path: root/include/asm-ia64
2008-04-22[IA64] move XP and XPC to drivers/misc/sgi-xpDean Nelson
Move XPC and XPNET from arch/ia64/sn/kernel to drivers/misc/sgi-xp. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-22[IA64] simplify notify hooks in mca.cHidetoshi Seto
There are many notify_die() and almost all take same style with ia64_mca_spin(). This patch defines macros and replace them all, to reduce lines and to improve readability. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-21Merge branch 'semaphore' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'semaphore' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: Deprecate the asm/semaphore.h files in feature-removal-schedule. Convert asm/semaphore.h users to linux/semaphore.h security: Remove unnecessary inclusions of asm/semaphore.h lib: Remove unnecessary inclusions of asm/semaphore.h kernel: Remove unnecessary inclusions of asm/semaphore.h include: Remove unnecessary inclusions of asm/semaphore.h fs: Remove unnecessary inclusions of asm/semaphore.h drivers: Remove unnecessary inclusions of asm/semaphore.h net: Remove unnecessary inclusions of asm/semaphore.h arch: Remove unnecessary inclusions of asm/semaphore.h
2008-04-19sched, cpuset: customize sched domains, coreHidetoshi Seto
[rebased for sched-devel/latest] - Add a new cpuset file, having levels: sched_relax_domain_level - Modify partition_sched_domains() and build_sched_domains() to take attributes parameter passed from cpuset. - Fill newidle_idx for node domains which currently unused but might be required if sched_relax_domain_level become higher. - We can change the default level by boot option 'relax_domain_level='. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19asm-generic: add node_to_cpumask_ptr macroMike Travis
Create a simple macro to always return a pointer to the node_to_cpumask(node) value. This relies on compiler optimization to remove the extra indirection: #define node_to_cpumask_ptr(v, node) \ cpumask_t _##v = node_to_cpumask(node), *v = &_##v For those systems with a large cpumask size, then a true pointer to the array element can be used: #define node_to_cpumask_ptr(v, node) \ cpumask_t *v = &(node_to_cpumask_map[node]) A node_to_cpumask_ptr_next() macro is provided to access another node_to_cpumask value. The other change is to always include asm-generic/topology.h moving the ifdef CONFIG_NUMA to this same file. Note: there are no references to either of these new macros in this patch, only the definition. Based on 2.6.25-rc5-mm1 # alpha Cc: Richard Henderson <rth@twiddle.net> # fujitsu Cc: David Howells <dhowells@redhat.com> # ia64 Cc: Tony Luck <tony.luck@intel.com> # powerpc Cc: Paul Mackerras <paulus@samba.org> Cc: Anton Blanchard <anton@samba.org> # sparc Cc: David S. Miller <davem@davemloft.net> Cc: William L. Irwin <wli@holomorphy.com> # x86 Cc: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-18include: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they (or some user of them) rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have to fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-04-18Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: (27 commits) [IA64] kdump: Add crash_save_vmcoreinfo for INIT [IA64] Fix NUMA configuration issue [IA64] Itanium Spec updates [IA64] Untangle sync_icache_dcache() page size determination [IA64] arch/ia64/kernel/: use time_* macros [IA64] remove redundant display of free swap space in show_mem() [IA64] make IOMMU respect the segment boundary limits [IA64] kprobes: kprobe-booster for ia64 [IA64] fix getpid and set_tid_address fast system calls for pid namespaces [IA64] Replace explicit jiffies tests with time_* macros. [IA64] use goto to jump out do/while_each_thread [IA64] Fix unlock ordering in smp_callin [IA64] pgd_offset() constfication. [IA64] kdump: crash.c coding style fix [IA64] kdump: add kdump_on_fatal_mca [IA64] Minimize per_cpu reservations. [IA64] Correct pernodesize calculation. [IA64] Kernel parameter for max number of concurrent global TLB purges [IA64] Multiple outstanding ptc.g instruction support [IA64] Implement smp_call_function_mask for ia64 ...
