path: root/include/asm-generic/vmlinux.lds.h
2013-10-17kernel: add support for init_array constructorsFrantisek Hrbata
This adds the .init_array section as yet another section with constructors. This is needed because gcc could add __gcov_init calls to .init_array or .ctors section, depending on gcc (and binutils) version . v2: - reuse mod->ctors for .init_array section for modules, because gcc uses .ctors or .init_array, but not both at the same time v3: - fail to load if that does happen somehow. Signed-off-by: Frantisek Hrbata <fhrbata@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-07-26tracing: Add __tracepoint_string() to export string pointersSteven Rostedt (Red Hat)
There are several tracepoints (mostly in RCU), that reference a string pointer and uses the print format of "%s" to display the string that exists in the kernel, instead of copying the actual string to the ring buffer (saves time and ring buffer space). But this has an issue with userspace tools that read the binary buffers that has the address of the string but has no access to what the string itself is. The end result is just output that looks like: rcu_dyntick: ffffffff818adeaa 1 0 rcu_dyntick: ffffffff818adeb5 0 140000000000000 rcu_dyntick: ffffffff818adeb5 0 140000000000000 rcu_utilization: ffffffff8184333b rcu_utilization: ffffffff8184333b The above is pretty useless when read by the userspace tools. Ideally we would want something that looks like this: rcu_dyntick: Start 1 0 rcu_dyntick: End 0 140000000000000 rcu_dyntick: Start 140000000000000 0 rcu_callback: rcu_preempt rhp=0xffff880037aff710 func=put_cred_rcu 0/4 rcu_callback: rcu_preempt rhp=0xffff880078961980 func=file_free_rcu 0/5 rcu_dyntick: End 0 1 The trace_printk() which also only stores the address of the string format instead of recording the string into the buffer itself, exports the mapping of kernel addresses to format strings via the printk_format file in the debugfs tracing directory. The tracepoint strings can use this same method and output the format to the same file and the userspace tools will be able to decipher the address without any modification. The tracepoint strings need its own section to save the strings because the trace_printk section will cause the trace_printk() buffers to be allocated if anything exists within the section. trace_printk() is only used for debugging and should never exist in the kernel, we can not use the trace_printk sections. Add a new tracepoint_str section that will also be examined by the output of the printk_format file. Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-07-07Merge branch 'cpuinit-delete' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull first stage of __cpuinit removal from Paul Gortmaker: "The two commits here 1) dummy out all the __cpuinit macros so that we no longer generate such sections, and then 2) remove all the section processing that we used to do for those sections. This makes all the __cpuinit and friends no-ops, so that we can remove the use cases of it at our leisure. Expect stage 2, which does the tree wide removal sweep at the end of the merge window." * 'cpuinit-delete' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: modpost: remove all traces of cpuinit/cpuexit sections init.h: remove __cpuinit sections from the kernel
2013-07-03rapidio: convert switch drivers to modulesAlexandre Bounine
Rework RapidIO switch drivers to add an option to build them as loadable kernel modules. This patch removes RapidIO-specific vmlinux section and converts switch drivers to be compatible with LDM driver registration method. To simplify registration of device-specific callback routines this patch introduces rio_switch_ops data structure. The sw_sysfs() callback is removed from the list of device-specific operations because under the new structure its functions can be handled by switch driver's probe() and remove() routines. If a specific switch device driver is not loaded the RapidIO subsystem core will use default standard-based operations to configure a switch. Because the current implementation of RapidIO enumeration/discovery method relies on availability of device-specific operations for error management, switch device drivers must be loaded before the RapidIO enumeration/discovery starts. This patch also moves several common routines from enumeration/discovery module into the RapidIO core code to make switch-specific operations accessible to all components of RapidIO subsystem. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@Prodrive.nl> Cc: Micha Nelissen <micha.nelissen@Prodrive.nl> Cc: Stef van Os <stef.van.os@Prodrive.nl> Cc: Jean Delvare <jdelvare@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-26modpost: remove all traces of cpuinit/cpuexit sectionsPaul Gortmaker
Delete all audit rules that were checking how the .cpuXYZ related sections were inter-operating with other __init like sections, now that __cpuinit is gone. Update the linker script to not have any knowledge of .cpuinit sections. [lds.h update courtesy of Ralf Baechle <ralf@linux-mips.org>] Cc: Arnd Bergmann <arnd@arndb.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-06-03Finally eradicate CONFIG_HOTPLUGStephen Rothwell
Ever since commit 45f035ab9b8f ("CONFIG_HOTPLUG should be always on"), it has been basically impossible to build a kernel with CONFIG_HOTPLUG turned off. Remove all the remaining references to it. Cc: Russell King <linux@arm.linux.org.uk> Cc: Doug Thompson <dougthompson@xmission.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-15CONFIG_SYMBOL_PREFIX: cleanup.Rusty Russell
