Add early_memremap() support to be able to specify encrypted and
decrypted mappings with and without write-protection. The use of
write-protection is necessary when encrypting data "in place". The
write-protect attribute is considered cacheable for loads, but not
stores. This implies that the hardware will never give the core a
dirty line with this memtype.
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Cc: Alexander Potapenko <glider@google.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Brijesh Singh <brijesh.singh@amd.com>
Cc: Dave Young <dyoung@redhat.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Larry Woodman <lwoodman@redhat.com>
Cc: Matt Fleming <matt@codeblueprint.co.uk>
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: Toshimitsu Kani <toshi.kani@hpe.com>
Cc: kasan-dev@googlegroups.com
Cc: kvm@vger.kernel.org
Cc: linux-doc@vger.kernel.org
Cc: linux-efi@vger.kernel.org
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/479b5832c30fae3efa7932e48f81794e86397229.1500319216.git.thomas.lendacky@amd.com
Changes to the existing page table macros will allow the SME support to
be enabled in a simple fashion with minimal changes to files that use these
macros. Since the memory encryption mask will now be part of the regular
pagetable macros, we introduce two new macros (_PAGE_TABLE_NOENC and
_KERNPG_TABLE_NOENC) to allow for early pagetable creation/initialization
without the encryption mask before SME becomes active. Two new pgprot()
macros are defined to allow setting or clearing the page encryption mask.
The FIXMAP_PAGE_NOCACHE define is introduced for use with MMIO. SME does
not support encryption for MMIO areas so this define removes the encryption
mask from the page attribute.
Two new macros are introduced (__sme_pa() / __sme_pa_nodebug()) to allow
creating a physical address with the encryption mask. These are used when
working with the cr3 register so that the PGD can be encrypted. The current
__va() macro is updated so that the virtual address is generated based off
of the physical address without the encryption mask thus allowing the same
virtual address to be generated regardless of whether encryption is enabled
for that physical location or not.
Also, an early initialization function is added for SME. If SME is active,
this function:
- Updates the early_pmd_flags so that early page faults create mappings
- Updates the __supported_pte_mask to include the encryption mask.
- Updates the protection_map entries to include the encryption mask so
that user-space allocations will automatically have the encryption mask
applied.
Link: http://lkml.kernel.org/r/b36e952c4c39767ae7f0a41cf5345adf27438480.1500319216.git.thomas.lendacky@amd.com
Pull uacess-unaligned removal from Al Viro:
"That stuff had just one user, and an exotic one, at that - binfmt_flat
on arm and m68k"
* 'work.uaccess-unaligned' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
kill {__,}{get,put}_user_unaligned()
binfmt_flat: flat_{get,put}_addr_from_rp() should be able to fail
This series of patches splits BUILD_BUG related macros out of
"include/linux/bug.h" into new file "include/linux/build_bug.h" (patch
5), and changes the pointer type checking in the `container_of()` macro
to deal with pointers of array type better (patch 6). Patches 1 to 4
are prerequisites.
Patches 2, 3, 4, and 5 have been inserted since the previous version of
this patch series. Patch 6 here corresponds to v3 and v4's patch 2.
Patch 1 was a prerequisite in v3 of this series to avoid a lot of
warnings when <linux/bug.h> was included by <linux/kernel.h>. That is
no longer relevant for v5 of the series, but I left it in because it was
acked by a Arnd Bergmann and Michal Nazarewicz.
Patches 2, 3, and 4 are some checkpatch clean-ups on
"include/linux/bug.h" before splitting out the BUILD_BUG stuff in patch
5.
Patch 5 splits the BUILD_BUG related macros out of "include/linux/bug.h"
into new file "include/linux/build_bug.h" because including
<linux/bug.h> in "include/linux/kernel.h" would result in build failures
due to circular dependencies.
Patch 6 changes the pointer type checking by `container_of()` to avoid
some incompatible pointer warnings when the dereferenced pointer has
array type.
1) asm-generic/bug.h: declare struct pt_regs; before function prototype
2) linux/bug.h: correct formatting of block comment
3) linux/bug.h: correct "(foo*)" should be "(foo *)"
4) linux/bug.h: correct "space required before that '-'"
5) bug: split BUILD_BUG stuff out into <linux/build_bug.h>
6) kernel.h: handle pointers to arrays better in container_of()
This patch (of 6):
The declaration of `__warn()` has `struct pt_regs *regs` as one of its
parameters. This can result in compiler warnings if `struct regs` is not
already declared. Add an empty declaration of `struct pt_regs` to avoid
the warnings.
