_distance to fix a build error
- Correct return code of a PMU event init function
- An update for the default configs
* tag 's390-4.20-2' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390/perf: Change CPUM_CF return code in event init function
s390: update defconfigs
s390/mm: Fix ERROR: "__node_distance" undefined!
s390/kasan: increase instrumented stack size to 64k
s390/cpum_sf: Rework attribute definition for diagnostic sampling
s390/mm: fix mis-accounting of pgtable_bytes
mm: add mm_pxd_folded checks to pgtable_bytes accounting functions
mm: introduce mm_[p4d|pud|pmd]_folded
mm: make the __PAGETABLE_PxD_FOLDED defines non-empty
s390: avoid vmlinux segments overlap
s390/vdso: add missing FORCE to build targets
s390/decompressor: add missing FORCE to build targets
Add three architecture overrideable functions to test if the
p4d, pud, or pmd layer of a page table is folded or not.
Documentation and comments.
Link: http://lkml.kernel.org/r/20180828145728.11873-7-willy@infradead.org
Signed-off-by: Matthew Wilcox <willy@infradead.org>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Nicolas Pitre <nicolas.pitre@linaro.org>
Cc: Souptick Joarder <jrdr.linux@gmail.com>
Some architectures just don't have PAGE_KERNEL_EXEC. The mm/nommu.c and
mm/vmalloc.c code have been using PAGE_KERNEL as a fallback for years.
Move this fallback to asm-generic.
Link: http://lkml.kernel.org/r/20180510185507.2439-3-mcgrof@kernel.org
Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org>
Suggested-by: Matthew Wilcox <willy@infradead.org>
Some architectures do not define certain PAGE_KERNEL_* flags, this is
either because:
a) The way to implement some of these flags is *not yet ported*, or
b) The architecture *has no way* to describe them
Over time we have accumulated a few PAGE_KERNEL_* fallback workarounds
for architectures in the kernel which do not define them using
*relatively safe* equivalents. Move these scattered fallback hacks into
asm-generic.
We start off with PAGE_KERNEL_RO using PAGE_KERNEL as a fallback. This
has been in place on the firmware loader for years. Move the fallback
into the respective asm-generic header.
Link: http://lkml.kernel.org/r/20180510185507.2439-2-mcgrof@kernel.org
Merge L1 Terminal Fault fixes from Thomas Gleixner:
"L1TF, aka L1 Terminal Fault, is yet another speculative hardware
engineering trainwreck. It's a hardware vulnerability which allows
unprivileged speculative access to data which is available in the
Level 1 Data Cache when the page table entry controlling the virtual
address, which is used for the access, has the Present bit cleared or
other reserved bits set.
If an instruction accesses a virtual address for which the relevant
page table entry (PTE) has the Present bit cleared or other reserved
bits set, then speculative execution ignores the invalid PTE and loads
the referenced data if it is present in the Level 1 Data Cache, as if
the page referenced by the address bits in the PTE was still present
and accessible.
While this is a purely speculative mechanism and the instruction will
raise a page fault when it is retired eventually, the pure act of
loading the data and making it available to other speculative
instructions opens up the opportunity for side channel attacks to
unprivileged malicious code, similar to the Meltdown attack.
While Meltdown breaks the user space to kernel space protection, L1TF
allows to attack any physical memory address in the system and the
attack works across all protection domains. It allows an attack of SGX
and also works from inside virtual machines because the speculation
bypasses the extended page table (EPT) protection mechanism.
The assoicated CVEs are: CVE-2018-3615, CVE-2018-3620, CVE-2018-3646
The mitigations provided by this pull request include:
- Host side protection by inverting the upper address bits of a non
present page table entry so the entry points to uncacheable memory.
- Hypervisor protection by flushing L1 Data Cache on VMENTER.
- SMT (HyperThreading) control knobs, which allow to 'turn off' SMT
by offlining the sibling CPU threads. The knobs are available on
the kernel command line and at runtime via sysfs
- Control knobs for the hypervisor mitigation, related to L1D flush
and SMT control. The knobs are available on the kernel command line
- Extensive documentation about L1TF including various degrees of
mitigations.
Thanks to all people who have contributed to this in various ways -
patches, review, testing, backporting - and the fruitful, sometimes
heated, but at the end constructive discussions.
