path: root/include/asm-mips/mipsregs.h
2006-11-30[MIPS] Remove unused R10000 performance counter definitions.Ralf Baechle
2006-07-13[MIPS] vr41xx: Replace magic number for P4K bit with symbol.Yoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-13[MIPS] TRACE_IRQFLAGS_SUPPORT support.Ralf Baechle
2006-07-13[MIPS] VR41xx: Set VR41_CONF_BP only for PrId 0x0c80.Yoichi Yuasa
2006-06-29[MIPS] Fix use of ehb instruction for non-R2 configurations.Ralf Baechle
2006-06-20Merge git://git.infradead.org/hdrcleanup-2.6Linus Torvalds
* git://git.infradead.org/hdrcleanup-2.6: (63 commits) [S390] __FD_foo definitions. Switch to __s32 types in joystick.h instead of C99 types for consistency. Add <sys/types.h> to headers included for userspace in <linux/input.h> Move inclusion of <linux/compat.h> out of user scope in asm-x86_64/mtrr.h Remove struct fddi_statistics from user view in <linux/if_fddi.h> Move user-visible parts of drivers/s390/crypto/z90crypt.h to include/asm-s390 Revert include/media changes: Mauro says those ioctls are only used in-kernel(!) Include <linux/types.h> and use __uXX types in <linux/cramfs_fs.h> Use __uXX types in <linux/i2o_dev.h>, include <linux/ioctl.h> too Remove private struct dx_hash_info from public view in <linux/ext3_fs.h> Include <linux/types.h> and use __uXX types in <linux/affs_hardblocks.h> Use __uXX types in <linux/divert.h> for struct divert_blk et al. Use __u32 for elf_addr_t in <asm-powerpc/elf.h>, not u32. It's user-visible. Remove PPP_FCS from user view in <linux/ppp_defs.h>, remove __P mess entirely Use __uXX types in user-visible structures in <linux/nbd.h> Don't use 'u32' in user-visible struct ip_conntrack_old_tuple. Use __uXX types for S390 DASD volume label definitions which are user-visible S390 BIODASDREADCMB ioctl should use __u64 not u64 type. Remove unneeded inclusion of <linux/time.h> from <linux/ufs_fs.h> Fix private integer types used in V4L2 ioctls. ... Manually resolve conflict in include/linux/mtd/physmap.h
2006-06-19[MIPS] Cleanup __emt() a bit.Ralf Baechle
2006-06-01[MIPS] DSP and MDMX share the same config flag bit.Thiemo Seufer
Clarify comment. Signed-off-by: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-04-19[MIPS] MT: Improved multithreading support.Ralf Baechle
2006-04-19[MIPS] Provide access functions for c0_badvaddr.Ralf Baechle
2006-01-10MIPS: DSP: Put mask field into the right place.Ralf Baechle
2005-10-29Virtual SMP support for the 34K.Ralf Baechle
2005-10-29Fix parenthesis in macros.Ralf Baechle
2005-10-29Philips PNX8550 support: MIPS32-like core with 2 Trimedias on it.Pete Popov
2005-10-29Detect the MIPS R2 vectored interrupt, external interrupt controllerRalf Baechle
options and the precense of the MT ASE. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Macros to access the register of processors using the new MIPSRalf Baechle
Multithreading ASE, also know as MT ASE. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> diff --git a/include/asm-mips/mipsmtregs.h b/include/asm-mips/mipsmtregs.h new file mode 100644
2005-10-29A few more macros to access MIPS R2 architecture registers.Ralf Baechle
2005-10-29Get the thing to compile again ...Ralf Baechle
2005-10-29Use macros for the RM7k cp0.config bits instead of magic numbers.Maciej W. Rozycki
Minor clean-ups. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Remove dead code which was causing warnings.Ralf Baechle
2005-10-29Support the MIPS32 / MIPS64 DSP ASE.Ralf Baechle
2005-10-29Cleanup decoding of MIPSxx config registers.Ralf Baechle
2005-10-29Better interface to run uncached cache setup code.Thiemo Seufer
2005-10-29Provide functions to access cop0 config4-7 registersRalf Baechle
