path: root/include/asm-mips/bootinfo.h
2008-07-20[MIPS] Routerboard 532: Support for base systemRalf Baechle
Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Florian Fainelli <florian.fainelli@telecomint.eu> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-15[MIPS] Remove mips_machtype for LASAT machinesThomas Bogendoerfer
This is the LASAT part of the mips_machtype removal. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-15[MIPS] Remove mips_machtype from EMMA2RH machinesThomas Bogendoerfer
This is the EMMA2RH part of the mips_machtype removal. [Ralf: Fixed to the #error statements] Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-15[MIPS] Remove mips_machtype from ARC based machinesThomas Bogendoerfer
This is the ARC part of the mips_machtype removal. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-15[MIPS] remove machtype for group ToshibaYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] RM: Collected changesThomas Bogendoerfer
- EISA support for non PCI RMs (RM200 and RM400-xxx). The major part is the splitting of the EISA and onboard ISA of the RM200, which makes the EISA bus on the RM200 look like on other RMs. - 64bit kernel support - system type detection is now common for big and little endian - moved sniprom code to arch/mips/fw - added call_o32 function to arch/mips/fw/lib, which uses a private stack for calling prom functions - fix problem with ISA interrupts, which makes using PIT clockevent possible Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] remove unused mips_machtypeYoichi Yuasa
Removed unused mips_machtype. These are only set but not used. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] ARC: Get rid of mips_machgroupRalf Baechle
This has not been any serious user of this ill conceived thing since the original invention in like '95. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Add support for BCM47XX CPUs.Aurelien Jarno
Note that the BCM4710 does not support the wait instruction, this is not a mistake in the code. It originally comes from the OpenWrt patches. Cc: Michael Buesch <mb@bu3sch.de> Cc: Felix Fietkau <nbd@openwrt.org> Cc: Florian Schirmer <jolt@tuxbox.org> Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Add back support for LASAT platformsBrian Murphy
Signed-off-by: Brian Murphy <brian@murphy.dk> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] DDB5477: Remove supportYoichi Yuasa
2007-07-31[MIPS] Remove unused GROUP_TOSHIBA_NAMESYoichi Yuasa
2007-07-10[MIPS] WRPPMC: Fix build.Ralf Baechle
Using another systems defines is a safe way to get your code broken by accident when that system is removed. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-10[MIPS] remove LASAT Networks platforms supportYoichi Yuasa
2007-07-10[MIPS] PMC MSP71xx mips commonMarc St-Jean
Patch to add mips common support for the PMC-Sierra MSP71xx devices. Signed-off-by: Marc St-Jean <Marc_St-Jean@pmc-sierra.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-10[MIPS] New files for lemote fulong mini-PC supportSongmao Tian
Signed-off-by: Fuxin Zhang <zhangfx@lemote.com> Signed-off-by: Songmao Tian <tiansm@lemote.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-10[MIPS] Remove Momenco Ocelot C supportFranck Bui-Huu
Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> delete mode 100644 arch/mips/configs/ocelot_c_defconfig delete mode 100644 arch/mips/momentum/ocelot_c/Makefile delete mode 100644 arch/mips/momentum/ocelot_c/cpci-irq.c delete mode 100644 arch/mips/momentum/ocelot_c/dbg_io.c delete mode 100644 arch/mips/momentum/ocelot_c/irq.c delete mode 100644 arch/mips/momentum/ocelot_c/ocelot_c_fpga.h delete mode 100644 arch/mips/momentum/ocelot_c/platform.c delete mode 100644 arch/mips/momentum/ocelot_c/prom.c delete mode 100644 arch/mips/momentum/ocelot_c/reset.c delete mode 100644 arch/mips/momentum/ocelot_c/setup.c delete mode 100644 arch/mips/momentum/ocelot_c/uart-irq.c delete mode 100644 arch/mips/pci/fixup-ocelot-c.c delete mode 100644 arch/mips/pci/pci-ocelot-c.c
2007-07-10[MIPS] EV64120: Remove supportYoichi Yuasa
2007-05-11[MIPS] Remove Momenco Jaguar ATX supportFranck Bui-Huu
It has some hackish code and it odd DMA results in the need to support old features in kernel code. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-05-11[MIPS] Remove Momenco Ocelot G supportFranck Bui-Huu
2007-05-09Fix misspellings collected by members of KJ list.Robert P. J. Day
Fix the misspellings of "propogate", "writting" and (oh, the shame :-) "kenrel" in the source tree. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-06[MIPS] prom_free_prom_memory cleanupAtsushi Nemoto
Current prom_free_prom_memory() implementations are almost same as free_init_pages(), or no-op. Make free_init_pages() extern (again) and make prom_free_prom_memory() use it. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-12-09[PATCH] add STB810 support (Philips PNX8550-based)Vitaly Wool
Signed-off-by: Vitaly Wool <vitalywool@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-03[MIPS] Remove IT8172-based platforms, ITE 8172G and Globespan IVR support.Yoichi Yuasa
As per feature-removal-schedule.txt. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-09-27[MIPS] Remove EV96100 as previously announced.Ralf Baechle
2006-06-19[MIPS] Support for the RM9000-based Basler eXcite smart camera platform.Ralf Baechle
Signed-off-by: Thomas Koeller <thomas.koeller@baslerweb.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Support for the R5500-based NEC EMMA2RH Mark-eins boarddmitry pervushin
Signed-off-by: dmitry pervushin <dpervushin@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Cleanup memory managment initialization.Ralf Baechle
Historically plat_mem_setup did the entire platform initialization. This was rather impractical because it meant plat_mem_setup had to get away without any kind of memory allocator. To keep old code from breaking plat_setup was just renamed to plat_setup and a second platform initialization hook for anything else was introduced. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Support for Toshiba's RBHMA4500 eval board for the TX4938.Ralf Baechle
2005-10-29Philips PNX8550 support: MIPS32-like core with 2 Trimedias on it.Pete Popov
2005-10-29IP30 Identification.Thiemo Seufer
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Thiemo Seufer <ths@networkno.de>
2005-10-29Base Au1200 2.6 support.Pete Popov
