path: root/include/asm-m68knommu
2006-02-07[PATCH] m68knommu: hardirq.h needs definition of NR_IRQSGreg Ungerer
Need to include the local asm/irq.h to get the NR_IRQS definition. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] m68k: kill mach_floppy_setup, convert to proper __setup() in driversAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] death of get_thread_info/put_thread_infoAl Viro
{get,put}_thread_info() were introduced in 2.5.4 and never had been called by anything in the tree. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] m68knommu: save reg a5 on context changeGreg Ungerer
Fix a5 register corruption when processing user space signals handlers. We need to save a5 through each contenxt change. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] m68knommu: fix find_next_zero_bit in bitops.hGreg Ungerer
We're starting a number of big applications (memory footprint app. 1MByte) on our Arcturus uC5272. Therefore memory fragmentation is a real pain for us. We've switched to uClinux-2.4.27-uc1 and found that page_alloc2 fragments the memory heavily. Digging into it we found a bug in the find_next_zero_bit function in the m68knommu/bitops.h file. if the size isn't a multiple of 32 than the upper bits of the last word to be searched should be masked. But the functions masks the lower bits of the last word because it uses a right shift instead of a left shift operator. Patch submitted by Sascha Smejkal <s.smejkal@centersystems.at> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] Generic ioctl.hBrian Gerst
Most arches copied the i386 ioctl.h. Combine them into a generic header. Signed-off-by: Brian Gerst <bgerst@didntduck.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, add default include/asm-*/mutex.h filesArjan van de Ven
add the per-arch mutex.h files for the remaining architectures. We default to asm-generic/mutex-dec.h, because that performs quite well on most arches. Arches that do not have atomic decrement/increment instructions should switch to mutex-xchg.h instead. Arches can also provide their own implementation for the mutex fastpath primitives. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-09[PATCH] mutex subsystem, add atomic_xchg() to all archesIngo Molnar
add atomic_xchg() to all the architectures. Needed by the new mutex code. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org>
2006-01-08[PATCH] consolidate asm/futex.hJeff Dike
Most of the architectures have the same asm/futex.h. This consolidates them into asm-generic, with the arches including it from their own asm/futex.h. In the case of UML, this reverts the old broken futex.h and goes back to using the same one as almost everyone else. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] m68knommu: remove enable_irq_nosync()Christoph Hellwig
m68k, m68knommu and h8300 define this, but it's not actually used anywhere. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] m68knommu: enable_irq/disable_irqChristoph Hellwig
mach_enable_irq/mach_disable_irq are never actually set, so let's remove them. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] atomic_long_t & include/asm-generic/atomic.h V2Christoph Lameter
Several counters already have the need to use 64 atomic variables on 64 bit platforms (see mm_counter_t in sched.h). We have to do ugly ifdefs to fall back to 32 bit atomic on 32 bit platforms. The VM statistics patch that I am working on will also make more extensive use of atomic64. This patch introduces a new type atomic_long_t by providing definitions in asm-generic/atomic.h that works similar to the c "long" type. Its 32 bits on 32 bit platforms and 64 bits on 64 bit platforms. Also cleans up the determination of the mm_counter_t in sched.h. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[FLS64]: generic versionStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-13[PATCH] atomic: inc_not_zeroNick Piggin
Introduce an atomic_inc_not_zero operation. Make this a special case of atomic_add_unless because lockless pagecache actually wants atomic_inc_not_negativeone due to its offset refcount. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] atomic: cmpxchgNick Piggin
Introduce an atomic_cmpxchg operation. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] m68knommu: move some platform irq support out of irq.hGreg Ungerer
Move some of the m68knommu platform specific irq core support to its own header, irqnode.h. Having it in asm-m68knommu/irq.h causes some build pain, since it is included in a number of common code places (and not all the required definitions will be included at these places). Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] m68knommu: enable cache support code for ColdFIre 5249Greg Ungerer
Enable the ColdFire 5249 cache support code - it should have been on. Also one more change of "extern inline" to "static inline". Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-01[PATCH] m68knommu: add 5208 ColdFire reset/reboot supportGreg Ungerer
