path: root/include/asm-mips/mach-au1x00/au1000.h
2006-02-07[MIPS] Au1200: Make KGDB compileSergei Shtylylov
AMD Au1200 SOC just doesn't have UART3, so KGDB won't even compile for it as is, here's the fix to make KGDB use UART1. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-01-10MIPS: Au1550: Fix OHCI memory map sizeSergei Shtylyov
USB OpenHCI host controller on Au1550 only decodes memory addresses from 0x14020000 to 0x1407FFFF according to the databook, which gives 0x60000 (on the prior Au1x00 chips the map size was 1MB). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Acked-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Removed __ilog2 since it's no longer needed and conflicts with thePete Popov
generic one. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29* use 'unsigned long' as address supplied to au_write[bwl]()Pete Popov
* remove two already unused and commented structures * added an ULL suffix to several address constants that use bits 35-32 Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Au1100 FB driver uplift for 2.6.Pete Popov
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Antonino Daplas <adaplas@pol.net>
2005-10-29Moved irq_tab_alchemy to the board specific irqmap.c files.Pete Popov
Cleaned up a to of warnings in dbdma.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Base Au1200 2.6 support.Pete Popov
2005-09-05[PATCH] mips: nuke trailing whitespaceRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