There is work in progress to provide other forms of mitigations, which
might be less horrible performance wise for a particular kind of
workloads, but this is not yet ready for consumption due to their
complexity and limitations"
* 'l1tf-final' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (75 commits)
x86/microcode: Allow late microcode loading with SMT disabled
tools headers: Synchronise x86 cpufeatures.h for L1TF additions
x86/mm/kmmio: Make the tracer robust against L1TF
x86/mm/pat: Make set_memory_np() L1TF safe
x86/speculation/l1tf: Make pmd/pud_mknotpresent() invert
x86/speculation/l1tf: Invert all not present mappings
cpu/hotplug: Fix SMT supported evaluation
KVM: VMX: Tell the nested hypervisor to skip L1D flush on vmentry
x86/speculation: Use ARCH_CAPABILITIES to skip L1D flush on vmentry
x86/speculation: Simplify sysfs report of VMX L1TF vulnerability
Documentation/l1tf: Remove Yonah processors from not vulnerable list
x86/KVM/VMX: Don't set l1tf_flush_l1d from vmx_handle_external_intr()
x86/irq: Let interrupt handlers set kvm_cpu_l1tf_flush_l1d
x86: Don't include linux/irq.h from asm/hardirq.h
x86/KVM/VMX: Introduce per-host-cpu analogue of l1tf_flush_l1d
x86/irq: Demote irq_cpustat_t::__softirq_pending to u16
x86/KVM/VMX: Move the l1tf_flush_l1d test to vmx_l1d_flush()
x86/KVM/VMX: Replace 'vmx_l1d_flush_always' with 'vmx_l1d_flush_cond'
x86/KVM/VMX: Don't set l1tf_flush_l1d to true from vmx_l1d_flush()
cpu/hotplug: detect SMT disabled by BIOS
pfn_modify_allowed() and arch_has_pfn_modify_check() are outside of the
!__ASSEMBLY__ section in include/asm-generic/pgtable.h, which confuses
assembler on archs that don't have __HAVE_ARCH_PFN_MODIFY_ALLOWED (e.g.
ia64) and breaks build:
include/asm-generic/pgtable.h: Assembler messages:
include/asm-generic/pgtable.h:538: Error: Unknown opcode `static inline bool pfn_modify_allowed(unsigned long pfn,pgprot_t prot)'
include/asm-generic/pgtable.h:540: Error: Unknown opcode `return true'
include/asm-generic/pgtable.h:543: Error: Unknown opcode `static inline bool arch_has_pfn_modify_check(void)'
include/asm-generic/pgtable.h:545: Error: Unknown opcode `return false'
arch/ia64/kernel/entry.S:69: Error: `mov' does not fit into bundle
Move those two static inlines into the !__ASSEMBLY__ section so that they
don't confuse the asm build pass.
Fixes: 42e4089c7890 ("x86/speculation/l1tf: Disallow non privileged high MMIO PROT_NONE mappings")
The following kernel panic was observed on ARM64 platform due to a stale
TLB entry.
1. ioremap with 4K size, a valid pte page table is set.
2. iounmap it, its pte entry is set to 0.
3. ioremap the same address with 2M size, update its pmd entry with
a new value.
4. CPU may hit an exception because the old pmd entry is still in TLB,
which leads to a kernel panic.
Commit b6bdb7517c3d ("mm/vmalloc: add interfaces to free unmapped page
table") has addressed this panic by falling to pte mappings in the above
case on ARM64.
To support pmd mappings in all cases, TLB purge needs to be performed
in this case on ARM64.
Add a new arg, 'addr', to pud_free_pmd_page() and pmd_free_pte_page()
so that TLB purge can be added later in seprate patches.
[toshi.kani@hpe.com: merge changes, rewrite patch description]
Fixes: 28ee90fe6048 ("x86/mm: implement free pmd/pte page interfaces")
Signed-off-by: Chintan Pandya <cpandya@codeaurora.org>
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: mhocko@suse.com
Cc: akpm@linux-foundation.org
Cc: hpa@zytor.com
Cc: linux-mm@kvack.org
Cc: Joerg Roedel <joro@8bytes.org>
Cc: stable@vger.kernel.org
Link: https://lkml.kernel.org/r/20180627141348.21777-3-toshi.kani@hpe.com
For L1TF PROT_NONE mappings are protected by inverting the PFN in the page
table entry. This sets the high bits in the CPU's address space, thus
making sure to point to not point an unmapped entry to valid cached memory.
Some server system BIOSes put the MMIO mappings high up in the physical
address space. If such an high mapping was mapped to unprivileged users
they could attack low memory by setting such a mapping to PROT_NONE. This
could happen through a special device driver which is not access
protected. Normal /dev/mem is of course access protected.
To avoid this forbid PROT_NONE mappings or mprotect for high MMIO mappings.
Valid page mappings are allowed because the system is then unsafe anyways.
It's not expected that users commonly use PROT_NONE on MMIO. But to
minimize any impact this is only enforced if the mapping actually refers to
a high MMIO address (defined as the MAX_PA-1 bit being set), and also skip
the check for root.
For mmaps this is straight forward and can be handled in vm_insert_pfn and
in remap_pfn_range().
For mprotect it's a bit trickier. At the point where the actual PTEs are
accessed a lot of state has been changed and it would be difficult to undo
on an error. Since this is a uncommon case use a separate early page talk
walk pass for MMIO PROT_NONE mappings that checks for this condition
early. For non MMIO and non PROT_NONE there are no changes.