Add reset/reboot code to support the ColdFire 5208 family. Patch originally from Matt Wadell (from code originally written by Mike Lavender). Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-01[PATCH] m68knommu: add 5208 ColdFire UART supportGreg Ungerer
Add support for the UARTs on the ColdFire 5208 family. Patch originally from Matt Wadell (from code originally written by Mike Lavender). Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-01[PATCH] m68knommu: add 5208 ColdFire pit interrupt supportGreg Ungerer
The PIT timer in the 5208 ColdFire has slightly different interrupt bit definitions than the PIT timer used on other ColdFire parts. Define the commonly used bit and mask numbers here, and let part specific defines take precedence if they are defined. Patch originally from Matt Wadell (from code originally written by Mike Lavender). Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-01[PATCH] m68knommu: add 5208 ColdFire pit timer supportGreg Ungerer
Add support for the PIT timer used in the 5208 ColdFire fmaily. Patch originally from Matt Wadell (from code originally modified by Mike Lavender). Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-01[PATCH] m68knommu: use board defines to distinguish boardsGreg Ungerer
Use board name defines to distinguish boards, instead of combinations of more generic defines. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-01[PATCH] m68knommu: add 5208 ColdFire cache supportGreg Ungerer
Add support for the cpu cache of the 5208 ColdFire fmaily. Patch originally from Matt Wadell (from code originally written by Mike Lavender). Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-01[PATCH] m68knommu: add 5208 ColdFire support definesGreg Ungerer
Add support for the internal register map of the 5208 ColdFire fmaily. Patch originally from Matt Wadell (from code originally written by Mike Lavender). Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-01[PATCH] m68knommu: add 5208 ColdFire support defines for its internal mapGreg Ungerer
Define the register space of the new 5208 ColdFire family (which includes to 5207). It is mostly similar to the other ColdFire parts. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-01[PATCH] m68knommu: use board name defines to differentiate board definitionsGreg Ungerer
Use board name define to differentiate boards, not combination of more generic defines. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-01[PATCH] m68knommu: remove unmaintained asm-m68knommu/ide.hGreg Ungerer
Remove unmaintained asm-m68knommu/ide.h. It is completely out of date - and there is no underlying support for it. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-01[PATCH] m68knommu: remove auto-generated asm-offsets.hGreg Ungerer
Remove auto-generated file from source base. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-01[PATCH] m68knommu: change use of extern inline to static inline in headersGreg Ungerer
"extern inline" doesn't make much sense here. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] semaphore: Remove __MUTEX_INITIALIZER()Arthur Othieno
__MUTEX_INITIALIZER() has no users, and equates to the more commonly used DECLARE_MUTEX(), thus making it pretty much redundant. Remove it for good. Signed-off-by: Arthur Othieno <a.othieno@bluewin.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] unify sys_ptrace prototypeChristoph Hellwig
Make sure we always return, as all syscalls should. Also move the common prototype to <linux/syscalls.h> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] remove some more check_region stuffJeff Garzik
Removed some more references to check_region(). I checked these changes into the 'checkreg' branch of rsync://rsync.kernel.org/pub/scm/linux/kernel/git/jgarzik/misc-2.6.git The only valid references remaining are in: drivers/scsi/advansys.c drivers/scsi/BusLogic.c drivers/cdrom/sbpcd.c sound/oss/pss.c Remove last vestiges of ide_check_region() drivers/char/specialix: trim trailing whitespace drivers/char/specialix: eliminate use of check_region() Remove outdated and unused references to check_region() [sound oss] remove check_region() usage from cs4232, wavfront [netdrvr eepro] trim trailing whitespace [netdrvr eepro] remove check_region() usage Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-21[PATCH] Remove unused var from asm/futex.hPaolo 'Blaisorblade' Giarrusso