We have CONFIG_SYMBOL_PREFIX, which three archs define to the string "_". But Al Viro broke this in "consolidate cond_syscall and SYSCALL_ALIAS declarations" (in linux-next), and he's not the first to do so. Using CONFIG_SYMBOL_PREFIX is awkward, since we usually just want to prefix it so something. So various places define helpers which are defined to nothing if CONFIG_SYMBOL_PREFIX isn't set: 1) include/asm-generic/unistd.h defines __SYMBOL_PREFIX. 2) include/asm-generic/vmlinux.lds.h defines VMLINUX_SYMBOL(sym) 3) include/linux/export.h defines MODULE_SYMBOL_PREFIX. 4) include/linux/kernel.h defines SYMBOL_PREFIX (which differs from #7) 5) kernel/modsign_certificate.S defines ASM_SYMBOL(sym) 6) scripts/modpost.c defines MODULE_SYMBOL_PREFIX 7) scripts/Makefile.lib defines SYMBOL_PREFIX on the commandline if CONFIG_SYMBOL_PREFIX is set, so that we have a non-string version for pasting. (arch/h8300/include/asm/linkage.h defines SYMBOL_NAME(), too). Let's solve this properly: 1) No more generic prefix, just CONFIG_HAVE_UNDERSCORE_SYMBOL_PREFIX. 2) Make linux/export.h usable from asm. 3) Define VMLINUX_SYMBOL() and VMLINUX_SYMBOL_STR(). 4) Make everyone use them. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: James Hogan <james.hogan@imgtec.com> Tested-by: James Hogan <james.hogan@imgtec.com> (metag)
2013-02-21Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC cleanups from Arnd Bergmann: "A large number of cleanups, all over the platforms. This is dominated largely by the Samsung platforms (s3c, s5p, exynos) and a few of the others moving code out of arch/arm into more appropriate subsystems. The clocksource and irqchip drivers are now abstracted to the point where platforms that are already cleaned up do not need to even specify the driver they use, it can all get configured from the device tree as we do for normal device drivers. The clocksource changes basically touch every single platform in the process. We further clean up the use of platform specific header files here, with the goal of turning more of the platforms over to being "multiplatform" enabled, which implies that they cannot expose their headers to architecture independent code any more. It is expected that no functional changes are part of the cleanup. The overall reduction in total code lines is mostly the result of removing broken and obsolete code." * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (133 commits) ARM: mvebu: correct gated clock documentation ARM: kirkwood: add missing include for nsa310 ARM: exynos: move exynos4210-combiner to drivers/irqchip mfd: db8500-prcmu: update resource passing drivers/db8500-cpufreq: delete dangling include ARM: at91: remove NEOCORE 926 board sunxi: Cleanup the reset code and add meaningful registers defines ARM: S3C24XX: header mach/regs-mem.h local ARM: S3C24XX: header mach/regs-power.h local ARM: S3C24XX: header mach/regs-s3c2412-mem.h local ARM: S3C24XX: Remove plat-s3c24xx directory in arch/arm/ ARM: S3C24XX: transform s3c2443 subirqs into new structure ARM: S3C24XX: modify s3c2443 irq init to initialize all irqs ARM: S3C24XX: move s3c2443 irq code to irq.c ARM: S3C24XX: transform s3c2416 irqs into new structure ARM: S3C24XX: modify s3c2416 irq init to initialize all irqs ARM: S3C24XX: move s3c2416 irq init to common irq code ARM: S3C24XX: Modify s3c_irq_wake to use the hwirq property ARM: S3C24XX: Move irq syscore-ops to irq-pm clocksource: always define CLOCKSOURCE_OF_DECLARE ...
2013-01-24clk: add common of_clk_init() functionPrashant Gaikwad
Modify of_clk_init function so that it will determine which driver to initialize based on device tree instead of each driver registering to it. Based on a similar patch for drivers/irqchip by Thomas Petazzoni and drivers/clocksource by Stephen Warren. Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com> Tested-by: Tony Prisk <linux@prisktech.co.nz> Tested-by: Pawel Moll <pawel.moll@arm.com> Tested-by: Rob Herring <rob.herring@calxeda.com> Tested-by: Josh Cartwright <josh.cartwright@ni.com> Reviewed-by: Josh Cartwright <josh.cartwright@ni.com> Acked-by: Maxime Ripard <maxime.ripard@anandra.org> Signed-off-by: Mike Turquette <mturquette@linaro.org> [mturquette@linaro.org: merge conflict from missing CLKSRC_OF_TABLES()] Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-01-14Merge tag 'gic-vic-to-irqchip' of git://sources.calxeda.com/kernel/linux ↵Olof Johansson
into next/cleanup From Rob Herring: Initial irqchip init infrastructure and GIC and VIC clean-ups This creates irqchip initialization infrastructure from Thomas Petazzoni. The VIC and GIC irqchip code is moved to drivers/irqchips and adapted to use the new infrastructure. All DT enabled platforms using GIC and VIC are converted over to use the new irqchip_init. * tag 'gic-vic-to-irqchip' of git://sources.calxeda.com/kernel/linux: irqchip: Move ARM vic.h to include/linux/irqchip/arm-vic.h ARM: picoxcell: use common irqchip_init function ARM: spear: use common irqchip_init function irqchip: Move ARM VIC to drivers/irqchip ARM: samsung: remove unused tick.h ARM: remove unneeded vic.h includes ARM: remove mach .handle_irq for VIC users ARM: VIC: set handle_arch_irq in VIC initialization ARM: VIC: shrink down vic.h irqchip: Move ARM gic.h to include/linux/irqchip/arm-gic.h ARM: use common irqchip_init for GIC init irqchip: Move ARM GIC to drivers/irqchip ARM: remove mach .handle_irq for GIC users ARM: GIC: set handle_arch_irq in GIC initialization ARM: GIC: remove direct use of gic_raise_softirq ARM: GIC: remove assembly ifdefs from gic.h ARM: mach-ux500: use SGI0 to wake up the other core arm: add set_handle_irq() to register the parent IRQ controller handler function irqchip: add basic infrastructure irqchip: add to the directories part of the IRQ subsystem in MAINTAINERS Fixed up massive merge conflicts with the timer cleanup