path: root/include/asm-generic
2015-05-06nosave: consolidate __nosave_{begin,end} in <asm/sections.h>Geert Uytterhoeven
commit 7f8998c7aef3ac9c5f3f2943e083dfa6302e90d0 upstream. The different architectures used their own (and different) declarations: extern __visible const void __nosave_begin, __nosave_end; extern const void __nosave_begin, __nosave_end; extern long __nosave_begin, __nosave_end; Consolidate them using the first variant in <asm/sections.h>. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-31mm: use paravirt friendly ops for NUMA hinting ptesMel Gorman
commit 29c7787075c92ca8af353acd5301481e6f37082f upstream. David Vrabel identified a regression when using automatic NUMA balancing under Xen whereby page table entries were getting corrupted due to the use of native PTE operations. Quoting him Xen PV guest page tables require that their entries use machine addresses if the preset bit (_PAGE_PRESENT) is set, and (for successful migration) non-present PTEs must use pseudo-physical addresses. This is because on migration MFNs in present PTEs are translated to PFNs (canonicalised) so they may be translated back to the new MFN in the destination domain (uncanonicalised). pte_mknonnuma(), pmd_mknonnuma(), pte_mknuma() and pmd_mknuma() set and clear the _PAGE_PRESENT bit using pte_set_flags(), pte_clear_flags(), etc. In a Xen PV guest, these functions must translate MFNs to PFNs when clearing _PAGE_PRESENT and translate PFNs to MFNs when setting _PAGE_PRESENT. His suggested fix converted p[te|md]_[set|clear]_flags to using paravirt-friendly ops but this is overkill. He suggested an alternative of using p[te|md]_modify in the NUMA page table operations but this is does more work than necessary and would require looking up a VMA for protections. This patch modifies the NUMA page table operations to use paravirt friendly operations to set/clear the flags of interest. Unfortunately this will take a performance hit when updating the PTEs on CONFIG_PARAVIRT but I do not see a way around it that does not break Xen. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: David Vrabel <david.vrabel@citrix.com> Tested-by: David Vrabel <david.vrabel@citrix.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Anvin <hpa@zytor.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Steven Noonan <steven@uplinklabs.net> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06word-at-a-time: avoid undefined behaviour in zero_bytemask macroWill Deacon
commit ec6931b281797b69e6cf109f9cc94d5a2bf994e0 upstream. The asm-generic, big-endian version of zero_bytemask creates a mask of bytes preceding the first zero-byte by left shifting ~0ul based on the position of the first zero byte. Unfortunately, if the first (top) byte is zero, the output of prep_zero_mask has only the top bit set, resulting in undefined C behaviour as we shift left by an amount equal to the width of the type. As it happens, GCC doesn't manage to spot this through the call to fls(), but the issue remains if architectures choose to implement their shift instructions differently. An example would be arch/arm/ (AArch32), where LSL Rd, Rn, #32 results in Rd == 0x0, whilst on arch/arm64 (AArch64) LSL Xd, Xn, #64 results in Xd == Xn. Rather than check explicitly for the problematic shift, this patch adds an extra shift by 1, replacing fls with __fls. Since zero_bytemask is never called with a zero argument (has_zero() is used to check the data first), we don't need to worry about calling __fls(0), which is undefined. Cc: Victor Kamensky <victor.kamensky@linaro.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-17mm: Use ptep/pmdp_set_numa() for updating _PAGE_NUMA bitAneesh Kumar K.V
Archs like ppc64 doesn't do tlb flush in set_pte/pmd functions when using a hash table MMU for various reasons (the flush is handled as part of the PTE modification when necessary). ppc64 thus doesn't implement flush_tlb_range for hash based MMUs. Additionally ppc64 require the tlb flushing to be batched within ptl locks. The reason to do that is to ensure that the hash page table is in sync with linux page table. We track the hpte index in linux pte and if we clear them without flushing hash and drop the ptl lock, we can have another cpu update the pte and can end up with duplicate entry in the hash table, which is fatal. We also want to keep set_pte_at simpler by not requiring them to do hash flush for performance reason. We do that by assuming that set_pte_at() is never *ever* called on a PTE that is already valid. This was the case until the NUMA code went in which broke that assumption. Fix that by introducing a new pair of helpers to set _PAGE_NUMA in a way similar to ptep/pmdp_set_wrprotect(), with a generic implementation using set_pte_at() and a powerpc specific one using the appropriate mechanism needed to keep the hash table in sync. Acked-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-01-27Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc mremap fix from Ben Herrenschmidt: "This is the patch that I had sent after -rc8 and which we decided to wait before merging. It's based on a different tree than my -next branch (it needs some pre-reqs that were in -rc4 or so while my -next is based on -rc1) so I left it as a separate branch for your to pull. It's identical to the request I did 2 or 3 weeks back. This fixes crashes in mremap with THP on powerpc. The fix however requires a small change in the generic code. It moves a condition into a helper we can override from the arch which is harmless, but it *also* slightly changes the order of the set_pmd and the withdraw & deposit, which should be fine according to Kirill (who wrote that code) but I agree -rc8 is a bit late... It was acked by Kirill and Andrew told me to just merge it via powerpc" * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/thp: Fix crash on mremap
