Based on work by George G. Davis <gdavis@mvista.com>.
See http://lwn.net/Articles/390419/
Change-Id: I8df700d20a154e179f8cf6cdfe4015efc5d384f2
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/62998
Reviewed-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Rebase-Id: R2607a46c8bd1e521abe44a57a5ccf7317333d6c9
The nfsservctl system call is now gone, so we should remove all
linkage for it.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
This allows the cast in lowmem_page_address (introduced as a warning
fixup to 33dd4e0ec911 "mm: make some struct page's const") to be
removed.
Propagate const'ness to page_to_section() as well since it is required
by __page_to_pfn.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: Michel Lespinasse <walken@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/cross-platform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc:
ARM: Consolidate the clkdev header files
ARM: set vga memory base at run-time
ARM: convert PCI defines to variables
ARM: pci: make pcibios_assign_all_busses use pci_has_flag
ARM: remove unnecessary mach/hardware.h includes
pci: move microblaze and powerpc pci flag functions into asm-generic
powerpc: rename ppc_pci_*_flags to pci_*_flags
Fix up conflicts in arch/microblaze/include/asm/pci-bridge.h
Only a few core funcs need to be implemented for SMP systems, so allow the
arches to override them while getting the rest for free.
At least, this is enough to allow the Blackfin SMP port to use things.
Cc: Arun Sharma <asharma@fb.com>
Since arches are expected to implement this guy, add a common version for
people the same way as atomic_clear_mask is handled.
The atomic helpers are supposed to take an atomic_t pointer, not a random
unsigned long pointer. So convert atomic_clear_mask over.
While we're here, also add some nice documentation to the func.
We already declared inc/dec helpers, so we don't need to call the
atomic_{add,sub}_return funcs directly.
This clarifies the differences between <linux/atomic.h> and
<asm-generic/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Suggested-by: Mike Frysinger <vapier.adi@gmail.com>
After changing all consumers of atomics to include <linux/atomic.h>, we
ran into some compile time errors due to this dependency chain:
linux/atomic.h
-> asm/atomic.h
-> asm-generic/atomic-long.h
where atomic-long.h could use funcs defined later in linux/atomic.h
without a prototype. This patches moves the code that includes
asm-generic/atomic*.h to linux/atomic.h.
Archs that need <asm-generic/atomic64.h> need to select
CONFIG_GENERIC_ATOMIC64 from now on (some of them used to include it
unconditionally).
Compile tested on i386 and x86_64 with allnoconfig.
This is in preparation for more generic atomic primitives based on
__atomic_add_unless.
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
The majority of architectures implement ext2 atomic bitops as
test_and_{set,clear}_bit() without spinlock.
This adds this type of generic implementation in ext2-atomic-setbit.h and
use it wherever possible.
Suggested-by: Andreas Dilger <adilger@dilger.ca>
Suggested-by: Arnd Bergmann <arnd@arndb.de>
* Merge akpm patch series: (122 commits)
drivers/connector/cn_proc.c: remove unused local
Documentation/SubmitChecklist: add RCU debug config options
reiserfs: use hweight_long()
reiserfs: use proper little-endian bitops
pnpacpi: register disabled resources
drivers/rtc/rtc-tegra.c: properly initialize spinlock
drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time()
drivers/rtc: add support for Qualcomm PMIC8xxx RTC
drivers/rtc/rtc-s3c.c: support clock gating
drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200
init: skip calibration delay if previously done
misc/eeprom: add eeprom access driver for digsy_mtc board
misc/eeprom: add driver for microwire 93xx46 EEPROMs
checkpatch.pl: update $logFunctions
checkpatch: make utf-8 test --strict
checkpatch.pl: add ability to ignore various messages
checkpatch: add a "prefer __aligned" check
checkpatch: validate signature styles and To: and Cc: lines
checkpatch: add __rcu as a sparse modifier
checkpatch: suggest using min_t or max_t
Did this as a merge because of (trivial) conflicts in
- Documentation/feature-removal-schedule.txt
- arch/xtensa/include/asm/uaccess.h
that were just easier to fix up in the merge than in the patch series.
This header isn't exported to user-space, and even if it was, the
__KERNEL__ check covers the entire file, so we'd get a useless stub in the
first place. So punt it.
When CONFIG_PCI is not enabled, CONFIG_EISA=y, and CONFIG_GENERIC_IOMAP=y,
drivers/net/3c59x.c build fails due to a recent small change to
<asm-generic/iomap.h> that surrounds pci_iomap() and pci_iounmap() with
#ifdef CONFIG_PCI/#endif.
