path: root/include/asm-m32r
2008-06-06asm-m32r/uaccess.h must #include <asm/setup.h>Adrian Bunk
This patch fixes the following compile error caused by commit 4016a1390d07f15b267eecb20e76a48fd5c524ef (mm/nommu.c: return 0 from kobjsize with invalid objects): /home/bunk/linux/kernel-2.6/git/linux-2.6/mm/nommu.c: In function 'kobjsize': /home/bunk/linux/kernel-2.6/git/linux-2.6/mm/nommu.c:112: error: 'memory_end' undeclared (first use in this function) /home/bunk/linux/kernel-2.6/git/linux-2.6/mm/nommu.c:112: error: (Each undeclared identifier is reported only once /home/bunk/linux/kernel-2.6/git/linux-2.6/mm/nommu.c:112: error: for each function it appears in.) The patch also removes now no longer required memory_{start,end} declarations inside access_ok(). Reported-by: Adrian Bunk <adrian.bunk@movial.fi> Signed-off-by: Adrian Bunk <adrian.bunk@movial.fi> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Michael Hennerich <Michael.Hennerich@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-02m32r: types: use <asm-generic/int-*.h> for the m32r architectureH. Peter Anvin
This modifies <asm-m32r/types.h> to use the <asm-generic/int-*.h> generic include files. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Hirokazu Takata <takata@linux-m32r.org>
2008-04-29kernel: Move arches to use common unaligned accessHarvey Harrison
Unaligned access is ok for the following arches: cris, m68k, mn10300, powerpc, s390, x86 Arches that use the memmove implementation for native endian, and the byteshifting for the opposite endianness. h8300, m32r, xtensa Packed struct for native endian, byteshifting for other endian: alpha, blackfin, ia64, parisc, sparc, sparc64, mips, sh m86knommu is generic_be for Coldfire, otherwise unaligned access is ok. frv, arm chooses endianness based on compiler settings, uses the byteshifting versions. Remove the unaligned trap handler from frv as it is now unused. v850 is le, uses the byteshifting versions for both be and le. Remove the now unused asm-generic implementation. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: introduce pte_special pte bitNick Piggin
s390 for one, cannot implement VM_MIXEDMAP with pfn_valid, due to their memory model (which is more dynamic than most). Instead, they had proposed to implement it with an additional path through vm_normal_page(), using a bit in the pte to determine whether or not the page should be refcounted: vm_normal_page() { ... if (unlikely(vma->vm_flags & (VM_PFNMAP|VM_MIXEDMAP))) { if (vma->vm_flags & VM_MIXEDMAP) { #ifdef s390 if (!mixedmap_refcount_pte(pte)) return NULL; #else if (!pfn_valid(pfn)) return NULL; #endif goto out; } ... } This is fine, however if we are allowed to use a bit in the pte to determine refcountedness, we can use that to _completely_ replace all the vma based schemes. So instead of adding more cases to the already complex vma-based scheme, we can have a clearly seperate and simple pte-based scheme (and get slightly better code generation in the process): vm_normal_page() { #ifdef s390 if (!mixedmap_refcount_pte(pte)) return NULL; return pte_page(pte); #else ... #endif } And finally, we may rather make this concept usable by any architecture rather than making it s390 only, so implement a new type of pte state for this. Unfortunately the old vma based code must stay, because some architectures may not be able to spare pte bits. This makes vm_normal_page a little bit more ugly than we would like, but the 2 cases are clearly seperate. So introduce a pte_special pte state, and use it in mm/memory.c. It is currently a noop for all architectures, so this doesn't actually result in any compiled code changes to mm/memory.o. BTW: I haven't put vm_normal_page() into arch code as-per an earlier suggestion. The reason is that, regardless of where vm_normal_page is actually implemented, the *abstraction* is still exactly the same. Also, while it depends on whether the architecture has pte_special or not, that is the only two possible cases, and it really isn't an arch specific function -- the role of the arch code should be to provide primitive functions and accessors with which to build the core code; pte_special does that. We do not want architectures to know or care about vm_normal_page itself, and we definitely don't want them being able to invent something new there out of sight of mm/ code. If we made vm_normal_page an arch function, then we have to make vm_insert_mixed (next patch) an arch function too. So I don't think moving it to arch code fundamentally improves any abstractions, while it does practically make the code more difficult to follow, for both mm and arch developers, and easier to misuse. [akpm@linux-foundation.org: build fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Carsten Otte <cotte@de.ibm.com> Cc: Jared Hulbert <jaredeh@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (58 commits) ide: remove ide_init_default_irq() macro ide: move default IDE ports setup to ide_generic host driver ide: remove obsoleted "idex=noprobe" kernel parameter (take 2) ide: remove needless hwif->irq check from ide_hwif_configure() ide: init hwif->{io_ports,irq} explicitly in legacy VLB host drivers ide: limit legacy VLB host drivers to alpha, x86 and mips cmd640: init hwif->{io_ports,irq} explicitly cmd640: cleanup setup_device_ptrs() ide: add ide-4drives host driver (take 3) ide: remove ppc ifdef from init_ide_data() ide: remove ide_default_io_ctl() macro ide: remove CONFIG_IDE_ARCH_OBSOLETE_INIT ide: add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS (take 2) ppc/pmac: remove no longer needed IDE quirk ppc: don't include <linux/ide.h> ppc: remove ppc_ide_md ppc/pplus: remove ppc_ide_md.ide_init_hwif hook ppc/sandpoint: remove ppc_ide_md hooks ppc/lopec: remove ppc_ide_md hooks ppc/mpc8xx: remove ppc_ide_md hooks ...