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
Acked-by: Dave Hansen <dave.hansen@intel.com>
Pull sparc updates from David Miller:
1) Add support for ADI (Application Data Integrity) found in more
recent sparc64 cpus. Essentially this is keyed based access to
virtual memory, and if the key encoded in the virual address is
wrong you get a trap.
The mm changes were reviewed by Andrew Morton and others.
Work by Khalid Aziz.
2) Validate DAX completion index range properly, from Rob Gardner.
3) Add proper Kconfig deps for DAX driver. From Guenter Roeck.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next:
sparc64: Make atomic_xchg() an inline function rather than a macro.
sparc64: Properly range check DAX completion index
sparc: Make auxiliary vectors for ADI available on 32-bit as well
sparc64: Oracle DAX driver depends on SPARC64
sparc64: Update signal delivery to use new helper functions
sparc64: Add support for ADI (Application Data Integrity)
mm: Allow arch code to override copy_highpage()
mm: Clear arch specific VM flags on protection change
mm: Add address parameter to arch_validate_prot()
sparc64: Add auxiliary vectors to report platform ADI properties
sparc64: Add handler for "Memory Corruption Detected" trap
sparc64: Add HV fault type handlers for ADI related faults
sparc64: Add support for ADI register fields, ASIs and traps
mm, swap: Add infrastructure for saving page metadata on swap
signals, sparc: Add signal codes for ADI violations
On architectures with CONFIG_HAVE_ARCH_HUGE_VMAP set, ioremap() may
create pud/pmd mappings. A kernel panic was observed on arm64 systems
with Cortex-A75 in the following steps as described by Hanjun Guo.
1. ioremap a 4K size, valid page table will build,
2. iounmap it, pte0 will set to 0;
3. ioremap the same address with 2M size, pgd/pmd is unchanged,
then set the a new value for pmd;
4. pte0 is leaked;
5. CPU may meet exception because the old pmd is still in TLB,
which will lead to kernel panic.
This panic is not reproducible on x86. INVLPG, called from iounmap,
purges all levels of entries associated with purged address on x86. x86
still has memory leak.
The patch changes the ioremap path to free unmapped page table(s) since
doing so in the unmap path has the following issues:
- The iounmap() path is shared with vunmap(). Since vmap() only
supports pte mappings, making vunmap() to free a pte page is an
overhead for regular vmap users as they do not need a pte page freed
up.
- Checking if all entries in a pte page are cleared in the unmap path
is racy, and serializing this check is expensive.
- The unmap path calls free_vmap_area_noflush() to do lazy TLB purges.
Clearing a pud/pmd entry before the lazy TLB purges needs extra TLB
purge.
Add two interfaces, pud_free_pmd_page() and pmd_free_pte_page(), which
clear a given pud/pmd entry and free up a page for the lower level
entries.
This patch implements their stub functions on x86 and arm64, which work
as workaround.
[akpm@linux-foundation.org: fix typo in pmd_free_pte_page() stub]
Link: http://lkml.kernel.org/r/20180314180155.19492-2-toshi.kani@hpe.com
Fixes: e61ce6ade404e ("mm: change ioremap to set up huge I/O mappings")
Reported-by: Lei Li <lious.lilei@hisilicon.com>
Cc: Wang Xuefeng <wxf.wang@hisilicon.com>
Cc: Hanjun Guo <guohanjun@huawei.com>
Cc: Borislav Petkov <bp@suse.de>
If a processor supports special metadata for a page, for example ADI
version tags on SPARC M7, this metadata must be saved when the page is
swapped out. The same metadata must be restored when the page is swapped
back in. This patch adds two new architecture specific functions -
arch_do_swap_page() to be called when a page is swapped in, and
arch_unmap_one() to be called when a page is being unmapped for swap
out. These architecture hooks allow page metadata to be saved if the
architecture supports it.
Signed-off-by: Khalid Aziz <khalid.aziz@oracle.com>
Cc: Khalid Aziz <khalid@gonehiking.org>
Acked-by: Jerome Marchand <jmarchan@redhat.com>
Reviewed-by: Anthony Yznaga <anthony.yznaga@oracle.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Instead of marking the pmd ready for split, invalidate the pmd. This
should take care of powerpc requirement. Only side effect is that we
mark the pmd invalid early. This can result in us blocking access to
the page a bit longer if we race against a thp split.
[kirill.shutemov@linux.intel.com: rebased, dirty THP once]
Link: http://lkml.kernel.org/r/20171213105756.69879-13-kirill.shutemov@linux.intel.com
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: David Daney <david.daney@cavium.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Nitin Gupta <nitin.m.gupta@oracle.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Vlastimil noted that pmdp_invalidate() is not atomic and we can lose
dirty and access bits if CPU sets them after pmdp dereference, but
before set_pmd_at().
The patch change pmdp_invalidate() to make the entry non-present
atomically and return previous value of the entry. This value can be
used to check if CPU set dirty/accessed bits under us.