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (58 commits) ide: remove ide_init_default_irq() macro ide: move default IDE ports setup to ide_generic host driver ide: remove obsoleted "idex=noprobe" kernel parameter (take 2) ide: remove needless hwif->irq check from ide_hwif_configure() ide: init hwif->{io_ports,irq} explicitly in legacy VLB host drivers ide: limit legacy VLB host drivers to alpha, x86 and mips cmd640: init hwif->{io_ports,irq} explicitly cmd640: cleanup setup_device_ptrs() ide: add ide-4drives host driver (take 3) ide: remove ppc ifdef from init_ide_data() ide: remove ide_default_io_ctl() macro ide: remove CONFIG_IDE_ARCH_OBSOLETE_INIT ide: add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS (take 2) ppc/pmac: remove no longer needed IDE quirk ppc: don't include <linux/ide.h> ppc: remove ppc_ide_md ppc/pplus: remove ppc_ide_md.ide_init_hwif hook ppc/sandpoint: remove ppc_ide_md hooks ppc/lopec: remove ppc_ide_md hooks ppc/mpc8xx: remove ppc_ide_md hooks ...
2008-04-18ide: remove ide_init_default_irq() macroBartlomiej Zolnierkiewicz
* Use ide_default_irq() instead of ide_init_default_irq() in ide_generic host driver (so the correct IRQ is always set regardless of CONFIG_PCI / CONFIG_BLK_DEV_IDEPCI). * Remove no longer needed ide_init_default_irq() macro. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: remove ide_default_io_ctl() macroBartlomiej Zolnierkiewicz
It is always == '((base) + 0x206)' if CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS=y and it is not needed otherwise (arm, blackfin, parisc, ppc64, sh, sparc[64]). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS (take 2)Bartlomiej Zolnierkiewicz
* Add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS to drivers/ide/Kconfig and use it instead of defining IDE_ARCH_OBSOLETE_DEFAULTS in <arch/ide.h>. v2: * Define ide_default_irq() in ide-probe.c/ns87415.c if not already defined and drop defining ide_default_irq() for CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS=n. [ Thanks to Stephen Rothwell and David Miller for noticing the problem. ] Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: David Miller <davem@davemloft.net> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-17Pull miscellaneous into release branchTony Luck
Conflicts: arch/ia64/kernel/mca.c
2008-04-17Pull nptcg into release branchTony Luck
Conflicts: arch/ia64/mm/tlb.c
2008-04-17Pull kvm-patches into release branchTony Luck
2008-04-17Pull percpureserve into release branchTony Luck
2008-04-17Pull regset into release branchTony Luck
2008-04-17Pull virt-cpu-accounting into release branchTony Luck
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-04-11[IA64] Fix NUMA configuration issueZoltan Menyhart
There is a NUMA memory configuration issue in 2.6.24: A 2-node machine of ours has got the following memory layout: Node 0: 0 - 2 Gbytes Node 0: 4 - 8 Gbytes Node 1: 8 - 16 Gbytes Node 0: 16 - 18 Gbytes "efi_memmap_init()" merges the three last ranges into one. "register_active_ranges()" is called as follows: efi_memmap_walk(register_active_ranges, NULL); i.e. once for the 4 - 18 Gbytes range. It picks up the node number from the start address, and registers all the memory for the node #0. "register_active_ranges()" should be called as follows to make sure there is no merged address range at its entry: efi_memmap_walk(filter_memory, register_active_ranges); "filter_memory()" is similar to "filter_rsvd_memory()", but the reserved memory ranges are not filtered out. Signed-off-by: Zoltan Menyhart <Zoltan.Menyhart@bull.net> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-09[IA64] Itanium Spec updatesRuss Anderson
Updates based on the "Intel® Itanium® Architecture Software Developer's Manual Specification Update October 2007". http://download.intel.com/design/itanium/specupdt/24869911.pdf Signed-off-by: Russ Anderson <rja@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-09[IA64] kprobes: kprobe-booster for ia64Masami Hiramatsu