2014-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) BPF debugger and asm tool by Daniel Borkmann. 2) Speed up create/bind in AF_PACKET, also from Daniel Borkmann. 3) Correct reciprocal_divide and update users, from Hannes Frederic Sowa and Daniel Borkmann. 4) Currently we only have a "set" operation for the hw timestamp socket ioctl, add a "get" operation to match. From Ben Hutchings. 5) Add better trace events for debugging driver datapath problems, also from Ben Hutchings. 6) Implement auto corking in TCP, from Eric Dumazet. Basically, if we have a small send and a previous packet is already in the qdisc or device queue, defer until TX completion or we get more data. 7) Allow userspace to manage ipv6 temporary addresses, from Jiri Pirko. 8) Add a qdisc bypass option for AF_PACKET sockets, from Daniel Borkmann. 9) Share IP header compression code between Bluetooth and IEEE802154 layers, from Jukka Rissanen. 10) Fix ipv6 router reachability probing, from Jiri Benc. 11) Allow packets to be captured on macvtap devices, from Vlad Yasevich. 12) Support tunneling in GRO layer, from Jerry Chu. 13) Allow bonding to be configured fully using netlink, from Scott Feldman. 14) Allow AF_PACKET users to obtain the VLAN TPID, just like they can already get the TCI. From Atzm Watanabe. 15) New "Heavy Hitter" qdisc, from Terry Lam. 16) Significantly improve the IPSEC support in pktgen, from Fan Du. 17) Allow ipv4 tunnels to cache routes, just like sockets. From Tom Herbert. 18) Add Proportional Integral Enhanced packet scheduler, from Vijay Subramanian. 19) Allow openvswitch to mmap'd netlink, from Thomas Graf. 20) Key TCP metrics blobs also by source address, not just destination address. From Christoph Paasch. 21) Support 10G in generic phylib. From Andy Fleming. 22) Try to short-circuit GRO flow compares using device provided RX hash, if provided. From Tom Herbert. The wireless and netfilter folks have been busy little bees too. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2064 commits) net/cxgb4: Fix referencing freed adapter ipv6: reallocate addrconf router for ipv6 address when lo device up fib_frontend: fix possible NULL pointer dereference rtnetlink: remove IFLA_BOND_SLAVE definition rtnetlink: remove check for fill_slave_info in rtnl_have_link_slave_info qlcnic: update version to 5.3.55 qlcnic: Enhance logic to calculate msix vectors. qlcnic: Refactor interrupt coalescing code for all adapters. qlcnic: Update poll controller code path qlcnic: Interrupt code cleanup qlcnic: Enhance Tx timeout debugging. qlcnic: Use bool for rx_mac_learn. bonding: fix u64 division rtnetlink: add missing IFLA_BOND_AD_INFO_UNSPEC sfc: Use the correct maximum TX DMA ring size for SFC9100 Add Shradha Shah as the sfc driver maintainer. net/vxlan: Share RX skb de-marking and checksum checks with ovs tulip: cleanup by using ARRAY_SIZE() ip_tunnel: clear IPCB in ip_tunnel_xmit() in case dst_link_failure() is called net/cxgb4: Don't retrieve stats during recovery ...
2014-01-23Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge second patch-bomb from Andrew Morton: - various misc bits - the rest of MM - add generic fixmap.h, use it - backlight updates - dynamic_debug updates - printk() updates - checkpatch updates - binfmt_elf - ramfs - init/ - autofs4 - drivers/rtc - nilfs - hfsplus - Documentation/ - coredump - procfs - fork - exec - kexec - kdump - partitions - rapidio - rbtree - userns - memstick - w1 - decompressors * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (197 commits) lib/decompress_unlz4.c: always set an error return code on failures romfs: fix returm err while getting inode in fill_super drivers/w1/masters/w1-gpio.c: add strong pullup emulation drivers/memstick/host/rtsx_pci_ms.c: fix ms card data transfer bug userns: relax the posix_acl_valid() checks arch/sh/kernel/dwarf.c: use rbtree postorder iteration helper instead of solution using repeated rb_erase() fs-ext3-use-rbtree-postorder-iteration-helper-instead-of-opencoding-fix fs/ext3: use rbtree postorder iteration helper instead of opencoding fs/jffs2: use rbtree postorder iteration helper instead of opencoding fs/ext4: use rbtree postorder iteration helper instead of opencoding fs/ubifs: use rbtree postorder iteration helper instead of opencoding net/netfilter/ipset/ip_set_hash_netiface.c: use rbtree postorder iteration instead of opencoding rbtree/test: test rbtree_postorder_for_each_entry_safe() rbtree/test: move rb_node to the middle of the test struct rapidio: add modular rapidio core build into powerpc and mips branches partitions/efi: complete documentation of gpt kernel param purpose kdump: add /sys/kernel/vmcoreinfo ABI documentation kdump: fix exported size of vmcoreinfo note kexec: add sysctl to disable kexec_load fs/exec.c: call arch_pick_mmap_layout() only once ...