Link: http://lkml.kernel.org/r/20170525120316.24473-2-abbotti@mev.co.uk
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
Acked-by: Michal Nazarewicz <mina86@mina86.com>
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc updates from Michael Ellerman:
"Highlights include:
- Support for STRICT_KERNEL_RWX on 64-bit server CPUs.
- Platform support for FSP2 (476fpe) board
- Enable ZONE_DEVICE on 64-bit server CPUs.
- Generic & powerpc spin loop primitives to optimise busy waiting
- Convert VDSO update function to use new update_vsyscall() interface
- Optimisations to hypercall/syscall/context-switch paths
- Improvements to the CPU idle code on Power8 and Power9.
As well as many other fixes and improvements.
Thanks to: Akshay Adiga, Andrew Donnellan, Andrew Jeffery, Anshuman
Khandual, Anton Blanchard, Balbir Singh, Benjamin Herrenschmidt,
Christophe Leroy, Christophe Lombard, Colin Ian King, Dan Carpenter,
Gautham R. Shenoy, Hari Bathini, Ian Munsie, Ivan Mikhaylov, Javier
Martinez Canillas, Madhavan Srinivasan, Masahiro Yamada, Matt Brown,
Michael Neuling, Michal Suchanek, Murilo Opsfelder Araujo, Naveen N.
Rao, Nicholas Piggin, Oliver O'Halloran, Paul Mackerras, Pavel Machek,
Russell Currey, Santosh Sivaraj, Stephen Rothwell, Thiago Jung
Bauermann, Yang Li"
* tag 'powerpc-4.13-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (158 commits)
powerpc/Kconfig: Enable STRICT_KERNEL_RWX for some configs
powerpc/mm/radix: Implement STRICT_RWX/mark_rodata_ro() for Radix
powerpc/mm/hash: Implement mark_rodata_ro() for hash
powerpc/vmlinux.lds: Align __init_begin to 16M
powerpc/lib/code-patching: Use alternate map for patch_instruction()
powerpc/xmon: Add patch_instruction() support for xmon
powerpc/kprobes/optprobes: Use patch_instruction()
powerpc/kprobes: Move kprobes over to patch_instruction()
powerpc/mm/radix: Fix execute permissions for interrupt_vectors
powerpc/pseries: Fix passing of pp0 in updatepp() and updateboltedpp()
powerpc/64s: Blacklist rtas entry/exit from kprobes
powerpc/64s: Blacklist functions invoked on a trap
powerpc/64s: Un-blacklist system_call() from kprobes
powerpc/64s: Move system_call() symbol to just after setting MSR_EE
powerpc/64s: Blacklist system_call() and system_call_common() from kprobes
powerpc/64s: Convert .L__replay_interrupt_return to a local label
powerpc64/elfv1: Only dereference function descriptor for non-text symbols
cxl: Export library to support IBM XSL
powerpc/dts: Use #include "..." to include local DT
powerpc/perf/hv-24x7: Aggregate result elements on POWER9 SMT8
Merge misc updates from Andrew Morton:
- a few hotfixes
- various misc updates
- ocfs2 updates
- most of MM
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (108 commits)
mm, memory_hotplug: move movable_node to the hotplug proper
mm, memory_hotplug: drop CONFIG_MOVABLE_NODE
mm, memory_hotplug: drop artificial restriction on online/offline
mm: memcontrol: account slab stats per lruvec
mm: memcontrol: per-lruvec stats infrastructure
mm: memcontrol: use generic mod_memcg_page_state for kmem pages
mm: memcontrol: use the node-native slab memory counters
mm: vmstat: move slab statistics from zone to node counters
mm/zswap.c: delete an error message for a failed memory allocation in zswap_dstmem_prepare()
mm/zswap.c: improve a size determination in zswap_frontswap_init()
mm/zswap.c: delete an error message for a failed memory allocation in zswap_pool_create()
mm/swapfile.c: sort swap entries before free
mm/oom_kill: count global and memory cgroup oom kills
mm: per-cgroup memory reclaim stats
mm: kmemleak: treat vm_struct as alternative reference to vmalloc'ed objects
mm: kmemleak: factor object reference updating out of scan_block()
mm: kmemleak: slightly reduce the size of some structures on 64-bit architectures
mm, mempolicy: don't check cpuset seqlock where it doesn't matter
mm, cpuset: always use seqlock when changing task's nodemask
mm, mempolicy: simplify rebinding mempolicies when updating cpusets
Pull user access str* updates from Al Viro:
"uaccess str...() dead code removal"
* 'uaccess.strlen' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
s390 keyboard.c: don't open-code strndup_user()
mips: get rid of unused __strnlen_user()
get rid of unused __strncpy_from_user() instances
kill strlen_user()
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing updates from Steven Rostedt:
"The new features of this release:
- Added TRACE_DEFINE_SIZEOF() which allows trace events that use
sizeof() it the TP_printk() to be converted to the actual size such
that trace-cmd and perf can parse them correctly.