due to adjacent changes: Signed-off-by: Olof Johansson <olof@lixom.net> Conflicts: arch/arm/mach-bcm/board_bcm.c arch/arm/mach-cns3xxx/cns3420vb.c arch/arm/mach-ep93xx/adssphere.c arch/arm/mach-ep93xx/edb93xx.c arch/arm/mach-ep93xx/gesbc9312.c arch/arm/mach-ep93xx/micro9.c arch/arm/mach-ep93xx/simone.c arch/arm/mach-ep93xx/snappercl15.c arch/arm/mach-ep93xx/ts72xx.c arch/arm/mach-ep93xx/vision_ep9307.c arch/arm/mach-highbank/highbank.c arch/arm/mach-imx/mach-imx6q.c arch/arm/mach-msm/board-dt-8960.c arch/arm/mach-netx/nxdb500.c arch/arm/mach-netx/nxdkn.c arch/arm/mach-netx/nxeb500hmi.c arch/arm/mach-nomadik/board-nhk8815.c arch/arm/mach-picoxcell/common.c arch/arm/mach-realview/realview_eb.c arch/arm/mach-realview/realview_pb1176.c arch/arm/mach-realview/realview_pb11mp.c arch/arm/mach-realview/realview_pba8.c arch/arm/mach-realview/realview_pbx.c arch/arm/mach-socfpga/socfpga.c arch/arm/mach-spear13xx/spear1310.c arch/arm/mach-spear13xx/spear1340.c arch/arm/mach-spear13xx/spear13xx.c arch/arm/mach-spear3xx/spear300.c arch/arm/mach-spear3xx/spear310.c arch/arm/mach-spear3xx/spear320.c arch/arm/mach-spear3xx/spear3xx.c arch/arm/mach-spear6xx/spear6xx.c arch/arm/mach-tegra/board-dt-tegra20.c arch/arm/mach-tegra/board-dt-tegra30.c arch/arm/mach-u300/core.c arch/arm/mach-ux500/board-mop500.c arch/arm/mach-ux500/cpu-db8500.c arch/arm/mach-versatile/versatile_ab.c arch/arm/mach-versatile/versatile_dt.c arch/arm/mach-versatile/versatile_pb.c arch/arm/mach-vexpress/v2m.c include/asm-generic/vmlinux.lds.h
2013-01-10irqchip: add basic infrastructureThomas Petazzoni
With the recent creation of the drivers/irqchip/ directory, it is desirable to move irq controller drivers here. At the moment, the only driver here is irq-bcm2835, the driver for the irq controller found in the ARM BCM2835 SoC, present in Rasberry Pi systems. This irq controller driver was exporting its initialization function and its irq handling function through a header file in <linux/irqchip/bcm2835.h>. When proposing to also move another irq controller driver in drivers/irqchip, Rob Herring raised the very valid point that moving things to drivers/irqchip was good in order to remove more stuff from arch/arm, but if it means adding gazillions of headers files in include/linux/irqchip/, it would not be very nice. So, upon the suggestion of Rob Herring and Arnd Bergmann, this commit introduces a small infrastructure that defines a central irqchip_init() function in drivers/irqchip/irqchip.c, which is meant to be called as the ->init_irq() callback of ARM platforms. This function calls of_irq_init() with an array of match strings and init functions generated from a special linker section. Note that the irq controller driver initialization function is responsible for setting the global handle_arch_irq() variable, so that ARM platforms no longer have to define the ->handle_irq field in their DT_MACHINE structure. A global header, <linux/irqchip.h> is also added to expose the single irqchip_init() function to the reset of the kernel. A further commit moves the BCM2835 irq controller driver to this new small infrastructure, therefore removing the include/linux/irqchip/ directory. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Arnd Bergmann <arnd@arndb.de> [rob.herring: reword commit message to reflect use of linker sections.] Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-01-02clocksource: add common of_clksrc_init() functionStephen Warren
It is desirable to move all clocksource drivers to drivers/clocksource, yet each requires its own initialization function. We'd rather not pollute <linux/> with a header for each function. Instead, create a single of_clksrc_init() function which will determine which clocksource driver to initialize based on device tree. Based on a similar patch for drivers/irqchip by Thomas Petazzoni. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-10-11vmlinux.lds.h: Allow architectures to add sections to the front of .bssDavid Daney
Follow-on MIPS patch will put an object here that needs 64K alignment to minimize padding. For those architectures that don't define BSS_FIRST_SECTIONS, there is no change. Signed-off-by: David Daney <david.daney@cavium.com> Cc: linux-mips@linux-mips.org Cc: linux-arch@vger.kernel.org, Cc: linux-kernel@vger.kernel.org Acked-by: Arnd Bergmann <arnd@arndb.de> Patchwork: https://patchwork.linux-mips.org/patch/4221/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-05-16ftrace: Sort all function addresses, not just per pageSteven Rostedt
Instead of just sorting the ip's of the functions per ftrace page, sort the entire list before adding them to the ftrace pages. This will allow the bsearch algorithm to be sped up as it can also sort by pages, not just records within a page. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-03-26params: <level>_initcall-like kernel parametersPawel Moll
This patch adds a set of macros that can be used to declare kernel parameters to be parsed _before_ initcalls at a chosen level are executed. We rename the now-unused "flags" field of struct kernel_param as the level. It's signed, for when we use this for early params as well, in future. Linker macro collating init calls had to be modified in order to add additional symbols between levels that are later used by the init code to split the calls into blocks. Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-03-23consolidate WARN_...ONCE() static variablesJan Beulich