2014-01-23Merge git://git.infradead.org/users/eparis/auditLinus Torvalds
Pull audit update from Eric Paris: "Again we stayed pretty well contained inside the audit system. Venturing out was fixing a couple of function prototypes which were inconsistent (didn't hurt anything, but we used the same value as an int, uint, u32, and I think even a long in a couple of places). We also made a couple of minor changes to when a couple of LSMs called the audit system. We hoped to add aarch64 audit support this go round, but it wasn't ready. I'm disappearing on vacation on Thursday. I should have internet access, but it'll be spotty. If anything goes wrong please be sure to cc rgb@redhat.com. He'll make fixing things his top priority" * git://git.infradead.org/users/eparis/audit: (50 commits) audit: whitespace fix in kernel-parameters.txt audit: fix location of __net_initdata for audit_net_ops audit: remove pr_info for every network namespace audit: Modify a set of system calls in audit class definitions audit: Convert int limit uses to u32 audit: Use more current logging style audit: Use hex_byte_pack_upper audit: correct a type mismatch in audit_syscall_exit() audit: reorder AUDIT_TTY_SET arguments audit: rework AUDIT_TTY_SET to only grab spin_lock once audit: remove needless switch in AUDIT_SET audit: use define's for audit version audit: documentation of audit= kernel parameter audit: wait_for_auditd rework for readability audit: update MAINTAINERS audit: log task info on feature change audit: fix incorrect set of audit_sock audit: print error message when fail to create audit socket audit: fix dangling keywords in audit_log_set_loginuid() output audit: log on errors from filter user rules ...
2014-01-23add generic fixmap.hMark Salter
Many architectures provide an asm/fixmap.h which defines support for compile-time 'special' virtual mappings which need to be made before paging_init() has run. This support is also used for early ioremap on x86. Much of this support is identical across the architectures. This patch consolidates all of the common bits into asm-generic/fixmap.h which is intended to be included from arch/*/include/asm/fixmap.h. Signed-off-by: Mark Salter <msalter@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: James Hogan <james.hogan@imgtec.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Richard Weinberger <richard@nod.at> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jonas Bonn <jonas.bonn@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23asm/types.h: Remove include/asm-generic/int-l64.hGeert Uytterhoeven
Now all 64-bit architectures have been converted to int-ll64.h, we can remove int-l64.h in kernelspace. For backwards compatibility, alpha, ia64, mips64, and powerpc64 still use int-l64.h in userspace. This is the (reworked for UAPI) non-documentation part of more than two year old "asm/types.h: All architectures use int-ll64.h in kernelspace" (https://lkml.org/lkml/2011/8/13/104) Since <asm/types.h> (from include/uapi/asm-generic/types.h) is used for both kernel and user space, include/asm-generic/int-ll64.h cannot just become include/asm-generic/types.h, as Arnd suggested. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual rocket science stuff from trivial.git" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) neighbour.h: fix comment sched: Fix warning on make htmldocs caused by wait.h slab: struct kmem_cache is protected by slab_mutex doc: Fix typo in USB Gadget Documentation of/Kconfig: Spelling s/one/once/ mkregtable: Fix sscanf handling lp5523, lp8501: comment improvements thermal: rcar: comment spelling treewide: fix comments and printk msgs IXP4xx: remove '1 &&' from a condition check in ixp4xx_restart() Documentation: update /proc/uptime field description Documentation: Fix size parameter for snprintf arm: fix comment header and macro name asm-generic: uaccess: Spelling s/a ny/any/ mtd: onenand: fix comment header doc: driver-model/platform.txt: fix a typo drivers: fix typo in DEVTMPFS_MOUNT Kconfig help text doc: Fix typo (acces_process_vm -> access_process_vm) treewide: Fix typos in printk drivers/gpu/drm/qxl/Kconfig: reformat the help text ...