The race window is very small and I haven't seen any reports that can be
attributed to the bug. For this reason, I don't think backporting to
stable trees needed.
Link: http://lkml.kernel.org/r/20171213105756.69879-11-kirill.shutemov@linux.intel.com
Reported-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Patch series "Do not lose dirty bit on THP pages", v4.
The bug can lead to data loss, but the race window is tiny and I haven't
seen any reports that suggested that it happens in reality. So I don't
think it worth sending it to stable.
Unfortunately, there's no way to address the issue in a generic way. We
need to fix all architectures that support THP one-by-one.
All architectures that have THP supported have to provide atomic
pmdp_invalidate() that returns previous value.
If generic implementation of pmdp_invalidate() is used, architecture
needs to provide atomic pmdp_estabish().
pmdp_estabish() is not used out-side generic implementation of
pmdp_invalidate() so far, but I think this can change in the future.
This patch (of 12):
This is an implementation of pmdp_establish() that is only suitable for
an architecture that doesn't have hardware dirty/accessed bits. In this
case we can't race with CPU which sets these bits and non-atomic
approach is fine.
Link: http://lkml.kernel.org/r/20171213105756.69879-2-kirill.shutemov@linux.intel.com
Pull x86 PTI preparatory patches from Thomas Gleixner:
"Todays Advent calendar window contains twentyfour easy to digest
patches. The original plan was to have twenty three matching the date,
but a late fixup made that moot.
- Move the cpu_entry_area mapping out of the fixmap into a separate
address space. That's necessary because the fixmap becomes too big
with NRCPUS=8192 and this caused already subtle and hard to
diagnose failures.
The top most patch is fresh from today and cures a brain slip of
that tall grumpy german greybeard, who ignored the intricacies of
32bit wraparounds.
- Limit the number of CPUs on 32bit to 64. That's insane big already,
but at least it's small enough to prevent address space issues with
the cpu_entry_area map, which have been observed and debugged with
the fixmap code
- A few TLB flush fixes in various places plus documentation which of
the TLB functions should be used for what.
- Rename the SYSENTER stack to CPU_ENTRY_AREA stack as it is used for
more than sysenter now and keeping the name makes backtraces
confusing.
- Prevent LDT inheritance on exec() by moving it to arch_dup_mmap(),
which is only invoked on fork().
- Make vysycall more robust.
- A few fixes and cleanups of the debug_pagetables code. Check
PAGE_PRESENT instead of checking the PTE for 0 and a cleanup of the
C89 initialization of the address hint array which already was out
of sync with the index enums.
- Move the ESPFIX init to a different place to prepare for PTI.
- Several code moves with no functional change to make PTI
integration simpler and header files less convoluted.
- Documentation fixes and clarifications"
* 'x86-pti-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits)
x86/cpu_entry_area: Prevent wraparound in setup_cpu_entry_area_ptes() on 32bit
init: Invoke init_espfix_bsp() from mm_init()
x86/cpu_entry_area: Move it out of the fixmap
x86/cpu_entry_area: Move it to a separate unit
x86/mm: Create asm/invpcid.h
x86/mm: Put MMU to hardware ASID translation in one place
x86/mm: Remove hard-coded ASID limit checks
x86/mm: Move the CR3 construction functions to tlbflush.h
x86/mm: Add comments to clarify which TLB-flush functions are supposed to flush what
x86/mm: Remove superfluous barriers
x86/mm: Use __flush_tlb_one() for kernel memory
x86/microcode: Dont abuse the TLB-flush interface
x86/uv: Use the right TLB-flush API
x86/entry: Rename SYSENTER_stack to CPU_ENTRY_AREA_entry_stack
x86/doc: Remove obvious weirdnesses from the x86 MM layout documentation
x86/mm/64: Improve the memory map documentation
x86/ldt: Prevent LDT inheritance on exec
x86/ldt: Rework locking
arch, mm: Allow arch_dup_mmap() to fail
x86/vsyscall/64: Warn and fail vsyscall emulation in NATIVE mode
init_espfix_bsp() needs to be invoked before the page table isolation
initialization. Move it into mm_init() which is the place where pti_init()
will be added.
While at it get rid of the #ifdeffery and provide proper stub functions.
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Juergen Gross <jgross@suse.com>
In response to compile breakage introduced by a series that added the
pud_write helper to x86, Stephen notes:
did you consider using the other paradigm:
In arch include files:
#define pud_write pud_write
static inline int pud_write(pud_t pud)
Then in include/asm-generic/pgtable.h:
#ifndef pud_write
#endif
If you had, then the powerpc code would have worked ... ;-) and many
of the other interfaces in include/asm-generic/pgtable.h are
protected that way ...
Given that some architecture already define pmd_write() as a macro, it's
a net reduction to drop the definition of __HAVE_ARCH_PMD_WRITE.