- Some rework of the TRACE_DEFINE_ENUM() such that the above
TRACE_DEFINE_SIZEOF() could reuse the same code.
- Recording of tgid (Thread Group ID). This is similar to how task
COMMs are recorded (cached at sched_switch), where it is in a table
and used on output of the trace and trace_pipe files.
- Have ":mod:<module>" be cached when written into set_ftrace_filter.
Then the functions of the module will be traced at module load.
- Some random clean ups and small fixes"
* tag 'trace-v4.13' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (26 commits)
ftrace: Test for NULL iter->tr in regex for stack_trace_filter changes
ftrace: Decrement count for dyn_ftrace_total_info for init functions
ftrace: Unlock hash mutex on failed allocation in process_mod_list()
tracing: Add support for display of tgid in trace output
tracing: Add support for recording tgid of tasks
ftrace: Decrement count for dyn_ftrace_total_info file
ftrace: Remove unused function ftrace_arch_read_dyn_info()
sh/ftrace: Remove only user of ftrace_arch_read_dyn_info()
ftrace: Have cached module filters be an active filter
ftrace: Implement cached modules tracing on module load
ftrace: Have the cached module list show in set_ftrace_filter
ftrace: Add :mod: caching infrastructure to trace_array
tracing: Show address when function names are not found
ftrace: Add missing comment for FTRACE_OPS_FL_RCU
tracing: Rename update the enum_map file
tracing: Add TRACE_DEFINE_SIZEOF() macros
tracing: define TRACE_DEFINE_SIZEOF() macro to map sizeof's to their values
tracing: Rename enum_replace to eval_replace
trace: rename enum_map functions
trace: rename trace.c enum functions
When unmapping a hugepage range, huge_pte_clear() is used to clear the
page table entries that are marked as not present. huge_pte_clear()
internally just ends up calling pte_clear() which does not correctly
deal with hugepages consisting of contiguous page table entries.
Add a size argument to address this issue and allow architectures to
override huge_pte_clear() by wrapping it in a #ifndef block.
Update s390 implementation with the size parameter as well.
Note that the change only affects huge_pte_clear() - the other generic
hugetlb functions don't need any change.
Link: http://lkml.kernel.org/r/20170522162555.4313-1-punit.agrawal@arm.com
Signed-off-by: Punit Agrawal <punit.agrawal@arm.com>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390 bits]
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Steve Capper <steve.capper@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
Cc: Michal Hocko <mhocko@suse.com>
no users left
The config option name is now renamed to 'TIMER_OF' for consistency with
the CLOCKSOURCE_OF_DECLARE => TIMER_OF_DECLARE change.
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
The table name is now renamed to 'timer' for consistency with
The kernel and its modules have sections containing the enum
string to value conversions. Rename this section because we
intend to store more than enums in it.
Link: http://lkml.kernel.org/r/20170531215653.3240-2-jeremy.linton@arm.com
Signed-off-by: Jeremy Linton <jeremy.linton@arm.com>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
After discussing it, this feature is dropped as it is not considered
adequate:
https://patchwork.kernel.org/patch/9639317/
There is no user of this macro yet, so there is no impact on the drivers.
This reverts commit 376bc27150f180d9f5eddec6a14117780177589d.
By moving the kernel side __SI_* defintions right next to the userspace
ones we can kill the non-uapi versions of <asm/siginfo.h> include
include/asm-generic/siginfo.h and untangle the unholy mess of includes.
