path: root/include/asm-generic/rtc.h
2009-01-15alpha: fix RTC on marvelIvan Kokshaysky
Unlike other alphas, marvel doesn't have real PC-style CMOS clock hardware - RTC accesses are emulated via PAL calls. Unfortunately, for unknown reason these calls work only on CPU #0. So current implementation for arbitrary CPU makes CMOS_READ/WRITE to be executed on CPU #0 via IPI. However, for obvious reason this doesn't work with standard get/set_rtc_time() functions, where a bunch of CMOS accesses is done with disabled interrupts. Solved by making the IPI calls for entire get/set_rtc_time() functions, not for individual CMOS accesses. Which is also a lot more effective performance-wise. The patch is largely based on the code from Jay Estabrook. My changes: - tweak asm-generic/rtc.h by adding a couple of #defines to avoid a massive code duplication in arch/alpha/include/asm/rtc.h; - sys_marvel.c: fix get/set_rtc_time() return values (Jay's FIXMEs). NOTE: this fixes *only* LIB_RTC drivers. Legacy (CONFIG_RTC) driver wont't work on marvel. Actually I think that we should just disable CONFIG_RTC on alpha (maybe in 2.6.30?), like most other arches - AFAIK, all modern distributions use LIB_RTC anyway. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20rtc: use bcd2bin/bin2bcdAdrian Bunk
Change various rtc related code to use the new bcd2bin/bin2bcd functions instead of the obsolete BCD_TO_BIN/BIN_TO_BCD/BCD2BIN/BIN2BCD macros. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-23rtc: fix deadlockIngo Molnar
if get_rtc_time() is _ever_ called with IRQs off, we deadlock badly in it, waiting for jiffies to increment. So make the code more robust by doing an explicit mdelay(20). This solves a very hard to reproduce/debug hard lockup reported by Mikael Pettersson. Reported-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-30remove __KERNEL__ tests of unexported headers under asm-generic/Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-04x86: fix RTC lockdep warning: potential hardirq recursionAndrew Morton
After disabling both CONFIG_DEBUG_LOCKING_API_SELFTESTS and netconsole (using current mainline) I get a login prompt, and also... [ 5.181668] SELinux: policy loaded with handle_unknown=deny [ 5.183315] type=1403 audit(1202100038.157:3): policy loaded auid=4294967295 ses=4294967295 [ 5.822073] SELinux: initialized (dev usbfs, type usbfs), uses genfs_contexts [ 7.819146] ------------[ cut here ]------------ [ 7.819146] WARNING: at kernel/lockdep.c:2033 trace_hardirqs_on+0x9b/0x10d() [ 7.819146] Modules linked in: generic ext3 jbd ide_disk ide_core [ 7.819146] Pid: 399, comm: hwclock Not tainted 2.6.24 #4 [ 7.819146] [<c011d140>] warn_on_slowpath+0x41/0x51 [ 7.819146] [<c01364a9>] ? lock_release_holdtime+0x50/0x56 [ 7.819146] [<c013770c>] ? check_usage_forwards+0x19/0x3b [ 7.819146] [<c01390c4>] ? __lock_acquire+0xac3/0xb0b [ 7.819146] [<c0108c98>] ? native_sched_clock+0x8b/0x9f [ 7.819146] [<c01364a9>] ? lock_release_holdtime+0x50/0x56 [ 7.819146] [<c030ca6c>] ? _spin_unlock_irq+0x22/0x42 [ 7.819146] [<c013848b>] trace_hardirqs_on+0x9b/0x10d [ 7.819146] [<c030ca6c>] _spin_unlock_irq+0x22/0x42 [ 7.819146] [<c011481e>] hpet_rtc_interrupt+0xdf/0x290 [ 7.819146] [<c014ea90>] handle_IRQ_event+0x1a/0x46 [ 7.819146] [<c014f8ea>] handle_edge_irq+0xbe/0xff [ 7.819146] [<c0106e08>] do_IRQ+0x6d/0x84 [ 7.819146] [<c0105596>] common_interrupt+0x2e/0x34 [ 7.819146] [<c013007b>] ? ktime_get_ts+0x8/0x3f [ 7.819146] [<c0139420>] ? lock_release+0x167/0x16f [ 7.819146] [<c017974a>] ? core_sys_select+0x2c/0x327 [ 7.819146] [<c0179792>] core_sys_select+0x74/0x327 [ 7.819146] [<c0108c98>] ? native_sched_clock+0x8b/0x9f [ 7.819146] [<c01364a9>] ? lock_release_holdtime+0x50/0x56 [ 7.819146] [<c030ca6c>] ? _spin_unlock_irq+0x22/0x42 [ 7.819146] [<c01384d6>] ? trace_hardirqs_on+0xe6/0x10d [ 7.819146] [<c030ca77>] ? _spin_unlock_irq+0x2d/0x42 [ 7.819146] [<c023b437>] ? rtc_do_ioctl+0x11b/0x677 [ 7.819146] [<c01c487e>] ? inode_has_perm+0x5e/0x68 [ 7.819146] [<c01364a9>] ? lock_release_holdtime+0x50/0x56 [ 7.819146] [<c0108c98>] ? native_sched_clock+0x8b/0x9f [ 7.819146] [<c01c490b>] ? file_has_perm+0x83/0x8c [ 7.819146] [<c023ba08>] ? rtc_ioctl+0xf/0x11 [ 7.819146] [<c017898d>] ? do_ioctl+0x55/0x67 [ 7.819146] [<c0179d15>] sys_select+0x93/0x163 [ 7.819146] [<c0104b39>] ? sysenter_past_esp+0x9a/0xa5 [ 7.819146] [<c0104afe>] sysenter_past_esp+0x5f/0xa5 [ 7.819146] ======================= [ 7.819146] ---[ end trace 96540ca301ffb84c ]--- [ 7.819210] rtc: lost 6 interrupts [ 7.870668] type=1400 audit(1202128840.794:4): avc: denied { audit_write } for pid=399 comm="hwclock" capability=29 scontext=system_u:system_r:hwclock_t:s0 tcontext=system_u:system_r:hwclock_t:s0 tclass=capability [ 9.538866] input: PC Speaker as /class/input/input5 Because hpet_rtc_interrupt()'s call to get_rtc_time() ends up resolving to include/asm-generic/rtc.h's (hilariously inlined) get_rtc_time(), which does spin_unlock_irq() from hard IRQ context. The obvious patch fixes it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-24Add some basic resume trace facilitiesLinus Torvalds
Considering that there isn't a lot of hw we can depend on during resume, this is about as good as it gets. This is x86-only for now, although the basic concept (and most of the code) will certainly work on almost any platform. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