Add kprobe-booster support on ia64. Kprobe-booster improves the performance of kprobes by eliminating single-step, where possible. Currently, kprobe-booster is implemented on x86 and x86-64. This is an ia64 port. On ia64, kprobe-booster executes a copied bundle directly, instead of single stepping. Bundles which have B or X unit and which may cause an exception (including break) are not executed directly. And also, to prevent hitting break exceptions on the copied bundle, only the hindmost kprobe is executed directly if several kprobes share a bundle and are placed in different slots. Note: set_brl_inst() is used for preparing an instruction buffer(it does not modify any active code), so it does not need any atomic operation. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: bibo,mao <bibo.mao@intel.com> Cc: Rusty Lynch <rusty.lynch@intel.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-09[IA64] pgd_offset() constfication.KOSAKI Motohiro
when compile 2.6.25-rc8-mm1, below warning happend. because walk_page_range pass argument as "const struct mm*", but pgd_offset() receive as "struct mm*". CC mm/pagewalk.o mm/pagewalk.c: In function 'walk_page_range': mm/pagewalk.c:111: warning: passing argument 1 of 'pgd_offset' discards qualifiers from pointer target type Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-08[IA64] Minimize per_cpu reservations.holt@sgi.com
This attached patch significantly shrinks boot memory allocation on ia64. It does this by not allocating per_cpu areas for cpus that can never exist. In the case where acpi does not have any numa node description of the cpus, I defaulted to assigning the first 32 round-robin on the known nodes.. For the !CONFIG_ACPI I used for_each_possible_cpu(). Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-04[IA64] Kernel parameter for max number of concurrent global TLB purgesFenghua Yu
The patch defines kernel parameter "nptcg=". The parameter overrides max number of concurrent global TLB purges which is reported from either PAL_VM_SUMMARY or SAL PALO. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-04[IA64] Multiple outstanding ptc.g instruction supportFenghua Yu
According to SDM2.2, Itanium supports multiple outstanding ptc.g instructions. But current kernel function ia64_global_tlb_purge() uses a spinlock to serialize ptc.g instructions issued by multiple processors. This serialization might have scalability issue on a big SMP machine where many processors could purge TLB in parallel. The patch fixes this problem by issuing multiple ptc.g instructions in ia64_global_tlb_purge(). It also adds support for the "PALO" table to get a platform view of the max number of outstanding ptc.g instructions (which may be different from the processor view found from PAL_VM_SUMMARY). PALO specification can be found at: http://www.dig64.org/home/DIG64_PALO_R1_0.pdf spinaphore implementation by Matthew Wilcox. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-03[IA64] Implement smp_call_function_mask for ia64Xiantao Zhang
This interface provides more flexible functionality for smp infrastructure ... e.g. KVM frequently needs to operate on a subset of cpus. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-03[IA64] Add API for allocating Dynamic TR resource.Xiantao Zhang
Dynamic TR resource should be managed in the uniform way. Add two interfaces for kernel: ia64_itr_entry: Allocate a (pair of) TR for caller. ia64_ptr_entry: Purge a (pair of ) TR by caller. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Anthony Xu <anthony.xu@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-02kvm: provide kvm.h for all architecture: fixes headers_installChristian Borntraeger
Currently include/linux/kvm.h is not considered by make headers_install, because Kbuild cannot handle " unifdef-$(CONFIG_FOO) += foo.h. This problem was introduced by commit fb56dbb31c4738a3918db81fd24da732ce3b4ae6 Author: Avi Kivity <avi@qumranet.com> Date: Sun Dec 2 10:50:06 2007 +0200 KVM: Export include/linux/kvm.h only if $ARCH actually supports KVM Currently, make headers_check barfs due to <asm/kvm.h>, which <linux/kvm.h> includes, not existing. Rather than add a zillion <asm/kvm.h>s, export kvm. only if the arch actually supports it. Signed-off-by: Avi Kivity <avi@qumranet.com> which makes this an 2.6.25 regression. One way of solving the issue is to enhance Kbuild, but Avi and David conviced me, that changing headers_install is not the way to go. This patch changes the definition for linux/kvm.h to unifdef-y. If  unifdef-y is used for linux/kvm.h "make headers_check" will fail on all architectures without asm/kvm.h. Therefore, this patch also provides asm/kvm.h on all architectures. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Avi Kivity <avi@qumranet.com> Cc: Sam Ravnborg <sam@ravnborg.org Cc: David Woodhouse <dwmw2@infradead.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-12[IA64] use CORE_DUMP_USE_REGSETShaohua Li