2014-01-17audit: Modify a set of system calls in audit class definitionsAKASHI Takahiro
Each asm-generic/audit_xx.h defines a set of system calls for respective audit permission class (read, write, change attribute or exec). This patch changes two entries: 1) fchown in audit_change_attr.h Make fchown included by its own because in asm-generic/unistd.h, for example, fchown always exists while chown is optional. This change is necessary at least for arm64. 2) truncate64 in audit_write.h Add missing truncate64/ftruncate64 as well as truncate/ftruncate Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2014-01-15powerpc/thp: Fix crash on mremapAneesh Kumar K.V
This patch fix the below crash NIP [c00000000004cee4] .__hash_page_thp+0x2a4/0x440 LR [c0000000000439ac] .hash_page+0x18c/0x5e0 ... Call Trace: [c000000736103c40] [00001ffffb000000] 0x1ffffb000000(unreliable) [437908.479693] [c000000736103d50] [c0000000000439ac] .hash_page+0x18c/0x5e0 [437908.479699] [c000000736103e30] [c00000000000924c] .do_hash_page+0x4c/0x58 On ppc64 we use the pgtable for storing the hpte slot information and store address to the pgtable at a constant offset (PTRS_PER_PMD) from pmd. On mremap, when we switch the pmd, we need to withdraw and deposit the pgtable again, so that we find the pgtable at PTRS_PER_PMD offset from new pmd. We also want to move the withdraw and deposit before the set_pmd so that, when page fault find the pmd as trans huge we can be sure that pgtable can be located at the offset. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-01-13Merge tag 'v3.13-rc8' into core/lockingIngo Molnar
Refresh the tree with the latest fixes, before applying new changes. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-12arch: Introduce smp_load_acquire(), smp_store_release()Peter Zijlstra
A number of situations currently require the heavyweight smp_mb(), even though there is no need to order prior stores against later loads. Many architectures have much cheaper ways to handle these situations, but the Linux kernel currently has no portable way to make use of them. This commit therefore supplies smp_load_acquire() and smp_store_release() to remedy this situation. The new smp_load_acquire() primitive orders the specified load against any subsequent reads or writes, while the new smp_store_release() primitive orders the specifed store against any prior reads or writes. These primitives allow array-based circular FIFOs to be implemented without an smp_mb(), and also allow a theoretical hole in rcu_assign_pointer() to be closed at no additional expense on most architectures. In addition, the RCU experience transitioning from explicit smp_read_barrier_depends() and smp_wmb() to rcu_dereference() and rcu_assign_pointer(), respectively resulted in substantial improvements in readability. It therefore seems likely that replacing other explicit barriers with smp_load_acquire() and smp_store_release() will provide similar benefits. It appears that roughly half of the explicit barriers in core kernel code might be so replaced. [Changelog by PaulMck] Reviewed-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Will Deacon <will.deacon@arm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Michael Ellerman <michael@ellerman.id.au> Cc: Michael Neuling <mikey@neuling.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Victor Kaplansky <VICTORK@il.ibm.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Oleg Nesterov <oleg@redhat.com> Link: http://lkml.kernel.org/r/20131213150640.908486364@infradead.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-12arch: Clean up asm/barrier.h implementations using asm-generic/barrier.hPeter Zijlstra
We're going to be adding a few new barrier primitives, and in order to avoid endless duplication make more agressive use of asm-generic/barrier.h. Change the asm-generic/barrier.h such that it allows partial barrier definitions and fills out the rest with defaults. There are a few architectures (m32r, m68k) that could probably do away with their barrier.h file entirely but are kept for now due to their unconventional nop() implementation. Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org> Reviewed-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Michael Ellerman <michael@ellerman.id.au> Cc: Michael Neuling <mikey@neuling.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Victor Kaplansky <VICTORK@il.ibm.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20131213150640.846368594@infradead.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-06Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/qlogic/qlcnic/qlcnic_sriov_pf.c net/ipv6/ip6_tunnel.c net/ipv6/ip6_vti.c ipv6 tunnel statistic bug fixes conflicting with consolidation into generic sw per-cpu net stats. qlogic conflict between queue counting bug fix and the addition of multiple MAC address support. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-02asm-generic: uaccess: Spelling s/a ny/any/Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-12-20mm: Fix NULL pointer dereference in madvise(MADV_WILLNEED) supportKirill A. Shutemov
Sasha Levin found a NULL pointer dereference that is due to a missing page table lock, which in turn is due to the pmd entry in question being a transparent huge-table entry. The code - introduced in commit 1998cc048901 ("mm: make madvise(MADV_WILLNEED) support swap file prefetch") - correctly checks for this situation using pmd_none_or_trans_huge_or_clear_bad(), but it turns out that that function doesn't work correctly. pmd_none_or_trans_huge_or_clear_bad() expected that pmd_bad() would trigger if the transparent hugepage bit was set, but it doesn't do that if pmd_numa() is also set. Note that the NUMA bit only gets set on real NUMA machines, so people trying to reproduce this on most normal development systems would never actually trigger this. Fix it by removing the very subtle (and subtly incorrect) expectation, and instead just checking pmd_trans_huge() explicitly. Reported-by: Sasha Levin <sasha.levin@oracle.com> Acked-by: Andrea Arcangeli <aarcange@redhat.com> [ Additionally remove the now stale test for pmd_trans_huge() inside the pmd_bad() case - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-19lib: hash: follow-up fixups for arch hashFrancesco Fusco
This patch adds the include file to pull in __read_mostly on some architectures e.g. ppc and also fixes up signatures in generic asm. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Francesco Fusco <ffusco@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-18mm: fix TLB flush race between migration, and change_protection_rangeRik van Riel
