path: root/include/asm-generic/syscall.h
2009-09-22asm-generic: syscall_get_nr returns intRoland McGrath
Only 32 bits of system call number are meaningful, so make the specification for syscall_get_nr() be to return int, not long. Signed-off-by: Roland McGrath <roland@redhat.com>
2008-09-05tracehook: comment pasto fixesRoland McGrath
Fix some pasto's in comments in the new linux/tracehook.h and asm-generic/syscall.h files. Reported-by: Wenji Huang <wenji.huang@oracle.com> Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26tracehook: asm/syscall.hRoland McGrath
This adds asm-generic/syscall.h, which documents what a real asm-ARCH/syscall.h file should define. This is not used yet, but will provide all the machine-dependent details of examining a user system call about to begin, in progress, or just ended. Each arch should add an asm-ARCH/syscall.h that defines all the entry points documented in asm-generic/syscall.h, as short inlines if possible. This lets us write new tracing code that understands user system call registers, without any new arch-specific work. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Reviewed-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
