path: root/include/asm-ia64/string.h
2008-08-01[IA64] Move include/asm-ia64 to arch/ia64/include/asmTony Luck
After moving the the include files there were a few clean-ups: 1) Some files used #include <asm-ia64/xyz.h>, changed to <asm/xyz.h> 2) Some comments alerted maintainers to look at various header files to make matching updates if certain code were to be changed. Updated these comments to use the new include paths. 3) Some header files mentioned their own names in initial comments. Just deleted these self references. Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