Since that patch to iomap.h looks correct, add stubs for pci_iomap() and
pci_iounmap() with CONFIG_PCI is not enabled to fix the build errors.
drivers/net/3c59x.c:1026: error: implicit declaration of function 'pci_iomap'
drivers/net/3c59x.c:1038: error: implicit declaration of function 'pci_iounmap'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Cc: Jonas Bonn <jonas@southpole.se>
Use the CONFIG_HAS_IOPORT and CONFIG_PCI options to decide whether or
not functions for mapping these areas are provided.
Signed-off-by: Jonas Bonn <jonas@southpole.se>
Some of the implementations, in particular the ioremap variants, in
asm-generic/io.h are for systems without an MMU. In order to be able to
use the generic header file for systems with an MMU, this patch wraps
these implementations in checks for CONFIG_MMU.
Tested on OpenRISC.
Cc: liqin.chen@sunplusct.com
Cc: gxt@mprc.pku.edu.cn
With a non-constant 8-bit argument, a call to udelay() generates a warning:
drivers/gpu/drm/radeon/atom.c: In function 'atom_op_delay':
drivers/gpu/drm/radeon/atom.c:654: warning: comparison is always false due to limited range of data type
The code looks like it works OK with an 8-bit arg, and the calling code is
doing nothing wrong, so udelay() needs fixing.
Fixing it was rather tricky. Simply typecasting `n' in the comparison with
20000 didn't change anything. Hence the divide-by-20000 trick.
Using a do{}while loop didn't work because udelay() is used in ?: statements,
hence the ({...}) construct.
While I was there I replaced the brain-bending ?:?:?: mess with nice if/else
code.
Probably other architectures are generating the same warning and can use a
similar change.
[Taken from the x86 tree and moved to asm-generic by Jonas Bonn]
Cc: <linux-arch@vger.kernel.org>
Move separate microblaze and powerpc pci flag functions pci_set_flags,
pci_add_flags, and pci_has_flag into asm-generic/pci-bridge.h so other
archs can use them.
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Several architectures are using a common delay.h implementation that
appears to have originated with the x86 architecture. This common
implementation is a bit fuller than the current asm-generic version
and has some compile-time checks that should be interesting for all
architectures.
This patch takes the common delay.h version and replaces the rather
trivial asm-generic version with it. As no architecture was actually
using asm-generic/delay.h, this change is rather innocuous; it will,
however, allow us to switch at least four architectures over to using
the asm-generic version.
git://git.secretlab.ca/git/linux-2.6
* 'gpio/merge' of git://git.secretlab.ca/git/linux-2.6:
gpio: add GPIOF_ values regardless on kconfig settings
gpio: include linux/gpio.h where needed
gpio/omap4: Fix missing interrupts during device wakeup due to IOPAD.
* 'spi/merge' of git://git.secretlab.ca/git/linux-2.6:
spi/bfin_spi: fix handling of default bits per word setting
Make GPIOF_ defined values available even when GPIOLIB nor GENERIC_GPIO
is enabled by moving them to <linux/gpio.h>.
Fixes these build errors in linux-next:
sound/soc/codecs/ak4641.c:524: error: 'GPIOF_OUT_INIT_LOW' undeclared (first use in this function)
sound/soc/codecs/wm8915.c:2921: error: 'GPIOF_OUT_INIT_LOW' undeclared (first use in this function)
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
* 'gpio/next' of git://git.secretlab.ca/git/linux-2.6:
gpio/pch_gpio: Support new device ML7223
gpio: make gpio_{request,free}_array gpio array parameter const
GPIO: OMAP: move to drivers/gpio
GPIO: OMAP: move register offset defines into <plat/gpio.h>
gpio: Convert gpio_is_valid to return bool
gpio: Move the s5pc100 GPIO to drivers/gpio
gpio: Move the s5pv210 GPIO to drivers/gpio
gpio: Move the exynos4 GPIO to drivers/gpio
gpio: Move to Samsung common GPIO library to drivers/gpio
gpio/nomadik: add function to read GPIO pull down status
gpio/nomadik: show all pins in debug
gpio: move Nomadik GPIO driver to drivers/gpio
gpio: move U300 GPIO driver to drivers/gpio
langwell_gpio: add runtime pm support
gpio/pca953x: Add support for pca9574 and pca9575 devices
gpio/cs5535: Show explicit dependency between gpio_cs5535 and mfd_cs5535
* setns:
ns: Wire up the setns system call
Done as a merge to make it easier to fix up conflicts in arm due to
addition of sendmmsg system call
32bit and 64bit on x86 are tested and working. The rest I have looked
at closely and I can't find any problems.
setns is an easy system call to wire up. It just takes two ints so I
don't expect any weird architecture porting problems.