[ tglx: Removed uapi/asm/siginfo.h from m32r, microblaze, mn10300 and score ]
Cc: linux-ia64@vger.kernel.org
Cc: sparclinux@vger.kernel.org
Link: http://lkml.kernel.org/r/20170603190102.28866-6-hch@lst.de
Having it in asm-generic/siginfo.h doesn't make any sense as it is in no way
architecture specific. Move it to signal.h instead where several related
functions already reside.
Link: http://lkml.kernel.org/r/20170603190102.28866-5-hch@lst.de
architecture specific. Move it to posix-timers.h instead.
Link: http://lkml.kernel.org/r/20170603190102.28866-4-hch@lst.de
Add --orphan-handling=warn to final link flags. This ensures we can
handle all sections explicitly. This would have caught subtle breakage
such as 7de3b27bac47da9de08409df1d69664acbb72197 at build-time.
Also bring existing orphan sections into the fold:
- .text.hot and .text.unlikely are compiler generated sections.
- .sdata2, .dynsbss, .plt are used by PPC32
- We previously did not specify DWARF_DEBUG or STABS_DEBUG
- DWARF_DEBUG did not include all DWARF sections that can be emitted
- A number of sections are unused and can be discarded.
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
no callers, no consistent semantics, no sane way to use it...
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull Kbuild UAPI updates from Masahiro Yamada:
"Improvement of headers_install by Nicolas Dichtel.
It has been long since the introduction of uapi directories, but the
de-coupling of exported headers has not been completed. Headers listed
in header-y are exported whether they exist in uapi directories or
not. His work fixes this inconsistency.
All (and only) headers under uapi directories are now exported. The
asm-generic wrappers are still exceptions, but this is a big step
forward"
* tag 'kbuild-uapi-v4.12' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild:
arch/include: remove empty Kbuild files
uapi: export all arch specifics directories
uapi: export all headers under uapi directories
smc_diag.h: fix include from userland
btrfs_tree.h: fix include from userland
uapi: includes linux/types.h before exporting files
Makefile.headersinst: remove destination-y option
Makefile.headersinst: cleanup input files
x86: stop exporting msr-index.h to userland
nios2: put setup.h in uapi
h8300: put bitsperlong.h in uapi
Regularly, when a new header is created in include/uapi/, the developer
forgets to add it in the corresponding Kbuild file. This error is usually
detected after the release is out.
In fact, all headers under uapi directories should be exported, thus it's
useless to have an exhaustive list.
After this patch, the following files, which were not exported, are now
exported (with make headers_install_all):
asm-arc/kvm_para.h
asm-arc/ucontext.h
asm-blackfin/shmparam.h
asm-blackfin/ucontext.h
asm-c6x/shmparam.h
asm-c6x/ucontext.h
asm-cris/kvm_para.h
asm-h8300/shmparam.h
asm-h8300/ucontext.h
asm-hexagon/shmparam.h
asm-m32r/kvm_para.h
asm-m68k/kvm_para.h
asm-m68k/shmparam.h
asm-metag/kvm_para.h
asm-metag/shmparam.h
asm-metag/ucontext.h
asm-mips/hwcap.h
asm-mips/reg.h
asm-mips/ucontext.h
asm-nios2/kvm_para.h
asm-nios2/ucontext.h
asm-openrisc/shmparam.h
asm-parisc/kvm_para.h
asm-powerpc/perf_regs.h
asm-sh/kvm_para.h
asm-sh/ucontext.h
asm-tile/shmparam.h
asm-unicore32/shmparam.h
asm-unicore32/ucontext.h
asm-x86/hwcap2.h
asm-xtensa/kvm_para.h
drm/armada_drm.h
drm/etnaviv_drm.h
drm/vgem_drm.h
linux/aspeed-lpc-ctrl.h
linux/auto_dev-ioctl.h
linux/bcache.h
linux/btrfs_tree.h
linux/can/vxcan.h
linux/cifs/cifs_mount.h
linux/coresight-stm.h
linux/cryptouser.h
linux/fsmap.h
linux/genwqe/genwqe_card.h
linux/hash_info.h
linux/kcm.h
linux/kcov.h
linux/kfd_ioctl.h
linux/lightnvm.h
linux/module.h
linux/nbd-netlink.h
linux/nilfs2_api.h
linux/nilfs2_ondisk.h
linux/nsfs.h
linux/pr.h
linux/qrtr.h
linux/rpmsg.h
linux/sched/types.h
linux/sed-opal.h
linux/smc.h
linux/smc_diag.h
linux/stm.h
linux/switchtec_ioctl.h
linux/vfio_ccw.h
linux/wil6210_uapi.h
rdma/bnxt_re-abi.h
Note that I have removed from this list the files which are generated in every
exported directories (like .install or .install.cmd).