There are a few subtle races, between change_protection_range (used by mprotect and change_prot_numa) on one side, and NUMA page migration and compaction on the other side. The basic race is that there is a time window between when the PTE gets made non-present (PROT_NONE or NUMA), and the TLB is flushed. During that time, a CPU may continue writing to the page. This is fine most of the time, however compaction or the NUMA migration code may come in, and migrate the page away. When that happens, the CPU may continue writing, through the cached translation, to what is no longer the current memory location of the process. This only affects x86, which has a somewhat optimistic pte_accessible. All other architectures appear to be safe, and will either always flush, or flush whenever there is a valid mapping, even with no permissions (SPARC). The basic race looks like this: CPU A CPU B CPU C load TLB entry make entry PTE/PMD_NUMA fault on entry read/write old page start migrating page change PTE/PMD to new page read/write old page [*] flush TLB reload TLB from new entry read/write new page lose data [*] the old page may belong to a new user at this point! The obvious fix is to flush remote TLB entries, by making sure that pte_accessible aware of the fact that PROT_NONE and PROT_NUMA memory may still be accessible if there is a TLB flush pending for the mm. This should fix both NUMA migration and compaction. [mgorman@suse.de: fix build] Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Alex Thorlton <athorlton@sgi.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/intel/i40e/i40e_main.c drivers/net/macvtap.c Both minor merge hassles, simple overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-17Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Three fixes for scheduler crashes, each triggers in relatively rare, hardware environment dependent situations" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/fair: Rework sched_fair time accounting math64: Add mul_u64_u32_shr() sched: Remove PREEMPT_NEED_RESCHED from generic code sched: Initialize power_orig for overlapping groups
2013-12-17lib: introduce arch optimized hash libraryFrancesco Fusco
We introduce a new hashing library that is meant to be used in the contexts where speed is more important than uniformity of the hashed values. The hash library leverages architecture specific implementation to achieve high performance and fall backs to jhash() for the generic case. On Intel-based x86 architectures, the library can exploit the crc32l instruction, part of the Intel SSE4.2 instruction set, if the instruction is supported by the processor. This implementation is twice as fast as the jhash() implementation on an i7 processor. Additional architectures, such as Arm64 provide instructions for accelerating the computation of CRC, so they could be added as well in follow-up work. Signed-off-by: Francesco Fusco <ffusco@redhat.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Thomas Graf <tgraf@redhat.com> Cc: linux-kernel@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-12word-at-a-time: provide generic big-endian zero_bytemask implementationWill Deacon
Whilst architectures may be able to do better than this (which they can, by simply defining their own macro), this is a generic stab at a zero_bytemask implementation for the asm-generic, big-endian word-at-a-time implementation. On arm64, a clz instruction is used to implement the fls efficiently. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-11sched: Remove PREEMPT_NEED_RESCHED from generic codePeter Zijlstra
While hunting a preemption issue with Alexander, Ben noticed that the currently generic PREEMPT_NEED_RESCHED stuff is horribly broken for load-store architectures. We currently rely on the IPI to fold TIF_NEED_RESCHED into PREEMPT_NEED_RESCHED, but when this IPI lands while we already have a load for the preempt-count but before the store, the store will erase the PREEMPT_NEED_RESCHED change. The current preempt-count only works on load-store archs because interrupts are assumed to be completely balanced wrt their preempt_count fiddling; the previous preempt_count load will match the preempt_count state after the interrupt and therefore nothing gets lost. This patch removes the PREEMPT_NEED_RESCHED usage from generic code and pushes it into x86 arch code; the generic code goes back to relying on TIF_NEED_RESCHED. Boot tested on x86_64 and compile tested on ppc64. Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Reported-and-Tested-by: Alexander Graf <agraf@suse.de> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20131128132641.GP10022@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: - Made x86 ablk_helper generic for ARM - Phase out chainiv in favour of eseqiv (affects IPsec) - Fixed aes-cbc IV corruption on s390 - Added constant-time crypto_memneq which replaces memcmp - Fixed aes-ctr in omap-aes - Added OMAP3 ROM RNG support - Add PRNG support for MSM SoC's - Add and use Job Ring API in caam - Misc fixes [ NOTE! This pull request was sent within the merge window, but Herbert has some questionable email sending setup that makes him public enemy #1 as far as gmail is concerned. So most of his emails seem to be trapped by gmail as spam, resulting in me not seeing them. - Linus ] * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (49 commits) crypto: s390 - Fix aes-cbc IV corruption crypto: omap-aes - Fix CTR mode counter length crypto: omap-sham - Add missing modalias padata: make the sequence counter an atomic_t crypto: caam - Modify the interface layers to use JR API's crypto: caam - Add API's to allocate/free Job Rings crypto: caam - Add Platform driver for Job Ring hwrng: msm - Add PRNG support for MSM SoC's ARM: DT: msm: Add Qualcomm's PRNG driver binding document crypto: skcipher - Use eseqiv even on UP machines crypto: talitos - Simplify key parsing crypto: picoxcell - Simplify and harden key parsing crypto: ixp4xx - Simplify and harden key parsing crypto: authencesn - Simplify key parsing crypto: authenc - Export key parsing helper function crypto: mv_cesa: remove deprecated IRQF_DISABLED hwrng: OMAP3 ROM Random Number Generator support crypto: sha256_ssse3 - also test for BMI2 crypto: mv_cesa - Remove redundant of_match_ptr crypto: sahara - Remove redundant of_match_ptr ...