While doing this I have noticed that we have some architectures that are
very slow to get new system calls. cris seems to be the slowest where
the last system calls wired up were preadv and pwritev. avr32 is weird
in that recvmmsg was wired up but never declared in unistd.h. frv is
behind with perf_event_open being the last syscall wired up. On h8300
the last system call wired up was epoll_wait. On m32r the last system
call wired up was fallocate. mn10300 has recvmmsg as the last system
call wired up. The rest seem to at least have syncfs wired up which was
new in the 2.6.39.
v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com>
v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com>
v4: Moved wiring up of the system call to another patch
v5: ported to v2.6.39-rc6
v6: rebased onto parisc-next and net-next to avoid syscall conflicts.
v7: ported to Linus's latest post 2.6.39 tree.
> arch/blackfin/include/asm/unistd.h | 3 ++-
> arch/blackfin/mach-common/entry.S | 1 +
Oh - ia64 wiring looks good.
Acked-by: Tony Luck <tony.luck@intel.com>
gpio_{request,free}_array should not (and do not) modify the passed gpio
array, so make the parameter const.
Acked-by: Eric Miao <eric.y.miao@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
net: Kill ratelimit.h dependency in linux/net.h
net: Add linux/sysctl.h includes where needed.
net: Kill ether_table[] declaration.
inetpeer: fix race in unused_list manipulations
atm: expose ATM device index in sysfs
IPVS: bug in ip_vs_ftp, same list heaad used in all netns.
bug.h: Move ratelimit warn interfaces to ratelimit.h
bonding: cleanup module option descriptions
net:8021q:vlan.c Fix pr_info to just give the vlan fullname and version.
net: davinci_emac: fix dev_err use at probe
can: convert to %pK for kptr_restrict support
net: fix ETHTOOL_SFEATURES compatibility with old ethtool_ops.set_flags
netfilter: Fix several warnings in compat_mtw_from_user().
netfilter: ipset: fix ip_set_flush return code
netfilter: ipset: remove unused variable from type_pf_tdel()
netfilter: ipset: Use proper timeout value to jiffies conversion
Make the code a bit more readable.
Instead of casting an int to an unsigned then comparing to
MAX_NR_GPIOS, add a >= 0 test and let the compiler optimizer
do the conversion to unsigned.
The generated code should be the same.
The style that we normally use in asm-generic is to test the macro itself
for existence, so in asm-generic, do:
#ifndef find_next_zero_bit_le
extern unsigned long find_next_zero_bit_le(const void *addr,
unsigned long size, unsigned long offset);
#endif
and in the architectures, write
static inline unsigned long find_next_zero_bit_le(const void *addr,
#define find_next_zero_bit_le find_next_zero_bit_le
This adds the #ifndef for each of the find bitops in the generic header
and source files.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Greg Ungerer <gerg@uclinux.org>
This is a series of low level ptrace unification steps to make it easier
for common code (like KGDB) to poke at register state. This also avoids
having to duplicate higher level operations for most ports which don't
have special needs for accessing things.
This patch:
This implements a bunch of helper funcs for poking the registers of a
ptrace structure. Now common code should be able to portably update
specific registers (like kgdb updating the PC).
Cc: Jason Wessel <jason.wessel@windriver.com>
Cc: Sergei Shtylyov <sshtylyov@mvista.com>
Cc: Dongdong Deng <dongdong.deng@windriver.com>
As reported by Ingo Molnar, we still have configuration combinations
where use of the WARN_RATELIMIT interfaces break the build because
dependencies don't get met.
Instead of going down the long road of trying to make it so that
ratelimit.h can get included by kernel.h or asm-generic/bug.h,
just move the interface into ratelimit.h and make users have
to include that.
Reported-by: Ingo Molnar <mingo@elte.hu>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (89 commits)
bonding: documentation and code cleanup for resend_igmp
bonding: prevent deadlock on slave store with alb mode (v3)
net: hold rtnl again in dump callbacks
Add Fujitsu 1000base-SX PCI ID to tg3
bnx2x: protect sequence increment with mutex
sch_sfq: fix peek() implementation
isdn: netjet - blacklist Digium TDM400P
via-velocity: don't annotate MAC registers as packed
xen: netfront: hold RTNL when updating features.
sctp: fix memory leak of the ASCONF queue when free asoc
net: make dev_disable_lro use physical device if passed a vlan dev (v2)
net: move is_vlan_dev into public header file (v2)
bug.h: Fix build with CONFIG_PRINTK disabled.
