path: root/include/asm-mips/pgtable-bits.h
2008-10-11MIPS: Move headfiles to new location below arch/mips/includeRalf Baechle
2008-06-16[MIPS] Fix build for PNX platforms.Ralf Baechle
Build error was caused by commit 351336929ccf222ae38ff0cb7a8dd5fd5c6236a0. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Allow setting of the cache attribute at run time.Chris Dearman
Slightly tacky, but there is a precedent in the sparc archirecture code. Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Tidy up cache attributesChris Dearman
Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] All MIPS32 processors support64-bit physical addresses.Chris Dearman
Still, only the 4K may actually implement it. Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2005-10-29Rename CONFIG_CPU_MIPS{32,64} to CONFIG_CPU_MIPS{32|64}_R1.Ralf Baechle
