path: root/include/asm-mips/bitops.h
2007-10-19forbid asm/bitops.h direct inclusionJiri Slaby
forbid asm/bitops.h direct inclusion Because of compile errors that may occur after bit changes if asm/bitops.h is included directly without e.g. linux/kernel.h which includes linux/bitops.h, forbid direct inclusion of asm/bitops.h. Thanks to Adrian Bunk. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18mips: lock bitopsNick Piggin
mips can avoid one mb when acquiring a lock with test_and_set_bit_lock. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18mips: fix bitopsNick Piggin
Documentation/atomic_ops.txt defines these primitives must contain a memory barrier both before and after their memory operation. This is consistent with the atomic ops implementation on mips. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18bitops: introduce lock opsNick Piggin
Introduce test_and_set_bit_lock / clear_bit_unlock bitops with lock semantics. Convert all architectures to use the generic implementation. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-By: David Howells <dhowells@redhat.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Andi Kleen <ak@muc.de> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-11[MIPS] Fix "no space between function name and open parenthesis" warnings.Ralf Baechle
2007-07-20[MIPS] Make support for weakly ordered LL/SC a config option.Ralf Baechle
None of weakly ordered processor supported in tree need this but it seems like this could change ... Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-06-26[MIPS] Remove a duplicated local variable in test_and_clear_bit()Atsushi Nemoto
Fix a sparse warning caused by 2c921d07f8c641e691b0dfd80a5cfe14c60ec489 include2/asm/bitops.h:313:23: warning: symbol 'res' shadows an earlier one include2/asm/bitops.h:309:16: originally declared here Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-06-11[MIPS] Fix smp barriers in test_and_{change,clear,set}_bitRalf Baechle
2007-03-17[MIPS] Lockdep: Fix recursion bug.Ralf Baechle
trace_hardirqs_off -> atomic_inc -> local_irq_restore -> trace_hardirqs_off Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-07[MIPS] R2 bitops compile fix for gcc < 4.0.Ralf Baechle
2007-02-18[MIPS] Use MIPS R2 instructions for bitops.Ralf Baechle
Add R2 optimized variants of clear_bit, set_bit and test_and_clear_bit. With gcc 4.1.1 this saves 1592 bytes on a defconfig (minus IPv6) kernel. Turns out that R2 bitop instructions are no gain for the other bitop functions. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-13[MIPS] Improve branch prediction in ll/sc atomic operations.Ralf Baechle
Now that finally all supported versions of binutils have functioning support for .subsection use .subsection to tweak the branch prediction I did not modify the R10000 errata variants because it seems unclear if this will invalidate the workaround which actually relies on the cheesy prediction of branch likely to cause a misspredict if the sc was successful. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-12-04[MIPS] Cleanup memory barriers for weakly ordered systems.Ralf Baechle
Also the R4000 / R4600 LL/SC instructions imply a sync so no explicit sync needed. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] Remove unused definition of cpu_to_lelongp()Ralf Baechle
2006-11-30[MIPS] Remove userspace proofing from <asm/bitops.h>.Ralf Baechle
2006-07-13[MIPS] TRACE_IRQFLAGS_SUPPORT support.Ralf Baechle
2006-04-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6David Woodhouse
2006-04-27[MIPS] Fix bitops for MIPS32/MIPS64 CPUs.Atsushi Nemoto
With recent rewrite for generic bitops, fls() for 32bit kernel with MIPS64_CPU is broken. Also, ffs(), fls() should be defined the same way as the libc and compiler built-in routines (returns int instead of unsigned long). Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-26[PATCH] bitops: mips: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - unless defined(CONFIG_CPU_MIPS32) or defined(CONFIG_CPU_MIPS64) - remove __ffs() - remove ffs() - remove ffz() - remove fls() - remove fls64() - remove find_{next,first}{,_zero}_bit() - remove sched_find_first_bit() - remove generic_hweight64() - remove generic_hweight{32,16,8}() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove ext2_{set,clear}_bit_atomic() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: use non atomic operations for minix_*_bit() and ext2_*_bit()Akinobu Mita
Bitmap functions for the minix filesystem and the ext2 filesystem except ext2_set_bit_atomic() and ext2_clear_bit_atomic() do not require the atomic guarantees. But these are defined by using atomic bit operations on several architectures. (cris, frv, h8300, ia64, m32r, m68k, m68knommu, mips, s390, sh, sh64, sparc, sparc64, v850, and xtensa) This patch switches to non atomic bit operation. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[MIPS] Cleanup fls implementation.Ralf Baechle
fls was the only called of flz, so fold flz into fls, same for the __ilog2 call. Delete the now unused flz function. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-01-03[FLS64]: generic versionStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-29Fixup a few lose ends in explicit support for MIPS R1/R2.Ralf Baechle
2005-10-29Use clz / dclz on MIPS32 / MIPS64 processors.Ralf Baechle
2005-10-29Always use ".set mips3" rather than select between "mips2" or "mips3"Maciej W. Rozycki
for assembling ll/sc sequences to avoid problems with 64-bit configurations. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Enable a suitable ISA for the assembler around ll/sc so that codeMaciej W. Rozycki
builds even for processors that don't support the instructions. Plus minor formatting fixes. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-09-05[PATCH] mips: nuke trailing whitespaceRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: clean up 32/64-bit configurationRalf Baechle
Start cleaning 32-bit vs. 64-bit configuration. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