wireless: fix fatal kernel-doc error + warning in mac80211.h
wireless: fix cfg80211.h new kernel-doc warnings
iwlagn: dbg_fixed_rate only used when CONFIG_MAC80211_DEBUGFS enabled
dst: catch uninitialized metrics
be2net: hash key for rss-config cmd not set
bridge: initialize fake_rtable metrics
net: fix __dst_destroy_metrics_generic()
Fix up trivial conflicts in drivers/staging/brcm80211/brcmfmac/wl_cfg80211.c
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (26 commits)
arch/tile: prefer "tilepro" as the name of the 32-bit architecture
compat: include aio_abi.h for aio_context_t
arch/tile: cleanups for tilegx compat mode
arch/tile: allocate PCI IRQs later in boot
arch/tile: support signal "exception-trace" hook
arch/tile: use better definitions of xchg() and cmpxchg()
include/linux/compat.h: coding-style fixes
tile: add an RTC driver for the Tilera hypervisor
arch/tile: finish enabling support for TILE-Gx 64-bit chip
compat: fixes to allow working with tile arch
arch/tile: update defconfig file to something more useful
tile: do_hardwall_trap: do not play with task->sighand
tile: replace mm->cpu_vm_mask with mm_cpumask()
tile,mn10300: add device parameter to dma_cache_sync()
audit: support the "standard" <asm-generic/unistd.h>
arch/tile: clarify flush_buffer()/finv_buffer() function names
arch/tile: kernel-related cleanups from removing static page size
arch/tile: various header improvements for building drivers
arch/tile: disable GX prefetcher during cache flush
arch/tile: tolerate disabling CONFIG_BLK_DEV_INITRD
Apps are increasingly using more than 1024 file descriptors. See
discussion in several distro bug trackers, e.g. BugLink:
http://bugs.launchpad.net/bugs/663090
https://issues.rpath.com/browse/RPL-2054
You don't want to raise the default soft limit, since that might break
apps that use select(), but it's safe to raise the default hard limit;
that way, apps that know they need lots of file descriptors can raise
their soft limit without needing root, and without user intervention.
Ubuntu is doing this with a kernel change because they have a policy of
not changing kernel defaults in userland.
While 4096 might not be enough for *all* apps, it seems to be plenty for
the apps I've seen lately that are unhappy with 1024.
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Cc: Dan Kegel <dank@kegel.com>
The copy_to_user_page() function is supposed to flush the icache on the
memory that was written, but the current asm-generic version lacks that
logic. While normally it isn't a big deal as the asm-generic version of
icache flushing is a stub, it is a deal for ports that want to use the
asm-generic version as a baseline and then overlay its own specific parts
(like icache flushing).
Some of these functions have grown beyond inline sanity, move them
out-of-line.
Requested-by: Andrew Morton <akpm@linux-foundation.org>
Requested-by: Hugh Dickins <hughd@google.com>
Instead of using a single batch (the small on-stack, or an allocated
page), try and extend the batch every time it runs out and only flush once
either the extend fails or we're done.
Requested-by: Nick Piggin <npiggin@kernel.dk>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Namhyung Kim <namhyung@gmail.com>
In case other architectures require RCU freed page-tables to implement
gup_fast() and software filled hashes and similar things, provide the
means to do so by moving the logic into generic code.
Requested-by: David Miller <davem@davemloft.net>
Rework the existing mmu_gather infrastructure.
The direct purpose of these patches was to allow preemptible mmu_gather,
but even without that I think these patches provide an improvement to the
status quo.
The first 9 patches rework the mmu_gather infrastructure. For review
purpose I've split them into generic and per-arch patches with the last of
those a generic cleanup.
The next patch provides generic RCU page-table freeing, and the followup
is a patch converting s390 to use this. I've also got 4 patches from
DaveM lined up (not included in this series) that uses this to implement
gup_fast() for sparc64.
Then there is one patch that extends the generic mmu_gather batching.
After that follow the mm preemptibility patches, these make part of the mm
a lot more preemptible. It converts i_mmap_lock and anon_vma->lock to
mutexes which together with the mmu_gather rework makes mmu_gather
preemptible as well.
Making i_mmap_lock a mutex also enables a clean-up of the truncate code.
This also allows for preemptible mmu_notifiers, something that XPMEM I
think wants.
Furthermore, it removes the new and universially detested unmap_mutex.
This patch:
Remove the first obstacle towards a fully preemptible mmu_gather.
