path: root/include/asm-generic/termbits.h
2010-08-10tty: Add EXTPROC support for LINEMODEhyc@symas.com
This patch is against the 2.6.34 source. Paraphrased from the 1989 BSD patch by David Borman @ cray.com: These are the changes needed for the kernel to support LINEMODE in the server. There is a new bit in the termios local flag word, EXTPROC. When this bit is set, several aspects of the terminal driver are disabled. Input line editing, character echo, and mapping of signals are all disabled. This allows the telnetd to turn off these functions when in linemode, but still keep track of what state the user wants the terminal to be in. New ioctl: TIOCSIG Generate a signal to processes in the current process group of the pty. There is a new mode for packet driver, the TIOCPKT_IOCTL bit. When packet mode is turned on in the pty, and the EXTPROC bit is set, then whenever the state of the pty is changed, the next read on the master side of the pty will have the TIOCPKT_IOCTL bit set. This allows the process on the server side of the pty to know when the state of the terminal has changed; it can then issue the appropriate ioctl to retrieve the new state. Since the original BSD patches accompanied the source code for telnet I've left that reference here, but obviously the feature is useful for any remote terminal protocol, including ssh. The corresponding feature has existed in the BSD tty driver since 1989. For historical reference, a good copy of the relevant files can be found here: http://anonsvn.mit.edu/viewvc/krb5/trunk/src/appl/telnet/?pathrev=17741 Signed-off-by: Howard Chu <hyc@symas.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11asm-generic: add generic ABI headersArnd Bergmann
These header files are typically copied from an existing architecture into any new one, slightly modified and then remain untouched until the end of time in the name of ABI stability. To make it easier for future architectures, provide a sane generic version here. In cases where multiple architectures already use identical code, I used the most common version. In cases like stat.h that are more or less broken everywhere, I provide a version that is meant to be ideal for new architectures. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