Link: http://lkml.kernel.org/r/151129126721.37405.13339850900081557813.stgit@dwillia2-desk3.amr.corp.intel.com
Suggested-by: Stephen Rothwell <sfr@canb.auug.org.au>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: Oliver OHalloran <oliveroh@au1.ibm.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Currently only get_user_pages_fast() can safely handle the writable gup
case due to its use of pud_access_permitted() to check whether the pud
entry is writable. In the gup slow path pud_write() is used instead of
pud_access_permitted() and to date it has been unimplemented, just calls
BUG_ON().
kernel BUG at ./include/linux/hugetlb.h:244!
RIP: 0010:follow_devmap_pud+0x482/0x490
Call Trace:
follow_page_mask+0x28c/0x6e0
__get_user_pages+0xe4/0x6c0
get_user_pages_unlocked+0x130/0x1b0
get_user_pages_fast+0x89/0xb0
iov_iter_get_pages_alloc+0x114/0x4a0
nfs_direct_read_schedule_iovec+0xd2/0x350
? nfs_start_io_direct+0x63/0x70
nfs_file_direct_read+0x1e0/0x250
nfs_file_read+0x90/0xc0
For now this just implements a simple check for the _PAGE_RW bit similar
to pmd_write. However, this implies that the gup-slow-path check is
missing the extra checks that the gup-fast-path performs with
pud_access_permitted. Later patches will align all checks to use the
'access_permitted' helper if the architecture provides it.
Note that the generic 'access_permitted' helper fallback is the simple
_PAGE_RW check on architectures that do not define the
'access_permitted' helper(s).
[dan.j.williams@intel.com: fix powerpc compile error]
Link: http://lkml.kernel.org/r/151129126165.37405.16031785266675461397.stgit@dwillia2-desk3.amr.corp.intel.com
Link: http://lkml.kernel.org/r/151043109938.2842.14834662818213616199.stgit@dwillia2-desk3.amr.corp.intel.com
Fixes: a00cc7d9dd93 ("mm, x86: add support for PUD-sized transparent hugepages")
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Soft dirty bit is designed to keep tracked over page migration. This
patch makes it work in the same manner for thp migration too.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Signed-off-by: Zi Yan <zi.yan@cs.rutgers.edu>
Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com>
Cc: David Nellans <dnellans@nvidia.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Minchan Kim <minchan@kernel.org>
When THP migration is being used, memory management code needs to handle
pmd migration entries properly. This patch uses !pmd_present() or
is_swap_pmd() (depending on whether pmd_none() needs separate code or
not) to check pmd migration entries at the places where a pmd entry is
present.
Since pmd-related code uses split_huge_page(), split_huge_pmd(),
pmd_trans_huge(), pmd_trans_unstable(), or
pmd_none_or_trans_huge_or_clear_bad(), this patch:
1. adds pmd migration entry split code in split_huge_pmd(),
2. takes care of pmd migration entries whenever pmd_trans_huge() is present,
3. makes pmd_none_or_trans_huge_or_clear_bad() pmd migration entry aware.
Since split_huge_page() uses split_huge_pmd() and pmd_trans_unstable()
is equivalent to pmd_none_or_trans_huge_or_clear_bad(), we do not change
them.
Until this commit, a pmd entry should be:
1. pointing to a pte page,
2. is_swap_pmd(),
3. pmd_trans_huge(),
4. pmd_devmap(), or
5. pmd_none().
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Changes to the existing page table macros will allow the SME support to
be enabled in a simple fashion with minimal changes to files that use these
macros. Since the memory encryption mask will now be part of the regular
pagetable macros, we introduce two new macros (_PAGE_TABLE_NOENC and
_KERNPG_TABLE_NOENC) to allow for early pagetable creation/initialization
without the encryption mask before SME becomes active. Two new pgprot()
macros are defined to allow setting or clearing the page encryption mask.
The FIXMAP_PAGE_NOCACHE define is introduced for use with MMIO. SME does
not support encryption for MMIO areas so this define removes the encryption
mask from the page attribute.
Two new macros are introduced (__sme_pa() / __sme_pa_nodebug()) to allow
creating a physical address with the encryption mask. These are used when
working with the cr3 register so that the PGD can be encrypted. The current
__va() macro is updated so that the virtual address is generated based off
of the physical address without the encryption mask thus allowing the same
virtual address to be generated regardless of whether encryption is enabled
for that physical location or not.
Also, an early initialization function is added for SME. If SME is active,
this function:
- Updates the early_pmd_flags so that early page faults create mappings
- Updates the __supported_pte_mask to include the encryption mask.
- Updates the protection_map entries to include the encryption mask so
that user-space allocations will automatically have the encryption mask
applied.
