path: root/include/asm-generic/system.h
2011-07-25asm-generic/system.h: drop useless __KERNEL__Mike Frysinger
This header isn't exported to user-space, and even if it was, the __KERNEL__ check covers the entire file, so we'd get a useless stub in the first place. So punt it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-09asm-generic: cmpxchg does not handle non-long argumentsMathieu Lacage
The version of cmpxchg defined in asm-generic/system.h does not handle correctly non-long arguments. Use the version defined in cmpxchg.h instead. Signed-off-by: Mathieu Lacage <mathieu.lacage@inria.fr> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-11asm-generic: add generic versions of common headersArnd Bergmann
These are all kernel internal interfaces that get copied around a lot. In most cases, architectures can provide their own optimized versions, but these generic versions can work as well. I have tried to use the most common contents of each header to allow existing architectures to migrate easily. Thanks to Remis for suggesting a number of cleanups. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