As recently done by Russell King for ARM, commit 4732efbeb997189d9f9b04708dc26bf8613ed721 introduces a generic asm/futex.h copied along most arches, which includes a "-ENOSYS support" to be changed if needed. However, it includes an unused var (taken from the "real" version) which GCC warns about. Remove it from all arches having that file version (i.e. same GIT id). $ git-diff-tree -r HEAD and $ git-ls-tree -r HEAD include/|grep 9feff4ce1424bc390608326240be369eb13aa648 may be more interesting than looking at the patch itself, to make sure I've just copied the arm header to all other archs having the original dummy version of this file. Cc: Jakub Jelinek <jakub@redhat.com> Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] feature removal of io_remap_page_range()Randy Dunlap
As written in Documentation/feature-removal-schedule.txt, remove the io_remap_page_range() kernel API. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-12[PATCH] m68knommu: optimized local_irq_disable, and platform reboot codeGreg Ungerer
Switch to a space optimized version of local_irq_disable() for ColdFire platforms. Also add reboot support for the Freescale M5272 platform. Patch originally submitted by Philippe De Muyter <phdm@macqel.be>. Add reboot support for the Freescale M523x ColdFire platform. Patch originally submitted by Jate Sujjavanich. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-12[PATCH] m68knommu: implement scatter/gather support macrosGreg Ungerer
Implement the scattergather support macros for m68knommu targets. Patch originally submitted by Leon Woestenberg <leonw@mailcan.com>. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-12[PATCH] m68knommu: fix cache actions for ColdFire 5249, 527x and 528x processorsGreg Ungerer
Add better support for flushing the cache's on some ColdFire processors. The 5249 cache code is now enabled (it was stubbed out), it really is needed. Add support for the 527x and 528x families - we only use the simple instruction cache on them. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-11[PATCH] m68knommu: allow for SDRAM and GPIO differences on 5270/1 and 5274/5 ↵Greg Ungerer
processors Allow for differences in the SDRAM controller setup and GPIO pin setup of the 5270/1 and 5274/5 parts. With separate config options for each now this no longer needs to be board specific. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-11[PATCH] m68knommu: add SPI register definitions for 528x processorsGreg Ungerer
Add QSPI register definitions of ColdFIre 528x processor SPI controller. Patch originally submitted by Derek Cheung <derek.cheung@sympatico.ca> Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-11[PATCH] m68knommu: dma support for 523x processorsGreg Ungerer
Support the DMA unit of the ColdFire 523x processor family. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-11[PATCH] m68knommu: change addr arg to const in bitops.h/find_next_zero_bit()Greg Ungerer
Change addr arg to find_next_zero_bit to be a const. Cleans up compiler warning. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-11[PATCH] m68knommu: correct prototype args in checksum.hGreg Ungerer
Bring arg types for csum_partial_copy and csum_paritial_copy_from_user prototypes into line with their actual implementation. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-11[PATCH] m68knommu: cache support for 523x/528x processorsGreg Ungerer
Add support for the cache of the ColdFIre 523x family of processors. Enable the 528x cache by default now, all final shipping silicon has the cache bug fixed. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-08[PATCH] m68knommu: include ColdFire 523x processor register definitionsGreg Ungerer
Include the ColdFire 523x register definitions when compiling for that target processor. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-08[PATCH] m68knommu: include support for the ColdFire 523x processor UARTsGreg Ungerer
Add support definitions for the integrated UARTs on the 523x ColdFire processor family. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-08[PATCH] m68knommu: defines to support the ColdFire 523x processorGreg Ungerer
Add processor level and clock support defines for the ColdFire 523x processor. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-08[PATCH] m68knommu: ColdFire 523x processor register definitionsGreg Ungerer
ColdFire 523x processor hardware register definitions. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] remove verify_area(): remove verify_area() from various uaccess.h ↵Jesper Juhl
headers Remove the deprecated (and unused) verify_area() from various uaccess.h headers. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] remove asm-*/hdreg.hChristoph Hellwig
unused and useless.. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] auxiliary vector cleanupsH. J. Lu
The size of auxiliary vector is fixed at 42 in linux/sched.h. But it isn't very obvious when looking at linux/elf.h. This patch adds AT_VECTOR_SIZE so that we can change it if necessary when a new vector is added. Because of include file ordering problems, doing this necessitated the extraction of the AT_* symbols into a standalone header file. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