2008-04-18ide: remove ide_init_default_irq() macroBartlomiej Zolnierkiewicz
* Use ide_default_irq() instead of ide_init_default_irq() in ide_generic host driver (so the correct IRQ is always set regardless of CONFIG_PCI / CONFIG_BLK_DEV_IDEPCI). * Remove no longer needed ide_init_default_irq() macro. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: remove ide_default_io_ctl() macroBartlomiej Zolnierkiewicz
It is always == '((base) + 0x206)' if CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS=y and it is not needed otherwise (arm, blackfin, parisc, ppc64, sh, sparc[64]). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS (take 2)Bartlomiej Zolnierkiewicz
* Add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS to drivers/ide/Kconfig and use it instead of defining IDE_ARCH_OBSOLETE_DEFAULTS in <arch/ide.h>. v2: * Define ide_default_irq() in ide-probe.c/ns87415.c if not already defined and drop defining ide_default_irq() for CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS=n. [ Thanks to Stephen Rothwell and David Miller for noticing the problem. ] Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: David Miller <davem@davemloft.net> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-04-02kvm: provide kvm.h for all architecture: fixes headers_installChristian Borntraeger
Currently include/linux/kvm.h is not considered by make headers_install, because Kbuild cannot handle " unifdef-$(CONFIG_FOO) += foo.h. This problem was introduced by commit fb56dbb31c4738a3918db81fd24da732ce3b4ae6 Author: Avi Kivity <avi@qumranet.com> Date: Sun Dec 2 10:50:06 2007 +0200 KVM: Export include/linux/kvm.h only if $ARCH actually supports KVM Currently, make headers_check barfs due to <asm/kvm.h>, which <linux/kvm.h> includes, not existing. Rather than add a zillion <asm/kvm.h>s, export kvm. only if the arch actually supports it. Signed-off-by: Avi Kivity <avi@qumranet.com> which makes this an 2.6.25 regression. One way of solving the issue is to enhance Kbuild, but Avi and David conviced me, that changing headers_install is not the way to go. This patch changes the definition for linux/kvm.h to unifdef-y. If  unifdef-y is used for linux/kvm.h "make headers_check" will fail on all architectures without asm/kvm.h. Therefore, this patch also provides asm/kvm.h on all architectures. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Avi Kivity <avi@qumranet.com> Cc: Sam Ravnborg <sam@ravnborg.org Cc: David Woodhouse <dwmw2@infradead.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08CONFIG_HIGHPTE vs. sub-page page tables.Martin Schwidefsky
Background: I've implemented 1K/2K page tables for s390. These sub-page page tables are required to properly support the s390 virtualization instruction with KVM. The SIE instruction requires that the page tables have 256 page table entries (pte) followed by 256 page status table entries (pgste). The pgstes are only required if the process is using the SIE instruction. The pgstes are updated by the hardware and by the hypervisor for a number of reasons, one of them is dirty and reference bit tracking. To avoid wasting memory the standard pte table allocation should return 1K/2K (31/64 bit) and 2K/4K if the process is using SIE. Problem: Page size on s390 is 4K, page table size is 1K or 2K. That means the s390 version for pte_alloc_one cannot return a pointer to a struct page. Trouble is that with the CONFIG_HIGHPTE feature on x86 pte_alloc_one cannot return a pointer to a pte either, since that would require more than 32 bit for the return value of pte_alloc_one (and the pte * would not be accessible since its not kmapped). Solution: The only solution I found to this dilemma is a new typedef: a pgtable_t. For s390 pgtable_t will be a (pte *) - to be introduced with a later patch. For everybody else it will be a (struct page *). The additional problem with the initialization of the ptl lock and the NR_PAGETABLE accounting is solved with a constructor pgtable_page_ctor and a destructor pgtable_page_dtor. The page table allocation and free functions need to call these two whenever a page table page is allocated or freed. pmd_populate will get a pgtable_t instead of a struct page pointer. To get the pgtable_t back from a pmd entry that has been installed with pmd_populate a new function pmd_pgtable is added. It replaces the pmd_page call in free_pte_range and apply_to_pte_range. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08avoid overflows in kernel/time.cH. Peter Anvin