Thanks to Julien Floret <julien.floret@6wind.com> for the tip to get all
subdirs with a pure makefile command.
For the record, note that exported files for asm directories are a mix of
files listed by:
- include/uapi/asm-generic/Kbuild.asm;
- arch/<arch>/include/uapi/asm/Kbuild;
- arch/<arch>/include/asm/Kbuild.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Acked-by: Mark Salter <msalter@redhat.com>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU updates from Joerg Roedel:
- code optimizations for the Intel VT-d driver
- ability to switch off a previously enabled Intel IOMMU
- support for 'struct iommu_device' for OMAP, Rockchip and Mediatek
IOMMUs
- header optimizations for IOMMU core code headers and a few fixes that
became necessary in other parts of the kernel because of that
- ACPI/IORT updates and fixes
- Exynos IOMMU optimizations
- updates for the IOMMU dma-api code to bring it closer to use per-cpu
iova caches
- new command-line option to set default domain type allocated by the
iommu core code
- another command line option to allow the Intel IOMMU switched off in
a tboot environment
- ARM/SMMU: TLB sync optimisations for SMMUv2, Support for using an
IDENTITY domain in conjunction with DMA ops, Support for SMR masking,
Support for 16-bit ASIDs (was previously broken)
- various other small fixes and improvements
* tag 'iommu-updates-v4.12' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (63 commits)
soc/qbman: Move dma-mapping.h include to qman_priv.h
soc/qbman: Fix implicit header dependency now causing build fails
iommu: Remove trace-events include from iommu.h
iommu: Remove pci.h include from trace/events/iommu.h
arm: dma-mapping: Don't override dma_ops in arch_setup_dma_ops()
ACPI/IORT: Fix CONFIG_IOMMU_API dependency
iommu/vt-d: Don't print the failure message when booting non-kdump kernel
iommu: Move report_iommu_fault() to iommu.c
iommu: Include device.h in iommu.h
x86, iommu/vt-d: Add an option to disable Intel IOMMU force on
iommu/arm-smmu: Return IOVA in iova_to_phys when SMMU is bypassed
iommu/arm-smmu: Correct sid to mask
iommu/amd: Fix incorrect error handling in amd_iommu_bind_pasid()
iommu: Make iommu_bus_notifier return NOTIFY_DONE rather than error code
omap3isp: Remove iommu_group related code
iommu/omap: Add iommu-group support
iommu/omap: Make use of 'struct iommu_device'
iommu/omap: Store iommu_dev pointer in arch_data
iommu/omap: Move data structures to omap-iommu.h
iommu/omap: Drop legacy-style device support
Patch series "set_memory_* functions header refactor", v3.
The set_memory_* APIs came out of a desire to have a better way to
change memory attributes. Many of these attributes were linked to cache
functionality so the prototypes were put in cacheflush.h. These days,
the APIs have grown and have a much wider use than just cache APIs. To
support this growth, split off set_memory_* and friends into a separate
header file to avoid growing cacheflush.h for APIs that have nothing to
do with caches.