Due to the alignment of following variables, these typically consume more than just the single byte that 'bool' requires, and as there are a few hundred instances, the cache pollution (not so much the waste of memory) sums up. Put these variables into their own section, outside of any half way frequently used memory range. Do the same also to the __warned variable of rcu_lockdep_assert(). (Don't, however, include the ones used by printk_once() and alike, as they can potentially be hot.) Signed-off-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-24m68k: Finally remove leftover markers sectionsKirill Tkhai
Markers have removed already twice: 1: fc5377668c3d808e1d53c4aee152c836f55c3490 2: eb878b3bc0349344dbf70c51bf01fc734d5cf2d3 But a little bit is still here. Signed-off-by: Tkhai Kirill <tkhai@yandex.ru> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-05-24Merge branch 'for-2.6.40' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.40' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: Unify input section names percpu: Avoid extra NOP in percpu_cmpxchg16b_double percpu: Cast away printk format warning percpu: Always align percpu output section to PAGE_SIZE Fix up fairly trivial conflict in arch/x86/include/asm/percpu.h as per Tejun
2011-05-24Merge branch 'fixes-2.6.39' into for-2.6.40Tejun Heo
2011-05-19Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (107 commits) perf stat: Add more cache-miss percentage printouts perf stat: Add -d -d and -d -d -d options to show more CPU events ftrace/kbuild: Add recordmcount files to force full build ftrace: Add self-tests for multiple function trace users ftrace: Modify ftrace_set_filter/notrace to take ops ftrace: Allow dynamically allocated function tracers ftrace: Implement separate user function filtering ftrace: Free hash with call_rcu_sched() ftrace: Have global_ops store the functions that are to be traced ftrace: Add ops parameter to ftrace_startup/shutdown functions ftrace: Add enabled_functions file ftrace: Use counters to enable functions to trace ftrace: Separate hash allocation and assignment ftrace: Create a global_ops to hold the filter and notrace hashes ftrace: Use hash instead for FTRACE_FL_FILTER ftrace: Replace FTRACE_FL_NOTRACE flag with a hash of ignored functions perf bench, x86: Add alternatives-asm.h wrapper x86, 64-bit: Fix copy_[to/from]_user() checks for the userspace address limit x86, mem: memset_64.S: Optimize memset by enhanced REP MOVSB/STOSB x86, mem: memmove_64.S: Optimize memmove by enhanced REP MOVSB/STOSB ...
2011-05-19module: Sort exported symbolsAlessio Igor Bogani
This patch places every exported symbol in its own section (i.e. "___ksymtab+printk"). Thus the linker will use its SORT() directive to sort and finally merge all symbol in the right and final section (i.e. "__ksymtab"). The symbol prefixed archs use an underscore as prefix for symbols. To avoid collision we use a different character to create the temporary section names. This work was supported by a hardware donation from the CE Linux Forum. Signed-off-by: Alessio Igor Bogani <abogani@kernel.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (folded in '+' fixup) Tested-by: Dirk Behme <dirk.behme@googlemail.com>
2011-04-27Merge branch 'tip/perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/core Conflicts: include/linux/perf_event.h Merge reason: pick up the latest jump-label enhancements, they are cooked ready. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-04-04jump label: Introduce static_branch() interfaceJason Baron
Introduce: static __always_inline bool static_branch(struct jump_label_key *key); instead of the old JUMP_LABEL(key, label) macro. In this way, jump labels become really easy to use: Define: struct jump_label_key jump_key; Can be used as: if (static_branch(&jump_key)) do unlikely code enable/disale via: jump_label_inc(&jump_key); jump_label_dec(&jump_key); that's it! For the jump labels disabled case, the static_branch() becomes an atomic_read(), and jump_label_inc()/dec() are simply atomic_inc(), atomic_dec() operations. We show testing results for this change below. Thanks to H. Peter Anvin for suggesting the 'static_branch()' construct. Since we now require a 'struct jump_label_key *key', we can store a pointer into the jump table addresses. In this way, we can enable/disable jump labels, in basically constant time. This change allows us to completely remove the previous hashtable scheme. Thanks to Peter Zijlstra for this re-write. Testing: I ran a series of 'tbench 20' runs 5 times (with reboots) for 3 configurations, where tracepoints were disabled. jump label configured in avg: 815.6 jump label *not* configured in (using atomic reads) avg: 800.1 jump label *not* configured in (regular reads) avg: 803.4 Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20110316212947.GA8792@redhat.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Suggested-by: H. Peter Anvin <hpa@linux.intel.com> Tested-by: David Daney <ddaney@caviumnetworks.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-04-04percpu: Unify input section namesMike Frysinger
The two percpu helper macros have the section names duplicated. So create a new define to merge the two. This also allows arches who need to link things more directly themselves to avoid duplicating the input sections in their linker script. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2011-03-24percpu: Always align percpu output section to PAGE_SIZETejun Heo