When the conversion factor between jiffies and milli- or microseconds is not a single multiply or divide, as for the case of HZ == 300, we currently do a multiply followed by a divide. The intervening result, however, is subject to overflows, especially since the fraction is not simplified (for HZ == 300, we multiply by 300 and divide by 1000). This is exposed to the user when passing a large timeout to poll(), for example. This patch replaces the multiply-divide with a reciprocal multiplication on 32-bit platforms. When the input is an unsigned long, there is no portable way to do this on 64-bit platforms there is no portable way to do this since it requires a 128-bit intermediate result (which gcc does support on 64-bit platforms but may generate libgcc calls, e.g. on 64-bit s390), but since the output is a 32-bit integer in the cases affected, just simplify the multiply-divide (*3/10 instead of *300/1000). The reciprocal multiply used can have off-by-one errors in the upper half of the valid output range. This could be avoided at the expense of having to deal with a potential 65-bit intermediate result. Since the intent is to avoid overflow problems and most of the other time conversions are only semiexact, the off-by-one errors were considered an acceptable tradeoff. At Ralf Baechle's suggestion, this version uses a Perl script to compute the necessary constants. We already have dependencies on Perl for kernel compiles. This does, however, require the Perl module Math::BigInt, which is included in the standard Perl distribution starting with version 5.8.0. In order to support older versions of Perl, include a table of canned constants in the script itself, and structure the script so that Math::BigInt isn't required if pulling values from said table. Running the script requires that the HZ value is available from the Makefile. Thus, this patch also adds the Kconfig variable CONFIG_HZ to the architectures which didn't already have it (alpha, cris, frv, h8300, m32r, m68k, m68knommu, sparc, v850, and xtensa.) It does *not* touch the sh or sh64 architectures, since Paul Mundt has dealt with those separately in the sh tree. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Ralf Baechle <ralf@linux-mips.org>, Cc: Sam Ravnborg <sam@ravnborg.org>, Cc: Paul Mundt <lethal@linux-sh.org>, Cc: Richard Henderson <rth@twiddle.net>, Cc: Michael Starvik <starvik@axis.com>, Cc: David Howells <dhowells@redhat.com>, Cc: Yoshinori Sato <ysato@users.sourceforge.jp>, Cc: Hirokazu Takata <takata@linux-m32r.org>, Cc: Geert Uytterhoeven <geert@linux-m68k.org>, Cc: Roman Zippel <zippel@linux-m68k.org>, Cc: William L. Irwin <sparclinux@vger.kernel.org>, Cc: Chris Zankel <chris@zankel.net>, Cc: H. Peter Anvin <hpa@zytor.com>, Cc: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08asm-*/posix_types.h: scrub __GLIBC__Mike Frysinger
Some arches (like alpha and ia64) already have a clean posix_types.h header. This brings all the others in line by removing all references to __GLIBC__ (and some undocumented __USE_ALL). Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aout: move STACK_TOP[_MAX] to asm/processor.hDavid Howells
Move STACK_TOP[_MAX] out of asm/a.out.h and into asm/processor.h as they're required whether or not A.OUT format is available. Signed-off-by: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07local_t m32r use architecture specific cmpxchg_localMathieu Desnoyers
On m32r, use the new cmpxchg_local as primitive for the local_cmpxchg operation. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Fix m32r __xchgMathieu Desnoyers
the #endif /* CONFIG_SMP */ should cover the default condition, or it may cause bad parameter to be silently missed. To make it work correctly, we have to remove the ifdef CONFIG SMP surrounding __xchg_called_with_bad_pointer declaration. Thanks to Adrian Bunk for detecting this. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Hirokazu Takata <takata@linux-m32r.org> Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07New cmpxchg_local (optimized for UP case) for m32rMathieu Desnoyers
Add __xchg_local, xchg_local (define), __cmpxchg_local_u32, __cmpxchg_local, cmpxchg_local(macro). cmpxchg_local and cmpxchg64_local will use the architecture specific __cmpxchg_local_u32 for 32 bits arguments, and use the generic __cmpxchg_local_generic for 8, 16 and 64 bits arguments. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Sanitize the type of struct user.u_ar0H. Peter Anvin