2013-11-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual earth-shaking, news-breaking, rocket science pile from trivial.git" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (23 commits) doc: usb: Fix typo in Documentation/usb/gadget_configs.txt doc: add missing files to timers/00-INDEX timekeeping: Fix some trivial typos in comments mm: Fix some trivial typos in comments irq: Fix some trivial typos in comments NUMA: fix typos in Kconfig help text mm: update 00-INDEX doc: Documentation/DMA-attributes.txt fix typo DRM: comment: `halve' -> `half' Docs: Kconfig: `devlopers' -> `developers' doc: typo on word accounting in kprobes.c in mutliple architectures treewide: fix "usefull" typo treewide: fix "distingush" typo mm/Kconfig: Grammar s/an/a/ kexec: Typo s/the/then/ Documentation/kvm: Update cpuid documentation for steal time and pv eoi treewide: Fix common typo in "identify" __page_to_pfn: Fix typo in comment Correct some typos for word frequency clk: fixed-factor: Fix a trivial typo ...
2013-11-15Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module updates from Rusty Russell: "Mainly boring here, too. rmmod --wait finally removed, though" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: modpost: fix bogus 'exported twice' warnings. init: fix in-place parameter modification regression asmlinkage, module: Make ksymtab and kcrctab symbols and __this_module __visible kernel: add support for init_array constructors modpost: Optionally ignore secondary errors seen if a single module build fails module: remove rmmod --wait option.
2013-11-13Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge first patch-bomb from Andrew Morton: "Quite a lot of other stuff is banked up awaiting further next->mainline merging, but this batch contains: - Lots of random misc patches - OCFS2 - Most of MM - backlight updates - lib/ updates - printk updates - checkpatch updates - epoll tweaking - rtc updates - hfs - hfsplus - documentation - procfs - update gcov to gcc-4.7 format - IPC" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (269 commits) ipc, msg: fix message length check for negative values ipc/util.c: remove unnecessary work pending test devpts: plug the memory leak in kill_sb ./Makefile: export initial ramdisk compression config option init/Kconfig: add option to disable kernel compression drivers: w1: make w1_slave::flags long to avoid memory corruption drivers/w1/masters/ds1wm.cuse dev_get_platdata() drivers/memstick/core/ms_block.c: fix unreachable state in h_msb_read_page() drivers/memstick/core/mspro_block.c: fix attributes array allocation drivers/pps/clients/pps-gpio.c: remove redundant of_match_ptr kernel/panic.c: reduce 1 byte usage for print tainted buffer gcov: reuse kbasename helper kernel/gcov/fs.c: use pr_warn() kernel/module.c: use pr_foo() gcov: compile specific gcov implementation based on gcc version gcov: add support for gcc 4.7 gcov format gcov: move gcov structs definitions to a gcc version specific file kernel/taskstats.c: return -ENOMEM when alloc memory fails in add_del_listener() kernel/taskstats.c: add nla_nest_cancel() for failure processing between nla_nest_start() and nla_nest_end() kernel/sysctl_binary.c: use scnprintf() instead of snprintf() ...
2013-11-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "All kinds of stuff this time around; some more notable parts: - RCU'd vfsmounts handling - new primitives for coredump handling - files_lock is gone - Bruce's delegations handling series - exportfs fixes plus misc stuff all over the place" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (101 commits) ecryptfs: ->f_op is never NULL locks: break delegations on any attribute modification locks: break delegations on link locks: break delegations on rename locks: helper functions for delegation breaking locks: break delegations on unlink namei: minor vfs_unlink cleanup locks: implement delegations locks: introduce new FL_DELEG lock flag vfs: take i_mutex on renamed file vfs: rename I_MUTEX_QUOTA now that it's not used for quotas vfs: don't use PARENT/CHILD lock classes for non-directories vfs: pull ext4's double-i_mutex-locking into common code exportfs: fix quadratic behavior in filehandle lookup exportfs: better variable name exportfs: move most of reconnect_path to helper function exportfs: eliminate unused "noprogress" counter exportfs: stop retrying once we race with rename/remove exportfs: clear DISCONNECTED on all parents sooner exportfs: more detailed comment for path_reconnect ...