Percpu allocator honors alignment request upto PAGE_SIZE and both the percpu addresses in the percpu address space and the translated kernel addresses should be aligned accordingly. The calculation of the former depends on the alignment of percpu output section in the kernel image. The linker script macros PERCPU_VADDR() and PERCPU() are used to define this output section and the latter takes @align parameter. Several architectures are using @align smaller than PAGE_SIZE breaking percpu memory alignment. This patch removes @align parameter from PERCPU(), renames it to PERCPU_SECTION() and makes it always align to PAGE_SIZE. While at it, add PCPU_SETUP_BUG_ON() checks such that alignment problems are reliably detected and remove percpu alignment comment recently added in workqueue.c as the condition would trigger BUG way before reaching there. For um, this patch raises the alignment of percpu area. As the area is in .init, there shouldn't be any noticeable difference. This problem was discovered by David Howells while debugging boot failure on mn10300. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: uclinux-dist-devel@blackfin.uclinux.org Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: user-mode-linux-devel@lists.sourceforge.net
2011-03-16Merge branch 'for-2.6.39' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu, x86: Add arch-specific this_cpu_cmpxchg_double() support percpu: Generic support for this_cpu_cmpxchg_double() alpha: use L1_CACHE_BYTES for cacheline size in the linker script percpu: align percpu readmostly subsection to cacheline Fix up trivial conflict in arch/x86/kernel/vmlinux.lds.S due to the percpu alignment having changed ("x86: Reduce back the alignment of the per-CPU data section")
2011-03-08x86: Separate out entry text sectionJiri Olsa
Put x86 entry code into a separate link section: .entry.text. Separating the entry text section seems to have performance benefits - caused by more efficient instruction cache usage. Running hackbench with perf stat --repeat showed that the change compresses the icache footprint. The icache load miss rate went down by about 15%: before patch: 19417627 L1-icache-load-misses ( +- 0.147% ) after patch: 16490788 L1-icache-load-misses ( +- 0.180% ) The motivation of the patch was to fix a particular kprobes bug that relates to the entry text section, the performance advantage was discovered accidentally. Whole perf output follows: - results for current tip tree: Performance counter stats for './hackbench/hackbench 10' (500 runs): 19417627 L1-icache-load-misses ( +- 0.147% ) 2676914223 instructions # 0.497 IPC ( +- 0.079% ) 5389516026 cycles ( +- 0.144% ) 0.206267711 seconds time elapsed ( +- 0.138% ) - results for current tip tree with the patch applied: Performance counter stats for './hackbench/hackbench 10' (500 runs): 16490788 L1-icache-load-misses ( +- 0.180% ) 2717734941 instructions # 0.502 IPC ( +- 0.079% ) 5414756975 cycles ( +- 0.148% ) 0.206747566 seconds time elapsed ( +- 0.137% ) Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: masami.hiramatsu.pt@hitachi.com Cc: ananth@in.ibm.com Cc: davem@davemloft.net Cc: 2nddept-manager@sdl.hitachi.co.jp LKML-Reference: <20110307181039.GB15197@jolsa.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-02-03tracing: Replace syscall_meta_data struct array with pointer arraySteven Rostedt
Currently the syscall_meta structures for the syscall tracepoints are placed in the __syscall_metadata section, and at link time, the linker makes one large array of all these syscall metadata structures. On boot up, this array is read (much like the initcall sections) and the syscall data is processed. The problem is that there is no guarantee that gcc will place complex structures nicely together in an array format. Two structures in the same file may be placed awkwardly, because gcc has no clue that they are suppose to be in an array. A hack was used previous to force the alignment to 4, to pack the structures together. But this caused alignment issues with other architectures (sparc). Instead of packing the structures into an array, the structures' addresses are now put into the __syscall_metadata section. As pointers are always the natural alignment, gcc should always pack them tightly together (otherwise initcall, extable, etc would also fail). By having the pointers to the structures in the section, we can still iterate the trace_events without causing unnecessary alignment problems with other architectures, or depending on the current behaviour of gcc that will likely change in the future just to tick us kernel developers off a little more. The __syscall_metadata section is also moved into the .init.data section as it is now only needed at boot up. Suggested-by: David Miller <davem@davemloft.net> Acked-by: David S. Miller <davem@davemloft.net> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-02-03tracepoints: Fix section alignment using pointer arrayMathieu Desnoyers
Make the tracepoints more robust, making them solid enough to handle compiler changes by not relying on anything based on compiler-specific behavior with respect to structure alignment. Implement an approach proposed by David Miller: use an array of const pointers to refer to the individual structures, and export this pointer array through the linker script rather than the structures per se. It will consume 32 extra bytes per tracepoint (24 for structure padding and 8 for the pointers), but are less likely to break due to compiler changes. History: commit 7e066fb8 tracepoints: add DECLARE_TRACE() and DEFINE_TRACE() added the aligned(32) type and variable attribute to the tracepoint structures to deal with gcc happily aligning statically defined structures on 32-byte multiples. One attempt was to use a 8-byte alignment for tracepoint structures by applying both the variable and type attribute to tracepoint structures definitions and declarations. It worked fine with gcc 4.5.1, but broke with gcc 4.4.4 and 4.4.5. The reason is that the "aligned" attribute only specify the _minimum_ alignment for a structure, leaving both the compiler and the linker free to align on larger multiples. Because tracepoint.c expects the structures to be placed as an array within each section, up-alignment cause NULL-pointer exceptions due to the extra unexpected padding. (this patch applies on top of -tip) Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: David S. Miller <davem@davemloft.net> LKML-Reference: <20110126222622.GA10794@Krystal> CC: Frederic Weisbecker <fweisbec@gmail.com> CC: Ingo Molnar <mingo@elte.hu> CC: Thomas Gleixner <tglx@linutronix.de> CC: Andrew Morton <akpm@linux-foundation.org> CC: Peter Zijlstra <peterz@infradead.org> CC: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-02-02tracing: Replace trace_event struct array with pointer arraySteven Rostedt