struct user.u_ar0 is defined to contain a pointer offset on all architectures in which it is defined (all architectures which define an a.out format except SPARC.) However, it has a pointer type in the headers, which is pointless -- <asm/user.h> is not exported to userspace, and it just makes the code messy. Redefine the field as "unsigned long" (which is the same size as a pointer on all Linux architectures) and change the setting code to user offsetof() instead of hand-coded arithmetic. Cc: Linux Arch Mailing List <linux-arch@vger.kernel.org> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Håvard Skinnemoen <hskinnemoen@atmel.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Cleanup asm/{elf,page,user}.h: #ifdef __KERNEL__ is no longer neededKirill A. Shutemov
asm/elf.h, asm/page.h and asm/user.h don't export to userspace now, so we can drop #ifdef __KERNEL__ for them. [k.shutemov@gmail.com: remove #ifdef __KERNEL_] Signed-off-by: Kirill A. Shutemov <k.shutemov@gmail.com> Reviewed-by: David Woodhouse <dwmw2@infradead.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Kirill A. Shutemov <k.shutemov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Fix __const_udelay declaration and definition mismatchesJeff Dike
The declaration and implementation of __const_udelay use different names for the parameter on a number of architectures: include/asm-avr32/delay.h:15:extern void __const_udelay(unsigned long usecs); arch/avr32/lib/delay.c:39:inline void __const_udelay(unsigned long xloops) include/asm-sh/delay.h:15:extern void __const_udelay(unsigned long usecs); arch/sh/lib/delay.c:22:inline void __const_udelay(unsigned long xloops) include/asm-m32r/delay.h:15:extern void __const_udelay(unsigned long usecs); arch/m32r/lib/delay.c:58:void __const_udelay(unsigned long xloops) include/asm-x86/delay.h:16:extern void __const_udelay(unsigned long usecs); arch/x86/lib/delay_32.c:82:inline void __const_udelay(unsigned long xloops) arch/x86/lib/delay_64.c:46:inline void __const_udelay(unsigned long xloops) The units of the parameter isn't usecs, so that name is definitely wrong. It's also not exactly loops, so I suppose xloops is an OK name. This patch changes these names from usecs to xloops. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05timerfd: fix remaining architecturesAndrew Morton
Cc: David Howells <dhowells@redhat.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05add mm argument to pte/pmd/pud/pgd_freeBenjamin Herrenschmidt
(with Martin Schwidefsky <schwidefsky@de.ibm.com>) The pgd/pud/pmd/pte page table allocation functions get a mm_struct pointer as first argument. The free functions do not get the mm_struct argument. This is 1) asymmetrical and 2) to do mm related page table allocations the mm argument is needed on the free function as well. [kamalesh@linux.vnet.ibm.com: i386 fix] [akpm@linux-foundation.org: coding-syle fixes] Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05m32r: remove dead config symbols from M32R codeJiri Olsa
remove dead config symbols from M32R code Signed-off-by: Jiri Olsa <olsajiri@gmail.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-31[NET]: Introducing socket mark socket option.Laszlo Attila Toth
A userspace program may wish to set the mark for each packets its send without using the netfilter MARK target. Changing the mark can be used for mark based routing without netfilter or for packet filtering. It requires CAP_NET_ADMIN capability. Signed-off-by: Laszlo Attila Toth <panther@balabit.hu> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-30core: remove last users of empty FASTCALL macroHarvey Harrison
FASTCALL is always empty after the x86 removal. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-28m32r: Update sys_rt_sigsuspendHirokazu Takata
Update sys_rt_sigsuspend() of arch/m32r/signal.c. This modification is derived from generic one of kernel/signal.c. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-11-28m32r: Ignore warnings for unused syscallsHirokazu Takata
checksyscalls.sh reports warnings for missing syscalls. But, on m32r, some legacy syscalls were removed elaborately. This patch kills warnings for obsolete syscalls, which are no longer used in the m32r kernel. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-11-28m32r: Add missing syscallsHirokazu Takata
Add the following 39 syscalls for m32r: sys_add_key, sys_request_key, sys_keyctl, sys_ioprio_set, sys_ioprio_get, sys_inotify_init, sys_inotify_add_watch, sys_inotify_rm_watch, sys_migrate_pages, sys_openat, sys_mkdirat, sys_mknodat, sys_fchownat, sys_futimesat, sys_fstatat64, sys_unlinkat, sys_renameat, sys_linkat, sys_symlinkat, sys_readlinkat, sys_fchmodat, sys_faccessat, sys_pselect6, sys_ppoll, sys_unshare, sys_set_robust_list, sys_get_robust_list, sys_splice, sys_sync_file_range, sys_tee, sys_vmsplice, sys_move_pages, sys_getcpu, sys_epoll_pwait, sys_utimensat, sys_signalfd, sys_timerfd, sys_eventfd, sys_fallocate Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-10-22Add CONFIG_DEBUG_SG sg validationJens Axboe