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Cc: Dave Young <dyoung@redhat.com>
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: kasan-dev@googlegroups.com
Cc: kvm@vger.kernel.org
Cc: linux-doc@vger.kernel.org
Cc: linux-efi@vger.kernel.org
Link: http://lkml.kernel.org/r/b36e952c4c39767ae7f0a41cf5345adf27438480.1500319216.git.thomas.lendacky@amd.com
This is a preparation patch for the transition of x86 to the generic GUP_fast()
implementation.
On x86, we would need to do additional permission checks to determine if
access is allowed.
Let's abstract it out into separate helpers.
Cc: Aneesh Kumar K . V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Dann Frazier <dann.frazier@canonical.com>
Cc: Steve Capper <steve.capper@linaro.org>
Link: http://lkml.kernel.org/r/20170316152655.37789-3-kirill.shutemov@linux.intel.com
Convert all non-architecture-specific code to 5-level paging.
It's mostly mechanical adding handling one more page table level in
places where we deal with pud_t.
Without this KSM will consider the page write protected, but a numa
fault can later mark the page writable. This can result in memory
corruption.
Link: http://lkml.kernel.org/r/1487498625-10891-3-git-send-email-aneesh.kumar@linux.vnet.ibm.com
in a protnone pte.
Patch series "Numabalancing preserve write fix", v2.
This patch series address an issue w.r.t THP migration and autonuma
preserve write feature. migrate_misplaced_transhuge_page() cannot deal
with concurrent modification of the page. It does a page copy without
following the migration pte sequence. IIUC, this was done to keep the
migration simpler and at the time of implemenation we didn't had THP
page cache which would have required a more elaborate migration scheme.
That means thp autonuma migration expect the protnone with saved write
to be done such that both kernel and user cannot update the page
content. This patch series enables archs like ppc64 to do that. We are
good with the hash translation mode with the current code, because we
never create a hardware page table entry for a protnone pte.
This patch (of 2):
Autonuma preserves the write permission across numa fault to avoid
taking a writefault after a numa fault (Commit: b191f9b106ea " mm: numa:
preserve PTE write permissions across a NUMA hinting fault").
Architecture can implement protnone in different ways and some may
choose to implement that by clearing Read/ Write/Exec bit of pte.
Setting the write bit on such pte can result in wrong behaviour. Fix
this up by allowing arch to override how to save the write bit on a
protnone pte.
[aneesh.kumar@linux.vnet.ibm.com: don't mark pte saved write in case of dirty_accountable]
Link: http://lkml.kernel.org/r/1487942884-16517-1-git-send-email-aneesh.kumar@linux.vnet.ibm.com
[aneesh.kumar@linux.vnet.ibm.com: v3]
Link: http://lkml.kernel.org/r/1487498625-10891-2-git-send-email-aneesh.kumar@linux.vnet.ibm.com
Link: http://lkml.kernel.org/r/1487050314-3892-2-git-send-email-aneesh.kumar@linux.vnet.ibm.com
Acked-by: Michael Neuling <mikey@neuling.org>
Cc: Michael Ellerman <michaele@au1.ibm.com>
The current transparent hugepage code only supports PMDs. This patch
adds support for transparent use of PUDs with DAX. It does not include
support for anonymous pages. x86 support code also added.
Most of this patch simply parallels the work that was done for huge
PMDs. The only major difference is how the new ->pud_entry method in
mm_walk works. The ->pmd_entry method replaces the ->pte_entry method,
whereas the ->pud_entry method works along with either ->pmd_entry or
->pte_entry. The pagewalk code takes care of locking the PUD before
calling ->pud_walk, so handlers do not need to worry whether the PUD is
stable.
[dave.jiang@intel.com: fix SMP x86 32bit build for native_pud_clear()]
Link: http://lkml.kernel.org/r/148719066814.31111.3239231168815337012.stgit@djiang5-desk3.ch.intel.com
[dave.jiang@intel.com: native_pud_clear missing on i386 build]
Link: http://lkml.kernel.org/r/148640375195.69754.3315433724330910314.stgit@djiang5-desk3.ch.intel.com
Link: http://lkml.kernel.org/r/148545059381.17912.8602162635537598445.stgit@djiang5-desk3.ch.intel.com
Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
Tested-by: Alexander Kapshuk <alexander.kapshuk@gmail.com>
Cc: Jan Kara <jack@suse.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Nilesh Choudhury <nilesh.choudhury@oracle.com>
Add arch specific callback in the generic THP page cache code that will
deposit and withdarw preallocated page table. Archs like ppc64 use this
preallocated table to store the hash pte slot information.
Testing:
kernel build of the patch series on tmpfs mounted with option huge=always
The related thp stat:
thp_fault_alloc 72939
thp_fault_fallback 60547
thp_collapse_alloc 603
thp_collapse_alloc_failed 0
thp_file_alloc 253763
thp_file_mapped 4251
thp_split_page 51518
thp_split_page_failed 1
thp_deferred_split_page 73566
thp_split_pmd 665
thp_zero_page_alloc 3
thp_zero_page_alloc_failed 0
[akpm@linux-foundation.org: remove unneeded parentheses, per Kirill]
Link: http://lkml.kernel.org/r/20161113150025.17942-2-aneesh.kumar@linux.vnet.ibm.com
Cc: Michael Neuling <mikey@neuling.org>
Cc: Balbir Singh <bsingharora@gmail.com>
Independent of whether the vma is for anonymous memory, some arches like
ppc64 would like to override pmd_move_must_withdraw().
