path: root/include/asm-generic/statfs.h
2010-08-09add f_flags to struct statfs(64)Christoph Hellwig
Add a flags field to help glibc implementing statvfs(3) efficiently. We copy the flag values from glibc, and add a new ST_VALID flag to denote that f_flags is implemented. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-26remove __KERNEL_STRICT_NAMESArnd Bergmann
With the last used of non-strict names gone from the exported header files, we can remove the old libc5 compatibility cruft from our headers and only export strict types. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-04Make <asm-generic/statfs.h> suitable for 64-bit platforms.David Woodhouse
At the moment, 64-bit platforms (other than Alpha) are all redefining things for themselves instead of using <asm-generic/statfs.h>. As is ARM, since it has special requirements w.r.t. padding. Make <asm-generic/statfs.h> more generic, and they can use it directly. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