Add a Kconfig entry which will toggle some sanity checks on the sg entry and tables. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-22Change table chaining layoutJens Axboe
Change the page member of the scatterlist structure to be an unsigned long, and encode more stuff in the lower bits: - Bits 0 and 1 zero: this is a normal sg entry. Next sg entry is located at sg + 1. - Bit 0 set: this is a chain entry, the next real entry is at ->page_link with the two low bits masked off. - Bit 1 set: this is the final entry in the sg entry. sg_next() will return NULL when passed such an entry. It's thus important that sg table users use the proper accessors to get and set the page member. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-20ide: add CONFIG_IDE_ARCH_OBSOLETE_INITBartlomiej Zolnierkiewicz
Add CONFIG_IDE_ARCH_OBSOLETE_INIT to drivers/ide/Kconfig and use it instead of defining IDE_ARCH_OBSOLETE_INIT in <arch/ide.h>. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19forbid asm/bitops.h direct inclusionJiri Slaby
forbid asm/bitops.h direct inclusion Because of compile errors that may occur after bit changes if asm/bitops.h is included directly without e.g. linux/kernel.h which includes linux/bitops.h, forbid direct inclusion of asm/bitops.h. Thanks to Adrian Bunk. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19remove asm/bitops.h includesJiri Slaby
remove asm/bitops.h includes including asm/bitops directly may cause compile errors. don't include it and include linux/bitops instead. next patch will deny including asm header directly. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19remove unused flush_tlb_pgtablesBenjamin Herrenschmidt
Nobody uses flush_tlb_pgtables anymore, this patch removes all remaining traces of it from all archs. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18bitops: introduce lock opsNick Piggin
Introduce test_and_set_bit_lock / clear_bit_unlock bitops with lock semantics. Convert all architectures to use the generic implementation. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-By: David Howells <dhowells@redhat.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Andi Kleen <ak@muc.de> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17remove include/asm-*/ipc.hAdrian Bunk
All asm/ipc.h files do only #include <asm-generic/ipc.h>. This patch therefore removes all include/asm-*/ipc.h files and moves the contents of include/asm-generic/ipc.h to include/linux/ipc.h. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17remove strict ansi check from __u64 in asm/types.hOlaf Hering
Remove the __STRICT_ANSI__ check from the __u64/__s64 declaration on 32bit targets. GCC can be made to warn about usage of long long types with ISO C90 (-ansi), but only with -pedantic. You can write this in a way that even then it doesn't cause warnings, namely by: #ifdef __GNUC__ __extension__ typedef __signed__ long long __s64; __extension__ typedef unsigned long long __u64; #endif The __extension__ keyword in front of this switches off any pedantic warnings for this expression. Signed-off-by: Olaf Hering <olh@suse.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17kill DECLARE_MUTEX_LOCKEDChristoph Hellwig
DECLARE_MUTEX_LOCKED was used for semaphores used as completions and we've got rid of them. Well, except for one in libusual that the maintainer explicitly wants to keep as semaphore. So convert that useage to an explicit sema_init and kill of DECLARE_MUTEX_LOCKED so that new code is reminded to use a completion. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: "Satyam Sharma" <satyam.sharma@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16m32r: convert to generic sys_ptraceChristoph Hellwig
Convert m32r to the generic sys_ptrace. The conversion requires an architecture hook after ptrace_attach which this patch adds. The hook will also be needed for a conersion of ia64 to the generic ptrace code. Thanks to Hirokazu Takata for fixing a bug in the first version of this code. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16include/asm-m32r/thread_info.h: kmalloc + memset conversion to kzallocMariusz Kozlowski
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-03Binfmt_flat: Add minimum support for the Blackfin relocationsBernd Schmidt