One option is to encapsulate the vma_is_anonymous() check for general
architectures inside pmd_move_must_withdraw() so that is always called
and architectures that need unconditional overriding can override this
function. ppc64 needs to override the function when the MMU is
configured to use hash PTE's.
[bsingharora@gmail.com: reworked changelog]
Link: http://lkml.kernel.org/r/20161113150025.17942-1-aneesh.kumar@linux.vnet.ibm.com
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
It only returns 0 so we can save us the testing of its retval
everywhere.
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: mcgrof@suse.com
Cc: dri-devel@lists.freedesktop.org
Cc: Dave Airlie <airlied@redhat.com>
Cc: dan.j.williams@intel.com
Cc: torvalds@linux-foundation.org
Link: http://lkml.kernel.org/r/20161026174839.rusfxkm3xt4ennhe@pd.tnic
We get 1 warning when building kernel with W=1:
drivers/char/mem.c:220:12: warning: no previous prototype for 'phys_mem_access_prot_allowed' [-Wmissing-prototypes]
int __weak phys_mem_access_prot_allowed(struct file *file,
In fact, its declaration is spreading to several header files in
different architecture, but need to be declare in common header file.
So this patch moves phys_mem_access_prot_allowed() to pgtable.h.
Link: http://lkml.kernel.org/r/1473751597-12139-1-git-send-email-baoyou.xie@linaro.org
Signed-off-by: Baoyou Xie <baoyou.xie@linaro.org>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
I've just discovered that the useful-sounding has_transparent_hugepage()
is actually an architecture-dependent minefield: on some arches it only
builds if CONFIG_TRANSPARENT_HUGEPAGE=y, on others it's also there when
not, but on some of those (arm and arm64) it then gives the wrong
answer; and on mips alone it's marked __init, which would crash if
called later (but so far it has not been called later).
Straighten this out: make it available to all configs, with a sensible
default in asm-generic/pgtable.h, removing its definitions from those
arches (arc, arm, arm64, sparc, tile) which are served by the default,
adding #define has_transparent_hugepage has_transparent_hugepage to
those (mips, powerpc, s390, x86) which need to override the default at
runtime, and removing the __init from mips (but maybe that kind of code
should be avoided after init: set a static variable the first time it's
called).
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Andres Lagar-Cavilla <andreslc@google.com>
Cc: Yang Shi <yang.shi@linaro.org>
Cc: Ning Qu <quning@gmail.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arch/arc]
Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [arch/s390]
Acked-by: Ingo Molnar <mingo@kernel.org>
We remove one instace of flush_tlb_range here. That was added by commit
f714f4f20e59 ("mm: numa: call MMU notifiers on THP migration"). But the
pmdp_huge_clear_flush_notify should have done the require flush for us.
Hence remove the extra flush.
Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com>
With ppc64 we use the deposited pgtable_t to store the hash pte slot
information. We should not withdraw the deposited pgtable_t without
marking the pmd none. This ensure that low level hash fault handling
will skip this huge pte and we will handle them at upper levels.
Recent change to pmd splitting changed the above in order to handle the
race between pmd split and exit_mmap. The race is explained below.
Consider following race:
CPU0 CPU1
shrink_page_list()
add_to_swap()
split_huge_page_to_list()
__split_huge_pmd_locked()
pmdp_huge_clear_flush_notify()
// pmd_none() == true
exit_mmap()
unmap_vmas()
zap_pmd_range()
// no action on pmd since pmd_none() == true
pmd_populate()
As result the THP will not be freed. The leak is detected by check_mm():
BUG: Bad rss-counter state mm:ffff880058d2e580 idx:1 val:512
The above required us to not mark pmd none during a pmd split.
The fix for ppc is to clear the huge pte of _PAGE_USER, so that low
level fault handling code skip this pte. At higher level we do take ptl
lock. That should serialze us against the pmd split. Once the lock is
acquired we do check the pmd again using pmd_same. That should always
return false for us and hence we should retry the access. We do the
pmd_same check in all case after taking plt with
THP (do_huge_pmd_wp_page, do_huge_pmd_numa_page and
huge_pmd_set_accessed)
Also make sure we wait for irq disable section in other cpus to finish
before flipping a huge pte entry with a regular pmd entry. Code paths
like find_linux_pte_or_hugepte depend on irq disable to get
a stable pte_t pointer. A parallel thp split need to make sure we
don't convert a pmd pte to a regular pmd entry without waiting for the
irq disable section to finish.
