path: root/include/asm-h8300/bitops.h
2007-10-19forbid asm/bitops.h direct inclusionJiri Slaby
forbid asm/bitops.h direct inclusion Because of compile errors that may occur after bit changes if asm/bitops.h is included directly without e.g. linux/kernel.h which includes linux/bitops.h, forbid direct inclusion of asm/bitops.h. Thanks to Adrian Bunk. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18bitops: introduce lock opsNick Piggin
Introduce test_and_set_bit_lock / clear_bit_unlock bitops with lock semantics. Convert all architectures to use the generic implementation. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-By: David Howells <dhowells@redhat.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Andi Kleen <ak@muc.de> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-26[PATCH] bitops: h8300: use generic bitopsAkinobu Mita
- remove generic_ffs() - remove find_{next,first}{,_zero}_bit() - remove sched_find_first_bit() - remove generic_hweight{32,16,8}() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove ext2_{set,clear}_bit_atomic() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() - remove generic_fls() - remove generic_fls64() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: use non atomic operations for minix_*_bit() and ext2_*_bit()Akinobu Mita
Bitmap functions for the minix filesystem and the ext2 filesystem except ext2_set_bit_atomic() and ext2_clear_bit_atomic() do not require the atomic guarantees. But these are defined by using atomic bit operations on several architectures. (cris, frv, h8300, ia64, m32r, m68k, m68knommu, mips, s390, sh, sh64, sparc, sparc64, v850, and xtensa) This patch switches to non atomic bit operation. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] include/asm-*/bitops.h: fix more "~0UL >> size" typosAlexey Dobriyan
"[PATCH] m68knommu: fix find_next_zero_bit in bitops.h" fixed a typo in m68knommu implementation of find_next_zero_bit(). grep(1) shows that cris, frv, h8300, v850 are also affected. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[FLS64]: generic versionStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