Currently the trace_event structures are placed in the _ftrace_events section, and at link time, the linker makes one large array of all the trace_event structures. On boot up, this array is read (much like the initcall sections) and the events are processed. The problem is that there is no guarantee that gcc will place complex structures nicely together in an array format. Two structures in the same file may be placed awkwardly, because gcc has no clue that they are suppose to be in an array. A hack was used previous to force the alignment to 4, to pack the structures together. But this caused alignment issues with other architectures (sparc). Instead of packing the structures into an array, the structures' addresses are now put into the _ftrace_event section. As pointers are always the natural alignment, gcc should always pack them tightly together (otherwise initcall, extable, etc would also fail). By having the pointers to the structures in the section, we can still iterate the trace_events without causing unnecessary alignment problems with other architectures, or depending on the current behaviour of gcc that will likely change in the future just to tick us kernel developers off a little more. The _ftrace_event section is also moved into the .init.data section as it is now only needed at boot up. Suggested-by: David Miller <davem@davemloft.net> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-01-25percpu: align percpu readmostly subsection to cachelineTejun Heo
Currently percpu readmostly subsection may share cachelines with other percpu subsections which may result in unnecessary cacheline bounce and performance degradation. This patch adds @cacheline parameter to PERCPU() and PERCPU_VADDR() linker macros, makes each arch linker scripts specify its cacheline size and use it to align percpu subsections. This is based on Shaohua's x86 only patch. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Shaohua Li <shaohua.li@intel.com>
2011-01-24module: show version information for built-in modules in sysfsDmitry Torokhov
Currently only drivers that are built as modules have their versions shown in /sys/module/<module_name>/version, but this information might also be useful for built-in drivers as well. This especially important for drivers that do not define any parameters - such drivers, if built-in, are completely invisible from userspace. This patch changes MODULE_VERSION() macro so that in case when we are compiling built-in module, version information is stored in a separate section. Kernel then uses this data to create 'version' sysfs attribute in the same fashion it creates attributes for module parameters. Signed-off-by: Dmitry Torokhov <dtor@vmware.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-01-13include/asm-generic/vmlinux.lds.h: make readmostly section correctly alignShaohua Li
The readmostly section should end at a cacheline aligned address, otherwise the last several data might share cachline with other data and make the readmostly data still have cache bounce. For example, in ia64, secpath_cachep is the last readmostly data, and it shares cacheline with init_uts_ns. a000000100e80480 d secpath_cachep a000000100e80488 D init_uts_ns Signed-off-by: Shaohua Li <shaohua.li@intel.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-23of: Add support for linking device tree blobs into vmlinuxDirk Brandewie
This patch adds support for linking device tree blob(s) into vmlinux. Modifies asm-generic/vmlinux.lds.h to add linking .dtb sections into vmlinux. To maintain compatiblity with the of/fdt driver code platforms MUST copy the blob to a non-init memory location before the kernel frees the .init.* sections in the image. Modifies scripts/Makefile.lib to add a kbuild command to compile DTS files to device tree blobs and a rule to create objects to wrap the blobs for linking. STRUCT_ALIGNMENT is defined in vmlinux.lds.h for use in the rule to create wrapper objects for the dtb in Makefile.lib. The STRUCT_ALIGN() macro in vmlinux.lds.h is modified to use the STRUCT_ALIGNMENT definition. The DTB's are placed on 32 byte boundries to allow parsing the blob with driver/of/fdt.c during early boot without having to copy the blob to get the structure alignment GCC expects. A DTB is linked in by adding the DTB object to the list of objects to be linked into vmlinux in the archtecture specific Makefile using obj-y += foo.dtb.o Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Acked-by: Michal Marek <mmarek@suse.cz> [grant.likely@secretlab.ca: cleaned up whitespace inconsistencies] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-28Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: initramfs: Fix build break on symbol-prefixed archs initramfs: fix initramfs size calculation initramfs: generalize initramfs_data.xxx.S variants scripts/kallsyms: Enable error messages while hush up unnecessary warnings scripts/setlocalversion: update comment kbuild: Use a single clean rule for kernel and external modules kbuild: Do not run make clean in $(srctree) scripts/mod/modpost.c: fix commentary accordingly to last changes kbuild: Really don't clean bounds.h and asm-offsets.h