Add minimum support for the Blackfin relocations, since we don't have enough space in each reloc. The idea is to store a value with one relocation so that subsequent ones can access it. Actually, this patch is required for Blackfin. Currently if BINFMT_FLAT is enabled, git-tree kernel will fail to compile. Signed-off-by: Bernd Schmidt <bernd.schmidt@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Cc: David McCullough <davidm@snapgear.com> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Miles Bader <miles.bader@necel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-09-06m32r: Rename STI/CLI macrosHirokazu Takata
The names of STI and CLI macros were derived from i386 arch historically, but their name are incomprehensible. So, for easy to understand, rename these macros to ENABLE_INTERRUPTS and DISABLE_INTERRUPTS, respectively. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-09-03m32r: Define symbols to unify platform-dependent ICU checksHirokazu Takata
On some m32r platforms, cascaded ICUs are used. This patch is required to simplify ei_handler and consolidate platform- dependent ICU check routines. platform ICU/INT1 ICU/INT0 ICU/INT2 -------------- -------- -------- -------- m32104ut o - - m32700ut o o o opsput o o o usrv o - - (others) - - - Signed-off-by: Hitoshi Yamamoto <hitoshiy@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-07-31remove unused TIF_NOTIFY_RESUME flagStephane Eranian
Remove unused TIF_NOTIFY_RESUME flag for all processor architectures. The flag was not used excecpt on IA-64 where the patch replaces it with TIF_PERFMON_WORK. Signed-off-by: stephane eranian <eranian@hpl.hp.com> Cc: <linux-arch@vger.kernel.org> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19[PATCH] sched: sched_cacheflush is now unusedRalf Baechle
Since Ingo's recent scheduler rewrite which was merged as commit 0437e109e1841607f2988891eaa36c531c6aa6ac sched_cacheflush is unused. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-07-19arch: personality independent stack topPeter Zijlstra
New arch macro STACK_TOP_MAX it gives the larges valid stack address for the architecture in question. It differs from STACK_TOP in that it will not distinguish between personalities but will always return the largest possible address. This is used to create the initial stack on execve, which we will move down to the proper location once the binfmt code has figured out where that is. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ollie Wild <aaw@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17fbdev: detect primary display deviceAntonino A. Daplas
Add function helper, fb_is_primary_device(). Given struct fb_info, it will return a nonzero value if the device is the primary display. Currently, only the i386 is supported where the function checks for the IORESOURCE_ROM_SHADOW flag. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17fbdev: move arch-specific bits to their respective subdirectoriesAntonino A. Daplas
Move arch-specific bits of fb_mmap() to their respective subdirectories [bob.picco@hp.com: efi_range_is_wc is referenced but not declared] [bunk@stusta.de: fix include/asm-m68k/fb.h] Signed-off-by: Antonino Daplas <adaplas@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Add __GFP_MOVABLE for callers to flag allocations from high memory that may ↵Mel Gorman
be migrated It is often known at allocation time whether a page may be migrated or not. This patch adds a flag called __GFP_MOVABLE and a new mask called GFP_HIGH_MOVABLE. Allocations using the __GFP_MOVABLE can be either migrated using the page migration mechanism or reclaimed by syncing with backing storage and discarding. An API function very similar to alloc_zeroed_user_highpage() is added for __GFP_MOVABLE allocations called alloc_zeroed_user_highpage_movable(). The flags used by alloc_zeroed_user_highpage() are not changed because it would change the semantics of an existing API. After this patch is applied there are no in-kernel users of alloc_zeroed_user_highpage() so it probably should be marked deprecated if this patch is merged. Note that this patch includes a minor cleanup to the use of __GFP_ZERO in shmem.c to keep all flag modifications to inode->mapping in the shmem_dir_alloc() helper function. This clean-up suggestion is courtesy of Hugh Dickens. Additional credit goes to Christoph Lameter and Linus Torvalds for shaping the concept. Credit to Hugh Dickens for catching issues with shmem swap vector and ramfs allocations. [akpm@linux-foundation.org: build fix] [hugh@veritas.com: __GFP_ZERO cleanup] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17mm: remove ptep_test_and_clear_dirty and ptep_clear_flush_dirtyMartin Schwidefsky
Nobody is using ptep_test_and_clear_dirty and ptep_clear_flush_dirty. Remove the functions from all architectures. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