2013-11-13bitops/find: clarify and extend documentationCody P Schafer
Add return value documentation and clarify the units of the @size parameter. Signed-off-by: Cody P Schafer <cody@linux.vnet.ibm.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Cody P Schafer <cody@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-12Merge tag 'gpio-v3.13-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO changes from Linus Walleij: "Here is the bulk of GPIO changes for the v3.13 development cycle. I've got ACKs for the things that affect other subsystems (or it's my own subsystem, like pinctrl). Most of that pertain to an attempt from my side to consolidate and get rid of custom GPIO implementations in the ARM tree. I will continue doing this. The main change this time is the new GPIO descriptor API, background for this can be found in Corbet's summary from this january in LWN: http://lwn.net/Articles/533632/ Summary: - Merged the GPIO descriptor API from Alexandre Courbot. This is a first step toward trying to get rid of the global GPIO numberspace for the future. - Add an API so that driver can flag that a certain GPIO line is being used by a irqchip backend for generating IRQs, so that we can enforce checks, like not allowing users to switch that line to an output at runtime, since this makes no sense. Implemented corresponding calls in a few select drivers. - ACPI GPIO cleanups, refactorings and switch to using the descriptor-based interface. - Support for the TPS80036 Palmas GPIO variant. - A new driver for the Broadcom Kona GPIO SoC IP block. - Device tree support for the PCF857x driver. - A set of ARM GPIO refactorings with the goal of getting rid of a bunch of custom GPIO implementations from the arch/arm/* tree: * Move the IOP GPIO driver to the GPIO subsystem and fix all users to use the gpiolib API for accessing GPIOs. Delete the old custom GPIO implementation. * Delete the unused custom PXA GPIO implemention. * Convert all users of the IXP4 custom GPIO implementation to use gpiolib and delete the custom implementation. * Delete the custom Gemini GPIO implementation, also completely unused. - Various cleanups and renamings" * tag 'gpio-v3.13-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (85 commits) gpio: gpio-mxs: Remove unneeded dt checks gpio: pl061: don't depend on CONFIG_ARM gpio: bcm-kona: add missing .owner to struct gpio_chip gpiolib: provide a declaration of seq_file in gpio/driver.h gpiolib: include gpio/consumer.h in of_gpio.h for desc_to_gpio() gpio: provide stubs for devres gpio functions gpiolib: devres: add missing headers gpiolib: make GPIO_DEVRES depend on GPIOLIB gpiolib: devres: fix devm_gpiod_get_index() gpiolib / ACPI: document the GPIO descriptor based interface gpiolib / ACPI: allow passing GPIOF_ACTIVE_LOW for GpioInt resources gpiolib / ACPI: add ACPI support for gpiod_get_index() gpiolib / ACPI: convert to gpiod interfaces gpiolib: add gpiod_get() and gpiod_put() functions gpiolib: port of_ functions to use gpiod gpiolib: export descriptor-based GPIO interface Fixup "MAINTAINERS: GPIO-INTEL-MID: add maintainer" gpio: bcm281xx: Don't print addresses of GPIO area in probe() gpio: tegra: use new gpio_lock_as_irq() API gpio: rcar: Include linux/of.h header ...
2013-11-12Merge tag 'pinctrl-for-v3.13-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pin control updates from Linus Walleij: "Main pin control pull request for the v3.13 cycle. The changes hitting arch/blackfin are ACKed by the Blackfin maintainer, and the device tree bindings are ACKed to the extent possible by someone from the device tree maintainers group. - Blackfin ADI pin control driver, we move yet another architecture under this subsystem umbrella. - Incremental updates to the Renesas Super-H PFC pin control driver. New subdriver for the r8a7791 SoC. - Non-linear GPIO ranges from the gpiolib side of things, this enabled simplified device tree bindings by referring entire groups of pins on some pin controller to act as back-end for a certain GPIO-chip driver. - Add the Abilis TB10x pin control driver used on the ARC architecture. Also the corresponding GPIO driver is merged through this tree, so the ARC has full support for pins and GPIOs after this. - Subdrivers for Freescale i.MX1, i.MX27 and i.MX50 pin controller instances. The i.MX1 and i.MX27 is an entirely new family (silicon) of controllers whereas i.MX50 is a variant of the previous supported controller. - Then the usual slew of fixes, cleanups and incremental updates" The ARC DT changes are apparently still pending, that hopefully gets sorted out in a timely manner. * tag 'pinctrl-for-v3.13-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (48 commits) pinctrl: imx50: add pinctrl support code for the IMX50 SoC pinctrl: at91: copy define to driver pinctrl: remove minor dead code pinctrl: imx: fix using pin->input_val wrongly pinctrl: imx1: fix return value check in imx1_pinctrl_core_probe() gpio: tb10x: fix return value check in tb10x_gpio_probe() gpio: tb10x: use module_platform_driver to simplify the code pinctrl: imx27: imx27 pincontrol driver pinctrl: imx1 core driver pinctrl: sh-pfc: r8a7791 PFC support sh-pfc: r8a7778: Add CAN pin groups gpio: add TB10x GPIO driver pinctrl: at91: correct a few typos pinctrl: mvebu: remove redundant of_match_ptr pinctrl: tb10x: use module_platform_driver to simplify the code pinctrl: tb10x: fix the error handling in tb10x_pinctrl_probe() pinctrl: add documentation for pinctrl_get_group_pins() pinctrl: rockchip: emulate both edge triggered interrupts pinctrl: rockchip: add rk3188 specifics pinctrl: rockchip: remove redundant check ...
