path: root/include/asm-mips/mach-db1x00
2008-04-17Pb1200/DBAu1200: fix bad IDE resource sizeSergei Shtylyov
The header files for the Pb1200/DBAu1200 boards have wrong definition for the IDE interface's decoded range length -- it should be 512 bytes according to what the IDE driver does. In addition, the IDE platform device claims 1 byte too many for its memory resource -- fix the platform code and the IDE driver in accordance. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-24Alchemy: compile fixManuel Lauss
Commit 8b798c4d16b762d15f4055597ff8d87f73b35552 broke alchemy build, fix it. Pointed out by Adrian Bunk. Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-10-17[MIPS] Alchemy: Renumber interrupts so irq_cpu can work.Ralf Baechle
2006-06-23[PATCH] Au1550/1200: add missing PSC #define's, make OSS driver use the ↵Sergei Shtylyov
proper ones Add missing PSC #define's required for the drivers using PSC on DBAu1550 board (also fixing Au1550 PSC3 address) and all Au1200-based boards as well. Make the OSS driver use the correct PSC definitions fo each board. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2005-11-17[MIPS] Add missing arch defines for the Alchemy MTD driver.Ralf Baechle
2005-10-29Updated pcmcia driver with pb1200 and db1200 support.Pete Popov
Updated db1200_defconfig so pcmcia is enabled by default. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Base Au1200 2.6 support.Pete Popov
2005-09-05[PATCH] mips: nuke trailing whitespaceRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