Link: http://lkml.kernel.org/r/1488920133-27229-2-git-send-email-labbott@redhat.com
Signed-off-by: Laura Abbott <labbott@redhat.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
'arm/smmu', 'arm/core', 'x86/vt-d', 'x86/amd' and 'core' into next
Pull x86 mm updates from Ingo Molnar:
"The main x86 MM changes in this cycle were:
- continued native kernel PCID support preparation patches to the TLB
flushing code (Andy Lutomirski)
- various fixes related to 32-bit compat syscall returning address
over 4Gb in applications, launched from 64-bit binaries - motivated
by C/R frameworks such as Virtuozzo. (Dmitry Safonov)
- continued Intel 5-level paging enablement: in particular the
conversion of x86 GUP to the generic GUP code. (Kirill A. Shutemov)
- x86/mpx ABI corner case fixes/enhancements (Joerg Roedel)
- ... plus misc updates, fixes and cleanups"
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (62 commits)
mm, zone_device: Replace {get, put}_zone_device_page() with a single reference to fix pmem crash
x86/mm: Fix flush_tlb_page() on Xen
x86/mm: Make flush_tlb_mm_range() more predictable
x86/mm: Remove flush_tlb() and flush_tlb_current_task()
x86/vm86/32: Switch to flush_tlb_mm_range() in mark_screen_rdonly()
x86/mm/64: Fix crash in remove_pagetable()
Revert "x86/mm/gup: Switch GUP to the generic get_user_page_fast() implementation"
x86/boot/e820: Remove a redundant self assignment
x86/mm: Fix dump pagetables for 4 levels of page tables
x86/mpx, selftests: Only check bounds-vs-shadow when we keep shadow
x86/mpx: Correctly report do_mpx_bt_fault() failures to user-space
Revert "x86/mm/numa: Remove numa_nodemask_from_meminfo()"
x86/espfix: Add support for 5-level paging
x86/kasan: Extend KASAN to support 5-level paging
x86/mm: Add basic defines/helpers for CONFIG_X86_5LEVEL=y
x86/paravirt: Add 5-level support to the paravirt code
x86/mm: Define virtual memory map for 5-level paging
x86/asm: Remove __VIRTUAL_MASK_SHIFT==47 assert
x86/boot: Detect 5-level paging support
Pull x86 asm updates from Ingo Molnar:
"The main changes in this cycle were:
- unwinder fixes and enhancements
- improve ftrace interaction with the unwinder
- optimize the code footprint of WARN() and related debugging
constructs
- ... plus misc updates, cleanups and fixes"
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits)
x86/unwind: Dump all stacks in unwind_dump()
x86/unwind: Silence more entry-code related warnings
x86/ftrace: Fix ebp in ftrace_regs_caller that screws up unwinder
x86/unwind: Remove unused 'sp' parameter in unwind_dump()
x86/unwind: Prepend hex mask value with '0x' in unwind_dump()
x86/unwind: Properly zero-pad 32-bit values in unwind_dump()
x86/unwind: Ensure stack pointer is aligned
debug: Avoid setting BUGFLAG_WARNING twice
x86/unwind: Silence entry-related warnings
x86/unwind: Read stack return address in update_stack_state()
x86/unwind: Move common code into update_stack_state()
debug: Fix __bug_table[] in arch linker scripts
debug: Add _ONCE() logic to report_bug()
x86/debug: Define BUG() again for !CONFIG_BUG
x86/debug: Implement __WARN() using UD0
x86/ftrace: Use Makefile logic instead of #ifdef for compiling ftrace_*.o
x86/ftrace: Add -mfentry support to x86_32 with DYNAMIC_FTRACE set
x86/ftrace: Clean up ftrace_regs_caller
x86/ftrace: Add stack frame pointer to ftrace_caller
x86/ftrace: Move the ftrace specific code out of entry_32.S
Pull uaccess unification updates from Al Viro:
"This is the uaccess unification pile. It's _not_ the end of uaccess
work, but the next batch of that will go into the next cycle. This one
mostly takes copy_from_user() and friends out of arch/* and gets the
zero-padding behaviour in sync for all architectures.
Dealing with the nocache/writethrough mess is for the next cycle;
fortunately, that's x86-only. Same for cleanups in iov_iter.c (I am
sold on access_ok() in there, BTW; just not in this pile), same for
reducing __copy_... callsites, strn*... stuff, etc. - there will be a
pile about as large as this one in the next merge window.
This one sat in -next for weeks. -3KLoC"
* 'work.uaccess' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (96 commits)
HAVE_ARCH_HARDENED_USERCOPY is unconditional now
CONFIG_ARCH_HAS_RAW_COPY_USER is unconditional now
m32r: switch to RAW_COPY_USER
hexagon: switch to RAW_COPY_USER
microblaze: switch to RAW_COPY_USER
get rid of padding, switch to RAW_COPY_USER
ia64: get rid of copy_in_user()
ia64: sanitize __access_ok()
ia64: get rid of 'segment' argument of __do_{get,put}_user()
ia64: get rid of 'segment' argument of __{get,put}_user_check()
ia64: add extable.h
powerpc: get rid of zeroing, switch to RAW_COPY_USER
esas2r: don't open-code memdup_user()
alpha: fix stack smashing in old_adjtimex(2)
don't open-code kernel_setsockopt()
mips: switch to RAW_COPY_USER
mips: get rid of tail-zeroing in primitives
mips: make copy_from_user() zero tail explicitly
mips: clean and reorder the forest of macros...
mips: consolidate __invoke_... wrappers
all architectures converted
The IORT linker section introduced by commit 34ceea275f62
("ACPI/IORT: Introduce linker section for IORT entries probing")
was needed to make sure SMMU drivers are registered (and therefore
probed) in the kernel before devices using the SMMU have a chance
to probe in turn.