2013-11-09constify copy_siginfo_to_user{,32}()Al Viro
2013-10-19gpiolib: export descriptor-based GPIO interfaceAlexandre Courbot
This patch exports the gpiod_* family of API functions, a safer alternative to the legacy GPIO interface. Differences between the gpiod and legacy gpio APIs are: - gpio works with integers, whereas gpiod operates on opaque handlers which cannot be forged or used before proper acquisition - gpiod get/set functions are aware of the active low state of a GPIO - gpio consumers should now include <linux/gpio/consumer.h> to access the new interface, whereas chips drivers will use <linux/gpio/driver.h> The legacy gpio API is now built as inline functions on top of gpiod. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-10-17kernel: add support for init_array constructorsFrantisek Hrbata
This adds the .init_array section as yet another section with constructors. This is needed because gcc could add __gcov_init calls to .init_array or .ctors section, depending on gcc (and binutils) version . v2: - reuse mod->ctors for .init_array section for modules, because gcc uses .ctors or .init_array, but not both at the same time v3: - fail to load if that does happen somehow. Signed-off-by: Frantisek Hrbata <fhrbata@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-10-16pinctrl/gpio: non-linear GPIO ranges accesible from gpiolibChristian Ruppert
This patch adds the infrastructure required to register non-linear gpio ranges through gpiolib and the standard GPIO device tree bindings. Signed-off-by: Christian Ruppert <christian.ruppert@abilis.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-10-16Merge tag 'v3.12-rc4' into develLinus Walleij
Linux 3.12-rc4
2013-10-16gpio: add API to be strict about GPIO IRQ usageLinus Walleij
It is currently often possible in many GPIO drivers to request a GPIO line to be used as IRQ after calling gpio_to_irq() and, as the gpiolib is not aware of this, set the same line to output and start driving it, with undesired side effects. As it is a bogus usage scenario to request a line flagged as output to used as IRQ, we introduce APIs to let gpiolib track the use of a line as IRQ, and also set this flag from the userspace ABI. The API is symmetric so that lines can also be flagged from .irq_enable() and unflagged from IRQ by .irq_disable(). The debugfs file is altered so that we see if a line is reserved for IRQ. Cc: Enric Balletbo i Serra <eballetbo@gmail.com> Cc: Grant Likely <grant.likely@linaro.org> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Alexandre Courbot <acourbot@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-10-14__page_to_pfn: Fix typo in commentZhang Yanfei
Fix typo in __page_to_pfn comment: s/encorded/encoded. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-10-09Merge tag 'v3.12-rc4' into sched/coreIngo Molnar
Merge Linux v3.12-rc4 to fix a conflict and also to refresh the tree before applying more scheduler patches. Conflicts: arch/avr32/include/asm/Kbuild Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-02mm: Fix generic hugetlb pte check return type.David Miller
The include/asm-generic/hugetlb.h stubs that just vector huge_pte_*() calls to the pte_*() implementations won't work in certain situations. x86 and sparc, for example, return "unsigned long" from the bit checks, and just go "return pte_val(pte) & PTE_BIT_FOO;" But since huge_pte_*() returns 'int', if any high bits on 64-bit are relevant, they get chopped off. The net effect is that we can loop forever trying to COW a huge page, because the huge_pte_write() check signals false all the time. Reported-by: Gurudas Pai <gurudas.pai@oracle.com> Tested-by: Gurudas Pai <gurudas.pai@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: David Rientjes <rientjes@google.com>
2013-09-30include/asm-generic/vtime.h: avoid zero-length fileAndrew Morton
patch(1) can't handle zero-length files - it appears to simply not create the file, so my powerpc build fails. Put something in here to make life easier. Cc: Hugh Dickins <hughd@google.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-28sched: Revert need_resched() to look at TIF_NEED_RESCHEDPeter Zijlstra
Yuanhan reported a serious throughput regression in his pigz benchmark. Using the ftrace patch I found that several idle paths need more TLC before we can switch the generic need_resched() over to preempt_need_resched. The preemption paths benefit most from preempt_need_resched and do indeed use it; all other need_resched() users don't really care that much so reverting need_resched() back to tif_need_resched() is the simple and safe solution. Reported-by: Yuanhan Liu <yuanhan.liu@linux.intel.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Huang Ying <ying.huang@intel.com> Cc: lkp@linux.intel.com Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20130927153003.GF15690@laptop.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-25sched, x86: Optimize the preempt_schedule() callPeter Zijlstra
Remove the bloat of the C calling convention out of the preempt_enable() sites by creating an ASM wrapper which allows us to do an asm("call ___preempt_schedule") instead. calling.h bits by Andi Kleen Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-tk7xdi1cvvxewixzke8t8le1@git.kernel.org [ Fixed build error. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-25sched: Extract the basic add/sub preempt_count modifiersPeter Zijlstra
Rewrite the preempt_count macros in order to extract the 3 basic preempt_count value modifiers: __preempt_count_add() __preempt_count_sub() and the new: __preempt_count_dec_and_test() And since we're at it anyway, replace the unconventional $op_preempt_count names with the more conventional preempt_count_$op. Since these basic operators are equivalent to the previous _notrace() variants, do away with the _notrace() versions. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-ewbpdbupy9xpsjhg960zwbv8@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-25sched: Create more preempt_count accessorsPeter Zijlstra
We need a few special preempt_count accessors: - task_preempt_count() for when we're interested in the preemption count of another (non-running) task. - init_task_preempt_count() for properly initializing the preemption count. - init_idle_preempt_count() a special case of the above for the idle threads. With these no generic code ever touches thread_info::preempt_count anymore and architectures could choose to remove it. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-jf5swrio8l78j37d06fzmo4r@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-25sched, arch: Create asm/preempt.hPeter Zijlstra
In order to prepare to per-arch implementations of preempt_count move the required bits into an asm-generic header and use this for all archs. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-h5j0c1r3e3fk015m30h8f1zx@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-24crypto: create generic version of ablk_helperArd Biesheuvel
Create a generic version of ablk_helper so it can be reused by other architectures. Acked-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