After we have regset support, we can use CORE_DUMP_USE_REGSET. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-03-12[IA64] regset: 64-bit supportShaohua Li
This is the 64-bit regset implementation under IA64. Basically register read/write, which is derived from current ptrace register read/write. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-03-06[IA64] kprobes arch consolidation build fixHarvey Harrison
ia64 named their handler kprobes_fault_handler while all other arches used kprobe_fault_handler. Change the function definition and header declaration. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-03-05[IA64] remove duplicate code from arch_ptrace()Petr Tesarik
Remove all code which does exactly the same thing as ptrace_request(). Signed-off-by: Petr Tesarik <ptesarik@suse.cz> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-03-05[IA64] convert sys_ptrace to arch_ptracePetr Tesarik
Convert sys_ptrace() to arch_ptrace(). Signed-off-by: Petr Tesarik <ptesarik@suse.cz> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-03-04Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] fix ia64 kprobes compilation [IA64] move gcc_intrin.h from header-y to unifdef-y [IA64] workaround tiger ia64_sal_get_physical_id_info hang [IA64] move defconfig to arch/ia64/configs/ [IA64] Fix irq migration in multiple vector domain [IA64] signal(ia64_ia32): add a signal stack overflow check [IA64] signal(ia64): add a signal stack overflow check [IA64] CONFIG_SGI_SN2 - auto select NUMA and ACPI_NUMA
2008-03-04Kprobes: indicate kretprobe support in KconfigAnanth N Mavinakayanahalli
Add CONFIG_HAVE_KRETPROBES to the arch/<arch>/Kconfig file for relevant architectures with kprobes support. This facilitates easy handling of in-kernel modules (like samples/kprobes/kretprobe_example.c) that depend on kretprobes being present in the kernel. Thanks to Sam Ravnborg for helping make the patch more lean. Per Mathieu's suggestion, added CONFIG_KRETPROBES and fixed up dependencies. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04[IA64] fix ia64 kprobes compilationAdrian Bunk
This patch fixes the following compile error with a recent gcc: CC kernel/kprobes.o /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/kprobes.c:1066: error: __ksymtab_jprobe_return causes a section type conflict Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-03-04[IA64] move gcc_intrin.h from header-y to unifdef-yDoug Chapman
When I submitted 0df29025fd0379d5950d206314d0b10a2c8a9607 to ad an #ifdef __KERNEL__ to include/asm-ia64/gcc_intrin.h a few weeks ago I neglected to move gcc_intrin.h from header-y to unifdef-y. Thanks to David Woodhouse for pointing this out. Signed-off-by: Doug Chapman <doug.chapman@hp.com> Signed-off-by: Jarod Wilson <jwilson@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-03-04[IA64] workaround tiger ia64_sal_get_physical_id_info hangAlex Chiang
This fixes regression introduced in 113134fcbca83619be4c68d0ca66db6093777b5d Intel Tiger platforms hang when calling SAL_GET_PHYSICAL_ID_INFO instead of properly returning -1 for unimplemented, so add a version check. SGI Altix platforms have an incorrect SAL version hard-coded into their prom -- they encode 2.9, but actually implement 3.2 -- so fix it up and allow ia64_sal_get_physical_id_info to keep working. Signed-off-by: Alex Chiang <achiang@hp.com> Acked-by: Russ Anderson <rja@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-03-04[IA64] Fix irq migration in multiple vector domainKenji Kaneshige