The current scheme assumes mmu_gather is always done with preemption
disabled and uses per-cpu storage for the page batches. Change this to
try and allocate a page for batching and in case of failure, use a small
on-stack array to make some progress.
Preemptible mmu_gather is desired in general and usable once i_mmap_lock
becomes a mutex. Doing it before the mutex conversion saves us from
having to rework the code by moving the mmu_gather bits inside the
pte_lock.
Also avoid flushing the tlb batches from under the pte lock, this is
useful even without the i_mmap_lock conversion as it significantly reduces
pte lock hold times.
[akpm@linux-foundation.org: fix comment tpyo]
Acked-by: Mel Gorman <mel@csn.ul.ie>
Based upon an email by Joe Perches.
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (29 commits)
[S390] cpu hotplug: fix external interrupt subclass mask handling
[S390] oprofile: dont access lowcore
[S390] oprofile: add missing irq stats counter
[S390] Ignore sendmmsg system call note wired up warning
[S390] s390,oprofile: fix compile error for !CONFIG_SMP
[S390] s390,oprofile: fix alert counter increment
[S390] Remove unused includes in process.c
[S390] get CPC image name
[S390] sclp: event buffer dissection
[S390] chsc: process channel-path-availability information
[S390] refactor page table functions for better pgste support
[S390] merge page_test_dirty and page_clear_dirty
[S390] qdio: prevent compile warning
[S390] sclp: remove unnecessary sendmask check
[S390] convert old cpumask API into new one
[S390] pfault: cleanup code
[S390] pfault: cpu hotplug vs missing completion interrupts
[S390] smp: add __noreturn attribute to cpu_die()
[S390] percpu: implement arch specific irqsafe_cpu_ops
[S390] vdso: disable gcov profiling
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-2.6.40' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: Unify input section names
percpu: Avoid extra NOP in percpu_cmpxchg16b_double
percpu: Cast away printk format warning
percpu: Always align percpu output section to PAGE_SIZE
Fix up fairly trivial conflict in arch/x86/include/asm/percpu.h as per Tejun
Add a generic mechanism to ratelimit WARN(foo, fmt, ...) messages
using a hidden per call site static struct ratelimit_state.
Also add an __WARN_RATELIMIT variant to be able to use a specific
The page_clear_dirty primitive always sets the default storage key
which resets the access control bits and the fetch protection bit.
That will surprise a KVM guest that sets non-zero access control
bits or the fetch protection bit. Merge page_test_dirty and
page_clear_dirty back to a single function and only clear the
dirty bit from the storage key.
In addition move the function page_test_and_clear_dirty and
page_test_and_clear_young to page.h where they belong. This
requires to change the parameter from a struct page * to a page
frame number.
Commit e66eed651fd1 ("list: remove prefetching from regular list
iterators") removed the include of prefetch.h from list.h, which
uncovered several cases that had apparently relied on that rather
obscure header file dependency.
So this fixes things up a bit, using
grep -L linux/prefetch.h $(git grep -l '[^a-z_]prefetchw*(' -- '*.[ch]')
grep -L 'prefetchw*(' $(git grep -l 'linux/prefetch.h' -- '*.[ch]')
to guide us in finding files that either need <linux/prefetch.h>
inclusion, or have it despite not needing it.
There are more of them around (mostly network drivers), but this gets
many core ones.
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (107 commits)
perf stat: Add more cache-miss percentage printouts
perf stat: Add -d -d and -d -d -d options to show more CPU events
ftrace/kbuild: Add recordmcount files to force full build
ftrace: Add self-tests for multiple function trace users
ftrace: Modify ftrace_set_filter/notrace to take ops
ftrace: Allow dynamically allocated function tracers
ftrace: Implement separate user function filtering
ftrace: Free hash with call_rcu_sched()
ftrace: Have global_ops store the functions that are to be traced
ftrace: Add ops parameter to ftrace_startup/shutdown functions
ftrace: Add enabled_functions file
ftrace: Use counters to enable functions to trace
ftrace: Separate hash allocation and assignment
ftrace: Create a global_ops to hold the filter and notrace hashes
ftrace: Use hash instead for FTRACE_FL_FILTER
ftrace: Replace FTRACE_FL_NOTRACE flag with a hash of ignored functions
perf bench, x86: Add alternatives-asm.h wrapper
x86, 64-bit: Fix copy_[to/from]_user() checks for the userspace address limit
x86, mem: memset_64.S: Optimize memset by enhanced REP MOVSB/STOSB
x86, mem: memmove_64.S: Optimize memmove by enhanced REP MOVSB/STOSB