Through the introduction of deferred IOMMU configuration the linker
section based IORT probing infrastructure is not needed any longer, in
that device/SMMU probe dependencies are managed through the probe
deferral mechanism, making the IORT linker section infrastructure
unused, so that it can be removed.
Remove the unused IORT linker section probing infrastructure
from the kernel to complete the ACPI IORT IOMMU configure probe
deferral mechanism implementation.
Tested-by: Hanjun Guo <hanjun.guo@linaro.org>
Reviewed-by: Robin Murphy <robin.murphy@arm.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Cc: Sricharan R <sricharan@codeaurora.org>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
Dan reported that his static checking complains about BUGFLAG_WARNING
being set on both sides of the bitwise-or, it figures that that might've
been an unintentional mistake.
Since there are no architectures that implement __WARN_TAINT() (I
converted them all to implement __WARN_FLAGS()), and all __WARN_FLAGS()
implementations already set BUGFLAG_WARNING, we can remove the bit from
BUGFLAG_TAINT() and make Dan's checker happy.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Link: http://lkml.kernel.org/r/20170410084939.4bwhrvpmauwfzauq@hirez.programming.kicks-ass.net
When __{start,end}_ro_after_init is referenced from C code, we run into
the following build errors on blackfin:
kernel/extable.c:169: undefined reference to `__start_ro_after_init'
kernel/extable.c:169: undefined reference to `__end_ro_after_init'
The build error is due to the fact that blackfin is one of the few
arches that prepends an underscore '_' to all symbols defined in C.
Fix this by wrapping __{start,end}_ro_after_init in vmlinux.lds.h with
VMLINUX_SYMBOL(), which adds the necessary prefix for arches that have
HAVE_UNDERSCORE_SYMBOL_PREFIX.
Link: http://lkml.kernel.org/r/1491259387-15869-1-git-send-email-jeyu@redhat.com
Signed-off-by: Jessica Yu <jeyu@redhat.com>
Cc: Eddie Kovsky <ewk@edkovsky.org>
Pull timer fixes from Thomas Gleixner:
"Two small fixes for the new CLKEVT_OF infrastructure"
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
vmlinux.lds: Add __clkevt_of_table to kernel
clockevents: Fix syntax error in clkevt-of macro
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux into uaccess.parisc
A section name for .data..ro_after_init was added by both:
commit d07a980c1b8d ("s390: add proper __ro_after_init support")
and
commit d7c19b066dcf ("mm: kmemleak: scan .data.ro_after_init")
The latter adds incorrect wrapping around the existing s390 section, and
came later. I'd prefer the s390 naming, so this moves the s390-specific
name up to the asm-generic/sections.h and renames the section as used by
kmemleak (and in the future, kernel/extable.c).
Link: http://lkml.kernel.org/r/20170327192213.GA129375@beast
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> [s390 parts]
Acked-by: Jakub Kicinski <jakub.kicinski@netronome.com>
Josh suggested moving the _ONCE logic inside the trap handler, using a
bit in the bug_entry::flags field, avoiding the need for the extra
variable.
Sadly this only works for WARN_ON_ONCE(), since the others have
printk() statements prior to triggering the trap.
Still, this saves a fair amount of text and some data:
text data filename
10682460 4530992 defconfig-build/vmlinux.orig
10665111 4530096 defconfig-build/vmlinux.patched
Suggested-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
provide raw_copy_..._user() and select ARCH_HAS_RAW_COPY_USER to use those.
only h8300 actually used those; might as well define them there.