Fix the problem that the following error message is sometimes displayed at irq migration when vector domain is enabled. "Unexpected interrupt vector %d on CPU %d is not mapped to any IRQ!" The cause of this problem is an interrupt is sent to the previous target CPU after cleaning up vector to irq mapping table. To clean up vector to irq map on the previous target CPU safty, change the irq migration in multiple vector domain as follows. The original idea is from x86 interrupt management code. - Delay vector to irq table cleanup until the interrupts are sent to new target CPUs. By this, it is ensured that target CPU is completely changed on the interrupt controller side. - Even after the interrupts are sent to new target CPUs, there can be pended interrupts remaining on the previous target CPU. So we need to delay clearning up vector to irq table until the pended interrupt is handled. For this, send IPI to the previous target CPU with lower priority vector and clean up vector to irq table in its handler. This patch affects only to irq migration code with multiple vector domain is enabled. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-02-20[IA64] VIRT_CPU_ACCOUNTING (accurate cpu time accounting)Hidetoshi Seto
This patch implements VIRT_CPU_ACCOUNTING for ia64, which enable us to use more accurate cpu time accounting. The VIRT_CPU_ACCOUNTING is an item of kernel config, which s390 and powerpc arch have. By turning this config on, these archs change the mechanism of cpu time accounting from tick-sampling based one to state-transition based one. The state-transition based accounting is done by checking time (cycle counter in processor) at every state-transition point, such as entrance/exit of kernel, interrupt, softirq etc. The difference between point to point is the actual time consumed during in the state. There is no doubt about that this value is more accurate than that of tick-sampling based accounting. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-02-11[IA64] Fix build for sim_defconfigTony Luck
Commit bdc807871d58285737d50dc6163d0feb72cb0dc2 broke the build for this config because the sim_defconfig selects CONFIG_HZ=250 but include/asm-ia64/param.h has an ifdef for the simulator to force HZ to 32. So we ended up with a kernel/timeconst.h set for HZ=250 ... which then failed the check for the right HZ value and died with: Drop the #ifdef magic from param.h and make force CONFIG_HZ=32 directly for the simulator. Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-02-08Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] Fix large MCA bootmem allocation [IA64] Simplify cpu_idle_wait [IA64] Synchronize RBS on PTRACE_ATTACH [IA64] Synchronize kernel RSE to user-space and back [IA64] Rename TIF_PERFMON_WORK back to TIF_NOTIFY_RESUME [IA64] Wire up timerfd_{create,settime,gettime} syscalls
2008-02-08[IA64] Synchronize RBS on PTRACE_ATTACHPetr Tesarik
When attaching to a stopped process, the RSE must be explicitly synced to user-space, so the debugger can read the correct values. Signed-off-by: Petr Tesarik <ptesarik@suse.cz> CC: Roland McGrath <roland@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-02-08[IA64] Synchronize kernel RSE to user-space and backPetr Tesarik
This is base kernel patch for ptrace RSE bug. It's basically a backport from the utrace RSE patch I sent out several weeks ago. please review. when a thread is stopped (ptraced), debugger might change thread's user stack (change memory directly), and we must avoid the RSE stored in kernel to override user stack (user space's RSE is newer than kernel's in the case). To workaround the issue, we copy kernel RSE to user RSE before the task is stopped, so user RSE has updated data. we then copy user RSE to kernel after the task is resummed from traced stop and kernel will use the newer RSE to return to user. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Petr Tesarik <ptesarik@suse.cz> CC: Roland McGrath <roland@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-02-08[IA64] Rename TIF_PERFMON_WORK back to TIF_NOTIFY_RESUMEPetr Tesarik