2010-10-26vmlinux.lds.h: lower init ramfs alignment to 4Mike Frysinger
The new init ramfs format (cpio based) requires an alignment of 4 (per the documentation and per the source files themselves). As for compressed sources, the decompressors can all deal with unaligned buffers. The cpio source is also found in the __init sections of the kernel, so once they are read and expanded into a tmpfs, the source is freed. That means there is no need to force page alignment here either. This has been used on Blackfin systems for many releases without issue. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26vmlinux.lds.h: gather .data..shared_aligned sections in DATA_DATAMike Frysinger
With the recent change "net: remove time limit in process_backlog()", the softnet_data variable changed from "DEFINE_PER_CPU()" to "DEFINE_PER_CPU_ALIGNED()" which moved it from the .data section to the .data.shared_align section. I'm not saying this patch is wrong, just that is what caused me to notice this larger problem. No one else in the kernel is using this aligned macro variant, so I imagine that's why no one has noticed yet. Since .data..shared_align isn't declared in any vmlinux files that I can see, the linker just places it last. This "just works" for most people, but when building a ROM kernel on Blackfin systems, it causes section overlap errors: bfin-uclinux-ld.real: section .init.data [00000000202e06b8 -> 00000000202e48b7] overlaps section .data.shared_aligned [00000000202e06b8 -> 00000000202e0723] I imagine other arches which support the ROM config option and thus do funky placement would see similar issues ... On x86, it is stuck in a dedicated section at the end: [8] .data PROGBITS ffffffff810ec000 2ec0000303a8 00 WA 0 0 4096 [9] .data.shared_alig PROGBITS ffffffff8111c3c0 31c3c00000c8 00 WA 0 0 64 So make sure we include this section in the DATA_DATA macro so that it is placed in the right location. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Cc: Greg Ungerer <gerg@snapgear.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-21Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86-32, percpu: Correct the ordering of the percpu readmostly section x86, mm: Enable ARCH_DMA_ADDR_T_64BIT with X86_64 || HIGHMEM64G x86: Spread tlb flush vector between nodes percpu: Introduce a read-mostly percpu API x86, mm: Fix incorrect data type in vmalloc_sync_all() x86, mm: Hold mm->page_table_lock while doing vmalloc_sync x86, mm: Fix bogus whitespace in sync_global_pgds() x86-32: Fix sparse warning for the __PHYSICAL_MASK calculation x86, mm: Add RESERVE_BRK_ARRAY() helper mm, x86: Saving vmcore with non-lazy freeing of vmas x86, kdump: Change copy_oldmem_page() to use cached addressing x86, mm: fix uninitialized addr in kernel_physical_mapping_init() x86, kmemcheck: Remove double test x86, mm: Make spurious_fault check explicitly check the PRESENT bit x86-64, mem: Update all PGDs for direct mapping and vmemmap mapping changes x86, mm: Separate x86_64 vmalloc_sync_all() into separate functions x86, mm: Avoid unnecessary TLB flush
2010-10-21x86-32, percpu: Correct the ordering of the percpu readmostly sectionH. Peter Anvin
Checkin c957ef2c59e952803766ddc22e89981ab534606f had inconsistent ordering of .data..percpu..page_aligned and .data..percpu..readmostly; the still-broken version affected x86-32 at least. The page aligned version really must be page aligned... Signed-off-by: H. Peter Anvin <hpa@zytor.com> LKML-Reference: <1287544022.4571.7.camel@sli10-conroe.sh.intel.com> Cc: Shaohua Li <shaohua.li@intel.com> Cc: Eric Dumazet <eric.dumazet@gmail.com>
2010-10-20percpu: Introduce a read-mostly percpu APIShaohua Li
Add a new readmostly percpu section and API. This can be used to avoid dirtying data lines which are generally not written to, which is especially important for data which may be accessed by processors other than the one for which the percpu area belongs to. [ hpa: moved it *after* the page-aligned section, for obvious reasons. ] Signed-off-by: Shaohua Li <shaohua.li@intel.com> LKML-Reference: <1287544022.4571.7.camel@sli10-conroe.sh.intel.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-09-29initramfs: fix initramfs size calculationHendrik Brueckner
The size of a built-in initramfs is calculated in init/initramfs.c by "__initramfs_end - __initramfs_start". Those symbols are defined in the linker script include/asm-generic/vmlinux.lds.h: #define INIT_RAM_FS \ . = ALIGN(PAGE_SIZE); \ VMLINUX_SYMBOL(__initramfs_start) = .; \ *(.init.ramfs) \ VMLINUX_SYMBOL(__initramfs_end) = .; If the initramfs file has an odd number of bytes, the "__initramfs_end" symbol points to an odd address, for example, the symbols in the System.map might look like: 0000000000572000 T __initramfs_start 00000000005bcd05 T __initramfs_end <-- odd address At least on s390 this causes a problem: Certain s390 instructions, especially instructions for loading addresses (larl) or branch addresses must be on even addresses. The compiler loads the symbol addresses with the "larl" instruction. This instruction sets the last bit to 0 and, therefore, for odd size files, the calculated size is one byte less than it should be: 0000000000540a9c <populate_rootfs>: 540a9c: eb cf f0 78 00 24 stmg %r12,%r15,120(%r15), 540aa2: c0 10 00 01 8a af larl %r1,572000 <__initramfs_start> 540aa8: c0 c0 00 03 e1 2e larl %r12,5bcd04 <initramfs_end> (Instead of 5bcd05) ... 540abe: 1b c1 sr %r12,%r1 To fix the problem, this patch introduces the global variable __initramfs_size, which is calculated in the "usr/initramfs_data.S" file. The populate_rootfs() function can then use the start marker of the .init.ramfs section and the value of __initramfs_size for loading the initramfs. Because the start marker and size is sufficient, the __initramfs_end symbol is no longer needed and is removed. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: Michal Marek <mmarek@suse.cz> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-09-22jump label: Base patch for jump labelJason Baron
