path: root/include/asm-ia64/Kbuild
2008-03-04[IA64] move gcc_intrin.h from header-y to unifdef-yDoug Chapman
When I submitted 0df29025fd0379d5950d206314d0b10a2c8a9607 to ad an #ifdef __KERNEL__ to include/asm-ia64/gcc_intrin.h a few weeks ago I neglected to move gcc_intrin.h from header-y to unifdef-y. Thanks to David Woodhouse for pointing this out. Signed-off-by: Doug Chapman <doug.chapman@hp.com> Signed-off-by: Jarod Wilson <jwilson@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-12-07[PATCH] cleanup asm/setup.h userspace visibilityAdrian Bunk
Make the contents of the userspace asm/setup.h header consistent on all architectures: - export setup.h to userspace on all architectures - export only COMMAND_LINE_SIZE to userspace - frv: move COMMAND_LINE_SIZE from param.h - i386: remove duplicate COMMAND_LINE_SIZE from param.h - arm: - export ATAGs to userspace - change u8/u16/u32 to __u8/__u16/__u32 Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-19[HEADERS] One line per header in Kbuild files to reduce conflictsDavid Woodhouse
2006-09-16[PATCH] Fix 'make headers_check' on ia64David Woodhouse
On Tue, 2006-09-12 at 17:44 +0100, David Woodhouse wrote: > asm-ia64/ptrace.h requires asm/asm-offsets.h, which does not exist > asm-ia64/resource.h requires asm/ustack.h, which does not exist Hide parts which shouldn't be visible to userspace. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-18Add Kbuild file for IA64 'make headers_install'David Woodhouse
