Remove the Au1550 resource table and instead extract MMIO/IRQ/DMA
resources from platform resource information like any well-behaved
platform driver.
Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net>
Signed-off-by: Jan Nikitenko <jan.nikitenko@gmail.com>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Fix several errors and warnings given by checkpatch.pl:
- space after opening and before closing parentheses;
- opening brace following 'struct' not on the same line;
- leading spaces instead of tabs;
- use of C99 // comments;
- macros with complex values not enclosed in parentheses;
- missing space between the type and asterisk in a variable declaration;
- space between asterisk and function name;
- including <asm/io.h> instead of <linux/io.h> and <asm/irq.h> instead of
<linux/irq.h>;
- use of '__inline__' instead of 'inline';
- space between function name and opening parenthesis;
- line over 80 characters.
In addition to these changes, also do the following:
- remove needless parentheses;
- insert spaces between operator and its operands;
- replace spaces after the macro name with tabs in the #define directives and
after the type in the structure field declarations;
- remove excess tabs after the macro name in the #define directives and in the
'extern' variable declarations;
- remove excess spaces between # and define for the SSI_*_MASK macros to align
with other such macros;
- put '||' operator on the same line with its first operand;
- properly indent multi-line function prototypes;
- make the multi-line comment style consistent with the kernel style elsewhere
by adding empty first line and/or adding space/asterisk on their left side;
- make two-line comments that only have one line of text one-line;
- convert the large multi-line comment in au1xxx_ide.h into several one-liners,
replace spaces with tabs there;
- fix typos/errors, capitalize acronyms, etc. in the comments;
- insert missing and remove excess new lines;
- update MontaVista copyright;
- remove Pete Popov's and Steve Longerbeam's old email addresses...
Here is a driver for the Alchemy au1550 PSC (Programmable Serial
Controller) in SPI master mode.
It supports dma transfers using the Alchemy descriptor based dma controller
for 4-8 bits per word SPI transfers. For 9-24 bits per word transfers, pio
irq based mode is used to avoid setup of dma channels from scratch on each
number of bits per word change.
Tested with au1550; this may also work on other MIPS Alchemy cpus, like
au1200/au1210/au1250. Used extensively with SD card connected via SPI;
this handles 8.1MHz SPI clock transfers using dma without any problem (the
highest SPI clock freq possible with au1550 running on 324MHz).
The driver supports sharing of SPI bus by multiple devices. All features
of Alchemy SPI mode are supported (all SPI modes, msb/lsb first, bits per
word in 4-24 range).
As the SPI clock of the controller depends on main input clock that shall
be configured externally, platform data structure for au1550 SPI controller
driver contains mainclk_hz attribute to define the input clock rate. From
this value, dividers of the controller for SPI clock are set up for
required frequency.
Whitespace and section fixups. Remove partial workaround for platform
setup bug in dma_mask setup; it couldn't work with multiple controllers.