base patch to implement 'jump labeling'. Based on a new 'asm goto' inline assembly gcc mechanism, we can now branch to labels from an 'asm goto' statment. This allows us to create a 'no-op' fastpath, which can subsequently be patched with a jump to the slowpath code. This is useful for code which might be rarely used, but which we'd like to be able to call, if needed. Tracepoints are the current usecase that these are being implemented for. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jason Baron <jbaron@redhat.com> LKML-Reference: <ee8b3595967989fdaf84e698dc7447d315ce972a.1284733808.git.jbaron@redhat.com> [ cleaned up some formating ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-08-06Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (162 commits) tracing/kprobes: unregister_trace_probe needs to be called under mutex perf: expose event__process function perf events: Fix mmap offset determination perf, powerpc: fsl_emb: Restore setting perf_sample_data.period perf, powerpc: Convert the FSL driver to use local64_t perf tools: Don't keep unreferenced maps when unmaps are detected perf session: Invalidate last_match when removing threads from rb_tree perf session: Free the ref_reloc_sym memory at the right place x86,mmiotrace: Add support for tracing STOS instruction perf, sched migration: Librarize task states and event headers helpers perf, sched migration: Librarize the GUI class perf, sched migration: Make the GUI class client agnostic perf, sched migration: Make it vertically scrollable perf, sched migration: Parameterize cpu height and spacing perf, sched migration: Fix key bindings perf, sched migration: Ignore unhandled task states perf, sched migration: Handle ignored migrate out events perf: New migration tool overview tracing: Drop cpparg() macro perf: Use tracepoint_synchronize_unregister() to flush any pending tracepoint call ... Fix up trivial conflicts in Makefile and drivers/cpufreq/cpufreq.c
2010-08-04Merge branch 'upstream/pvhvm' into upstream/xenJeremy Fitzhardinge
* upstream/pvhvm: Introduce CONFIG_XEN_PVHVM compile option blkfront: do not create a PV cdrom device if xen_hvm_guest support multiple .discard.* sections to avoid section type conflicts xen/pvhvm: fix build problem when !CONFIG_XEN xenfs: enable for HVM domains too x86: Call HVMOP_pagetable_dying on exit_mmap. x86: Unplug emulated disks and nics. x86: Use xen_vcpuop_clockevent, xen_clocksource and xen wallclock. xen: Fix find_unbound_irq in presence of ioapic irqs. xen: Add suspend/resume support for PV on HVM guests. xen: Xen PCI platform device driver. x86/xen: event channels delivery on HVM. x86: early PV on HVM features initialization. xen: Add support for HVM hypercalls. Conflicts: arch/x86/xen/enlighten.c arch/x86/xen/time.c
2010-08-02Merge commit 'v2.6.35' into perf/coreIngo Molnar
Conflicts: tools/perf/Makefile tools/perf/util/hist.c Merge reason: Resolve the conflicts and update to latest upstream. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-07-27support multiple .discard.* sections to avoid section type conflictsJeremy Fitzhardinge
gcc 4.4.4 will complain if you use a .discard section for both text and data ("causes a section type conflict"). Add support for ".discard.*" sections, and use .discard.text for a dummy function in the x86 RESERVE_BRK() macro. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2010-07-23Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: vmlinux.lds: fix .data..init_task output section (fix popwerpc boot) powerpc: Fix erroneous lmb->memblock conversions powerpc/mm: Add some debug output when hash insertion fails powerpc/mm: Fix bugs in huge page hashing powerpc/mm: Move around testing of _PAGE_PRESENT in hash code powerpc/mm: Handle hypervisor pte insert failure in __hash_page_huge powerpc/kexec: Fix boundary case for book-e kexec memory limits
2010-07-23vmlinux.lds: fix .data..init_task output section (fix popwerpc boot)Sam Ravnborg
The .data..init_task output section was missing a load offset causing a popwerpc target to fail to boot. Sean MacLennan tracked it down to the definition of INIT_TASK_DATA_SECTION(). There are only two users of INIT_TASK_DATA_SECTION() in the kernel today: cris and popwerpc. cris do not support relocatable kernels and is thus not impacted by this change. Fix INIT_TASK_DATA_SECTION() to specify load offset like all other output sections. Reported-by: Sean MacLennan <smaclennan@pikatech.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-07-20tracing: Properly align linker defined symbolsSam Ravnborg
We define a number of symbols in the linker scipt like this: __start_syscalls_metadata = .; *(__syscalls_metadata) But we do not know the alignment of "." when we assign the __start_syscalls_metadata symbol. gcc started to uses bigger alignment for structs (32 bytes), so we saw situations where the linker due to alignment constraints increased the value of "." after the symbol assignment. This resulted in boot fails. Fix this by forcing a 32 byte alignment of "." before the assignment. This patch introduces the forced alignment for ftrace_events and syscalls_metadata. It may be required in more places. Reported-by: Zeev Tarantov <zeev.tarantov@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> LKML-Reference: <20100710063459.GA14596@merkur.ravnborg.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