Fixes: eef1b3ba053a ("thp: implement split_huge_pmd()")
Similar to the conversion of vm_insert_mixed() use pfn_t in the
vmf_insert_pfn_pmd() to tag the resulting pte with _PAGE_DEVICE when the
pfn is backed by a devm_memremap_pages() mapping.
Cc: Dave Hansen <dave@sr71.net>
Cc: Matthew Wilcox <willy@linux.intel.com>
With new refcounting we don't need to mark PMDs splitting. Let's drop
code to handle this.
Tested-by: Sasha Levin <sasha.levin@oracle.com>
Tested-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Christoph Lameter <cl@linux.com>
mremap() with MREMAP_FIXED on a VM_PFNMAP range causes the following
WARN_ON_ONCE() message in untrack_pfn().
WARNING: CPU: 1 PID: 3493 at arch/x86/mm/pat.c:985 untrack_pfn+0xbd/0xd0()
Call Trace:
[<ffffffff817729ea>] dump_stack+0x45/0x57
[<ffffffff8109e4b6>] warn_slowpath_common+0x86/0xc0
[<ffffffff8109e5ea>] warn_slowpath_null+0x1a/0x20
[<ffffffff8106a88d>] untrack_pfn+0xbd/0xd0
[<ffffffff811d2d5e>] unmap_single_vma+0x80e/0x860
[<ffffffff811d3725>] unmap_vmas+0x55/0xb0
[<ffffffff811d916c>] unmap_region+0xac/0x120
[<ffffffff811db86a>] do_munmap+0x28a/0x460
[<ffffffff811dec33>] move_vma+0x1b3/0x2e0
[<ffffffff811df113>] SyS_mremap+0x3b3/0x510
[<ffffffff817793ee>] entry_SYSCALL_64_fastpath+0x12/0x71
MREMAP_FIXED moves a pfnmap from old vma to new vma. untrack_pfn() is
called with the old vma after its pfnmap page table has been removed,
which causes follow_phys() to fail. The new vma has a new pfnmap to
the same pfn & cache type with VM_PAT set. Therefore, we only need to
clear VM_PAT from the old vma in this case.
Add untrack_pfn_moved(), which clears VM_PAT from a given old vma.
move_vma() is changed to call this function with the old vma when
VM_PFNMAP is set. move_vma() then calls do_munmap(), and untrack_pfn()
is a no-op since VM_PAT is cleared.
Reported-by: Stas Sergeev <stsp@list.ru>
Link: http://lkml.kernel.org/r/1450832064-10093-2-git-send-email-toshi.kani@hpe.com
Pull s390 updates from Martin Schwidefsky:
"There is only one new feature in this pull for the 4.4 merge window,
most of it is small enhancements, cleanup and bug fixes:
- Add the s390 backend for the software dirty bit tracking. This
adds two new pgtable functions pte_clear_soft_dirty and
pmd_clear_soft_dirty which is why there is a hit to
arch/x86/include/asm/pgtable.h in this pull request.
- A series of cleanup patches for the AP bus, this includes the
removal of the support for two outdated crypto cards (PCICC and
PCICA).
- The irq handling / signaling on buffer full in the runtime
instrumentation code is dropped.
- Some micro optimizations: remove unnecessary memory barriers for a
couple of functions: [smb_]rmb, [smb_]wmb, atomics, bitops, and for
spin_unlock. Use the builtin bswap if available and make
test_and_set_bit_lock more cache friendly.
- Statistics and a tracepoint for the diagnose calls to the
hypervisor.
- The CPU measurement facility support to sample KVM guests is
improved.
- The vector instructions are now always enabled for user space
processes if the hardware has the vector facility. This simplifies
the FPU handling code. The fpu-internal.h header is split into fpu
internals, api and types just like x86.
- Cleanup and improvements for the common I/O layer.
- Rework udelay to solve a problem with kprobe. udelay has busy loop
semantics but still uses an idle processor state for the wait"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (66 commits)
s390: remove runtime instrumentation interrupts
s390/cio: de-duplicate subchannel validation
s390/css: unneeded initialization in for_each_subchannel
s390/Kconfig: use builtin bswap
s390/dasd: fix disconnected device with valid path mask
s390/dasd: fix invalid PAV assignment after suspend/resume
s390/dasd: fix double free in dasd_eckd_read_conf
s390/kernel: fix ptrace peek/poke for floating point registers
s390/cio: move ccw_device_stlck functions
s390/cio: move ccw_device_call_handler
s390/topology: reduce per_cpu() invocations
s390/nmi: reduce size of percpu variable
s390/nmi: fix terminology
s390/nmi: remove casts
s390/nmi: remove pointless error strings
s390: don't store registers on disabled wait anymore
s390: get rid of __set_psw_mask()
s390/fpu: split fpu-internal.h into fpu internals, api, and type headers
s390/dasd: fix list_del corruption after lcu changes
s390/spinlock: remove unneeded serializations at unlock