The code introduced by commit 0c8893c9095d ("clockevents: Add a
clkevt-of mechanism like clksrc-of") refer to __clkevt_of_table
what doesn't exist in the vmlinux. As a result kernel build
failed with error: "clkevt-probe.c:63: undefined reference to
`__clkevt_of_table’"
Fixes: 0c8893c9095d ("clockevents: Add a clkevt-of mechanism like clksrc-of")
Signed-off-by: Alexander Kochetkov <al.kochet@gmail.com>
... and make the users of generic uaccess.h use that.
This is a preparation patch for the transition of x86 to the generic GUP_fast()
implementation.
On x86, we would need to do additional permission checks to determine if
access is allowed.
Let's abstract it out into separate helpers.
Cc: Aneesh Kumar K . V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Dann Frazier <dann.frazier@canonical.com>
Cc: Steve Capper <steve.capper@linaro.org>
Link: http://lkml.kernel.org/r/20170316152655.37789-3-kirill.shutemov@linux.intel.com
The only arch that defines it to something meaningful is x86.
But x86 doesn't use the generic GUP_fast() implementation -- the
only place where the callback is called.
Let's drop it.
Link: http://lkml.kernel.org/r/20170316152655.37789-2-kirill.shutemov@linux.intel.com
Convert all non-architecture-specific code to 5-level paging.
It's mostly mechanical adding handling one more page table level in
places where we deal with pud_t.
Like with pgtable-nopud.h for 4-level paging, this new header is base
for converting an architectures to properly folded p4d_t level.
We are going to introduce <asm-generic/pgtable-nop4d.h> to provide
abstraction for properly (in opposite to 5level-fixup.h hack) folded
p4d level. The new header will be included from pgtable-nopud.h.
If an architecture uses <asm-generic/nop*d.h>, we cannot use
5level-fixup.h directly to quickly convert the architecture to 5-level
paging as it would conflict with pgtable-nop4d.h.
With this patch an architecture can define __ARCH_USE_5LEVEL_HACK before
inclusion <asm-genenric/nop*d.h> to use 5level-fixup.h.
We are going to switch core MM to 5-level paging abstraction.
This is preparation step which adds <asm-generic/5level-fixup.h>
As with 4level-fixup.h, the new header allows quickly make all
architectures compatible with 5-level paging in core MM.
In long run we would like to switch architectures to properly folded p4d
level by using <asm-generic/pgtable-nop4d.h>, but it requires more
changes to arch-specific code.
Often all is needed is these small helpers, instead of compiler.h or a
full kprobes.h. This is important for asm helpers, in fact even some
asm/kprobes.h make use of these helpers... instead just keep a generic
asm file with helpers useful for asm code with the least amount of
clutter as possible.
Likewise we need now to also address what to do about this file for both
when architectures have CONFIG_HAVE_KPROBES, and when they do not. Then
for when architectures have CONFIG_HAVE_KPROBES but have disabled
CONFIG_KPROBES.
Right now most asm/kprobes.h do not have guards against CONFIG_KPROBES,
this means most architecture code cannot include asm/kprobes.h safely.
Correct this and add guards for architectures missing them.
Additionally provide architectures that not have kprobes support with
the default asm-generic solution. This lets us force asm/kprobes.h on
the header include/linux/kprobes.h always, but most importantly we can
now safely include just asm/kprobes.h on architecture code without
bringing the full kitchen sink of header files.
Two architectures already provided a guard against CONFIG_KPROBES on its
kprobes.h: sh, arch. The rest of the architectures needed gaurds added.
We avoid including any not-needed headers on asm/kprobes.h unless
kprobes have been enabled.
In a subsequent atomic change we can try now to remove compiler.h from
include/linux/kprobes.h.
During this sweep I've also identified a few architectures defining a
common macro needed for both kprobes and ftrace, that of the definition
of the breakput instruction up. Some refer to this as
BREAKPOINT_INSTRUCTION. This must be kept outside of the #ifdef
CONFIG_KPROBES guard.
[mcgrof@kernel.org: fix arm64 build]
Link: http://lkml.kernel.org/r/CAB=NE6X1WMByuARS4mZ1g9+W=LuVBnMDnh_5zyN0CLADaVh=Jw@mail.gmail.com
[sfr@canb.auug.org.au: fixup for kprobes declarations moving]
Link: http://lkml.kernel.org/r/20170214165933.13ebd4f4@canb.auug.org.au
Link: http://lkml.kernel.org/r/20170203233139.32682-1-mcgrof@kernel.org
Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org>
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