Since the RSE synchronization will need a TIF_ flag, but all work-to-be-done bits are already used, so we have to multiplex TIF_NOTIFY_RESUME again. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Petr Tesarik <ptesarik@suse.cz> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-02-08[IA64] Wire up timerfd_{create,settime,gettime} syscallsTony Luck
Add ia64 hooks for the new syscalls that were added in commit 4d672e7ac79b5ec5cdc90e450823441e20464691 Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-02-08CONFIG_HIGHPTE vs. sub-page page tables.Martin Schwidefsky
Background: I've implemented 1K/2K page tables for s390. These sub-page page tables are required to properly support the s390 virtualization instruction with KVM. The SIE instruction requires that the page tables have 256 page table entries (pte) followed by 256 page status table entries (pgste). The pgstes are only required if the process is using the SIE instruction. The pgstes are updated by the hardware and by the hypervisor for a number of reasons, one of them is dirty and reference bit tracking. To avoid wasting memory the standard pte table allocation should return 1K/2K (31/64 bit) and 2K/4K if the process is using SIE. Problem: Page size on s390 is 4K, page table size is 1K or 2K. That means the s390 version for pte_alloc_one cannot return a pointer to a struct page. Trouble is that with the CONFIG_HIGHPTE feature on x86 pte_alloc_one cannot return a pointer to a pte either, since that would require more than 32 bit for the return value of pte_alloc_one (and the pte * would not be accessible since its not kmapped). Solution: The only solution I found to this dilemma is a new typedef: a pgtable_t. For s390 pgtable_t will be a (pte *) - to be introduced with a later patch. For everybody else it will be a (struct page *). The additional problem with the initialization of the ptl lock and the NR_PAGETABLE accounting is solved with a constructor pgtable_page_ctor and a destructor pgtable_page_dtor. The page table allocation and free functions need to call these two whenever a page table page is allocated or freed. pmd_populate will get a pgtable_t instead of a struct page pointer. To get the pgtable_t back from a pmd entry that has been installed with pmd_populate a new function pmd_pgtable is added. It replaces the pmd_page call in free_pte_range and apply_to_pte_range. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aout: move STACK_TOP[_MAX] to asm/processor.hDavid Howells
Move STACK_TOP[_MAX] out of asm/a.out.h and into asm/processor.h as they're required whether or not A.OUT format is available. Signed-off-by: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Add cmpxchg_local, cmpxchg64 and cmpxchg64_local to ia64Mathieu Desnoyers
Add the primitives cmpxchg_local, cmpxchg64 and cmpxchg64_local to ia64. They use cmpxchg_acq as underlying macro, just like the already existing ia64 cmpxchg(). Changelog: ia64 cmpxchg_local coding style fix Quoting Keith Owens: As a matter of coding style, I prefer #define cmpxchg_local cmpxchg #define cmpxchg64_local cmpxchg64 Which makes it absolutely clear that they are the same code. With your patch, humans have to do a string compare of two defines to see if they are the same. Note cmpxchg is *not* a performance win vs interrupt disable / enable on IA64. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Christoph Lameter <clameter@sgi.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Keith Owens <kaos@ocs.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Sanitize the type of struct user.u_ar0H. Peter Anvin
struct user.u_ar0 is defined to contain a pointer offset on all architectures in which it is defined (all architectures which define an a.out format except SPARC.) However, it has a pointer type in the headers, which is pointless -- <asm/user.h> is not exported to userspace, and it just makes the code messy. Redefine the field as "unsigned long" (which is the same size as a pointer on all Linux architectures) and change the setting code to user offsetof() instead of hand-coded arithmetic. Cc: Linux Arch Mailing List <linux-arch@vger.kernel.org> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Håvard Skinnemoen <hskinnemoen@atmel.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
